[GRASS-SVN] r37182 - in grass/trunk: lib/init mswindows
Tue May 12 02:59:49 EDT 2009
Author: hamish
Date: 2009-05-12 02:59:48 -0400 (Tue, 12 May 2009)
New Revision: 37182
   grass/trunk/lib/init/functions.sh
   grass/trunk/lib/init/init.bat
   grass/trunk/mswindows/GRASS-Installer.nsi
PATHEXT is not dynamic so put in static init.bat|sh files; icon text cosmetics (merge from devbr6)
Modified: grass/trunk/lib/init/functions.sh
--- grass/trunk/lib/init/functions.sh	2009-05-12 06:43:19 UTC (rev 37181)
+++ grass/trunk/lib/init/functions.sh	2009-05-12 06:59:48 UTC (rev 37182)
@@ -131,6 +131,12 @@
 	PYTHONPATH="$GISBASE/etc/python:$PYTHONPATH"
     fi
     export PYTHONPATH
+    # Add python to list of executable extensions to search for in MS-Windows PATH
+    if [ "$MINGW" ] ; then
+	PATHEXT="${PATHEXT};.PY"
+	export PATHEXT
+    fi
 set_defaults()
Modified: grass/trunk/lib/init/init.bat
--- grass/trunk/lib/init/init.bat	2009-05-12 06:43:19 UTC (rev 37181)
+++ grass/trunk/lib/init/init.bat	2009-05-12 06:59:48 UTC (rev 37182)
@@ -46,6 +46,9 @@
 if "%GRASS_HTML_BROWSER%"=="" set GRASS_HTML_BROWSER=%SYSTEMDRIVE%/PROGRA~1/INTERN~1/IEXPLORE.EXE
 if "%GRASS_PROJSHARE%"=="" set GRASS_PROJSHARE=CONFIG_PROJSHARE
+rem Add python scripts to the PATHEXT variable
+set PATHEXT=%PATHEXT%;.PY
 if "%1" == "-version" goto displaylicence
 if "%1" == "-v" goto displaylicence
@@ -102,6 +105,7 @@
 :wxpython
 set PYTHONPATH=%PYTHONPATH%;%WINGISBASE%\etc\python;%WINGISBASE%\etc\wxpython
 python "%GISBASE%/etc/wxpython/gis_set.py"
 if %errorlevel% == 2 goto exitinit
Modified: grass/trunk/mswindows/GRASS-Installer.nsi
--- grass/trunk/mswindows/GRASS-Installer.nsi	2009-05-12 06:43:19 UTC (rev 37181)
+++ grass/trunk/mswindows/GRASS-Installer.nsi	2009-05-12 06:59:48 UTC (rev 37182)
@@ -482,34 +482,37 @@
 	SetShellVarContext current
 	CreateShortCut "$DESKTOP\GRASS ${VERSION_NUMBER}.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-wxpython"\
-	"$INSTALL_DIR\icons\GRASS.ico" "" SW_SHOWMINIMIZED "" "Launch GRASS ${VERSION_NUMBER}"
+	"$INSTALL_DIR\icons\GRASS.ico" "" SW_SHOWMINIMIZED "" "Launch GRASS ${VERSION_NUMBER} with the new wxPython GUI"
-	CreateShortCut "$DESKTOP\GRASS ${VERSION_NUMBER} msys.lnk" "$INSTALL_DIR\msys\msys.bat" "/grass/bin/${GRASS_COMMAND} -wxpython"\
-	"$INSTALL_DIR\icons\GRASS.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER} with msys Terminal"
+	CreateShortCut "$DESKTOP\GRASS ${VERSION_NUMBER} with MSYS.lnk" "$INSTALL_DIR\msys\msys.bat" "/grass/bin/${GRASS_COMMAND} -wxpython"\
+	"$INSTALL_DIR\icons\GRASS.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER} with the new wxPython GUI and a MSYS UNIX terminal"
 	;Create the Windows Start Menu Shortcuts
 	SetShellVarContext all
 	CreateDirectory "$SMPROGRAMS\${GRASS_BASE}"
-	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS Old GUI.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-tcltk"\
+	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS Old TclTk GUI.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-tcltk"\
+	"$INSTALL_DIR\icons\GRASS.ico" "" SW_SHOWMINIMIZED "" "Launch GRASS ${VERSION_NUMBER} with the old TclTk GUI"
 	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS ${VERSION_NUMBER}.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-wxpython"\
 	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS Command Line.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-text"\
-	"$INSTALL_DIR\icons\GRASS_CMD.ico" "" SW_SHOWNORMAL "" "Launch GRASS in Text Mode on the Command Line"
+	"$INSTALL_DIR\icons\GRASS_CMD.ico" "" SW_SHOWNORMAL "" "Launch GRASS in text mode"
-	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS MSYS Console.lnk" "$INSTALL_DIR\msys\msys.bat" ""\
-	"$INSTALL_DIR\icons\MSYS_Custom_Icon.ico" "" SW_SHOWNORMAL "" "Open the MSYS Console"
+	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\MSYS UNIX Console.lnk" "$INSTALL_DIR\msys\msys.bat" ""\
+	"$INSTALL_DIR\icons\MSYS_Custom_Icon.ico" "" SW_SHOWNORMAL "" "Open a MSYS UNIX console"
 	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS Web Site.lnk" "$INSTALL_DIR\GRASS-WebSite.url" ""\
-	"$INSTALL_DIR\icons\GRASS_Web.ico" "" SW_SHOWNORMAL "" "Visit the GRASS Web Site"
+	"$INSTALL_DIR\icons\GRASS_Web.ico" "" SW_SHOWNORMAL "" "Visit the GRASS website"
-	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS ${VERSION_NUMBER} msys.lnk" "$INSTALL_DIR\msys\msys.bat" "/grass/bin/${GRASS_COMMAND} -wxpython"\
-	"$INSTALL_DIR\icons\GRASS.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER} with MSYS Terminal"
+	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS ${VERSION_NUMBER} with MSYS.lnk" "$INSTALL_DIR\msys\msys.bat" "/grass/bin/${GRASS_COMMAND} -wxpython"\
+; FIXME: ship the WinGrass release notes .html file instead of URL
+; http://trac.osgeo.org/grass/browser/grass-web/trunk/grass64/binary/mswindows/native/README.html?format=raw
+; probably ship with devel versions too? ie Release Notes, not the Release Announcement press release.
 	!if ${INSTALLER_TYPE} == "Release"
 		CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\Release Notes.lnk" "$INSTALL_DIR\WinGRASS-README.url" ""\
 		"$INSTALL_DIR\icons\WinGRASS.ico" "" SW_SHOWNORMAL "" "Visit the WinGRASS Project Web Page"
@@ -562,9 +565,6 @@
 	FileWrite $0 'rem Path to the python directory$\r$\n'
 	FileWrite $0 'set PYTHONHOME=%GRASSDIR%\Python25$\r$\n'
 	FileWrite $0 '$\r$\n'
-	FileWrite $0 'rem Add python scripts to the PATHEXT variable$\r$\n'
-	FileWrite $0 'set PATHEXT=%PATHEXT%;.PY$\r$\n'
-	FileWrite $0 '$\r$\n'
 	FileWrite $0 'set WINGISBASE=%GRASSDIR%$\r$\n'
 	FileWrite $0 '"%WINGISBASE%\etc\Init.bat" %*'
 	FileClose $0
