[GRASS-SVN] r36539 - grass/trunk/lib/vector/Vlib
Mon Mar 30 16:13:16 EDT 2009
Author: martinl
Date: 2009-03-30 16:13:06 -0400 (Mon, 30 Mar 2009)
New Revision: 36539
   grass/trunk/lib/vector/Vlib/geos.c
remove unused variable from geos.c
Modified: grass/trunk/lib/vector/Vlib/geos.c
--- grass/trunk/lib/vector/Vlib/geos.c	2009-03-30 18:56:18 UTC (rev 36538)
+++ grass/trunk/lib/vector/Vlib/geos.c	2009-03-30 20:13:06 UTC (rev 36539)
@@ -37,9 +37,7 @@
 GEOSGeometry *Vect_read_line_geos(const struct Map_info *Map, int line)
     int type, dim;
-    GEOSGeometry *geom;
-    GEOSCoordSequence *pseq;
     if (!Points)
 	Points = Vect_new_line_struct();
@@ -70,7 +68,7 @@
 GEOSGeometry *Vect_read_area_geos(const struct Map_info * Map, int area)
-    int i, type, dim, nholes, isle;
+    int i, dim, nholes, isle;
     GEOSGeometry *boundary, **holes;
     if (!Points)
