[GRASS-SVN] r36462 - in grass/trunk: locale/po vector/lidar/v.surf.bspline
Mon Mar 23 10:54:29 EDT 2009
Author: neteler
Date: 2009-03-23 10:54:29 -0400 (Mon, 23 Mar 2009)
New Revision: 36462
   grass/trunk/locale/po/grassmods_cs.po
   grass/trunk/locale/po/grassmods_fr.po
   grass/trunk/vector/lidar/v.surf.bspline/main.c
less foggy msg
Modified: grass/trunk/locale/po/grassmods_cs.po
--- grass/trunk/locale/po/grassmods_cs.po	2009-03-23 14:53:20 UTC (rev 36461)
+++ grass/trunk/locale/po/grassmods_cs.po	2009-03-23 14:54:29 UTC (rev 36462)
@@ -25609,7 +25609,7 @@
 #: ../vector/lidar/v.surf.bspline/main.c:238
 #, c-format
 msgid ""
-"No vector map of sparse points to interpolate. Interpolation will be done "
+"No vector map of sparse points to interpolate was specified. Interpolation will be done "
 "with <%s> vector map"
 msgstr ""
 "®ádná vektorová mapa pro interpolaci. Interpolace bude aplikována na "
Modified: grass/trunk/locale/po/grassmods_fr.po
--- grass/trunk/locale/po/grassmods_fr.po	2009-03-23 14:53:20 UTC (rev 36461)
+++ grass/trunk/locale/po/grassmods_fr.po	2009-03-23 14:54:29 UTC (rev 36462)
@@ -12637,7 +12637,7 @@
 #, c-format
 msgid ""
 msgstr ""
Modified: grass/trunk/vector/lidar/v.surf.bspline/main.c
--- grass/trunk/vector/lidar/v.surf.bspline/main.c	2009-03-23 14:53:20 UTC (rev 36461)
+++ grass/trunk/vector/lidar/v.surf.bspline/main.c	2009-03-23 14:54:29 UTC (rev 36462)
@@ -235,7 +235,7 @@
     /* Open input ext vector */
     if (!in_ext_opt->answer) {
 	ext = FALSE;
-	G_message(_("No vector map of sparse points to interpolate. "
+	G_message(_("No vector map of sparse points to interpolate was specified. "
 		    "Interpolation will be done with <%s> vector map"),
 		  in_opt->answer);
