[GRASS-SVN] r36512 - in grass/trunk: . include include/Make lib/vector/Vlib vector/v.select
Sun Mar 29 09:53:04 EDT 2009
Author: martinl
Date: 2009-03-29 09:53:03 -0400 (Sun, 29 Mar 2009)
New Revision: 36512
Added:
   grass/trunk/lib/vector/Vlib/geos.c
   grass/trunk/vector/v.select/geos.c
   grass/trunk/vector/v.select/overlap.c
   grass/trunk/vector/v.select/proto.h
   grass/trunk/configure
   grass/trunk/configure.in
   grass/trunk/include/Make/Grass.make
   grass/trunk/include/Make/Platform.make.in
   grass/trunk/include/Vect.h
   grass/trunk/include/config.h.in
   grass/trunk/lib/vector/Vlib/buffer2.c
   grass/trunk/lib/vector/Vlib/dgraph.c
   grass/trunk/lib/vector/Vlib/e_intersect.c
   grass/trunk/vector/v.select/main.c
very basic support for GEOS
v.select updated to used optionally GEOS operators
Modified: grass/trunk/configure
--- grass/trunk/configure	2009-03-29 13:12:13 UTC (rev 36511)
+++ grass/trunk/configure	2009-03-29 13:53:03 UTC (rev 36512)
@@ -74,6 +74,9 @@
   --with-gdal[=path/gdal-config] enable GDAL/OGR support (gdal-config with path, \
 e.g. '--with-gdal=/usr/local/bin/gdal-config')"
 ac_help="$ac_help
+  --with-geos[=path/geos-config] enable GEOS support (geos-config with path, \
+e.g. '--with-geos=/usr/local/bin/geos-config')"
+ac_help="$ac_help
   --with-includes=DIRS    site include files are in DIRS"
 ac_help="$ac_help
   --with-libs=DIRS        site library files are in DIRS"
@@ -731,7 +734,7 @@
 fi
 echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:735: checking host system type" >&5
+echo "configure:738: checking host system type" >&5
 host_alias=$host
 case "$host_alias" in
@@ -754,7 +757,7 @@
 # Extract the first word of "gcc", so it can be a program name with args.
 set dummy gcc; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:758: checking for $ac_word" >&5
+echo "configure:761: checking for $ac_word" >&5
 if test -n "$CC"; then
   ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -781,7 +784,7 @@
   # Extract the first word of "cc", so it can be a program name with args.
 set dummy cc; ac_word=$2
-echo "configure:785: checking for $ac_word" >&5
+echo "configure:788: checking for $ac_word" >&5
@@ -829,7 +832,7 @@
       # Extract the first word of "cl", so it can be a program name with args.
 set dummy cl; ac_word=$2
-echo "configure:833: checking for $ac_word" >&5
+echo "configure:836: checking for $ac_word" >&5
@@ -858,7 +861,7 @@
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:862: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:865: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
 ac_ext=c
 # CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -869,12 +872,12 @@
 cat > conftest.$ac_ext << EOF
-#line 873 "configure"
+#line 876 "configure"
 #include "confdefs.h"
 main(){return(0);}
 EOF
-if { (eval echo configure:878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:881: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cc_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -900,19 +903,19 @@
   { echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:904: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:907: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
 cross_compiling=$ac_cv_prog_cc_cross
 echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:909: checking whether we are using GNU C" >&5
+echo "configure:912: checking whether we are using GNU C" >&5
 cat > conftest.c <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:916: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:919: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gcc=yes
 else
   ac_cv_prog_gcc=no
@@ -930,7 +933,7 @@
 ac_save_CFLAGS="$CFLAGS"
 CFLAGS=
 echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:934: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:937: checking whether ${CC-cc} accepts -g" >&5
 echo 'void f(){}' > conftest.c
 if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -959,10 +962,10 @@
 fi
 echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:963: checking for Cygwin environment" >&5
+echo "configure:966: checking for Cygwin environment" >&5
 cat > conftest.$ac_ext <<EOF
-#line 966 "configure"
+#line 969 "configure"
 int main() {
@@ -973,7 +976,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:977: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:980: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -989,17 +992,17 @@
 CYGWIN=
 test "$ac_cv_cygwin" = yes && CYGWIN=yes
 echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:993: checking for mingw32 environment" >&5
+echo "configure:996: checking for mingw32 environment" >&5
-#line 996 "configure"
+#line 999 "configure"
 int main() {
 return __MINGW32__;
 ; return 0; }
 EOF
-if { (eval echo configure:1003: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1006: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_mingw32=yes
 else
@@ -1017,7 +1020,7 @@
 echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1021: checking for executable suffix" >&5
+echo "configure:1024: checking for executable suffix" >&5
 if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
   ac_cv_exeext=.exe
@@ -1036,23 +1039,23 @@
 IEEEFLAG=
 echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1040: checking for full floating-point support" >&5
+echo "configure:1043: checking for full floating-point support" >&5
 if test "$cross_compiling" = yes; then
      echo "$ac_t""unknown (cross-compiling)" 1>&6
 echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1045: checking whether "cc -mieee" works" >&5
+echo "configure:1048: checking whether "cc -mieee" works" >&5
 ac_save_cflags=${CFLAGS}
 CFLAGS="$CFLAGS -mieee"
-#line 1049 "configure"
+#line 1052 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:1056: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1059: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
      echo "$ac_t""yes" 1>&6
         IEEEFLAG="-mieee"
@@ -1068,7 +1071,7 @@
 else
-#line 1072 "configure"
+#line 1075 "configure"
 #include <float.h>
@@ -1082,7 +1085,7 @@
 EOF
-if { (eval echo configure:1086: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
@@ -1095,14 +1098,14 @@
   CFLAGS=-mieee
 echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1099: checking for full floating-point support with -mieee" >&5
+echo "configure:1102: checking for full floating-point support with -mieee" >&5
     { echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
 else
-#line 1106 "configure"
+#line 1109 "configure"
 #include <float.h>
@@ -1116,7 +1119,7 @@
 EOF
-if { (eval echo configure:1120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1123: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
     IEEEFLAG="-mieee"
@@ -1153,7 +1156,7 @@
 # Extract the first word of "pwd", so it can be a program name with args.
 set dummy pwd; ac_word=$2
-echo "configure:1157: checking for $ac_word" >&5
+echo "configure:1160: checking for $ac_word" >&5
 case "$pwd" in
@@ -1191,7 +1194,7 @@
 fi
 echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1195: checking for source directory" >&5
+echo "configure:1198: checking for source directory" >&5
 if test -z "$srcdir" ; then
   SRCDIR=`$pwd`
@@ -1202,7 +1205,7 @@
 echo "$ac_t"""$SRCDIR"" 1>&6
 echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1206: checking for build directory" >&5
+echo "configure:1209: checking for build directory" >&5
 DSTDIR=`$pwd`
 WINDSTDIR=`$winpwd`
@@ -1287,7 +1290,7 @@
 echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1291: checking for MacOSX App" >&5
+echo "configure:1294: checking for MacOSX App" >&5
 case "$enable_macosx_app" in
 	yes)	MACOSX_APP=1	;;
 	no)	MACOSX_APP=	;;
@@ -1310,7 +1313,7 @@
     echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1314: checking how to build libraries" >&5
+echo "configure:1317: checking how to build libraries" >&5
     # Check whether --enable-shared or --disable-shared was given.
 if test "${enable_shared+set}" = set; then
   enableval="$enable_shared"
@@ -1353,7 +1356,7 @@
 # Extract the first word of "ranlib", so it can be a program name with args.
 set dummy ranlib; ac_word=$2
-echo "configure:1357: checking for $ac_word" >&5
+echo "configure:1360: checking for $ac_word" >&5
 if test -n "$RANLIB"; then
   ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -1378,7 +1381,7 @@
 fi
 echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1382: checking how to run the C preprocessor" >&5
+echo "configure:1385: checking how to run the C preprocessor" >&5
 # On Suns, sometimes $CPP names a directory.
 if test -n "$CPP" && test -d "$CPP"; then
   CPP=
@@ -1391,13 +1394,13 @@
   # On the NeXT, cc -E runs the code through the compiler's parser,
   # not just through cpp.
-#line 1395 "configure"
+#line 1398 "configure"
 #include <assert.h>
 Syntax Error
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1401: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1404: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
@@ -1408,13 +1411,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -E -traditional-cpp"
-#line 1412 "configure"
+#line 1415 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1418: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1421: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1425,13 +1428,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -nologo -E"
-#line 1429 "configure"
+#line 1432 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1435: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1438: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1459,7 +1462,7 @@
     # Step 0.a: Enable 64 bit support?
     echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1463: checking if 64bit support is requested" >&5
+echo "configure:1466: checking if 64bit support is requested" >&5
     # Check whether --enable-64bit or --disable-64bit was given.
 if test "${enable_64bit+set}" = set; then
   enableval="$enable_64bit"
@@ -1479,7 +1482,7 @@
     # Step 0.b: Enable Solaris 64 bit VIS support?
     echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1483: checking if 64bit Sparc VIS support is requested" >&5
+echo "configure:1486: checking if 64bit Sparc VIS support is requested" >&5
     # Check whether --enable-64bit-vis or --disable-64bit-vis was given.
 if test "${enable_64bit_vis+set}" = set; then
   enableval="$enable_64bit_vis"
@@ -1503,7 +1506,7 @@
     # there are a few systems, like Next, where this doesn't work.
     echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1507: checking system version (for dynamic loading)" >&5
+echo "configure:1510: checking system version (for dynamic loading)" >&5
     if test -f /usr/lib/NextStep/software_version; then
 	system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
     else
@@ -1529,13 +1532,13 @@
     # Linux can use either -ldl or -ldld for dynamic loading.
     echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1533: checking for dlopen in -ldl" >&5
+echo "configure:1536: checking for dlopen in -ldl" >&5
 ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ldl  $LIBS"
-#line 1539 "configure"
+#line 1542 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -1546,7 +1549,7 @@
 dlopen()
 ; return 0; }
 EOF
-if { (eval echo configure:1550: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1553: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -1593,7 +1596,7 @@
     # Extract the first word of "ar", so it can be a program name with args.
 set dummy ar; ac_word=$2
-echo "configure:1597: checking for $ac_word" >&5
+echo "configure:1600: checking for $ac_word" >&5
 if test -n "$AR"; then
   ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -1722,13 +1725,13 @@
 	    # known GMT value.
 	    echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1726: checking for gettimeofday in -lbsd" >&5
+echo "configure:1729: checking for gettimeofday in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 1732 "configure"
+#line 1735 "configure"
@@ -1739,7 +1742,7 @@
 gettimeofday()
 ; return 0; }
 EOF
-if { (eval echo configure:1743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1780,13 +1783,13 @@
 	    # is always linked to, for compatibility.
 	    echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1784: checking for inet_ntoa in -lbind" >&5
+echo "configure:1787: checking for inet_ntoa in -lbind" >&5
 ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-lbind  $LIBS"
-#line 1790 "configure"
+#line 1793 "configure"
@@ -1797,7 +1800,7 @@
 inet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:1801: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1804: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1858,13 +1861,13 @@
 	    SHLIB_SUFFIX=".sl"
 	    echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1862: checking for shl_load in -ldld" >&5
+echo "configure:1865: checking for shl_load in -ldld" >&5
 ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
 LIBS="-ldld  $LIBS"
-#line 1868 "configure"
+#line 1871 "configure"
@@ -1875,7 +1878,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:1879: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1882: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1940,13 +1943,13 @@
 	HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
 	    SHLIB_SUFFIX=".sl"
-echo "configure:1944: checking for shl_load in -ldld" >&5
+echo "configure:1947: checking for shl_load in -ldld" >&5
 LIBS="-ldld  $LIBS"
-#line 1950 "configure"
+#line 1953 "configure"
@@ -1957,7 +1960,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:1961: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -2079,15 +2082,15 @@
 	    else
 		ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2083: checking for dld.h" >&5
+echo "configure:2086: checking for dld.h" >&5
-#line 2086 "configure"
+#line 2089 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2091: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2094: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2147,15 +2150,15 @@
 	    else
-echo "configure:2151: checking for dld.h" >&5
+echo "configure:2154: checking for dld.h" >&5
-#line 2154 "configure"
+#line 2157 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2159: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2162: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2252,9 +2255,9 @@
 	    CC_SEARCH_FLAGS=""
 	    LD_SEARCH_FLAGS=""
 	    echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2256: checking for ELF" >&5
+echo "configure:2259: checking for ELF" >&5
-#line 2258 "configure"
+#line 2261 "configure"
 #ifdef __ELF__
@@ -2284,15 +2287,15 @@
 	    # Not available on all versions:  check for include file.
 	    ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2288: checking for dlfcn.h" >&5
+echo "configure:2291: checking for dlfcn.h" >&5
-#line 2291 "configure"
+#line 2294 "configure"
 #include <dlfcn.h>
 EOF
-{ (eval echo configure:2296: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2299: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2316,9 +2319,9 @@
 		CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
 		LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2320: checking for ELF" >&5
+echo "configure:2323: checking for ELF" >&5
-#line 2322 "configure"
+#line 2325 "configure"
 #ifdef __ELF__
@@ -2642,17 +2645,17 @@
 	    # that don't grok the -Bexport option.  Test that it does.
 	    hold_ldflags=$LDFLAGS
 	    echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2646: checking for ld accepts -Bexport flag" >&5
+echo "configure:2649: checking for ld accepts -Bexport flag" >&5
 	    LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2649 "configure"
+#line 2652 "configure"
 int main() {
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:2656: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2659: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   found=yes
 else
@@ -3016,6 +3019,13 @@
 fi
+# Check whether --with-geos or --without-geos was given.
+if test "${with_geos+set}" = set; then
+  withval="$with_geos"
+fi
 # Check whether --with-includes or --without-includes was given.
 if test "${with_includes+set}" = set; then
   withval="$with_includes"
@@ -3420,7 +3430,7 @@
 # Done checking fortran
 echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3424: checking for additional include dirs" >&5
+echo "configure:3434: checking for additional include dirs" >&5
 case "$with_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3443,7 +3453,7 @@
 # With libs option
 echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3447: checking for additional library dirs" >&5
+echo "configure:3457: checking for additional library dirs" >&5
 case "$with_libs" in
 	{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3477,7 +3487,7 @@
 # SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
 # ./install, which can be erroneously created by make from ./install.sh.
 echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3481: checking for a BSD compatible install" >&5
+echo "configure:3491: checking for a BSD compatible install" >&5
 if test -z "$INSTALL"; then
   IFS="${IFS= 	}"; ac_save_IFS="$IFS"; IFS=":"
@@ -3530,7 +3540,7 @@
 # Extract the first word of "flex", so it can be a program name with args.
 set dummy flex; ac_word=$2
-echo "configure:3534: checking for $ac_word" >&5
+echo "configure:3544: checking for $ac_word" >&5
 if test -n "$LEX"; then
   ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3561,13 +3571,13 @@
   *) ac_lib=l ;;
   esac
   echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3565: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3575: checking for yywrap in -l$ac_lib" >&5
 ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
 LIBS="-l$ac_lib  $LIBS"
-#line 3571 "configure"
+#line 3581 "configure"
@@ -3578,7 +3588,7 @@
 yywrap()
 ; return 0; }
 EOF
-if { (eval echo configure:3582: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3603,7 +3613,7 @@
     # Extract the first word of "lex", so it can be a program name with args.
 set dummy lex; ac_word=$2
-echo "configure:3607: checking for $ac_word" >&5
+echo "configure:3617: checking for $ac_word" >&5
 case "$LEXPATH" in
@@ -3643,7 +3653,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:3647: checking for $ac_word" >&5
+echo "configure:3657: checking for $ac_word" >&5
 if test -n "$YACC"; then
   ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3674,7 +3684,7 @@
     # Extract the first word of "yacc", so it can be a program name with args.
 set dummy yacc; ac_word=$2
-echo "configure:3678: checking for $ac_word" >&5
+echo "configure:3688: checking for $ac_word" >&5
 case "$YACCPATH" in
@@ -3712,7 +3722,7 @@
-echo "configure:3716: checking for $ac_word" >&5
+echo "configure:3726: checking for $ac_word" >&5
@@ -3741,7 +3751,7 @@
-echo "configure:3745: checking for $ac_word" >&5
+echo "configure:3755: checking for $ac_word" >&5
@@ -3772,7 +3782,7 @@
-echo "configure:3776: checking for $ac_word" >&5
+echo "configure:3786: checking for $ac_word" >&5
 if test -n "$ENV"; then
   ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3801,7 +3811,7 @@
 # Extract the first word of "perl", so it can be a program name with args.
 set dummy perl; ac_word=$2
-echo "configure:3805: checking for $ac_word" >&5
+echo "configure:3815: checking for $ac_word" >&5
 case "$PERL" in
@@ -3832,10 +3842,10 @@
 fi
 echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:3836: checking for ANSI C header files" >&5
+echo "configure:3846: checking for ANSI C header files" >&5
-#line 3839 "configure"
+#line 3849 "configure"
 #include <stdlib.h>
 #include <stdarg.h>
@@ -3843,7 +3853,7 @@
 #include <float.h>
 EOF
-{ (eval echo configure:3847: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3857: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3860,7 +3870,7 @@
 if test $ac_cv_header_stdc = yes; then
   # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 3864 "configure"
+#line 3874 "configure"
 #include <string.h>
 EOF
@@ -3878,7 +3888,7 @@
   # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 3882 "configure"
+#line 3892 "configure"
 #include <stdlib.h>
 EOF
@@ -3899,7 +3909,7 @@
 else
-#line 3903 "configure"
+#line 3913 "configure"
 #include <ctype.h>
 #define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -3910,7 +3920,7 @@
 exit (0); }
 EOF
-if { (eval echo configure:3914: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3924: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
 else
@@ -3937,15 +3947,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:3941: checking for $ac_hdr" >&5
+echo "configure:3951: checking for $ac_hdr" >&5
-#line 3944 "configure"
+#line 3954 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3949: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3959: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3974,15 +3984,15 @@
 do
-echo "configure:3978: checking for $ac_hdr" >&5
+echo "configure:3988: checking for $ac_hdr" >&5
-#line 3981 "configure"
+#line 3991 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3986: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3996: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4011,15 +4021,15 @@
 do
-echo "configure:4015: checking for $ac_hdr" >&5
+echo "configure:4025: checking for $ac_hdr" >&5
-#line 4018 "configure"
+#line 4028 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4023: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4033: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4048,15 +4058,15 @@
 do
-echo "configure:4052: checking for $ac_hdr" >&5
+echo "configure:4062: checking for $ac_hdr" >&5
-#line 4055 "configure"
+#line 4065 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4060: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4070: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4085,15 +4095,15 @@
 do
-echo "configure:4089: checking for $ac_hdr" >&5
+echo "configure:4099: checking for $ac_hdr" >&5
-#line 4092 "configure"
+#line 4102 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4097: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4107: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4119,10 +4129,10 @@
 done
 echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4123: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4133: checking whether time.h and sys/time.h may both be included" >&5
-#line 4126 "configure"
+#line 4136 "configure"
 #include <sys/types.h>
 #include <sys/time.h>
@@ -4131,7 +4141,7 @@
 struct tm *tp;
 ; return 0; }
 EOF
-if { (eval echo configure:4135: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4145: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_header_time=yes
 else
@@ -4151,10 +4161,10 @@
 fi
 echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4155: checking for off_t" >&5
+echo "configure:4165: checking for off_t" >&5
-#line 4158 "configure"
+#line 4168 "configure"
 #if STDC_HEADERS
@@ -4181,10 +4191,10 @@
 fi
 echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4185: checking for uid_t in sys/types.h" >&5
+echo "configure:4195: checking for uid_t in sys/types.h" >&5
-#line 4188 "configure"
+#line 4198 "configure"
 EOF
@@ -4212,10 +4222,10 @@
 fi
 echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4216: checking return type of signal handlers" >&5
+echo "configure:4226: checking return type of signal handlers" >&5
-#line 4219 "configure"
+#line 4229 "configure"
 #include <signal.h>
@@ -4232,7 +4242,7 @@
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:4236: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4246: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_type_signal=void
 else
@@ -4250,10 +4260,10 @@
-echo "configure:4254: checking for Cygwin environment" >&5
+echo "configure:4264: checking for Cygwin environment" >&5
-#line 4257 "configure"
+#line 4267 "configure"
 int main() {
@@ -4264,7 +4274,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:4268: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4278: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -4282,10 +4292,10 @@
 for ac_func in ftime gethostname gettimeofday lseek nice time uname
 do
 echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4286: checking for $ac_func" >&5
+echo "configure:4296: checking for $ac_func" >&5
-#line 4289 "configure"
+#line 4299 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char $ac_func(); below.  */
@@ -4308,7 +4318,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4312: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4322: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_$ac_func=yes"
 else
@@ -4334,10 +4344,10 @@
 for ac_func in seteuid setpriority setreuid setruid
 do
-echo "configure:4338: checking for $ac_func" >&5
+echo "configure:4348: checking for $ac_func" >&5
-#line 4341 "configure"
+#line 4351 "configure"
@@ -4360,7 +4370,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4364: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4374: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4386,10 +4396,10 @@
 for ac_func in drand48
 do
-echo "configure:4390: checking for $ac_func" >&5
+echo "configure:4400: checking for $ac_func" >&5
-#line 4393 "configure"
+#line 4403 "configure"
@@ -4412,7 +4422,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4416: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4426: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4438,10 +4448,10 @@
 for ac_func in putenv setenv
 do
-echo "configure:4442: checking for $ac_func" >&5
+echo "configure:4452: checking for $ac_func" >&5
-#line 4445 "configure"
+#line 4455 "configure"
@@ -4464,7 +4474,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4468: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4478: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4490,10 +4500,10 @@
 for ac_func in nanosleep
 do
-echo "configure:4494: checking for $ac_func" >&5
+echo "configure:4504: checking for $ac_func" >&5
-#line 4497 "configure"
+#line 4507 "configure"
@@ -4516,7 +4526,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4530: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4541,13 +4551,13 @@
 if test "$cross_compiling" != "yes" ; then
 echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4545: checking whether setpgrp takes no argument" >&5
+echo "configure:4555: checking whether setpgrp takes no argument" >&5
   { echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
 else
-#line 4551 "configure"
+#line 4561 "configure"
 #ifdef HAVE_UNISTD_H
@@ -4567,7 +4577,7 @@
 EOF
-if { (eval echo configure:4571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4581: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
   ac_cv_func_setpgrp_void=no
 else
@@ -4595,16 +4605,16 @@
 fi
 echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4599: checking for long long int" >&5
+echo "configure:4609: checking for long long int" >&5
-#line 4601 "configure"
+#line 4611 "configure"
 int main() {
 long long int x;
 ; return 0; }
 EOF
-if { (eval echo configure:4608: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4618: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
@@ -4624,7 +4634,7 @@
 rm -f conftest*
 echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4628: checking for W11" >&5
+echo "configure:4638: checking for W11" >&5
 case "$enable_w11" in
 	yes|no)	echo "$ac_t"""$enable_w11"" 1>&6	;;
 	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
@@ -4652,7 +4662,7 @@
 # Uses ac_ vars as temps to allow command line to override cache and checks.
 # --without-x overrides everything else, but does not touch the cache.
 echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4656: checking for X" >&5
+echo "configure:4666: checking for X" >&5
 # Check whether --with-x or --without-x was given.
 if test "${with_x+set}" = set; then
@@ -4712,12 +4722,12 @@
   # First, try using that file with no special directory specified.
-#line 4716 "configure"
+#line 4726 "configure"
 #include <$x_direct_test_include>
 EOF
-{ (eval echo configure:4721: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4731: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4786,14 +4796,14 @@
   LIBS="-l$x_direct_test_library $LIBS"
-#line 4790 "configure"
+#line 4800 "configure"
 int main() {
 ${x_direct_test_function}()
 ; return 0; }
 EOF
-if { (eval echo configure:4797: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4807: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LIBS="$ac_save_LIBS"
 # We can link X programs with no special library path.
@@ -4898,17 +4908,17 @@
     case "`(uname -sr) 2>/dev/null`" in
     "SunOS 5"*)
       echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:4902: checking whether -R must be followed by a space" >&5
+echo "configure:4912: checking whether -R must be followed by a space" >&5
       ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 4905 "configure"
+#line 4915 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:4912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4922: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_nospace=yes
 else
@@ -4924,14 +4934,14 @@
       else
 	LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 4928 "configure"
+#line 4938 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:4935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4945: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_space=yes
 else
@@ -4963,13 +4973,13 @@
     # libraries were built with DECnet support.  And karl at cs.umb.edu says
     # the Alpha needs dnet_stub (dnet does not exist).
     echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:4967: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:4977: checking for dnet_ntoa in -ldnet" >&5
 ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet  $LIBS"
-#line 4973 "configure"
+#line 4983 "configure"
@@ -4980,7 +4990,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:4984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4994: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5001,13 +5011,13 @@
     if test $ac_cv_lib_dnet_dnet_ntoa = no; then
       echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:5005: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:5015: checking for dnet_ntoa in -ldnet_stub" >&5
 ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet_stub  $LIBS"
-#line 5011 "configure"
+#line 5021 "configure"
@@ -5018,7 +5028,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:5022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5032: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5046,10 +5056,10 @@
     # The nsl library prevents programs from opening the X display
     # on Irix 5.2, according to dickey at clark.net.
     echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:5050: checking for gethostbyname" >&5
+echo "configure:5060: checking for gethostbyname" >&5
-#line 5053 "configure"
+#line 5063 "configure"
     which can conflict with char gethostbyname(); below.  */
@@ -5072,7 +5082,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5076: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5086: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gethostbyname=yes"
 else
@@ -5092,13 +5102,13 @@
     if test $ac_cv_func_gethostbyname = no; then
       echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5096: checking for gethostbyname in -lnsl" >&5
+echo "configure:5106: checking for gethostbyname in -lnsl" >&5
 ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 5102 "configure"
+#line 5112 "configure"
@@ -5109,7 +5119,7 @@
 gethostbyname()
 ; return 0; }
 EOF
-if { (eval echo configure:5113: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5123: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5138,10 +5148,10 @@
     # -lsocket must be given before -lnsl if both are needed.
     # We assume that if connect needs -lnsl, so does gethostbyname.
     echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5142: checking for connect" >&5
+echo "configure:5152: checking for connect" >&5
-#line 5145 "configure"
+#line 5155 "configure"
     which can conflict with char connect(); below.  */
@@ -5164,7 +5174,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5168: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5178: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_connect=yes"
 else
@@ -5184,13 +5194,13 @@
     if test $ac_cv_func_connect = no; then
       echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5188: checking for connect in -lsocket" >&5
+echo "configure:5198: checking for connect in -lsocket" >&5
 ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
 LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5194 "configure"
+#line 5204 "configure"
@@ -5201,7 +5211,7 @@
 connect()
 ; return 0; }
 EOF
-if { (eval echo configure:5205: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5215: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5224,10 +5234,10 @@
     # gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
     echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5228: checking for remove" >&5
+echo "configure:5238: checking for remove" >&5
-#line 5231 "configure"
+#line 5241 "configure"
     which can conflict with char remove(); below.  */
@@ -5250,7 +5260,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5254: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5264: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_remove=yes"
 else
@@ -5270,13 +5280,13 @@
     if test $ac_cv_func_remove = no; then
       echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5274: checking for remove in -lposix" >&5
+echo "configure:5284: checking for remove in -lposix" >&5
 ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
 LIBS="-lposix  $LIBS"
-#line 5280 "configure"
+#line 5290 "configure"
@@ -5287,7 +5297,7 @@
 remove()
 ; return 0; }
 EOF
-if { (eval echo configure:5291: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5301: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5310,10 +5320,10 @@
     # BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
     echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5314: checking for shmat" >&5
+echo "configure:5324: checking for shmat" >&5
-#line 5317 "configure"
+#line 5327 "configure"
     which can conflict with char shmat(); below.  */
@@ -5336,7 +5346,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5340: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5350: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_shmat=yes"
 else
@@ -5356,13 +5366,13 @@
     if test $ac_cv_func_shmat = no; then
       echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5360: checking for shmat in -lipc" >&5
+echo "configure:5370: checking for shmat in -lipc" >&5
 ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
 LIBS="-lipc  $LIBS"
-#line 5366 "configure"
+#line 5376 "configure"
@@ -5373,7 +5383,7 @@
 shmat()
 ; return 0; }
 EOF
-if { (eval echo configure:5377: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5387: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5405,13 +5415,13 @@
   # libraries we check for below, so use a different variable.
   #  --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
   echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5409: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5419: checking for IceConnectionNumber in -lICE" >&5
 ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
 LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5415 "configure"
+#line 5425 "configure"
@@ -5422,7 +5432,7 @@
 IceConnectionNumber()
 ; return 0; }
 EOF
-if { (eval echo configure:5426: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5436: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5462,12 +5472,12 @@
 LIBS=""
 echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:5466: checking for library containing cuserid" >&5
+echo "configure:5476: checking for library containing cuserid" >&5
 ac_func_search_save_LIBS="$LIBS"
 ac_cv_search_cuserid="no"
-#line 5471 "configure"
+#line 5481 "configure"
@@ -5478,7 +5488,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:5482: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5492: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="none required"
 else
@@ -5489,7 +5499,7 @@
 test "$ac_cv_search_cuserid" = "no" && for i in compat; do
 LIBS="-l$i  $ac_func_search_save_LIBS"
-#line 5493 "configure"
+#line 5503 "configure"
@@ -5500,7 +5510,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:5504: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5514: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="-l$i"
 break
@@ -5526,10 +5536,10 @@
 # Note: -lxdr -liberty -lws2_32 is for MinGW
 echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:5530: checking for xdrmem_create" >&5
+echo "configure:5540: checking for xdrmem_create" >&5
-#line 5533 "configure"
+#line 5543 "configure"
     which can conflict with char xdrmem_create(); below.  */
@@ -5552,7 +5562,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5556: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5566: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_xdrmem_create=yes"
 else
@@ -5570,13 +5580,13 @@
   echo "$ac_t""no" 1>&6
 echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:5574: checking for xdrmem_create in -lsun" >&5
+echo "configure:5584: checking for xdrmem_create in -lsun" >&5
 ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lsun  $LIBS"
-#line 5580 "configure"
+#line 5590 "configure"
@@ -5587,7 +5597,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5591: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5601: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5606,13 +5616,13 @@
 echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:5610: checking for xdrmem_create in -lnsl" >&5
+echo "configure:5620: checking for xdrmem_create in -lnsl" >&5
 ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 5616 "configure"
+#line 5626 "configure"
@@ -5623,7 +5633,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5627: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5637: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5642,13 +5652,13 @@
 echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:5646: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:5656: checking for xdrmem_create in -lrpclib" >&5
 ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lrpclib  $LIBS"
-#line 5652 "configure"
+#line 5662 "configure"
@@ -5659,7 +5669,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5663: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5673: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5678,13 +5688,13 @@
 echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:5682: checking for xdrmem_create in -lxdr" >&5
+echo "configure:5692: checking for xdrmem_create in -lxdr" >&5
 ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lxdr -liberty -lws2_32  $LIBS"
-#line 5688 "configure"
+#line 5698 "configure"
@@ -5695,7 +5705,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5699: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5709: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5729,10 +5739,10 @@
 for ac_func in asprintf
 do
-echo "configure:5733: checking for $ac_func" >&5
+echo "configure:5743: checking for $ac_func" >&5
-#line 5736 "configure"
+#line 5746 "configure"
@@ -5755,7 +5765,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5759: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5782,10 +5792,10 @@
 # Test if mathlib needs -lm flag or is included with libc
 echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:5786: checking for atan" >&5
+echo "configure:5796: checking for atan" >&5
-#line 5789 "configure"
+#line 5799 "configure"
     which can conflict with char atan(); below.  */
@@ -5808,7 +5818,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5812: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_atan=yes"
 else
@@ -5826,13 +5836,13 @@
 echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:5830: checking for atan in -lm" >&5
+echo "configure:5840: checking for atan in -lm" >&5
 ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
 LIBS="-lm  $LIBS"
-#line 5836 "configure"
+#line 5846 "configure"
@@ -5843,7 +5853,7 @@
 atan()
 ; return 0; }
 EOF
-if { (eval echo configure:5847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5857: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5870,10 +5880,10 @@
 echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:5874: checking for dlsym" >&5
+echo "configure:5884: checking for dlsym" >&5
-#line 5877 "configure"
+#line 5887 "configure"
     which can conflict with char dlsym(); below.  */
@@ -5896,7 +5906,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dlsym=yes"
 else
@@ -5914,13 +5924,13 @@
 echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:5918: checking for dlsym in -ldl" >&5
+echo "configure:5928: checking for dlsym in -ldl" >&5
 ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
 LIBS="-ldl  $LIBS"
-#line 5924 "configure"
+#line 5934 "configure"
@@ -5931,7 +5941,7 @@
 dlsym()
 ; return 0; }
 EOF
-if { (eval echo configure:5935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5945: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5958,10 +5968,10 @@
 echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:5962: checking for iconv" >&5
+echo "configure:5972: checking for iconv" >&5
-#line 5965 "configure"
+#line 5975 "configure"
     which can conflict with char iconv(); below.  */
@@ -5984,7 +5994,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5988: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5998: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_iconv=yes"
 else
@@ -6002,13 +6012,13 @@
 echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6006: checking for iconv in -liconv" >&5
+echo "configure:6016: checking for iconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-liconv  $LIBS"
-#line 6012 "configure"
+#line 6022 "configure"
@@ -6019,7 +6029,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6023: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6038,13 +6048,13 @@
 echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6042: checking for iconv in -lgiconv" >&5
+echo "configure:6052: checking for iconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-lgiconv  $LIBS"
-#line 6048 "configure"
+#line 6058 "configure"
@@ -6055,7 +6065,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6059: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6069: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6074,10 +6084,10 @@
 echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6078: checking for libiconv" >&5
+echo "configure:6088: checking for libiconv" >&5
-#line 6081 "configure"
+#line 6091 "configure"
     which can conflict with char libiconv(); below.  */
@@ -6100,7 +6110,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6104: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6114: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_libiconv=yes"
 else
@@ -6118,13 +6128,13 @@
 echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6122: checking for libiconv in -liconv" >&5
+echo "configure:6132: checking for libiconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6128 "configure"
+#line 6138 "configure"
@@ -6135,7 +6145,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6149: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6154,13 +6164,13 @@
 echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6158: checking for libiconv in -lgiconv" >&5
+echo "configure:6168: checking for libiconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6164 "configure"
+#line 6174 "configure"
@@ -6171,7 +6181,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6185: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6208,10 +6218,10 @@
 have_socket=1
 echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6212: checking for socket" >&5
+echo "configure:6222: checking for socket" >&5
-#line 6215 "configure"
+#line 6225 "configure"
     which can conflict with char socket(); below.  */
@@ -6234,7 +6244,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6238: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6248: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_socket=yes"
 else
@@ -6252,13 +6262,13 @@
 echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6256: checking for socket in -lsocket" >&5
+echo "configure:6266: checking for socket in -lsocket" >&5
 ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
 LIBS="-lsocket  $LIBS"
-#line 6262 "configure"
+#line 6272 "configure"
@@ -6269,7 +6279,7 @@
 socket()
 ; return 0; }
 EOF
-if { (eval echo configure:6273: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6283: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6317,7 +6327,7 @@
 echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6321: checking for location of zlib includes" >&5
+echo "configure:6331: checking for location of zlib includes" >&5
 case "$with_zlib_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6343,15 +6353,15 @@
 do
-echo "configure:6347: checking for $ac_hdr" >&5
+echo "configure:6357: checking for $ac_hdr" >&5
-#line 6350 "configure"
+#line 6360 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6355: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6365: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6385,7 +6395,7 @@
 echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6389: checking for location of zlib library" >&5
+echo "configure:6399: checking for location of zlib library" >&5
 case "$with_zlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6410,13 +6420,13 @@
 echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6414: checking for deflate in -lz" >&5
+echo "configure:6424: checking for deflate in -lz" >&5
 ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
 LIBS="-lz  $LIBS"
-#line 6420 "configure"
+#line 6430 "configure"
@@ -6427,7 +6437,7 @@
 deflate()
 ; return 0; }
 EOF
-if { (eval echo configure:6431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6441: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6475,7 +6485,7 @@
 echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:6479: checking for location of External PROJ.4 includes" >&5
+echo "configure:6489: checking for location of External PROJ.4 includes" >&5
 case "$with_proj_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -6501,15 +6511,15 @@
 do
-echo "configure:6505: checking for $ac_hdr" >&5
+echo "configure:6515: checking for $ac_hdr" >&5
-#line 6508 "configure"
+#line 6518 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6513: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6523: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6546,7 +6556,7 @@
 else
 echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:6550: checking External PROJ.4 version" >&5
+echo "configure:6560: checking External PROJ.4 version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -6554,7 +6564,7 @@
 else
-#line 6558 "configure"
+#line 6568 "configure"
 #include <stdio.h>
@@ -6566,7 +6576,7 @@
 EOF
-if { (eval echo configure:6570: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:6580: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      proj_ver=`cat conftestdata`
         echo "$ac_t""$proj_ver" 1>&6
@@ -6591,7 +6601,7 @@
 echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:6595: checking for location of External PROJ.4 library" >&5
+echo "configure:6605: checking for location of External PROJ.4 library" >&5
 case "$with_proj_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -6616,13 +6626,13 @@
 echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:6620: checking for pj_get_def in -lproj" >&5
+echo "configure:6630: checking for pj_get_def in -lproj" >&5
 ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
 LIBS="-lproj  $LIBS"
-#line 6626 "configure"
+#line 6636 "configure"
@@ -6633,7 +6643,7 @@
 pj_get_def()
 ; return 0; }
 EOF
-if { (eval echo configure:6637: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6647: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6667,7 +6677,7 @@
 echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:6671: checking for location of External PROJ.4 data files" >&5
+echo "configure:6681: checking for location of External PROJ.4 data files" >&5
 case "$with_proj_share" in
         { echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -6691,14 +6701,14 @@
 # LOC_CHECK_SHARE does not work when cross compiling
 if test "$cross_compiling" = "yes" ; then
     echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:6695: checking for epsg" >&5
+echo "configure:6705: checking for epsg" >&5
 else
 ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:6702: checking for $PROJSHARE/epsg" >&5
+echo "configure:6712: checking for $PROJSHARE/epsg" >&5
     { echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -6730,7 +6740,7 @@
 # Extract the first word of "nad2bin", so it can be a program name with args.
 set dummy nad2bin; ac_word=$2
-echo "configure:6734: checking for $ac_word" >&5
+echo "configure:6744: checking for $ac_word" >&5
 case "$NAD2BIN" in
@@ -6770,7 +6780,7 @@
 echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:6774: checking whether to use regex" >&5
+echo "configure:6784: checking whether to use regex" >&5
 echo "$ac_t"""$with_regex"" 1>&6
 case "$with_regex" in
 	"no")	USE_REGEX=	;;
@@ -6790,7 +6800,7 @@
 echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:6794: checking for location of regex includes" >&5
+echo "configure:6804: checking for location of regex includes" >&5
 case "$with_regex_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -6816,15 +6826,15 @@
 do
-echo "configure:6820: checking for $ac_hdr" >&5
+echo "configure:6830: checking for $ac_hdr" >&5
-#line 6823 "configure"
+#line 6833 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6828: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6838: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6858,7 +6868,7 @@
 echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:6862: checking for location of regex library" >&5
+echo "configure:6872: checking for location of regex library" >&5
 case "$with_regex_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -6883,10 +6893,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:6887: checking for regcomp" >&5
+echo "configure:6897: checking for regcomp" >&5
-#line 6890 "configure"
+#line 6900 "configure"
     which can conflict with char regcomp(); below.  */
@@ -6909,7 +6919,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6913: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6923: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_regcomp=yes"
 else
@@ -6936,13 +6946,13 @@
 echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:6940: checking for regcomp in -lregex" >&5
+echo "configure:6950: checking for regcomp in -lregex" >&5
 ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
 LIBS="-lregex  $LIBS"
-#line 6946 "configure"
+#line 6956 "configure"
@@ -6953,7 +6963,7 @@
 regcomp()
 ; return 0; }
 EOF
-if { (eval echo configure:6957: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7003,7 +7013,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7007: checking whether to use Readline" >&5
+echo "configure:7017: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -7024,7 +7034,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7028: checking for location of Readline includes" >&5
+echo "configure:7038: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7050,15 +7060,15 @@
 do
-echo "configure:7054: checking for $ac_hdr" >&5
+echo "configure:7064: checking for $ac_hdr" >&5
-#line 7057 "configure"
+#line 7067 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7062: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7072: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7094,15 +7104,15 @@
 do
-echo "configure:7098: checking for $ac_hdr" >&5
+echo "configure:7108: checking for $ac_hdr" >&5
-#line 7101 "configure"
+#line 7111 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7106: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7116: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7136,7 +7146,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7140: checking for location of Readline library" >&5
+echo "configure:7150: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7161,13 +7171,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7165: checking for readline in -lreadline" >&5
+echo "configure:7175: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
-#line 7171 "configure"
+#line 7181 "configure"
@@ -7178,7 +7188,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:7182: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7192: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7213,13 +7223,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7217: checking for add_history in -lhistory" >&5
+echo "configure:7227: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 7223 "configure"
+#line 7233 "configure"
@@ -7230,7 +7240,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:7234: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7244: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7273,7 +7283,7 @@
 echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7277: checking whether to use JPEG" >&5
+echo "configure:7287: checking whether to use JPEG" >&5
 echo "$ac_t"""$with_jpeg"" 1>&6
 case "$with_jpeg" in
 	"no")	USE_JPEG=	;;
@@ -7293,7 +7303,7 @@
 echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7297: checking for location of JPEG includes" >&5
+echo "configure:7307: checking for location of JPEG includes" >&5
 case "$with_jpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -7319,15 +7329,15 @@
 do
-echo "configure:7323: checking for $ac_hdr" >&5
+echo "configure:7333: checking for $ac_hdr" >&5
-#line 7326 "configure"
+#line 7336 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7331: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7341: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7361,7 +7371,7 @@
 echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7365: checking for location of JPEG library" >&5
+echo "configure:7375: checking for location of JPEG library" >&5
 case "$with_jpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -7388,13 +7398,13 @@
 echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7392: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7402: checking for jpeg_start_compress in -ljpeg" >&5
 ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
 LIBS="-ljpeg  $LIBS"
-#line 7398 "configure"
+#line 7408 "configure"
@@ -7405,7 +7415,7 @@
 jpeg_start_compress()
 ; return 0; }
 EOF
-if { (eval echo configure:7409: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7419: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7424,13 +7434,13 @@
-echo "configure:7428: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7438: checking for jpeg_start_compress in -ljpeg" >&5
 LIBS="-ljpeg $ZLIB $LIBS"
-#line 7434 "configure"
+#line 7444 "configure"
@@ -7441,7 +7451,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7445: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7455: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7490,7 +7500,7 @@
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:7494: checking whether to use GDAL" >&5
+echo "configure:7504: checking whether to use GDAL" >&5
 GDAL_LIBS=
 GDAL_CFLAGS=
@@ -7508,7 +7518,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:7512: checking for $ac_word" >&5
+echo "configure:7522: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -7563,14 +7573,14 @@
   LIBS="$LIBS $GDAL_LIBS"
   CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 7567 "configure"
+#line 7577 "configure"
 #include <gdal.h>
 int main() {
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:7574: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7584: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
   echo "configure: failed program was:" >&5
@@ -7579,14 +7589,14 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 7583 "configure"
+#line 7593 "configure"
 #include <gdal.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:7590: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7600: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -7615,11 +7625,82 @@
+# GEOS option
+echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
+echo "configure:7632: checking whether to use GEOS" >&5
+GEOS_LIBS=
+GGEOS_CFLAGS=
+USE_GEOS=
+if test "`basename xx/$with_geos`" = "geos-config" ; then
+  GEOS_CONFIG="$with_geos"
+fi
+if test "$with_geos" = "no" ; then
+  echo "$ac_t""no" 1>&6
+else
+  echo "$ac_t""yes" 1>&6
+  # Extract the first word of "geos-config", so it can be a program name with args.
+set dummy geos-config; ac_word=$2
+echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
+echo "configure:7649: checking for $ac_word" >&5
+case "$GEOS_CONFIG" in
+  ac_cv_path_GEOS_CONFIG="$GEOS_CONFIG" # Let the user override the test with a path.
+  ac_cv_path_GEOS_CONFIG="$GEOS_CONFIG" # Let the user override the test with a dos path.
+  IFS="${IFS= 	}"; ac_save_ifs="$IFS"; IFS=":"
+  ac_dummy="$PATH"
+  for ac_dir in $ac_dummy; do
+    test -z "$ac_dir" && ac_dir=.
+    if test -f $ac_dir/$ac_word; then
+      ac_cv_path_GEOS_CONFIG="$ac_dir/$ac_word"
+      break
+    fi
+  done
+  IFS="$ac_save_ifs"
+  test -z "$ac_cv_path_GEOS_CONFIG" && ac_cv_path_GEOS_CONFIG="no"
+esac
+GEOS_CONFIG="$ac_cv_path_GEOS_CONFIG"
+if test -n "$GEOS_CONFIG"; then
+  echo "$ac_t""$GEOS_CONFIG" 1>&6
+else
+fi
+  if test "$GEOS_CONFIG" = "no" ; then
+    { echo "configure: error: *** couldn't find geos-config" 1>&2; exit 1; }
+  fi
+  if test "$GEOS_CONFIG" != "" ; then
+    GEOS_LIBS=`"$GEOS_CONFIG" --libs`
+    GEOS_CFLAGS=`"$GEOS_CONFIG" --cflags`
+    USE_GEOS=1
+  fi
+  cat >> confdefs.h <<\EOF
+#define HAVE_GEOS 1
+EOF
+fi
 # Enable TIFF option
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:7623: checking whether to use TIFF" >&5
+echo "configure:7704: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -7639,7 +7720,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:7643: checking for location of TIFF includes" >&5
+echo "configure:7724: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -7665,15 +7746,15 @@
 do
-echo "configure:7669: checking for $ac_hdr" >&5
+echo "configure:7750: checking for $ac_hdr" >&5
-#line 7672 "configure"
+#line 7753 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7677: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7758: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -7707,7 +7788,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7711: checking for location of TIFF library" >&5
+echo "configure:7792: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7738,13 +7819,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7742: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7823: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ltiff  $LIBS"
-#line 7748 "configure"
+#line 7829 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -7755,7 +7836,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7759: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7840: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -7774,13 +7855,13 @@
-echo "configure:7778: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7859: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 7784 "configure"
+#line 7865 "configure"
@@ -7791,7 +7872,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7795: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7876: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7810,13 +7891,13 @@
-echo "configure:7814: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7895: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 7820 "configure"
+#line 7901 "configure"
@@ -7827,7 +7908,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7831: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7846,13 +7927,13 @@
-echo "configure:7850: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7931: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 7856 "configure"
+#line 7937 "configure"
@@ -7863,7 +7944,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7948: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7882,13 +7963,13 @@
-echo "configure:7886: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7967: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 7892 "configure"
+#line 7973 "configure"
@@ -7899,7 +7980,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7903: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7918,13 +7999,13 @@
-echo "configure:7922: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8003: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 7928 "configure"
+#line 8009 "configure"
@@ -7935,7 +8016,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7939: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7954,13 +8035,13 @@
-echo "configure:7958: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8039: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 7964 "configure"
+#line 8045 "configure"
@@ -7971,7 +8052,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7975: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8056: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7990,13 +8071,13 @@
-echo "configure:7994: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8075: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8000 "configure"
+#line 8081 "configure"
@@ -8007,7 +8088,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8011: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8105,7 +8186,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8109: checking whether to use PNG" >&5
+echo "configure:8190: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -8124,7 +8205,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8128: checking for location of PNG includes" >&5
+echo "configure:8209: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8150,15 +8231,15 @@
 do
-echo "configure:8154: checking for $ac_hdr" >&5
+echo "configure:8235: checking for $ac_hdr" >&5
-#line 8157 "configure"
+#line 8238 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8162: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8243: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8192,7 +8273,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8196: checking for location of PNG library" >&5
+echo "configure:8277: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8217,13 +8298,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8221: checking for png_read_image in -lpng" >&5
+echo "configure:8302: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8227 "configure"
+#line 8308 "configure"
@@ -8234,7 +8315,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:8238: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8319: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8276,7 +8357,7 @@
 echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:8280: checking whether to use Tcl/Tk" >&5
+echo "configure:8361: checking whether to use Tcl/Tk" >&5
 echo "$ac_t"""$with_tcltk"" 1>&6
 case "$with_tcltk" in
 	"no")	USE_TCLTK=	;;
@@ -8296,7 +8377,7 @@
 echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:8300: checking for location of Tcl/Tk includes" >&5
+echo "configure:8381: checking for location of Tcl/Tk includes" >&5
 case "$with_tcltk_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -8322,15 +8403,15 @@
 do
-echo "configure:8326: checking for $ac_hdr" >&5
+echo "configure:8407: checking for $ac_hdr" >&5
-#line 8329 "configure"
+#line 8410 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8334: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8415: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8367,15 +8448,15 @@
 do
-echo "configure:8371: checking for $ac_hdr" >&5
+echo "configure:8452: checking for $ac_hdr" >&5
-#line 8374 "configure"
+#line 8455 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8379: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8460: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8409,7 +8490,7 @@
 echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:8413: checking Tcl version" >&5
+echo "configure:8494: checking Tcl version" >&5
 CPPFLAGS="$TCLINCDIR $CPPFLAGS"
 if test "$cross_compiling" = yes; then
@@ -8417,7 +8498,7 @@
     echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
-#line 8421 "configure"
+#line 8502 "configure"
 #include <stdio.h>
@@ -8429,7 +8510,7 @@
 EOF
-if { (eval echo configure:8433: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8514: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tcl_ver=`cat conftestdata`
     echo "$ac_t""$tcl_ver" 1>&6
@@ -8447,7 +8528,7 @@
 echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:8451: checking Tk version" >&5
+echo "configure:8532: checking Tk version" >&5
 CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -8455,7 +8536,7 @@
 else
-#line 8459 "configure"
+#line 8540 "configure"
 #include <stdio.h>
@@ -8467,7 +8548,7 @@
 EOF
-if { (eval echo configure:8471: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8552: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tk_ver=`cat conftestdata`
     echo "$ac_t""$tk_ver" 1>&6
@@ -8496,7 +8577,7 @@
 echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:8500: checking for location of Tcl/Tk library" >&5
+echo "configure:8581: checking for location of Tcl/Tk library" >&5
 case "$with_tcltk_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -8526,13 +8607,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:8530: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8611: checking for Tcl_Init in -ltcl" >&5
 ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl $MATHLIB $LIBS"
-#line 8536 "configure"
+#line 8617 "configure"
@@ -8543,7 +8624,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8628: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8562,13 +8643,13 @@
-echo "configure:8566: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8647: checking for Tcl_Init in -ltcl" >&5
 LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 8572 "configure"
+#line 8653 "configure"
@@ -8579,7 +8660,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8583: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8664: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8606,13 +8687,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8610: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8691: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 8616 "configure"
+#line 8697 "configure"
@@ -8623,7 +8704,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8627: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8708: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8642,13 +8723,13 @@
-echo "configure:8646: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8727: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 8652 "configure"
+#line 8733 "configure"
@@ -8659,7 +8740,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8663: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8744: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8686,13 +8767,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:8690: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8771: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 8696 "configure"
+#line 8777 "configure"
@@ -8703,7 +8784,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8788: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8722,13 +8803,13 @@
-echo "configure:8726: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8807: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 8732 "configure"
+#line 8813 "configure"
@@ -8739,7 +8820,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8824: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8817,13 +8898,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:8821: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:8902: checking for Tk_MainWindow in -ltk" >&5
 ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 8827 "configure"
+#line 8908 "configure"
@@ -8834,7 +8915,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:8838: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8919: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8853,13 +8934,13 @@
-echo "configure:8857: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:8938: checking for Tk_MainWindow in -ltk" >&5
 LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 8863 "configure"
+#line 8944 "configure"
@@ -8870,7 +8951,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:8874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8955: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8897,13 +8978,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8901: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:8982: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 8907 "configure"
+#line 8988 "configure"
@@ -8914,7 +8995,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:8918: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8933,13 +9014,13 @@
-echo "configure:8937: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9018: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 8943 "configure"
+#line 9024 "configure"
@@ -8950,7 +9031,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:8954: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9035: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8977,13 +9058,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:8981: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9062: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 8987 "configure"
+#line 9068 "configure"
@@ -8994,7 +9075,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:8998: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9079: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9013,13 +9094,13 @@
-echo "configure:9017: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9098: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9023 "configure"
+#line 9104 "configure"
@@ -9030,7 +9111,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9115: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9122,7 +9203,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:9126: checking whether to use PostgreSQL" >&5
+echo "configure:9207: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -9149,7 +9230,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9153: checking for location of PostgreSQL includes" >&5
+echo "configure:9234: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9175,15 +9256,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:9179: checking for $ac_hdr" >&5
+echo "configure:9260: checking for $ac_hdr" >&5
-#line 9182 "configure"
+#line 9263 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9187: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9268: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9221,7 +9302,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9225: checking for location of PostgreSQL library" >&5
+echo "configure:9306: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9250,13 +9331,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9254: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9335: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9260 "configure"
+#line 9341 "configure"
@@ -9267,7 +9348,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9271: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9352: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9286,13 +9367,13 @@
-echo "configure:9290: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9371: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9296 "configure"
+#line 9377 "configure"
@@ -9303,7 +9384,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9307: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9388: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9322,13 +9403,13 @@
-echo "configure:9326: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9407: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 9332 "configure"
+#line 9413 "configure"
@@ -9339,7 +9420,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9343: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9424: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9358,13 +9439,13 @@
-echo "configure:9362: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9443: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9368 "configure"
+#line 9449 "configure"
@@ -9375,7 +9456,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9460: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9432,13 +9513,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9436: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9517: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9442 "configure"
+#line 9523 "configure"
@@ -9449,7 +9530,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9453: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9534: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9471,13 +9552,13 @@
-echo "configure:9475: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9556: checking for PQcmdTuples in -lpq" >&5
-#line 9481 "configure"
+#line 9562 "configure"
@@ -9488,7 +9569,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9492: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9573: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9531,7 +9612,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9535: checking whether to use MySQL" >&5
+echo "configure:9616: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -9551,7 +9632,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9555: checking for location of MySQL includes" >&5
+echo "configure:9636: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9577,15 +9658,15 @@
 do
-echo "configure:9581: checking for $ac_hdr" >&5
+echo "configure:9662: checking for $ac_hdr" >&5
-#line 9584 "configure"
+#line 9665 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9589: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9670: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9622,7 +9703,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9626: checking for location of MySQL library" >&5
+echo "configure:9707: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9653,13 +9734,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9657: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9738: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 9663 "configure"
+#line 9744 "configure"
@@ -9670,7 +9751,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9674: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9755: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9689,13 +9770,13 @@
-echo "configure:9693: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9774: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9699 "configure"
+#line 9780 "configure"
@@ -9706,7 +9787,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9710: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9791: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9725,13 +9806,13 @@
-echo "configure:9729: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9810: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9735 "configure"
+#line 9816 "configure"
@@ -9742,7 +9823,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9827: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9761,13 +9842,13 @@
-echo "configure:9765: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9846: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9771 "configure"
+#line 9852 "configure"
@@ -9778,7 +9859,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9782: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9863: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9797,13 +9878,13 @@
-echo "configure:9801: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9882: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9807 "configure"
+#line 9888 "configure"
@@ -9814,7 +9895,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9818: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9899: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9833,13 +9914,13 @@
-echo "configure:9837: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9918: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9843 "configure"
+#line 9924 "configure"
@@ -9850,7 +9931,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9854: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9869,13 +9950,13 @@
-echo "configure:9873: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9954: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 9879 "configure"
+#line 9960 "configure"
@@ -9886,7 +9967,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9905,13 +9986,13 @@
-echo "configure:9909: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9990: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 9915 "configure"
+#line 9996 "configure"
@@ -9922,7 +10003,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10007: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10012,7 +10093,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
-echo "configure:10016: checking for $ac_word" >&5
+echo "configure:10097: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -10061,10 +10142,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:10065: checking for mysql_server_init" >&5
+echo "configure:10146: checking for mysql_server_init" >&5
-#line 10068 "configure"
+#line 10149 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -10090,7 +10171,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10094: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -10142,7 +10223,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:10146: checking whether to use SQLite" >&5
+echo "configure:10227: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -10162,7 +10243,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10166: checking for location of SQLite includes" >&5
+echo "configure:10247: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10188,15 +10269,15 @@
 do
-echo "configure:10192: checking for $ac_hdr" >&5
+echo "configure:10273: checking for $ac_hdr" >&5
-#line 10195 "configure"
+#line 10276 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10200: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10281: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10239,7 +10320,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10243: checking for location of SQLite library" >&5
+echo "configure:10324: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10266,13 +10347,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10270: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10351: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 10276 "configure"
+#line 10357 "configure"
@@ -10283,7 +10364,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10287: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10368: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10302,13 +10383,13 @@
-echo "configure:10306: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10387: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10312 "configure"
+#line 10393 "configure"
@@ -10319,7 +10400,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10372,7 +10453,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10376: checking whether to use FFMPEG" >&5
+echo "configure:10457: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -10392,7 +10473,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10396: checking for location of FFMPEG includes" >&5
+echo "configure:10477: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10418,15 +10499,15 @@
 do
-echo "configure:10422: checking for $ac_hdr" >&5
+echo "configure:10503: checking for $ac_hdr" >&5
-#line 10425 "configure"
+#line 10506 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10430: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10511: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10462,15 +10543,15 @@
 do
-echo "configure:10466: checking for $ac_hdr" >&5
+echo "configure:10547: checking for $ac_hdr" >&5
-#line 10469 "configure"
+#line 10550 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10474: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10555: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10506,15 +10587,15 @@
 do
-echo "configure:10510: checking for $ac_hdr" >&5
+echo "configure:10591: checking for $ac_hdr" >&5
-#line 10513 "configure"
+#line 10594 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10518: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10599: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10557,7 +10638,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10561: checking for location of FFMPEG library" >&5
+echo "configure:10642: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10584,13 +10665,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10588: checking for av_free in -lavutil" >&5
+echo "configure:10669: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 10594 "configure"
+#line 10675 "configure"
@@ -10601,7 +10682,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10605: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10686: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10620,13 +10701,13 @@
-echo "configure:10624: checking for av_free in -lavutil" >&5
+echo "configure:10705: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 10630 "configure"
+#line 10711 "configure"
@@ -10637,7 +10718,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10641: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10722: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10682,13 +10763,13 @@
 echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10686: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10767: checking for avcodec_init in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 10692 "configure"
+#line 10773 "configure"
@@ -10699,7 +10780,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10703: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10784: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10718,13 +10799,13 @@
-echo "configure:10722: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10803: checking for avcodec_init in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10728 "configure"
+#line 10809 "configure"
@@ -10735,7 +10816,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10739: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10820: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10780,13 +10861,13 @@
 echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10784: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10865: checking for av_set_parameters in -lavformat" >&5
 ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 10790 "configure"
+#line 10871 "configure"
@@ -10797,7 +10878,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10801: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10882: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10816,13 +10897,13 @@
-echo "configure:10820: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10901: checking for av_set_parameters in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10826 "configure"
+#line 10907 "configure"
@@ -10833,7 +10914,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10837: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10918: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10893,7 +10974,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10897: checking whether to use OpenGL" >&5
+echo "configure:10978: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -10927,7 +11008,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10931: checking for location of OpenGL includes" >&5
+echo "configure:11012: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10953,15 +11034,15 @@
 do
-echo "configure:10957: checking for $ac_hdr" >&5
+echo "configure:11038: checking for $ac_hdr" >&5
-#line 10960 "configure"
+#line 11041 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10965: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11046: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10995,7 +11076,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:10999: checking for location of OpenGL library" >&5
+echo "configure:11080: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -11024,13 +11105,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:11028: checking for glBegin in -lGL" >&5
+echo "configure:11109: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11034 "configure"
+#line 11115 "configure"
@@ -11041,7 +11122,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11126: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11060,13 +11141,13 @@
-echo "configure:11064: checking for glBegin in -lGL" >&5
+echo "configure:11145: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 11070 "configure"
+#line 11151 "configure"
@@ -11077,7 +11158,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11081: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11162: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11096,13 +11177,13 @@
-echo "configure:11100: checking for glBegin in -lGL" >&5
+echo "configure:11181: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 11106 "configure"
+#line 11187 "configure"
@@ -11113,7 +11194,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11198: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11132,13 +11213,13 @@
-echo "configure:11136: checking for glBegin in -lGL" >&5
+echo "configure:11217: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11142 "configure"
+#line 11223 "configure"
@@ -11149,7 +11230,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11234: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11211,13 +11292,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11215: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11296: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11221 "configure"
+#line 11302 "configure"
@@ -11228,7 +11309,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11232: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11247,13 +11328,13 @@
-echo "configure:11251: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11332: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11257 "configure"
+#line 11338 "configure"
@@ -11264,7 +11345,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11268: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11349: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11311,10 +11392,10 @@
 LIBS=" $OPENGLLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11315: checking for glXCreatePbuffer" >&5
+echo "configure:11396: checking for glXCreatePbuffer" >&5
-#line 11318 "configure"
+#line 11399 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -11337,7 +11418,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11341: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11422: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -11374,10 +11455,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11378: checking for glXCreateGLXPixmap" >&5
+echo "configure:11459: checking for glXCreateGLXPixmap" >&5
-#line 11381 "configure"
+#line 11462 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -11400,7 +11481,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11485: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -11443,7 +11524,7 @@
 echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:11447: checking for location of OpenGL framework" >&5
+echo "configure:11528: checking for location of OpenGL framework" >&5
 case "$with_opengl_framework" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -11467,15 +11548,15 @@
 do
-echo "configure:11471: checking for $ac_hdr" >&5
+echo "configure:11552: checking for $ac_hdr" >&5
-#line 11474 "configure"
+#line 11555 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11479: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11560: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11511,10 +11592,10 @@
 LIBS="-framework OpenGL -framework AGL -framework ApplicationServices  $LIBS"
 LDFLAGS="$OPENGLPATH $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11515: checking for glBegin" >&5
+echo "configure:11596: checking for glBegin" >&5
-#line 11518 "configure"
+#line 11599 "configure"
     which can conflict with char glBegin(); below.  */
@@ -11537,7 +11618,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11541: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11622: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -11574,10 +11655,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11578: checking for gluBeginCurve" >&5
+echo "configure:11659: checking for gluBeginCurve" >&5
-#line 11581 "configure"
+#line 11662 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -11600,7 +11681,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11604: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -11648,7 +11729,7 @@
-echo "configure:11652: checking for location of OpenGL includes" >&5
+echo "configure:11733: checking for location of OpenGL includes" >&5
@@ -11674,15 +11755,15 @@
 do
-echo "configure:11678: checking for $ac_hdr" >&5
+echo "configure:11759: checking for $ac_hdr" >&5
-#line 11681 "configure"
+#line 11762 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11686: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11767: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11716,7 +11797,7 @@
-echo "configure:11720: checking for location of OpenGL library" >&5
+echo "configure:11801: checking for location of OpenGL library" >&5
@@ -11741,18 +11822,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11745: checking for OpenGL library" >&5
+echo "configure:11826: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 11749 "configure"
+#line 11830 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:11756: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11837: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -11776,18 +11857,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11780: checking for GLU library" >&5
+echo "configure:11861: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 11784 "configure"
+#line 11865 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:11791: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11872: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -11836,7 +11917,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11840: checking whether to use ODBC" >&5
+echo "configure:11921: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -11855,7 +11936,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11859: checking for location of ODBC includes" >&5
+echo "configure:11940: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11881,15 +11962,15 @@
 do
-echo "configure:11885: checking for $ac_hdr" >&5
+echo "configure:11966: checking for $ac_hdr" >&5
-#line 11888 "configure"
+#line 11969 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11893: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11974: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11923,7 +12004,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:11927: checking for location of ODBC library" >&5
+echo "configure:12008: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -11948,13 +12029,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:11952: checking for SQLConnect in -lodbc" >&5
+echo "configure:12033: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 11958 "configure"
+#line 12039 "configure"
@@ -11965,7 +12046,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:11969: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12050: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11990,13 +12071,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:11994: checking for SQLConnect in -liodbc" >&5
+echo "configure:12075: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 12000 "configure"
+#line 12081 "configure"
@@ -12007,7 +12088,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12011: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12032,11 +12113,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12036: checking for ODBC library" >&5
+echo "configure:12117: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 12040 "configure"
+#line 12121 "configure"
 #include "confdefs.h"
 #include <windows.h>
 #include <sql.h>
@@ -12044,7 +12125,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:12048: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12129: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12093,7 +12174,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12097: checking whether to use FFTW" >&5
+echo "configure:12178: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -12112,7 +12193,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12116: checking for location of FFTW includes" >&5
+echo "configure:12197: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12138,15 +12219,15 @@
 do
-echo "configure:12142: checking for $ac_hdr" >&5
+echo "configure:12223: checking for $ac_hdr" >&5
-#line 12145 "configure"
+#line 12226 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12150: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12231: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12174,15 +12255,15 @@
 do
-echo "configure:12178: checking for $ac_hdr" >&5
+echo "configure:12259: checking for $ac_hdr" >&5
-#line 12181 "configure"
+#line 12262 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12186: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12267: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12210,15 +12291,15 @@
 do
-echo "configure:12214: checking for $ac_hdr" >&5
+echo "configure:12295: checking for $ac_hdr" >&5
 cat > conftest.$ac_ext <<EOF
-#line 12217 "configure"
+#line 12298 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12222: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12303: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12264,7 +12345,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12268: checking for location of FFTW library" >&5
+echo "configure:12349: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12289,13 +12370,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12293: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12374: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12299 "configure"
+#line 12380 "configure"
@@ -12306,7 +12387,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:12310: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12391: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12331,13 +12412,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12335: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12416: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 12341 "configure"
+#line 12422 "configure"
@@ -12348,7 +12429,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12352: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12433: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12373,13 +12454,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12377: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12458: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12383 "configure"
+#line 12464 "configure"
@@ -12390,7 +12471,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12394: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12475: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12447,7 +12528,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12451: checking whether to use BLAS" >&5
+echo "configure:12532: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -12468,7 +12549,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12472: checking for location of BLAS includes" >&5
+echo "configure:12553: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12488,7 +12569,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12492: checking for location of BLAS library" >&5
+echo "configure:12573: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12514,15 +12595,15 @@
 do
-echo "configure:12518: checking for $ac_hdr" >&5
+echo "configure:12599: checking for $ac_hdr" >&5
-#line 12521 "configure"
+#line 12602 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12526: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12607: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12557,13 +12638,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12561: checking for dnrm2_ in -lblas" >&5
+echo "configure:12642: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 12567 "configure"
+#line 12648 "configure"
@@ -12574,7 +12655,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12578: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12659: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12593,13 +12674,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:12597: checking for dnrm2_ in -lblas" >&5
+echo "configure:12678: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12603 "configure"
+#line 12684 "configure"
@@ -12610,7 +12691,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12614: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12695: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12654,13 +12735,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12658: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12739: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 12664 "configure"
+#line 12745 "configure"
@@ -12671,7 +12752,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:12675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12756: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12686,13 +12767,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo "$ac_t""yes" 1>&6
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12690: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12771: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 12696 "configure"
+#line 12777 "configure"
@@ -12703,7 +12784,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12788: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12718,13 +12799,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12722: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:12803: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12728 "configure"
+#line 12809 "configure"
@@ -12735,7 +12816,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:12739: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12820: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12780,16 +12861,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12784: checking for sgemm in $vlib_flags" >&5
+echo "configure:12865: checking for sgemm in $vlib_flags" >&5
-#line 12786 "configure"
+#line 12867 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:12793: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -12807,13 +12888,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12811: checking for sgemm_ in -lblas" >&5
+echo "configure:12892: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lblas  $LIBS"
-#line 12817 "configure"
+#line 12898 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -12824,7 +12905,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12828: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12909: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -12839,13 +12920,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12843: checking for dgemm_ in -ldgemm" >&5
+echo "configure:12924: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 12849 "configure"
+#line 12930 "configure"
@@ -12856,7 +12937,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12860: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12941: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12871,13 +12952,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:12875: checking for sgemm_ in -lsgemm" >&5
+echo "configure:12956: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 12881 "configure"
+#line 12962 "configure"
@@ -12888,7 +12969,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12922,13 +13003,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:12926: checking for acosp in -lsunmath" >&5
+echo "configure:13007: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 12932 "configure"
+#line 13013 "configure"
@@ -12939,7 +13020,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:12943: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12954,13 +13035,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:12958: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13039: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 12964 "configure"
+#line 13045 "configure"
@@ -12971,7 +13052,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12975: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13056: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13001,13 +13082,13 @@
 # Generic BLAS library
-echo "configure:13005: checking for sgemm_ in -lblas" >&5
+echo "configure:13086: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 13011 "configure"
+#line 13092 "configure"
@@ -13018,7 +13099,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13103: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13057,7 +13138,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13061: checking whether to use LAPACK" >&5
+echo "configure:13142: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -13082,7 +13163,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13086: checking for location of LAPACK includes" >&5
+echo "configure:13167: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13102,7 +13183,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13106: checking for location of LAPACK library" >&5
+echo "configure:13187: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13128,15 +13209,15 @@
 do
-echo "configure:13132: checking for $ac_hdr" >&5
+echo "configure:13213: checking for $ac_hdr" >&5
-#line 13135 "configure"
+#line 13216 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13140: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13221: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -13168,10 +13249,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13172: checking for dsegv_" >&5
+echo "configure:13253: checking for dsegv_" >&5
-#line 13175 "configure"
+#line 13256 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -13194,7 +13275,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13198: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13279: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -13221,13 +13302,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13225: checking for desgv_ in -llapack" >&5
+echo "configure:13306: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 13231 "configure"
+#line 13312 "configure"
@@ -13238,7 +13319,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13242: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13270,13 +13351,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13274: checking for dgesv_ in -llapack" >&5
+echo "configure:13355: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 13280 "configure"
+#line 13361 "configure"
@@ -13287,7 +13368,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13291: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13372: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13306,13 +13387,13 @@
-echo "configure:13310: checking for dgesv_ in -llapack" >&5
+echo "configure:13391: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13316 "configure"
+#line 13397 "configure"
@@ -13323,7 +13404,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13327: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13408: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13379,7 +13460,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13383: checking whether to use Cairo" >&5
+echo "configure:13464: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -13405,7 +13486,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:13409: checking for location of cairo includes" >&5
+echo "configure:13490: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -13431,15 +13512,15 @@
 do
-echo "configure:13435: checking for $ac_hdr" >&5
+echo "configure:13516: checking for $ac_hdr" >&5
-#line 13438 "configure"
+#line 13519 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13443: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13524: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13475,7 +13556,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:13479: checking for location of cairo library" >&5
+echo "configure:13560: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -13495,7 +13576,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:13499: checking for cairo linking flags" >&5
+echo "configure:13580: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -13511,10 +13592,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13515: checking for cairo_create" >&5
+echo "configure:13596: checking for cairo_create" >&5
-#line 13518 "configure"
+#line 13599 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -13537,7 +13618,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13541: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13622: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -13571,10 +13652,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:13575: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:13656: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 13578 "configure"
+#line 13659 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -13597,7 +13678,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13601: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13682: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -13639,7 +13720,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:13643: checking whether to use FreeType" >&5
+echo "configure:13724: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -13658,7 +13739,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:13662: checking for location of FreeType includes" >&5
+echo "configure:13743: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -13684,15 +13765,15 @@
 do
-echo "configure:13688: checking for $ac_hdr" >&5
+echo "configure:13769: checking for $ac_hdr" >&5
-#line 13691 "configure"
+#line 13772 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13696: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13777: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13726,7 +13807,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:13730: checking for location of FreeType library" >&5
+echo "configure:13811: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -13751,13 +13832,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:13755: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:13836: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 13761 "configure"
+#line 13842 "configure"
@@ -13768,7 +13849,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:13772: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13853: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13809,7 +13890,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:13813: checking whether to use NLS" >&5
+echo "configure:13894: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -13829,10 +13910,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:13833: checking for gettext" >&5
+echo "configure:13914: checking for gettext" >&5
-#line 13836 "configure"
+#line 13917 "configure"
     which can conflict with char gettext(); below.  */
@@ -13855,7 +13936,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13940: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -13873,13 +13954,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:13877: checking for gettext in -lintl" >&5
+echo "configure:13958: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 13883 "configure"
+#line 13964 "configure"
@@ -13890,7 +13971,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:13894: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13975: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13925,7 +14006,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:13929: checking whether to use C++" >&5
+echo "configure:14010: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -13941,7 +14022,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13945: checking for $ac_word" >&5
+echo "configure:14026: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -13970,7 +14051,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:13974: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:14055: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -13981,12 +14062,12 @@
 cat > conftest.$ac_ext << EOF
-#line 13985 "configure"
+#line 14066 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:13990: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14071: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -14012,19 +14093,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:14016: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:14097: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:14021: checking whether we are using GNU C++" >&5
+echo "configure:14102: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14028: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14109: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -14042,7 +14123,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:14046: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:14127: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -14083,7 +14164,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:14087: checking whether to use openDWG" >&5
+echo "configure:14168: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -14103,7 +14184,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:14107: checking for location of openDGW includes" >&5
+echo "configure:14188: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -14129,15 +14210,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:14133: checking for $ac_hdr" >&5
+echo "configure:14214: checking for $ac_hdr" >&5
-#line 14136 "configure"
+#line 14217 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14141: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14222: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14171,7 +14252,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:14175: checking for location of openDWG library" >&5
+echo "configure:14256: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -14212,7 +14293,7 @@
 echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:14216: checking whether to use POSIX threads" >&5
+echo "configure:14297: checking whether to use POSIX threads" >&5
 echo "$ac_t"""$with_pthread"" 1>&6
 case "$with_pthread" in
 	"no")	USE_PTHREAD=	;;
@@ -14232,7 +14313,7 @@
 echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:14236: checking for location of POSIX threads includes" >&5
+echo "configure:14317: checking for location of POSIX threads includes" >&5
 case "$with_pthread_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -14258,15 +14339,15 @@
 do
-echo "configure:14262: checking for $ac_hdr" >&5
+echo "configure:14343: checking for $ac_hdr" >&5
-#line 14265 "configure"
+#line 14346 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14270: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14351: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14300,7 +14381,7 @@
 echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:14304: checking for location of POSIX threads library" >&5
+echo "configure:14385: checking for location of POSIX threads library" >&5
 case "$with_pthread_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -14325,10 +14406,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:14329: checking for pthread_create" >&5
+echo "configure:14410: checking for pthread_create" >&5
-#line 14332 "configure"
+#line 14413 "configure"
     which can conflict with char pthread_create(); below.  */
@@ -14351,7 +14432,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14436: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_pthread_create=yes"
 else
@@ -14378,13 +14459,13 @@
 echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:14382: checking for pthread_create in -lpthread" >&5
+echo "configure:14463: checking for pthread_create in -lpthread" >&5
 ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
 LIBS="-lpthread  $LIBS"
-#line 14388 "configure"
+#line 14469 "configure"
@@ -14395,7 +14476,7 @@
 pthread_create()
 ; return 0; }
 EOF
-if { (eval echo configure:14399: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14480: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14451,7 +14532,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14455: checking for special C compiler options needed for large files" >&5
+echo "configure:14536: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -14459,7 +14540,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 14463 "configure"
+#line 14544 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -14475,7 +14556,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14479: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14560: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   echo "configure: failed program was:" >&5
@@ -14484,7 +14565,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 14488 "configure"
+#line 14569 "configure"
@@ -14500,7 +14581,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14504: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14585: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -14520,11 +14601,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:14524: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:14605: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 14528 "configure"
+#line 14609 "configure"
@@ -14540,14 +14621,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14544: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14625: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   cat conftest.$ac_ext >&5
   rm -rf conftest*
-#line 14551 "configure"
+#line 14632 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -14565,7 +14646,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14569: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14650: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -14584,11 +14665,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:14588: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:14669: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 14592 "configure"
+#line 14673 "configure"
@@ -14604,14 +14685,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14608: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14689: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14615 "configure"
+#line 14696 "configure"
 #define _LARGE_FILES 1
@@ -14629,7 +14710,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14633: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14714: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -14648,25 +14729,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:14652: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14733: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 14656 "configure"
+#line 14737 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14663: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14744: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14670 "configure"
+#line 14751 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -14675,7 +14756,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14679: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14760: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -14696,10 +14777,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:14700: checking if system supports Large Files at all" >&5
+echo "configure:14781: checking if system supports Large Files at all" >&5
-#line 14703 "configure"
+#line 14784 "configure"
 #include <stdio.h>
@@ -14731,7 +14812,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:14735: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14816: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -14760,7 +14841,7 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:14764: checking whether to use Python" >&5
+echo "configure:14845: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
@@ -14780,7 +14861,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
-echo "configure:14784: checking for $ac_word" >&5
+echo "configure:14865: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -14825,15 +14906,15 @@
 do
-echo "configure:14829: checking for $ac_hdr" >&5
+echo "configure:14910: checking for $ac_hdr" >&5
-#line 14832 "configure"
+#line 14913 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14837: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14918: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14873,7 +14954,7 @@
   # Extract the first word of "swig", so it can be a program name with args.
 set dummy swig; ac_word=$2
-echo "configure:14877: checking for $ac_word" >&5
+echo "configure:14958: checking for $ac_word" >&5
 case "$SWIG" in
@@ -14919,7 +15000,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:14923: checking whether to use wxWidgets" >&5
+echo "configure:15004: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -14939,7 +15020,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:14943: checking for $ac_word" >&5
+echo "configure:15024: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -14987,7 +15068,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:14991: checking wxWidgets version" >&5
+echo "configure:15072: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -15010,15 +15091,15 @@
 do
-echo "configure:15014: checking for $ac_hdr" >&5
+echo "configure:15095: checking for $ac_hdr" >&5
-#line 15017 "configure"
+#line 15098 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15022: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15103: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15260,6 +15341,10 @@
 s%@GDAL_CFLAGS@%$GDAL_CFLAGS%g
 s%@USE_GDAL@%$USE_GDAL%g
 s%@USE_OGR@%$USE_OGR%g
+s%@GEOS_CONFIG@%$GEOS_CONFIG%g
+s%@GEOS_LIBS@%$GEOS_LIBS%g
+s%@GEOS_CFLAGS@%$GEOS_CFLAGS%g
+s%@USE_GEOS@%$USE_GEOS%g
 s%@TIFF_INCLUDE_DIRS@%$TIFF_INCLUDE_DIRS%g
 s%@TIFF_LIBRARY_DIRS@%$TIFF_LIBRARY_DIRS%g
 s%@TIFFLIB@%$TIFFLIB%g
@@ -15632,6 +15717,8 @@
 echo "  GDAL support:               `if test -n "${USE_GDAL}" ; then echo yes ; else echo no ; fi`"
+echo "  GEOS support:               `if test -n "${USE_GEOS}" ; then echo yes ; else echo no ; fi`"
 echo "  JPEG support:               `if test -n "${USE_JPEG}" ; then echo yes ; else echo no ; fi`"
 echo "  LAPACK support:             `if test -n "${USE_LAPACK}" ; then echo yes ; else echo no ; fi`"
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in	2009-03-29 13:12:13 UTC (rev 36511)
+++ grass/trunk/configure.in	2009-03-29 13:53:03 UTC (rev 36512)
@@ -209,6 +209,10 @@
 [  --with-gdal[=path/gdal-config] enable GDAL/OGR support (gdal-config with path, \
 e.g. '--with-gdal=/usr/local/bin/gdal-config')])
+AC_ARG_WITH(geos,
+[  --with-geos[=path/geos-config] enable GEOS support (geos-config with path, \
+e.g. '--with-geos=/usr/local/bin/geos-config')])
 AC_ARG_WITH(includes,
 [  --with-includes=DIRS    site include files are in DIRS])
@@ -725,6 +729,41 @@
 AC_SUBST(USE_GDAL)
 AC_SUBST(USE_OGR)
+# GEOS option
+AC_MSG_CHECKING(whether to use GEOS)
+GEOS_LIBS=
+GGEOS_CFLAGS=
+USE_GEOS=
+if test "`basename xx/$with_geos`" = "geos-config" ; then
+  GEOS_CONFIG="$with_geos"
+fi
+if test "$with_geos" = "no" ; then
+  AC_MSG_RESULT(no)
+else
+  AC_MSG_RESULT(yes)
+  AC_PATH_PROG(GEOS_CONFIG, geos-config, no)
+  if test "$GEOS_CONFIG" = "no" ; then
+    AC_MSG_ERROR([*** couldn't find geos-config])
+  fi
+  if test "$GEOS_CONFIG" != "" ; then
+    GEOS_LIBS=`"$GEOS_CONFIG" --libs`
+    GEOS_CFLAGS=`"$GEOS_CONFIG" --cflags`
+    USE_GEOS=1
+  fi
+  AC_DEFINE(HAVE_GEOS)
+fi
+AC_SUBST(GEOS_LIBS)
+AC_SUBST(GEOS_CFLAGS)
+AC_SUBST(USE_GEOS)
 # Enable TIFF option
 LOC_CHECK_USE(tiff,TIFF,USE_TIFF)
@@ -1746,6 +1785,7 @@
 LOC_MSG_USE(FFTW support,USE_FFTW)
 LOC_MSG_USE(FreeType support,USE_FREETYPE)
 LOC_MSG_USE(GDAL support,USE_GDAL)
+LOC_MSG_USE(GEOS support,USE_GEOS)
 LOC_MSG_USE(JPEG support,USE_JPEG)
 LOC_MSG_USE(LAPACK support,USE_LAPACK)
 LOC_MSG_USE(Large File support (LFS), USE_LARGEFILES)
Modified: grass/trunk/include/Make/Grass.make
--- grass/trunk/include/Make/Grass.make	2009-03-29 13:12:13 UTC (rev 36511)
+++ grass/trunk/include/Make/Grass.make	2009-03-29 13:53:03 UTC (rev 36512)
@@ -67,7 +67,7 @@
 CFLAGS      =  $(INC) $(COMPILE_FLAGS)
 CXXFLAGS    =  $(INC) $(COMPILE_FLAGS_CXX)
 LDFLAGS     =  $(LIBPATH) $(LINK_FLAGS) $(LD_SEARCH_FLAGS) $(PQLIBPATH)
-VECT_CFLAGS =  $(GDALCFLAGS)
+VECT_CFLAGS =  $(GDALCFLAGS) $(GEOSCFLAGS)
 # Object with _fmode which must be linked to each executable on Windows
 ifdef MINGW
@@ -239,7 +239,7 @@
 GRAPHLIB      = -l$(GRAPH_LIBNAME)
 RTREELIB      = -l$(RTREE_LIBNAME)
 VEDITLIB      = -l$(VEDIT_LIBNAME) $(GISLIB) $(VECTRLIB)
-VECTLIB       = $(VECTRLIB) $(DIG2LIB) $(GRAPHLIB) $(RTREELIB) $(LINKMLIB) $(DBMILIB) $(GDALLIBS)
+VECTLIB       = $(VECTRLIB) $(DIG2LIB) $(GRAPHLIB) $(RTREELIB) $(LINKMLIB) $(DBMILIB) $(GDALLIBS) $(GEOSLIBS)
 # Interpolation
 INTERPDATALIB = -l$(INTERPDATA_LIBNAME)
Modified: grass/trunk/include/Make/Platform.make.in
--- grass/trunk/include/Make/Platform.make.in	2009-03-29 13:12:13 UTC (rev 36511)
+++ grass/trunk/include/Make/Platform.make.in	2009-03-29 13:53:03 UTC (rev 36512)
@@ -190,6 +190,11 @@
 USE_GDAL            = @USE_GDAL@
 USE_OGR             = @USE_OGR@
+#GEOS
+GEOSLIBS            = @GEOS_LIBS@
+GEOSCFLAGS          = @GEOS_CFLAGS@
+USE_GEOS            = @USE_GEOS@
 #FreeType:
 FTINC               = @FTINC@
 FTLIB               = @FTLIB@
Modified: grass/trunk/include/Vect.h
--- grass/trunk/include/Vect.h	2009-03-29 13:12:13 UTC (rev 36511)
+++ grass/trunk/include/Vect.h	2009-03-29 13:53:03 UTC (rev 36512)
@@ -3,6 +3,10 @@
 #include <grass/gis.h>
 #include <grass/vect/digit.h>
+#ifdef HAVE_GEOS
+#include <geos_c.h>
+#endif
 /* --- ANSI prototypes for the lib/vector/Vlib functions --- */
@@ -464,4 +468,11 @@
 int Vect_attach_isles(struct Map_info *, BOUND_BOX *);
 int Vect_attach_centroids(struct Map_info *, BOUND_BOX *);
+    /* GEOS support */
+#ifdef HAVE_GEOS
+GEOSGeometry *Vect_read_line_geos(const struct Map_info *, int);
+GEOSGeometry *Vect_read_area_geos(const struct Map_info *, int);
+GEOSGeometry *Vect_line_to_geos(const struct Map_info *, const struct line_pnts*, int);
+#endif
 #endif /* GRASS_VECT_H */
Modified: grass/trunk/include/config.h.in
--- grass/trunk/include/config.h.in	2009-03-29 13:12:13 UTC (rev 36511)
+++ grass/trunk/include/config.h.in	2009-03-29 13:53:03 UTC (rev 36512)
@@ -143,6 +143,9 @@
 /* define if OGR is to be used */
 #undef HAVE_OGR
+/* define if GEOS is to be used */
+#undef HAVE_GEOS
 /* define if postgres client header exists */
 #undef HAVE_LIBPQ_FE_H
Property changes on: grass/trunk/lib/vector/Vlib/buffer2.c
___________________________________________________________________
   + text/x-csrc
   + Author Date Id
   + native
Property changes on: grass/trunk/lib/vector/Vlib/dgraph.c
   + text/x-csrc
   + Author Date Id
Property changes on: grass/trunk/lib/vector/Vlib/e_intersect.c
   + text/x-csrc
   + Author Date Id
Added: grass/trunk/lib/vector/Vlib/geos.c
--- grass/trunk/lib/vector/Vlib/geos.c	                        (rev 0)
+++ grass/trunk/lib/vector/Vlib/geos.c	2009-03-29 13:53:03 UTC (rev 36512)
@@ -0,0 +1,178 @@
+ * \file geos.c
+ * \brief Vector library - GEOS support
+ * Higher level functions for reading/writing/manipulating vectors.
+ * (C) 2009 by the GRASS Development Team
+ * This program is free software under the GNU General Public License
+ * (>=v2).  Read the file COPYING that comes with GRASS for details.
+ * \author Martin Landa <landa.martin gmail.com>
+#include <grass/config.h>
+#include <grass/gis.h>
+#include <grass/Vect.h>
+#include <grass/glocale.h>
+#ifdef HAVE_GEOS
+static struct line_pnts *Points;
+   \brief Read vector feature and stores it as GEOSGeometry instance
+   Note: Free allocated memory by GEOSGeom_destroy().
+   \param Map pointer to Map_info structure
+   \param line feature id
+   \return pointer to GEOSGeometry instance
+   \return NULL on error
+GEOSGeometry *Vect_read_line_geos(const struct Map_info *Map, int line)
+    int type, dim;
+    GEOSGeometry *geom;
+    GEOSCoordSequence *pseq;
+    if (!Points)
+	Points = Vect_new_line_struct();
+    G_debug(3, "Vect_read_line_geos(line=%d)", line);
+    if (Vect_is_3d(Map))
+	dim = 3;
+    else
+	dim = 2;
+    type = Vect_read_line(Map, Points, NULL, line);
+    if (type < 0)
+	return NULL;
+    return Vect_line_to_geos(Map, Points, type);
+   \brief Read vector area and stores it as GEOSGeometry instance
+   \param area area id
+GEOSGeometry *Vect_read_area_geos(const struct Map_info * Map, int area)
+    int i, type, dim, nholes, isle;
+    GEOSGeometry *boundary, **holes;
+    if (!Points)
+    G_debug(3, "Vect_read_area_geos(area=%d)", area);
+	dim = 3;
+    else
+	dim = 2;
+    if (Vect_get_area_points(Map, area, Points) == -1) {
+	G_fatal_error(_("Vect_read_area_geos(): unable to read area id %d"),
+		      area);
+    boundary = Vect_line_to_geos(Map, Points, GV_BOUNDARY);
+    if (!boundary) {
+		      area);
+    nholes = Vect_get_area_num_isles(Map, area);
+    holes = (GEOSGeometry **) G_malloc(nholes * sizeof(GEOSGeometry *));
+    for (i = 0; i < nholes; i++) {
+	isle = Vect_get_area_isle(Map, area, i);
+	if (isle < 1)
+	    continue;
+	if (Vect_get_isle_points(Map, isle, Points) < 0)
+	    G_fatal_error(_("Vect_read_area_geos(): unable to read isle id %d of area id %d"),
+			  isle, area);
+	holes[i] = Vect_line_to_geos(Map, Points, GV_BOUNDARY);
+    return GEOSGeom_createPolygon(boundary, holes, nholes);
+   \brief Create GEOSGeometry of given type from feature points.
+   Supported types:
+   - GV_POINT    -> POINT
+   - GV_LINE     -> LINESTRING
+   - GV_BOUNDARY -> LINERING
+   \param type feature type (see supported types)
+GEOSGeometry *Vect_line_to_geos(const struct Map_info * Map,
+				const struct line_pnts * points, int type)
+    int i, dim;
+    G_debug(3, "Vect_line_to_geos(type=%d)", type);
+	dim = 3;
+    else
+	dim = 2;
+    if (type == GV_POINT) {
+	if (points->n_points != 1)
+	    return NULL;
+    else {			/* GV_LINES */
+	if (points->n_points < 2)
+	    return NULL;
+    if (!(type & (GV_POINT | GV_LINES)))
+	return NULL;
+    pseq = GEOSCoordSeq_create(points->n_points, dim);
+    for (i = 0; i < points->n_points; i++) {
+	GEOSCoordSeq_setX(pseq, i, points->x[i]);
+	GEOSCoordSeq_setY(pseq, i, points->y[i]);
+	if (dim == 3)
+	    GEOSCoordSeq_setZ(pseq, i, points->z[i]);
+	geom = GEOSGeom_createPoint(pseq);
+    else if (type == GV_LINE)
+	geom = GEOSGeom_createLineString(pseq);
+    else {			/* GV_BOUNDARY */
+	if (GEOSisRing(geom)) {
+	    /* GEOSGeom_destroy(geom); */
+	    geom = GEOSGeom_createLinearRing(pseq);
+    /* GEOSCoordSeq_destroy(pseq); */
+    return geom;
+#endif /* HAVE_GEOS */
Property changes on: grass/trunk/lib/vector/Vlib/geos.c
   + text/x-csrc
   + Author Date Id
   + native
Added: grass/trunk/vector/v.select/geos.c
--- grass/trunk/vector/v.select/geos.c	                        (rev 0)
+++ grass/trunk/vector/v.select/geos.c	2009-03-29 13:53:03 UTC (rev 36512)
@@ -0,0 +1,123 @@
+#include <grass/dbmi.h>
+#include "proto.h"
+#ifdef HAVE_GEOS
+static int relate_geos(const struct Map_info *, const GEOSGeometry *,
+		       int, int, const char *, int);
+int line_relate_geos(const struct Map_info *BIn, const GEOSGeometry * AGeom,
+		     int bline, int operator, const char *relate)
+    return relate_geos(BIn, AGeom, bline, operator, relate, 0);
+int area_relate_geos(const struct Map_info *BIn, const GEOSGeometry * AGeom,
+		     int barea, int operator, const char *relate)
+    return relate_geos(BIn, AGeom, barea, operator, relate, 1);
+int relate_geos(const struct Map_info *BIn, const GEOSGeometry * AGeom,
+		int bfid, int operator, const char *relate, int area)
+    GEOSGeometry *BGeom = NULL;
+    int found;
+    found = 0;
+    if (area)
+	BGeom = Vect_read_area_geos(BIn, bfid);
+    else
+	BGeom = Vect_read_line_geos(BIn, bfid);
+    if (!BGeom)
+	return 0;
+       if (!BGeom) {
+       if (area)
+       G_fatal_error(_("Unable to read area id %d from vector map <%s>"),
+       bfid, Vect_get_full_name(BIn));
+       else
+       G_fatal_error(_("Unable to read line id %d from vector map <%s>"),
+    switch (operator) {
+    case OP_EQUALS:{
+	    if (GEOSEquals(AGeom, BGeom)) {
+		found = 1;
+		break;
+	    break;
+    case OP_DISJOINT:{
+	    if (GEOSDisjoint(AGeom, BGeom)) {
+		found = 1;
+		break;
+	    break;
+    case OP_INTERSECTS:{
+	    if (GEOSIntersects(AGeom, BGeom)) {
+		found = 1;
+		break;
+	    break;
+    case OP_TOUCHES:{
+	    if (GEOSTouches(AGeom, BGeom)) {
+		found = 1;
+		break;
+	    break;
+    case OP_CROSSES:{
+	    if (GEOSCrosses(AGeom, BGeom)) {
+		found = 1;
+		break;
+	    break;
+    case OP_WITHIN:{
+	    if (GEOSWithin(AGeom, BGeom)) {
+		found = 1;
+		break;
+	    break;
+    case OP_CONTAINS:{
+	    if (GEOSContains(AGeom, BGeom)) {
+		found = 1;
+		break;
+	    break;
+    case OP_OVERLAPS:{
+	    if (GEOSOverlaps(AGeom, BGeom)) {
+		found = 1;
+		break;
+	    break;
+    case OP_RELATE:{
+	    if (GEOSRelatePattern(AGeom, BGeom, relate)) {
+		found = 1;
+		break;
+	    break;
+    default:
+	break;
+    if (BGeom)
+	GEOSGeom_destroy(BGeom);
+    return found;
Property changes on: grass/trunk/vector/v.select/geos.c
   + text/x-csrc
   + Author Date Id
   + native
Modified: grass/trunk/vector/v.select/main.c
--- grass/trunk/vector/v.select/main.c	2009-03-29 13:12:13 UTC (rev 36511)
+++ grass/trunk/vector/v.select/main.c	2009-03-29 13:53:03 UTC (rev 36512)
@@ -4,8 +4,9 @@
  * MODULE:       v.select - select features from one map by features in another map.
  * AUTHOR(S):    Radim Blazek <radim.blazek gmail.com> (original contributor)
  *               Glynn Clements <glynn gclements.plus.com>, Markus Neteler <neteler itc.it>
+ *               Martin Landa <landa.martin gmail.com> (GEOS support)
  * PURPOSE:
- * COPYRIGHT:    (C) 2003-2008 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2003-2009 by the GRASS Development Team
  *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -16,110 +17,30 @@
 #include <stdlib.h>
 #include <string.h>
 #include <stdio.h>
-#define OP_OVERLAP 0
+#include "proto.h"
-/* Add all elements of area A to the list */
-void add_aarea(struct Map_info *In, int aarea, int *ALines)
-    int i, j, aline, naisles, aisle, acentroid;
-    static struct ilist *BoundList = NULL;
-    if (!BoundList)
-	BoundList = Vect_new_list();
-    acentroid = Vect_get_area_centroid(In, aarea);
-    ALines[acentroid] = 1;
-    Vect_get_area_boundaries(In, aarea, BoundList);
-    for (i = 0; i < BoundList->n_values; i++) {
-	aline = abs(BoundList->value[i]);
-	ALines[aline] = 1;
-    naisles = Vect_get_area_num_isles(In, aarea);
-    for (j = 0; j < naisles; j++) {
-	aisle = Vect_get_area_isle(In, aarea, j);
-	Vect_get_isle_boundaries(In, aisle, BoundList);
-/* Returns 1 if line1 from Map1 overlaps area2 from Map2,
- *         0 otherwise */
-int line_overlap_area(struct Map_info *LMap, int line, struct Map_info *AMap,
-		      int area)
-    int i, nisles, isle;
-    static struct line_pnts *LPoints = NULL;
-    static struct line_pnts *APoints = NULL;
-    G_debug(4, "line_overlap_area line = %d area = %d", line, area);
-    if (!LPoints) {
-	LPoints = Vect_new_line_struct();
-	APoints = Vect_new_line_struct();
-    /* Read line coordinates */
-    Vect_read_line(LMap, LPoints, NULL, line);
-    /* Try if any of line vertices is within area */
-    for (i = 0; i < LPoints->n_points; i++) {
-	if (Vect_point_in_area(AMap, area, LPoints->x[i], LPoints->y[i])) {
-	    G_debug(4, "  -> line vertex inside area");
-	    return 1;
-    /* Skip points */
-    if (LPoints->n_points < 2)
-	return 0;
-    /* Try intersections of line with area/isles boundary */
-    /* Outer boundary */
-    Vect_get_area_points(AMap, area, APoints);
-    if (Vect_line_check_intersection(LPoints, APoints, 0)) {
-	G_debug(4, "  -> line intersects outer area boundary");
-	return 1;
-    nisles = Vect_get_area_num_isles(AMap, area);
-    for (i = 0; i < nisles; i++) {
-	isle = Vect_get_area_isle(AMap, area, i);
-	Vect_get_isle_points(AMap, isle, APoints);
-	    G_debug(4, "  -> line intersects area island boundary");
-	    return 1;
-    return 0;
 int main(int argc, char *argv[])
-    int i;
-    int input, operator;
-    int aline, nalines;
-    int type[2], field[2];
+    int i, iopt;
+    int operator;
+    int aline, nalines, nskipped;
+    int ltype, itype[2], ifield[2];
     int **cats, *ncats, nfields, *fields;
     char *pre[2];
     struct GModule *module;
-    struct Option *in_opt[2], *out_opt, *type_opt[2], *field_opt[2],
-	*operator_opt;
-    struct Flag *table_flag, *r_flag;
+    struct {
+	struct Option *input[2], *output, *type[2], *field[2],
+	    *operator, *relate;
+    } parm;
+    struct {
+	struct Flag *table, *reverse, *geos;
+    } flag;
     struct Map_info In[2], Out;
     struct field_info *IFi, *OFi;
     struct line_pnts *APoints, *BPoints;
@@ -133,82 +54,138 @@
     pre[1] = "b";
     module = G_define_module();
-    module->keywords = _("vector, query");
+    module->keywords = _("vector, spatial query");
     module->description =
 	_("Selects features from vector map (A) by features from other vector map (B).");
-    in_opt[0] = G_define_standard_option(G_OPT_V_INPUT);
-    in_opt[0]->description = _("Name of input vector map (A)");
-    in_opt[0]->key = "ainput";
+    parm.input[0] = G_define_standard_option(G_OPT_V_INPUT);
+    parm.input[0]->description = _("Name of input vector map (A)");
+    parm.input[0]->key = "ainput";
-    type_opt[0] = G_define_standard_option(G_OPT_V_TYPE);
-    type_opt[0]->label = _("Feature type (vector map A)");
-    type_opt[0]->key = "atype";
-    type_opt[0]->guisection = _("Selection");
+    parm.type[0] = G_define_standard_option(G_OPT_V_TYPE);
+    parm.type[0]->label = _("Feature type (vector map A)");
+    parm.type[0]->key = "atype";
+    parm.type[0]->guisection = _("Selection");
-    field_opt[0] = G_define_standard_option(G_OPT_V_FIELD);
-    field_opt[0]->label = _("Layer number (vector map A)");
-    field_opt[0]->key = "alayer";
-    field_opt[0]->guisection = _("Selection");
+    parm.field[0] = G_define_standard_option(G_OPT_V_FIELD);
+    parm.field[0]->label = _("Layer number (vector map A)");
+    parm.field[0]->key = "alayer";
+    parm.field[0]->guisection = _("Selection");
-    in_opt[1] = G_define_standard_option(G_OPT_V_INPUT);
-    in_opt[1]->description = _("Name of input vector map (B)");
-    in_opt[1]->key = "binput";
+    parm.input[1] = G_define_standard_option(G_OPT_V_INPUT);
+    parm.input[1]->description = _("Name of input vector map (B)");
+    parm.input[1]->key = "binput";
-    type_opt[1] = G_define_standard_option(G_OPT_V_TYPE);
-    type_opt[1]->label = _("Feature type (vector map B)");
-    type_opt[1]->key = "btype";
-    type_opt[1]->guisection = _("Selection");
+    parm.type[1] = G_define_standard_option(G_OPT_V_TYPE);
+    parm.type[1]->label = _("Feature type (vector map B)");
+    parm.type[1]->key = "btype";
+    parm.type[1]->guisection = _("Selection");
-    field_opt[1] = G_define_standard_option(G_OPT_V_FIELD);
-    field_opt[1]->label = _("Layer number (vector map B)");
-    field_opt[1]->key = "blayer";
-    field_opt[1]->guisection = _("Selection");
+    parm.field[1] = G_define_standard_option(G_OPT_V_FIELD);
+    parm.field[1]->label = _("Layer number (vector map B)");
+    parm.field[1]->key = "blayer";
+    parm.field[1]->guisection = _("Selection");
-    out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
+    parm.output = G_define_standard_option(G_OPT_V_OUTPUT);
-    operator_opt = G_define_option();
-    operator_opt->key = "operator";
-    operator_opt->type = TYPE_STRING;
-    operator_opt->required = NO;
-    operator_opt->multiple = NO;
-    operator_opt->options = "overlap";
-    operator_opt->answer = "overlap";
-    operator_opt->label =
+    parm.operator = G_define_option();
+    parm.operator->key = "operator";
+    parm.operator->type = TYPE_STRING;
+    parm.operator->required = YES;
+    parm.operator->multiple = NO;
+    parm.operator->label =
 	_("Operator defines required relation between features");
-    operator_opt->description =
+    parm.operator->description =
 	_("A feature is written to output if the result of operation 'ainput operator binput' is true. "
 	  "An input feature is considered to be true, if category of given layer is defined.");
-    operator_opt->descriptions = _("overlap;features partially or completely overlap");
+#ifndef HAVE_GEOS
+    parm.operator->options = "overlaps";
+    parm.operator->answer = "overlaps";
+    parm.operator->descriptions = _("overlaps;features partially or completely overlap");
+#else
+    parm.operator->options = "equals,disjoint,intersects,touches,crosses,within,contains,overlaps,relate";
+    parm.operator->descriptions = _("equals;features are spatially equals (requires flag 'g');"
+				    "disjoint;features do not spatially intersect (requires flag 'g');"
+				    "intersects;features spatially intersect (requires flag 'g');"
+				    "touches;features spatially touches (requires flag 'g');"
+				    "crosses;features spatially crosses (requires flag 'g');"
+				    "within;feature A is completely inside feature B (requires flag 'g');"
+				    "contains;feature B is completely inside feature A (requires flag 'g');"
+				    "overlaps;features spatilly overlap;"
+				    "relate;feature A is spatially related to feature B "
+				    "(requires 'relate' option and flag 'g');");
+#endif
-    table_flag = G_define_flag();
-    table_flag->key = 't';
-    table_flag->description = _("Do not create attribute table");
+    parm.relate = G_define_option();
+    parm.relate->key = "relate";
+    parm.relate->type = TYPE_STRING;
+    parm.relate->required = NO;
+    parm.relate->multiple = NO;
+    parm.relate->description = _("Intersection Matrix Pattern used for 'relate' operator");
+    flag.table = G_define_flag();
+    flag.table->key = 't';
+    flag.table->description = _("Do not create attribute table");
-    r_flag = G_define_flag();
-    r_flag->key = 'r';
-    r_flag->description = _("Reverse selection");
-    r_flag->guisection = _("Selection");
+    flag.reverse = G_define_flag();
+    flag.reverse->key = 'r';
+    flag.reverse->description = _("Reverse selection");
+    flag.reverse->guisection = _("Selection");
+#ifdef HAVE_GEOS
+    flag.geos = G_define_flag();
+    flag.geos->key = 'g';
+    flag.geos->description = _("Use GEOS operators");
+#else
+    flag.geos = NULL;
+#endif
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
+    if (parm.operator->answer[0] == 'e')
+	operator = OP_EQUALS;
+    else if (parm.operator->answer[0] == 'd')
+	operator = OP_DISJOINT;
+    else if (parm.operator->answer[0] == 'i')
+	operator = OP_INTERSECTS;
+    else if (parm.operator->answer[0] == 't')
+	operator = OP_TOUCHES;
+    else if (parm.operator->answer[0] == 'c' && parm.operator->answer[1] == 'r')
+	operator = OP_CROSSES;
+    else if (parm.operator->answer[0] == 'w')
+	operator = OP_WITHIN;
+    else if (parm.operator->answer[0] == 'c' && parm.operator->answer[1] == 'o')
+	operator = OP_CONTAINS;
+    else if (parm.operator->answer[0] == 'o')
+	operator = OP_OVERLAPS;
+    else if (parm.operator->answer[0] == 'r')
+	operator = OP_RELATE;
+    else
+	G_fatal_error(_("Unknown operator"));
+    if (operator != OP_OVERLAPS && flag.geos && !flag.geos->answer) {
+	G_fatal_error(_("Enable GEOS operators (flag '%c') to use '%s'"),
+		      flag.geos->key, parm.operator->answer);
-    if (operator_opt->answer[0] == 'o')
-	operator = OP_OVERLAP;
+    if (operator == OP_RELATE && !parm.relate->answer) {
+	G_fatal_error(_("Required parameter <%s> not set"),
+		      parm.relate->key);
+    for (iopt = 0; iopt < 2; iopt++) {
+	itype[iopt] = Vect_option_to_types(parm.type[iopt]);
+	ifield[iopt] = atoi(parm.field[iopt]->answer);
-    for (input = 0; input < 2; input++) {
-	type[input] = Vect_option_to_types(type_opt[input]);
-	field[input] = atoi(field_opt[input]->answer);
-	Vect_check_input_output_name(in_opt[input]->answer, out_opt->answer,
+	Vect_check_input_output_name(parm.input[iopt]->answer, parm.output->answer,
 				     GV_FATAL_EXIT);
 	Vect_set_open_level(2);
-	Vect_open_old(&(In[input]), in_opt[input]->answer, "");
+	Vect_open_old(&(In[iopt]), parm.input[iopt]->answer, "");
     /* Read field info */
-    IFi = Vect_get_field(&(In[0]), field[0]);
+    IFi = Vect_get_field(&(In[0]), ifield[0]);
     BPoints = Vect_new_line_struct();
@@ -219,20 +196,26 @@
     /* Open output */
-    Vect_open_new(&Out, out_opt->answer, Vect_is_3d(&(In[0])));
-    Vect_set_map_name(&Out, "Output from v.select");
+    Vect_open_new(&Out, parm.output->answer, Vect_is_3d(&(In[0])));
+    Vect_set_map_name(&Out, _("Output from v.select"));
     Vect_set_person(&Out, G_whoami());
     Vect_copy_head_data(&(In[0]), &Out);
     Vect_hist_copy(&(In[0]), &Out);
     Vect_hist_command(&Out);
+    nskipped = 0;
     nalines = Vect_get_num_lines(&(In[0]));
+#ifdef HAVE_GEOS
+    initGEOS(G_message, G_fatal_error);
+    GEOSGeometry *AGeom = NULL;
+#endif
     /* Alloc space for input lines array */
     ALines = (int *)G_calloc(nalines + 1, sizeof(int));
     /* Lines in A. Go through all lines and mark those that meets condition */
-    if (type[0] & (GV_POINTS | GV_LINES)) {
+    if (itype[0] & (GV_POINTS | GV_LINES)) {
 	G_message(_("Processing features..."));
 	for (aline = 1; aline <= nalines; aline++) {
@@ -242,75 +225,112 @@
 	    G_percent(aline, nalines, 2);	/* must be before any continue */
 	    /* Check category */
-	    if (Vect_get_line_cat(&(In[0]), aline, field[0]) < 0)
+	    if (Vect_get_line_cat(&(In[0]), aline, ifield[0]) < 0) {
+		nskipped++;
 		continue;
 	    /* Read line and check type */
-	    if (!(Vect_read_line(&(In[0]), APoints, NULL, aline) & type[0]))
+	    ltype = Vect_read_line(&(In[0]), APoints, NULL, aline);
+	    if (!(ltype & itype[0]))
 		continue;
 	    Vect_get_line_box(&(In[0]), aline, &abox);
 	    abox.T = PORT_DOUBLE_MAX;
 	    abox.B = -PORT_DOUBLE_MAX;
+	    if (flag.geos && flag.geos->answer) {
+		if (!(ltype & (GV_POINT | GV_LINE)))
+		    continue;
+		AGeom = Vect_line_to_geos(&(In[0]), APoints, ltype);
+		if (!AGeom)
+				  aline, Vect_get_full_name(&(In[0])));
 	    /* Check if this line overlaps any feature in B */
 	    /* x Lines in B */
-	    if (type[1] & (GV_POINTS | GV_LINES)) {
+	    if (itype[1] & (GV_POINTS | GV_LINES)) {
 		int i;
 		int found = 0;
 		/* Lines */
-		Vect_select_lines_by_box(&(In[1]), &abox, type[1], List);
+		Vect_select_lines_by_box(&(In[1]), &abox, itype[1], List);
 		for (i = 0; i < List->n_values; i++) {
 		    int bline;
 		    bline = List->value[i];
 		    G_debug(3, "  bline = %d", bline);
-		    if (!Vect_get_line_cat(&(In[1]), bline, field[1]) < 0)
+		    if (!Vect_get_line_cat(&(In[1]), bline, ifield[1]) < 0) {
+			nskipped++;
 			continue;
+			if(line_relate_geos(&(In[1]), AGeom,
+					    bline, operator, parm.relate->answer)) {
+			    found = 1;
+			    break;
+		    else {
+			Vect_read_line(&(In[1]), BPoints, NULL, bline);
-		    Vect_read_line(&(In[1]), BPoints, NULL, bline);
-		    if (Vect_line_check_intersection(APoints, BPoints, 0)) {
-			found = 1;
-			break;
+			if (Vect_line_check_intersection(APoints, BPoints, 0)) {
+			    found = 1;
+			    break;
 		if (found) {
 		    ALines[aline] = 1;
 		    continue;	/* Go to next A line */
 	    /* x Areas in B. */
-	    if (type[1] & GV_AREA) {
+	    if (itype[1] & GV_AREA) {
 		int i;
 		Vect_select_areas_by_box(&(In[1]), &abox, List);
 		    int barea;
 		    barea = List->value[i];
 		    G_debug(3, "  barea = %d", barea);
-		    if (Vect_get_area_cat(&(In[1]), barea, field[1]) < 0)
+		    if (Vect_get_area_cat(&(In[1]), barea, ifield[1]) < 0) {
+			nskipped++;
 			continue;
-		    if (line_overlap_area(&(In[0]), aline, &(In[1]), barea)) {
-			break;
+			if(area_relate_geos(&(In[1]), AGeom,
+					    barea, operator, parm.relate->answer)) {
+			    ALines[aline] = 1;
+			    break;
+		    else {
+			if (line_overlap_area(&(In[0]), aline, &(In[1]), barea)) {
+			    break;
+		GEOSGeom_destroy(AGeom);
+		AGeom = NULL;
     /* Areas in A. */
-    if (type[0] & GV_AREA) {
+    if (itype[0] & GV_AREA) {
 	int aarea, naareas;
 	G_message(_("Processing areas..."));
@@ -323,33 +343,54 @@
 	    G_percent(aarea, naareas, 2);	/* must be before any continue */
-	    if (Vect_get_area_cat(&(In[0]), aarea, field[0]) < 0)
+	    if (Vect_get_area_cat(&(In[0]), aarea, ifield[0]) < 0) {
+		nskipped++;
 		continue;
 	    Vect_get_area_box(&(In[0]), aarea, &abox);
+		AGeom = Vect_read_area_geos(&(In[0]), aarea);
+		if (!AGeom)
 	    /* x Lines in B */
 		    int bline;
-		    if (Vect_get_line_cat(&(In[1]), bline, field[1]) < 0)
+		    if (Vect_get_line_cat(&(In[1]), bline, ifield[1]) < 0) {
+			nskipped++;
 			continue;
-		    if (line_overlap_area(&(In[1]), bline, &(In[0]), aarea)) {
-			add_aarea(&(In[0]), aarea, ALines);
-			continue;
+			    add_aarea(&(In[0]), aarea, ALines);
+			    break;
+		    else {
+			if (line_overlap_area(&(In[1]), bline, &(In[0]), aarea)) {
+			    continue;
 	    /* x Areas in B */
 		int naisles;
 		int found = 0;
@@ -389,25 +430,36 @@
 			barea = TmpList->value[j];
+			    nskipped++;
 			    continue;
 			/* Check if any centroid of area B is in area A.
 			 * This test is important in if area B is completely within area A */
 			bcentroid = Vect_get_area_centroid(&(In[1]), barea);
 			Vect_read_line(&(In[1]), BPoints, NULL, bcentroid);
-			    (&(In[0]), aarea, BPoints->x[0], BPoints->y[0])) {
-			    found = 1;
-			    break;
+				found = 1;
+				break;
-			/* Check intersectin of lines from List with area B */
-			    (&(In[0]), aline, &(In[1]), barea)) {
-			    found = 1;
-			    break;
+			else {
+			    if (Vect_point_in_area(&(In[0]), aarea,
+						   BPoints->x[0], BPoints->y[0])) {
+				found = 1;
+				break;
+			    /* Check intersectin of lines from List with area B */
+						  &(In[1]), barea)) {
+				found = 1;
+				break;
 		    if (found) {
@@ -416,11 +468,19 @@
+		AGeom = NULL;
     Vect_close(&(In[1]));
+#ifdef HAVE_GEOS
+    finishGEOS();
+#endif
     /* Write lines */
     nfields = Vect_cidx_get_num_fields(&(In[0]));
     cats = (int **)G_malloc(nfields * sizeof(int *));
@@ -441,14 +501,14 @@
 	G_debug(4, "aline = %d ALines[aline] = %d", aline, ALines[aline]);
-	if ((!r_flag->answer && !(ALines[aline])) ||
-	    (r_flag->answer && ALines[aline]))
+	if ((!flag.reverse->answer && !(ALines[aline])) ||
+	    (flag.reverse->answer && ALines[aline]))
 	    continue;
 	atype = Vect_read_line(&(In[0]), APoints, ACats, aline);
 	Vect_write_line(&Out, atype, APoints, ACats);
-	if (!(table_flag->answer) && (IFi != NULL)) {
+	if (!(flag.table->answer) && (IFi != NULL)) {
 	    for (i = 0; i < ACats->n_cats; i++) {
 		int f, j;
@@ -465,7 +525,7 @@
     /* Copy tables */
-    if (!(table_flag->answer)) {
+    if (!(flag.table->answer)) {
 	int ttype, ntabs = 0;
 	G_message(_("Writing attributes..."));
@@ -529,7 +589,11 @@
     Vect_build(&Out);
     Vect_close(&Out);
-    G_done_msg(" ");
+    if (nskipped > 0) {
+      G_warning(_("%d features without category skipped"), nskipped);
+    G_done_msg(_("%d features written to output."), Vect_get_num_lines(&Out));
     exit(EXIT_SUCCESS);
Added: grass/trunk/vector/v.select/overlap.c
--- grass/trunk/vector/v.select/overlap.c	                        (rev 0)
+++ grass/trunk/vector/v.select/overlap.c	2009-03-29 13:53:03 UTC (rev 36512)
@@ -0,0 +1,90 @@
+#include "proto.h"
+/* Add all elements of area A to the list */
+void add_aarea(struct Map_info *In, int aarea, int *ALines)
+    int i, j, aline, naisles, aisle, acentroid;
+    static struct ilist *BoundList = NULL;
+    if (!BoundList)
+	BoundList = Vect_new_list();
+    acentroid = Vect_get_area_centroid(In, aarea);
+    ALines[acentroid] = 1;
+    Vect_get_area_boundaries(In, aarea, BoundList);
+    for (i = 0; i < BoundList->n_values; i++) {
+	aline = abs(BoundList->value[i]);
+    naisles = Vect_get_area_num_isles(In, aarea);
+    for (j = 0; j < naisles; j++) {
+	aisle = Vect_get_area_isle(In, aarea, j);
+	Vect_get_isle_boundaries(In, aisle, BoundList);
+/* Returns 1 if line1 from Map1 overlaps area2 from Map2,
+ *         0 otherwise */
+int line_overlap_area(struct Map_info *LMap, int line, struct Map_info *AMap,
+		      int area)
+    int i, nisles, isle;
+    static struct line_pnts *LPoints = NULL;
+    static struct line_pnts *APoints = NULL;
+    G_debug(4, "line_overlap_area line = %d area = %d", line, area);
+    if (!LPoints) {
+	LPoints = Vect_new_line_struct();
+	APoints = Vect_new_line_struct();
+    /* Read line coordinates */
+    Vect_read_line(LMap, LPoints, NULL, line);
+    /* Try if any of line vertices is within area */
+    for (i = 0; i < LPoints->n_points; i++) {
+	if (Vect_point_in_area(AMap, area, LPoints->x[i], LPoints->y[i])) {
+	    G_debug(4, "  -> line vertex inside area");
+	    return 1;
+    /* Skip points */
+    if (LPoints->n_points < 2)
+	return 0;
+    /* Try intersections of line with area/isles boundary */
+    /* Outer boundary */
+    Vect_get_area_points(AMap, area, APoints);
+    if (Vect_line_check_intersection(LPoints, APoints, 0)) {
+	G_debug(4, "  -> line intersects outer area boundary");
+	return 1;
+    nisles = Vect_get_area_num_isles(AMap, area);
+    for (i = 0; i < nisles; i++) {
+	isle = Vect_get_area_isle(AMap, area, i);
+	Vect_get_isle_points(AMap, isle, APoints);
+	    G_debug(4, "  -> line intersects area island boundary");
+	    return 1;
+    return 0;
Property changes on: grass/trunk/vector/v.select/overlap.c
   + text/x-csrc
   + Author Date Id
   + native
Added: grass/trunk/vector/v.select/proto.h
--- grass/trunk/vector/v.select/proto.h	                        (rev 0)
+++ grass/trunk/vector/v.select/proto.h	2009-03-29 13:53:03 UTC (rev 36512)
@@ -0,0 +1,20 @@
+#define OP_EQUALS     0
+#define OP_DISJOINT   1
+#define OP_INTERSECTS 2
+#define OP_TOUCHES    3
+#define OP_CROSSES    4
+#define OP_WITHIN     5
+#define OP_CONTAINS   6
+#define OP_OVERLAPS   7
+#define OP_RELATE     8
+/* geos.c */
+int line_relate_geos(const struct Map_info *, const GEOSGeometry *,
+		     int, int, const char *);
+int area_relate_geos(const struct Map_info *, const GEOSGeometry *,
+/* overlap.c */
+void add_aarea(struct Map_info *, int, int *);
+int line_overlap_area(struct Map_info *, int, struct Map_info *, int);
