[GRASS-SVN] r36533 - grass/trunk/lib/vector/diglib
Mon Mar 30 12:16:08 EDT 2009
Author: mmetz
Date: 2009-03-30 12:16:06 -0400 (Mon, 30 Mar 2009)
New Revision: 36533
   grass/trunk/lib/vector/diglib/poly.c
find poly orientation now deals with partially collapsed boundaries
Modified: grass/trunk/lib/vector/diglib/poly.c
--- grass/trunk/lib/vector/diglib/poly.c	2009-03-30 16:14:50 UTC (rev 36532)
+++ grass/trunk/lib/vector/diglib/poly.c	2009-03-30 16:16:06 UTC (rev 36533)
@@ -5,6 +5,7 @@
  * AUTHOR(S):    Original author CERL, probably Dave Gerdes.
  *               Update to GRASS 5.7 Radim Blazek.
+ *               Update to GRASS 7.0 Markus Metz
  * PURPOSE:      Lower level functions for reading/writing/manipulating vectors.
@@ -24,15 +25,18 @@
 #endif
- **  fills BPoints (must be inited previously) by points from input
- **  array LPoints. Each input LPoints[i] must have at least 2 points.
- **  returns number of points or -1 on error
+ * fills BPoints (must be inited previously) by points from input
+ * array LPoints
+ * each input LPoints[i] must have at least 2 points
+ * returns number of points or -1 on error
-int dig_get_poly_points(int n_lines, struct line_pnts **LPoints, int *direction,	/* line direction: > 0 or < 0 */
-			struct line_pnts *BPoints)
+int dig_get_poly_points(int n_lines, struct line_pnts **LPoints,
+	    int *direction,	/* line direction: > 0 or < 0 */
+	    struct line_pnts *BPoints)
     register int i, j, point, start, end, inc;
     struct line_pnts *Points;
@@ -48,7 +52,7 @@
     n_points = 0;
     for (i = 0; i < n_lines; i++) {
 	Points = LPoints[i];
-	n_points += Points->n_points - 1;	/* each line from first to last - 1 */
+	n_points += Points->n_points - 1;  /* each line from first to last - 1 */
     n_points++;			/* last point */
@@ -86,12 +90,16 @@
- **  Calculate signed area size for polygon.
- **  Total area is positive for clockwise and negative for counterclockwise
- **  Formula modified from
- **  Sunday, Daniel. 2002. Fast Polygon Area and Newell Normal Computation.
- **  Journal of Graphics Tools; 7(2):9-13.
+ * calculate signed area size for polygon
+ * points must be closed polygon with first point = last point
+ * formula modified from:
+ * Sunday, Daniel. 2002. Fast Polygon Area and Newell Normal Computation.
+ * Journal of Graphics Tools; 7(2):9-13.
+ * returns signed area, positive for clockwise, negative for
+ * counterclockwise, 0 for degenerate
 int dig_find_area_poly(struct line_pnts *Points, double *totalarea)
@@ -117,41 +125,44 @@
- * find orientation of polygon
+ * find orientation of polygon (clockwise or counterclockwise)
  * faster than signed area for > 4 vertices
- * return value is positive for CW, negative for CCW, 0 for degenerate
- * Points must be closed polygon
  * this code uses bits and pieces from softSurfer and GEOS
  * (C) 2000 softSurfer (www.softsurfer.com)
  * (C) 2006 Refractions Research Inc.
+ * and now copes with partially collapsed boundaries
+ * the code is long but fast
+ * it can be written much shorter, but that comes with speed penalty
+ * returns orientation, positive for CW, negative for CCW, 0 for degenerate
 double dig_find_poly_orientation(struct line_pnts *Points)
     unsigned int pnext, pprev, pcur = 0;
     unsigned int lastpoint = Points->n_points - 1;
-    double *x, *y;
+    double *x, *y, orientation;
-    /* first find leftmost highest vertex of the polygon */
-    /* could also be leftmost lowest, rightmost highest or rightmost lowest */
     x = Points->x;
     y = Points->y;
+    /* first find leftmost highest vertex of the polygon */
     for (pnext = 1; pnext < lastpoint; pnext++) {
 	if (y[pnext] < y[pcur])
 	    continue;
 	else if (y[pnext] == y[pcur]) {    /* just as high */
-	    if (x[pnext] < x[pcur])   	/* but to the right */
+	    if (x[pnext] > x[pcur])   	   /* but to the right */
 		continue;
 	pcur = pnext;          /* a new leftmost highest vertex */
     /* Points are not pruned, so ... */
-    pprev = pnext = pcur;
+    pnext = pcur;
+    pprev = pcur;
     /* find next distinct point */
     do {
@@ -171,6 +182,131 @@
     /* orientation at vertex pcur == signed area for triangle pprev, pcur, pnext
      * rather use robust determinant of Olivier Devillers? */
-    return (x[pnext] - x[pprev]) * (y[pcur] - y[pprev])
+    orientation =  (x[pnext] - x[pprev]) * (y[pcur] - y[pprev])
          - (x[pcur] - x[pprev]) * (y[pnext] - y[pprev]);
+    if (orientation)
+	return orientation;
+    /* orientation is 0, can happen with dirty boundaries, next check */
+    /* find rightmost highest vertex of the polygon */
+    pcur = 0;
+    for (pnext = 1; pnext < lastpoint; pnext++) {
+	if (y[pnext] < y[pcur])
+	    continue;
+	else if (y[pnext] == y[pcur]) {    /* just as high */
+	    if (x[pnext] < x[pcur])   	/* but to the left */
+		continue;
+	pcur = pnext;          /* a new rightmost highest vertex */
+    /* Points are not pruned, so ... */
+    pnext = pcur;
+    pprev = pcur;
+    /* find next distinct point */
+    do {
+	if (pnext < lastpoint - 1)
+	    pnext++;
+	else
+	    pnext = 0;
+    } while (pnext != pcur && x[pcur] == x[pnext] && y[pcur] == y[pnext]);
+    /* find previous distinct point */
+    do {
+	if (pprev > 0)
+	    pprev--;
+	else
+	    pprev = lastpoint - 1;
+    } while (pprev != pcur && x[pcur] == x[pprev] && y[pcur] == y[pprev]);
+    /* orientation at vertex pcur == signed area for triangle pprev, pcur, pnext
+     * rather use robust determinant of Olivier Devillers? */
+         - (x[pcur] - x[pprev]) * (y[pnext] - y[pprev]);
+    if (orientation)
+    /* orientation is 0, next check */
+    /* find leftmost lowest vertex of the polygon */
+    pcur = 0;
+	if (y[pnext] > y[pcur])
+	    continue;
+	else if (y[pnext] == y[pcur]) {    /* just as low */
+		continue;
+	pcur = pnext;          /* a new leftmost lowest vertex */
+    pnext = pcur;
+    pprev = pcur;
+    do {
+	    pnext++;
+	else
+	    pnext = 0;
+    do {
+	if (pprev > 0)
+	    pprev--;
+	else
+    if (orientation)
+    /* orientation is 0, last check */
+    /* find rightmost lowest vertex of the polygon */
+    pcur = 0;
+	    continue;
+		continue;
+	pcur = pnext;          /* a new rightmost lowest vertex */
+    pnext = pcur;
+    pprev = pcur;
+    do {
+	    pnext++;
+	else
+	    pnext = 0;
+    do {
+	if (pprev > 0)
+	    pprev--;
+	else
+    return orientation;   /* 0 for degenerate */
