[GRASS-SVN] r39673 - in grass/trunk/gui/wxpython: . xml
Tue Nov 3 07:10:18 EST 2009
Author: martinl
Date: 2009-11-03 07:10:18 -0500 (Tue, 03 Nov 2009)
New Revision: 39673
   grass/trunk/gui/wxpython/wxgui.py
   grass/trunk/gui/wxpython/xml/menudata.xml
quit wxGUI/GRASS
	(merge r39672 from devbr6)
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py	2009-11-03 12:08:39 UTC (rev 39672)
+++ grass/trunk/gui/wxpython/wxgui.py	2009-11-03 12:10:18 UTC (rev 39673)
@@ -27,6 +27,7 @@
 import string
 import getopt
 import platform
+import signal
 ### XML
 try:
@@ -1456,6 +1457,19 @@
                 self.OnAddVector(None)
         event.Skip()
+    def OnQuit(self, event):
+        """!Quit GRASS"""
+        # quit wxGUI session
+        self.OnCloseWindow(event)
+        # quit GRASS shell
+        try:
+            pid = os.environ['GRASS_SHELL_PID']
+        except KeyError:
+            return
+        os.kill(int(pid), signal.SIGQUIT)
     def OnCloseWindow(self, event):
         """!Cleanup when wxGUI is quit"""
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml	2009-11-03 12:08:39 UTC (rev 39672)
+++ grass/trunk/gui/wxpython/xml/menudata.xml	2009-11-03 12:10:18 UTC (rev 39673)
@@ -644,9 +644,14 @@
 	</menuitem>
 	<separator />
 	<menuitem>
-	  <label>E&amp;xit</label>
-	  <help>Quit GUI</help>
+	  <label>Quit GUI</label>
+	  <help>Quit wxGUI session</help>
 	  <handler>self.OnCloseWindow</handler>
+	</menuitem>
+	<menuitem>
+	  <label>Quit GRASS GIS</label>
+	  <help>Quit GRASS session including wxGUI</help>
+	  <handler>self.OnQuit</handler>
 	  <shortcut>Ctrl+Q</shortcut>
 	</menuitem>
       </items>
