[GRASS-SVN] r36477 - grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline
Wed Mar 25 03:16:16 EDT 2009
Author: neteler
Date: 2009-03-25 03:16:16 -0400 (Wed, 25 Mar 2009)
New Revision: 36477
   grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/description.html
sync to 6.5
Modified: grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/description.html
--- grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/description.html	2009-03-25 07:14:37 UTC (rev 36476)
+++ grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/description.html	2009-03-25 07:16:16 UTC (rev 36477)
@@ -1,79 +1,91 @@
 <h2>DESCRIPTION</h2>
-<em>v.surf.bspline</em> makes a bilinear/bicubic spline interpolation
-with Tykhonov regularization. The required input is an only 3d points
-vector map that will be used to interpolate a reference surface.
-<br>
-<br>
-Interpolation is carried out by adjusting a Least-Squares (LS) system
-in which the parameters to estime are spline functions. The number of
-splines doesn't depend on the resolution region, but it depends on the
-spline steps values in the north-south and west-east directions. These
-spline steps are set by "<b><i>sin=</i></b>" and "<b><i>sie=</i></b>",
-respectively. If the number of splines is bigger than the number of
-points, the LS system is bad conditioned because there are more unkowns
-than observations. In that case the LS normal matrix can't be inverted.
-To allow the inversion of the normal matrix a Tykhonov regularization
-is done. The minimizing function is the gradient in the case of a bilinear
-interpolation, and the curvature in the bicubic interpolation. The
-lambda_i parameter associated with the regularization smooths the
-interpolation. The higher the lambda_i parameter, the smoother the
+<em>v.surf.bspline</em> performs a bilinear/bicubic spline interpolation with
+Tykhonov regularization. The input is a 2D or 3D vector points map. Values to
+interpolate can be the z values of 3D points or the values in a user-specified
+attribue column in a 2D or 3D map. Output can be a raster or vector map.
+Optionally, a "sparse point" vector map can be input specify vector points
+output.
+<br> <br>
+From a theoretical perspective, the interpolating procedure takes place in two
+parts: the first is an estimate of the linear coefficients of a spline function
+is derived from the observation points using a least squares regression; the
+second is the computation of the interpolated surface (or interpolated vector
+points). As used here, the splines are 2D piece-wise non-zero polynomial
+functions calculated within a limited, 2D area. The length of each spline step
+is defined by <b><i>sie</i></b> for the east-west direction and
+<b><i>sin</i></b> for the north-south direction. For optimum performance, the
+length of spline step should be no less than the distance between observation
+points. Each vector point observation is modeled as a linear function of the
+non-zero splines in the area around the observation. The least squares
+regression predicts the the coefficients of these linear functions.
+Regularization, avoids the need to have one one observation and one coefficient
+for each spline (in order to avoid instability).
+<p>
+With regularly distributed data points, a spline step corresponding to the
+maximum distance between two points in both the east and north directions is
+sufficient. But often data points are not regularly distributed and require
+statistial regularization or estimation. In such cases, v.surf.bspline will
+attempt to minimize the gradient of bilinear splines or the curvature of bicubic
+splines in areas lacking point observations. As a general rule, spline step
+length should be greater than the mean distance between observation points
+(twice the distance between points is a good starting point). Separate east-west
+and north-south spline step length arguments allows the user to account for some
+degree of anisotropy in the distribution of observation points. Short spline
+step lengths--especially spline step lengths that are less than the distance
+between observation points--can greatly increase processing time.
+<p>
+Moreover, the maximum number of splines for each direction at each time is
+fixed, regardless of the spline step length. As the total number of splines used
+increases (i.e., with small spline step lengths), the region is automatically
+into subregions for interpolation. Each subregion can contain no more than
+150x150 splines. To avoid subregion boundary problems, subregions are created to
+partially overlap each other. A weighted mean of observations, based on point
+locations, is calculated within each subregion.
+<p>
+The Tykhonov regularization parameter ("<b><i>lambda_i</i></b>") acts to smooth
+the interpolation. With a small <b><i>lambda_i</i></b>, the interpolated surface
+closely follows observation points; a larger value will produce a smoother
 interpolation.
-<br>
-<br>
-The number of splines has a great influence on two things, mainly. The
-first thing is the module's execution time. The second is the RAM use.
-The higher the number of splines, the longer the time of execution and
-the higher RAM use. A numerical example: 100 splines in each direction
-imply 10e4 splines in total, that is, a square LS normal matrix of 10e4
-size. Inverting this matrix means inverting 100 millions elements!
-To improve this problems a Tcholebsky method with triangulars matrixes
-is used in the normal matrix inversion. It has also fixed a maximum number
-of splines for each direction. However, it is also possible running the
-module with a higher number of splines. For a number of spline higher than
-the fixed maximum, the whole region is divided into smaller regions. Each
-subregion is 150x150 splines wide. To avoid contour problems, the subregions
-are overlaped one to each other. To estimate a single value within the
-overlaped zones, a weighted mean considering the point positions into each
-subregion is carried out.
-<br>
-<br>
-The required input is a 3d points vector. If nothing is specified z-coordinates
-will be used in the interpolation. It could be also possible to consider
-an attribute value by specifying "<b><i>layer=</i></b>" and "<b><i>column=</i></b>"
-parameters. If a vector map with another type of features is used, only
-points will be considered. If the "<b><i>sparse=</i></b>" vector is
-used, the "<b><i>input=</i></b>" vector map will be used to create a
-reference surface. This surface will be used to make an estimation on the
-points within the "<b><i>sparse=</i></b>". In this case a vector output
-("<b><i>output=</i></b>") must be specify. If the "<b><i>sparse=</i></b>"
-is not supplied, the final interpolation output will be the interpolated
-reference surface from the "<b><i>input=</i></b>" vector map. In this case,
-one of both the raster or vector output format can be choosen. For raster
-format ("<b><i>raster=</i></b>"), the point estimation will be done
-on a regular grid with a resolution equal to the GRASS region. For vector
-format, the estimation will be done on the sparse points of the
-"<b><i>input=</i></b>" vector supplied. Both, vector and raster output,
-are not allowed simultaneously.
-<br>
-<br>
-A cross validation method has been implemented. It helps to find the optimal
-lambda_i value that fits the data. It shows the <i>mean</i> and <i>rms</i>
-of the residuals from the true point value and the estimated from the
-interpolation made with all the data without the point itself. This procedure
-is done for fixed lambda_i values. The results of the cross validation will
-appear in the stdout and no vector nor raster output will be created. The
-external input ("<b><i>sparse=</i></b>") will be not considered. Due to
-the nature of the algorithm, it is advised the user no to try the cross-
-validation with more than 100 points at a time because it will take too long.
-The execution time could be reduced by considering a lower number of splines.
-Although, as seen, it is possible to use a high number of splines, more than
-150x150 splines is not recommended.
-<br>
-<br>
-In a raster map output ("<b><i>raster=</i></b>"), region resolution implying
-more than 2000x2000 (4 mill) cells are not allowed. If the user tries with a
-more than those cells an error message will ask for a lower region resolution.
+<p>
+The input can be a 2D pr 3D vector points map. If "<b><i>layer =</i></b>" 0 the
+z-value of a 3D map is used for interpolation. If layer > 0, the user must
+specify an attribute column to used for interpolation using the
+"<b><i>column=</i></b>" argument (2D or 3D map).
+<p>
+v.surf.bspline can produce a raster OR a vector output (NOT simultaneously).
+However, a vector output cannot be obtained using the default GRASS DBF driver.
+<p>
+If output is a vector points map and a "<b><i>sparse=</i></b>" vector points map
+is not specified, the output vector map will contain points at the same
+locations as observation points in the input map, but the values of the output
+points are interpolated values. If a "<b><i>sparse=</i></b>" vector points map
+is specified, the output vector map will contain points at the same locations as
+the sparse vector map points, and values will be those of the interpolated
+raster surface at those points.
+<p>
+A cross validation "leave-one-out" analysis is available to help to determine
+the optimal <b><i>lambda_i</i></b> value that produces an interpolation that
+best fits the original observation data. The more points used for
+cross-validation, the longer the time needed for computation. Empirical testing
+indicates a threshold of a maximum of 100 points is recommended. The
+cross-validation output reports <i>mean</i> and <i>rms</i> of the residuals from
+the true point value and the estimated from the interpolation for a fixed series
+of <b><i>lambda_i</i></b> values. No vector nor raster output will be created
+when cross-validation is selected.
+<p>
+A raster output map ("<b><i>raster=</i></b>") of more than 2000x2000 (4 mill)
+cells is not allowed. If an output map would exceed this size, an error message
+is generated.
 <h2>EXAMPLES</h2>
 <h4>Basic interpolation</h4>
@@ -82,85 +94,90 @@
 v.surf.bspline input=point_vector output=interpolate_surface type=bicubic
 </pre></div>
-In this case, a bicubic spline interpolation will be done and an
-estimation on the points of point_vector will be the output.
+A bicubic spline interpolation will be done and a vector points map with estimated
+(i.e., interpolated) values will be created.
-<h4>Basic interpolation and raster output with a long spline step</h4>
+<h4>Basic interpolation and raster output with a longer spline step</h4>
 <div class="code"><pre>
 v.surf.bspline input=point_vector raster=interpolate_surface sie=25 sin=25
 </pre></div>
-Now, a bilinear spline interpolation will be done on a grid. The spline steps
-are set to 25. It doesn't mean that the grid will have a resolution equal to 25,
-but that each 25 units there will be a spline.
+A bilinear spline interpolation will be done with a spline step length of 25 map
+units. An interpolated raster map will be created at the current region resolution.
-<h4> Estimation of lambda_i parameter with a cross validation proccess</h4>
+<h4>Estimation of <b><i>lambda_i</i></b> parameter with a cross validation proccess</h4>
 v.surf.bspline -c input=point_vector
 </pre></div>
 <h4>Estimation on sparse points</h4>
 v.surf.bspline input=point_vector sparse=sparse_points output=interpolate_surface
 </pre></div>
-In this last case, an estimation on the points of the sparse_points vector
-will be done. The reference surface used for this estimation will be that
-interpolated using the point_vector vector.
+An output map of vector points will be created, corresponding to the sparse vector map, with interpolated values.
 <h4>Using attribute values instead Z-coordinates</h4>
 v.surf.bspline input=point_vector raster=interpolate_surface layer=1 column=attrib_column
 </pre></div>
-This last case, the module uses the attribute values in attrib_column
-in the table associated to layer 1.
+The interpolation will be done using the values in attrib_column, in the
+table associated with layer 1.
 <h2>BUGS</h2>
 Known issues:
-<br>
-<br>
-In order to avoid RAM memory problems, an auxiliar table will be needed for
-recording some intermediate calculi. Since the "<b>GROUP BY</b>" SQL function is used,
-which is not supported by the "<b>dbf</b>" driver, this driver is not
-allowed with the vector map output "<b><i>output=</i></b>". There is no problem
-with the raster map output.
-<br>
-<br>
-At this time, using the external vector input ("<b><i>sparse=</i></b>") implies
-interpoling with Z-coordinates. Updates to allow using attribute values
-will be done in a near future (I hope).
-<br>
-<br>
+<p>
+In order to avoid RAM memory problems, an auxiliary table is needed for
+recording some intermediate calculations. This requires the "<b>GROUP BY</b>"
+SQL function is used, which is not supported by the "<b>dbf</b>" driver. For
+this reason, vector map output "<b><i>output=</i></b>" is not permitted with the
+DBF driver. There are no problems with the raster map output from the DBF
+driver.
+<p>
+At this time, sparse vector input ("<b><i>sparse=</i></b>") can only be used
+with interpolation from 3D vector z-coordinates (<a href="http://trac.osgeo.org/grass/ticket/96">trac #96</a>).
+<p>
 <h2>SEE ALSO</h2>
-<em><a HREF="v.surf.rst.html">v.surf.rst</a></em>
+<em><a
+href="http://grass.osgeo.org/grass64/manuals/html64_user/v.surf.idw.html">v.surf.idw</a>,
+<a
+href="http://grass.osgeo.org/grass64/manuals/html64_user/v.surf.rst.html">v.surf.rst</a></em>
 <h2>AUTHORS</h2>
 Original version in GRASS 5.4: (s.bspline.reg)
-<BR>
+<br>
 Maria Antonia Brovelli, Massimiliano Cannata, Ulisse Longoni, Mirko Reguzzoni
-<BR><BR>
+<p>
 Update for GRASS 6.X and improvements:
-<BR>
+<br>
 Roberto Antolin
 <h2>REFERENCES</h2>
-Brovelli M. A., Cannata M., and Longoni U.M., 2004, LIDAR Data Filtering and DTM Interpolation Within GRASS, Transactions in GIS, April 2004, vol. 8, iss. 2, pp. 155-174(20), Blackwell Publishing Ltd
-<br>
-<br>
-Brovelli M. A. and Cannata M., 2004, Digital Terrain model reconstruction  in urban areas from airborne laser scanning data: the method and an  example for Pavia (Northern Italy). Computers and Geosciences 30, pp.325-331
-<br>
-<br>
-Brovelli M. A e Longoni U.M., 2003, Software per il filtraggio di dati LIDAR, Rivista dell'Agenzia del Territorio, n. 3-2003, pp. 11-22 (ISSN 1593-2192)
-<br>
-<br>
-Brovelli M. A., Cannata M. and Longoni U.M., 2002, DTM LIDAR in  area urbana, Bollettino SIFET N.2, 2002, pp. 7-26
-<br>
+Brovelli M. A., Cannata M., and Longoni U.M., 2004, LIDAR Data
+Filtering and DTM Interpolation Within GRASS, Transactions in GIS,
+April 2004, vol. 8, iss. 2, pp. 155-174(20), Blackwell Publishing Ltd
+<p>
+Brovelli M. A. and Cannata M., 2004, Digital Terrain model
+reconstruction in urban areas from airborne laser scanning data: the
+method and an example for Pavia (Northern Italy). Computers and
+Geosciences 30, pp.325-331
+<p>
+Brovelli M. A e Longoni U.M., 2003, Software per il filtraggio di
+dati LIDAR, Rivista dell'Agenzia del Territorio, n. 3-2003, pp. 11-22
+(ISSN 1593-2192)
+<p>
+Antolin R. and Brovelli M.A., 2007, LiDAR data Filtering with GRASS GIS for the
+Determination of Digital Terrain Models. Proceedings of Jornadas de SIG Libre,
+Girona, Espa&ntilde;a. CD ISBN: 978-84-690-3886-9 <br>
 <p><i>Last changed: $Date$</i>
