[GRASS-SVN] r36945 - grass/branches/releasebranch_6_4
Sat May 2 14:33:34 EDT 2009
Author: neteler
Date: 2009-05-02 14:33:33 -0400 (Sat, 02 May 2009)
New Revision: 36945
   grass/branches/releasebranch_6_4/configure
   grass/branches/releasebranch_6_4/configure.in
don't rely on wx-config being named exactly that (bug #579, debian bug # 526200) (merge from develbranch_6)
Modified: grass/branches/releasebranch_6_4/configure
--- grass/branches/releasebranch_6_4/configure	2009-05-02 16:32:06 UTC (rev 36944)
+++ grass/branches/releasebranch_6_4/configure	2009-05-02 18:33:33 UTC (rev 36945)
@@ -69,15 +69,16 @@
 ac_help="$ac_help
   --with-regex            support regex functionality (default: yes)"
 ac_help="$ac_help
-  --with-python[=path/python-config] enable support for Python SWIG bindings (python-config with path, \
-e.g. '--with-python=/usr/bin/python2.5-config', default: no)"
+  --with-gdal[=path/gdal-config] enable GDAL/OGR support (gdal-config with path, \
+e.g. '--with-gdal=/usr/local/bin/gdal-config')"
 ac_help="$ac_help
+  --with-python[=path/python-config] enable support for Python SWIG bindings \
+(python-config with path, e.g. '--with-python=/usr/bin/python2.5-config', \
+default: no)"
+ac_help="$ac_help
   --with-wxwidgets[=path/wx-config] enable wxWidgets support (wx-config with path, \
 e.g. '--with-wxwidgets=/usr/local/bin/wx-config', default: no)"
 ac_help="$ac_help
-  --with-gdal[=path/gdal-config] enable GDAL/OGR support (gdal-config with path, \
-e.g. '--with-gdal=/usr/local/bin/gdal-config')"
-ac_help="$ac_help
   --with-includes=DIRS    site include files are in DIRS"
 ac_help="$ac_help
   --with-libs=DIRS        site library files are in DIRS"
@@ -728,7 +729,7 @@
 fi
 echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:732: checking host system type" >&5
+echo "configure:733: checking host system type" >&5
 host_alias=$host
 case "$host_alias" in
@@ -751,7 +752,7 @@
 # Extract the first word of "gcc", so it can be a program name with args.
 set dummy gcc; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:755: checking for $ac_word" >&5
+echo "configure:756: checking for $ac_word" >&5
 if test -n "$CC"; then
   ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -778,7 +779,7 @@
   # Extract the first word of "cc", so it can be a program name with args.
 set dummy cc; ac_word=$2
-echo "configure:782: checking for $ac_word" >&5
+echo "configure:783: checking for $ac_word" >&5
@@ -826,7 +827,7 @@
       # Extract the first word of "cl", so it can be a program name with args.
 set dummy cl; ac_word=$2
-echo "configure:830: checking for $ac_word" >&5
+echo "configure:831: checking for $ac_word" >&5
@@ -855,7 +856,7 @@
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:859: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:860: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
 ac_ext=c
 # CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -866,12 +867,12 @@
 cat > conftest.$ac_ext << EOF
-#line 870 "configure"
+#line 871 "configure"
 #include "confdefs.h"
 main(){return(0);}
 EOF
-if { (eval echo configure:875: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:876: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cc_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -897,19 +898,19 @@
   { echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:901: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:902: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
 cross_compiling=$ac_cv_prog_cc_cross
 echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:906: checking whether we are using GNU C" >&5
+echo "configure:907: checking whether we are using GNU C" >&5
 cat > conftest.c <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:913: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:914: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gcc=yes
 else
   ac_cv_prog_gcc=no
@@ -927,7 +928,7 @@
 ac_save_CFLAGS="$CFLAGS"
 CFLAGS=
 echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:931: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:932: checking whether ${CC-cc} accepts -g" >&5
 echo 'void f(){}' > conftest.c
 if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -956,10 +957,10 @@
 fi
 echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:960: checking for Cygwin environment" >&5
+echo "configure:961: checking for Cygwin environment" >&5
 cat > conftest.$ac_ext <<EOF
-#line 963 "configure"
+#line 964 "configure"
 int main() {
@@ -970,7 +971,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:974: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:975: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -986,17 +987,17 @@
 CYGWIN=
 test "$ac_cv_cygwin" = yes && CYGWIN=yes
 echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:990: checking for mingw32 environment" >&5
+echo "configure:991: checking for mingw32 environment" >&5
-#line 993 "configure"
+#line 994 "configure"
 int main() {
 return __MINGW32__;
 ; return 0; }
 EOF
-if { (eval echo configure:1000: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1001: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_mingw32=yes
 else
@@ -1014,7 +1015,7 @@
 echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1018: checking for executable suffix" >&5
+echo "configure:1019: checking for executable suffix" >&5
 if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
   ac_cv_exeext=.exe
@@ -1033,23 +1034,23 @@
 IEEEFLAG=
 echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1037: checking for full floating-point support" >&5
+echo "configure:1038: checking for full floating-point support" >&5
 if test "$cross_compiling" = yes; then
      echo "$ac_t""unknown (cross-compiling)" 1>&6
 echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1042: checking whether "cc -mieee" works" >&5
+echo "configure:1043: checking whether "cc -mieee" works" >&5
 ac_save_cflags=${CFLAGS}
 CFLAGS="$CFLAGS -mieee"
-#line 1046 "configure"
+#line 1047 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:1053: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1054: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
      echo "$ac_t""yes" 1>&6
         IEEEFLAG="-mieee"
@@ -1065,7 +1066,7 @@
 else
-#line 1069 "configure"
+#line 1070 "configure"
 #include <float.h>
@@ -1079,7 +1080,7 @@
 EOF
-if { (eval echo configure:1083: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1084: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
@@ -1092,14 +1093,14 @@
   CFLAGS=-mieee
 echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1096: checking for full floating-point support with -mieee" >&5
+echo "configure:1097: checking for full floating-point support with -mieee" >&5
     { echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
 else
-#line 1103 "configure"
+#line 1104 "configure"
 #include <float.h>
@@ -1113,7 +1114,7 @@
 EOF
-if { (eval echo configure:1117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1118: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
     IEEEFLAG="-mieee"
@@ -1150,7 +1151,7 @@
 # Extract the first word of "pwd", so it can be a program name with args.
 set dummy pwd; ac_word=$2
-echo "configure:1154: checking for $ac_word" >&5
+echo "configure:1155: checking for $ac_word" >&5
 case "$pwd" in
@@ -1188,7 +1189,7 @@
 fi
 echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1192: checking for source directory" >&5
+echo "configure:1193: checking for source directory" >&5
 if test -z "$srcdir" ; then
   SRCDIR=`$pwd`
@@ -1199,7 +1200,7 @@
 echo "$ac_t"""$SRCDIR"" 1>&6
 echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1203: checking for build directory" >&5
+echo "configure:1204: checking for build directory" >&5
 DSTDIR=`$pwd`
 WINDSTDIR=`$winpwd`
@@ -1284,7 +1285,7 @@
 echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1288: checking for MacOSX App" >&5
+echo "configure:1289: checking for MacOSX App" >&5
 case "$enable_macosx_app" in
 	yes)	MACOSX_APP=1	;;
 	no)	MACOSX_APP=	;;
@@ -1307,7 +1308,7 @@
     echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1311: checking how to build libraries" >&5
+echo "configure:1312: checking how to build libraries" >&5
     # Check whether --enable-shared or --disable-shared was given.
 if test "${enable_shared+set}" = set; then
   enableval="$enable_shared"
@@ -1350,7 +1351,7 @@
 # Extract the first word of "ranlib", so it can be a program name with args.
 set dummy ranlib; ac_word=$2
-echo "configure:1354: checking for $ac_word" >&5
+echo "configure:1355: checking for $ac_word" >&5
 if test -n "$RANLIB"; then
   ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -1375,7 +1376,7 @@
 fi
 echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1379: checking how to run the C preprocessor" >&5
+echo "configure:1380: checking how to run the C preprocessor" >&5
 # On Suns, sometimes $CPP names a directory.
 if test -n "$CPP" && test -d "$CPP"; then
   CPP=
@@ -1388,13 +1389,13 @@
   # On the NeXT, cc -E runs the code through the compiler's parser,
   # not just through cpp.
-#line 1392 "configure"
+#line 1393 "configure"
 #include <assert.h>
 Syntax Error
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1398: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1399: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
@@ -1405,13 +1406,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -E -traditional-cpp"
-#line 1409 "configure"
+#line 1410 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1415: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1416: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1422,13 +1423,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -nologo -E"
-#line 1426 "configure"
+#line 1427 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1432: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1433: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1456,7 +1457,7 @@
     # Step 0.a: Enable 64 bit support?
     echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1460: checking if 64bit support is requested" >&5
+echo "configure:1461: checking if 64bit support is requested" >&5
     # Check whether --enable-64bit or --disable-64bit was given.
 if test "${enable_64bit+set}" = set; then
   enableval="$enable_64bit"
@@ -1476,7 +1477,7 @@
     # Step 0.b: Enable Solaris 64 bit VIS support?
     echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1480: checking if 64bit Sparc VIS support is requested" >&5
+echo "configure:1481: checking if 64bit Sparc VIS support is requested" >&5
     # Check whether --enable-64bit-vis or --disable-64bit-vis was given.
 if test "${enable_64bit_vis+set}" = set; then
   enableval="$enable_64bit_vis"
@@ -1500,7 +1501,7 @@
     # there are a few systems, like Next, where this doesn't work.
     echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1504: checking system version (for dynamic loading)" >&5
+echo "configure:1505: checking system version (for dynamic loading)" >&5
     if test -f /usr/lib/NextStep/software_version; then
 	system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
     else
@@ -1526,13 +1527,13 @@
     # Linux can use either -ldl or -ldld for dynamic loading.
     echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1530: checking for dlopen in -ldl" >&5
+echo "configure:1531: checking for dlopen in -ldl" >&5
 ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ldl  $LIBS"
-#line 1536 "configure"
+#line 1537 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -1543,7 +1544,7 @@
 dlopen()
 ; return 0; }
 EOF
-if { (eval echo configure:1547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1548: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -1590,7 +1591,7 @@
     # Extract the first word of "ar", so it can be a program name with args.
 set dummy ar; ac_word=$2
-echo "configure:1594: checking for $ac_word" >&5
+echo "configure:1595: checking for $ac_word" >&5
 if test -n "$AR"; then
   ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -1719,13 +1720,13 @@
 	    # known GMT value.
 	    echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1723: checking for gettimeofday in -lbsd" >&5
+echo "configure:1724: checking for gettimeofday in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 1729 "configure"
+#line 1730 "configure"
@@ -1736,7 +1737,7 @@
 gettimeofday()
 ; return 0; }
 EOF
-if { (eval echo configure:1740: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1741: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1777,13 +1778,13 @@
 	    # is always linked to, for compatibility.
 	    echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1781: checking for inet_ntoa in -lbind" >&5
+echo "configure:1782: checking for inet_ntoa in -lbind" >&5
 ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-lbind  $LIBS"
-#line 1787 "configure"
+#line 1788 "configure"
@@ -1794,7 +1795,7 @@
 inet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:1798: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1799: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1855,13 +1856,13 @@
 	    SHLIB_SUFFIX=".sl"
 	    echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1859: checking for shl_load in -ldld" >&5
+echo "configure:1860: checking for shl_load in -ldld" >&5
 ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
 LIBS="-ldld  $LIBS"
-#line 1865 "configure"
+#line 1866 "configure"
@@ -1872,7 +1873,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:1876: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1877: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1937,13 +1938,13 @@
 	HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
 	    SHLIB_SUFFIX=".sl"
-echo "configure:1941: checking for shl_load in -ldld" >&5
+echo "configure:1942: checking for shl_load in -ldld" >&5
 LIBS="-ldld  $LIBS"
-#line 1947 "configure"
+#line 1948 "configure"
@@ -1954,7 +1955,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:1958: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -2076,15 +2077,15 @@
 	    else
 		ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2080: checking for dld.h" >&5
+echo "configure:2081: checking for dld.h" >&5
-#line 2083 "configure"
+#line 2084 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2088: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2089: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2144,15 +2145,15 @@
 	    else
-echo "configure:2148: checking for dld.h" >&5
+echo "configure:2149: checking for dld.h" >&5
-#line 2151 "configure"
+#line 2152 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2156: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2157: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2249,9 +2250,9 @@
 	    CC_SEARCH_FLAGS=""
 	    LD_SEARCH_FLAGS=""
 	    echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2253: checking for ELF" >&5
+echo "configure:2254: checking for ELF" >&5
-#line 2255 "configure"
+#line 2256 "configure"
 #ifdef __ELF__
@@ -2281,15 +2282,15 @@
 	    # Not available on all versions:  check for include file.
 	    ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2285: checking for dlfcn.h" >&5
+echo "configure:2286: checking for dlfcn.h" >&5
-#line 2288 "configure"
+#line 2289 "configure"
 #include <dlfcn.h>
 EOF
-{ (eval echo configure:2293: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2294: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2313,9 +2314,9 @@
 		CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
 		LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2317: checking for ELF" >&5
+echo "configure:2318: checking for ELF" >&5
-#line 2319 "configure"
+#line 2320 "configure"
 #ifdef __ELF__
@@ -2639,17 +2640,17 @@
 	    # that don't grok the -Bexport option.  Test that it does.
 	    hold_ldflags=$LDFLAGS
 	    echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2643: checking for ld accepts -Bexport flag" >&5
+echo "configure:2644: checking for ld accepts -Bexport flag" >&5
 	    LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2646 "configure"
+#line 2647 "configure"
 int main() {
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:2653: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2654: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   found=yes
 else
@@ -3007,6 +3008,14 @@
 fi
+# Check whether --with-gdal or --without-gdal was given.
+if test "${with_gdal+set}" = set; then
+  withval="$with_gdal"
+fi
 # Check whether --with-python or --without-python was given.
 if test "${with_python+set}" = set; then
   withval="$with_python"
@@ -3015,6 +3024,7 @@
   with_python="no"
 fi
 # Check whether --with-wxwidgets or --without-wxwidgets was given.
 if test "${with_wxwidgets+set}" = set; then
   withval="$with_wxwidgets"
@@ -3026,13 +3036,6 @@
 # With includes and libs options
-# Check whether --with-gdal or --without-gdal was given.
-if test "${with_gdal+set}" = set; then
-  withval="$with_gdal"
-fi
 # Check whether --with-includes or --without-includes was given.
 if test "${with_includes+set}" = set; then
   withval="$with_includes"
@@ -3421,7 +3424,7 @@
 # Done checking fortran
 echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3425: checking for additional include dirs" >&5
+echo "configure:3428: checking for additional include dirs" >&5
 case "$with_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3444,7 +3447,7 @@
 # With libs option
 echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3448: checking for additional library dirs" >&5
+echo "configure:3451: checking for additional library dirs" >&5
 case "$with_libs" in
 	{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3478,7 +3481,7 @@
 # SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
 # ./install, which can be erroneously created by make from ./install.sh.
 echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3482: checking for a BSD compatible install" >&5
+echo "configure:3485: checking for a BSD compatible install" >&5
 if test -z "$INSTALL"; then
   IFS="${IFS= 	}"; ac_save_IFS="$IFS"; IFS=":"
@@ -3531,7 +3534,7 @@
 # Extract the first word of "flex", so it can be a program name with args.
 set dummy flex; ac_word=$2
-echo "configure:3535: checking for $ac_word" >&5
+echo "configure:3538: checking for $ac_word" >&5
 if test -n "$LEX"; then
   ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3562,13 +3565,13 @@
   *) ac_lib=l ;;
   esac
   echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3566: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3569: checking for yywrap in -l$ac_lib" >&5
 ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
 LIBS="-l$ac_lib  $LIBS"
-#line 3572 "configure"
+#line 3575 "configure"
@@ -3579,7 +3582,7 @@
 yywrap()
 ; return 0; }
 EOF
-if { (eval echo configure:3583: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3586: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3604,7 +3607,7 @@
     # Extract the first word of "lex", so it can be a program name with args.
 set dummy lex; ac_word=$2
-echo "configure:3608: checking for $ac_word" >&5
+echo "configure:3611: checking for $ac_word" >&5
 case "$LEXPATH" in
@@ -3644,7 +3647,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:3648: checking for $ac_word" >&5
+echo "configure:3651: checking for $ac_word" >&5
 if test -n "$YACC"; then
   ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3675,7 +3678,7 @@
     # Extract the first word of "yacc", so it can be a program name with args.
 set dummy yacc; ac_word=$2
-echo "configure:3679: checking for $ac_word" >&5
+echo "configure:3682: checking for $ac_word" >&5
 case "$YACCPATH" in
@@ -3713,7 +3716,7 @@
-echo "configure:3717: checking for $ac_word" >&5
+echo "configure:3720: checking for $ac_word" >&5
@@ -3742,7 +3745,7 @@
-echo "configure:3746: checking for $ac_word" >&5
+echo "configure:3749: checking for $ac_word" >&5
@@ -3773,7 +3776,7 @@
-echo "configure:3777: checking for $ac_word" >&5
+echo "configure:3780: checking for $ac_word" >&5
 if test -n "$ENV"; then
   ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3802,7 +3805,7 @@
 # Extract the first word of "perl", so it can be a program name with args.
 set dummy perl; ac_word=$2
-echo "configure:3806: checking for $ac_word" >&5
+echo "configure:3809: checking for $ac_word" >&5
 case "$PERL" in
@@ -3833,10 +3836,10 @@
 fi
 echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:3837: checking for ANSI C header files" >&5
+echo "configure:3840: checking for ANSI C header files" >&5
-#line 3840 "configure"
+#line 3843 "configure"
 #include <stdlib.h>
 #include <stdarg.h>
@@ -3844,7 +3847,7 @@
 #include <float.h>
 EOF
-{ (eval echo configure:3848: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3851: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3861,7 +3864,7 @@
 if test $ac_cv_header_stdc = yes; then
   # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 3865 "configure"
+#line 3868 "configure"
 #include <string.h>
 EOF
@@ -3879,7 +3882,7 @@
   # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 3883 "configure"
+#line 3886 "configure"
 #include <stdlib.h>
 EOF
@@ -3900,7 +3903,7 @@
 else
-#line 3904 "configure"
+#line 3907 "configure"
 #include <ctype.h>
 #define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -3911,7 +3914,7 @@
 exit (0); }
 EOF
-if { (eval echo configure:3915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3918: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
 else
@@ -3938,15 +3941,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:3942: checking for $ac_hdr" >&5
+echo "configure:3945: checking for $ac_hdr" >&5
-#line 3945 "configure"
+#line 3948 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3950: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3953: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3975,15 +3978,15 @@
 do
-echo "configure:3979: checking for $ac_hdr" >&5
+echo "configure:3982: checking for $ac_hdr" >&5
-#line 3982 "configure"
+#line 3985 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3987: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3990: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4012,15 +4015,15 @@
 do
-echo "configure:4016: checking for $ac_hdr" >&5
+echo "configure:4019: checking for $ac_hdr" >&5
-#line 4019 "configure"
+#line 4022 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4024: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4027: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4049,15 +4052,15 @@
 do
-echo "configure:4053: checking for $ac_hdr" >&5
+echo "configure:4056: checking for $ac_hdr" >&5
-#line 4056 "configure"
+#line 4059 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4061: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4064: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4086,15 +4089,15 @@
 do
-echo "configure:4090: checking for $ac_hdr" >&5
+echo "configure:4093: checking for $ac_hdr" >&5
-#line 4093 "configure"
+#line 4096 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4098: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4101: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4120,10 +4123,10 @@
 done
 echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4124: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4127: checking whether time.h and sys/time.h may both be included" >&5
-#line 4127 "configure"
+#line 4130 "configure"
 #include <sys/types.h>
 #include <sys/time.h>
@@ -4132,7 +4135,7 @@
 struct tm *tp;
 ; return 0; }
 EOF
-if { (eval echo configure:4136: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4139: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_header_time=yes
 else
@@ -4152,10 +4155,10 @@
 fi
 echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4156: checking for off_t" >&5
+echo "configure:4159: checking for off_t" >&5
-#line 4159 "configure"
+#line 4162 "configure"
 #if STDC_HEADERS
@@ -4182,10 +4185,10 @@
 fi
 echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4186: checking for uid_t in sys/types.h" >&5
+echo "configure:4189: checking for uid_t in sys/types.h" >&5
-#line 4189 "configure"
+#line 4192 "configure"
 EOF
@@ -4213,10 +4216,10 @@
 fi
 echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4217: checking return type of signal handlers" >&5
+echo "configure:4220: checking return type of signal handlers" >&5
-#line 4220 "configure"
+#line 4223 "configure"
 #include <signal.h>
@@ -4233,7 +4236,7 @@
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:4237: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4240: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_type_signal=void
 else
@@ -4251,10 +4254,10 @@
-echo "configure:4255: checking for Cygwin environment" >&5
+echo "configure:4258: checking for Cygwin environment" >&5
-#line 4258 "configure"
+#line 4261 "configure"
 int main() {
@@ -4265,7 +4268,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:4269: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4272: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -4283,10 +4286,10 @@
 for ac_func in ftime gethostname gettimeofday lseek nice time uname
 do
 echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4287: checking for $ac_func" >&5
+echo "configure:4290: checking for $ac_func" >&5
-#line 4290 "configure"
+#line 4293 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char $ac_func(); below.  */
@@ -4309,7 +4312,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4316: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_$ac_func=yes"
 else
@@ -4335,10 +4338,10 @@
 for ac_func in seteuid setpriority setreuid setruid
 do
-echo "configure:4339: checking for $ac_func" >&5
+echo "configure:4342: checking for $ac_func" >&5
-#line 4342 "configure"
+#line 4345 "configure"
@@ -4361,7 +4364,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4368: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4387,10 +4390,10 @@
 for ac_func in drand48
 do
-echo "configure:4391: checking for $ac_func" >&5
+echo "configure:4394: checking for $ac_func" >&5
-#line 4394 "configure"
+#line 4397 "configure"
@@ -4413,7 +4416,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4417: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4420: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4439,10 +4442,10 @@
 for ac_func in putenv setenv
 do
-echo "configure:4443: checking for $ac_func" >&5
+echo "configure:4446: checking for $ac_func" >&5
-#line 4446 "configure"
+#line 4449 "configure"
@@ -4465,7 +4468,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4469: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4472: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4491,10 +4494,10 @@
 for ac_func in nanosleep
 do
-echo "configure:4495: checking for $ac_func" >&5
+echo "configure:4498: checking for $ac_func" >&5
-#line 4498 "configure"
+#line 4501 "configure"
@@ -4517,7 +4520,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4521: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4524: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4542,13 +4545,13 @@
 if test "$cross_compiling" != "yes" ; then
 echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4546: checking whether setpgrp takes no argument" >&5
+echo "configure:4549: checking whether setpgrp takes no argument" >&5
   { echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
 else
-#line 4552 "configure"
+#line 4555 "configure"
 #ifdef HAVE_UNISTD_H
@@ -4568,7 +4571,7 @@
 EOF
-if { (eval echo configure:4572: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4575: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
   ac_cv_func_setpgrp_void=no
 else
@@ -4596,16 +4599,16 @@
 fi
 echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4600: checking for long long int" >&5
+echo "configure:4603: checking for long long int" >&5
-#line 4602 "configure"
+#line 4605 "configure"
 int main() {
 long long int x;
 ; return 0; }
 EOF
-if { (eval echo configure:4609: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4612: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
@@ -4625,7 +4628,7 @@
 rm -f conftest*
 echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4629: checking for W11" >&5
+echo "configure:4632: checking for W11" >&5
 case "$enable_w11" in
 	yes|no)	echo "$ac_t"""$enable_w11"" 1>&6	;;
 	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
@@ -4653,7 +4656,7 @@
 # Uses ac_ vars as temps to allow command line to override cache and checks.
 # --without-x overrides everything else, but does not touch the cache.
 echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4657: checking for X" >&5
+echo "configure:4660: checking for X" >&5
 # Check whether --with-x or --without-x was given.
 if test "${with_x+set}" = set; then
@@ -4713,12 +4716,12 @@
   # First, try using that file with no special directory specified.
-#line 4717 "configure"
+#line 4720 "configure"
 #include <$x_direct_test_include>
 EOF
-{ (eval echo configure:4722: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4725: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4787,14 +4790,14 @@
   LIBS="-l$x_direct_test_library $LIBS"
-#line 4791 "configure"
+#line 4794 "configure"
 int main() {
 ${x_direct_test_function}()
 ; return 0; }
 EOF
-if { (eval echo configure:4798: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4801: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LIBS="$ac_save_LIBS"
 # We can link X programs with no special library path.
@@ -4899,17 +4902,17 @@
     case "`(uname -sr) 2>/dev/null`" in
     "SunOS 5"*)
       echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:4903: checking whether -R must be followed by a space" >&5
+echo "configure:4906: checking whether -R must be followed by a space" >&5
       ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 4906 "configure"
+#line 4909 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:4913: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4916: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_nospace=yes
 else
@@ -4925,14 +4928,14 @@
       else
 	LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 4929 "configure"
+#line 4932 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:4936: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4939: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_space=yes
 else
@@ -4964,13 +4967,13 @@
     # libraries were built with DECnet support.  And karl at cs.umb.edu says
     # the Alpha needs dnet_stub (dnet does not exist).
     echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:4968: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:4971: checking for dnet_ntoa in -ldnet" >&5
 ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet  $LIBS"
-#line 4974 "configure"
+#line 4977 "configure"
@@ -4981,7 +4984,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:4985: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4988: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5002,13 +5005,13 @@
     if test $ac_cv_lib_dnet_dnet_ntoa = no; then
       echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:5006: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:5009: checking for dnet_ntoa in -ldnet_stub" >&5
 ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet_stub  $LIBS"
-#line 5012 "configure"
+#line 5015 "configure"
@@ -5019,7 +5022,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:5023: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5026: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5047,10 +5050,10 @@
     # The nsl library prevents programs from opening the X display
     # on Irix 5.2, according to dickey at clark.net.
     echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:5051: checking for gethostbyname" >&5
+echo "configure:5054: checking for gethostbyname" >&5
-#line 5054 "configure"
+#line 5057 "configure"
     which can conflict with char gethostbyname(); below.  */
@@ -5073,7 +5076,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5077: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5080: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gethostbyname=yes"
 else
@@ -5093,13 +5096,13 @@
     if test $ac_cv_func_gethostbyname = no; then
       echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5097: checking for gethostbyname in -lnsl" >&5
+echo "configure:5100: checking for gethostbyname in -lnsl" >&5
 ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 5103 "configure"
+#line 5106 "configure"
@@ -5110,7 +5113,7 @@
 gethostbyname()
 ; return 0; }
 EOF
-if { (eval echo configure:5114: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5139,10 +5142,10 @@
     # -lsocket must be given before -lnsl if both are needed.
     # We assume that if connect needs -lnsl, so does gethostbyname.
     echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5143: checking for connect" >&5
+echo "configure:5146: checking for connect" >&5
-#line 5146 "configure"
+#line 5149 "configure"
     which can conflict with char connect(); below.  */
@@ -5165,7 +5168,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5169: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5172: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_connect=yes"
 else
@@ -5185,13 +5188,13 @@
     if test $ac_cv_func_connect = no; then
       echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5189: checking for connect in -lsocket" >&5
+echo "configure:5192: checking for connect in -lsocket" >&5
 ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
 LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5195 "configure"
+#line 5198 "configure"
@@ -5202,7 +5205,7 @@
 connect()
 ; return 0; }
 EOF
-if { (eval echo configure:5206: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5209: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5225,10 +5228,10 @@
     # gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
     echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5229: checking for remove" >&5
+echo "configure:5232: checking for remove" >&5
-#line 5232 "configure"
+#line 5235 "configure"
     which can conflict with char remove(); below.  */
@@ -5251,7 +5254,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5255: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5258: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_remove=yes"
 else
@@ -5271,13 +5274,13 @@
     if test $ac_cv_func_remove = no; then
       echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5275: checking for remove in -lposix" >&5
+echo "configure:5278: checking for remove in -lposix" >&5
 ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
 LIBS="-lposix  $LIBS"
-#line 5281 "configure"
+#line 5284 "configure"
@@ -5288,7 +5291,7 @@
 remove()
 ; return 0; }
 EOF
-if { (eval echo configure:5292: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5295: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5311,10 +5314,10 @@
     # BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
     echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5315: checking for shmat" >&5
+echo "configure:5318: checking for shmat" >&5
-#line 5318 "configure"
+#line 5321 "configure"
     which can conflict with char shmat(); below.  */
@@ -5337,7 +5340,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5341: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5344: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_shmat=yes"
 else
@@ -5357,13 +5360,13 @@
     if test $ac_cv_func_shmat = no; then
       echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5361: checking for shmat in -lipc" >&5
+echo "configure:5364: checking for shmat in -lipc" >&5
 ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
 LIBS="-lipc  $LIBS"
-#line 5367 "configure"
+#line 5370 "configure"
@@ -5374,7 +5377,7 @@
 shmat()
 ; return 0; }
 EOF
-if { (eval echo configure:5378: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5381: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5406,13 +5409,13 @@
   # libraries we check for below, so use a different variable.
   #  --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
   echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5410: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5413: checking for IceConnectionNumber in -lICE" >&5
 ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
 LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5416 "configure"
+#line 5419 "configure"
@@ -5423,7 +5426,7 @@
 IceConnectionNumber()
 ; return 0; }
 EOF
-if { (eval echo configure:5427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5430: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5461,7 +5464,7 @@
 echo $ac_n "checking whether to use Curses""... $ac_c" 1>&6
-echo "configure:5465: checking whether to use Curses" >&5
+echo "configure:5468: checking whether to use Curses" >&5
 echo "$ac_t"""$with_curses"" 1>&6
 case "$with_curses" in
 	"no")	USE_CURSES=	;;
@@ -5480,15 +5483,15 @@
 do
-echo "configure:5484: checking for $ac_hdr" >&5
+echo "configure:5487: checking for $ac_hdr" >&5
-#line 5487 "configure"
+#line 5490 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5492: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5495: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5519,10 +5522,10 @@
 echo $ac_n "checking curses.h WINDOW structure component""... $ac_c" 1>&6
-echo "configure:5523: checking curses.h WINDOW structure component" >&5
+echo "configure:5526: checking curses.h WINDOW structure component" >&5
 CURSES_MAXY=NONE
-#line 5526 "configure"
+#line 5529 "configure"
 #include <curses.h>
@@ -5531,7 +5534,7 @@
 WINDOW w; w.maxy = 0;
 ; return 0; }
 EOF
-if { (eval echo configure:5535: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5538: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   CURSES_MAXY=maxy
 else
@@ -5540,7 +5543,7 @@
 fi
 rm -f conftest*
-#line 5544 "configure"
+#line 5547 "configure"
 #include <curses.h>
@@ -5549,7 +5552,7 @@
 WINDOW w; w._maxy = 0;
 ; return 0; }
 EOF
-if { (eval echo configure:5553: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5556: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   CURSES_MAXY=_maxy
 else
@@ -5565,13 +5568,13 @@
 echo "$ac_t""$CURSES_MAXY" 1>&6
 echo $ac_n "checking for initscr in -lncurses""... $ac_c" 1>&6
-echo "configure:5569: checking for initscr in -lncurses" >&5
+echo "configure:5572: checking for initscr in -lncurses" >&5
 ac_lib_var=`echo ncurses'_'initscr | sed 'y%./+-%__p_%'`
 LIBS="-lncurses  $LIBS"
-#line 5575 "configure"
+#line 5578 "configure"
@@ -5582,7 +5585,7 @@
 initscr()
 ; return 0; }
 EOF
-if { (eval echo configure:5586: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5589: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5601,13 +5604,13 @@
   echo "$ac_t""no" 1>&6
 echo $ac_n "checking for initscr in -lcurses""... $ac_c" 1>&6
-echo "configure:5605: checking for initscr in -lcurses" >&5
+echo "configure:5608: checking for initscr in -lcurses" >&5
 ac_lib_var=`echo curses'_'initscr | sed 'y%./+-%__p_%'`
 LIBS="-lcurses  $LIBS"
-#line 5611 "configure"
+#line 5614 "configure"
@@ -5618,7 +5621,7 @@
 initscr()
 ; return 0; }
 EOF
-if { (eval echo configure:5622: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5625: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5647,13 +5650,13 @@
 echo $ac_n "checking for keypad in -lncurses""... $ac_c" 1>&6
-echo "configure:5651: checking for keypad in -lncurses" >&5
+echo "configure:5654: checking for keypad in -lncurses" >&5
 ac_lib_var=`echo ncurses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5657 "configure"
+#line 5660 "configure"
@@ -5664,7 +5667,7 @@
 keypad()
 ; return 0; }
 EOF
-if { (eval echo configure:5668: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5671: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5686,13 +5689,13 @@
 echo $ac_n "checking for keypad in -lcurses""... $ac_c" 1>&6
-echo "configure:5690: checking for keypad in -lcurses" >&5
+echo "configure:5693: checking for keypad in -lcurses" >&5
 ac_lib_var=`echo curses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5696 "configure"
+#line 5699 "configure"
@@ -5703,7 +5706,7 @@
 keypad()
 ; return 0; }
 EOF
-if { (eval echo configure:5707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5710: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5733,13 +5736,13 @@
 fi # $USE_CURSES
 echo $ac_n "checking for gtty in -lcompat""... $ac_c" 1>&6
-echo "configure:5737: checking for gtty in -lcompat" >&5
+echo "configure:5740: checking for gtty in -lcompat" >&5
 ac_lib_var=`echo compat'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lcompat  $LIBS"
-#line 5743 "configure"
+#line 5746 "configure"
@@ -5750,7 +5753,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5754: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5757: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5769,13 +5772,13 @@
 echo $ac_n "checking for gtty in -lbsd-compat""... $ac_c" 1>&6
-echo "configure:5773: checking for gtty in -lbsd-compat" >&5
+echo "configure:5776: checking for gtty in -lbsd-compat" >&5
 ac_lib_var=`echo bsd-compat'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lbsd-compat  $LIBS"
-#line 5779 "configure"
+#line 5782 "configure"
@@ -5786,7 +5789,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5793: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5805,13 +5808,13 @@
 echo $ac_n "checking for gtty in -lbsd""... $ac_c" 1>&6
-echo "configure:5809: checking for gtty in -lbsd" >&5
+echo "configure:5812: checking for gtty in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 5815 "configure"
+#line 5818 "configure"
@@ -5822,7 +5825,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5829: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5856,12 +5859,12 @@
 LIBS=""
 echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:5860: checking for library containing cuserid" >&5
+echo "configure:5863: checking for library containing cuserid" >&5
 ac_func_search_save_LIBS="$LIBS"
 ac_cv_search_cuserid="no"
-#line 5865 "configure"
+#line 5868 "configure"
@@ -5872,7 +5875,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:5876: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5879: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="none required"
 else
@@ -5883,7 +5886,7 @@
 test "$ac_cv_search_cuserid" = "no" && for i in compat; do
 LIBS="-l$i  $ac_func_search_save_LIBS"
-#line 5887 "configure"
+#line 5890 "configure"
@@ -5894,7 +5897,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:5898: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="-l$i"
 break
@@ -5920,10 +5923,10 @@
 # Note: -lxdr -liberty -lws2_32 is for MinGW
 echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:5924: checking for xdrmem_create" >&5
+echo "configure:5927: checking for xdrmem_create" >&5
-#line 5927 "configure"
+#line 5930 "configure"
     which can conflict with char xdrmem_create(); below.  */
@@ -5946,7 +5949,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5953: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_xdrmem_create=yes"
 else
@@ -5964,13 +5967,13 @@
 echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:5968: checking for xdrmem_create in -lsun" >&5
+echo "configure:5971: checking for xdrmem_create in -lsun" >&5
 ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lsun  $LIBS"
-#line 5974 "configure"
+#line 5977 "configure"
@@ -5981,7 +5984,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5985: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5988: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6000,13 +6003,13 @@
 echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:6004: checking for xdrmem_create in -lnsl" >&5
+echo "configure:6007: checking for xdrmem_create in -lnsl" >&5
 ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 6010 "configure"
+#line 6013 "configure"
@@ -6017,7 +6020,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6036,13 +6039,13 @@
 echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:6040: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:6043: checking for xdrmem_create in -lrpclib" >&5
 ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lrpclib  $LIBS"
-#line 6046 "configure"
+#line 6049 "configure"
@@ -6053,7 +6056,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6060: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6072,13 +6075,13 @@
 echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:6076: checking for xdrmem_create in -lxdr" >&5
+echo "configure:6079: checking for xdrmem_create in -lxdr" >&5
 ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lxdr -liberty -lws2_32  $LIBS"
-#line 6082 "configure"
+#line 6085 "configure"
@@ -6089,7 +6092,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6093: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6096: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6123,10 +6126,10 @@
 for ac_func in asprintf
 do
-echo "configure:6127: checking for $ac_func" >&5
+echo "configure:6130: checking for $ac_func" >&5
-#line 6130 "configure"
+#line 6133 "configure"
@@ -6149,7 +6152,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6176,10 +6179,10 @@
 # Test if mathlib needs -lm flag or is included with libc
 echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:6180: checking for atan" >&5
+echo "configure:6183: checking for atan" >&5
-#line 6183 "configure"
+#line 6186 "configure"
     which can conflict with char atan(); below.  */
@@ -6202,7 +6205,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6206: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6209: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_atan=yes"
 else
@@ -6220,13 +6223,13 @@
 echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:6224: checking for atan in -lm" >&5
+echo "configure:6227: checking for atan in -lm" >&5
 ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
 LIBS="-lm  $LIBS"
-#line 6230 "configure"
+#line 6233 "configure"
@@ -6237,7 +6240,7 @@
 atan()
 ; return 0; }
 EOF
-if { (eval echo configure:6241: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6244: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6264,10 +6267,10 @@
 echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:6268: checking for dlsym" >&5
+echo "configure:6271: checking for dlsym" >&5
-#line 6271 "configure"
+#line 6274 "configure"
     which can conflict with char dlsym(); below.  */
@@ -6290,7 +6293,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6294: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dlsym=yes"
 else
@@ -6308,13 +6311,13 @@
 echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:6312: checking for dlsym in -ldl" >&5
+echo "configure:6315: checking for dlsym in -ldl" >&5
 ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
 LIBS="-ldl  $LIBS"
-#line 6318 "configure"
+#line 6321 "configure"
@@ -6325,7 +6328,7 @@
 dlsym()
 ; return 0; }
 EOF
-if { (eval echo configure:6329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6332: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6352,10 +6355,10 @@
 echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:6356: checking for iconv" >&5
+echo "configure:6359: checking for iconv" >&5
-#line 6359 "configure"
+#line 6362 "configure"
     which can conflict with char iconv(); below.  */
@@ -6378,7 +6381,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6382: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6385: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_iconv=yes"
 else
@@ -6396,13 +6399,13 @@
 echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6400: checking for iconv in -liconv" >&5
+echo "configure:6403: checking for iconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-liconv  $LIBS"
-#line 6406 "configure"
+#line 6409 "configure"
@@ -6413,7 +6416,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6417: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6420: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6432,13 +6435,13 @@
 echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6436: checking for iconv in -lgiconv" >&5
+echo "configure:6439: checking for iconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-lgiconv  $LIBS"
-#line 6442 "configure"
+#line 6445 "configure"
@@ -6449,7 +6452,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6453: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6456: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6468,10 +6471,10 @@
 echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6472: checking for libiconv" >&5
+echo "configure:6475: checking for libiconv" >&5
-#line 6475 "configure"
+#line 6478 "configure"
     which can conflict with char libiconv(); below.  */
@@ -6494,7 +6497,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_libiconv=yes"
 else
@@ -6512,13 +6515,13 @@
 echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6516: checking for libiconv in -liconv" >&5
+echo "configure:6519: checking for libiconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6522 "configure"
+#line 6525 "configure"
@@ -6529,7 +6532,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6533: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6536: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6548,13 +6551,13 @@
 echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6552: checking for libiconv in -lgiconv" >&5
+echo "configure:6555: checking for libiconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6558 "configure"
+#line 6561 "configure"
@@ -6565,7 +6568,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6572: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6602,10 +6605,10 @@
 have_socket=1
 echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6606: checking for socket" >&5
+echo "configure:6609: checking for socket" >&5
-#line 6609 "configure"
+#line 6612 "configure"
     which can conflict with char socket(); below.  */
@@ -6628,7 +6631,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6632: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6635: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_socket=yes"
 else
@@ -6646,13 +6649,13 @@
 echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6650: checking for socket in -lsocket" >&5
+echo "configure:6653: checking for socket in -lsocket" >&5
 ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
 LIBS="-lsocket  $LIBS"
-#line 6656 "configure"
+#line 6659 "configure"
@@ -6663,7 +6666,7 @@
 socket()
 ; return 0; }
 EOF
-if { (eval echo configure:6667: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6670: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6711,7 +6714,7 @@
 echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6715: checking for location of zlib includes" >&5
+echo "configure:6718: checking for location of zlib includes" >&5
 case "$with_zlib_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6737,15 +6740,15 @@
 do
-echo "configure:6741: checking for $ac_hdr" >&5
+echo "configure:6744: checking for $ac_hdr" >&5
-#line 6744 "configure"
+#line 6747 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6749: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6752: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6779,7 +6782,7 @@
 echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6783: checking for location of zlib library" >&5
+echo "configure:6786: checking for location of zlib library" >&5
 case "$with_zlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6804,13 +6807,13 @@
 echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6808: checking for deflate in -lz" >&5
+echo "configure:6811: checking for deflate in -lz" >&5
 ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
 LIBS="-lz  $LIBS"
-#line 6814 "configure"
+#line 6817 "configure"
@@ -6821,7 +6824,7 @@
 deflate()
 ; return 0; }
 EOF
-if { (eval echo configure:6825: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6828: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6869,7 +6872,7 @@
 echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:6873: checking for location of External PROJ.4 includes" >&5
+echo "configure:6876: checking for location of External PROJ.4 includes" >&5
 case "$with_proj_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -6895,15 +6898,15 @@
 do
-echo "configure:6899: checking for $ac_hdr" >&5
+echo "configure:6902: checking for $ac_hdr" >&5
-#line 6902 "configure"
+#line 6905 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6907: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6910: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6940,7 +6943,7 @@
 else
 echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:6944: checking External PROJ.4 version" >&5
+echo "configure:6947: checking External PROJ.4 version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -6948,7 +6951,7 @@
 else
-#line 6952 "configure"
+#line 6955 "configure"
 #include <stdio.h>
@@ -6960,7 +6963,7 @@
 EOF
-if { (eval echo configure:6964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:6967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      proj_ver=`cat conftestdata`
         echo "$ac_t""$proj_ver" 1>&6
@@ -6985,7 +6988,7 @@
 echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:6989: checking for location of External PROJ.4 library" >&5
+echo "configure:6992: checking for location of External PROJ.4 library" >&5
 case "$with_proj_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -7010,13 +7013,13 @@
 echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:7014: checking for pj_get_def in -lproj" >&5
+echo "configure:7017: checking for pj_get_def in -lproj" >&5
 ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
 LIBS="-lproj  $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 7020 "configure"
+#line 7023 "configure"
@@ -7027,7 +7030,7 @@
 pj_get_def()
 ; return 0; }
 EOF
-if { (eval echo configure:7031: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7061,7 +7064,7 @@
 echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:7065: checking for location of External PROJ.4 data files" >&5
+echo "configure:7068: checking for location of External PROJ.4 data files" >&5
 case "$with_proj_share" in
         { echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -7085,14 +7088,14 @@
 # LOC_CHECK_SHARE does not work when cross compiling
 if test "$cross_compiling" = "yes" ; then
     echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:7089: checking for epsg" >&5
+echo "configure:7092: checking for epsg" >&5
 else
 ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:7096: checking for $PROJSHARE/epsg" >&5
+echo "configure:7099: checking for $PROJSHARE/epsg" >&5
     { echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -7124,7 +7127,7 @@
 # Extract the first word of "nad2bin", so it can be a program name with args.
 set dummy nad2bin; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:7128: checking for $ac_word" >&5
+echo "configure:7131: checking for $ac_word" >&5
 case "$NAD2BIN" in
@@ -7164,7 +7167,7 @@
 echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:7168: checking whether to use regex" >&5
+echo "configure:7171: checking whether to use regex" >&5
 echo "$ac_t"""$with_regex"" 1>&6
 case "$with_regex" in
 	"no")	USE_REGEX=	;;
@@ -7184,7 +7187,7 @@
 echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:7188: checking for location of regex includes" >&5
+echo "configure:7191: checking for location of regex includes" >&5
 case "$with_regex_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -7210,15 +7213,15 @@
 do
-echo "configure:7214: checking for $ac_hdr" >&5
+echo "configure:7217: checking for $ac_hdr" >&5
-#line 7217 "configure"
+#line 7220 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7222: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7225: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7252,7 +7255,7 @@
 echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:7256: checking for location of regex library" >&5
+echo "configure:7259: checking for location of regex library" >&5
 case "$with_regex_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -7277,10 +7280,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:7281: checking for regcomp" >&5
+echo "configure:7284: checking for regcomp" >&5
-#line 7284 "configure"
+#line 7287 "configure"
     which can conflict with char regcomp(); below.  */
@@ -7303,7 +7306,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7307: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7310: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_regcomp=yes"
 else
@@ -7330,13 +7333,13 @@
 echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:7334: checking for regcomp in -lregex" >&5
+echo "configure:7337: checking for regcomp in -lregex" >&5
 ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
 LIBS="-lregex  $LIBS"
-#line 7340 "configure"
+#line 7343 "configure"
@@ -7347,7 +7350,7 @@
 regcomp()
 ; return 0; }
 EOF
-if { (eval echo configure:7351: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7354: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7397,7 +7400,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7401: checking whether to use Readline" >&5
+echo "configure:7404: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -7418,7 +7421,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7422: checking for location of Readline includes" >&5
+echo "configure:7425: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7444,15 +7447,15 @@
 do
-echo "configure:7448: checking for $ac_hdr" >&5
+echo "configure:7451: checking for $ac_hdr" >&5
-#line 7451 "configure"
+#line 7454 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7456: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7459: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7488,15 +7491,15 @@
 do
-echo "configure:7492: checking for $ac_hdr" >&5
+echo "configure:7495: checking for $ac_hdr" >&5
-#line 7495 "configure"
+#line 7498 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7500: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7503: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -7530,7 +7533,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7534: checking for location of Readline library" >&5
+echo "configure:7537: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7555,13 +7558,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7559: checking for readline in -lreadline" >&5
+echo "configure:7562: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
-#line 7565 "configure"
+#line 7568 "configure"
@@ -7572,7 +7575,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:7576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7579: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7607,13 +7610,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7611: checking for add_history in -lhistory" >&5
+echo "configure:7614: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 7617 "configure"
+#line 7620 "configure"
@@ -7624,7 +7627,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:7628: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7631: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7667,7 +7670,7 @@
 echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7671: checking whether to use JPEG" >&5
+echo "configure:7674: checking whether to use JPEG" >&5
 echo "$ac_t"""$with_jpeg"" 1>&6
 case "$with_jpeg" in
 	"no")	USE_JPEG=	;;
@@ -7687,7 +7690,7 @@
 echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7691: checking for location of JPEG includes" >&5
+echo "configure:7694: checking for location of JPEG includes" >&5
 case "$with_jpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -7713,15 +7716,15 @@
 do
-echo "configure:7717: checking for $ac_hdr" >&5
+echo "configure:7720: checking for $ac_hdr" >&5
-#line 7720 "configure"
+#line 7723 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7725: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7728: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7755,7 +7758,7 @@
 echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7759: checking for location of JPEG library" >&5
+echo "configure:7762: checking for location of JPEG library" >&5
 case "$with_jpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -7782,13 +7785,13 @@
 echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7786: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7789: checking for jpeg_start_compress in -ljpeg" >&5
 ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ljpeg  $LIBS"
-#line 7792 "configure"
+#line 7795 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -7799,7 +7802,7 @@
 jpeg_start_compress()
 ; return 0; }
 EOF
-if { (eval echo configure:7803: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7806: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -7818,13 +7821,13 @@
-echo "configure:7822: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7825: checking for jpeg_start_compress in -ljpeg" >&5
 LIBS="-ljpeg $ZLIB $LIBS"
-#line 7828 "configure"
+#line 7831 "configure"
@@ -7835,7 +7838,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7839: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7884,7 +7887,7 @@
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:7888: checking whether to use GDAL" >&5
+echo "configure:7891: checking whether to use GDAL" >&5
 GDAL_LIBS=
 GDAL_CFLAGS=
@@ -7902,7 +7905,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
-echo "configure:7906: checking for $ac_word" >&5
+echo "configure:7909: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -7957,14 +7960,14 @@
   LIBS="$LIBS $GDAL_LIBS"
   CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 7961 "configure"
+#line 7964 "configure"
 #include <gdal.h>
 int main() {
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:7968: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
   echo "configure: failed program was:" >&5
@@ -7973,14 +7976,14 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 7977 "configure"
+#line 7980 "configure"
 #include <gdal.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:7984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7987: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -8013,7 +8016,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:8017: checking whether to use TIFF" >&5
+echo "configure:8020: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -8033,7 +8036,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:8037: checking for location of TIFF includes" >&5
+echo "configure:8040: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -8059,15 +8062,15 @@
 do
-echo "configure:8063: checking for $ac_hdr" >&5
+echo "configure:8066: checking for $ac_hdr" >&5
-#line 8066 "configure"
+#line 8069 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8071: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8074: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8101,7 +8104,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:8105: checking for location of TIFF library" >&5
+echo "configure:8108: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -8132,13 +8135,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:8136: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8139: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 LIBS="-ltiff  $LIBS"
-#line 8142 "configure"
+#line 8145 "configure"
@@ -8149,7 +8152,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8168,13 +8171,13 @@
-echo "configure:8172: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8175: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 8178 "configure"
+#line 8181 "configure"
@@ -8185,7 +8188,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8189: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8192: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8204,13 +8207,13 @@
-echo "configure:8208: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8211: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 8214 "configure"
+#line 8217 "configure"
@@ -8221,7 +8224,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8228: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8240,13 +8243,13 @@
-echo "configure:8244: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8247: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 8250 "configure"
+#line 8253 "configure"
@@ -8257,7 +8260,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8264: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8276,13 +8279,13 @@
-echo "configure:8280: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8283: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 8286 "configure"
+#line 8289 "configure"
@@ -8293,7 +8296,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8300: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8312,13 +8315,13 @@
-echo "configure:8316: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8319: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8322 "configure"
+#line 8325 "configure"
@@ -8329,7 +8332,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8333: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8336: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8348,13 +8351,13 @@
-echo "configure:8352: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8355: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8358 "configure"
+#line 8361 "configure"
@@ -8365,7 +8368,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8369: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8372: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8384,13 +8387,13 @@
-echo "configure:8388: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8391: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8394 "configure"
+#line 8397 "configure"
@@ -8401,7 +8404,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8405: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8408: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8499,7 +8502,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8503: checking whether to use PNG" >&5
+echo "configure:8506: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -8518,7 +8521,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8522: checking for location of PNG includes" >&5
+echo "configure:8525: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8544,15 +8547,15 @@
 do
-echo "configure:8548: checking for $ac_hdr" >&5
+echo "configure:8551: checking for $ac_hdr" >&5
-#line 8551 "configure"
+#line 8554 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8556: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8559: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8586,7 +8589,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8590: checking for location of PNG library" >&5
+echo "configure:8593: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8611,13 +8614,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8615: checking for png_read_image in -lpng" >&5
+echo "configure:8618: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8621 "configure"
+#line 8624 "configure"
@@ -8628,7 +8631,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:8632: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8635: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8670,7 +8673,7 @@
 echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:8674: checking whether to use Tcl/Tk" >&5
+echo "configure:8677: checking whether to use Tcl/Tk" >&5
 echo "$ac_t"""$with_tcltk"" 1>&6
 case "$with_tcltk" in
 	"no")	USE_TCLTK=	;;
@@ -8690,7 +8693,7 @@
 echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:8694: checking for location of Tcl/Tk includes" >&5
+echo "configure:8697: checking for location of Tcl/Tk includes" >&5
 case "$with_tcltk_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -8716,15 +8719,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8720: checking for $ac_hdr" >&5
+echo "configure:8723: checking for $ac_hdr" >&5
-#line 8723 "configure"
+#line 8726 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8728: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8731: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8761,15 +8764,15 @@
 do
-echo "configure:8765: checking for $ac_hdr" >&5
+echo "configure:8768: checking for $ac_hdr" >&5
-#line 8768 "configure"
+#line 8771 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8773: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8776: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8802,7 +8805,7 @@
 # Tcl/Tk version checks
 echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:8806: checking Tcl version" >&5
+echo "configure:8809: checking Tcl version" >&5
 CPPFLAGS="$TCLINCDIR $CPPFLAGS"
 if test "$cross_compiling" = yes; then
@@ -8810,7 +8813,7 @@
     echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
-#line 8814 "configure"
+#line 8817 "configure"
 #include <stdio.h>
@@ -8822,7 +8825,7 @@
 EOF
-if { (eval echo configure:8826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8829: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tcl_ver=`cat conftestdata`
     echo "$ac_t""$tcl_ver" 1>&6
@@ -8840,7 +8843,7 @@
 echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:8844: checking Tk version" >&5
+echo "configure:8847: checking Tk version" >&5
 CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -8848,7 +8851,7 @@
 else
-#line 8852 "configure"
+#line 8855 "configure"
 #include <stdio.h>
@@ -8860,7 +8863,7 @@
 EOF
-if { (eval echo configure:8864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tk_ver=`cat conftestdata`
     echo "$ac_t""$tk_ver" 1>&6
@@ -8891,7 +8894,7 @@
 echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:8895: checking for location of Tcl/Tk library" >&5
+echo "configure:8898: checking for location of Tcl/Tk library" >&5
 case "$with_tcltk_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -8921,13 +8924,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:8925: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8928: checking for Tcl_Init in -ltcl" >&5
 ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl $MATHLIB $LIBS"
-#line 8931 "configure"
+#line 8934 "configure"
@@ -8938,7 +8941,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8942: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8945: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8957,13 +8960,13 @@
-echo "configure:8961: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8964: checking for Tcl_Init in -ltcl" >&5
 LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 8967 "configure"
+#line 8970 "configure"
@@ -8974,7 +8977,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8978: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8981: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9001,13 +9004,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:9005: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:9008: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 9011 "configure"
+#line 9014 "configure"
@@ -9018,7 +9021,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:9022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9037,13 +9040,13 @@
-echo "configure:9041: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:9044: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 9047 "configure"
+#line 9050 "configure"
@@ -9054,7 +9057,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:9058: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9081,13 +9084,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:9085: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:9088: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 9091 "configure"
+#line 9094 "configure"
@@ -9098,7 +9101,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:9102: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9117,13 +9120,13 @@
-echo "configure:9121: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:9124: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 9127 "configure"
+#line 9130 "configure"
@@ -9134,7 +9137,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:9138: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9212,13 +9215,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:9216: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:9219: checking for Tk_MainWindow in -ltk" >&5
 ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 9222 "configure"
+#line 9225 "configure"
@@ -9229,7 +9232,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9233: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9236: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9248,13 +9251,13 @@
-echo "configure:9252: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:9255: checking for Tk_MainWindow in -ltk" >&5
 LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9258 "configure"
+#line 9261 "configure"
@@ -9265,7 +9268,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9269: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9272: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9292,13 +9295,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:9296: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9299: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 9302 "configure"
+#line 9305 "configure"
@@ -9309,7 +9312,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9316: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9328,13 +9331,13 @@
-echo "configure:9332: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9335: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9338 "configure"
+#line 9341 "configure"
@@ -9345,7 +9348,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9349: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9352: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9372,13 +9375,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:9376: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9379: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 9382 "configure"
+#line 9385 "configure"
@@ -9389,7 +9392,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9393: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9396: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9408,13 +9411,13 @@
-echo "configure:9412: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9415: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9418 "configure"
+#line 9421 "configure"
@@ -9425,7 +9428,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9429: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9432: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9517,7 +9520,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:9521: checking whether to use PostgreSQL" >&5
+echo "configure:9524: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -9544,7 +9547,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9548: checking for location of PostgreSQL includes" >&5
+echo "configure:9551: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9570,15 +9573,15 @@
 do
-echo "configure:9574: checking for $ac_hdr" >&5
+echo "configure:9577: checking for $ac_hdr" >&5
-#line 9577 "configure"
+#line 9580 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9582: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9585: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9616,7 +9619,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9620: checking for location of PostgreSQL library" >&5
+echo "configure:9623: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9645,13 +9648,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9649: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9652: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9655 "configure"
+#line 9658 "configure"
@@ -9662,7 +9665,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9666: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9669: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9681,13 +9684,13 @@
-echo "configure:9685: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9688: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9691 "configure"
+#line 9694 "configure"
@@ -9698,7 +9701,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9702: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9705: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9717,13 +9720,13 @@
-echo "configure:9721: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9724: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 9727 "configure"
+#line 9730 "configure"
@@ -9734,7 +9737,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9741: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9753,13 +9756,13 @@
-echo "configure:9757: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9760: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9763 "configure"
+#line 9766 "configure"
@@ -9770,7 +9773,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9774: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9777: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9827,13 +9830,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9831: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9834: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9837 "configure"
+#line 9840 "configure"
@@ -9844,7 +9847,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9848: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9851: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9866,13 +9869,13 @@
-echo "configure:9870: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9873: checking for PQcmdTuples in -lpq" >&5
-#line 9876 "configure"
+#line 9879 "configure"
@@ -9883,7 +9886,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9887: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9926,7 +9929,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9930: checking whether to use MySQL" >&5
+echo "configure:9933: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -9946,7 +9949,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9950: checking for location of MySQL includes" >&5
+echo "configure:9953: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9972,15 +9975,15 @@
 do
-echo "configure:9976: checking for $ac_hdr" >&5
+echo "configure:9979: checking for $ac_hdr" >&5
-#line 9979 "configure"
+#line 9982 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9984: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9987: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10017,7 +10020,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:10021: checking for location of MySQL library" >&5
+echo "configure:10024: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -10048,13 +10051,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:10052: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10055: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 10058 "configure"
+#line 10061 "configure"
@@ -10065,7 +10068,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10069: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10084,13 +10087,13 @@
-echo "configure:10088: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10091: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 10094 "configure"
+#line 10097 "configure"
@@ -10101,7 +10104,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10108: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10120,13 +10123,13 @@
-echo "configure:10124: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10127: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 10130 "configure"
+#line 10133 "configure"
@@ -10137,7 +10140,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10156,13 +10159,13 @@
-echo "configure:10160: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10163: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 10166 "configure"
+#line 10169 "configure"
@@ -10173,7 +10176,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10177: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10192,13 +10195,13 @@
-echo "configure:10196: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10199: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 10202 "configure"
+#line 10205 "configure"
@@ -10209,7 +10212,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10213: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10216: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10228,13 +10231,13 @@
-echo "configure:10232: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10235: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 10238 "configure"
+#line 10241 "configure"
@@ -10245,7 +10248,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10249: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10252: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10264,13 +10267,13 @@
-echo "configure:10268: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10271: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 10274 "configure"
+#line 10277 "configure"
@@ -10281,7 +10284,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10285: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10288: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10300,13 +10303,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:10304: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10307: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 10310 "configure"
+#line 10313 "configure"
@@ -10317,7 +10320,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10321: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10324: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10407,7 +10410,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
-echo "configure:10411: checking for $ac_word" >&5
+echo "configure:10414: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -10448,10 +10451,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:10452: checking for mysql_server_init" >&5
+echo "configure:10455: checking for mysql_server_init" >&5
-#line 10455 "configure"
+#line 10458 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -10474,7 +10477,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10478: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -10512,7 +10515,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:10516: checking whether to use SQLite" >&5
+echo "configure:10519: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -10532,7 +10535,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10536: checking for location of SQLite includes" >&5
+echo "configure:10539: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10558,15 +10561,15 @@
 do
-echo "configure:10562: checking for $ac_hdr" >&5
+echo "configure:10565: checking for $ac_hdr" >&5
-#line 10565 "configure"
+#line 10568 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10570: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10573: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10609,7 +10612,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10613: checking for location of SQLite library" >&5
+echo "configure:10616: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10636,13 +10639,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10640: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10643: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 10646 "configure"
+#line 10649 "configure"
@@ -10653,7 +10656,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10657: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10660: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10672,13 +10675,13 @@
-echo "configure:10676: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10679: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10682 "configure"
+#line 10685 "configure"
@@ -10689,7 +10692,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10693: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10696: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10742,7 +10745,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10746: checking whether to use FFMPEG" >&5
+echo "configure:10749: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -10762,7 +10765,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10766: checking for location of FFMPEG includes" >&5
+echo "configure:10769: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10788,15 +10791,15 @@
 do
-echo "configure:10792: checking for $ac_hdr" >&5
+echo "configure:10795: checking for $ac_hdr" >&5
-#line 10795 "configure"
+#line 10798 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10800: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10803: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10832,15 +10835,15 @@
 do
-echo "configure:10836: checking for $ac_hdr" >&5
+echo "configure:10839: checking for $ac_hdr" >&5
-#line 10839 "configure"
+#line 10842 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10844: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10847: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10876,15 +10879,15 @@
 do
-echo "configure:10880: checking for $ac_hdr" >&5
+echo "configure:10883: checking for $ac_hdr" >&5
-#line 10883 "configure"
+#line 10886 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10888: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10891: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10927,7 +10930,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10931: checking for location of FFMPEG library" >&5
+echo "configure:10934: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10954,13 +10957,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10958: checking for av_free in -lavutil" >&5
+echo "configure:10961: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 10964 "configure"
+#line 10967 "configure"
@@ -10971,7 +10974,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10975: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10978: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10990,13 +10993,13 @@
-echo "configure:10994: checking for av_free in -lavutil" >&5
+echo "configure:10997: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 11000 "configure"
+#line 11003 "configure"
@@ -11007,7 +11010,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:11011: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11014: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11052,13 +11055,13 @@
 echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:11056: checking for avcodec_init in -lavcodec" >&5
+echo "configure:11059: checking for avcodec_init in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 11062 "configure"
+#line 11065 "configure"
@@ -11069,7 +11072,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:11073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11076: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11088,13 +11091,13 @@
-echo "configure:11092: checking for avcodec_init in -lavcodec" >&5
+echo "configure:11095: checking for avcodec_init in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 11098 "configure"
+#line 11101 "configure"
@@ -11105,7 +11108,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:11109: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11112: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11150,13 +11153,13 @@
 echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:11154: checking for av_set_parameters in -lavformat" >&5
+echo "configure:11157: checking for av_set_parameters in -lavformat" >&5
 ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 11160 "configure"
+#line 11163 "configure"
@@ -11167,7 +11170,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:11171: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11174: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11186,13 +11189,13 @@
-echo "configure:11190: checking for av_set_parameters in -lavformat" >&5
+echo "configure:11193: checking for av_set_parameters in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 11196 "configure"
+#line 11199 "configure"
@@ -11203,7 +11206,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:11207: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11210: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11263,7 +11266,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:11267: checking whether to use OpenGL" >&5
+echo "configure:11270: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -11297,7 +11300,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:11301: checking for location of OpenGL includes" >&5
+echo "configure:11304: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -11323,15 +11326,15 @@
 do
-echo "configure:11327: checking for $ac_hdr" >&5
+echo "configure:11330: checking for $ac_hdr" >&5
-#line 11330 "configure"
+#line 11333 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11335: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11338: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11365,7 +11368,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:11369: checking for location of OpenGL library" >&5
+echo "configure:11372: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -11394,13 +11397,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:11398: checking for glBegin in -lGL" >&5
+echo "configure:11401: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11404 "configure"
+#line 11407 "configure"
@@ -11411,7 +11414,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11418: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11430,13 +11433,13 @@
-echo "configure:11434: checking for glBegin in -lGL" >&5
+echo "configure:11437: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 11440 "configure"
+#line 11443 "configure"
@@ -11447,7 +11450,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11451: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11466,13 +11469,13 @@
-echo "configure:11470: checking for glBegin in -lGL" >&5
+echo "configure:11473: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 11476 "configure"
+#line 11479 "configure"
@@ -11483,7 +11486,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11487: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11490: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11502,13 +11505,13 @@
-echo "configure:11506: checking for glBegin in -lGL" >&5
+echo "configure:11509: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11512 "configure"
+#line 11515 "configure"
@@ -11519,7 +11522,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11526: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11581,13 +11584,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11585: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11588: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11591 "configure"
+#line 11594 "configure"
@@ -11598,7 +11601,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11602: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11605: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11617,13 +11620,13 @@
-echo "configure:11621: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11624: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11627 "configure"
+#line 11630 "configure"
@@ -11634,7 +11637,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11638: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11641: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11678,10 +11681,10 @@
 LDFLAGS="$LDFLAGS $OPENGLLIB"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11682: checking for glXCreatePbuffer" >&5
+echo "configure:11685: checking for glXCreatePbuffer" >&5
-#line 11685 "configure"
+#line 11688 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -11704,7 +11707,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11708: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -11726,10 +11729,10 @@
 fi
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11730: checking for glXCreateGLXPixmap" >&5
+echo "configure:11733: checking for glXCreateGLXPixmap" >&5
-#line 11733 "configure"
+#line 11736 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -11752,7 +11755,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11756: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11759: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -11791,7 +11794,7 @@
-echo "configure:11795: checking for location of OpenGL includes" >&5
+echo "configure:11798: checking for location of OpenGL includes" >&5
@@ -11817,15 +11820,15 @@
 do
-echo "configure:11821: checking for $ac_hdr" >&5
+echo "configure:11824: checking for $ac_hdr" >&5
-#line 11824 "configure"
+#line 11827 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11829: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11832: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11860,10 +11863,10 @@
 LDFLAGS="$with_opengl_libs $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11864: checking for glBegin" >&5
+echo "configure:11867: checking for glBegin" >&5
-#line 11867 "configure"
+#line 11870 "configure"
     which can conflict with char glBegin(); below.  */
@@ -11886,7 +11889,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11893: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -11901,10 +11904,10 @@
   echo "$ac_t""yes" 1>&6
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11905: checking for gluBeginCurve" >&5
+echo "configure:11908: checking for gluBeginCurve" >&5
-#line 11908 "configure"
+#line 11911 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -11927,7 +11930,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11931: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -11971,7 +11974,7 @@
-echo "configure:11975: checking for location of OpenGL includes" >&5
+echo "configure:11978: checking for location of OpenGL includes" >&5
@@ -11997,15 +12000,15 @@
 do
-echo "configure:12001: checking for $ac_hdr" >&5
+echo "configure:12004: checking for $ac_hdr" >&5
-#line 12004 "configure"
+#line 12007 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12009: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12012: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12039,7 +12042,7 @@
-echo "configure:12043: checking for location of OpenGL library" >&5
+echo "configure:12046: checking for location of OpenGL library" >&5
@@ -12064,18 +12067,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:12068: checking for OpenGL library" >&5
+echo "configure:12071: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 12072 "configure"
+#line 12075 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:12079: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12082: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -12099,18 +12102,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:12103: checking for GLU library" >&5
+echo "configure:12106: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
 cat > conftest.$ac_ext <<EOF
-#line 12107 "configure"
+#line 12110 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:12114: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12159,7 +12162,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:12163: checking whether to use ODBC" >&5
+echo "configure:12166: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -12178,7 +12181,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12182: checking for location of ODBC includes" >&5
+echo "configure:12185: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12204,15 +12207,15 @@
 do
-echo "configure:12208: checking for $ac_hdr" >&5
+echo "configure:12211: checking for $ac_hdr" >&5
-#line 12211 "configure"
+#line 12214 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12216: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12219: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12246,7 +12249,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12250: checking for location of ODBC library" >&5
+echo "configure:12253: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12271,13 +12274,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12275: checking for SQLConnect in -lodbc" >&5
+echo "configure:12278: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 12281 "configure"
+#line 12284 "configure"
@@ -12288,7 +12291,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12292: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12295: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12313,13 +12316,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12317: checking for SQLConnect in -liodbc" >&5
+echo "configure:12320: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 12323 "configure"
+#line 12326 "configure"
@@ -12330,7 +12333,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12334: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12355,11 +12358,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12359: checking for ODBC library" >&5
+echo "configure:12362: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 12363 "configure"
+#line 12366 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -12367,7 +12370,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:12371: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12374: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12416,7 +12419,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12420: checking whether to use FFTW" >&5
+echo "configure:12423: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -12435,7 +12438,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12439: checking for location of FFTW includes" >&5
+echo "configure:12442: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12461,15 +12464,15 @@
 do
-echo "configure:12465: checking for $ac_hdr" >&5
+echo "configure:12468: checking for $ac_hdr" >&5
-#line 12468 "configure"
+#line 12471 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12473: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12476: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12497,15 +12500,15 @@
 do
-echo "configure:12501: checking for $ac_hdr" >&5
+echo "configure:12504: checking for $ac_hdr" >&5
-#line 12504 "configure"
+#line 12507 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12509: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12512: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12533,15 +12536,15 @@
 do
-echo "configure:12537: checking for $ac_hdr" >&5
+echo "configure:12540: checking for $ac_hdr" >&5
-#line 12540 "configure"
+#line 12543 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:12545: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12548: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -12587,7 +12590,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12591: checking for location of FFTW library" >&5
+echo "configure:12594: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12612,13 +12615,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12616: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12619: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12622 "configure"
+#line 12625 "configure"
@@ -12629,7 +12632,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:12633: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12636: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12654,13 +12657,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12658: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12661: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 12664 "configure"
+#line 12667 "configure"
@@ -12671,7 +12674,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12678: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12696,13 +12699,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12700: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12703: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12706 "configure"
+#line 12709 "configure"
@@ -12713,7 +12716,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12717: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12720: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12770,7 +12773,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12774: checking whether to use BLAS" >&5
+echo "configure:12777: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -12791,7 +12794,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12795: checking for location of BLAS includes" >&5
+echo "configure:12798: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12811,7 +12814,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12815: checking for location of BLAS library" >&5
+echo "configure:12818: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12837,15 +12840,15 @@
 do
-echo "configure:12841: checking for $ac_hdr" >&5
+echo "configure:12844: checking for $ac_hdr" >&5
-#line 12844 "configure"
+#line 12847 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12849: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12852: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12880,13 +12883,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12884: checking for dnrm2_ in -lblas" >&5
+echo "configure:12887: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 12890 "configure"
+#line 12893 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -12897,7 +12900,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12904: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -12916,13 +12919,13 @@
-echo "configure:12920: checking for dnrm2_ in -lblas" >&5
+echo "configure:12923: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12926 "configure"
+#line 12929 "configure"
@@ -12933,7 +12936,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12937: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12940: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12977,13 +12980,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12981: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12984: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 12987 "configure"
+#line 12990 "configure"
@@ -12994,7 +12997,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:12998: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13001: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13009,13 +13012,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:13013: checking for sgemm_ in -lf77blas" >&5
+echo "configure:13016: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 13019 "configure"
+#line 13022 "configure"
@@ -13026,7 +13029,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13030: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13041,13 +13044,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:13045: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:13048: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 13051 "configure"
+#line 13054 "configure"
@@ -13058,7 +13061,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:13062: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13065: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13103,16 +13106,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:13107: checking for sgemm in $vlib_flags" >&5
+echo "configure:13110: checking for sgemm in $vlib_flags" >&5
-#line 13109 "configure"
+#line 13112 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:13116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13119: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -13130,13 +13133,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:13134: checking for sgemm_ in -lblas" >&5
+echo "configure:13137: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 13140 "configure"
+#line 13143 "configure"
@@ -13147,7 +13150,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13151: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13154: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13162,13 +13165,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:13166: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13169: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 13172 "configure"
+#line 13175 "configure"
@@ -13179,7 +13182,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13186: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13194,13 +13197,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13198: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13201: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 13204 "configure"
+#line 13207 "configure"
@@ -13211,7 +13214,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13215: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13218: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13245,13 +13248,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13249: checking for acosp in -lsunmath" >&5
+echo "configure:13252: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 13255 "configure"
+#line 13258 "configure"
@@ -13262,7 +13265,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:13266: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13269: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13277,13 +13280,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13281: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13284: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 13287 "configure"
+#line 13290 "configure"
@@ -13294,7 +13297,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13298: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13301: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13324,13 +13327,13 @@
 # Generic BLAS library
-echo "configure:13328: checking for sgemm_ in -lblas" >&5
+echo "configure:13331: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 13334 "configure"
+#line 13337 "configure"
@@ -13341,7 +13344,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13345: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13348: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13380,7 +13383,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13384: checking whether to use LAPACK" >&5
+echo "configure:13387: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -13405,7 +13408,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13409: checking for location of LAPACK includes" >&5
+echo "configure:13412: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13425,7 +13428,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13429: checking for location of LAPACK library" >&5
+echo "configure:13432: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13451,15 +13454,15 @@
 do
-echo "configure:13455: checking for $ac_hdr" >&5
+echo "configure:13458: checking for $ac_hdr" >&5
-#line 13458 "configure"
+#line 13461 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13463: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13466: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13491,10 +13494,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13495: checking for dsegv_" >&5
+echo "configure:13498: checking for dsegv_" >&5
-#line 13498 "configure"
+#line 13501 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -13517,7 +13520,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13521: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13524: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -13544,13 +13547,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13548: checking for desgv_ in -llapack" >&5
+echo "configure:13551: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 13554 "configure"
+#line 13557 "configure"
@@ -13561,7 +13564,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13565: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13568: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13593,13 +13596,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13597: checking for dgesv_ in -llapack" >&5
+echo "configure:13600: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 13603 "configure"
+#line 13606 "configure"
@@ -13610,7 +13613,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13614: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13617: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13629,13 +13632,13 @@
-echo "configure:13633: checking for dgesv_ in -llapack" >&5
+echo "configure:13636: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13639 "configure"
+#line 13642 "configure"
@@ -13646,7 +13649,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13650: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13653: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13702,7 +13705,7 @@
 echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:13706: checking whether to use Motif" >&5
+echo "configure:13709: checking whether to use Motif" >&5
 echo "$ac_t"""$with_motif"" 1>&6
 case "$with_motif" in
 	"no")	USE_MOTIF=	;;
@@ -13721,7 +13724,7 @@
 echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:13725: checking for location of Motif includes" >&5
+echo "configure:13728: checking for location of Motif includes" >&5
 case "$with_motif_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -13747,15 +13750,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13751: checking for $ac_hdr" >&5
+echo "configure:13754: checking for $ac_hdr" >&5
-#line 13754 "configure"
+#line 13757 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13759: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13762: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13789,7 +13792,7 @@
 echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:13793: checking for location of Motif library" >&5
+echo "configure:13796: checking for location of Motif library" >&5
 case "$with_motif_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -13814,13 +13817,13 @@
 echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:13818: checking for XmStringCreate in -lXm" >&5
+echo "configure:13821: checking for XmStringCreate in -lXm" >&5
 ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
 LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS  $LIBS"
-#line 13824 "configure"
+#line 13827 "configure"
@@ -13831,7 +13834,7 @@
 XmStringCreate()
 ; return 0; }
 EOF
-if { (eval echo configure:13835: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13838: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13872,7 +13875,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13876: checking whether to use Cairo" >&5
+echo "configure:13879: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -13898,15 +13901,15 @@
 do
-echo "configure:13902: checking for $ac_hdr" >&5
+echo "configure:13905: checking for $ac_hdr" >&5
-#line 13905 "configure"
+#line 13908 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13910: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13913: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13943,10 +13946,10 @@
 LIBS="$LIBS $CAIROLIB"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13947: checking for cairo_create" >&5
+echo "configure:13950: checking for cairo_create" >&5
-#line 13950 "configure"
+#line 13953 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -13969,7 +13972,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13976: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -14004,7 +14007,7 @@
 echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:14008: checking whether to use GLw" >&5
+echo "configure:14011: checking whether to use GLw" >&5
 echo "$ac_t"""$with_glw"" 1>&6
 case "$with_glw" in
 	"no")	USE_GLW=	;;
@@ -14023,7 +14026,7 @@
 echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:14027: checking for location of GLw includes" >&5
+echo "configure:14030: checking for location of GLw includes" >&5
 case "$with_glw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -14049,15 +14052,15 @@
 do
-echo "configure:14053: checking for $ac_hdr" >&5
+echo "configure:14056: checking for $ac_hdr" >&5
-#line 14056 "configure"
+#line 14059 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14061: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14064: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14085,15 +14088,15 @@
 do
-echo "configure:14089: checking for $ac_hdr" >&5
+echo "configure:14092: checking for $ac_hdr" >&5
-#line 14092 "configure"
+#line 14095 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14097: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14100: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14133,7 +14136,7 @@
 echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:14137: checking for location of GLw library" >&5
+echo "configure:14140: checking for location of GLw library" >&5
 case "$with_glw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -14158,13 +14161,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14162: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:14165: checking for GLwCreateMDrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14168 "configure"
+#line 14171 "configure"
@@ -14175,7 +14178,7 @@
 GLwCreateMDrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14182: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14200,13 +14203,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14204: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:14207: checking for GLwCreateM1DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14210 "configure"
+#line 14213 "configure"
@@ -14217,7 +14220,7 @@
 GLwCreateM1DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14221: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14224: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14242,13 +14245,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14246: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:14249: checking for GLwCreateM2DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14252 "configure"
+#line 14255 "configure"
@@ -14259,7 +14262,7 @@
 GLwCreateM2DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14263: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14266: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14284,13 +14287,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14288: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:14291: checking for GLwCreateMDrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14294 "configure"
+#line 14297 "configure"
@@ -14301,7 +14304,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14305: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14308: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14326,13 +14329,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14330: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:14333: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14336 "configure"
+#line 14339 "configure"
@@ -14343,7 +14346,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14347: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14350: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14368,13 +14371,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14372: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:14375: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14378 "configure"
+#line 14381 "configure"
@@ -14385,7 +14388,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14389: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14392: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14412,13 +14415,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:14416: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14419: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14422 "configure"
+#line 14425 "configure"
@@ -14429,7 +14432,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14433: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14436: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14448,13 +14451,13 @@
-echo "configure:14452: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14455: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14458 "configure"
+#line 14461 "configure"
@@ -14465,7 +14468,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14469: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14472: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14492,13 +14495,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:14496: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14499: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14502 "configure"
+#line 14505 "configure"
@@ -14509,7 +14512,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14513: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14516: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14528,13 +14531,13 @@
-echo "configure:14532: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14535: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14538 "configure"
+#line 14541 "configure"
@@ -14545,7 +14548,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14549: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14552: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14658,7 +14661,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:14662: checking whether to use FreeType" >&5
+echo "configure:14665: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -14677,7 +14680,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:14681: checking for location of FreeType includes" >&5
+echo "configure:14684: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -14703,15 +14706,15 @@
 do
-echo "configure:14707: checking for $ac_hdr" >&5
+echo "configure:14710: checking for $ac_hdr" >&5
-#line 14710 "configure"
+#line 14713 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14715: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14718: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14745,7 +14748,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:14749: checking for location of FreeType library" >&5
+echo "configure:14752: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -14770,13 +14773,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:14774: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:14777: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 14780 "configure"
+#line 14783 "configure"
@@ -14787,7 +14790,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:14791: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14828,7 +14831,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:14832: checking whether to use NLS" >&5
+echo "configure:14835: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -14848,10 +14851,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:14852: checking for gettext" >&5
+echo "configure:14855: checking for gettext" >&5
-#line 14855 "configure"
+#line 14858 "configure"
     which can conflict with char gettext(); below.  */
@@ -14874,7 +14877,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14881: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -14892,13 +14895,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:14896: checking for gettext in -lintl" >&5
+echo "configure:14899: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 14902 "configure"
+#line 14905 "configure"
@@ -14909,7 +14912,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:14913: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14916: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14944,7 +14947,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:14948: checking whether to use C++" >&5
+echo "configure:14951: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -14960,7 +14963,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:14964: checking for $ac_word" >&5
+echo "configure:14967: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -14989,7 +14992,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:14993: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:14996: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -15000,12 +15003,12 @@
 cat > conftest.$ac_ext << EOF
-#line 15004 "configure"
+#line 15007 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:15009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15012: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -15031,19 +15034,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:15035: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:15038: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:15040: checking whether we are using GNU C++" >&5
+echo "configure:15043: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15047: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15050: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -15061,7 +15064,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:15065: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:15068: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -15102,7 +15105,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:15106: checking whether to use openDWG" >&5
+echo "configure:15109: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -15122,7 +15125,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15126: checking for location of openDGW includes" >&5
+echo "configure:15129: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15148,15 +15151,15 @@
 do
-echo "configure:15152: checking for $ac_hdr" >&5
+echo "configure:15155: checking for $ac_hdr" >&5
-#line 15155 "configure"
+#line 15158 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15160: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15163: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15190,7 +15193,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15194: checking for location of openDWG library" >&5
+echo "configure:15197: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -15237,7 +15240,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:15241: checking for special C compiler options needed for large files" >&5
+echo "configure:15244: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -15245,7 +15248,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 15249 "configure"
+#line 15252 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -15261,7 +15264,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15265: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15268: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   echo "configure: failed program was:" >&5
@@ -15270,7 +15273,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 15274 "configure"
+#line 15277 "configure"
@@ -15286,7 +15289,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15290: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15293: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -15306,11 +15309,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15310: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15313: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 15314 "configure"
+#line 15317 "configure"
@@ -15326,14 +15329,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15330: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15333: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   cat conftest.$ac_ext >&5
   rm -rf conftest*
-#line 15337 "configure"
+#line 15340 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -15351,7 +15354,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15355: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15358: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -15370,11 +15373,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15374: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15377: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 15378 "configure"
+#line 15381 "configure"
@@ -15390,14 +15393,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15394: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15397: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15401 "configure"
+#line 15404 "configure"
 #define _LARGE_FILES 1
@@ -15415,7 +15418,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15419: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15422: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -15434,25 +15437,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15438: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15441: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 15442 "configure"
+#line 15445 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15449: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15452: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15456 "configure"
+#line 15459 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -15461,7 +15464,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15465: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15468: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -15482,10 +15485,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:15486: checking if system supports Large Files at all" >&5
+echo "configure:15489: checking if system supports Large Files at all" >&5
-#line 15489 "configure"
+#line 15492 "configure"
 #include <stdio.h>
@@ -15517,7 +15520,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:15521: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15524: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -15546,7 +15549,7 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:15550: checking whether to use Python" >&5
+echo "configure:15553: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
@@ -15566,7 +15569,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
-echo "configure:15570: checking for $ac_word" >&5
+echo "configure:15573: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -15611,15 +15614,15 @@
 do
-echo "configure:15615: checking for $ac_hdr" >&5
+echo "configure:15618: checking for $ac_hdr" >&5
-#line 15618 "configure"
+#line 15621 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15623: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15626: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15659,7 +15662,7 @@
   # Extract the first word of "swig", so it can be a program name with args.
 set dummy swig; ac_word=$2
-echo "configure:15663: checking for $ac_word" >&5
+echo "configure:15666: checking for $ac_word" >&5
 case "$SWIG" in
@@ -15705,7 +15708,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:15709: checking whether to use wxWidgets" >&5
+echo "configure:15712: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -15718,14 +15721,14 @@
 else
   USE_WXWIDGETS="1"
-  if test "`basename $with_wxwidgets`" = "wx-config" ; then
+  if test "$with_wxwidgets" != "yes" ; then
     WX_CONFIG="$with_wxwidgets"
   fi
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:15729: checking for $ac_word" >&5
+echo "configure:15732: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -15773,7 +15776,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:15777: checking wxWidgets version" >&5
+echo "configure:15780: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -15796,15 +15799,15 @@
 do
-echo "configure:15800: checking for $ac_hdr" >&5
+echo "configure:15803: checking for $ac_hdr" >&5
-#line 15803 "configure"
+#line 15806 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15808: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15811: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
Modified: grass/branches/releasebranch_6_4/configure.in
--- grass/branches/releasebranch_6_4/configure.in	2009-05-02 16:32:06 UTC (rev 36944)
+++ grass/branches/releasebranch_6_4/configure.in	2009-05-02 18:33:33 UTC (rev 36945)
@@ -198,19 +198,22 @@
 LOC_ARG_WITH(opendwg, openDWG, no)
 LOC_ARG_WITH(curses, Curses, yes)
 LOC_ARG_WITH(regex, regex)
+AC_ARG_WITH(gdal,
+[  --with-gdal[=path/gdal-config] enable GDAL/OGR support (gdal-config with path, \
+e.g. '--with-gdal=/usr/local/bin/gdal-config')])
 AC_ARG_WITH(python,
-[  --with-python[=path/python-config] enable support for Python SWIG bindings (python-config with path, \
-e.g. '--with-python=/usr/bin/python2.5-config', default: no)],, with_python="no")
+[  --with-python[=path/python-config] enable support for Python SWIG bindings \
+(python-config with path, e.g. '--with-python=/usr/bin/python2.5-config', \
+default: no)],, with_python="no")
 AC_ARG_WITH(wxwidgets,
 [  --with-wxwidgets[=path/wx-config] enable wxWidgets support (wx-config with path, \
 e.g. '--with-wxwidgets=/usr/local/bin/wx-config', default: no)],, with_wxwidgets="no")
 # With includes and libs options
-AC_ARG_WITH(gdal,
-[  --with-gdal[=path/gdal-config] enable GDAL/OGR support (gdal-config with path, \
-e.g. '--with-gdal=/usr/local/bin/gdal-config')])
 AC_ARG_WITH(includes,
 [  --with-includes=DIRS    site include files are in DIRS])
@@ -1732,7 +1735,7 @@
 else
   AC_MSG_RESULT(yes)
   USE_WXWIDGETS="1"
   fi
