[GRASS-SVN] r37116 - grass/branches/releasebranch_6_4/lib/python
Sun May 10 14:46:56 EDT 2009
Author: martinl
Date: 2009-05-10 14:46:56 -0400 (Sun, 10 May 2009)
New Revision: 37116
   grass/branches/releasebranch_6_4/lib/python/grass.py
grass.region(): cast values to float
               (merge trunk, r37114)
Modified: grass/branches/releasebranch_6_4/lib/python/grass.py
--- grass/branches/releasebranch_6_4/lib/python/grass.py	2009-05-10 18:39:56 UTC (rev 37115)
+++ grass/branches/releasebranch_6_4/lib/python/grass.py	2009-05-10 18:46:56 UTC (rev 37116)
@@ -219,7 +219,7 @@
 # key-value parsers
-def parse_key_val(s, sep = '=', dflt = None):
+def parse_key_val(s, sep = '=', dflt = None, val_type = None):
     """Parse a string into a dictionary, where entries are separated
     by newlines and the key and value are separated by `sep' (default: `=')
@@ -231,7 +231,10 @@
 	    v = kv[1]
 	else:
 	    v = dflt
-	result[k] = v
+        if val_type:
+            result[k] = val_type(v)
+        else:
+            result[k] = v
     return result
 # interface to g.gisenv
@@ -248,7 +251,7 @@
 def region():
     """Returns the output from running "g.region -g", as a dictionary."""
     s = read_command("g.region", flags='g')
-    return parse_key_val(s)
+    return parse_key_val(s, val_type = float)
 def use_temp_region():
     """Copies the current region to a temporary region with "g.region save=",
