[GRASS-SVN] r37167 - grass/trunk/general/g.mapsets
Mon May 11 13:18:54 EDT 2009
Author: hamish
Date: 2009-05-11 13:18:54 -0400 (Mon, 11 May 2009)
New Revision: 37167
Added:
   grass/trunk/general/g.mapsets/g.mapsets_picker.py
Removed:
   grass/trunk/general/g.mapsets/g.mapsets.py
   grass/trunk/general/g.mapsets/Makefile
   grass/trunk/general/g.mapsets/main.c
avoid namespace collision on MS-Windows
Modified: grass/trunk/general/g.mapsets/Makefile
--- grass/trunk/general/g.mapsets/Makefile	2009-05-11 17:12:57 UTC (rev 37166)
+++ grass/trunk/general/g.mapsets/Makefile	2009-05-11 17:18:54 UTC (rev 37167)
@@ -2,7 +2,7 @@
 MODULE_TOPDIR = ../..
 PGM = g.mapsets
-GUI = $(ETC)/gui/scripts/g.mapsets.py
+GUI = $(ETC)/gui/scripts/g.mapsets_picker.py
 LIBES     = $(GISLIB)
 DEPENDENCIES= $(GISDEP)
Deleted: grass/trunk/general/g.mapsets/g.mapsets.py
--- grass/trunk/general/g.mapsets/g.mapsets.py	2009-05-11 17:12:57 UTC (rev 37166)
+++ grass/trunk/general/g.mapsets/g.mapsets.py	2009-05-11 17:18:54 UTC (rev 37167)
@@ -1,160 +0,0 @@
-#!/usr/bin/env python
-import os
-import sys
-import pwd
-import grass
-import wx
-import wx.lib.mixins.listctrl as listmix
-class MapsetsFrame(wx.Frame):
-    def __init__(self):
-        wx.Frame.__init__(self, parent = None, id = wx.ID_ANY,
-                          title = "Check mapsets to access")
-        self.SetMinSize((350, 400))
-        sizer = wx.BoxSizer(wx.VERTICAL)
-        # list of mapsets
-        self.mapsetlb = CheckListMapset(parent=self)
-        self.mapsetlb.LoadData()
-        sizer.Add(item=self.mapsetlb, proportion=1,
-                  flag=wx.ALL | wx.EXPAND, border=5)
-        # dialog buttons
-        line = wx.StaticLine(parent=self, id=wx.ID_ANY,
-                             style=wx.LI_HORIZONTAL)
-        sizer.Add(item=line, proportion=0,
-                  flag=wx.EXPAND | wx.ALIGN_CENTRE | wx.ALL, border=5)
-        btnsizer = wx.StdDialogButtonSizer()
-        btnOK = wx.Button(self, wx.ID_OK)
-        btnOK.Bind(wx.EVT_BUTTON, self.OnOK)
-        btnOK.SetToolTipString("Close dialog and apply changes")
-        btnOK.SetDefault()
-        btnsizer.AddButton(btnOK)
-        btnCancel = wx.Button(self, wx.ID_CANCEL)
-        btnCancel.Bind(wx.EVT_BUTTON, self.OnCancel)
-        btnCancel.SetToolTipString("Close dialog and ignore changes")
-        btnsizer.AddButton(btnCancel)
-        btnsizer.Realize()
-        sizer.Add(item=btnsizer, proportion=0,
-                  flag=wx.EXPAND | wx.ALIGN_RIGHT | wx.ALL, border=5)
-        # do layout
-        self.Layout()
-        self.SetSizer(sizer)
-        sizer.Fit(self)
-    def GetMapsets(self):
-        """Get list of checked mapsets"""
-        ms = []
-        i = 0
-        for mset in self.mapsetlb.mapsets:
-            if self.mapsetlb.IsChecked(i):
-                ms.append(mset)
-            i += 1
-        return ms
-    def OnCancel(self, event):
-        """Button 'Cancel' pressed"""
-        self.Close()
-    def OnOK(self, event):
-        """Button 'OK' pressed"""
-        mapsets = ','.join(self.GetMapsets())
-        grass.run_command('g.mapsets',
-                          quiet = True,
-                          mapset = mapsets)
-        self.Close()
-class CheckListMapset(wx.ListCtrl, listmix.ListCtrlAutoWidthMixin, listmix.CheckListCtrlMixin):
-    """List of mapset/owner/group"""
-    def __init__(self, parent, pos=wx.DefaultPosition,
-                 log=None):
-        self.parent = parent
-        wx.ListCtrl.__init__(self, parent, wx.ID_ANY,
-                             style=wx.LC_REPORT)
-        listmix.CheckListCtrlMixin.__init__(self)
-        self.log = log
-        # setup mixins
-        listmix.ListCtrlAutoWidthMixin.__init__(self)
-    def LoadData(self):
-        """Load data into list"""
-        self.InsertColumn(0, 'Mapset')
-        self.InsertColumn(1, 'Owner')
-        ### self.InsertColumn(2, 'Group')
-        gisenv = grass.gisenv()
-        locationPath = os.path.join(gisenv['GISDBASE'], gisenv['LOCATION_NAME'])
-        self.curr_mapset = gisenv['MAPSET']
-        ret = grass.read_command('g.mapsets',
-                                 flags = 'l',
-                                 fs = '|')
-        self.mapsets = []
-        if ret:
-            self.mapsets = ret.rstrip('\n').split('|')
-                                 flags = 'p',
-                                 fs = '|')
-        mapsets_access = []
-        if ret:
-            mapsets_access = ret.rstrip('\n').split('|')
-        for mapset in self.mapsets:
-            index = self.InsertStringItem(sys.maxint, mapset)
-            mapsetPath = os.path.join(locationPath,
-                                      mapset)
-            stat_info = os.stat(mapsetPath)
-	    if os.name in ('posix', 'mac'):
-                self.SetStringItem(index, 1, "%s" % pwd.getpwuid(stat_info.st_uid)[0])
-                # FIXME: get group name
-                ### self.SetStringItem(index, 2, "%-8s" % stat_info.st_gid)
-	    else:
-                # FIXME: no pwd under MS Windows (owner: 0, group: 0)
-                self.SetStringItem(index, 1, "%-8s" % stat_info.st_uid)
-            if mapset in mapsets_access:
-                self.CheckItem(self.mapsets.index(mapset), True)
-        self.SetColumnWidth(col=0, width=wx.LIST_AUTOSIZE)
-        self.SetColumnWidth(col=1, width=wx.LIST_AUTOSIZE)
-    def OnCheckItem(self, index, flag):
-        """Mapset checked/unchecked"""
-        mapset = self.mapsets[index]
-        if mapset == 'PERMANENT' or mapset == self.curr_mapset:
-            self.CheckItem(index, True)
-class MyApp(wx.App):
-    def OnInit(self):
-        frame = MapsetsFrame()
-        frame.CentreOnScreen()
-        frame.Show()
-        self.SetTopWindow(frame)
-        return True
-if __name__ == "__main__":
-    app = MyApp(0)
-    app.MainLoop()
Copied: grass/trunk/general/g.mapsets/g.mapsets_picker.py (from rev 37165, grass/trunk/general/g.mapsets/g.mapsets.py)
--- grass/trunk/general/g.mapsets/g.mapsets_picker.py	                        (rev 0)
+++ grass/trunk/general/g.mapsets/g.mapsets_picker.py	2009-05-11 17:18:54 UTC (rev 37167)
@@ -0,0 +1,160 @@
+#!/usr/bin/env python
+import os
+import sys
+import pwd
+import grass
+import wx
+import wx.lib.mixins.listctrl as listmix
+class MapsetsFrame(wx.Frame):
+    def __init__(self):
+        wx.Frame.__init__(self, parent = None, id = wx.ID_ANY,
+                          title = "Check mapsets to access")
+        self.SetMinSize((350, 400))
+        sizer = wx.BoxSizer(wx.VERTICAL)
+        # list of mapsets
+        self.mapsetlb = CheckListMapset(parent=self)
+        self.mapsetlb.LoadData()
+        sizer.Add(item=self.mapsetlb, proportion=1,
+                  flag=wx.ALL | wx.EXPAND, border=5)
+        # dialog buttons
+        line = wx.StaticLine(parent=self, id=wx.ID_ANY,
+                             style=wx.LI_HORIZONTAL)
+        sizer.Add(item=line, proportion=0,
+                  flag=wx.EXPAND | wx.ALIGN_CENTRE | wx.ALL, border=5)
+        btnsizer = wx.StdDialogButtonSizer()
+        btnOK = wx.Button(self, wx.ID_OK)
+        btnOK.Bind(wx.EVT_BUTTON, self.OnOK)
+        btnOK.SetToolTipString("Close dialog and apply changes")
+        btnOK.SetDefault()
+        btnsizer.AddButton(btnOK)
+        btnCancel = wx.Button(self, wx.ID_CANCEL)
+        btnCancel.Bind(wx.EVT_BUTTON, self.OnCancel)
+        btnCancel.SetToolTipString("Close dialog and ignore changes")
+        btnsizer.AddButton(btnCancel)
+        btnsizer.Realize()
+        sizer.Add(item=btnsizer, proportion=0,
+                  flag=wx.EXPAND | wx.ALIGN_RIGHT | wx.ALL, border=5)
+        # do layout
+        self.Layout()
+        self.SetSizer(sizer)
+        sizer.Fit(self)
+    def GetMapsets(self):
+        """Get list of checked mapsets"""
+        ms = []
+        i = 0
+        for mset in self.mapsetlb.mapsets:
+            if self.mapsetlb.IsChecked(i):
+                ms.append(mset)
+            i += 1
+        return ms
+    def OnCancel(self, event):
+        """Button 'Cancel' pressed"""
+        self.Close()
+    def OnOK(self, event):
+        """Button 'OK' pressed"""
+        mapsets = ','.join(self.GetMapsets())
+        grass.run_command('g.mapsets',
+                          quiet = True,
+                          mapset = mapsets)
+        self.Close()
+class CheckListMapset(wx.ListCtrl, listmix.ListCtrlAutoWidthMixin, listmix.CheckListCtrlMixin):
+    """List of mapset/owner/group"""
+    def __init__(self, parent, pos=wx.DefaultPosition,
+                 log=None):
+        self.parent = parent
+        wx.ListCtrl.__init__(self, parent, wx.ID_ANY,
+                             style=wx.LC_REPORT)
+        listmix.CheckListCtrlMixin.__init__(self)
+        self.log = log
+        # setup mixins
+        listmix.ListCtrlAutoWidthMixin.__init__(self)
+    def LoadData(self):
+        """Load data into list"""
+        self.InsertColumn(0, 'Mapset')
+        self.InsertColumn(1, 'Owner')
+        ### self.InsertColumn(2, 'Group')
+        gisenv = grass.gisenv()
+        locationPath = os.path.join(gisenv['GISDBASE'], gisenv['LOCATION_NAME'])
+        self.curr_mapset = gisenv['MAPSET']
+        ret = grass.read_command('g.mapsets',
+                                 flags = 'l',
+                                 fs = '|')
+        self.mapsets = []
+        if ret:
+            self.mapsets = ret.rstrip('\n').split('|')
+                                 flags = 'p',
+                                 fs = '|')
+        mapsets_access = []
+        if ret:
+            mapsets_access = ret.rstrip('\n').split('|')
+        for mapset in self.mapsets:
+            index = self.InsertStringItem(sys.maxint, mapset)
+            mapsetPath = os.path.join(locationPath,
+                                      mapset)
+            stat_info = os.stat(mapsetPath)
+	    if os.name in ('posix', 'mac'):
+                self.SetStringItem(index, 1, "%s" % pwd.getpwuid(stat_info.st_uid)[0])
+                # FIXME: get group name
+                ### self.SetStringItem(index, 2, "%-8s" % stat_info.st_gid)
+	    else:
+                # FIXME: no pwd under MS Windows (owner: 0, group: 0)
+                self.SetStringItem(index, 1, "%-8s" % stat_info.st_uid)
+            if mapset in mapsets_access:
+                self.CheckItem(self.mapsets.index(mapset), True)
+        self.SetColumnWidth(col=0, width=wx.LIST_AUTOSIZE)
+        self.SetColumnWidth(col=1, width=wx.LIST_AUTOSIZE)
+    def OnCheckItem(self, index, flag):
+        """Mapset checked/unchecked"""
+        mapset = self.mapsets[index]
+        if mapset == 'PERMANENT' or mapset == self.curr_mapset:
+            self.CheckItem(index, True)
+class MyApp(wx.App):
+    def OnInit(self):
+        frame = MapsetsFrame()
+        frame.CentreOnScreen()
+        frame.Show()
+        self.SetTopWindow(frame)
+        return True
+if __name__ == "__main__":
+    app = MyApp(0)
+    app.MainLoop()
Modified: grass/trunk/general/g.mapsets/main.c
--- grass/trunk/general/g.mapsets/main.c	2009-05-11 17:12:57 UTC (rev 37166)
+++ grass/trunk/general/g.mapsets/main.c	2009-05-11 17:18:54 UTC (rev 37167)
@@ -113,8 +113,8 @@
     if (opt.dialog->answer) {
-	sprintf(path, "%s/etc/gui/scripts/g.mapsets.py", G_gisbase());
-	G_spawn(getenv("GRASS_PYTHON"), "g.mapsets.py", path, NULL);
+	sprintf(path, "%s/etc/gui/scripts/g.mapsets_picker.py", G_gisbase());
+	G_spawn(getenv("GRASS_PYTHON"), "g.mapsets_picker.py", path, NULL);
     if (opt.mapset->answer) {
