[GRASS-SVN] r36459 - grass/branches/develbranch_6/locale/po
Mon Mar 23 10:50:53 EDT 2009
Author: neteler
Date: 2009-03-23 10:50:52 -0400 (Mon, 23 Mar 2009)
New Revision: 36459
   grass/branches/develbranch_6/locale/po/grassmods_cs.po
   grass/branches/develbranch_6/locale/po/grassmods_es.po
less foggy msg
Modified: grass/branches/develbranch_6/locale/po/grassmods_cs.po
--- grass/branches/develbranch_6/locale/po/grassmods_cs.po	2009-03-23 14:32:11 UTC (rev 36458)
+++ grass/branches/develbranch_6/locale/po/grassmods_cs.po	2009-03-23 14:50:52 UTC (rev 36459)
@@ -27272,7 +27272,7 @@
 #: ../vector/lidar/v.surf.bspline/main.c:236
 #, c-format
 msgid ""
-"No vector map of sparse points to interpolate. Interpolation will be done "
+"No vector map of sparse points to interpolate was specified. Interpolation will be done "
 "with <%s> vector map"
 msgstr ""
 "®ádná vektorová mapa pro interpolaci. Interpolace bude aplikována na "
Modified: grass/branches/develbranch_6/locale/po/grassmods_es.po
--- grass/branches/develbranch_6/locale/po/grassmods_es.po	2009-03-23 14:32:11 UTC (rev 36458)
+++ grass/branches/develbranch_6/locale/po/grassmods_es.po	2009-03-23 14:50:52 UTC (rev 36459)
@@ -16910,7 +16910,7 @@
 #, fuzzy, c-format
 msgid ""
 msgstr ""
 "Ningún mapa vectorial a interpolar. La interpolación se hará con el mapa "
