[GRASS-SVN] r37264 - grass/branches/develbranch_6/lib/vector/diglib
Mon May 18 13:24:10 EDT 2009
Author: martinl
Date: 2009-05-18 13:24:10 -0400 (Mon, 18 May 2009)
New Revision: 37264
   grass/branches/develbranch_6/lib/vector/diglib/file.c
doxygen updated (diglib/file.c)
	(merge from trunk, r37263)
Modified: grass/branches/develbranch_6/lib/vector/diglib/file.c
--- grass/branches/develbranch_6/lib/vector/diglib/file.c	2009-05-18 17:14:59 UTC (rev 37263)
+++ grass/branches/develbranch_6/lib/vector/diglib/file.c	2009-05-18 17:24:10 UTC (rev 37264)
@@ -1,19 +1,22 @@
+   \file diglib/file.c
-* MODULE:       Vector library
-* AUTHOR(S):    Dave Gerdes, Radim Blazek
-* PURPOSE:      Lower level functions for reading/writing/manipulating vectors.
-* COPYRIGHT:    (C) 2001 by the GRASS Development Team
-*               This program is free software under the GNU General Public
-*   	    	License (>=v2). Read the file COPYING that comes with GRASS
-*   	    	for details.
+   \brief Vector library (diglib) - file management
+   Lower level functions for reading/writing/manipulating vectors.
+   Note: seems that the time is almost the same for both cases:
+    - reading from file
+    - load whole file to memory and read from memory
+   (C) 2001-2009 by the GRASS Development Team
+   This program is free software under the GNU General Public License
+   (>=v2).  Read the file COPYING that comes with GRASS for details.
+   \author Dave Gerdes, Radim Blazek
 #include <string.h>
 #include <stdio.h>
 #include <unistd.h>
@@ -21,32 +24,42 @@
 #include <sys/stat.h>
 #include <grass/gis.h>
 #include <grass/Vect.h>
+#include <grass/glocale.h>
- *  Note: seems that the time is almost the same for both cases:
- *        - reading from file
- *        - load whole file to memory and read from memory
+  \brief Get GVFILE position.
-/* Get GVFILE position.
- *  Returns: current file position
-long dig_ftell(GVFILE * file)
+  \param file pointer to GVFILE structure
+  \return current file position
+long dig_ftell(GVFILE *file)
-    if (file->loaded)		/* using memory */
+    if (file->loaded) /* using memory */
 	return (file->current - file->start);
     return (ftell(file->file));
-/* Set GVFILE position.
- *  Returns: 0 OK, -1 error
+  \brief Set GVFILE position.
+  Start positions:
+   - SEEK_SET (start)
+   - SEEK_CUR (current position)
+   - SEEK_END (end)
+  \param offset offset position
+  \param whence start position
+  \return 0 OK
+  \return -1 error
 int dig_fseek(GVFILE * file, long offset, int whence)
-    if (file->loaded) {		/* using memory */
+    if (file->loaded) {	 /* using memory */
 	switch (whence) {
 	case SEEK_SET:
 	    file->current = file->start + offset;
@@ -64,13 +77,14 @@
     return (fseek(file->file, offset, whence));
-/* Rewind  GVFILE position.
- *  Returns: nothing
+  \brief Rewind GVFILE position.
 void dig_rewind(GVFILE * file)
 	file->current = file->start;
     else {
@@ -78,13 +92,16 @@
-/* Flush GVFILE.
+  \brief Flush GVFILE.
+  \return 0
 int dig_fflush(GVFILE * file)
 	return 0;
     else {
@@ -92,17 +109,23 @@
-/* Read GVFILE.
- *  Returns: number of read members
+  \brief Read GVFILE.
+  \param[out] ptr data buffer
+  \param size buffer size
+  \param nmemb number of members
+  \return number of read members
-size_t dig_fread(void *ptr, size_t size, size_t nmemb, GVFILE * file)
+size_t dig_fread(void *ptr, size_t size, size_t nmemb, GVFILE *file)
     long tot;
     size_t cnt;
-	if (file->current >= file->end) {	/* EOF */
+	if (file->current >= file->end) { /* EOF */
 	    return 0;
 	tot = size * nmemb;
@@ -118,24 +141,31 @@
     return (fread(ptr, size, nmemb, file->file));
-/* Write GVFILE.
- *  Returns: number of items written
+  \brief Write GVFILE.
+  \param ptr data buffer
+  \param[out] file pointer to GVFILE structure
+  \return number of items written
-size_t dig_fwrite(void *ptr, size_t size, size_t nmemb, GVFILE * file)
+size_t dig_fwrite(void *ptr, size_t size, size_t nmemb, GVFILE *file)
-	G_fatal_error("Writing to file loaded to memory not supported");
+	G_fatal_error(_("Writing to file loaded to memory not supported"));
     return fwrite(ptr, size, nmemb, file->file);
-/* Init GVFILE.
-void dig_file_init(GVFILE * file)
+  \brief Initialize GVFILE.
+void dig_file_init(GVFILE *file)
     file->file = NULL;
     file->start = NULL;
@@ -146,11 +176,17 @@
     file->loaded = 0;
-/* Load opened GVFILE to memory.
- *  Warning: position in file is set to the beginning.
- *  Returns: 1 loaded, 0, not loaded, -1 Error
+  \brief Load opened GVFILE to memory.
+  Warning: position in file is set to the beginning.
+  \return 1 loaded
+  \return 0 not loaded
+  \return -1 error
 int dig_file_load(GVFILE * file)
     int ret, mode, load;
@@ -161,7 +197,7 @@
     G_debug(2, "dig_file_load ()");
     if (file->file == NULL) {
-	G_warning("Cannot load file to memory, file not open.");
+	G_warning(_("Unable to load file to memory, file not open"));
 	return -1;
@@ -176,16 +212,16 @@
 	else if (G_strcasecmp(cmode, "AUTO") == 0)
 	    mode = GV_MEMORY_AUTO;
 	else
-	    G_warning("Vector memory mode not supported, using 'AUTO'");
+	    G_warning(_("Vector memory mode not supported, using 'AUTO'"));
     G_debug(2, "  requested mode = %d", mode);
     fstat(fileno(file->file), &sbuf);
     size = sbuf.st_size;
     G_debug(2, "  size = %u", size);
     /* Decide if the file should be loaded */
     /* TODO: I don't know how to get size of free memory (portability) to decide if load or not for auto */
     if (mode == GV_MEMORY_AUTO)
@@ -225,10 +261,11 @@
     return 0;
-/* Free GVFILE.
+  \brief Free GVFILE.
 void dig_file_free(GVFILE * file)
     if (file->loaded) {
