[GRASS-SVN] r37120 - grass/branches/releasebranch_6_4/lib/python
Sun May 10 15:01:06 EDT 2009
Author: martinl
Date: 2009-05-10 15:01:06 -0400 (Sun, 10 May 2009)
New Revision: 37120
   grass/branches/releasebranch_6_4/lib/python/grass.py
grass.py: parse_command() added
Modified: grass/branches/releasebranch_6_4/lib/python/grass.py
--- grass/branches/releasebranch_6_4/lib/python/grass.py	2009-05-10 18:59:33 UTC (rev 37119)
+++ grass/branches/releasebranch_6_4/lib/python/grass.py	2009-05-10 19:01:06 UTC (rev 37120)
@@ -112,6 +112,30 @@
     ps = pipe_command(*args, **kwargs)
     return ps.communicate()[0]
+def parse_command(*args, **kwargs):
+    """Passes all arguments to read_command, then optionally parses
+    the output.
+    Output can be automatically parsed if <b>parse</b> parameter is
+    given. Use True for default parse function -- parse_key_val().
+    parse = None # do not parse output
+    if kwargs.has_key('parse'):
+        if type(kwargs['parse']) is types.TupleType:
+            parse = kwargs['parse'][0]
+            parse_args = kwargs['parse'][1]
+        else:
+            parse = parse_key_val # use default fn
+            parse_args = {}
+        del kwargs['parse']
+    res = read_command(*args, **kwargs)
+    if parse:
+        return parse(res, **parse_args)
+    return res
 def write_command(*args, **kwargs):
     """Passes all arguments to feed_command, with the string specified
     by the 'stdin' argument fed to the process' stdin.
