[GRASS-SVN] r37402 - in grass/branches/develbranch_6: . display/d.what.vect include/Make lib/form vector/v.digit vector/v.what visualization/nviz/src
Sat May 23 13:10:52 EDT 2009
Author: kyngchaos
Date: 2009-05-23 13:10:51 -0400 (Sat, 23 May 2009)
New Revision: 37402
   grass/branches/develbranch_6/configure
   grass/branches/develbranch_6/configure.in
   grass/branches/develbranch_6/display/d.what.vect/Makefile
   grass/branches/develbranch_6/include/Make/Platform.make.in
   grass/branches/develbranch_6/lib/form/Makefile
   grass/branches/develbranch_6/vector/v.digit/Makefile
   grass/branches/develbranch_6/vector/v.what/Makefile
   grass/branches/develbranch_6/visualization/nviz/src/Makefile
support 64bit build with 32bit TclTk aqua on OSX
Modified: grass/branches/develbranch_6/configure
--- grass/branches/develbranch_6/configure	2009-05-23 16:23:37 UTC (rev 37401)
+++ grass/branches/develbranch_6/configure	2009-05-23 17:10:51 UTC (rev 37402)
@@ -8830,858 +8830,11 @@
 # Done checking PNG
-# Enable TCLTK option
-echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:8838: checking whether to use Tcl/Tk" >&5
-echo "$ac_t"""$with_tcltk"" 1>&6
-case "$with_tcltk" in
-	"no")	USE_TCLTK=	;;
-	"yes")	USE_TCLTK="1"	;;
-	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
-esac
-TCLINCDIR=
-TCLTKLIBPATH=
-TCLTKLIBS=
-if test -n "$USE_TCLTK"; then
-# With Tcl/Tk includes directory
-echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:8858: checking for location of Tcl/Tk includes" >&5
-case "$with_tcltk_includes" in
-y | ye | yes | n | no)
-	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
-esac
-echo "$ac_t""$with_tcltk_includes" 1>&6
-if test -n "$with_tcltk_includes" ; then
-    for dir in $with_tcltk_includes; do
-        if test -d "$dir"; then
-            TCLINCDIR="$TCLINCDIR -I$dir"
-        else
-            { echo "configure: error: *** Tcl/Tk includes directory $dir does not exist." 1>&2; exit 1; }
-        fi
-    done
-fi
-ac_save_cppflags="$CPPFLAGS"
-CPPFLAGS="$TCLINCDIR $CPPFLAGS"
-for ac_hdr in tcl.h
-do
-ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
-echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8884: checking for $ac_hdr" >&5
-cat > conftest.$ac_ext <<EOF
-#line 8887 "configure"
-#include "confdefs.h"
-#include <$ac_hdr>
-EOF
-ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:8892: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
-ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
-if test -z "$ac_err"; then
-  rm -rf conftest*
-  eval "ac_cv_header_$ac_safe=yes"
-else
-  echo "$ac_err" >&5
-  echo "configure: failed program was:" >&5
-  cat conftest.$ac_ext >&5
-  rm -rf conftest*
-  eval "ac_cv_header_$ac_safe=no"
-fi
-rm -f conftest*
-if eval "test \"`echo '$ac_cv_header_'$ac_safe`\" = yes"; then
-  echo "$ac_t""yes" 1>&6
-    ac_tr_hdr=HAVE_`echo $ac_hdr | sed 'y%abcdefghijklmnopqrstuvwxyz./-%ABCDEFGHIJKLMNOPQRSTUVWXYZ___%'`
-  cat >> confdefs.h <<EOF
-#define $ac_tr_hdr 1
-EOF
-else
-  echo "$ac_t""no" 1>&6
-{ echo "configure: error: *** Unable to locate Tcl includes." 1>&2; exit 1; }
-fi
-done
-CPPFLAGS=$ac_save_cppflags
-CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
-for ac_hdr in tk.h
-do
-echo "configure:8929: checking for $ac_hdr" >&5
-#line 8932 "configure"
-#include <$ac_hdr>
-EOF
-{ (eval echo configure:8937: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-EOF
-else
-{ echo "configure: error: *** Unable to locate Tk includes." 1>&2; exit 1; }
-fi
-done
-# Tcl/Tk version checks
-echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:8970: checking Tcl version" >&5
-if test "$cross_compiling" = yes; then
-     tcl_ver=UNKNOWN
-    echo "$ac_t""unknown (cross-compiling)" 1>&6
-else
-  cat > conftest.$ac_ext <<EOF
-#line 8978 "configure"
-#include <stdio.h>
-#include <tcl.h>
-int main(void) {
- FILE *fp = fopen("conftestdata","w");
- fputs(TCL_VERSION, fp);
- return 0;
-EOF
-if { (eval echo configure:8990: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
-then
-     tcl_ver=`cat conftestdata`
-    echo "$ac_t""$tcl_ver" 1>&6
-else
-  rm -fr conftest*
-     { echo "configure: error: *** Could not determine Tcl version." 1>&2; exit 1; }
-fi
-rm -fr conftest*
-fi
-echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:9008: checking Tk version" >&5
-     tk_ver=UNKNOWN
-else
-#line 9016 "configure"
-#include <stdio.h>
-#include <tk.h>
-int main(void) {
- fputs(TK_VERSION, fp);
- return 0;
-EOF
-if { (eval echo configure:9028: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
-then
-     tk_ver=`cat conftestdata`
-    echo "$ac_t""$tk_ver" 1>&6
-else
-  rm -fr conftest*
-     { echo "configure: error: *** Could not determine Tk version." 1>&2; exit 1; }
-fi
-rm -fr conftest*
-fi
-if test "$tcl_ver" = "$tk_ver" ; then
-    tcltk_ver=$tcl_ver
-else
-    { echo "configure: error: *** Tcl/Tk version mismatch." 1>&2; exit 1; }
-fi
-TCL_VERSION="$tcl_ver"
-# FreeBSD and CygWin don't have a "dot" between major/minor version number
-tcltk_ver2=`echo $tcltk_ver | sed 's/\.//g'`
-# With Tcl/Tk library directory
-echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:9059: checking for location of Tcl/Tk library" >&5
-case "$with_tcltk_libs" in
-	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
-esac
-echo "$ac_t""$with_tcltk_libs" 1>&6
-if test -n "$with_tcltk_libs"; then
-    for dir in $with_tcltk_libs; do
-            TCLTKLIBPATH="$TCLTKLIBPATH -L$dir"
-        else
-            { echo "configure: error: *** Tcl/Tk library directory $dir does not exist." 1>&2; exit 1; }
-        fi
-    done
-fi
-TCLLIB=
-TKLIB=
-ac_save_ldflags="$LDFLAGS"
-LDFLAGS="$TCLTKLIBPATH $LDFLAGS"
-echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:9089: checking for Tcl_Init in -ltcl" >&5
-ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
-ac_save_LIBS="$LIBS"
-LIBS="-ltcl $MATHLIB $LIBS"
-#line 9095 "configure"
-/* Override any gcc2 internal prototype to avoid an error.  */
-/* We use char because int might match the return type of a gcc2
-    builtin and then its argument prototype would still apply.  */
-char Tcl_Init();
-int main() {
-Tcl_Init()
-; return 0; }
-EOF
-if { (eval echo configure:9106: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-  eval "ac_cv_lib_$ac_lib_var=yes"
-else
-  rm -rf conftest*
-  eval "ac_cv_lib_$ac_lib_var=no"
-fi
-rm -f conftest*
-LIBS="$ac_save_LIBS"
-if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
-  TCLLIB="$TCLLIB -ltcl $MATHLIB"
-else
-echo "configure:9125: checking for Tcl_Init in -ltcl" >&5
-LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 9131 "configure"
-char Tcl_Init();
-int main() {
-Tcl_Init()
-; return 0; }
-EOF
-if { (eval echo configure:9142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  TCLLIB="$TCLLIB -ltcl $MATHLIB $DLLIB"
-else
-LDFLAGS=${ac_save_ldflags}
-echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:9169: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
-ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
-LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 9175 "configure"
-char Tcl_Init();
-int main() {
-Tcl_Init()
-; return 0; }
-EOF
-if { (eval echo configure:9186: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  TCLLIB="$TCLLIB -ltcl$tcltk_ver $MATHLIB"
-else
-echo "configure:9205: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
-LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 9211 "configure"
-char Tcl_Init();
-int main() {
-Tcl_Init()
-; return 0; }
-EOF
-if { (eval echo configure:9222: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  TCLLIB="$TCLLIB -ltcl$tcltk_ver $MATHLIB $DLLIB"
-else
-echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:9249: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
-ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
-LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 9255 "configure"
-char Tcl_Init();
-int main() {
-Tcl_Init()
-; return 0; }
-EOF
-if { (eval echo configure:9266: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  TCLLIB="$TCLLIB -ltcl$tcltk_ver2 $MATHLIB"
-else
-echo "configure:9285: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
-LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 9291 "configure"
-char Tcl_Init();
-int main() {
-Tcl_Init()
-; return 0; }
-EOF
-if { (eval echo configure:9302: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  TCLLIB="$TCLLIB -ltcl$tcltk_ver2 $MATHLIB $DLLIB"
-else
-    { echo "configure: error: *** Unable to locate Tcl library." 1>&2; exit 1; }
-fi
-fi
-fi
-fi
-fi
-fi
-echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:9380: checking for Tk_MainWindow in -ltk" >&5
-ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
-LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 9386 "configure"
-char Tk_MainWindow();
-int main() {
-Tk_MainWindow()
-; return 0; }
-EOF
-if { (eval echo configure:9397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  TKLIB="$TKLIB -ltk $MATHLIB"
-else
-echo "configure:9416: checking for Tk_MainWindow in -ltk" >&5
-LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9422 "configure"
-int main() {
-Tk_MainWindow()
-; return 0; }
-EOF
-if { (eval echo configure:9433: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  TKLIB="$TKLIB -ltk $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS"
-else
-echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:9460: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
-ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
-LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 9466 "configure"
-int main() {
-Tk_MainWindow()
-; return 0; }
-EOF
-if { (eval echo configure:9477: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  TKLIB="$TKLIB -ltk$tcltk_ver $MATHLIB"
-else
-echo "configure:9496: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
-LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9502 "configure"
-int main() {
-Tk_MainWindow()
-; return 0; }
-EOF
-if { (eval echo configure:9513: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  TKLIB="$TKLIB -ltk$tcltk_ver $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS"
-else
-echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:9540: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
-ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
-LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 9546 "configure"
-int main() {
-Tk_MainWindow()
-; return 0; }
-EOF
-if { (eval echo configure:9557: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  TKLIB="$TKLIB -ltk$tcltk_ver2 $MATHLIB"
-else
-echo "configure:9576: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
-LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9582 "configure"
-int main() {
-Tk_MainWindow()
-; return 0; }
-EOF
-if { (eval echo configure:9593: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  TKLIB="$TKLIB -ltk$tcltk_ver2 $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS"
-else
-    { echo "configure: error: *** Unable to locate Tk library." 1>&2; exit 1; }
-fi
-fi
-fi
-fi
-fi
-fi
-TCLTKLIBS="$TKLIB $TCLLIB"
-cat >> confdefs.h <<\EOF
-#define HAVE_TCLTK 1
-EOF
-fi # $USE_TCLTK
-TKINCDIR=$TCLINCDIR
-# Done checking Tcl/Tk
 # Enable PostgreSQL option
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:9685: checking whether to use PostgreSQL" >&5
+echo "configure:8838: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -9708,7 +8861,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9712: checking for location of PostgreSQL includes" >&5
+echo "configure:8865: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9734,15 +8887,15 @@
 do
-echo "configure:9738: checking for $ac_hdr" >&5
+echo "configure:8891: checking for $ac_hdr" >&5
-#line 9741 "configure"
+#line 8894 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9746: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8899: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9780,7 +8933,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9784: checking for location of PostgreSQL library" >&5
+echo "configure:8937: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9809,13 +8962,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9813: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8966: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9819 "configure"
+#line 8972 "configure"
@@ -9826,7 +8979,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9830: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8983: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9845,13 +8998,13 @@
-echo "configure:9849: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9002: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9855 "configure"
+#line 9008 "configure"
@@ -9862,7 +9015,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9866: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9881,13 +9034,13 @@
-echo "configure:9885: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9038: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 9891 "configure"
+#line 9044 "configure"
@@ -9898,7 +9051,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9902: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9055: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9917,13 +9070,13 @@
-echo "configure:9921: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9074: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9927 "configure"
+#line 9080 "configure"
@@ -9934,7 +9087,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9938: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9091: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9991,13 +9144,13 @@
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9995: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9148: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 10001 "configure"
+#line 9154 "configure"
@@ -10008,7 +9161,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:10012: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9165: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10030,13 +9183,13 @@
-echo "configure:10034: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9187: checking for PQcmdTuples in -lpq" >&5
-#line 10040 "configure"
+#line 9193 "configure"
@@ -10047,7 +9200,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:10051: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9204: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10090,7 +9243,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:10094: checking whether to use MySQL" >&5
+echo "configure:9247: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -10110,7 +9263,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:10114: checking for location of MySQL includes" >&5
+echo "configure:9267: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -10136,15 +9289,15 @@
 do
-echo "configure:10140: checking for $ac_hdr" >&5
+echo "configure:9293: checking for $ac_hdr" >&5
-#line 10143 "configure"
+#line 9296 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10148: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9301: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10181,7 +9334,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:10185: checking for location of MySQL library" >&5
+echo "configure:9338: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -10212,13 +9365,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:10216: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9369: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 10222 "configure"
+#line 9375 "configure"
@@ -10229,7 +9382,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10233: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9386: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10248,13 +9401,13 @@
-echo "configure:10252: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9405: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 10258 "configure"
+#line 9411 "configure"
@@ -10265,7 +9418,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10269: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9422: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10284,13 +9437,13 @@
-echo "configure:10288: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9441: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 10294 "configure"
+#line 9447 "configure"
@@ -10301,7 +9454,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10305: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9458: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10320,13 +9473,13 @@
-echo "configure:10324: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9477: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 10330 "configure"
+#line 9483 "configure"
@@ -10337,7 +9490,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10341: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9494: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10356,13 +9509,13 @@
-echo "configure:10360: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9513: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 10366 "configure"
+#line 9519 "configure"
@@ -10373,7 +9526,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10377: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9530: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10392,13 +9545,13 @@
-echo "configure:10396: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9549: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 10402 "configure"
+#line 9555 "configure"
@@ -10409,7 +9562,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10413: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9566: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10428,13 +9581,13 @@
-echo "configure:10432: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9585: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 10438 "configure"
+#line 9591 "configure"
@@ -10445,7 +9598,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10449: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9602: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10464,13 +9617,13 @@
-echo "configure:10468: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9621: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 10474 "configure"
+#line 9627 "configure"
@@ -10481,7 +9634,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10485: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9638: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10571,7 +9724,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:10575: checking for $ac_word" >&5
+echo "configure:9728: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -10612,10 +9765,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:10616: checking for mysql_server_init" >&5
+echo "configure:9769: checking for mysql_server_init" >&5
-#line 10619 "configure"
+#line 9772 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -10638,7 +9791,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10642: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9795: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -10676,7 +9829,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:10680: checking whether to use SQLite" >&5
+echo "configure:9833: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -10696,7 +9849,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10700: checking for location of SQLite includes" >&5
+echo "configure:9853: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10722,15 +9875,15 @@
 do
-echo "configure:10726: checking for $ac_hdr" >&5
+echo "configure:9879: checking for $ac_hdr" >&5
-#line 10729 "configure"
+#line 9882 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10734: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9887: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10773,7 +9926,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10777: checking for location of SQLite library" >&5
+echo "configure:9930: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10800,13 +9953,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10804: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9957: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 10810 "configure"
+#line 9963 "configure"
@@ -10817,7 +9970,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9974: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10836,13 +9989,13 @@
-echo "configure:10840: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9993: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10846 "configure"
+#line 9999 "configure"
@@ -10853,7 +10006,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10857: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10010: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10906,7 +10059,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10910: checking whether to use FFMPEG" >&5
+echo "configure:10063: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -10926,7 +10079,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10930: checking for location of FFMPEG includes" >&5
+echo "configure:10083: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10952,15 +10105,15 @@
 do
-echo "configure:10956: checking for $ac_hdr" >&5
+echo "configure:10109: checking for $ac_hdr" >&5
-#line 10959 "configure"
+#line 10112 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10964: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10117: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10996,15 +10149,15 @@
 do
-echo "configure:11000: checking for $ac_hdr" >&5
+echo "configure:10153: checking for $ac_hdr" >&5
-#line 11003 "configure"
+#line 10156 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11008: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10161: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11040,15 +10193,15 @@
 do
-echo "configure:11044: checking for $ac_hdr" >&5
+echo "configure:10197: checking for $ac_hdr" >&5
-#line 11047 "configure"
+#line 10200 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11052: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10205: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11091,7 +10244,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:11095: checking for location of FFMPEG library" >&5
+echo "configure:10248: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -11118,13 +10271,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:11122: checking for av_free in -lavutil" >&5
+echo "configure:10275: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 11128 "configure"
+#line 10281 "configure"
@@ -11135,7 +10288,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:11139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10292: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11154,13 +10307,13 @@
-echo "configure:11158: checking for av_free in -lavutil" >&5
+echo "configure:10311: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 11164 "configure"
+#line 10317 "configure"
@@ -11171,7 +10324,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:11175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10328: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11216,13 +10369,13 @@
 echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:11220: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10373: checking for avcodec_init in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 11226 "configure"
+#line 10379 "configure"
@@ -11233,7 +10386,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:11237: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10390: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11252,13 +10405,13 @@
-echo "configure:11256: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10409: checking for avcodec_init in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 11262 "configure"
+#line 10415 "configure"
@@ -11269,7 +10422,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:11273: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10426: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11314,13 +10467,13 @@
 echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:11318: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10471: checking for av_set_parameters in -lavformat" >&5
 ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 11324 "configure"
+#line 10477 "configure"
@@ -11331,7 +10484,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:11335: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10488: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11350,13 +10503,13 @@
-echo "configure:11354: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10507: checking for av_set_parameters in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 11360 "configure"
+#line 10513 "configure"
@@ -11367,7 +10520,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:11371: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10524: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11415,7 +10568,6 @@
 # Done checking FFMPEG
 # Enable OpenGL option
 OPENGLINC=
@@ -11427,7 +10579,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:11431: checking whether to use OpenGL" >&5
+echo "configure:10583: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -11461,7 +10613,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:11465: checking for location of OpenGL includes" >&5
+echo "configure:10617: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -11487,15 +10639,15 @@
 do
-echo "configure:11491: checking for $ac_hdr" >&5
+echo "configure:10643: checking for $ac_hdr" >&5
-#line 11494 "configure"
+#line 10646 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11499: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10651: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11529,7 +10681,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:11533: checking for location of OpenGL library" >&5
+echo "configure:10685: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -11558,13 +10710,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:11562: checking for glBegin in -lGL" >&5
+echo "configure:10714: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11568 "configure"
+#line 10720 "configure"
@@ -11575,7 +10727,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11579: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10731: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11594,13 +10746,13 @@
-echo "configure:11598: checking for glBegin in -lGL" >&5
+echo "configure:10750: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 11604 "configure"
+#line 10756 "configure"
@@ -11611,7 +10763,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11615: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10767: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11630,13 +10782,13 @@
-echo "configure:11634: checking for glBegin in -lGL" >&5
+echo "configure:10786: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 11640 "configure"
+#line 10792 "configure"
@@ -11647,7 +10799,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11651: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10803: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11666,13 +10818,13 @@
-echo "configure:11670: checking for glBegin in -lGL" >&5
+echo "configure:10822: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11676 "configure"
+#line 10828 "configure"
@@ -11683,7 +10835,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11687: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10839: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11745,13 +10897,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11749: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:10901: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11755 "configure"
+#line 10907 "configure"
@@ -11762,7 +10914,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11766: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10918: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11781,13 +10933,13 @@
-echo "configure:11785: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:10937: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11791 "configure"
+#line 10943 "configure"
@@ -11798,7 +10950,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11802: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10954: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11842,10 +10994,10 @@
 LDFLAGS="$LDFLAGS $OPENGLLIB"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11846: checking for glXCreatePbuffer" >&5
+echo "configure:10998: checking for glXCreatePbuffer" >&5
-#line 11849 "configure"
+#line 11001 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -11868,7 +11020,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11872: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -11890,10 +11042,10 @@
 fi
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11894: checking for glXCreateGLXPixmap" >&5
+echo "configure:11046: checking for glXCreateGLXPixmap" >&5
-#line 11897 "configure"
+#line 11049 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -11916,7 +11068,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11920: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -11955,7 +11107,7 @@
-echo "configure:11959: checking for location of OpenGL includes" >&5
+echo "configure:11111: checking for location of OpenGL includes" >&5
@@ -11981,15 +11133,15 @@
 do
-echo "configure:11985: checking for $ac_hdr" >&5
+echo "configure:11137: checking for $ac_hdr" >&5
-#line 11988 "configure"
+#line 11140 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11993: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11145: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12024,10 +11176,10 @@
 LDFLAGS="$with_opengl_libs $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:12028: checking for glBegin" >&5
+echo "configure:11180: checking for glBegin" >&5
-#line 12031 "configure"
+#line 11183 "configure"
     which can conflict with char glBegin(); below.  */
@@ -12050,7 +11202,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12054: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11206: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -12065,10 +11217,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:12069: checking for gluBeginCurve" >&5
+echo "configure:11221: checking for gluBeginCurve" >&5
-#line 12072 "configure"
+#line 11224 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -12091,7 +11243,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12095: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11247: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -12135,7 +11287,7 @@
-echo "configure:12139: checking for location of OpenGL includes" >&5
+echo "configure:11291: checking for location of OpenGL includes" >&5
@@ -12161,15 +11313,15 @@
 do
-echo "configure:12165: checking for $ac_hdr" >&5
+echo "configure:11317: checking for $ac_hdr" >&5
-#line 12168 "configure"
+#line 11320 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12173: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11325: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12203,7 +11355,7 @@
-echo "configure:12207: checking for location of OpenGL library" >&5
+echo "configure:11359: checking for location of OpenGL library" >&5
@@ -12228,18 +11380,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:12232: checking for OpenGL library" >&5
+echo "configure:11384: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 12236 "configure"
+#line 11388 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:12243: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11395: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -12263,18 +11415,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:12267: checking for GLU library" >&5
+echo "configure:11419: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 12271 "configure"
+#line 11423 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:12278: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11430: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12319,11 +11471,883 @@
 # Done checking OpenGL
+# Enable TCLTK option
+echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
+echo "configure:11479: checking whether to use Tcl/Tk" >&5
+echo "$ac_t"""$with_tcltk"" 1>&6
+case "$with_tcltk" in
+	"no")	USE_TCLTK=	;;
+	"yes")	USE_TCLTK="1"	;;
+	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
+esac
+TCLINCDIR=
+TCLTKLIBPATH=
+TCLTKLIBS=
+if test -n "$USE_TCLTK"; then
+# With Tcl/Tk includes directory
+echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
+echo "configure:11499: checking for location of Tcl/Tk includes" >&5
+case "$with_tcltk_includes" in
+y | ye | yes | n | no)
+	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
+esac
+echo "$ac_t""$with_tcltk_includes" 1>&6
+if test -n "$with_tcltk_includes" ; then
+    for dir in $with_tcltk_includes; do
+        if test -d "$dir"; then
+            TCLINCDIR="$TCLINCDIR -I$dir"
+        else
+            { echo "configure: error: *** Tcl/Tk includes directory $dir does not exist." 1>&2; exit 1; }
+        fi
+    done
+fi
+ac_save_cppflags="$CPPFLAGS"
+CPPFLAGS="$TCLINCDIR $CPPFLAGS"
+for ac_hdr in tcl.h
+do
+ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
+echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
+echo "configure:11525: checking for $ac_hdr" >&5
+cat > conftest.$ac_ext <<EOF
+#line 11528 "configure"
+#include "confdefs.h"
+#include <$ac_hdr>
+EOF
+ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
+{ (eval echo configure:11533: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
+if test -z "$ac_err"; then
+  rm -rf conftest*
+  eval "ac_cv_header_$ac_safe=yes"
+else
+  echo "$ac_err" >&5
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+  eval "ac_cv_header_$ac_safe=no"
+fi
+rm -f conftest*
+if eval "test \"`echo '$ac_cv_header_'$ac_safe`\" = yes"; then
+  echo "$ac_t""yes" 1>&6
+    ac_tr_hdr=HAVE_`echo $ac_hdr | sed 'y%abcdefghijklmnopqrstuvwxyz./-%ABCDEFGHIJKLMNOPQRSTUVWXYZ___%'`
+  cat >> confdefs.h <<EOF
+#define $ac_tr_hdr 1
+EOF
+else
+  echo "$ac_t""no" 1>&6
+{ echo "configure: error: *** Unable to locate Tcl includes." 1>&2; exit 1; }
+fi
+done
+CPPFLAGS=$ac_save_cppflags
+CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
+for ac_hdr in tk.h
+do
+echo "configure:11570: checking for $ac_hdr" >&5
+#line 11573 "configure"
+#include <$ac_hdr>
+EOF
+{ (eval echo configure:11578: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+  rm -rf conftest*
+else
+  rm -rf conftest*
+fi
+rm -f conftest*
+EOF
+else
+{ echo "configure: error: *** Unable to locate Tk includes." 1>&2; exit 1; }
+fi
+done
+# Tcl/Tk version checks
+echo $ac_n "checking Tcl version""... $ac_c" 1>&6
+echo "configure:11611: checking Tcl version" >&5
+if test "$cross_compiling" = yes; then
+     tcl_ver=UNKNOWN
+    echo "$ac_t""unknown (cross-compiling)" 1>&6
+else
+  cat > conftest.$ac_ext <<EOF
+#line 11619 "configure"
+#include <stdio.h>
+#include <tcl.h>
+int main(void) {
+ FILE *fp = fopen("conftestdata","w");
+ fputs(TCL_VERSION, fp);
+ return 0;
+EOF
+if { (eval echo configure:11631: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+then
+     tcl_ver=`cat conftestdata`
+    echo "$ac_t""$tcl_ver" 1>&6
+else
+  rm -fr conftest*
+     { echo "configure: error: *** Could not determine Tcl version." 1>&2; exit 1; }
+fi
+rm -fr conftest*
+fi
+echo $ac_n "checking Tk version""... $ac_c" 1>&6
+echo "configure:11649: checking Tk version" >&5
+     tk_ver=UNKNOWN
+else
+#line 11657 "configure"
+#include <stdio.h>
+#include <tk.h>
+int main(void) {
+ fputs(TK_VERSION, fp);
+ return 0;
+EOF
+if { (eval echo configure:11669: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+then
+     tk_ver=`cat conftestdata`
+    echo "$ac_t""$tk_ver" 1>&6
+else
+  rm -fr conftest*
+     { echo "configure: error: *** Could not determine Tk version." 1>&2; exit 1; }
+fi
+rm -fr conftest*
+fi
+if test "$tcl_ver" = "$tk_ver" ; then
+    tcltk_ver=$tcl_ver
+else
+    { echo "configure: error: *** Tcl/Tk version mismatch." 1>&2; exit 1; }
+fi
+TCL_VERSION="$tcl_ver"
+# FreeBSD and CygWin don't have a "dot" between major/minor version number
+tcltk_ver2=`echo $tcltk_ver | sed 's/\.//g'`
+# With Tcl/Tk library directory
+echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
+echo "configure:11700: checking for location of Tcl/Tk library" >&5
+case "$with_tcltk_libs" in
+	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
+esac
+echo "$ac_t""$with_tcltk_libs" 1>&6
+if test -n "$with_tcltk_libs"; then
+    for dir in $with_tcltk_libs; do
+            TCLTKLIBPATH="$TCLTKLIBPATH -L$dir"
+        else
+            { echo "configure: error: *** Tcl/Tk library directory $dir does not exist." 1>&2; exit 1; }
+        fi
+    done
+fi
+TCLLIB=
+TKLIB=
+# Can't test tcl/tk libs on 64bit OSX Aqua for now
+# assume that if OpenGL Aqua, then user specifies TclTk Aqua,
+# as there is no test for Tcl/Tk Aqua and Tck/Tk X11 won't work
+TCLTKAQUA_IS64BIT=
+if test "$OPENGL_AQUA" = 1 ; then
+    temp_CFLAGS="$CFLAGS"
+    CFLAGS="`echo \"$CFLAGS\" | sed -E 's/-arch +x86_64//g' | sed -E 's/-arch +ppc64//g'`"
+    # can't save LDFLAGS, need to remember arch flags to insert back later
+    temp_ARCHES=
+    for a in x86_64 ppc64
+    do
+        if test -n "`echo \"$LDFLAGS\" | grep -E -e '-arch +'$a`" ; then
+            temp_ARCHES="$temp_ARCHES -arch $a"
+        fi
+    done
+    LDFLAGS="`echo \"$LDFLAGS\" | sed -E 's/-arch +x86_64//g' | sed -E 's/-arch +ppc64//g'`"
+fi
+ac_save_ldflags="$LDFLAGS"
+LDFLAGS="$TCLTKLIBPATH $LDFLAGS"
+echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
+echo "configure:11748: checking for Tcl_Init in -ltcl" >&5
+ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
+ac_save_LIBS="$LIBS"
+LIBS="-ltcl $MATHLIB $LIBS"
+#line 11754 "configure"
+/* Override any gcc2 internal prototype to avoid an error.  */
+/* We use char because int might match the return type of a gcc2
+    builtin and then its argument prototype would still apply.  */
+char Tcl_Init();
+int main() {
+Tcl_Init()
+; return 0; }
+EOF
+if { (eval echo configure:11765: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+  eval "ac_cv_lib_$ac_lib_var=yes"
+else
+  rm -rf conftest*
+  eval "ac_cv_lib_$ac_lib_var=no"
+fi
+rm -f conftest*
+LIBS="$ac_save_LIBS"
+if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
+  TCLLIB="$TCLLIB -ltcl $MATHLIB"
+else
+echo "configure:11784: checking for Tcl_Init in -ltcl" >&5
+LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
+#line 11790 "configure"
+char Tcl_Init();
+int main() {
+Tcl_Init()
+; return 0; }
+EOF
+if { (eval echo configure:11801: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+else
+  rm -rf conftest*
+fi
+rm -f conftest*
+  TCLLIB="$TCLLIB -ltcl $MATHLIB $DLLIB"
+else
+LDFLAGS=${ac_save_ldflags}
+echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
+echo "configure:11828: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
+LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
+#line 11834 "configure"
+char Tcl_Init();
+int main() {
+Tcl_Init()
+; return 0; }
+EOF
+if { (eval echo configure:11845: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+else
+  rm -rf conftest*
+fi
+rm -f conftest*
+  TCLLIB="$TCLLIB -ltcl$tcltk_ver $MATHLIB"
+else
+echo "configure:11864: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
+#line 11870 "configure"
+char Tcl_Init();
+int main() {
+Tcl_Init()
+; return 0; }
+EOF
+if { (eval echo configure:11881: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+else
+  rm -rf conftest*
+fi
+rm -f conftest*
+  TCLLIB="$TCLLIB -ltcl$tcltk_ver $MATHLIB $DLLIB"
+else
+echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
+echo "configure:11908: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
+LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
+#line 11914 "configure"
+char Tcl_Init();
+int main() {
+Tcl_Init()
+; return 0; }
+EOF
+if { (eval echo configure:11925: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+else
+  rm -rf conftest*
+fi
+rm -f conftest*
+  TCLLIB="$TCLLIB -ltcl$tcltk_ver2 $MATHLIB"
+else
+echo "configure:11944: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
+#line 11950 "configure"
+char Tcl_Init();
+int main() {
+Tcl_Init()
+; return 0; }
+EOF
+if { (eval echo configure:11961: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+else
+  rm -rf conftest*
+fi
+rm -f conftest*
+  TCLLIB="$TCLLIB -ltcl$tcltk_ver2 $MATHLIB $DLLIB"
+else
+    { echo "configure: error: *** Unable to locate Tcl library." 1>&2; exit 1; }
+fi
+fi
+fi
+fi
+fi
+fi
+echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
+echo "configure:12039: checking for Tk_MainWindow in -ltk" >&5
+ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
+LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
+#line 12045 "configure"
+char Tk_MainWindow();
+int main() {
+Tk_MainWindow()
+; return 0; }
+EOF
+if { (eval echo configure:12056: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+else
+  rm -rf conftest*
+fi
+rm -f conftest*
+  TKLIB="$TKLIB -ltk $MATHLIB"
+else
+echo "configure:12075: checking for Tk_MainWindow in -ltk" >&5
+LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
+#line 12081 "configure"
+int main() {
+Tk_MainWindow()
+; return 0; }
+EOF
+if { (eval echo configure:12092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+else
+  rm -rf conftest*
+fi
+rm -f conftest*
+  TKLIB="$TKLIB -ltk $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS"
+else
+echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
+echo "configure:12119: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
+LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
+#line 12125 "configure"
+int main() {
+Tk_MainWindow()
+; return 0; }
+EOF
+if { (eval echo configure:12136: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+else
+  rm -rf conftest*
+fi
+rm -f conftest*
+  TKLIB="$TKLIB -ltk$tcltk_ver $MATHLIB"
+else
+echo "configure:12155: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
+#line 12161 "configure"
+int main() {
+Tk_MainWindow()
+; return 0; }
+EOF
+if { (eval echo configure:12172: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+else
+  rm -rf conftest*
+fi
+rm -f conftest*
+  TKLIB="$TKLIB -ltk$tcltk_ver $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS"
+else
+echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
+echo "configure:12199: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
+LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
+#line 12205 "configure"
+int main() {
+Tk_MainWindow()
+; return 0; }
+EOF
+if { (eval echo configure:12216: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+else
+  rm -rf conftest*
+fi
+rm -f conftest*
+  TKLIB="$TKLIB -ltk$tcltk_ver2 $MATHLIB"
+else
+echo "configure:12235: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
+#line 12241 "configure"
+int main() {
+Tk_MainWindow()
+; return 0; }
+EOF
+if { (eval echo configure:12252: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+else
+  rm -rf conftest*
+fi
+rm -f conftest*
+  TKLIB="$TKLIB -ltk$tcltk_ver2 $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS"
+else
+    { echo "configure: error: *** Unable to locate Tk library." 1>&2; exit 1; }
+fi
+fi
+fi
+fi
+fi
+fi
+# restore CFLAGS/LDLFAGS from Aqua 64bit strip
+# only Tcl/Tk-based makefiles will strip 64bit out during compile
+   CFLAGS="$temp_CFLAGS"
+   LDFLAGS="$temp_ARCHES $LDFLAGS"
+fi
+TCLTKLIBS="$TKLIB $TCLLIB"
+cat >> confdefs.h <<\EOF
+#define HAVE_TCLTK 1
+EOF
+fi # $USE_TCLTK
+TKINCDIR=$TCLINCDIR
+# Done checking Tcl/Tk
 # Enable ODBC option
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:12327: checking whether to use ODBC" >&5
+echo "configure:12351: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -12342,7 +12366,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12346: checking for location of ODBC includes" >&5
+echo "configure:12370: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12368,15 +12392,15 @@
 do
-echo "configure:12372: checking for $ac_hdr" >&5
+echo "configure:12396: checking for $ac_hdr" >&5
-#line 12375 "configure"
+#line 12399 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12380: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12404: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12410,7 +12434,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12414: checking for location of ODBC library" >&5
+echo "configure:12438: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12435,13 +12459,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12439: checking for SQLConnect in -lodbc" >&5
+echo "configure:12463: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 12445 "configure"
+#line 12469 "configure"
@@ -12452,7 +12476,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12456: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12480: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12477,13 +12501,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12481: checking for SQLConnect in -liodbc" >&5
+echo "configure:12505: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 12487 "configure"
+#line 12511 "configure"
@@ -12494,7 +12518,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12519,11 +12543,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12523: checking for ODBC library" >&5
+echo "configure:12547: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 12527 "configure"
+#line 12551 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -12531,7 +12555,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:12535: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12559: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12580,7 +12604,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12584: checking whether to use FFTW" >&5
+echo "configure:12608: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -12599,7 +12623,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12603: checking for location of FFTW includes" >&5
+echo "configure:12627: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12625,15 +12649,15 @@
 do
-echo "configure:12629: checking for $ac_hdr" >&5
+echo "configure:12653: checking for $ac_hdr" >&5
-#line 12632 "configure"
+#line 12656 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12637: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12661: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12661,15 +12685,15 @@
 do
-echo "configure:12665: checking for $ac_hdr" >&5
+echo "configure:12689: checking for $ac_hdr" >&5
-#line 12668 "configure"
+#line 12692 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12673: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12697: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12697,15 +12721,15 @@
 do
-echo "configure:12701: checking for $ac_hdr" >&5
+echo "configure:12725: checking for $ac_hdr" >&5
-#line 12704 "configure"
+#line 12728 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12709: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12733: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12751,7 +12775,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12755: checking for location of FFTW library" >&5
+echo "configure:12779: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12776,13 +12800,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12780: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12804: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12786 "configure"
+#line 12810 "configure"
@@ -12793,7 +12817,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:12797: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12818,13 +12842,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12822: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12846: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 12828 "configure"
+#line 12852 "configure"
@@ -12835,7 +12859,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12839: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12863: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12860,13 +12884,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12864: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12888: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12870 "configure"
+#line 12894 "configure"
@@ -12877,7 +12901,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12881: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12905: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12934,7 +12958,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12938: checking whether to use BLAS" >&5
+echo "configure:12962: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -12955,7 +12979,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12959: checking for location of BLAS includes" >&5
+echo "configure:12983: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12975,7 +12999,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12979: checking for location of BLAS library" >&5
+echo "configure:13003: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -13001,15 +13025,15 @@
 do
-echo "configure:13005: checking for $ac_hdr" >&5
+echo "configure:13029: checking for $ac_hdr" >&5
-#line 13008 "configure"
+#line 13032 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13013: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13037: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13044,13 +13068,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:13048: checking for dnrm2_ in -lblas" >&5
+echo "configure:13072: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 13054 "configure"
+#line 13078 "configure"
@@ -13061,7 +13085,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:13065: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13080,13 +13104,13 @@
-echo "configure:13084: checking for dnrm2_ in -lblas" >&5
+echo "configure:13108: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 13090 "configure"
+#line 13114 "configure"
@@ -13097,7 +13121,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:13101: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13125: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13141,13 +13165,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:13145: checking for ATL_xerbla in -latlas" >&5
+echo "configure:13169: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 13151 "configure"
+#line 13175 "configure"
@@ -13158,7 +13182,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:13162: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13186: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13173,13 +13197,13 @@
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:13177: checking for sgemm_ in -lf77blas" >&5
+echo "configure:13201: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 13183 "configure"
+#line 13207 "configure"
@@ -13190,7 +13214,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13194: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13218: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13205,13 +13229,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:13209: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:13233: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 13215 "configure"
+#line 13239 "configure"
@@ -13222,7 +13246,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:13226: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13250: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13267,16 +13291,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:13271: checking for sgemm in $vlib_flags" >&5
+echo "configure:13295: checking for sgemm in $vlib_flags" >&5
-#line 13273 "configure"
+#line 13297 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:13280: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13304: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -13294,13 +13318,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:13298: checking for sgemm_ in -lblas" >&5
+echo "configure:13322: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 13304 "configure"
+#line 13328 "configure"
@@ -13311,7 +13335,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13315: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13339: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13326,13 +13350,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:13330: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13354: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 13336 "configure"
+#line 13360 "configure"
@@ -13343,7 +13367,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13347: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13371: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13358,13 +13382,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13362: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13386: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 13368 "configure"
+#line 13392 "configure"
@@ -13375,7 +13399,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13403: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13409,13 +13433,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13413: checking for acosp in -lsunmath" >&5
+echo "configure:13437: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 13419 "configure"
+#line 13443 "configure"
@@ -13426,7 +13450,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:13430: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13441,13 +13465,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13445: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13469: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 13451 "configure"
+#line 13475 "configure"
@@ -13458,7 +13482,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13462: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13486: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13488,13 +13512,13 @@
 # Generic BLAS library
-echo "configure:13492: checking for sgemm_ in -lblas" >&5
+echo "configure:13516: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 13498 "configure"
+#line 13522 "configure"
@@ -13505,7 +13529,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13509: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13533: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13544,7 +13568,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13548: checking whether to use LAPACK" >&5
+echo "configure:13572: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -13569,7 +13593,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13573: checking for location of LAPACK includes" >&5
+echo "configure:13597: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13589,7 +13613,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13593: checking for location of LAPACK library" >&5
+echo "configure:13617: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13615,15 +13639,15 @@
 do
-echo "configure:13619: checking for $ac_hdr" >&5
+echo "configure:13643: checking for $ac_hdr" >&5
-#line 13622 "configure"
+#line 13646 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13627: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13651: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13655,10 +13679,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13659: checking for dsegv_" >&5
+echo "configure:13683: checking for dsegv_" >&5
-#line 13662 "configure"
+#line 13686 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -13681,7 +13705,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13709: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -13708,13 +13732,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13712: checking for desgv_ in -llapack" >&5
+echo "configure:13736: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 13718 "configure"
+#line 13742 "configure"
@@ -13725,7 +13749,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13729: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13753: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13757,13 +13781,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13761: checking for dgesv_ in -llapack" >&5
+echo "configure:13785: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 13767 "configure"
+#line 13791 "configure"
@@ -13774,7 +13798,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13778: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13802: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13793,13 +13817,13 @@
-echo "configure:13797: checking for dgesv_ in -llapack" >&5
+echo "configure:13821: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13803 "configure"
+#line 13827 "configure"
@@ -13810,7 +13834,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13814: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13838: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13866,7 +13890,7 @@
 echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:13870: checking whether to use Motif" >&5
+echo "configure:13894: checking whether to use Motif" >&5
 echo "$ac_t"""$with_motif"" 1>&6
 case "$with_motif" in
 	"no")	USE_MOTIF=	;;
@@ -13885,7 +13909,7 @@
 echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:13889: checking for location of Motif includes" >&5
+echo "configure:13913: checking for location of Motif includes" >&5
 case "$with_motif_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -13911,15 +13935,15 @@
 do
-echo "configure:13915: checking for $ac_hdr" >&5
+echo "configure:13939: checking for $ac_hdr" >&5
-#line 13918 "configure"
+#line 13942 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13923: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13947: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13953,7 +13977,7 @@
 echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:13957: checking for location of Motif library" >&5
+echo "configure:13981: checking for location of Motif library" >&5
 case "$with_motif_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -13978,13 +14002,13 @@
 echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:13982: checking for XmStringCreate in -lXm" >&5
+echo "configure:14006: checking for XmStringCreate in -lXm" >&5
 ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
 LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS  $LIBS"
-#line 13988 "configure"
+#line 14012 "configure"
@@ -13995,7 +14019,7 @@
 XmStringCreate()
 ; return 0; }
 EOF
-if { (eval echo configure:13999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14023: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14036,7 +14060,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:14040: checking whether to use Cairo" >&5
+echo "configure:14064: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -14062,7 +14086,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:14066: checking for location of cairo includes" >&5
+echo "configure:14090: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -14088,15 +14112,15 @@
 do
-echo "configure:14092: checking for $ac_hdr" >&5
+echo "configure:14116: checking for $ac_hdr" >&5
-#line 14095 "configure"
+#line 14119 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14100: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14124: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14132,7 +14156,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:14136: checking for location of cairo library" >&5
+echo "configure:14160: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -14152,7 +14176,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:14156: checking for cairo linking flags" >&5
+echo "configure:14180: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -14168,10 +14192,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:14172: checking for cairo_create" >&5
+echo "configure:14196: checking for cairo_create" >&5
-#line 14175 "configure"
+#line 14199 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -14194,7 +14218,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14198: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14222: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -14228,10 +14252,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:14232: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:14256: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 14235 "configure"
+#line 14259 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -14254,7 +14278,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14258: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14282: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -14296,7 +14320,7 @@
 echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:14300: checking whether to use GLw" >&5
+echo "configure:14324: checking whether to use GLw" >&5
 echo "$ac_t"""$with_glw"" 1>&6
 case "$with_glw" in
 	"no")	USE_GLW=	;;
@@ -14315,7 +14339,7 @@
 echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:14319: checking for location of GLw includes" >&5
+echo "configure:14343: checking for location of GLw includes" >&5
 case "$with_glw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -14341,15 +14365,15 @@
 do
-echo "configure:14345: checking for $ac_hdr" >&5
+echo "configure:14369: checking for $ac_hdr" >&5
-#line 14348 "configure"
+#line 14372 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14353: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14377: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14377,15 +14401,15 @@
 do
-echo "configure:14381: checking for $ac_hdr" >&5
+echo "configure:14405: checking for $ac_hdr" >&5
-#line 14384 "configure"
+#line 14408 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14389: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14413: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14425,7 +14449,7 @@
 echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:14429: checking for location of GLw library" >&5
+echo "configure:14453: checking for location of GLw library" >&5
 case "$with_glw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -14450,13 +14474,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14454: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:14478: checking for GLwCreateMDrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14460 "configure"
+#line 14484 "configure"
@@ -14467,7 +14491,7 @@
 GLwCreateMDrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14471: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14495: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14492,13 +14516,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14496: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:14520: checking for GLwCreateM1DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14502 "configure"
+#line 14526 "configure"
@@ -14509,7 +14533,7 @@
 GLwCreateM1DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14513: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14537: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14534,13 +14558,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14538: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:14562: checking for GLwCreateM2DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14544 "configure"
+#line 14568 "configure"
@@ -14551,7 +14575,7 @@
 GLwCreateM2DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14555: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14579: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14576,13 +14600,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14580: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:14604: checking for GLwCreateMDrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14586 "configure"
+#line 14610 "configure"
@@ -14593,7 +14617,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14597: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14621: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14618,13 +14642,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14622: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:14646: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14628 "configure"
+#line 14652 "configure"
@@ -14635,7 +14659,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14639: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14663: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14660,13 +14684,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14664: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:14688: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14670 "configure"
+#line 14694 "configure"
@@ -14677,7 +14701,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14681: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14705: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14704,13 +14728,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:14708: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14732: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14714 "configure"
+#line 14738 "configure"
@@ -14721,7 +14745,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14725: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14749: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14740,13 +14764,13 @@
-echo "configure:14744: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14768: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14750 "configure"
+#line 14774 "configure"
@@ -14757,7 +14781,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14761: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14785: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14784,13 +14808,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:14788: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14812: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14794 "configure"
+#line 14818 "configure"
@@ -14801,7 +14825,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14805: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14829: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14820,13 +14844,13 @@
-echo "configure:14824: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14848: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14830 "configure"
+#line 14854 "configure"
@@ -14837,7 +14861,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14841: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14865: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14950,7 +14974,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:14954: checking whether to use FreeType" >&5
+echo "configure:14978: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -14969,7 +14993,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:14973: checking for location of FreeType includes" >&5
+echo "configure:14997: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -14995,15 +15019,15 @@
 do
-echo "configure:14999: checking for $ac_hdr" >&5
+echo "configure:15023: checking for $ac_hdr" >&5
-#line 15002 "configure"
+#line 15026 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15007: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15031: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15037,7 +15061,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:15041: checking for location of FreeType library" >&5
+echo "configure:15065: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -15062,13 +15086,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:15066: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:15090: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 15072 "configure"
+#line 15096 "configure"
@@ -15079,7 +15103,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:15083: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15107: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15120,7 +15144,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:15124: checking whether to use NLS" >&5
+echo "configure:15148: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -15140,10 +15164,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:15144: checking for gettext" >&5
+echo "configure:15168: checking for gettext" >&5
-#line 15147 "configure"
+#line 15171 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char gettext(); below.  */
@@ -15166,7 +15190,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15170: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15194: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -15184,13 +15208,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:15188: checking for gettext in -lintl" >&5
+echo "configure:15212: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 15194 "configure"
+#line 15218 "configure"
@@ -15201,7 +15225,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:15205: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15236,7 +15260,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:15240: checking whether to use C++" >&5
+echo "configure:15264: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -15252,7 +15276,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:15256: checking for $ac_word" >&5
+echo "configure:15280: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -15281,7 +15305,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:15285: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:15309: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -15292,12 +15316,12 @@
 cat > conftest.$ac_ext << EOF
-#line 15296 "configure"
+#line 15320 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:15301: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15325: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -15323,19 +15347,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:15327: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:15351: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:15332: checking whether we are using GNU C++" >&5
+echo "configure:15356: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15339: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15363: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -15353,7 +15377,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:15357: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:15381: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -15394,7 +15418,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:15398: checking whether to use openDWG" >&5
+echo "configure:15422: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -15414,7 +15438,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15418: checking for location of openDGW includes" >&5
+echo "configure:15442: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15440,15 +15464,15 @@
 do
-echo "configure:15444: checking for $ac_hdr" >&5
+echo "configure:15468: checking for $ac_hdr" >&5
-#line 15447 "configure"
+#line 15471 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15452: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15476: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15482,7 +15506,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15486: checking for location of openDWG library" >&5
+echo "configure:15510: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -15529,7 +15553,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:15533: checking for special C compiler options needed for large files" >&5
+echo "configure:15557: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -15537,7 +15561,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 15541 "configure"
+#line 15565 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -15553,7 +15577,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15557: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15581: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -15562,7 +15586,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 15566 "configure"
+#line 15590 "configure"
@@ -15578,7 +15602,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15582: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15606: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -15598,11 +15622,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15602: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15626: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 15606 "configure"
+#line 15630 "configure"
@@ -15618,14 +15642,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15622: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15646: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15629 "configure"
+#line 15653 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -15643,7 +15667,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15647: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15671: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -15662,11 +15686,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15666: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15690: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 15670 "configure"
+#line 15694 "configure"
@@ -15682,14 +15706,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15686: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15710: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15693 "configure"
+#line 15717 "configure"
 #define _LARGE_FILES 1
@@ -15707,7 +15731,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15711: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15735: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -15726,25 +15750,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15730: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15754: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 15734 "configure"
+#line 15758 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15741: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15765: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15748 "configure"
+#line 15772 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -15753,7 +15777,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15757: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15781: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -15774,10 +15798,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:15778: checking if system supports Large Files at all" >&5
+echo "configure:15802: checking if system supports Large Files at all" >&5
-#line 15781 "configure"
+#line 15805 "configure"
 #include <stdio.h>
@@ -15809,7 +15833,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:15813: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15837: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -15838,7 +15862,7 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:15842: checking whether to use Python" >&5
+echo "configure:15866: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
@@ -15858,7 +15882,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
-echo "configure:15862: checking for $ac_word" >&5
+echo "configure:15886: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -15900,15 +15924,15 @@
 do
-echo "configure:15904: checking for $ac_hdr" >&5
+echo "configure:15928: checking for $ac_hdr" >&5
-#line 15907 "configure"
+#line 15931 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15912: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15936: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15949,7 +15973,7 @@
   # Extract the first word of "swig", so it can be a program name with args.
 set dummy swig; ac_word=$2
-echo "configure:15953: checking for $ac_word" >&5
+echo "configure:15977: checking for $ac_word" >&5
 case "$SWIG" in
@@ -15995,7 +16019,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:15999: checking whether to use wxWidgets" >&5
+echo "configure:16023: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -16015,7 +16039,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:16019: checking for $ac_word" >&5
+echo "configure:16043: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -16063,7 +16087,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:16067: checking wxWidgets version" >&5
+echo "configure:16091: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -16086,15 +16110,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:16090: checking for $ac_hdr" >&5
+echo "configure:16114: checking for $ac_hdr" >&5
-#line 16093 "configure"
+#line 16117 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:16098: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16122: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -16350,11 +16374,6 @@
 s%@PNGINC@%$PNGINC%g
 s%@PNGLIB@%$PNGLIB%g
 s%@USE_PNG@%$USE_PNG%g
-s%@TCLINCDIR@%$TCLINCDIR%g
-s%@TKINCDIR@%$TKINCDIR%g
-s%@TCLTKLIBPATH@%$TCLTKLIBPATH%g
-s%@TCLTKLIBS@%$TCLTKLIBS%g
-s%@TCL_VERSION@%$TCL_VERSION%g
 s%@USE_POSTGRES@%$USE_POSTGRES%g
 s%@PQINCPATH@%$PQINCPATH%g
 s%@PQLIBPATH@%$PQLIBPATH%g
@@ -16380,6 +16399,12 @@
 s%@OPENGLINC@%$OPENGLINC%g
 s%@OPENGLLIB@%$OPENGLLIB%g
 s%@OPENGLULIB@%$OPENGLULIB%g
+s%@TCLINCDIR@%$TCLINCDIR%g
+s%@TKINCDIR@%$TKINCDIR%g
+s%@TCLTKLIBPATH@%$TCLTKLIBPATH%g
+s%@TCLTKLIBS@%$TCLTKLIBS%g
+s%@TCL_VERSION@%$TCL_VERSION%g
+s%@TCLTKAQUA_IS64BIT@%$TCLTKAQUA_IS64BIT%g
 s%@ODBCINC@%$ODBCINC%g
 s%@ODBCLIB@%$ODBCLIB%g
 s%@FFTWINC@%$FFTWINC%g
Modified: grass/branches/develbranch_6/configure.in
--- grass/branches/develbranch_6/configure.in	2009-05-23 16:23:37 UTC (rev 37401)
+++ grass/branches/develbranch_6/configure.in	2009-05-23 17:10:51 UTC (rev 37402)
@@ -875,76 +875,6 @@
 # Done checking PNG
-# Enable TCLTK option
-LOC_CHECK_USE(tcltk,Tcl/Tk,USE_TCLTK)
-TCLINCDIR=
-TCLTKLIBPATH=
-TCLTKLIBS=
-if test -n "$USE_TCLTK"; then
-# With Tcl/Tk includes directory
-LOC_CHECK_INC_PATH(tcltk,Tcl/Tk,TCLINCDIR)
-LOC_CHECK_INCLUDES(tcl.h,Tcl,$TCLINCDIR)
-LOC_CHECK_INCLUDES(tk.h,Tk,$TCLINCDIR $X_CFLAGS)
-# Tcl/Tk version checks
-LOC_CHECK_VERSION_STRING(tcl.h,TCL_VERSION,Tcl,tcl_ver,$TCLINCDIR,UNKNOWN)
-LOC_CHECK_VERSION_STRING(tk.h,TK_VERSION,Tk,tk_ver,$TCLINCDIR $X_CFLAGS,UNKNOWN)
-if test "$tcl_ver" = "$tk_ver" ; then
-    tcltk_ver=$tcl_ver
-else
-    AC_MSG_ERROR([*** Tcl/Tk version mismatch.])
-fi
-TCL_VERSION="$tcl_ver"
-# FreeBSD and CygWin don't have a "dot" between major/minor version number
-tcltk_ver2=`echo $tcltk_ver | sed 's/\.//g'`
-# With Tcl/Tk library directory
-LOC_CHECK_LIB_PATH(tcltk,Tcl/Tk,TCLTKLIBPATH)
-TCLLIB=
-TKLIB=
-LOC_CHECK_LIBS(tcl,           Tcl_Init,Tcl,$TCLTKLIBPATH,TCLLIB,,$MATHLIB,[
-LOC_CHECK_LIBS(tcl$tcltk_ver, Tcl_Init,Tcl,$TCLTKLIBPATH,TCLLIB,,$MATHLIB,[
-LOC_CHECK_LIBS(tcl$tcltk_ver2,Tcl_Init,Tcl,$TCLTKLIBPATH,TCLLIB,,$MATHLIB,[
-],$DLLIB)
-],$DLLIB)
-],$DLLIB)
-LOC_CHECK_LIBS(tk,           Tk_MainWindow,Tk,$TCLTKLIBPATH,TKLIB,$TCLLIB,$MATHLIB,[
-LOC_CHECK_LIBS(tk$tcltk_ver, Tk_MainWindow,Tk,$TCLTKLIBPATH,TKLIB,$TCLLIB,$MATHLIB,[
-LOC_CHECK_LIBS(tk$tcltk_ver2,Tk_MainWindow,Tk,$TCLTKLIBPATH,TKLIB,$TCLLIB,$MATHLIB,[
-],$X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS)
-TCLTKLIBS="$TKLIB $TCLLIB"
-AC_DEFINE(HAVE_TCLTK)
-fi # $USE_TCLTK
-TKINCDIR=$TCLINCDIR
-AC_SUBST(TCLINCDIR)
-AC_SUBST(TKINCDIR)
-AC_SUBST(TCLTKLIBPATH)
-AC_SUBST(TCLTKLIBS)
-AC_SUBST(TCL_VERSION)
-# Done checking Tcl/Tk
 # Enable PostgreSQL option
 LOC_CHECK_USE(postgres,PostgreSQL,USE_POSTGRES)
@@ -1127,7 +1057,6 @@
 # Done checking FFMPEG
 # Enable OpenGL option
 OPENGLINC=
@@ -1261,6 +1190,101 @@
 # Done checking OpenGL
+# Enable TCLTK option
+LOC_CHECK_USE(tcltk,Tcl/Tk,USE_TCLTK)
+TCLINCDIR=
+TCLTKLIBPATH=
+TCLTKLIBS=
+if test -n "$USE_TCLTK"; then
+# With Tcl/Tk includes directory
+LOC_CHECK_INC_PATH(tcltk,Tcl/Tk,TCLINCDIR)
+LOC_CHECK_INCLUDES(tcl.h,Tcl,$TCLINCDIR)
+LOC_CHECK_INCLUDES(tk.h,Tk,$TCLINCDIR $X_CFLAGS)
+# Tcl/Tk version checks
+LOC_CHECK_VERSION_STRING(tcl.h,TCL_VERSION,Tcl,tcl_ver,$TCLINCDIR,UNKNOWN)
+LOC_CHECK_VERSION_STRING(tk.h,TK_VERSION,Tk,tk_ver,$TCLINCDIR $X_CFLAGS,UNKNOWN)
+if test "$tcl_ver" = "$tk_ver" ; then
+    tcltk_ver=$tcl_ver
+else
+    AC_MSG_ERROR([*** Tcl/Tk version mismatch.])
+fi
+TCL_VERSION="$tcl_ver"
+# FreeBSD and CygWin don't have a "dot" between major/minor version number
+tcltk_ver2=`echo $tcltk_ver | sed 's/\.//g'`
+# With Tcl/Tk library directory
+LOC_CHECK_LIB_PATH(tcltk,Tcl/Tk,TCLTKLIBPATH)
+TCLLIB=
+TKLIB=
+# Can't test tcl/tk libs on 64bit OSX Aqua for now
+# assume that if OpenGL Aqua, then user specifies TclTk Aqua,
+# as there is no test for Tcl/Tk Aqua and Tck/Tk X11 won't work
+TCLTKAQUA_IS64BIT=
+if test "$OPENGL_AQUA" = 1 ; then
+    temp_CFLAGS="$CFLAGS"
+    CFLAGS="`echo \"$CFLAGS\" | sed -E 's/-arch +x86_64//g' | sed -E 's/-arch +ppc64//g'`"
+    # can't save LDFLAGS, need to remember arch flags to insert back later
+    temp_ARCHES=
+    for a in x86_64 ppc64
+    do
+        if test -n "`echo \"$LDFLAGS\" | grep -E -e '-arch +'$a`" ; then
+            temp_ARCHES="$temp_ARCHES -arch $a"
+        fi
+    done
+    LDFLAGS="`echo \"$LDFLAGS\" | sed -E 's/-arch +x86_64//g' | sed -E 's/-arch +ppc64//g'`"
+fi
+LOC_CHECK_LIBS(tcl,           Tcl_Init,Tcl,$TCLTKLIBPATH,TCLLIB,,$MATHLIB,[
+LOC_CHECK_LIBS(tcl$tcltk_ver, Tcl_Init,Tcl,$TCLTKLIBPATH,TCLLIB,,$MATHLIB,[
+LOC_CHECK_LIBS(tcl$tcltk_ver2,Tcl_Init,Tcl,$TCLTKLIBPATH,TCLLIB,,$MATHLIB,[
+],$DLLIB)
+],$DLLIB)
+],$DLLIB)
+LOC_CHECK_LIBS(tk,           Tk_MainWindow,Tk,$TCLTKLIBPATH,TKLIB,$TCLLIB,$MATHLIB,[
+LOC_CHECK_LIBS(tk$tcltk_ver, Tk_MainWindow,Tk,$TCLTKLIBPATH,TKLIB,$TCLLIB,$MATHLIB,[
+LOC_CHECK_LIBS(tk$tcltk_ver2,Tk_MainWindow,Tk,$TCLTKLIBPATH,TKLIB,$TCLLIB,$MATHLIB,[
+],$X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS)
+fi
+AC_DEFINE(HAVE_TCLTK)
+fi # $USE_TCLTK
+AC_SUBST(TCLINCDIR)
+AC_SUBST(TKINCDIR)
+AC_SUBST(TCLTKLIBPATH)
+AC_SUBST(TCLTKLIBS)
+AC_SUBST(TCL_VERSION)
+AC_SUBST(TCLTKAQUA_IS64BIT)
 LOC_CHECK_USE(odbc,ODBC,USE_ODBC)
Modified: grass/branches/develbranch_6/display/d.what.vect/Makefile
--- grass/branches/develbranch_6/display/d.what.vect/Makefile	2009-05-23 16:23:37 UTC (rev 37401)
+++ grass/branches/develbranch_6/display/d.what.vect/Makefile	2009-05-23 17:10:51 UTC (rev 37402)
@@ -12,6 +12,13 @@
 include $(MODULE_TOPDIR)/include/Make/Module.make
+ifeq ($(OPENGL_AQUA),1)
+ifneq ($(TCLTKAQUA_IS64BIT),1)
+CFLAGS := $(subst -arch ppc64,,$(subst -arch x86_64,,$(CFLAGS)))
+LDFLAGS := $(subst -arch ppc64,,$(subst -arch x86_64,,$(LDFLAGS)))
+endif
+endif
 default: cmd
Modified: grass/branches/develbranch_6/include/Make/Platform.make.in
--- grass/branches/develbranch_6/include/Make/Platform.make.in	2009-05-23 16:23:37 UTC (rev 37401)
+++ grass/branches/develbranch_6/include/Make/Platform.make.in	2009-05-23 17:10:51 UTC (rev 37402)
@@ -171,6 +171,8 @@
 TCLTKLIBPATH        = @TCLTKLIBPATH@
 TCLTKLIBS           = @TCLTKLIBS@
 TCLVERSION          = @TCL_VERSION@
+# set from configure when 64bit TclTk Aqua becomes possible on OSX
+TCLTKAQUA_IS64BIT    = @TCLTKAQUA_IS64BIT@
 #FFTW:
 FFTWINC             = @FFTWINC@
@@ -188,11 +190,6 @@
 USE_GDAL            = @USE_GDAL@
 USE_OGR             = @USE_OGR@
-#GEOS
-GEOSLIBS            = @GEOS_LIBS@
-GEOSCFLAGS          = @GEOS_CFLAGS@
-USE_GEOS            = @USE_GEOS@
 #FreeType:
 FTINC               = @FTINC@
 FTLIB               = @FTLIB@
@@ -227,6 +224,8 @@
 WXWIDGETSCPPFLAGS   = @WXWIDGETSCPPFLAGS@
 WXWIDGETSLIB        = @WXWIDGETSLIB@
 USE_WXWIDGETS       = @USE_WXWIDGETS@
+# set from configure when 64bit wxWidgets becomes possible on OSX
+WX_ISOSX64BIT       =
 #regex
 REGEXINCPATH        = @REGEXINCPATH@
Modified: grass/branches/develbranch_6/lib/form/Makefile
--- grass/branches/develbranch_6/lib/form/Makefile	2009-05-23 16:23:37 UTC (rev 37401)
+++ grass/branches/develbranch_6/lib/form/Makefile	2009-05-23 17:10:51 UTC (rev 37402)
@@ -20,6 +20,13 @@
 include $(MODULE_TOPDIR)/include/Make/Lib.make
+endif
+endif
 default: lib $(GTCLTKFORM)
 $(FORMDIR):
Modified: grass/branches/develbranch_6/vector/v.digit/Makefile
--- grass/branches/develbranch_6/vector/v.digit/Makefile	2009-05-23 16:23:37 UTC (rev 37401)
+++ grass/branches/develbranch_6/vector/v.digit/Makefile	2009-05-23 17:10:51 UTC (rev 37402)
@@ -11,6 +11,13 @@
+endif
+endif
 AUXDIR := $(GISBASE)/etc/v.digit
 TCLFILES := $(patsubst %,$(AUXDIR)/%,$(wildcard *.tcl))
Modified: grass/branches/develbranch_6/vector/v.what/Makefile
--- grass/branches/develbranch_6/vector/v.what/Makefile	2009-05-23 16:23:37 UTC (rev 37401)
+++ grass/branches/develbranch_6/vector/v.what/Makefile	2009-05-23 17:10:51 UTC (rev 37402)
@@ -12,6 +12,13 @@
+endif
+endif
 default: cmd
Modified: grass/branches/develbranch_6/visualization/nviz/src/Makefile
--- grass/branches/develbranch_6/visualization/nviz/src/Makefile	2009-05-23 16:23:37 UTC (rev 37401)
+++ grass/branches/develbranch_6/visualization/nviz/src/Makefile	2009-05-23 17:10:51 UTC (rev 37402)
@@ -18,7 +18,11 @@
 endif
 OGL_LIBS := $(OPENGLULIB) $(OPENGLLIB) $(MATHLIB)
 endif
+endif
 SURFLIB = $(OGSFLIB)
