[GRASS-SVN] r37345 - in grass/trunk: lib/python swig/python
Thu May 21 17:16:29 EDT 2009
Author: martinl
Date: 2009-05-21 17:16:28 -0400 (Thu, 21 May 2009)
New Revision: 37345
Added:
   grass/trunk/lib/python/__init__.py
   grass/trunk/lib/python/core.py
   grass/trunk/lib/python/db.py
   grass/trunk/lib/python/raster.py
   grass/trunk/lib/python/vector.py
Removed:
   grass/trunk/lib/python/grass.py
   grass/trunk/lib/python/Makefile
   grass/trunk/swig/python/Makefile
Python swig and script modules reorganized
grass
grass.lib
grass.lib.*
grass.script
grass.script.core
grass.script.db
grass.script.raster
grass.script.vector
Modified: grass/trunk/lib/python/Makefile
--- grass/trunk/lib/python/Makefile	2009-05-21 20:53:52 UTC (rev 37344)
+++ grass/trunk/lib/python/Makefile	2009-05-21 21:16:28 UTC (rev 37345)
@@ -3,13 +3,29 @@
 include $(MODULE_TOPDIR)/include/Make/Other.make
 include $(MODULE_TOPDIR)/include/Make/Doxygen.make
-default: $(ETC)/python
-	$(MAKE) $(ETC)/python/grass.py $(ETC)/python/README.txt
+PYDIR = $(ETC)/python
+GDIR = $(PYDIR)/grass
+DSTDIR = $(GDIR)/script
-$(ETC)/python:
-	-if [ ! -d $@ ]; then $(MKDIR) $@; fi
+MODULES = grass core db raster vector
-$(ETC)/python/%: %
+PYFILES := $(patsubst %,$(DSTDIR)/%.py,$(MODULES) __init__)
+default: $(DSTDIR)
+	$(MAKE) $(PYFILES) $(DSTDIR)/README.txt
+$(PYDIR):
+	test -d $@ || $(MKDIR) -p $@
+$(GDIR): $(PYDIR)
+$(DSTDIR): $(GDIR)
+	test -f __init__.py || touch $(GDIR)/__init__.py
+	@echo "import script" >> $(GDIR)/__init__.py
+$(DSTDIR)/%: %
 	$(INSTALL_DATA) $< $@
 #doxygen:
Added: grass/trunk/lib/python/__init__.py
--- grass/trunk/lib/python/__init__.py	                        (rev 0)
+++ grass/trunk/lib/python/__init__.py	2009-05-21 21:16:28 UTC (rev 37345)
@@ -0,0 +1,4 @@
+import core
+import db
+import raster
+import vector
Property changes on: grass/trunk/lib/python/__init__.py
___________________________________________________________________
   + text/x-python
   + Author Date Id
   + native
Added: grass/trunk/lib/python/core.py
--- grass/trunk/lib/python/core.py	                        (rev 0)
+++ grass/trunk/lib/python/core.py	2009-05-21 21:16:28 UTC (rev 37345)
@@ -0,0 +1,512 @@
+ at package grass.script.core
+ at brief GRASS Python scripting module
+Core functions to be used in Python scripts.
+Usage:
+ at code
+from grass.script import core as grass
+grass.parser()
+ at endcode
+(C) 2008-2009 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Glynn Clements
+ at author Martin Landa <landa.martin gmail.com>
+import os
+import sys
+import types
+import re
+import atexit
+import subprocess
+# subprocess wrapper that uses shell on Windows
+class Popen(subprocess.Popen):
+    def __init__(self, args, bufsize=0, executable=None,
+                 stdin=None, stdout=None, stderr=None,
+                 preexec_fn=None, close_fds=False, shell=None,
+                 cwd=None, env=None, universal_newlines=False,
+                 startupinfo=None, creationflags=0):
+	if shell == None:
+	    shell = (sys.platform == "win32")
+	subprocess.Popen.__init__(self, args, bufsize, executable,
+                                  stdin, stdout, stderr,
+                                  preexec_fn, close_fds, shell,
+                                  cwd, env, universal_newlines,
+                                  startupinfo, creationflags)
+PIPE = subprocess.PIPE
+STDOUT = subprocess.STDOUT
+def call(*args, **kwargs):
+    return Popen(*args, **kwargs).wait()
+# GRASS-oriented interface to subprocess module
+_popen_args = ["bufsize", "executable", "stdin", "stdout", "stderr",
+	       "preexec_fn", "close_fds", "cwd", "env",
+	       "universal_newlines", "startupinfo", "creationflags"]
+def _make_val(val):
+    if isinstance(val, types.StringType):
+	return val
+    if isinstance(val, types.ListType):
+	return ",".join(map(_make_val, val))
+    if isinstance(val, types.TupleType):
+	return _make_val(list(val))
+    return str(val)
+def make_command(prog, flags = "", overwrite = False, quiet = False, verbose = False, **options):
+    """Return a list of strings suitable for use as the args parameter to
+    Popen() or call(). Example:
+    >>> grass.make_command("g.message", flags = 'w', message = 'this is a warning')
+    ['g.message', '-w', 'message=this is a warning']
+    args = [prog]
+    if overwrite:
+	args.append("--o")
+    if quiet:
+	args.append("--q")
+    if verbose:
+	args.append("--v")
+    if flags:
+	args.append("-%s" % flags)
+    for opt, val in options.iteritems():
+	if val != None:
+	    if opt[0] == '_':
+		opt = opt[1:]
+	    args.append("%s=%s" % (opt, _make_val(val)))
+    return args
+def start_command(prog, flags = "", overwrite = False, quiet = False, verbose = False, **kwargs):
+    """Returns a Popen object with the command created by make_command.
+    Accepts any of the arguments which Popen() accepts apart from "args"
+    and "shell".
+    options = {}
+    popts = {}
+    for opt, val in kwargs.iteritems():
+	if opt in _popen_args:
+	    popts[opt] = val
+	else:
+	    options[opt] = val
+    args = make_command(prog, flags, overwrite, quiet, verbose, **options)
+    return Popen(args, **popts)
+def run_command(*args, **kwargs):
+    """Passes all arguments to start_command, then waits for the process to
+    complete, returning its exit code. Similar to subprocess.call(), but
+    with the make_command() interface.
+    ps = start_command(*args, **kwargs)
+    return ps.wait()
+def pipe_command(*args, **kwargs):
+    """Passes all arguments to start_command, but also adds
+    "stdout = PIPE". Returns the Popen object.
+    kwargs['stdout'] = PIPE
+    return start_command(*args, **kwargs)
+def feed_command(*args, **kwargs):
+    "stdin = PIPE". Returns the Popen object.
+    kwargs['stdin'] = PIPE
+def read_command(*args, **kwargs):
+    """Passes all arguments to pipe_command, then waits for the process to
+    complete, returning its stdout (i.e. similar to shell `backticks`).
+    ps = pipe_command(*args, **kwargs)
+    return ps.communicate()[0]
+def parse_command(*args, **kwargs):
+    """Passes all arguments to read_command, then parses the output by
+    parse_key_val().
+    Parsing function can be optionally given by <b>parse</b> parameter
+    including its arguments, e.g.
+    @code
+    parse_command(..., parse = (grass.parse_key_val, { 'sep' : ':' }))
+    @endcode
+    parse = None
+    if kwargs.has_key('parse'):
+        if type(kwargs['parse']) is types.TupleType:
+            parse = kwargs['parse'][0]
+            parse_args = kwargs['parse'][1]
+        del kwargs['parse']
+    if not parse:
+        parse = parse_key_val # use default fn
+        parse_args = {}
+    res = read_command(*args, **kwargs)
+    return parse(res, **parse_args)
+def write_command(*args, **kwargs):
+    """Passes all arguments to feed_command, with the string specified
+    by the 'stdin' argument fed to the process' stdin.
+    stdin = kwargs['stdin']
+    p = feed_command(*args, **kwargs)
+    p.stdin.write(stdin)
+    p.stdin.close()
+    return p.wait()
+def exec_command(prog, flags = "", overwrite = False, quiet = False, verbose = False, env = None, **kwargs):
+    """Interface to os.execvpe(), but with the make_command() interface."""
+    args = make_command(prog, flags, overwrite, quiet, verbose, **kwargs)
+    if env == None:
+	env = os.environ
+    os.execvpe(prog, args, env)
+# interface to g.message
+def message(msg, flag = None):
+    """Display a message using g.message"""
+    run_command("g.message", flags = flag, message = msg)
+def debug(msg, debug = 1):
+    """Display a debugging message using g.message -d"""
+    run_command("g.message", flags = 'd', message = msg, debug = debug)
+def verbose(msg):
+    """Display a verbose message using g.message -v"""
+    message(msg, flag = 'v')
+def info(msg):
+    """Display an informational message using g.message -i"""
+    message(msg, flag = 'i')
+def warning(msg):
+    """Display a warning message using g.message -w"""
+    message(msg, flag = 'w')
+def error(msg):
+    """Display an error message using g.message -e"""
+    message(msg, flag = 'e')
+def fatal(msg):
+    """Display an error message using g.message -e, then abort"""
+    error(msg)
+    sys.exit(1)
+# interface to g.parser
+def _parse_env():
+    options = {}
+    flags = {}
+    for var, val in os.environ.iteritems():
+	if var.startswith("GIS_OPT_"):
+	    opt = var.replace("GIS_OPT_", "", 1).lower()
+	    options[opt] = val;
+	if var.startswith("GIS_FLAG_"):
+	    flg = var.replace("GIS_FLAG_", "", 1).lower()
+	    flags[flg] = bool(int(val));
+    return (options, flags)
+def parser():
+    """Interface to g.parser, intended to be run from the top-level, e.g.:
+	if __name__ == "__main__":
+	    options, flags = grass.parser()
+	    main()
+    Thereafter, the global variables "options" and "flags" will be
+    dictionaries containing option/flag values, keyed by lower-case
+    option/flag names. The values in "options" are strings, those in
+    "flags" are Python booleans.
+    if not os.getenv("GISBASE"):
+        print >> sys.stderr, "You must be in GRASS GIS to run this program."
+        sys.exit(1)
+    if len(sys.argv) > 1 and sys.argv[1] == "@ARGS_PARSED@":
+	return _parse_env()
+    cmdline = [basename(sys.argv[0])]
+    cmdline += ['"' + arg + '"' for arg in sys.argv[1:]]
+    os.environ['CMDLINE'] = ' '.join(cmdline)
+    argv = sys.argv[:]
+    name = argv[0]
+    if not os.path.isabs(name):
+	if os.sep in name or (os.altsep and os.altsep in name):
+	    argv[0] = os.path.abspath(name)
+	else:
+	    argv[0] = os.path.join(sys.path[0], name)
+    if sys.platform == "win32":
+       os.execvp("g.parser.exe", [name] + argv)
+    else:
+       os.execvp("g.parser", [name] + argv)
+    raise OSError("error executing g.parser")
+# interface to g.tempfile
+def tempfile():
+    """Returns the name of a temporary file, created with g.tempfile."""
+    return read_command("g.tempfile", pid = os.getpid()).strip()
+# key-value parsers
+def parse_key_val(s, sep = '=', dflt = None, val_type = None, vsep = None):
+    """Parse a string into a dictionary, where entries are separated
+    by newlines and the key and value are separated by `sep' (default: `=')
+    result = {}
+    if not s:
+        return result
+    if vsep:
+        lines = s.split(vsep)
+        try:
+            lines.remove('\n')
+        except ValueError:
+            pass
+    else:
+        lines = s.splitlines()
+    for line in lines:
+	kv = line.split(sep, 1)
+	k = kv[0].strip()
+	if len(kv) > 1:
+	    v = kv[1]
+	else:
+	    v = dflt
+        if val_type:
+            result[k] = val_type(v)
+        else:
+            result[k] = v
+    return result
+# interface to g.gisenv
+def gisenv():
+    """Returns the output from running g.gisenv (with no arguments), as a
+    dictionary.
+    s = read_command("g.gisenv", flags='n')
+    return parse_key_val(s)
+# interface to g.region
+def region():
+    """Returns the output from running "g.region -g", as a dictionary."""
+    s = read_command("g.region", flags='g')
+    return parse_key_val(s, val_type = float)
+def use_temp_region():
+    """Copies the current region to a temporary region with "g.region save=",
+    then sets WIND_OVERRIDE to refer to that region. Installs an atexit
+    handler to delete the temporary region upon termination.
+    name = "tmp.%s.%d" % (os.path.basename(sys.argv[0]), os.getpid())
+    run_command("g.region", save = name)
+    os.environ['WIND_OVERRIDE'] = name
+    atexit.register(del_temp_region)
+def del_temp_region():
+    """Unsets WIND_OVERRIDE and removes any region named by it."""
+    try:
+	name = os.environ.pop('WIND_OVERRIDE')
+	run_command("g.remove", quiet = True, region = name)
+    except:
+	pass
+# interface to g.findfile
+def find_file(name, element = 'cell', mapset = None):
+    """Returns the output from running g.findfile as a dictionary."""
+    s = read_command("g.findfile", flags='n', element = element, file = name, mapset = mapset)
+# interface to g.list
+def list_grouped(type):
+    """Returns the output from running g.list, as a dictionary where the keys
+    are mapset names and the values are lists of maps in that mapset.
+    dashes_re = re.compile("^----+$")
+    mapset_re = re.compile("<(.*)>")
+    result = {}
+    mapset = None
+    for line in read_command("g.list", type = type).splitlines():
+	if line == "":
+	    continue
+	if dashes_re.match(line):
+	    continue
+	m = mapset_re.search(line)
+	if m:
+	    mapset = m.group(1)
+	    result[mapset] = []
+	    continue
+        if mapset:
+            result[mapset].extend(line.split())
+    return result
+def mlist_grouped(type, mapset = None, pattern = None):
+    """Returns the output from running g.mlist, as a dictionary where the keys
+    result = {}
+    mapset_element = None
+    for line in read_command("g.mlist", flags="m",
+                             type = type, mapset = mapset, pattern = pattern).splitlines():
+        try:
+            map, mapset_element = line.split('@')
+            print >> sys.stderr, "Invalid element '%s'" % line
+            continue
+        if result.has_key(mapset_element):
+            result[mapset_element].append(map)
+        else:
+	    result[mapset_element] = [map, ]
+    return result
+def _concat(xs):
+    result = []
+    for x in xs:
+	result.extend(x)
+    return result
+def list_pairs(type):
+    """Returns the output from running g.list, as a list of (map, mapset)
+    pairs.
+    return _concat([[(map, mapset) for map in maps]
+		    for mapset, maps in list_grouped(type).iteritems()])
+def list_strings(type):
+    """Returns the output from running g.list, as a list of qualified names."""
+    return ["%s@%s" % pair for pair in list_pairs(type)]
+# color parsing
+named_colors = {
+    "white":   (1.00, 1.00, 1.00),
+    "black":   (0.00, 0.00, 0.00),
+    "red":     (1.00, 0.00, 0.00),
+    "green":   (0.00, 1.00, 0.00),
+    "blue":    (0.00, 0.00, 1.00),
+    "yellow":  (1.00, 1.00, 0.00),
+    "magenta": (1.00, 0.00, 1.00),
+    "cyan":    (0.00, 1.00, 1.00),
+    "aqua":    (0.00, 0.75, 0.75),
+    "grey":    (0.75, 0.75, 0.75),
+    "gray":    (0.75, 0.75, 0.75),
+    "orange":  (1.00, 0.50, 0.00),
+    "brown":   (0.75, 0.50, 0.25),
+    "purple":  (0.50, 0.00, 1.00),
+    "violet":  (0.50, 0.00, 1.00),
+    "indigo":  (0.00, 0.50, 1.00)}
+def parse_color(val, dflt = None):
+    """Parses the string "val" as a GRASS colour, which can be either one of
+    the named colours or an R:G:B tuple e.g. 255:255:255. Returns an
+    (r,g,b) triple whose components are floating point values between 0
+    and 1.
+    if val in named_colors:
+        return named_colors[val]
+    vals = val.split(':')
+    if len(vals) == 3:
+        return tuple(float(v) / 255 for v in vals)
+    return dflt
+# check GRASS_OVERWRITE
+def overwrite():
+    """Return True if existing files may be overwritten"""
+    owstr = 'GRASS_OVERWRITE'
+    return owstr in os.environ and os.environ[owstr] != '0'
+# check GRASS_VERBOSE
+def verbosity():
+    """Return the verbosity level selected by GRASS_VERBOSE"""
+    vbstr = os.getenv('GRASS_VERBOSE')
+    if vbstr:
+	return int(vbstr)
+    else:
+	return 0
+## various utilities, not specific to GRASS
+# basename inc. extension stripping
+def basename(path, ext = None):
+    """Remove leading directory components and an optional extension
+    from the specified path
+    name = os.path.basename(path)
+    if not ext:
+	return name
+    fs = name.rsplit('.', 1)
+    if len(fs) > 1 and fs[1].lower() == ext:
+	name = fs[0]
+    return name
+# find a program (replacement for "which")
+def find_program(pgm, args = []):
+    """Attempt to run a program, with optional arguments. Return False
+    if the attempt failed due to a missing executable, True otherwise
+    nuldev = file(os.devnull, 'w+')
+    try:
+	call([pgm] + args, stdin = nuldev, stdout = nuldev, stderr = nuldev)
+	found = True
+    except:
+	found = False
+    nuldev.close()
+    return found
+# try to remove a file, without complaints
+def try_remove(path):
+    """Attempt to remove a file; no exception is generated if the
+    attempt fails.
+    try:
+	os.remove(path)
+    except:
+	pass
+# try to remove a directory, without complaints
+def try_rmdir(path):
+    """Attempt to remove a directory; no exception is generated if the
+    attempt fails.
+    try:
+	os.rmdir(path)
+    except:
+	pass
+def float_or_dms(s):
+    return sum(float(x) / 60 ** n for (n, x) in enumerate(s.split(':')))
Property changes on: grass/trunk/lib/python/core.py
   + text/x-python
   + Author Date Id
   + native
Added: grass/trunk/lib/python/db.py
--- grass/trunk/lib/python/db.py	                        (rev 0)
+++ grass/trunk/lib/python/db.py	2009-05-21 21:16:28 UTC (rev 37345)
@@ -0,0 +1,62 @@
+ at package grass.script.db
+Database related functions to be used in Python scripts.
+Usage:
+ at code
+from grass.script import core, db as grass
+grass.parser()
+grass.db_describe(table)
+ at endcode
+for details.
+from core import *
+# run "db.describe -c ..." and parse output
+def db_describe(table, **args):
+    """Return the list of columns for a database table
+    (interface to `db.describe -c').
+    s = read_command('db.describe', flags = 'c', table = table, **args)
+    if not s:
+	return None
+    cols = []
+    result = {}
+    for l in s.splitlines():
+	f = l.split(':')
+	key = f[0]
+	f[1] = f[1].lstrip(' ')
+	if key.startswith('Column '):
+	    n = int(key.split(' ')[1])
+	    cols.insert(n, f[1:])
+	elif key in ['ncols', 'nrows']:
+	    result[key] = int(f[1])
+	else:
+	    result[key] = f[1:]
+    result['cols'] = cols
+    return result
+# run "db.connect -p" and parse output
+def db_connection():
+    """Return the current database connection parameters
+    (interface to `db.connect -p').
+    s = read_command('db.connect', flags = 'p')
+    return parse_key_val(s, sep = ':')
Property changes on: grass/trunk/lib/python/db.py
   + text/x-python
   + Author Date Id
   + native
Deleted: grass/trunk/lib/python/grass.py
--- grass/trunk/lib/python/grass.py	2009-05-21 20:53:52 UTC (rev 37344)
+++ grass/trunk/lib/python/grass.py	2009-05-21 21:16:28 UTC (rev 37345)
@@ -1,636 +0,0 @@
-import os
-import sys
-import types
-import subprocess
-import re
-import atexit
-import string
-import types
-# subprocess wrapper that uses shell on Windows
-class Popen(subprocess.Popen):
-    def __init__(self, args, bufsize=0, executable=None,
-                 stdin=None, stdout=None, stderr=None,
-                 preexec_fn=None, close_fds=False, shell=None,
-                 cwd=None, env=None, universal_newlines=False,
-                 startupinfo=None, creationflags=0):
-	if shell == None:
-	    shell = (sys.platform == "win32")
-	subprocess.Popen.__init__(self, args, bufsize, executable,
-                                  stdin, stdout, stderr,
-                                  preexec_fn, close_fds, shell,
-                                  cwd, env, universal_newlines,
-                                  startupinfo, creationflags)
-PIPE = subprocess.PIPE
-STDOUT = subprocess.STDOUT
-def call(*args, **kwargs):
-    return Popen(*args, **kwargs).wait()
-# GRASS-oriented interface to subprocess module
-_popen_args = ["bufsize", "executable", "stdin", "stdout", "stderr",
-	       "preexec_fn", "close_fds", "cwd", "env",
-	       "universal_newlines", "startupinfo", "creationflags"]
-def _make_val(val):
-    if isinstance(val, types.StringType):
-	return val
-    if isinstance(val, types.ListType):
-	return ",".join(map(_make_val, val))
-    if isinstance(val, types.TupleType):
-	return _make_val(list(val))
-    return str(val)
-def make_command(prog, flags = "", overwrite = False, quiet = False, verbose = False, **options):
-    """Return a list of strings suitable for use as the args parameter to
-    Popen() or call(). Example:
-    >>> grass.make_command("g.message", flags = 'w', message = 'this is a warning')
-    ['g.message', '-w', 'message=this is a warning']
-    args = [prog]
-    if overwrite:
-	args.append("--o")
-    if quiet:
-	args.append("--q")
-    if verbose:
-	args.append("--v")
-    if flags:
-	args.append("-%s" % flags)
-    for opt, val in options.iteritems():
-	if val != None:
-	    if opt[0] == '_':
-		opt = opt[1:]
-	    args.append("%s=%s" % (opt, _make_val(val)))
-    return args
-def start_command(prog, flags = "", overwrite = False, quiet = False, verbose = False, **kwargs):
-    """Returns a Popen object with the command created by make_command.
-    Accepts any of the arguments which Popen() accepts apart from "args"
-    and "shell".
-    options = {}
-    popts = {}
-    for opt, val in kwargs.iteritems():
-	if opt in _popen_args:
-	    popts[opt] = val
-	else:
-	    options[opt] = val
-    args = make_command(prog, flags, overwrite, quiet, verbose, **options)
-    return Popen(args, **popts)
-def run_command(*args, **kwargs):
-    """Passes all arguments to start_command, then waits for the process to
-    complete, returning its exit code. Similar to subprocess.call(), but
-    with the make_command() interface.
-    ps = start_command(*args, **kwargs)
-    return ps.wait()
-def pipe_command(*args, **kwargs):
-    """Passes all arguments to start_command, but also adds
-    "stdout = PIPE". Returns the Popen object.
-    kwargs['stdout'] = PIPE
-    return start_command(*args, **kwargs)
-def feed_command(*args, **kwargs):
-    "stdin = PIPE". Returns the Popen object.
-    kwargs['stdin'] = PIPE
-def read_command(*args, **kwargs):
-    """Passes all arguments to pipe_command, then waits for the process to
-    complete, returning its stdout (i.e. similar to shell `backticks`).
-    ps = pipe_command(*args, **kwargs)
-    return ps.communicate()[0]
-def parse_command(*args, **kwargs):
-    """Passes all arguments to read_command, then parses the output by
-    parse_key_val().
-    Parsing function can be optionally given by <b>parse</b> parameter
-    including its arguments, e.g.
-    @code
-    parse_command(..., parse = (grass.parse_key_val, { 'sep' : ':' }))
-    @endcode
-    parse = None
-    if kwargs.has_key('parse'):
-        if type(kwargs['parse']) is types.TupleType:
-            parse = kwargs['parse'][0]
-            parse_args = kwargs['parse'][1]
-        del kwargs['parse']
-    if not parse:
-        parse = parse_key_val # use default fn
-        parse_args = {}
-    res = read_command(*args, **kwargs)
-    return parse(res, **parse_args)
-def write_command(*args, **kwargs):
-    """Passes all arguments to feed_command, with the string specified
-    by the 'stdin' argument fed to the process' stdin.
-    stdin = kwargs['stdin']
-    p = feed_command(*args, **kwargs)
-    p.stdin.write(stdin)
-    p.stdin.close()
-    return p.wait()
-def exec_command(prog, flags = "", overwrite = False, quiet = False, verbose = False, env = None, **kwargs):
-    """Interface to os.execvpe(), but with the make_command() interface."""
-    args = make_command(prog, flags, overwrite, quiet, verbose, **kwargs)
-    if env == None:
-	env = os.environ
-    os.execvpe(prog, args, env)
-# interface to g.message
-def message(msg, flag = None):
-    """Display a message using g.message"""
-    run_command("g.message", flags = flag, message = msg)
-def debug(msg, debug = 1):
-    """Display a debugging message using g.message -d"""
-    run_command("g.message", flags = 'd', message = msg, debug = debug)
-def verbose(msg):
-    """Display a verbose message using g.message -v"""
-    message(msg, flag = 'v')
-def info(msg):
-    """Display an informational message using g.message -i"""
-    message(msg, flag = 'i')
-def warning(msg):
-    """Display a warning message using g.message -w"""
-    message(msg, flag = 'w')
-def error(msg):
-    """Display an error message using g.message -e"""
-    message(msg, flag = 'e')
-def fatal(msg):
-    """Display an error message using g.message -e, then abort"""
-    error(msg)
-    sys.exit(1)
-# interface to g.parser
-def _parse_env():
-    options = {}
-    flags = {}
-    for var, val in os.environ.iteritems():
-	if var.startswith("GIS_OPT_"):
-	    opt = var.replace("GIS_OPT_", "", 1).lower()
-	    options[opt] = val;
-	if var.startswith("GIS_FLAG_"):
-	    flg = var.replace("GIS_FLAG_", "", 1).lower()
-	    flags[flg] = bool(int(val));
-    return (options, flags)
-def parser():
-    """Interface to g.parser, intended to be run from the top-level, e.g.:
-	if __name__ == "__main__":
-	    options, flags = grass.parser()
-	    main()
-    Thereafter, the global variables "options" and "flags" will be
-    dictionaries containing option/flag values, keyed by lower-case
-    option/flag names. The values in "options" are strings, those in
-    "flags" are Python booleans.
-    if not os.getenv("GISBASE"):
-        print >> sys.stderr, "You must be in GRASS GIS to run this program."
-        sys.exit(1)
-    if len(sys.argv) > 1 and sys.argv[1] == "@ARGS_PARSED@":
-	return _parse_env()
-    cmdline = [basename(sys.argv[0])]
-    cmdline += ['"' + arg + '"' for arg in sys.argv[1:]]
-    os.environ['CMDLINE'] = ' '.join(cmdline)
-    argv = sys.argv[:]
-    name = argv[0]
-    if not os.path.isabs(name):
-	if os.sep in name or (os.altsep and os.altsep in name):
-	    argv[0] = os.path.abspath(name)
-	else:
-	    argv[0] = os.path.join(sys.path[0], name)
-    if sys.platform == "win32":
-       os.execvp("g.parser.exe", [name] + argv)
-    else:
-       os.execvp("g.parser", [name] + argv)
-    raise OSError("error executing g.parser")
-# interface to g.tempfile
-def tempfile():
-    """Returns the name of a temporary file, created with g.tempfile."""
-    return read_command("g.tempfile", pid = os.getpid()).strip()
-# key-value parsers
-def parse_key_val(s, sep = '=', dflt = None, val_type = None, vsep = None):
-    """Parse a string into a dictionary, where entries are separated
-    by newlines and the key and value are separated by `sep' (default: `=')
-    result = {}
-    if not s:
-        return result
-    if vsep:
-        lines = s.split(vsep)
-        try:
-            lines.remove('\n')
-        except ValueError:
-            pass
-    else:
-        lines = s.splitlines()
-    for line in lines:
-	kv = line.split(sep, 1)
-	k = kv[0].strip()
-	if len(kv) > 1:
-	    v = kv[1]
-	else:
-	    v = dflt
-        if val_type:
-            result[k] = val_type(v)
-        else:
-            result[k] = v
-    return result
-# interface to g.gisenv
-def gisenv():
-    """Returns the output from running g.gisenv (with no arguments), as a
-    dictionary.
-    s = read_command("g.gisenv", flags='n')
-    return parse_key_val(s)
-# interface to g.region
-def region():
-    """Returns the output from running "g.region -g", as a dictionary."""
-    s = read_command("g.region", flags='g')
-    return parse_key_val(s, val_type = float)
-def use_temp_region():
-    """Copies the current region to a temporary region with "g.region save=",
-    then sets WIND_OVERRIDE to refer to that region. Installs an atexit
-    handler to delete the temporary region upon termination.
-    name = "tmp.%s.%d" % (os.path.basename(sys.argv[0]), os.getpid())
-    run_command("g.region", save = name)
-    os.environ['WIND_OVERRIDE'] = name
-    atexit.register(del_temp_region)
-def del_temp_region():
-    """Unsets WIND_OVERRIDE and removes any region named by it."""
-    try:
-	name = os.environ.pop('WIND_OVERRIDE')
-	run_command("g.remove", quiet = True, region = name)
-    except:
-	pass
-# interface to g.findfile
-def find_file(name, element = 'cell', mapset = None):
-    """Returns the output from running g.findfile as a dictionary."""
-    s = read_command("g.findfile", flags='n', element = element, file = name, mapset = mapset)
-# interface to g.list
-def list_grouped(type):
-    """Returns the output from running g.list, as a dictionary where the keys
-    are mapset names and the values are lists of maps in that mapset.
-    dashes_re = re.compile("^----+$")
-    mapset_re = re.compile("<(.*)>")
-    result = {}
-    mapset = None
-    for line in read_command("g.list", type = type).splitlines():
-	if line == "":
-	    continue
-	if dashes_re.match(line):
-	    continue
-	m = mapset_re.search(line)
-	if m:
-	    mapset = m.group(1)
-	    result[mapset] = []
-	    continue
-        if mapset:
-            result[mapset].extend(line.split())
-    return result
-def mlist_grouped(type, mapset = None, pattern = None):
-    """Returns the output from running g.mlist, as a dictionary where the keys
-    result = {}
-    mapset_element = None
-    for line in read_command("g.mlist", flags="m",
-                             type = type, mapset = mapset, pattern = pattern).splitlines():
-        try:
-            map, mapset_element = line.split('@')
-            print >> sys.stderr, "Invalid element '%s'" % line
-            continue
-        if result.has_key(mapset_element):
-            result[mapset_element].append(map)
-        else:
-	    result[mapset_element] = [map, ]
-    return result
-def _concat(xs):
-    result = []
-    for x in xs:
-	result.extend(x)
-    return result
-def list_pairs(type):
-    """Returns the output from running g.list, as a list of (map, mapset)
-    pairs.
-    return _concat([[(map, mapset) for map in maps]
-		    for mapset, maps in list_grouped(type).iteritems()])
-def list_strings(type):
-    """Returns the output from running g.list, as a list of qualified names."""
-    return ["%s@%s" % pair for pair in list_pairs(type)]
-# color parsing
-named_colors = {
-    "white":   (1.00, 1.00, 1.00),
-    "black":   (0.00, 0.00, 0.00),
-    "red":     (1.00, 0.00, 0.00),
-    "green":   (0.00, 1.00, 0.00),
-    "blue":    (0.00, 0.00, 1.00),
-    "yellow":  (1.00, 1.00, 0.00),
-    "magenta": (1.00, 0.00, 1.00),
-    "cyan":    (0.00, 1.00, 1.00),
-    "aqua":    (0.00, 0.75, 0.75),
-    "grey":    (0.75, 0.75, 0.75),
-    "gray":    (0.75, 0.75, 0.75),
-    "orange":  (1.00, 0.50, 0.00),
-    "brown":   (0.75, 0.50, 0.25),
-    "purple":  (0.50, 0.00, 1.00),
-    "violet":  (0.50, 0.00, 1.00),
-    "indigo":  (0.00, 0.50, 1.00)}
-def parse_color(val, dflt = None):
-    """Parses the string "val" as a GRASS colour, which can be either one of
-    the named colours or an R:G:B tuple e.g. 255:255:255. Returns an
-    (r,g,b) triple whose components are floating point values between 0
-    and 1.
-    if val in named_colors:
-        return named_colors[val]
-    vals = val.split(':')
-    if len(vals) == 3:
-        return tuple(float(v) / 255 for v in vals)
-    return dflt
-# check GRASS_OVERWRITE
-def overwrite():
-    """Return True if existing files may be overwritten"""
-    owstr = 'GRASS_OVERWRITE'
-    return owstr in os.environ and os.environ[owstr] != '0'
-# check GRASS_VERBOSE
-def verbosity():
-    """Return the verbosity level selected by GRASS_VERBOSE"""
-    vbstr = os.getenv('GRASS_VERBOSE')
-    if vbstr:
-	return int(vbstr)
-    else:
-	return 0
-## various utilities, not specific to GRASS
-# basename inc. extension stripping
-def basename(path, ext = None):
-    """Remove leading directory components and an optional extension
-    from the specified path
-    name = os.path.basename(path)
-    if not ext:
-	return name
-    fs = name.rsplit('.', 1)
-    if len(fs) > 1 and fs[1].lower() == ext:
-	name = fs[0]
-    return name
-# find a program (replacement for "which")
-def find_program(pgm, args = []):
-    """Attempt to run a program, with optional arguments. Return False
-    if the attempt failed due to a missing executable, True otherwise
-    nuldev = file(os.devnull, 'w+')
-    try:
-	call([pgm] + args, stdin = nuldev, stdout = nuldev, stderr = nuldev)
-	found = True
-    except:
-	found = False
-    nuldev.close()
-    return found
-# try to remove a file, without complaints
-def try_remove(path):
-    """Attempt to remove a file; no exception is generated if the
-    attempt fails.
-    try:
-	os.remove(path)
-    except:
-	pass
-# try to remove a directory, without complaints
-def try_rmdir(path):
-    """Attempt to remove a directory; no exception is generated if the
-    attempt fails.
-    try:
-	os.rmdir(path)
-    except:
-	pass
-# run "v.db.connect -g ..." and parse output
-def vector_db(map, **args):
-    """Return the database connection details for a vector map
-    (interface to `v.db.connect -g').
-    @param map vector map
-    @return dictionary { layer : { 'layer', 'table, 'database', 'driver', 'key' }
-    s = read_command('v.db.connect', flags = 'g', map = map, fs = ';', **args)
-    result = {}
-    for l in s.splitlines():
-	f = l.split(';')
-	if len(f) != 5:
-	    continue
-        if '/' in f[0]:
-            f1 = f[0].split('/')
-            layer = f1[0]
-            name = f1[1]
-        else:
-            layer = f[0]
-            name = ''
-	result[int(layer)] = {
-            'layer'    : layer,
-            'name'     : name,
-            'table'    : f[1],
-            'key'      : f[2],
-            'database' : f[3],
-            'driver'   : f[4] }
-    return result
-def vector_layer_db(map, layer):
-    """Return the database connection details for a vector map layer.
-    If db connection for given layer is not defined, fatal() is called."""
-    try:
-        f = vector_db(map)[int(layer)]
-    except KeyError:
-	grass.fatal("Database connection not defined for layer %s" % layer)
-    return f
-# run "db.describe -c ..." and parse output
-def db_describe(table, **args):
-    """Return the list of columns for a database table
-    (interface to `db.describe -c').
-    s = read_command('db.describe', flags = 'c', table = table, **args)
-    if not s:
-	return None
-    cols = []
-    result = {}
-	f = l.split(':')
-	key = f[0]
-	f[1] = f[1].lstrip(' ')
-	if key.startswith('Column '):
-	    n = int(key.split(' ')[1])
-	    cols.insert(n, f[1:])
-	elif key in ['ncols', 'nrows']:
-	    result[key] = int(f[1])
-	else:
-	    result[key] = f[1:]
-    result['cols'] = cols
-    return result
-# run "db.connect -p" and parse output
-def db_connection():
-    """Return the current database connection parameters
-    (interface to `db.connect -p').
-    s = read_command('db.connect', flags = 'p')
-    return parse_key_val(s, sep = ':')
-# run "v.info -c ..." and parse output
-def vector_columns(map, layer = None, **args):
-    """Return a dictionary of the columns for the database table connected to
-    a vector map (interface to `v.info -c').
-    s = read_command('v.info', flags = 'c', map = map, layer = layer, quiet = True, **args)
-    result = {}
-    for line in s.splitlines():
-	f = line.split('|')
-	if len(f) == 2:
-            result[f[1]] = f[0]
-    return result
-# add vector history
-def vector_history(map):
-    """Set the command history for a vector map to the command used to
-    invoke the script (interface to `v.support').
-    run_command('v.support', map = map, cmdhist = os.environ['CMDLINE'])
-# run "v.info -t" and parse output
-def vector_info_topo(map):
-    """Return information about a vector map (interface to `v.info -t')."""
-    s = read_command('v.info', flags = 't', map = map)
-    return parse_key_val(s, val_type = int)
-# add raster history
-def raster_history(map):
-    """Set the command history for a raster map to the command used to
-    invoke the script (interface to `r.support').
-    @return True on success
-    @return False on failure
-    current_mapset = gisenv()['MAPSET']
-    if find_file(name = map)['mapset'] == current_mapset:
-        run_command('r.support', map = map, history = os.environ['CMDLINE'])
-        return True
-    warning("Unable to write history for <%s>. Raster map <%s> not found in current mapset." % (map, map))
-    return False
-def float_or_dms(s):
-    return sum(float(x) / 60 ** n for (n, x) in enumerate(s.split(':')))
-# run "r.info -rgstmpud ..." and parse output
-def raster_info(map):
-    """Return information about a raster map (interface to `r.info')."""
-    s = read_command('r.info', flags = 'rgstmpud', map = map)
-    kv = parse_key_val(s)
-    for k in ['min', 'max', 'north', 'south', 'east', 'west']:
-	kv[k] = float(kv[k])
-    for k in ['nsres', 'ewres']:
-	kv[k] = float_or_dms(kv[k])
-    return kv
-# interface to r.mapcalc
-def mapcalc(exp, **kwargs):
-    t = string.Template(exp)
-    e = t.substitute(**kwargs)
-    if run_command('r.mapcalc', expression = e) != 0:
-	fatal("An error occurred while running r.mapcalc")
Added: grass/trunk/lib/python/raster.py
--- grass/trunk/lib/python/raster.py	                        (rev 0)
+++ grass/trunk/lib/python/raster.py	2009-05-21 21:16:28 UTC (rev 37345)
@@ -0,0 +1,67 @@
+ at package grass.script.raster
+Raster related functions to be used in Python scripts.
+Usage:
+ at code
+from grass.script import core, raster as grass
+grass.parser()
+grass.raster_history(map)
+ at endcode
+for details.
+import os
+import string
+from core import *
+# add raster history
+def raster_history(map):
+    """Set the command history for a raster map to the command used to
+    invoke the script (interface to `r.support').
+    @return True on success
+    @return False on failure
+    current_mapset = gisenv()['MAPSET']
+    if find_file(name = map)['mapset'] == current_mapset:
+        run_command('r.support', map = map, history = os.environ['CMDLINE'])
+        return True
+    warning("Unable to write history for <%s>. Raster map <%s> not found in current mapset." % (map, map))
+    return False
+# run "r.info -rgstmpud ..." and parse output
+def raster_info(map):
+    """Return information about a raster map (interface to `r.info')."""
+    s = read_command('r.info', flags = 'rgstmpud', map = map)
+    kv = parse_key_val(s)
+    for k in ['min', 'max', 'north', 'south', 'east', 'west']:
+	kv[k] = float(kv[k])
+    for k in ['nsres', 'ewres']:
+	kv[k] = float_or_dms(kv[k])
+    return kv
+# interface to r.mapcalc
+def mapcalc(exp, **kwargs):
+    t = string.Template(exp)
+    e = t.substitute(**kwargs)
+    if run_command('r.mapcalc', expression = e) != 0:
+	fatal("An error occurred while running r.mapcalc")
Property changes on: grass/trunk/lib/python/raster.py
   + text/x-python
   + Author Date Id
   + native
Added: grass/trunk/lib/python/vector.py
--- grass/trunk/lib/python/vector.py	                        (rev 0)
+++ grass/trunk/lib/python/vector.py	2009-05-21 21:16:28 UTC (rev 37345)
@@ -0,0 +1,105 @@
+ at package grass.script.vector
+Vector related functions to be used in Python scripts.
+Usage:
+ at code
+from grass.script import core, vector as grass
+grass.parser()
+grass.vector_db(map)
+ at endcode
+for details.
+import os
+from core import *
+# run "v.db.connect -g ..." and parse output
+def vector_db(map, **args):
+    """Return the database connection details for a vector map
+    (interface to `v.db.connect -g').
+    @param map vector map
+    @return dictionary { layer : { 'layer', 'table, 'database', 'driver', 'key' }
+    s = read_command('v.db.connect', flags = 'g', map = map, fs = ';', **args)
+    result = {}
+	f = l.split(';')
+	if len(f) != 5:
+	    continue
+        if '/' in f[0]:
+            f1 = f[0].split('/')
+            layer = f1[0]
+            name = f1[1]
+        else:
+            layer = f[0]
+            name = ''
+	result[int(layer)] = {
+            'layer'    : layer,
+            'name'     : name,
+            'table'    : f[1],
+            'key'      : f[2],
+            'database' : f[3],
+            'driver'   : f[4] }
+    return result
+def vector_layer_db(map, layer):
+    """Return the database connection details for a vector map layer.
+    If db connection for given layer is not defined, fatal() is called."""
+    try:
+        f = vector_db(map)[int(layer)]
+    except KeyError:
+	grass.fatal("Database connection not defined for layer %s" % layer)
+    return f
+# run "v.info -c ..." and parse output
+def vector_columns(map, layer = None, **args):
+    """Return a dictionary of the columns for the database table connected to
+    a vector map (interface to `v.info -c').
+    s = read_command('v.info', flags = 'c', map = map, layer = layer, quiet = True, **args)
+    result = {}
+    for line in s.splitlines():
+	f = line.split('|')
+	if len(f) == 2:
+            result[f[1]] = f[0]
+    return result
+# add vector history
+def vector_history(map):
+    """Set the command history for a vector map to the command used to
+    invoke the script (interface to `v.support').
+    run_command('v.support', map = map, cmdhist = os.environ['CMDLINE'])
+# run "v.info -t" and parse output
+def vector_info_topo(map):
+    """Return information about a vector map (interface to `v.info -t')."""
+    s = read_command('v.info', flags = 't', map = map)
+    return parse_key_val(s, val_type = int)
Property changes on: grass/trunk/lib/python/vector.py
   + text/x-python
   + Author Date Id
   + native
Modified: grass/trunk/swig/python/Makefile
--- grass/trunk/swig/python/Makefile	2009-05-21 20:53:52 UTC (rev 37344)
+++ grass/trunk/swig/python/Makefile	2009-05-21 21:16:28 UTC (rev 37345)
@@ -39,28 +39,34 @@
 include $(MODULE_TOPDIR)/include/Make/Python.make
-DSTDIR = $(ARCH_DISTDIR)/etc/python/swig
+DSTDIR = $(GDIR)/lib
 LIBFILES := $(patsubst %,$(DSTDIR)/_%.so,$(MODULES))
-PYCFILES := $(patsubst %,$(DSTDIR)/%.pyc,$(MODULES) __init__)
 default:
 	$(MAKE) $(DSTDIR)
-	$(MAKE) $(LIBFILES) $(PYFILES) $(PYCFILES)
+	$(MAKE) $(LIBFILES) $(PYFILES)
-$(DSTDIR):
+$(PYDIR):
+$(GDIR): $(PYDIR)
+$(DSTDIR): $(GDIR)
+	@echo "import lib" >> $(GDIR)/__init__.py
 $(DSTDIR)/_%.so: _%.so
 	$(INSTALL) $< $@
 $(DSTDIR)/%.py: %.py
-$(DSTDIR)/%.pyc: %.pyc
-	$(INSTALL_DATA) $< $@
 numptr:
 	$(MAKE) -C NumPtr
