[GRASS-SVN] r39666 - grass/trunk/lib/vector/Vlib
Mon Nov 2 03:21:07 EST 2009
Author: mmetz
Date: 2009-11-02 03:21:05 -0500 (Mon, 02 Nov 2009)
New Revision: 39666
   grass/trunk/lib/vector/Vlib/open.c
disable unused feature
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c	2009-11-02 03:12:19 UTC (rev 39665)
+++ grass/trunk/lib/vector/Vlib/open.c	2009-11-02 08:21:05 UTC (rev 39666)
@@ -519,6 +519,8 @@
     ret = Vect__open_old(Map, name, mapset, NULL, 1, 0);
+    /* the update lists are unused, a waste of time and memory */
     if (ret > 0) {
 	Map->plus.do_uplist = 1;
@@ -528,11 +530,8 @@
 	Map->plus.upnodes = NULL;
 	Map->plus.n_upnodes = 0;
 	Map->plus.alloc_upnodes = 0;
-	/* read spatial index */
-	/* Build spatial index from topo */
-	/* Vect_build_sidx_from_topo(Map); */
     return ret;
@@ -581,7 +580,9 @@
     ret = Vect__open_old(Map, name, mapset, NULL, 1, 1);
-    if (ret > 0) {		/* Probably not important */
+    if (ret > 0) {
 	Map->plus.uplines = NULL;
@@ -591,6 +592,7 @@
     return ret;
