[GRASS-SVN] r37652 - in grass/trunk/gui/wxpython: . scripts
Sun May 31 08:47:02 EDT 2009
Author: hamish
Date: 2009-05-31 08:47:02 -0400 (Sun, 31 May 2009)
New Revision: 37652
   grass/trunk/gui/wxpython/scripts/Makefile
   grass/trunk/gui/wxpython/scripts/p.cmd
   grass/trunk/gui/wxpython/scripts/p.db
   grass/trunk/gui/wxpython/scripts/p.mon
   grass/trunk/gui/wxpython/scripts/p.rast
   grass/trunk/gui/wxpython/scripts/p.vect
   grass/trunk/gui/wxpython/wxgui
don't hardcode python.exe, quote shell vars (merge from devbr6)
Modified: grass/trunk/gui/wxpython/scripts/Makefile
--- grass/trunk/gui/wxpython/scripts/Makefile	2009-05-31 12:43:52 UTC (rev 37651)
+++ grass/trunk/gui/wxpython/scripts/Makefile	2009-05-31 12:47:02 UTC (rev 37652)
@@ -7,6 +7,7 @@
 default: install_scripts
 install_scripts:
+	if [ ! -d $(ETC)/gui ] ; then $(MKDIR) $(ETC)/gui ; fi
 	if [ ! -d $(ETCDIR) ] ; then $(MKDIR) $(ETCDIR) ; fi
 	$(MAKE) $(ETCDIR)/d.rast3d
Modified: grass/trunk/gui/wxpython/scripts/p.cmd
--- grass/trunk/gui/wxpython/scripts/p.cmd	2009-05-31 12:43:52 UTC (rev 37651)
+++ grass/trunk/gui/wxpython/scripts/p.cmd	2009-05-31 12:47:02 UTC (rev 37652)
@@ -36,7 +36,7 @@
 if [ -e ${cmdfile} ] && [ -n "${cmdfile}" ]; then
 else
-    g.message -e "GRASS_PYCMDFILE File not found. Run p.mon"
+    g.message -e "GRASS_PYCMDFILE - File not found. Run p.mon"
     exit 1
 fi
@@ -44,6 +44,6 @@
 g.message -d message="$0: ${cmd}"
-echo ${cmd} >> ${cmdfile}
+echo "${cmd}" >> "${cmdfile}"
 exit 0
Modified: grass/trunk/gui/wxpython/scripts/p.db
--- grass/trunk/gui/wxpython/scripts/p.db	2009-05-31 12:43:52 UTC (rev 37651)
+++ grass/trunk/gui/wxpython/scripts/p.db	2009-05-31 12:47:02 UTC (rev 37652)
@@ -23,10 +23,14 @@
 # CODE GOES HERE
-PYTHONPATH="$GISBASE/etc/wxpython"
+if [ -z "$PYTHONPATH" ] ; then
+   PYTHONPATH="$GISBASE/etc/wxpython"
+else
+   PYTHONPATH="$GISBASE/etc/wxpython:$PYTHONPATH"
+fi
 export PYTHONPATH
-python $PYTHONPATH/gui_modules/dbm.py $GIS_OPT_TABLE
+"$GRASS_PYTHON" "$PYTHONPATH/gui_modules/dbm.py" "$GIS_OPT_TABLE"
 exit 0
Modified: grass/trunk/gui/wxpython/scripts/p.mon
--- grass/trunk/gui/wxpython/scripts/p.mon	2009-05-31 12:43:52 UTC (rev 37651)
+++ grass/trunk/gui/wxpython/scripts/p.mon	2009-05-31 12:47:02 UTC (rev 37652)
@@ -64,8 +64,11 @@
 # CODE GOES HERE
+else
+fi
 export PYTHONPATH
 start="$GIS_OPT_START"
@@ -75,10 +78,10 @@
 # create the command file
 command_file="`g.tempfile pid=$$`"
-g.gisenv set=GRASS_PYCMDFILE=${command_file}
+g.gisenv set="GRASS_PYCMDFILE=${command_file}"
 if [ -n "$start" ] ; then
-    python $PYTHONPATH/gui_modules/mapdisp.py "$start" ${command_file} &
+    "$GRASS_PYTHON" "$PYTHONPATH/gui_modules/mapdisp.py" "$start" "${command_file}" &
 fi
 if [[ -n "$stop" || -n "$select" || -n "$unlock" ]] ; then
Modified: grass/trunk/gui/wxpython/scripts/p.rast
--- grass/trunk/gui/wxpython/scripts/p.rast	2009-05-31 12:43:52 UTC (rev 37651)
+++ grass/trunk/gui/wxpython/scripts/p.rast	2009-05-31 12:47:02 UTC (rev 37652)
@@ -58,12 +58,12 @@
     echo -n
 else
     exit 1
 fi
-eval "`echo ${GIS_OPT_MAP}| sed -e 's/^/NAME=/' -e 's/@/; MAPSET=/'`;"
+eval "`echo ${GIS_OPT_MAP} | sed -e 's/^/NAME=/' -e 's/@/; MAPSET=/'`;"
 #echo $NAME
@@ -109,5 +109,5 @@
 cmd="addraster ${name} ${mapset} ${CATLIST} ${VALLIST} ${INVERT} ${OPACITY}"
-#echo ${cmd}
-echo ${cmd} >>${cmdfile}
+#echo "${cmd}"
Modified: grass/trunk/gui/wxpython/scripts/p.vect
--- grass/trunk/gui/wxpython/scripts/p.vect	2009-05-31 12:43:52 UTC (rev 37651)
+++ grass/trunk/gui/wxpython/scripts/p.vect	2009-05-31 12:47:02 UTC (rev 37652)
@@ -282,12 +282,12 @@
     echo -n
 else
-    echo "WARNING: GRASS_PYCMDFILE File not existing. Run p.mon" >&2
+    echo "WARNING: GRASS_PYCMDFILE - File not found. Run p.mon" >&2
     exit 1
 fi
 #echo $NAME
@@ -332,4 +332,4 @@
 #cmd="self.map.AddRasterLayer(self, $NAME $MAPSET $CATLIST $VALLIST $INVERCATS $INVERT $OPACITY)"
 cmd="addvector ${name} ${mapset}"
Modified: grass/trunk/gui/wxpython/wxgui
--- grass/trunk/gui/wxpython/wxgui	2009-05-31 12:43:52 UTC (rev 37651)
+++ grass/trunk/gui/wxpython/wxgui	2009-05-31 12:47:02 UTC (rev 37652)
@@ -16,8 +16,13 @@
     exit 1
 fi
+if [ -z "$GRASS_PYTHON" ] ; then
+    g.message -e "GRASS_PYTHON environment variable not set"
+    exit 1
+fi
 if [ $# -eq 0 ] ; then
-    python "$GISBASE/etc/wxpython/wxgui.py" &
+    "$GRASS_PYTHON" "$GISBASE/etc/wxpython/wxgui.py" &
     exit 0
 fi
@@ -27,9 +32,9 @@
 if test -n "$GIS_OPT_WORKSPACE" ; then
     # load workspace file
-    python "$GISBASE/etc/wxpython/wxgui.py" "--workspace" "$GIS_OPT_WORKSPACE" &
+    "$GRASS_PYTHON" "$GISBASE/etc/wxpython/wxgui.py" "--workspace" "$GIS_OPT_WORKSPACE" &
 else
 fi
 exit 0
