[GRASS-SVN] r37245 - grass/branches/develbranch_6/imagery/i.atcorr
Sat May 16 12:42:16 EDT 2009
Author: neteler
Date: 2009-05-16 12:42:16 -0400 (Sat, 16 May 2009)
New Revision: 37245
   grass/branches/develbranch_6/imagery/i.atcorr/main.cpp
downsize the static cache for 32bit CPUs
Modified: grass/branches/develbranch_6/imagery/i.atcorr/main.cpp
--- grass/branches/develbranch_6/imagery/i.atcorr/main.cpp	2009-05-16 16:41:59 UTC (rev 37244)
+++ grass/branches/develbranch_6/imagery/i.atcorr/main.cpp	2009-05-16 16:42:16 UTC (rev 37245)
@@ -29,6 +29,7 @@
 * Addition of IRS-1C LISS, Feb 2009: Markus Neteler
+TODO: use dynamic allocation for TiCache
 #include <cstdlib>
@@ -131,7 +132,9 @@
     enum TICacheSize
-        MAX_TIs = 8192 /* this value is a guess, increase it if in general more categories are used */
+        MAX_TIs = 4096 /* this value is a guess, increase it if in general
+                        * more categories are used. TODO: use dynamic allocation
+                        * since 4096 is the limit on 32bit */
     TransformInput tis[MAX_TIs];
     float alts[MAX_TIs];
@@ -173,8 +176,9 @@
     enum TIMapSize
-	MAX_TICs = 8192  /* this value is a guess. It means that <size> TI's will be
-                          * the max combinations of vis/alt pairs */
+	MAX_TICs = 4096  /* this value is a guess. It means that <size> TI's will be
+                          * the max combinations of vis/alt pairs. TODO: use dynamic allocation
     TICache tic[MAX_TICs]; /* array of TICaches */
