[GRASS-SVN] r37084 - in grass/branches/develbranch_6/gui/wxpython: . gui_modules xml
Sat May 9 14:54:17 EDT 2009
Author: martinl
Date: 2009-05-09 14:54:17 -0400 (Sat, 09 May 2009)
New Revision: 37084
Added:
   grass/branches/develbranch_6/gui/wxpython/gui_modules/ogc_services.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/__init__.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
   grass/branches/develbranch_6/gui/wxpython/wxgui.py
   grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
wxGUI: WMS dialog implemented (very initial stage)
       (merge from trunk, r37080, r37083)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/__init__.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/__init__.py	2009-05-09 18:46:22 UTC (rev 37083)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/__init__.py	2009-05-09 18:54:17 UTC (rev 37084)
@@ -21,6 +21,7 @@
     "nviz_mapdisp.py",
     "nviz.py",
     "nviz_tools.py",
+    "ogc_services.py",
     "preferences.py",
     "profile.py",
     "render.py",
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py	2009-05-09 18:46:22 UTC (rev 37083)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py	2009-05-09 18:54:17 UTC (rev 37084)
@@ -253,15 +253,15 @@
         """Write message in selected style"""
         if pid:
             line = '(' + str(pid) + ') ' + line
-        self.WriteLog(line, style=self.cmd_output.StyleCommand)
+        self.WriteLog(line, style=self.cmd_output.StyleCommand, switchPage = True)
     def WriteWarning(self, line):
         """Write message in warning style"""
-        self.WriteLog(line, style=self.cmd_output.StyleWarning)
+        self.WriteLog(line, style=self.cmd_output.StyleWarning, switchPage = True)
     def WriteError(self, line):
         """Write message in error style"""
-        self.WriteLog(line, style=self.cmd_output.StyleError)
+        self.WriteLog(line, style=self.cmd_output.StyleError, switchPage = True)
     def RunCmd(self, command, compReg=True, switchPage=False,
                onDone = None):
Copied: grass/branches/develbranch_6/gui/wxpython/gui_modules/ogc_services.py (from rev 37080, grass/trunk/gui/wxpython/gui_modules/ogc_services.py)
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/ogc_services.py	                        (rev 0)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/ogc_services.py	2009-05-09 18:54:17 UTC (rev 37084)
@@ -0,0 +1,298 @@
+ at package ogc_services.py
+ at brief Dialogs for OGC services
+Currently is implemeted only WMS.
+List of classes:
+ - WMSDialog
+ - LayersList
+(C) 2009 by the GRASS Development Team
+This program is free software under the GNU General Public License
+(>=v2). Read the file COPYING that comes with GRASS for details.
+ at author Martin Landa <landa.martin gmail.com>
+import wx
+from wx.gizmos import TreeListCtrl
+import wx.lib.mixins.listctrl as listmix
+import gcmd
+from preferences import globalSettings as UserSettings
+class WMSDialog(wx.Dialog):
+    def __init__(self, parent, service = 'wms',
+                 id=wx.ID_ANY,
+                 style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
+        """Dialog to import data from WMS server"""
+        self.parent  = parent  # GMFrame
+        self.service = service # currently only WMS is implemented
+        wx.Dialog.__init__(self, parent, id, style=style)
+        if self.service == 'wms':
+            self.SetTitle(_("Import data from WMS server"))
+        self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
+        self.__createWidgets()
+        self.__doLayout()
+        self.SetMinSize((550, 400))
+    def __createWidgets(self):
+        """Create dialog widgets"""
+        # settings
+        self.settingsBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
+                                        label = _(" Server settings "))
+        self.serverText = wx.StaticText(parent = self.panel, id = wx.ID_ANY, label = _("Server:"))
+        self.server  = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY)
+        # list of layers
+        self.layersBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
+                                label=_(" List of layers "))
+        self.list = LayersList(self.panel)
+        self.list.LoadData()
+        self.add = wx.CheckBox(parent=self.panel, id=wx.ID_ANY,
+                               label=_("Add imported layers into layer tree"))
+        self.add.SetValue(UserSettings.Get(group='cmd', key='addNewLayer', subkey='enabled'))
+        # buttons
+        # cancel
+        self.btn_cancel = wx.Button(parent = self.panel, id = wx.ID_CANCEL)
+        self.btn_cancel.SetToolTipString(_("Close dialog"))
+        # connect
+        self.btn_connect = wx.Button(parent = self.panel, id = wx.ID_ANY, label = _("&Connect"))
+        self.btn_connect.SetToolTipString(_("Connect to the server"))
+        self.btn_connect.SetDefault()
+        if not self.server.GetValue():
+            self.btn_connect.Enable(False)
+        # import
+        self.btn_import = wx.Button(parent = self.panel, id = wx.ID_OK, label = _("&Import"))
+        self.btn_import.SetToolTipString(_("Import selected layers"))
+        self.btn_import.Enable(False)
+        # bindings
+        self.btn_cancel.Bind(wx.EVT_BUTTON, self.OnCancel)
+        self.btn_connect.Bind(wx.EVT_BUTTON, self.OnConnect)
+        self.server.Bind(wx.EVT_TEXT, self.OnServer)
+    def __doLayout(self):
+        """Do dialog layout"""
+        dialogSizer = wx.BoxSizer(wx.VERTICAL)
+        # settings
+        settingsSizer = wx.StaticBoxSizer(self.settingsBox, wx.HORIZONTAL)
+        gridSizer = wx.FlexGridSizer(cols=2, vgap=5, hgap=5)
+        gridSizer.Add(item=self.serverText,
+                      flag=wx.ALIGN_CENTER_VERTICAL)
+        gridSizer.AddGrowableCol(1)
+        gridSizer.Add(item=self.server,
+                      flag=wx.EXPAND | wx.ALL)
+        settingsSizer.Add(item=gridSizer, proportion=1,
+        dialogSizer.Add(item=settingsSizer, proportion=0,
+                        flag=wx.ALL | wx.EXPAND, border=5)
+        # list of layers
+        layersSizer = wx.StaticBoxSizer(self.layersBox, wx.HORIZONTAL)
+        layersSizer.Add(item=self.list, proportion=1,
+        dialogSizer.Add(item=layersSizer, proportion=1,
+                        flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=5)
+        dialogSizer.Add(item=self.add, proportion=0,
+        # buttons
+        btnsizer = wx.BoxSizer(orient=wx.HORIZONTAL)
+        btnsizer.Add(item=self.btn_cancel, proportion=0,
+                     flag=wx.ALL | wx.ALIGN_CENTER,
+                     border=10)
+        btnsizer.Add(item=self.btn_connect, proportion=0,
+                     border=10)
+        btnsizer.Add(item=self.btn_import, proportion=0,
+                     border=10)
+        dialogSizer.Add(item=btnsizer, proportion=0,
+                        flag=wx.ALIGN_CENTER)
+        self.panel.SetAutoLayout(True)
+        self.panel.SetSizer(dialogSizer)
+        dialogSizer.Fit(self.panel)
+        self.Layout()
+    def OnCancel(self, event):
+        """Button 'Cancel' pressed -> close the dialog"""
+        self.Close()
+    def OnConnect(self, event):
+        """Button 'Connect' pressed"""
+        server = self.server.GetValue()
+        if not server:
+            return # not reachable
+        layers = {}
+        ret = gcmd.RunCommand('r.in.wms',
+                              quiet = True,
+                              parent = self,
+                              read = True,
+                              flags = 'l',
+                              mapserver = server)
+        if not ret:
+            return # no layers found
+        lastLayer = lastStyle = ''
+        for line in ret.splitlines():
+            key, value = line.split(':', 1)
+            key = key.strip().lower()
+            value = value.strip()
+            if key == 'layer':
+                layers[value] = {}
+                lastLayer = value
+            elif key == 'title':
+                layers[lastLayer][key] = value
+            elif key == 'style':
+                if not layers[lastLayer].has_key('style'):
+                    layers[lastLayer]['style'] = {}
+                layers[lastLayer]['style'][value] = ''
+                lastStyle = value
+            elif key == 'style title':
+                layers[lastLayer]['style'][lastStyle] = value
+        # update list of layers
+        self.list.LoadData(layers)
+        if len(layers.keys()) > 0:
+            self.btn_import.Enable(True)
+        else:
+    def OnServer(self, event):
+        """Server settings changed"""
+        value = event.GetString()
+        if value:
+            self.btn_connect.Enable(True)
+        else:
+    def GetLayers(self):
+        """Get list of selected layers/styles to be imported"""
+        return self.list.GetSelectedLayers()
+    def GetSettings(self):
+        """Get connection settings"""
+        return { 'server' : self.server.GetValue() }
+class LayersList(TreeListCtrl, listmix.ListCtrlAutoWidthMixin):
+    def __init__(self, parent, pos=wx.DefaultPosition):
+        """List of layers to be imported (dxf, shp...)"""
+        TreeListCtrl.__init__(self, parent, wx.ID_ANY,
+                              style = wx.TR_DEFAULT_STYLE | wx.TR_HIDE_ROOT |
+                              wx.TR_FULL_ROW_HIGHLIGHT | wx.TR_MULTIPLE)
+        # setup mixins
+        listmix.ListCtrlAutoWidthMixin.__init__(self)
+        self.AddColumn(_('Layer / Style'))
+        self.AddColumn(_('Title'))
+        self.SetMainColumn(0) # column with the tree
+        self.SetColumnWidth(0, 175)
+        self.root = None
+    def LoadData(self, data = {}):
+        """Load data into list"""
+        # detete first all items
+        self.DeleteAllItems()
+        self.root = self.AddRoot(_("Layers"))
+        layers = data.keys()
+        if not layers:
+            return
+        layers.sort()
+        for layer in layers:
+            title = data[layer]['title']
+            lchild = self.AppendItem(self.root, layer)
+            self.SetItemText(lchild, title, 1)
+            if data[layer].has_key('style'):
+                styles = data[layer]['style'].keys()
+                if not styles:
+                    continue
+                styles.sort()
+                for style in styles:
+                    title = data[layer]['style'][style]
+                    schild = self.AppendItem(lchild, style)
+                    self.SetItemText(schild, title, 1)
+        self.Expand(self.root)
+    def GetItemCount(self):
+        """Required for listmix.ListCtrlAutoWidthMixin"""
+        return 0
+    def GetCountPerPage(self):
+        return 0
+    def GetSelectedLayers(self):
+        """Get selected layers/styles"""
+        layers = {}
+        for item in self.GetSelections():
+            parent = self.GetItemParent(item)
+            if parent == self.root: # -> layer
+                layer = self.GetItemText(item, 0)
+                layers[layer] = []
+                sitem, cookie = self.GetFirstChild(item)
+                while sitem:
+                    layers[layer].append(self.GetItemText(sitem, 0))
+                    sitem, cookie = self.GetNextChild(item, cookie)
+            else: # -> style
+                layer = self.GetItemText(parent, 0)
+                layers[layer].append(self.GetItemText(item, 0))
+        return layers
Modified: grass/branches/develbranch_6/gui/wxpython/wxgui.py
--- grass/branches/develbranch_6/gui/wxpython/wxgui.py	2009-05-09 18:46:22 UTC (rev 37083)
+++ grass/branches/develbranch_6/gui/wxpython/wxgui.py	2009-05-09 18:54:17 UTC (rev 37084)
@@ -85,6 +85,7 @@
 import gui_modules.goutput as goutput
 import gui_modules.gdialogs as gdialogs
 import gui_modules.colorrules as colorrules
+import gui_modules.ogc_services as ogc_services
 from   gui_modules.debug import Debug as Debug
 from   icons.icon import Icons as Icons
@@ -1143,7 +1144,30 @@
         dlg = gdialogs.MultiImportDialog(parent=self, type='ogr',
                                          title=_("Import OGR layers"))
         dlg.ShowModal()
+    def OnImportWMS(self, event):
+        """Import data from OGC WMS server"""
+        dlg = ogc_services.WMSDialog(parent = self, service = 'wms')
+        dlg.CenterOnScreen()
+        if dlg.ShowModal() == wx.ID_OK: # -> import layers
+            layers = dlg.GetLayers()
+                for layer in layers.keys():
+                    cmd = ['r.in.wms',
+                           'mapserver=%s' % dlg.GetSettings()['server'],
+                           'layers=%s' % layer,
+                           'output=%s' % layer]
+                    styles = ','.join(layers[layer])
+                    if styles:
+                        cmd.append('styles=%s' % styles)
+                    self.goutput.RunCmd(cmd, switchPage = True)
+            else:
+                self.goutput.WriteWarning(_("Nothing to import. No WMS layer selected."))
+        dlg.Destroy()
     def OnShowAttributeTable(self, event):
         Show attribute table of the given vector map layer
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml	2009-05-09 18:46:22 UTC (rev 37083)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml	2009-05-09 18:54:17 UTC (rev 37084)
@@ -126,8 +126,7 @@
 	    <menuitem>
 	      <label>WMS import</label>
 	      <help>Downloads and imports data from WMS servers.</help>
-	      <handler>self.OnMenuCmd</handler>
-	      <command>r.in.wms</command>
+	      <handler>self.OnImportWMS</handler>
 	    </menuitem>
 	  </items>
 	</menu>
