[GRASS-SVN] r36546 - grass/trunk
Tue Mar 31 01:34:36 EDT 2009
Author: martinl
Date: 2009-03-31 01:34:35 -0400 (Tue, 31 Mar 2009)
New Revision: 36546
   grass/trunk/configure
   grass/trunk/configure.in
checking for geos_c.h
Modified: grass/trunk/configure
--- grass/trunk/configure	2009-03-31 04:27:55 UTC (rev 36545)
+++ grass/trunk/configure	2009-03-31 05:34:35 UTC (rev 36546)
@@ -7681,13 +7681,58 @@
   if test "$GEOS_CONFIG" = "no" ; then
     { echo "configure: error: *** couldn't find geos-config" 1>&2; exit 1; }
   fi
   if test "$GEOS_CONFIG" != "" ; then
     GEOS_LIBS=`"$GEOS_CONFIG" --libs`
     GEOS_CFLAGS=`"$GEOS_CONFIG" --cflags`
     USE_GEOS=1
   fi
+ac_save_cppflags="$CPPFLAGS"
+CPPFLAGS="$GEOS_CFLAGS $CPPFLAGS"
+for ac_hdr in geos_c.h
+do
+ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
+echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
+echo "configure:7699: checking for $ac_hdr" >&5
+cat > conftest.$ac_ext <<EOF
+#line 7702 "configure"
+#include "confdefs.h"
+#include <$ac_hdr>
+EOF
+ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
+{ (eval echo configure:7707: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
+if test -z "$ac_err"; then
+  rm -rf conftest*
+  eval "ac_cv_header_$ac_safe=yes"
+else
+  echo "$ac_err" >&5
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+  eval "ac_cv_header_$ac_safe=no"
+fi
+rm -f conftest*
+if eval "test \"`echo '$ac_cv_header_'$ac_safe`\" = yes"; then
+  echo "$ac_t""yes" 1>&6
+    ac_tr_hdr=HAVE_`echo $ac_hdr | sed 'y%abcdefghijklmnopqrstuvwxyz./-%ABCDEFGHIJKLMNOPQRSTUVWXYZ___%'`
+  cat >> confdefs.h <<EOF
+#define $ac_tr_hdr 1
+EOF
+else
+  echo "$ac_t""no" 1>&6
+{ echo "configure: error: *** Unable to locate GEOS includes." 1>&2; exit 1; }
+fi
+done
+CPPFLAGS=$ac_save_cppflags
   cat >> confdefs.h <<\EOF
 #define HAVE_GEOS 1
 EOF
@@ -7702,7 +7747,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:7706: checking whether to use TIFF" >&5
+echo "configure:7751: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -7722,7 +7767,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:7726: checking for location of TIFF includes" >&5
+echo "configure:7771: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -7748,15 +7793,15 @@
 do
-echo "configure:7752: checking for $ac_hdr" >&5
+echo "configure:7797: checking for $ac_hdr" >&5
-#line 7755 "configure"
+#line 7800 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7760: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7805: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7790,7 +7835,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7794: checking for location of TIFF library" >&5
+echo "configure:7839: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7821,13 +7866,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7825: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7870: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ltiff  $LIBS"
-#line 7831 "configure"
+#line 7876 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -7838,7 +7883,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7887: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -7857,13 +7902,13 @@
-echo "configure:7861: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7906: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 7867 "configure"
+#line 7912 "configure"
@@ -7874,7 +7919,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7923: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7893,13 +7938,13 @@
-echo "configure:7897: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7942: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 7903 "configure"
+#line 7948 "configure"
@@ -7910,7 +7955,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7914: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7929,13 +7974,13 @@
-echo "configure:7933: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7978: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 7939 "configure"
+#line 7984 "configure"
@@ -7946,7 +7991,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7995: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7965,13 +8010,13 @@
-echo "configure:7969: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8014: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 7975 "configure"
+#line 8020 "configure"
@@ -7982,7 +8027,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7986: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8031: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8001,13 +8046,13 @@
-echo "configure:8005: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8050: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8011 "configure"
+#line 8056 "configure"
@@ -8018,7 +8063,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8037,13 +8082,13 @@
-echo "configure:8041: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8086: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8047 "configure"
+#line 8092 "configure"
@@ -8054,7 +8099,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8058: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8103: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8073,13 +8118,13 @@
-echo "configure:8077: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8122: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8083 "configure"
+#line 8128 "configure"
@@ -8090,7 +8135,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8094: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8188,7 +8233,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8192: checking whether to use PNG" >&5
+echo "configure:8237: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -8207,7 +8252,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8211: checking for location of PNG includes" >&5
+echo "configure:8256: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8233,15 +8278,15 @@
 do
-echo "configure:8237: checking for $ac_hdr" >&5
+echo "configure:8282: checking for $ac_hdr" >&5
-#line 8240 "configure"
+#line 8285 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8245: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8290: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8275,7 +8320,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8279: checking for location of PNG library" >&5
+echo "configure:8324: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8300,13 +8345,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8304: checking for png_read_image in -lpng" >&5
+echo "configure:8349: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8310 "configure"
+#line 8355 "configure"
@@ -8317,7 +8362,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:8321: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8359,7 +8404,7 @@
 echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:8363: checking whether to use Tcl/Tk" >&5
+echo "configure:8408: checking whether to use Tcl/Tk" >&5
 echo "$ac_t"""$with_tcltk"" 1>&6
 case "$with_tcltk" in
 	"no")	USE_TCLTK=	;;
@@ -8379,7 +8424,7 @@
 echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:8383: checking for location of Tcl/Tk includes" >&5
+echo "configure:8428: checking for location of Tcl/Tk includes" >&5
 case "$with_tcltk_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -8405,15 +8450,15 @@
 do
-echo "configure:8409: checking for $ac_hdr" >&5
+echo "configure:8454: checking for $ac_hdr" >&5
-#line 8412 "configure"
+#line 8457 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8417: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8462: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8450,15 +8495,15 @@
 do
-echo "configure:8454: checking for $ac_hdr" >&5
+echo "configure:8499: checking for $ac_hdr" >&5
-#line 8457 "configure"
+#line 8502 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8462: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8507: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8492,7 +8537,7 @@
 echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:8496: checking Tcl version" >&5
+echo "configure:8541: checking Tcl version" >&5
 CPPFLAGS="$TCLINCDIR $CPPFLAGS"
 if test "$cross_compiling" = yes; then
@@ -8500,7 +8545,7 @@
     echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
-#line 8504 "configure"
+#line 8549 "configure"
 #include <stdio.h>
@@ -8512,7 +8557,7 @@
 EOF
-if { (eval echo configure:8516: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8561: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tcl_ver=`cat conftestdata`
     echo "$ac_t""$tcl_ver" 1>&6
@@ -8530,7 +8575,7 @@
 echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:8534: checking Tk version" >&5
+echo "configure:8579: checking Tk version" >&5
 CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -8538,7 +8583,7 @@
 else
-#line 8542 "configure"
+#line 8587 "configure"
 #include <stdio.h>
@@ -8550,7 +8595,7 @@
 EOF
-if { (eval echo configure:8554: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8599: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tk_ver=`cat conftestdata`
     echo "$ac_t""$tk_ver" 1>&6
@@ -8579,7 +8624,7 @@
 echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:8583: checking for location of Tcl/Tk library" >&5
+echo "configure:8628: checking for location of Tcl/Tk library" >&5
 case "$with_tcltk_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -8609,13 +8654,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:8613: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8658: checking for Tcl_Init in -ltcl" >&5
 ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl $MATHLIB $LIBS"
-#line 8619 "configure"
+#line 8664 "configure"
@@ -8626,7 +8671,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8630: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8645,13 +8690,13 @@
-echo "configure:8649: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8694: checking for Tcl_Init in -ltcl" >&5
 LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 8655 "configure"
+#line 8700 "configure"
@@ -8662,7 +8707,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8666: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8689,13 +8734,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8693: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8738: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 8699 "configure"
+#line 8744 "configure"
@@ -8706,7 +8751,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8710: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8755: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8725,13 +8770,13 @@
-echo "configure:8729: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8774: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 8735 "configure"
+#line 8780 "configure"
@@ -8742,7 +8787,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8791: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8769,13 +8814,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:8773: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8818: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 8779 "configure"
+#line 8824 "configure"
@@ -8786,7 +8831,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8835: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8805,13 +8850,13 @@
-echo "configure:8809: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8854: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 8815 "configure"
+#line 8860 "configure"
@@ -8822,7 +8867,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8871: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8900,13 +8945,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:8904: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:8949: checking for Tk_MainWindow in -ltk" >&5
 ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 8910 "configure"
+#line 8955 "configure"
@@ -8917,7 +8962,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:8921: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8966: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8936,13 +8981,13 @@
-echo "configure:8940: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:8985: checking for Tk_MainWindow in -ltk" >&5
 LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 8946 "configure"
+#line 8991 "configure"
@@ -8953,7 +8998,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:8957: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9002: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8980,13 +9025,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8984: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9029: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 8990 "configure"
+#line 9035 "configure"
@@ -8997,7 +9042,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9001: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9046: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9016,13 +9061,13 @@
-echo "configure:9020: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9065: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9026 "configure"
+#line 9071 "configure"
@@ -9033,7 +9078,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9037: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9082: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9060,13 +9105,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:9064: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9109: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 9070 "configure"
+#line 9115 "configure"
@@ -9077,7 +9122,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9081: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9126: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9096,13 +9141,13 @@
-echo "configure:9100: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9145: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9106 "configure"
+#line 9151 "configure"
@@ -9113,7 +9158,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9162: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9205,7 +9250,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:9209: checking whether to use PostgreSQL" >&5
+echo "configure:9254: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -9232,7 +9277,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9236: checking for location of PostgreSQL includes" >&5
+echo "configure:9281: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9258,15 +9303,15 @@
 do
-echo "configure:9262: checking for $ac_hdr" >&5
+echo "configure:9307: checking for $ac_hdr" >&5
-#line 9265 "configure"
+#line 9310 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9270: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9315: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9304,7 +9349,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9308: checking for location of PostgreSQL library" >&5
+echo "configure:9353: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9333,13 +9378,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9337: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9382: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9343 "configure"
+#line 9388 "configure"
@@ -9350,7 +9395,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9354: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9399: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9369,13 +9414,13 @@
-echo "configure:9373: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9418: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9379 "configure"
+#line 9424 "configure"
@@ -9386,7 +9431,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9390: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9405,13 +9450,13 @@
-echo "configure:9409: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9454: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 9415 "configure"
+#line 9460 "configure"
@@ -9422,7 +9467,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9426: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9471: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9441,13 +9486,13 @@
-echo "configure:9445: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9490: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9451 "configure"
+#line 9496 "configure"
@@ -9458,7 +9503,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9462: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9507: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9515,13 +9560,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9519: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9564: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9525 "configure"
+#line 9570 "configure"
@@ -9532,7 +9577,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9536: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9581: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9554,13 +9599,13 @@
-echo "configure:9558: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9603: checking for PQcmdTuples in -lpq" >&5
-#line 9564 "configure"
+#line 9609 "configure"
@@ -9571,7 +9616,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9575: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9620: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9614,7 +9659,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9618: checking whether to use MySQL" >&5
+echo "configure:9663: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -9634,7 +9679,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9638: checking for location of MySQL includes" >&5
+echo "configure:9683: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9660,15 +9705,15 @@
 do
-echo "configure:9664: checking for $ac_hdr" >&5
+echo "configure:9709: checking for $ac_hdr" >&5
-#line 9667 "configure"
+#line 9712 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9672: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9717: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9705,7 +9750,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9709: checking for location of MySQL library" >&5
+echo "configure:9754: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9736,13 +9781,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9740: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9785: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 9746 "configure"
+#line 9791 "configure"
@@ -9753,7 +9798,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9757: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9802: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9772,13 +9817,13 @@
-echo "configure:9776: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9821: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9782 "configure"
+#line 9827 "configure"
@@ -9789,7 +9834,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9793: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9838: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9808,13 +9853,13 @@
-echo "configure:9812: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9857: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9818 "configure"
+#line 9863 "configure"
@@ -9825,7 +9870,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9829: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9844,13 +9889,13 @@
-echo "configure:9848: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9893: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9854 "configure"
+#line 9899 "configure"
@@ -9861,7 +9906,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9865: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9880,13 +9925,13 @@
-echo "configure:9884: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9929: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9890 "configure"
+#line 9935 "configure"
@@ -9897,7 +9942,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9946: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9916,13 +9961,13 @@
-echo "configure:9920: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9965: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9926 "configure"
+#line 9971 "configure"
@@ -9933,7 +9978,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9937: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9982: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9952,13 +9997,13 @@
-echo "configure:9956: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10001: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 9962 "configure"
+#line 10007 "configure"
@@ -9969,7 +10014,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10018: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9988,13 +10033,13 @@
-echo "configure:9992: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10037: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 9998 "configure"
+#line 10043 "configure"
@@ -10005,7 +10050,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10054: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10095,7 +10140,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:10099: checking for $ac_word" >&5
+echo "configure:10144: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -10144,10 +10189,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:10148: checking for mysql_server_init" >&5
+echo "configure:10193: checking for mysql_server_init" >&5
-#line 10151 "configure"
+#line 10196 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -10173,7 +10218,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10177: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10222: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -10225,7 +10270,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:10229: checking whether to use SQLite" >&5
+echo "configure:10274: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -10245,7 +10290,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10249: checking for location of SQLite includes" >&5
+echo "configure:10294: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10271,15 +10316,15 @@
 do
-echo "configure:10275: checking for $ac_hdr" >&5
+echo "configure:10320: checking for $ac_hdr" >&5
-#line 10278 "configure"
+#line 10323 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10283: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10328: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10322,7 +10367,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10326: checking for location of SQLite library" >&5
+echo "configure:10371: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10349,13 +10394,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10353: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10398: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 10359 "configure"
+#line 10404 "configure"
@@ -10366,7 +10411,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10370: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10385,13 +10430,13 @@
-echo "configure:10389: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10434: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10395 "configure"
+#line 10440 "configure"
@@ -10402,7 +10447,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10406: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10451: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10455,7 +10500,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10459: checking whether to use FFMPEG" >&5
+echo "configure:10504: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -10475,7 +10520,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10479: checking for location of FFMPEG includes" >&5
+echo "configure:10524: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10501,15 +10546,15 @@
 do
-echo "configure:10505: checking for $ac_hdr" >&5
+echo "configure:10550: checking for $ac_hdr" >&5
-#line 10508 "configure"
+#line 10553 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10513: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10558: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10545,15 +10590,15 @@
 do
-echo "configure:10549: checking for $ac_hdr" >&5
+echo "configure:10594: checking for $ac_hdr" >&5
-#line 10552 "configure"
+#line 10597 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10557: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10602: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10589,15 +10634,15 @@
 do
-echo "configure:10593: checking for $ac_hdr" >&5
+echo "configure:10638: checking for $ac_hdr" >&5
-#line 10596 "configure"
+#line 10641 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10601: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10646: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10640,7 +10685,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10644: checking for location of FFMPEG library" >&5
+echo "configure:10689: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10667,13 +10712,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10671: checking for av_free in -lavutil" >&5
+echo "configure:10716: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 10677 "configure"
+#line 10722 "configure"
@@ -10684,7 +10729,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10688: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10733: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10703,13 +10748,13 @@
-echo "configure:10707: checking for av_free in -lavutil" >&5
+echo "configure:10752: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 10713 "configure"
+#line 10758 "configure"
@@ -10720,7 +10765,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10724: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10765,13 +10810,13 @@
 echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10769: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10814: checking for avcodec_init in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 10775 "configure"
+#line 10820 "configure"
@@ -10782,7 +10827,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10786: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10831: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10801,13 +10846,13 @@
-echo "configure:10805: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10850: checking for avcodec_init in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10811 "configure"
+#line 10856 "configure"
@@ -10818,7 +10863,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10863,13 +10908,13 @@
 echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10867: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10912: checking for av_set_parameters in -lavformat" >&5
 ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 10873 "configure"
+#line 10918 "configure"
@@ -10880,7 +10925,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10899,13 +10944,13 @@
-echo "configure:10903: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10948: checking for av_set_parameters in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10909 "configure"
+#line 10954 "configure"
@@ -10916,7 +10961,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10920: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10965: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10976,7 +11021,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10980: checking whether to use OpenGL" >&5
+echo "configure:11025: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -11010,7 +11055,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:11014: checking for location of OpenGL includes" >&5
+echo "configure:11059: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -11036,15 +11081,15 @@
 do
-echo "configure:11040: checking for $ac_hdr" >&5
+echo "configure:11085: checking for $ac_hdr" >&5
-#line 11043 "configure"
+#line 11088 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11048: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11093: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11078,7 +11123,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:11082: checking for location of OpenGL library" >&5
+echo "configure:11127: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -11107,13 +11152,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:11111: checking for glBegin in -lGL" >&5
+echo "configure:11156: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11117 "configure"
+#line 11162 "configure"
@@ -11124,7 +11169,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11128: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11173: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11143,13 +11188,13 @@
-echo "configure:11147: checking for glBegin in -lGL" >&5
+echo "configure:11192: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 11153 "configure"
+#line 11198 "configure"
@@ -11160,7 +11205,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11164: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11209: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11179,13 +11224,13 @@
-echo "configure:11183: checking for glBegin in -lGL" >&5
+echo "configure:11228: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 11189 "configure"
+#line 11234 "configure"
@@ -11196,7 +11241,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11200: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11245: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11215,13 +11260,13 @@
-echo "configure:11219: checking for glBegin in -lGL" >&5
+echo "configure:11264: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11225 "configure"
+#line 11270 "configure"
@@ -11232,7 +11277,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11236: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11281: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11294,13 +11339,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11298: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11343: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11304 "configure"
+#line 11349 "configure"
@@ -11311,7 +11356,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11315: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11360: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11330,13 +11375,13 @@
-echo "configure:11334: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11379: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11340 "configure"
+#line 11385 "configure"
@@ -11347,7 +11392,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11351: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11396: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11394,10 +11439,10 @@
 LIBS=" $OPENGLLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11398: checking for glXCreatePbuffer" >&5
+echo "configure:11443: checking for glXCreatePbuffer" >&5
-#line 11401 "configure"
+#line 11446 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -11420,7 +11465,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11424: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11469: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -11457,10 +11502,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11461: checking for glXCreateGLXPixmap" >&5
+echo "configure:11506: checking for glXCreateGLXPixmap" >&5
-#line 11464 "configure"
+#line 11509 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -11483,7 +11528,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11487: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11532: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -11526,7 +11571,7 @@
 echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:11530: checking for location of OpenGL framework" >&5
+echo "configure:11575: checking for location of OpenGL framework" >&5
 case "$with_opengl_framework" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -11550,15 +11595,15 @@
 do
-echo "configure:11554: checking for $ac_hdr" >&5
+echo "configure:11599: checking for $ac_hdr" >&5
-#line 11557 "configure"
+#line 11602 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11562: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11607: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11594,10 +11639,10 @@
 LIBS="-framework OpenGL -framework AGL -framework ApplicationServices  $LIBS"
 LDFLAGS="$OPENGLPATH $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11598: checking for glBegin" >&5
+echo "configure:11643: checking for glBegin" >&5
-#line 11601 "configure"
+#line 11646 "configure"
     which can conflict with char glBegin(); below.  */
@@ -11620,7 +11665,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11624: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11669: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -11657,10 +11702,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11661: checking for gluBeginCurve" >&5
+echo "configure:11706: checking for gluBeginCurve" >&5
-#line 11664 "configure"
+#line 11709 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -11683,7 +11728,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11687: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11732: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -11731,7 +11776,7 @@
-echo "configure:11735: checking for location of OpenGL includes" >&5
+echo "configure:11780: checking for location of OpenGL includes" >&5
@@ -11757,15 +11802,15 @@
 do
-echo "configure:11761: checking for $ac_hdr" >&5
+echo "configure:11806: checking for $ac_hdr" >&5
-#line 11764 "configure"
+#line 11809 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11769: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11814: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11799,7 +11844,7 @@
-echo "configure:11803: checking for location of OpenGL library" >&5
+echo "configure:11848: checking for location of OpenGL library" >&5
@@ -11824,18 +11869,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11828: checking for OpenGL library" >&5
+echo "configure:11873: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 11832 "configure"
+#line 11877 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:11839: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -11859,18 +11904,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11863: checking for GLU library" >&5
+echo "configure:11908: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 11867 "configure"
+#line 11912 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:11874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11919: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -11919,7 +11964,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11923: checking whether to use ODBC" >&5
+echo "configure:11968: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -11938,7 +11983,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11942: checking for location of ODBC includes" >&5
+echo "configure:11987: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11964,15 +12009,15 @@
 do
-echo "configure:11968: checking for $ac_hdr" >&5
+echo "configure:12013: checking for $ac_hdr" >&5
-#line 11971 "configure"
+#line 12016 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11976: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12021: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12006,7 +12051,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12010: checking for location of ODBC library" >&5
+echo "configure:12055: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12031,13 +12076,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12035: checking for SQLConnect in -lodbc" >&5
+echo "configure:12080: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 12041 "configure"
+#line 12086 "configure"
@@ -12048,7 +12093,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12052: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12097: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12073,13 +12118,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12077: checking for SQLConnect in -liodbc" >&5
+echo "configure:12122: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 12083 "configure"
+#line 12128 "configure"
@@ -12090,7 +12135,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12094: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12115,11 +12160,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12119: checking for ODBC library" >&5
+echo "configure:12164: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 12123 "configure"
+#line 12168 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -12127,7 +12172,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:12131: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12176,7 +12221,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12180: checking whether to use FFTW" >&5
+echo "configure:12225: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -12195,7 +12240,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12199: checking for location of FFTW includes" >&5
+echo "configure:12244: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12221,15 +12266,15 @@
 do
-echo "configure:12225: checking for $ac_hdr" >&5
+echo "configure:12270: checking for $ac_hdr" >&5
-#line 12228 "configure"
+#line 12273 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12233: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12278: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12257,15 +12302,15 @@
 do
-echo "configure:12261: checking for $ac_hdr" >&5
+echo "configure:12306: checking for $ac_hdr" >&5
-#line 12264 "configure"
+#line 12309 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12269: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12314: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12293,15 +12338,15 @@
 do
-echo "configure:12297: checking for $ac_hdr" >&5
+echo "configure:12342: checking for $ac_hdr" >&5
-#line 12300 "configure"
+#line 12345 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12305: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12350: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12347,7 +12392,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12351: checking for location of FFTW library" >&5
+echo "configure:12396: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12372,13 +12417,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12376: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12421: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12382 "configure"
+#line 12427 "configure"
@@ -12389,7 +12434,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:12393: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12438: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12414,13 +12459,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12418: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12463: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 12424 "configure"
+#line 12469 "configure"
@@ -12431,7 +12476,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12480: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12456,13 +12501,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12460: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12505: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12466 "configure"
+#line 12511 "configure"
@@ -12473,7 +12518,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12477: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12530,7 +12575,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12534: checking whether to use BLAS" >&5
+echo "configure:12579: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -12551,7 +12596,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12555: checking for location of BLAS includes" >&5
+echo "configure:12600: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12571,7 +12616,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12575: checking for location of BLAS library" >&5
+echo "configure:12620: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12597,15 +12642,15 @@
 do
-echo "configure:12601: checking for $ac_hdr" >&5
+echo "configure:12646: checking for $ac_hdr" >&5
-#line 12604 "configure"
+#line 12649 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12609: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12654: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12640,13 +12685,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12644: checking for dnrm2_ in -lblas" >&5
+echo "configure:12689: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 12650 "configure"
+#line 12695 "configure"
@@ -12657,7 +12702,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12661: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12706: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12676,13 +12721,13 @@
-echo "configure:12680: checking for dnrm2_ in -lblas" >&5
+echo "configure:12725: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12686 "configure"
+#line 12731 "configure"
@@ -12693,7 +12738,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12697: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12742: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12737,13 +12782,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12741: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12786: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 12747 "configure"
+#line 12792 "configure"
 #include "confdefs.h"
@@ -12754,7 +12799,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:12758: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12803: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12769,13 +12814,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo "$ac_t""yes" 1>&6
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12773: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12818: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 12779 "configure"
+#line 12824 "configure"
@@ -12786,7 +12831,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12835: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12801,13 +12846,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12805: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:12850: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12811 "configure"
+#line 12856 "configure"
@@ -12818,7 +12863,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:12822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12863,16 +12908,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12867: checking for sgemm in $vlib_flags" >&5
+echo "configure:12912: checking for sgemm in $vlib_flags" >&5
-#line 12869 "configure"
+#line 12914 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:12876: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12921: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -12890,13 +12935,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12894: checking for sgemm_ in -lblas" >&5
+echo "configure:12939: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lblas  $LIBS"
-#line 12900 "configure"
+#line 12945 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -12907,7 +12952,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12911: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12956: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -12922,13 +12967,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12926: checking for dgemm_ in -ldgemm" >&5
+echo "configure:12971: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 12932 "configure"
+#line 12977 "configure"
@@ -12939,7 +12984,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12943: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12988: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12954,13 +12999,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:12958: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13003: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 12964 "configure"
+#line 13009 "configure"
@@ -12971,7 +13016,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12975: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13005,13 +13050,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13009: checking for acosp in -lsunmath" >&5
+echo "configure:13054: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 13015 "configure"
+#line 13060 "configure"
@@ -13022,7 +13067,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:13026: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13071: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13037,13 +13082,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13041: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13086: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 13047 "configure"
+#line 13092 "configure"
@@ -13054,7 +13099,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13058: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13103: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13084,13 +13129,13 @@
 # Generic BLAS library
-echo "configure:13088: checking for sgemm_ in -lblas" >&5
+echo "configure:13133: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 13094 "configure"
+#line 13139 "configure"
@@ -13101,7 +13146,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13140,7 +13185,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13144: checking whether to use LAPACK" >&5
+echo "configure:13189: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -13165,7 +13210,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13169: checking for location of LAPACK includes" >&5
+echo "configure:13214: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13185,7 +13230,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13189: checking for location of LAPACK library" >&5
+echo "configure:13234: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13211,15 +13256,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13215: checking for $ac_hdr" >&5
+echo "configure:13260: checking for $ac_hdr" >&5
-#line 13218 "configure"
+#line 13263 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13223: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13268: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -13251,10 +13296,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13255: checking for dsegv_" >&5
+echo "configure:13300: checking for dsegv_" >&5
-#line 13258 "configure"
+#line 13303 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -13277,7 +13322,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13281: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13326: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -13304,13 +13349,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13308: checking for desgv_ in -llapack" >&5
+echo "configure:13353: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 13314 "configure"
+#line 13359 "configure"
@@ -13321,7 +13366,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13325: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13370: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13353,13 +13398,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13357: checking for dgesv_ in -llapack" >&5
+echo "configure:13402: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 13363 "configure"
+#line 13408 "configure"
@@ -13370,7 +13415,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13374: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13419: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13389,13 +13434,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:13393: checking for dgesv_ in -llapack" >&5
+echo "configure:13438: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13399 "configure"
+#line 13444 "configure"
@@ -13406,7 +13451,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13410: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13455: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13462,7 +13507,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13466: checking whether to use Cairo" >&5
+echo "configure:13511: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -13488,7 +13533,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:13492: checking for location of cairo includes" >&5
+echo "configure:13537: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -13514,15 +13559,15 @@
 do
-echo "configure:13518: checking for $ac_hdr" >&5
+echo "configure:13563: checking for $ac_hdr" >&5
-#line 13521 "configure"
+#line 13566 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13526: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13571: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13558,7 +13603,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:13562: checking for location of cairo library" >&5
+echo "configure:13607: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -13578,7 +13623,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:13582: checking for cairo linking flags" >&5
+echo "configure:13627: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -13594,10 +13639,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13598: checking for cairo_create" >&5
+echo "configure:13643: checking for cairo_create" >&5
-#line 13601 "configure"
+#line 13646 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -13620,7 +13665,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13624: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13669: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -13654,10 +13699,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:13658: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:13703: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 13661 "configure"
+#line 13706 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -13680,7 +13725,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13684: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13729: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -13722,7 +13767,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:13726: checking whether to use FreeType" >&5
+echo "configure:13771: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -13741,7 +13786,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:13745: checking for location of FreeType includes" >&5
+echo "configure:13790: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -13767,15 +13812,15 @@
 do
-echo "configure:13771: checking for $ac_hdr" >&5
+echo "configure:13816: checking for $ac_hdr" >&5
-#line 13774 "configure"
+#line 13819 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13779: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13824: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13809,7 +13854,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:13813: checking for location of FreeType library" >&5
+echo "configure:13858: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -13834,13 +13879,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:13838: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:13883: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 13844 "configure"
+#line 13889 "configure"
@@ -13851,7 +13896,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:13855: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13892,7 +13937,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:13896: checking whether to use NLS" >&5
+echo "configure:13941: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -13912,10 +13957,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:13916: checking for gettext" >&5
+echo "configure:13961: checking for gettext" >&5
-#line 13919 "configure"
+#line 13964 "configure"
     which can conflict with char gettext(); below.  */
@@ -13938,7 +13983,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13942: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13987: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -13956,13 +14001,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:13960: checking for gettext in -lintl" >&5
+echo "configure:14005: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 13966 "configure"
+#line 14011 "configure"
@@ -13973,7 +14018,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:13977: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14008,7 +14053,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:14012: checking whether to use C++" >&5
+echo "configure:14057: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -14024,7 +14069,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:14028: checking for $ac_word" >&5
+echo "configure:14073: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -14053,7 +14098,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:14057: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:14102: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -14064,12 +14109,12 @@
 cat > conftest.$ac_ext << EOF
-#line 14068 "configure"
+#line 14113 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:14073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14118: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -14095,19 +14140,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:14099: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:14144: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:14104: checking whether we are using GNU C++" >&5
+echo "configure:14149: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14111: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14156: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -14125,7 +14170,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:14129: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:14174: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -14166,7 +14211,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:14170: checking whether to use openDWG" >&5
+echo "configure:14215: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -14186,7 +14231,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:14190: checking for location of openDGW includes" >&5
+echo "configure:14235: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -14212,15 +14257,15 @@
 do
-echo "configure:14216: checking for $ac_hdr" >&5
+echo "configure:14261: checking for $ac_hdr" >&5
-#line 14219 "configure"
+#line 14264 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14224: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14269: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14254,7 +14299,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:14258: checking for location of openDWG library" >&5
+echo "configure:14303: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -14295,7 +14340,7 @@
 echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:14299: checking whether to use POSIX threads" >&5
+echo "configure:14344: checking whether to use POSIX threads" >&5
 echo "$ac_t"""$with_pthread"" 1>&6
 case "$with_pthread" in
 	"no")	USE_PTHREAD=	;;
@@ -14315,7 +14360,7 @@
 echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:14319: checking for location of POSIX threads includes" >&5
+echo "configure:14364: checking for location of POSIX threads includes" >&5
 case "$with_pthread_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -14341,15 +14386,15 @@
 do
-echo "configure:14345: checking for $ac_hdr" >&5
+echo "configure:14390: checking for $ac_hdr" >&5
-#line 14348 "configure"
+#line 14393 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14353: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14398: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14383,7 +14428,7 @@
 echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:14387: checking for location of POSIX threads library" >&5
+echo "configure:14432: checking for location of POSIX threads library" >&5
 case "$with_pthread_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -14408,10 +14453,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:14412: checking for pthread_create" >&5
+echo "configure:14457: checking for pthread_create" >&5
-#line 14415 "configure"
+#line 14460 "configure"
     which can conflict with char pthread_create(); below.  */
@@ -14434,7 +14479,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14438: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14483: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_pthread_create=yes"
 else
@@ -14461,13 +14506,13 @@
 echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:14465: checking for pthread_create in -lpthread" >&5
+echo "configure:14510: checking for pthread_create in -lpthread" >&5
 ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
 LIBS="-lpthread  $LIBS"
-#line 14471 "configure"
+#line 14516 "configure"
@@ -14478,7 +14523,7 @@
 pthread_create()
 ; return 0; }
 EOF
-if { (eval echo configure:14482: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14527: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14534,7 +14579,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14538: checking for special C compiler options needed for large files" >&5
+echo "configure:14583: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -14542,7 +14587,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 14546 "configure"
+#line 14591 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -14558,7 +14603,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14562: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14607: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   echo "configure: failed program was:" >&5
@@ -14567,7 +14612,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 14571 "configure"
+#line 14616 "configure"
@@ -14583,7 +14628,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14587: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14632: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -14603,11 +14648,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:14607: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:14652: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 14611 "configure"
+#line 14656 "configure"
@@ -14623,14 +14668,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14627: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14672: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   cat conftest.$ac_ext >&5
   rm -rf conftest*
-#line 14634 "configure"
+#line 14679 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -14648,7 +14693,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14652: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14697: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -14667,11 +14712,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:14671: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:14716: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 14675 "configure"
+#line 14720 "configure"
@@ -14687,14 +14732,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14691: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14736: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14698 "configure"
+#line 14743 "configure"
 #define _LARGE_FILES 1
@@ -14712,7 +14757,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14716: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14761: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -14731,25 +14776,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:14735: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14780: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 14739 "configure"
+#line 14784 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14746: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14791: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14753 "configure"
+#line 14798 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -14758,7 +14803,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14762: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14807: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -14779,10 +14824,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:14783: checking if system supports Large Files at all" >&5
+echo "configure:14828: checking if system supports Large Files at all" >&5
-#line 14786 "configure"
+#line 14831 "configure"
 #include <stdio.h>
@@ -14814,7 +14859,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:14818: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14863: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -14843,7 +14888,7 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:14847: checking whether to use Python" >&5
+echo "configure:14892: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
@@ -14863,7 +14908,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:14867: checking for $ac_word" >&5
+echo "configure:14912: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -14908,15 +14953,15 @@
 do
-echo "configure:14912: checking for $ac_hdr" >&5
+echo "configure:14957: checking for $ac_hdr" >&5
-#line 14915 "configure"
+#line 14960 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14920: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14965: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14956,7 +15001,7 @@
   # Extract the first word of "swig", so it can be a program name with args.
 set dummy swig; ac_word=$2
-echo "configure:14960: checking for $ac_word" >&5
+echo "configure:15005: checking for $ac_word" >&5
 case "$SWIG" in
@@ -15002,7 +15047,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:15006: checking whether to use wxWidgets" >&5
+echo "configure:15051: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -15022,7 +15067,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:15026: checking for $ac_word" >&5
+echo "configure:15071: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -15070,7 +15115,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:15074: checking wxWidgets version" >&5
+echo "configure:15119: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -15093,15 +15138,15 @@
 do
-echo "configure:15097: checking for $ac_hdr" >&5
+echo "configure:15142: checking for $ac_hdr" >&5
-#line 15100 "configure"
+#line 15145 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15105: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15150: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in	2009-03-31 04:27:55 UTC (rev 36545)
+++ grass/trunk/configure.in	2009-03-31 05:34:35 UTC (rev 36546)
@@ -750,13 +750,15 @@
   if test "$GEOS_CONFIG" = "no" ; then
     AC_MSG_ERROR([*** couldn't find geos-config])
   fi
   if test "$GEOS_CONFIG" != "" ; then
     GEOS_LIBS=`"$GEOS_CONFIG" --libs`
     GEOS_CFLAGS=`"$GEOS_CONFIG" --cflags`
     USE_GEOS=1
   fi
+  LOC_CHECK_INCLUDES(geos_c.h,GEOS,$GEOS_CFLAGS)
   AC_DEFINE(HAVE_GEOS)
 fi
