[GRASS-SVN] r39731 - in grass/trunk: . include/Make
Sat Nov 14 13:31:05 EST 2009
Author: glynn
Date: 2009-11-14 13:31:05 -0500 (Sat, 14 Nov 2009)
New Revision: 39731
   grass/trunk/aclocal.m4
   grass/trunk/configure
   grass/trunk/configure.in
   grass/trunk/include/Make/Platform.make.in
Re-write SC_CONFIG_CFLAGS to use $host
Modified: grass/trunk/aclocal.m4
--- grass/trunk/aclocal.m4	2009-11-14 12:03:37 UTC (rev 39730)
+++ grass/trunk/aclocal.m4	2009-11-14 18:31:05 UTC (rev 39731)
@@ -451,14 +451,6 @@
 #                       that tell the run-time dynamic linker where to look
 #                       for shared libraries such as libtcl.so.  Depends on
 #                       the variable LIB_RUNTIME_DIR in the Makefile.
-#       MAKE_LIB -      Command to execute to build the a library;
-#                       differs when building shared or static.
-#       MAKE_STUB_LIB -
-#                       Command to execute to build a stub library.
-#       INSTALL_LIB -   Command to execute to install a library;
-#       INSTALL_STUB_LIB -
-#                       Command to execute to install a stub library.
 #       STLIB_LD -      Base command to use for combining object files
 #                       into a static library.
 #       SHLIB_CFLAGS -  Flags to pass to cc when compiling the components
@@ -483,983 +475,96 @@
 #       SHLIB_SUFFIX -  Suffix to use for the names of dynamically loadable
 #                       extensions.  An empty string means we don't know how
 #                       to use shared libraries on this platform.
-# GRASS_SHLIB_LD_EXTRAS - Additional element which are added to SHLIB_LD_LIBS
-#                       for the build of Tcl and Tk, but not recorded in the
-#                       tclConfig.sh, since they are only used for the build
-#                       of Tcl and Tk.
-#                       Examples: MacOS X records the library version and
-#                       compatibility version in the shared library.  But
-#                       of course the Tcl version of this is only used for Tcl.
-#       LIB_SUFFIX -    Specifies everything that comes after the "libfoo"
-#                       in a static or shared library name, using the $LIB_VER variable
-#                       to put the version in the right place.  This is used
-#                       by platforms that need non-standard library names.
-#                       Examples:  ${LIB_VER}.so.1.1 on NetBSD, since it needs
-#                       to have a version after the .so, and ${LIB_VER}.a
-#                       on AIX, since a shared library needs to have
-#                       a .a extension whereas shared objects for loadable
-#                       extensions have a .so extension.  Defaults to
-#                       ${LIB_VER}${SHLIB_SUFFIX}.
-#       GRASS_NEEDS_EXP_FILE -
-#                       1 means that an export file is needed to link to a
-#                       shared library.
-#       GRASS_EXP_FILE -  The name of the installed export / import file which
-#                       should be used to link to the Tcl shared library.
-#                       Empty if Tcl is unshared.
-#       GRASS_BUILD_EXP_FILE -
-#                       The name of the built export / import file which
-#       GRASS_LIBS -
-#                       Libs to use when linking Tcl shell or some other
-#                       shell that includes Tcl libs.
-#	CFLAGS_DEBUG -
-#			Flags used when running the compiler in debug mode
-#	CFLAGS_OPTIMIZE -
-#			Flags used when running the compiler in optimize mode
-#	EXTRA_CFLAGS
 AC_DEFUN([SC_CONFIG_CFLAGS], [
-    # Step 0.a: Enable 64 bit support?
-    AC_MSG_CHECKING([if 64bit support is requested])
-    AC_ARG_ENABLE(64bit,[  --enable-64bit          enable 64bit support (where applicable)],,enableval="no")
-    if test "$enableval" = "yes"; then
-	do64bit=yes
-    else
-	do64bit=no
-    fi
-    AC_MSG_RESULT($do64bit)
-    # Step 0.b: Enable Solaris 64 bit VIS support?
-    AC_MSG_CHECKING([if 64bit Sparc VIS support is requested])
-    AC_ARG_ENABLE(64bit-vis,[  --enable-64bit-vis      enable 64bit Sparc VIS support],,enableval="no")
-	# Force 64bit on with VIS
-	do64bit=yes
-	do64bitVIS=yes
-    else
-	do64bitVIS=no
-    fi
-    AC_MSG_RESULT($do64bitVIS)
-    # Step 1: set the variable "system" to hold the name and version number
-    # for the system.  This can usually be done via the "uname" command, but
-    # there are a few systems, like Next, where this doesn't work.
-    AC_MSG_CHECKING([system version (for dynamic loading)])
-    if test -f /usr/lib/NextStep/software_version; then
-	system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
-    else
-	system=`uname -s`-`uname -r`
-	if test "$?" -ne 0 ; then
-	    AC_MSG_RESULT([unknown (can't find uname command)])
-	    system=unknown
-	else
-	    # Special check for weird MP-RAS system (uname returns weird
-	    # results, and the version is kept in special file).
-	    if test -r /etc/.relid -a "X`uname -n`" = "X`uname -s`" ; then
-		system=MP-RAS-`awk '{print $3}' /etc/.relid`
-	    fi
-	    if test "`uname -s`" = "AIX" ; then
-		system=AIX-`uname -v`.`uname -r`
-	    fi
-	    AC_MSG_RESULT($system)
-	fi
-    fi
-    # Step 2: check for existence of -ldl library.  This is needed because
-    # Linux can use either -ldl or -ldld for dynamic loading.
-    AC_CHECK_LIB(dl, dlopen, have_dl=yes, have_dl=no)
-    # Require ranlib early so we can override it in special cases below.
-    AC_REQUIRE([AC_PROG_RANLIB])
-    # Step 3: set configuration options based on system name and version.
-    do64bit_ok=no
-    EXTRA_CFLAGS=""
-    GRASS_EXPORT_FILE_SUFFIX=""
-    UNSHARED_LIB_SUFFIX=""
-    GRASS_TRIM_DOTS='`echo ${LIB_VER} | tr -d .`'
-    ECHO_VERSION='`echo ${LIB_VER}`'
-    GRASS_LIB_VERSIONS_OK=ok
-    CFLAGS_DEBUG=-g
-    CFLAGS_OPTIMIZE=-O
-    if test "$GCC" = "yes" ; then
-	CFLAGS_WARNING="-Wall -Wconversion -Wno-implicit-int"
-    else
-	CFLAGS_WARNING=""
-    fi
-    GRASS_NEEDS_EXP_FILE=0
-    GRASS_BUILD_EXP_FILE=""
-    GRASS_EXP_FILE=""
-dnl FIXME: Replace AC_CHECK_PROG with AC_CHECK_TOOL once cross compiling is fixed.
-dnl AC_CHECK_TOOL(AR, ar)
-    AC_CHECK_PROG(AR, ar, ar)
-    if test "${AR}" = "" ; then
-	AC_MSG_ERROR([Required archive tool 'ar' not found on PATH.])
-    fi
+    SHLIB_CFLAGS=""
+    SHLIB_LD_FLAGS=""
+    SHLIB_LD_LIBS=""
+    SHLIB_SUFFIX=""
+    SHLIB_LD=""
     STLIB_LD='${AR} cr'
+    STLIB_SUFFIX='.a'
+    LDFLAGS=""
+    CC_SEARCH_FLAGS=""
+    LD_SEARCH_FLAGS=""
     LD_LIBRARY_PATH_VAR="LD_LIBRARY_PATH"
     PLAT_OBJS=""
-    case $system in
-	AIX-5.*)
-	    if test "${GRASS_THREADS}" = "1" -a "$GCC" != "yes" ; then
-		# AIX requires the _r compiler when gcc isn't being used
-		if test "${CC}" != "cc_r" ; then
-		    CC=${CC}_r
-		fi
-		AC_MSG_RESULT(Using $CC for compiling with threads)
-	    fi
-	    LIBS="$LIBS -lc"
-	    # AIX-5 uses ELF style dynamic libraries
-	    SHLIB_CFLAGS=""
-	    # Note: need the LIBS below, otherwise Tk won't find Tcl's
-	    # symbols when dynamically loaded into tclsh.
-	    SHLIB_LD_LIBS='${LIBS}'
-	    SHLIB_SUFFIX=".so"
-	    LDFLAGS=""
-	    LD_LIBRARY_PATH_VAR="LIBPATH"
-	    # Check to enable 64-bit flags for compiler/linker
-	    if test "$do64bit" = "yes" ; then
-		    AC_MSG_WARN("64bit mode not supported with GCC on $system")
-		else
-		    do64bit_ok=yes
-		    EXTRA_CFLAGS="-q64"
-		    LDFLAGS="-q64"
-		    RANLIB="${RANLIB} -X64"
-		    AR="${AR} -X64"
-		    SHLIB_LD_FLAGS="-b64"
-		fi
-	    fi
-	    if test "`uname -m`" = "ia64" ; then
-		# AIX-5 uses ELF style dynamic libraries on IA-64, but not PPC
-		SHLIB_LD="/usr/ccs/bin/ld -G -z text"
-		# AIX-5 has dl* in libc.so
-		    CC_SEARCH_FLAGS='-Wl,-R,${LIB_RUNTIME_DIR}'
-		else
-		    CC_SEARCH_FLAGS='-R${LIB_RUNTIME_DIR}'
-		fi
-		LD_SEARCH_FLAGS='-R ${LIB_RUNTIME_DIR}'
-	    else
-		SHLIB_LD="${SRCDIR}/ldAix /bin/ld -bhalt:4 -bM:SRE -bE:lib.exp -H512 -T512 -bnoentry ${SHLIB_LD_FLAGS}"
-		CC_SEARCH_FLAGS='-L${LIB_RUNTIME_DIR}'
-		LD_SEARCH_FLAGS=${CC_SEARCH_FLAGS}
-		GRASS_NEEDS_EXP_FILE=1
-		GRASS_EXPORT_FILE_SUFFIX='${LIB_VER}.exp'
-	    fi
-	AIX-*)
-		    CC=${CC}_r
-		fi
-	    fi
-	    LIBS="$LIBS -lc"
-	    SHLIB_CFLAGS=""
-	    LDFLAGS=""
-		else
-		    do64bit_ok=yes
-		    LDFLAGS="-q64"
-		    AR="${AR} -X64"
-		fi
-	    fi
-	    # On AIX <=v4 systems, libbsd.a has to be linked in to support
-	    # non-blocking file IO.  This library has to be linked in after
-	    # the MATH_LIBS or it breaks the pow() function.  The way to
-	    # insure proper sequencing, is to add it to the tail of MATH_LIBS.
-	    # This library also supplies gettimeofday.
-	    # AIX does not have a timezone field in struct tm. When the AIX
-	    # bsd library is used, the timezone global and the gettimeofday
-	    # methods are to be avoided for timezone deduction instead, we
-	    # deduce the timezone by comparing the localtime result on a
-	    # known GMT value.
-	    AC_CHECK_LIB(bsd, gettimeofday, libbsd=yes, libbsd=no)
-	    if test $libbsd = yes; then
-	    	MATH_LIBS="$MATH_LIBS -lbsd"
-	    	AC_DEFINE(USE_DELTA_FOR_TZ)
-	    fi
-	BeOS*)
+    case $host in
+        *-linux-*)
 	    SHLIB_CFLAGS="-fPIC"
-	    SHLIB_LD="${CC} -nostart"
+            SHLIB_LD_FLAGS=""
 	    SHLIB_SUFFIX=".so"
-	    LDFLAGS=""
-	    # Check for inet_ntoa in -lbind, for BeOS (which also needs
-	    # -lsocket, even if the network functions are in -lnet which
-	    # is always linked to, for compatibility.
-	    AC_CHECK_LIB(bind, inet_ntoa, [LIBS="$LIBS -lbind -lsocket"])
-	BSD/OS-2.1*|BSD/OS-3*)
-	    SHLIB_CFLAGS=""
-	    SHLIB_LD="shlicc -r"
+	    SHLIB_LD="${CC} -shared"
+            LDFLAGS="-Wl,--export-dynamic"
+            CC_SEARCH_FLAGS='-Wl,-rpath-link,${LIB_RUNTIME_DIR}'
+            LD_SEARCH_FLAGS=${CC_SEARCH_FLAGS}
+            LD_LIBRARY_PATH_VAR="LD_LIBRARY_PATH"
+        *-pc-cygwin)
-	    LDFLAGS=""
-	    CC_SEARCH_FLAGS=""
-	    LD_SEARCH_FLAGS=""
-	BSD/OS-4.*)
-	    SHLIB_CFLAGS="-export-dynamic -fPIC"
-	    SHLIB_LD="cc -shared"
-	    LDFLAGS="-export-dynamic"
-	dgux*)
-	    SHLIB_CFLAGS="-K PIC"
-	    SHLIB_LD="cc -G"
-	    SHLIB_LD_LIBS=""
-	    LDFLAGS=""
-	HP-UX-*.11.*)
-	    # Use updated header definitions where possible
-	    AC_DEFINE(_XOPEN_SOURCE)          # Use the XOPEN network library
-	    AC_DEFINE(_XOPEN_SOURCE_EXTENDED) # Use the XOPEN network library
-	    LIBS="$LIBS -lxnet"               # Use the XOPEN network library
-	    SHLIB_SUFFIX=".sl"
-	    AC_CHECK_LIB(dld, shl_load, shared_ok=yes, shared_ok=no)
-	    if test "$shared_ok" = yes; then
-		SHLIB_CFLAGS="+z"
-		SHLIB_LD="ld -b"
-		LDFLAGS="-Wl,-E"
-		CC_SEARCH_FLAGS='-Wl,+s,+b,${LIB_RUNTIME_DIR}:.'
-		LD_SEARCH_FLAGS='+s +b ${LIB_RUNTIME_DIR}:.'
-		LD_LIBRARY_PATH_VAR="SHLIB_PATH"
-	    fi
-	    # Users may want PA-RISC 1.1/2.0 portable code - needs HP cc
-	    #EXTRA_CFLAGS="+DAportable"
-		    hpux_arch=`gcc -dumpmachine`
-		    case $hpux_arch in
-			hppa64*)
-			    # 64-bit gcc in use.  Fix flags for GNU ld.
-			    do64bit_ok=yes
-			    SHLIB_LD="gcc -shared"
-			    SHLIB_LD_LIBS=""
-			    LD_SEARCH_FLAGS=''
-			    CC_SEARCH_FLAGS=''
-		    esac
-		else
-		    do64bit_ok=yes
-			EXTRA_CFLAGS="+DD64"
-			LDFLAGS="+DD64 $LDFLAGS"
-		    else
-			EXTRA_CFLAGS="+DA2.0W"
-			LDFLAGS="+DA2.0W $LDFLAGS"
-		    fi
-		fi
-	    fi
-	HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
-		SHLIB_CFLAGS="+z"
-		SHLIB_LD="ld -b"
-		SHLIB_LD_LIBS=""
-		LDFLAGS="-Wl,-E"
-	    fi
-	IRIX-4.*)
-	    SHLIB_CFLAGS="-G 0"
-	    SHLIB_SUFFIX=".a"
-	    SHLIB_LD="echo tclLdAout $CC \{$SHLIB_CFLAGS\} | `pwd`/tclsh -r -G 0"
-	    LDFLAGS="-Wl,-D,08000000"
-	    SHARED_LIB_SUFFIX='${LIB_VER}.a'
-	IRIX-5.*)
-	    SHLIB_CFLAGS=""
-	    SHLIB_LD="ld -shared -rdata_shared"
-	    CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
-	    LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-	    EXTRA_CFLAGS=""
-	    LDFLAGS=""
-	IRIX-6.2)
-	    SHLIB_CFLAGS=""
-	IRIX-6.*|IRIX64-6.5*)
-	    SHLIB_CFLAGS=""
-	    SHLIB_LD="ld -n32 -shared -rdata_shared"
-		EXTRA_CFLAGS="-mabi=n32"
-		LDFLAGS="-mabi=n32"
-	    else
-		case $system in
-		    IRIX-6.3)
-			# Use to build 6.2 compatible binaries on 6.3.
-			EXTRA_CFLAGS="-n32 -D_OLD_TERMIOS"
-			EXTRA_CFLAGS="-n32"
-		esac
-		LDFLAGS="-n32"
-	    fi
-	IRIX64-6.*)
-	    SHLIB_CFLAGS=""
-	    LDFLAGS=""
-	            AC_MSG_WARN([64bit mode not supported by gcc])
-	        else
-	            do64bit_ok=yes
-	            SHLIB_LD="ld -64 -shared -rdata_shared"
-	            EXTRA_CFLAGS="-64"
-	            LDFLAGS="-64"
-	        fi
-	    fi
-	Linux*)
-	    SHLIB_CFLAGS="-fPIC"
-	    CFLAGS_OPTIMIZE=-O2
-	    # egcs-2.91.66 on Redhat Linux 6.0 generates lots of warnings
-	    # when you inline the string and math operations.  Turn this off to
-	    # get rid of the warnings.
-	    #CFLAGS_OPTIMIZE="${CFLAGS_OPTIMIZE} -D__NO_STRING_INLINES -D__NO_MATH_INLINES"
-	    if test "$have_dl" = yes; then
-		SHLIB_LD="${CC} -shared"
-		LDFLAGS="-Wl,--export-dynamic"
-		CC_SEARCH_FLAGS='-Wl,-rpath-link,${LIB_RUNTIME_DIR}'
-	    else
-		AC_CHECK_HEADER(dld.h, [
-		    SHLIB_LD="ld -shared"
-		    LDFLAGS=""
-		    LD_SEARCH_FLAGS=""])
-	    fi
-	    if test "`uname -m`" = "alpha" ; then
-		EXTRA_CFLAGS="-mieee"
-	    fi
-	    # The combo of gcc + glibc has a bug related
-	    # to inlining of functions like strtod(). The
-	    # -fno-builtin flag should address this problem
-	    # but it does not work. The -fno-inline flag
-	    # is kind of overkill but it works.
-	    # Disable inlining only when one of the
-	    # files in compat/*.c is being linked in.
-	    if test x"${USE_COMPAT}" != x ; then
-	        EXTRA_CFLAGS="${EXTRA_CFLAGS} -fno-inline"
-	    fi
-	    # XIM peeking works under XFree86.
-	    AC_DEFINE(PEEK_XCLOSEIM)
-	GNU*)
-	    else
-		    LDFLAGS=""
-	    fi
-	    fi
-        CYGWIN*)
-            SHLIB_CFLAGS=""
             SHLIB_SUFFIX=".dll"
 	    LD_LIBRARY_PATH_VAR="PATH"
-        MINGW*)
-            SHLIB_CFLAGS=""
+        *-pc-mingw32)
             SHLIB_SUFFIX=".dll"
             LDFLAGS="-Wl,--export-dynamic,--enable-runtime-pseudo-reloc"
-	MP-RAS-02*)
-	    SHLIB_LD="cc -G"
-	    SHLIB_LD_LIBS=""
-	    LDFLAGS=""
-	MP-RAS-*)
-	    SHLIB_LD="cc -G"
-	    SHLIB_LD_LIBS=""
-	    LDFLAGS="-Wl,-Bexport"
-	NetBSD-*)
-	    # NetBSD has ELF.
-	    SHLIB_LD="ld -Bshareable -x"
-	    SHLIB_LD_LIBS="${LIBS}"
-	    LDFLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR} -export-dynamic'
-	    if test "${GRASS_THREADS}" = "1" ; then
-		# The -pthread needs to go in the CFLAGS, not LIBS
-		LIBS=`echo $LIBS | sed s/-pthread//`
-		EXTRA_CFLAGS="-pthread"
-		LDFLAGS="$LDFLAGS -pthread"
-	    fi
-	    # NetBSD doesn't handle version numbers with dots.
-	    UNSHARED_LIB_SUFFIX='${GRASS_TRIM_DOTS}.a'
-	    SHARED_LIB_SUFFIX='${GRASS_TRIM_DOTS}.so',
-	    GRASS_LIB_VERSIONS_OK=nodots
-	OpenBSD-*)
-	    LDFLAGS=""
-	    AC_MSG_CHECKING(for ELF)
-	    AC_EGREP_CPP(yes, [
-#ifdef __ELF__
-	yes
-#endif
-		[AC_MSG_RESULT(yes)
-		SHARED_LIB_SUFFIX='${GRASS_TRIM_DOTS}.so.1.0'],
-		[AC_MSG_RESULT(no)
-	    # OpenBSD doesn't do version numbers with dots.
-	FreeBSD-[[1-2]].*)
-	    # Not available on all versions:  check for include file.
-	    AC_CHECK_HEADER(dlfcn.h, [
-		SHLIB_LD_LIBS=""
-		LDFLAGS=""
-#ifdef __ELF__
-	yes
-#endif
-		    AC_MSG_RESULT(yes)
-		    AC_MSG_RESULT(no)
-		SHLIB_CFLAGS=""
-		SHLIB_LD="echo tclLdAout $CC \{$SHLIB_CFLAGS\} | `pwd`/tclsh -r"
-		SHLIB_SUFFIX=".a"
-		LDFLAGS=""
-		SHARED_LIB_SUFFIX='${GRASS_TRIM_DOTS}.a'
-	FreeBSD-*)
-	    # FreeBSD 3.* and greater have ELF.
-	    fi
-	    case $system in
-	    FreeBSD-3.*)
-	    	# FreeBSD-3 doesn't handle version numbers with dots.
-	    esac
-	Rhapsody-*|Darwin-*)
+	*-apple-darwin*)
 	    SHLIB_CFLAGS="-fno-common"
-	    SHLIB_LD="cc -dynamiclib -compatibility_version \${GRASS_VERSION_MAJOR}.\${GRASS_VERSION_MINOR} -current_version \${GRASS_VERSION_MAJOR}.\${GRASS_VERSION_MINOR} -install_name \${INST_DIR}/lib/lib\${LIB_NAME}\${SHLIB_SUFFIX}"
-	    GRASS_SHLIB_LD_EXTRAS=""
 	    SHLIB_SUFFIX=".dylib"
-	    PLAT_OBJS=""
-	    CFLAGS_OPTIMIZE="-Os"
+	    SHLIB_LD="cc -dynamiclib -compatibility_version \${GRASS_VERSION_MAJOR}.\${GRASS_VERSION_MINOR} -current_version \${GRASS_VERSION_MAJOR}.\${GRASS_VERSION_MINOR} -install_name \${INST_DIR}/lib/lib\${LIB_NAME}\${SHLIB_SUFFIX}"
 	    LD_LIBRARY_PATH_VAR="DYLD_LIBRARY_PATH"
-	    # for compatibility with autoconf vers 2.13 :
-	    HACK=""
-	    EXTRA_CFLAGS=""
-	    LIBS="$LIBS"
-	NEXTSTEP-*)
-	    SHLIB_CFLAGS=""
-	    SHLIB_LD="cc -nostdlib -r"
-	    SHLIB_LD_LIBS=""
-	    LDFLAGS=""
-	OS/390-*)
-	    CFLAGS_OPTIMIZE=""      # Optimizer is buggy
-	    AC_DEFINE(_OE_SOCKETS)  # needed in sys/socket.h
-	OSF1-1.0|OSF1-1.1|OSF1-1.2)
-	    # OSF/1 1.[012] from OSF, and derivatives, including Paragon OSF/1
-	    SHLIB_CFLAGS=""
-	    # Hack: make package name same as library name
-	    SHLIB_LD='ld -R -export $@:'
-	    SHLIB_LD_LIBS=""
-	    LDFLAGS=""
-	OSF1-1.*)
-	    # OSF/1 1.3 from OSF using ELF, and derivatives, including AD2
-	    if test "$SHARED_BUILD" = "1" ; then
-	    else
-	        SHLIB_LD="ld -non_shared"
-	    fi
-	    SHLIB_LD_LIBS=""
-	    LDFLAGS=""
-	OSF1-V*)
-	    # Digital OSF/1
-	    SHLIB_CFLAGS=""
-	        SHLIB_LD='ld -shared -expect_unresolved "*"'
-	    else
-	        SHLIB_LD='ld -non_shared -expect_unresolved "*"'
-	    fi
-	    SHLIB_LD_LIBS=""
-	    LDFLAGS=""
-            else
-		EXTRA_CFLAGS="-DHAVE_TZSET -std1 -ieee"
-	    fi
-	    # see pthread_intro(3) for pthread support on osf1, k.furukawa
-		EXTRA_CFLAGS="${EXTRA_CFLAGS} -DHAVE_PTHREAD_ATTR_SETSTACKSIZE"
-		EXTRA_CFLAGS="${EXTRA_CFLAGS} -DGRASS_THREAD_STACK_MIN=PTHREAD_STACK_MIN*64"
-		LIBS=`echo $LIBS | sed s/-lpthreads//`
-		    LIBS="$LIBS -lpthread -lmach -lexc"
-		else
-		    EXTRA_CFLAGS="${EXTRA_CFLAGS} -pthread"
-		    LDFLAGS="-pthread"
-		fi
-	    fi
-	QNX-6*)
-	    # QNX RTP
-	    # This may work for all QNX, but it was only reported for v6.
-	    SHLIB_LD_LIBS=""
-	    LDFLAGS=""
-	RISCos-*)
-	    SHLIB_SUFFIX=".a"
-	SCO_SV-3.2*)
-	    # Note, dlopen is available only on SCO 3.2.5 and greater. However,
-	    # this test works, since "uname -s" was non-standard in 3.2.4 and
-	    # below.
-	    	SHLIB_CFLAGS="-fPIC -melf"
-	    	LDFLAGS="-melf -Wl,-Bexport"
-	    else
-	    	SHLIB_CFLAGS="-Kpic -belf"
-	    	LDFLAGS="-belf -Wl,-Bexport"
-	    fi
-	    SHLIB_LD="ld -G"
-	    SHLIB_LD_LIBS=""
-	SINIX*5.4*)
-	    SHLIB_LD="cc -G"
-	    SHLIB_LD_LIBS=""
-	    LDFLAGS=""
-	SunOS-4*)
-	    SHLIB_CFLAGS="-PIC"
-	    SHLIB_LD="ld"
-	    SHLIB_LD_LIBS=""
-	    LDFLAGS=""
-	    # SunOS can't handle version numbers with dots in them in library
-	    # specs, like -ltcl7.5, so use -ltcl75 instead.  Also, it
-	    # requires an extra version number at the end of .so file names.
-	    # So, the library has to have a name like libtcl75.so.1.0
-	SunOS-5.[[0-6]].*)
+	*-sun-solaris*)
 	    # Note: If _REENTRANT isn't defined, then Solaris
 	    # won't define thread-safe library routines.
 	    AC_DEFINE(_REENTRANT)
 	    AC_DEFINE(_POSIX_PTHREAD_SEMANTICS)
-	    LDFLAGS=""
-		SHLIB_LD="$CC -shared"
-	    else
-		SHLIB_CFLAGS="-KPIC"
-		CC_SEARCH_FLAGS='-R ${LIB_RUNTIME_DIR}'
-	    fi
+            if test "$GCC" = "yes" ; then
+                SHLIB_CFLAGS="-fPIC"
+                SHLIB_LD="$CC -shared"
+                CC_SEARCH_FLAGS='-Wl,-R,${LIB_RUNTIME_DIR}'
+            else
+                SHLIB_CFLAGS="-KPIC"
+                SHLIB_LD="/usr/ccs/bin/ld -G -z text"
+                CC_SEARCH_FLAGS='-R ${LIB_RUNTIME_DIR}'
+            fi
+            SHLIB_SUFFIX=".so"
+            SHLIB_LD_LIBS='${LIBS}'
-	SunOS-5*)
-	    # Note: If _REENTRANT isn't defined, then Solaris
-	    # won't define thread-safe library routines.
-	    AC_DEFINE(_REENTRANT)
-	    AC_DEFINE(_POSIX_PTHREAD_SEMANTICS)
-	    LDFLAGS=""
-		arch=`isainfo`
-		if test "$arch" = "sparcv9 sparc" ; then
-			else
-			    do64bit_ok=yes
-			    if test "$do64bitVIS" = "yes" ; then
-				EXTRA_CFLAGS="-xarch=v9a"
-			    	LDFLAGS="-xarch=v9a"
-			    else
-				EXTRA_CFLAGS="-xarch=v9"
-			    	LDFLAGS="-xarch=v9"
-			    fi
-			fi
-		else
-		    AC_MSG_WARN("64bit mode only supported sparcv9 system")
-		fi
-	    fi
-	    else
-		SHLIB_LD="CC -G -z text"
-	    fi
-	ULTRIX-4.*)
-	    SHLIB_SUFFIX=".a"
-	    if test "$GCC" != "yes" ; then
-		EXTRA_CFLAGS="-DHAVE_TZSET -std1"
-	    fi
-	UNIX_SV* | UnixWare-5*)
-	    SHLIB_LD="cc -G"
-	    SHLIB_LD_LIBS=""
-	    # Some UNIX_SV* systems (unixware 1.1.2 for example) have linkers
-	    # that don't grok the -Bexport option.  Test that it does.
-	    hold_ldflags=$LDFLAGS
-	    AC_MSG_CHECKING(for ld accepts -Bexport flag)
-	    LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-	    AC_TRY_LINK(, [int i;], found=yes, found=no)
-	    LDFLAGS=$hold_ldflags
-	    AC_MSG_RESULT($found)
-	    if test $found = yes; then
-	    else
-	    LDFLAGS=""
-	    fi
+            AC_MSG_ERROR([***Unknown platform: $host***])
     esac
-    # If we're running gcc, then change the C flags for compiling shared
-    # libraries to the right flags for gcc, instead of those for the
-    # standard manufacturer compiler.
-	    case $system in
-		AIX-*)
-		BSD/OS*)
-		NetBSD-*|FreeBSD-*)
-		RISCos-*)
-		SCO_SV-3.2*)
-		ULTRIX-4.*)
-	    esac
-	fi
-    if test "$SHARED_LIB_SUFFIX" = "" ; then
-	SHARED_LIB_SUFFIX='${LIB_VER}${SHLIB_SUFFIX}'
-    fi
-    if test "$UNSHARED_LIB_SUFFIX" = "" ; then
-	UNSHARED_LIB_SUFFIX='${LIB_VER}.a'
-    fi
-    if test "${SHARED_BUILD}" = "1" && test "${SHLIB_SUFFIX}" != "" ; then
-        LIB_SUFFIX=${SHARED_LIB_SUFFIX}
-        MAKE_LIB='${SHLIB_LD} -o [$]@ ${SHLIB_LD_FLAGS} ${OBJS} ${SHLIB_LD_LIBS} ${GRASS_SHLIB_LD_EXTRAS} ${LD_SEARCH_FLAGS}'
-        INSTALL_LIB='$(INSTALL_LIBRARY) $(LIB_FILE) $(LIB_INSTALL_DIR)/$(LIB_FILE)'
-    else
-        LIB_SUFFIX=${UNSHARED_LIB_SUFFIX}
-        if test "$RANLIB" = "" ; then
-            MAKE_LIB='$(STLIB_LD) [$]@ ${OBJS}'
-        else
-            MAKE_LIB='${STLIB_LD} [$]@ ${OBJS} ; ${RANLIB} [$]@'
-            INSTALL_LIB='$(INSTALL_LIBRARY) $(LIB_FILE) $(LIB_INSTALL_DIR)/$(LIB_FILE) ; (cd $(LIB_INSTALL_DIR) ; $(RANLIB) $(LIB_FILE))'
-        fi
-dnl        Not at all clear what this was doing in Tcl's configure.in
-dnl        or why it was needed was needed. In any event, this sort of
-dnl        things needs to be done in the big loop above.
-dnl        REMOVE THIS BLOCK LATER! (mdejong)
-dnl        case $system in
-dnl            BSD/OS*)
-dnl                ;;
-dnl            AIX-[[1-4]].*)
-dnl                ;;
-dnl            *)
-dnl                SHLIB_LD_LIBS=""
-dnl                ;;
-dnl        esac
-    fi
-    # Stub lib does not depend on shared/static configuration
-        MAKE_STUB_LIB='${STLIB_LD} [$]@ ${STUB_LIB_OBJS}'
-        INSTALL_STUB_LIB='$(INSTALL_LIBRARY) $(STUB_LIB_FILE) $(LIB_INSTALL_DIR)/$(STUB_LIB_FILE)'
-    else
-        MAKE_STUB_LIB='${STLIB_LD} [$]@ ${STUB_LIB_OBJS} ; ${RANLIB} [$]@'
-        INSTALL_STUB_LIB='$(INSTALL_LIBRARY) $(STUB_LIB_FILE) $(LIB_INSTALL_DIR)/$(STUB_LIB_FILE) ; (cd $(LIB_INSTALL_DIR) ; $(RANLIB) $(STUB_LIB_FILE))'
-    fi
     AC_SUBST(PLAT_OBJS)
-    AC_SUBST(CFLAGS)
-    AC_SUBST(CFLAGS_DEBUG)
-    AC_SUBST(CFLAGS_OPTIMIZE)
-    AC_SUBST(CFLAGS_WARNING)
-    AC_SUBST(EXTRA_CFLAGS)
     AC_SUBST(LDFLAGS)
-    AC_SUBST(LDFLAGS_DEBUG)
-    AC_SUBST(LDFLAGS_OPTIMIZE)
     AC_SUBST(CC_SEARCH_FLAGS)
     AC_SUBST(LD_SEARCH_FLAGS)
     AC_SUBST(LD_LIBRARY_PATH_VAR)
-    AC_SUBST(STLIB_LD)
     AC_SUBST(SHLIB_LD)
-    AC_SUBST(GRASS_SHLIB_LD_EXTRAS)
     AC_SUBST(SHLIB_LD_FLAGS)
     AC_SUBST(SHLIB_LD_LIBS)
     AC_SUBST(SHLIB_CFLAGS)
     AC_SUBST(SHLIB_SUFFIX)
-    AC_SUBST(MAKE_LIB)
-    AC_SUBST(MAKE_STUB_LIB)
-    AC_SUBST(INSTALL_LIB)
-    AC_SUBST(INSTALL_STUB_LIB)
-    AC_SUBST(RANLIB)
+    AC_SUBST(STLIB_LD)
+    AC_SUBST(STLIB_SUFFIX)
Modified: grass/trunk/configure
--- grass/trunk/configure	2009-11-14 12:03:37 UTC (rev 39730)
+++ grass/trunk/configure	2009-11-14 18:31:05 UTC (rev 39731)
@@ -17,10 +17,6 @@
 ac_help="$ac_help
   --enable-shared         build and link with shared libraries [--enable-shared]"
 ac_help="$ac_help
-  --enable-64bit          enable 64bit support (where applicable)"
-ac_help="$ac_help
-  --enable-64bit-vis      enable 64bit Sparc VIS support"
-ac_help="$ac_help
   --enable-w11            use W11 library for Windows X11 emulation"
 ac_help="$ac_help
   --with-cxx              support C++ functionality (default: no)"
@@ -750,7 +746,7 @@
 fi
 echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:754: checking host system type" >&5
+echo "configure:750: checking host system type" >&5
 host_alias=$host
 case "$host_alias" in
@@ -773,7 +769,7 @@
 # Extract the first word of "gcc", so it can be a program name with args.
 set dummy gcc; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:777: checking for $ac_word" >&5
+echo "configure:773: checking for $ac_word" >&5
 if test -n "$CC"; then
   ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -800,7 +796,7 @@
   # Extract the first word of "cc", so it can be a program name with args.
 set dummy cc; ac_word=$2
-echo "configure:804: checking for $ac_word" >&5
+echo "configure:800: checking for $ac_word" >&5
@@ -848,7 +844,7 @@
       # Extract the first word of "cl", so it can be a program name with args.
 set dummy cl; ac_word=$2
-echo "configure:852: checking for $ac_word" >&5
+echo "configure:848: checking for $ac_word" >&5
@@ -877,7 +873,7 @@
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:881: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:877: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
 ac_ext=c
 # CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -888,12 +884,12 @@
 cat > conftest.$ac_ext << EOF
-#line 892 "configure"
+#line 888 "configure"
 #include "confdefs.h"
 main(){return(0);}
 EOF
-if { (eval echo configure:897: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:893: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cc_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -919,19 +915,19 @@
   { echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:923: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:919: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
 cross_compiling=$ac_cv_prog_cc_cross
 echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:928: checking whether we are using GNU C" >&5
+echo "configure:924: checking whether we are using GNU C" >&5
 cat > conftest.c <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:935: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:931: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gcc=yes
 else
   ac_cv_prog_gcc=no
@@ -949,7 +945,7 @@
 ac_save_CFLAGS="$CFLAGS"
 CFLAGS=
 echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:953: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:949: checking whether ${CC-cc} accepts -g" >&5
 echo 'void f(){}' > conftest.c
 if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -978,10 +974,10 @@
 fi
 echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:982: checking for Cygwin environment" >&5
+echo "configure:978: checking for Cygwin environment" >&5
 cat > conftest.$ac_ext <<EOF
-#line 985 "configure"
+#line 981 "configure"
 int main() {
@@ -992,7 +988,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:996: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:992: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -1008,17 +1004,17 @@
 CYGWIN=
 test "$ac_cv_cygwin" = yes && CYGWIN=yes
 echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:1012: checking for mingw32 environment" >&5
+echo "configure:1008: checking for mingw32 environment" >&5
-#line 1015 "configure"
+#line 1011 "configure"
 int main() {
 return __MINGW32__;
 ; return 0; }
 EOF
-if { (eval echo configure:1022: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1018: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_mingw32=yes
 else
@@ -1036,7 +1032,7 @@
 echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1040: checking for executable suffix" >&5
+echo "configure:1036: checking for executable suffix" >&5
 if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
   ac_cv_exeext=.exe
@@ -1055,23 +1051,23 @@
 IEEEFLAG=
 echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1059: checking for full floating-point support" >&5
+echo "configure:1055: checking for full floating-point support" >&5
 if test "$cross_compiling" = yes; then
      echo "$ac_t""unknown (cross-compiling)" 1>&6
 echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1064: checking whether "cc -mieee" works" >&5
+echo "configure:1060: checking whether "cc -mieee" works" >&5
 ac_save_cflags=${CFLAGS}
 CFLAGS="$CFLAGS -mieee"
-#line 1068 "configure"
+#line 1064 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:1075: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1071: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
      echo "$ac_t""yes" 1>&6
         IEEEFLAG="-mieee"
@@ -1087,7 +1083,7 @@
 else
-#line 1091 "configure"
+#line 1087 "configure"
 #include <float.h>
@@ -1101,7 +1097,7 @@
 EOF
-if { (eval echo configure:1105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1101: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
@@ -1114,14 +1110,14 @@
   CFLAGS=-mieee
 echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1118: checking for full floating-point support with -mieee" >&5
+echo "configure:1114: checking for full floating-point support with -mieee" >&5
     { echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
 else
-#line 1125 "configure"
+#line 1121 "configure"
 #include <float.h>
@@ -1135,7 +1131,7 @@
 EOF
-if { (eval echo configure:1139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1135: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
     IEEEFLAG="-mieee"
@@ -1172,7 +1168,7 @@
 # Extract the first word of "pwd", so it can be a program name with args.
 set dummy pwd; ac_word=$2
-echo "configure:1176: checking for $ac_word" >&5
+echo "configure:1172: checking for $ac_word" >&5
 case "$pwd" in
@@ -1210,7 +1206,7 @@
 fi
 echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1214: checking for source directory" >&5
+echo "configure:1210: checking for source directory" >&5
 if test -z "$srcdir" ; then
   SRCDIR=`$pwd`
@@ -1221,7 +1217,7 @@
 echo "$ac_t"""$SRCDIR"" 1>&6
 echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1225: checking for build directory" >&5
+echo "configure:1221: checking for build directory" >&5
 DSTDIR=`$pwd`
 WINDSTDIR=`$winpwd`
@@ -1289,7 +1285,7 @@
 # Extract the first word of "svnversion", so it can be a program name with args.
 set dummy svnversion; ac_word=$2
-echo "configure:1293: checking for $ac_word" >&5
+echo "configure:1289: checking for $ac_word" >&5
 case "$SVN_VERSION" in
@@ -1345,7 +1341,7 @@
 echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1349: checking for MacOSX App" >&5
+echo "configure:1345: checking for MacOSX App" >&5
 case "$enable_macosx_app" in
 	yes)	MACOSX_APP=1	;;
 	no)	MACOSX_APP=	;;
@@ -1357,7 +1353,7 @@
 # Check for MacOSX archs
 echo $ac_n "checking for MacOSX architectures""... $ac_c" 1>&6
-echo "configure:1361: checking for MacOSX architectures" >&5
+echo "configure:1357: checking for MacOSX architectures" >&5
 MACOSX_ARCHS=
@@ -1386,7 +1382,7 @@
 # Check for MacOSX SDK
 echo $ac_n "checking for MacOSX SDK""... $ac_c" 1>&6
-echo "configure:1390: checking for MacOSX SDK" >&5
+echo "configure:1386: checking for MacOSX SDK" >&5
 MACOSX_SDK=
@@ -1396,7 +1392,7 @@
 ac_safe=`echo "$with_macosx_sdk/SDKSettings.plist" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $with_macosx_sdk/SDKSettings.plist""... $ac_c" 1>&6
-echo "configure:1400: checking for $with_macosx_sdk/SDKSettings.plist" >&5
+echo "configure:1396: checking for $with_macosx_sdk/SDKSettings.plist" >&5
     { echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -1440,7 +1436,7 @@
     echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1444: checking how to build libraries" >&5
+echo "configure:1440: checking how to build libraries" >&5
     # Check whether --enable-shared or --disable-shared was given.
 if test "${enable_shared+set}" = set; then
   enableval="$enable_shared"
@@ -1480,1195 +1476,56 @@
 ac_save_ldflags="$LDFLAGS"
-# Extract the first word of "ranlib", so it can be a program name with args.
-set dummy ranlib; ac_word=$2
-echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:1487: checking for $ac_word" >&5
-if test -n "$RANLIB"; then
-  ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
-else
-  IFS="${IFS= 	}"; ac_save_ifs="$IFS"; IFS=":"
-  ac_dummy="$PATH"
-  for ac_dir in $ac_dummy; do
-    test -z "$ac_dir" && ac_dir=.
-    if test -f $ac_dir/$ac_word; then
-      ac_cv_prog_RANLIB="ranlib"
-      break
-    fi
-  done
-  IFS="$ac_save_ifs"
-  test -z "$ac_cv_prog_RANLIB" && ac_cv_prog_RANLIB=":"
-fi
-RANLIB="$ac_cv_prog_RANLIB"
-  echo "$ac_t""$RANLIB" 1>&6
-else
-  echo "$ac_t""no" 1>&6
-fi
-echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1512: checking how to run the C preprocessor" >&5
-# On Suns, sometimes $CPP names a directory.
-if test -n "$CPP" && test -d "$CPP"; then
-  CPP=
-fi
-if test -z "$CPP"; then
-  # This must be in double quotes, not single quotes, because CPP may get
-  # substituted into the Makefile and "${CC-cc}" will confuse make.
-  CPP="${CC-cc} -E"
-  # On the NeXT, cc -E runs the code through the compiler's parser,
-  # not just through cpp.
-  cat > conftest.$ac_ext <<EOF
-#line 1525 "configure"
-#include "confdefs.h"
-#include <assert.h>
-Syntax Error
-EOF
-ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1531: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
-ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
-if test -z "$ac_err"; then
-else
-  echo "$ac_err" >&5
-  echo "configure: failed program was:" >&5
-  cat conftest.$ac_ext >&5
-  rm -rf conftest*
-  CPP="${CC-cc} -E -traditional-cpp"
-#line 1542 "configure"
-Syntax Error
-EOF
-{ (eval echo configure:1548: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
-else
-  rm -rf conftest*
-  CPP="${CC-cc} -nologo -E"
-#line 1559 "configure"
-Syntax Error
-EOF
-{ (eval echo configure:1565: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
-else
-  rm -rf conftest*
-  CPP=/lib/cpp
-fi
-rm -f conftest*
-fi
-rm -f conftest*
-fi
-rm -f conftest*
-  ac_cv_prog_CPP="$CPP"
-  CPP="$ac_cv_prog_CPP"
-else
-fi
-echo "$ac_t""$CPP" 1>&6
-    echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1593: checking if 64bit support is requested" >&5
-    # Check whether --enable-64bit or --disable-64bit was given.
-if test "${enable_64bit+set}" = set; then
-  enableval="$enable_64bit"
-else
-  enableval="no"
-fi
-	do64bit=yes
-    else
-	do64bit=no
-    fi
-    echo "$ac_t""$do64bit" 1>&6
-    echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1613: checking if 64bit Sparc VIS support is requested" >&5
-    # Check whether --enable-64bit-vis or --disable-64bit-vis was given.
-if test "${enable_64bit_vis+set}" = set; then
-  enableval="$enable_64bit_vis"
-else
-  enableval="no"
-fi
-	do64bit=yes
-	do64bitVIS=yes
-    else
-	do64bitVIS=no
-    fi
-    echo "$ac_t""$do64bitVIS" 1>&6
-    echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1637: checking system version (for dynamic loading)" >&5
-    else
-	    echo "$ac_t""unknown (can't find uname command)" 1>&6
-	    system=unknown
-	else
-		system=MP-RAS-`awk '{print }' /etc/.relid`
-	    fi
-	    fi
-	    echo "$ac_t""$system" 1>&6
-	fi
-    fi
-    echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1663: checking for dlopen in -ldl" >&5
-ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
-ac_save_LIBS="$LIBS"
-LIBS="-ldl  $LIBS"
-cat > conftest.$ac_ext <<EOF
-#line 1669 "configure"
-/* Override any gcc2 internal prototype to avoid an error.  */
-/* We use char because int might match the return type of a gcc2
-    builtin and then its argument prototype would still apply.  */
-char dlopen();
-int main() {
-dlopen()
-; return 0; }
-EOF
-if { (eval echo configure:1680: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-  eval "ac_cv_lib_$ac_lib_var=yes"
-else
-  rm -rf conftest*
-  eval "ac_cv_lib_$ac_lib_var=no"
-fi
-rm -f conftest*
-LIBS="$ac_save_LIBS"
-if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
-  echo "$ac_t""yes" 1>&6
-  have_dl=yes
-else
-have_dl=no
-fi
-    do64bit_ok=no
-    EXTRA_CFLAGS=""
-    CFLAGS_DEBUG=-g
-    else
-	CFLAGS_WARNING=""
-    fi
-    GRASS_EXP_FILE=""
-    # Extract the first word of "ar", so it can be a program name with args.
-set dummy ar; ac_word=$2
-echo "configure:1727: checking for $ac_word" >&5
-if test -n "$AR"; then
-  ac_cv_prog_AR="$AR" # Let the user override the test.
-else
-  ac_dummy="$PATH"
-      ac_cv_prog_AR="ar"
-      break
-    fi
-  done
-fi
-AR="$ac_cv_prog_AR"
-  echo "$ac_t""$AR" 1>&6
-else
-fi
-	{ echo "configure: error: Required archive tool 'ar' not found on PATH." 1>&2; exit 1; }
-    fi
+    SHLIB_CFLAGS=""
+    SHLIB_LD_FLAGS=""
+    SHLIB_LD_LIBS=""
+    SHLIB_SUFFIX=""
+    SHLIB_LD=""
     STLIB_LD='${AR} cr'
+    STLIB_SUFFIX='.a'
+    LDFLAGS=""
     PLAT_OBJS=""
-    case $system in
-	AIX-5.*)
-		    CC=${CC}_r
-		fi
-		echo "$ac_t""Using $CC for compiling with threads" 1>&6
-	    fi
-	    LIBS="$LIBS -lc"
-	    SHLIB_CFLAGS=""
-	    LDFLAGS=""
-		    echo "configure: warning: "64bit mode not supported with GCC on $system"" 1>&2
-		else
-		    do64bit_ok=yes
-		    LDFLAGS="-q64"
-		    AR="${AR} -X64"
-		fi
-	    fi
-		else
-		fi
-	    else
-	    fi
-	AIX-*)
-		    CC=${CC}_r
-		fi
-	    fi
-	    LIBS="$LIBS -lc"
-	    SHLIB_CFLAGS=""
-	    LDFLAGS=""
-		else
-		    do64bit_ok=yes
-		    LDFLAGS="-q64"
-		    AR="${AR} -X64"
-		fi
-	    fi
-	    echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1856: checking for gettimeofday in -lbsd" >&5
-ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
-LIBS="-lbsd  $LIBS"
-#line 1862 "configure"
-char gettimeofday();
-int main() {
-gettimeofday()
-; return 0; }
-EOF
-if { (eval echo configure:1873: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  libbsd=yes
-else
-libbsd=no
-fi
-	    	cat >> confdefs.h <<\EOF
-#define USE_DELTA_FOR_TZ 1
-EOF
-	    fi
-	BeOS*)
+    case $host in
+        *-linux-*)
+            SHLIB_LD_FLAGS=""
 	    SHLIB_SUFFIX=".so"
-	    LDFLAGS=""
-	    echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1914: checking for inet_ntoa in -lbind" >&5
-ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
-LIBS="-lbind  $LIBS"
-#line 1920 "configure"
-char inet_ntoa();
-int main() {
-inet_ntoa()
-; return 0; }
-EOF
-if { (eval echo configure:1931: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  LIBS="$LIBS -lbind -lsocket"
-else
-fi
-	    SHLIB_CFLAGS=""
+        *-pc-cygwin)
-	    LDFLAGS=""
-	BSD/OS-4.*)
-	dgux*)
-	    SHLIB_LD="cc -G"
-	    SHLIB_LD_LIBS=""
-	    LDFLAGS=""
-	HP-UX-*.11.*)
-#define _XOPEN_SOURCE 1
-EOF
-          # Use the XOPEN network library
-#define _XOPEN_SOURCE_EXTENDED 1
-EOF
-	    echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1992: checking for shl_load in -ldld" >&5
-ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
-LIBS="-ldld  $LIBS"
-#line 1998 "configure"
-char shl_load();
-int main() {
-shl_load()
-; return 0; }
-EOF
-if { (eval echo configure:2009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  shared_ok=yes
-else
-shared_ok=no
-fi
-		SHLIB_CFLAGS="+z"
-		SHLIB_LD="ld -b"
-		LDFLAGS="-Wl,-E"
-	    fi
-			hppa64*)
-			    do64bit_ok=yes
-			    SHLIB_LD_LIBS=""
-		    esac
-		else
-		    do64bit_ok=yes
-		    else
-		    fi
-		fi
-	    fi
-echo "configure:2074: checking for shl_load in -ldld" >&5
-LIBS="-ldld  $LIBS"
-#line 2080 "configure"
-char shl_load();
-int main() {
-shl_load()
-; return 0; }
-EOF
-if { (eval echo configure:2091: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  shared_ok=yes
-else
-shared_ok=no
-fi
-		SHLIB_CFLAGS="+z"
-		SHLIB_LD="ld -b"
-		SHLIB_LD_LIBS=""
-		LDFLAGS="-Wl,-E"
-	    fi
-	IRIX-4.*)
-	    SHLIB_SUFFIX=".a"
-	IRIX-5.*)
-	    SHLIB_CFLAGS=""
-	    EXTRA_CFLAGS=""
-	    LDFLAGS=""
-	IRIX-6.2)
-	    SHLIB_CFLAGS=""
-	    SHLIB_CFLAGS=""
-	    else
-		case $system in
-		    IRIX-6.3)
-		esac
-		LDFLAGS="-n32"
-	    fi
-	IRIX64-6.*)
-	    SHLIB_CFLAGS=""
-	    LDFLAGS=""
-	            echo "configure: warning: 64bit mode not supported by gcc" 1>&2
-	        else
-	            do64bit_ok=yes
-	            LDFLAGS="-64"
-	        fi
-	    fi
-	Linux*)
-	    else
-		ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
-echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2213: checking for dld.h" >&5
-#line 2216 "configure"
-#include <dld.h>
-EOF
-{ (eval echo configure:2221: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
-  rm -rf conftest*
-  eval "ac_cv_header_$ac_safe=yes"
-else
-  rm -rf conftest*
-  eval "ac_cv_header_$ac_safe=no"
-fi
-rm -f conftest*
-if eval "test \"`echo '$ac_cv_header_'$ac_safe`\" = yes"; then
-		    LDFLAGS=""
-else
-fi
-	    fi
-	    fi
-	    fi
-#define PEEK_XCLOSEIM 1
-EOF
-	GNU*)
-	    else
-echo "configure:2281: checking for dld.h" >&5
-#line 2284 "configure"
-#include <dld.h>
-EOF
-{ (eval echo configure:2289: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-		    LDFLAGS=""
-else
-fi
-	    fi
-	    fi
-        CYGWIN*)
-            SHLIB_CFLAGS=""
             SHLIB_SUFFIX=".dll"
-        MINGW*)
-            SHLIB_CFLAGS=""
+        *-pc-mingw32)
             SHLIB_SUFFIX=".dll"
-	MP-RAS-02*)
-	    SHLIB_LD="cc -G"
-	    SHLIB_LD_LIBS=""
-	    LDFLAGS=""
-	MP-RAS-*)
-	    SHLIB_LD="cc -G"
-	    SHLIB_LD_LIBS=""
-	NetBSD-*)
-	    # NetBSD has ELF.
-	    fi
-	OpenBSD-*)
-	    LDFLAGS=""
-	    echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2386: checking for ELF" >&5
-#line 2388 "configure"
-#ifdef __ELF__
-	yes
-#endif
-EOF
-if (eval "$ac_cpp conftest.$ac_ext") 2>&5 |
-  egrep "yes" >/dev/null 2>&1; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-	FreeBSD-[1-2].*)
-	    ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
-echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2418: checking for dlfcn.h" >&5
-#line 2421 "configure"
-#include <dlfcn.h>
-EOF
-{ (eval echo configure:2426: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-		SHLIB_LD_LIBS=""
-		LDFLAGS=""
-echo "configure:2450: checking for ELF" >&5
-#line 2452 "configure"
-#ifdef __ELF__
-	yes
-#endif
-EOF
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-else
-		SHLIB_CFLAGS=""
-		SHLIB_SUFFIX=".a"
-		LDFLAGS=""
-fi
-	FreeBSD-*)
-	    fi
-	    case $system in
-	    FreeBSD-3.*)
-	    esac
+	*-apple-darwin*)
-	    PLAT_OBJS=""
-	    HACK=""
-	    EXTRA_CFLAGS=""
-	    LIBS="$LIBS"
-	NEXTSTEP-*)
-	    SHLIB_CFLAGS=""
-	    SHLIB_LD_LIBS=""
-	    LDFLAGS=""
-	OS/390-*)
-#define _OE_SOCKETS 1
-EOF
-  # needed in sys/socket.h
-	    SHLIB_CFLAGS=""
-	    SHLIB_LD='ld -R -export :'
-	    SHLIB_LD_LIBS=""
-	    LDFLAGS=""
-	OSF1-1.*)
-	    else
-	    fi
-	    SHLIB_LD_LIBS=""
-	    LDFLAGS=""
-	OSF1-V*)
-	    # Digital OSF/1
-	    SHLIB_CFLAGS=""
-	    else
-	    fi
-	    SHLIB_LD_LIBS=""
-	    LDFLAGS=""
-            else
-	    fi
-		else
-		fi
-	    fi
-	QNX-6*)
-	    # QNX RTP
-	    SHLIB_LD_LIBS=""
-	    LDFLAGS=""
-	RISCos-*)
-	    SHLIB_SUFFIX=".a"
-	SCO_SV-3.2*)
-	    # below.
-	    else
-	    fi
-	    SHLIB_LD="ld -G"
-	    SHLIB_LD_LIBS=""
-	SINIX*5.4*)
-	    SHLIB_LD="cc -G"
-	    SHLIB_LD_LIBS=""
-	    LDFLAGS=""
-	SunOS-4*)
-	    SHLIB_LD="ld"
-	    SHLIB_LD_LIBS=""
-	    LDFLAGS=""
-	SunOS-5.[0-6].*)
+	*-sun-solaris*)
 #define _REENTRANT 1
 EOF
@@ -2677,223 +1534,42 @@
 #define _POSIX_PTHREAD_SEMANTICS 1
 EOF
-	    LDFLAGS=""
-	    else
-	    fi
+            else
+            fi
-	SunOS-5*)
-#define _REENTRANT 1
-EOF
-#define _POSIX_PTHREAD_SEMANTICS 1
-EOF
-	    LDFLAGS=""
-		arch=`isainfo`
-			else
-			    do64bit_ok=yes
-			    else
-			    fi
-			fi
-		else
-		    echo "configure: warning: "64bit mode only supported sparcv9 system"" 1>&2
-		fi
-	    fi
-	    else
-	    fi
-	ULTRIX-4.*)
-	    SHLIB_SUFFIX=".a"
-	    fi
-	    SHLIB_LD="cc -G"
-	    SHLIB_LD_LIBS=""
-	    echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2776: checking for ld accepts -Bexport flag" >&5
-#line 2779 "configure"
-int main() {
-int i;
-; return 0; }
-EOF
-if { (eval echo configure:2786: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-  found=yes
-else
-  rm -rf conftest*
-  found=no
-fi
-rm -f conftest*
-	    echo "$ac_t""$found" 1>&6
-	    else
-	    LDFLAGS=""
-	    fi
+            { echo "configure: error: ***Unknown platform: $host***" 1>&2; exit 1; }
     esac
-	    case $system in
-		AIX-*)
-		BSD/OS*)
-		RISCos-*)
-		SCO_SV-3.2*)
-		ULTRIX-4.*)
-	    esac
-	fi
-    fi
-    fi
-        MAKE_LIB='${SHLIB_LD} -o $@ ${SHLIB_LD_FLAGS} ${OBJS} ${SHLIB_LD_LIBS} ${GRASS_SHLIB_LD_EXTRAS} ${LD_SEARCH_FLAGS}'
-    else
-            MAKE_LIB='$(STLIB_LD) $@ ${OBJS}'
-        else
-            MAKE_LIB='${STLIB_LD} $@ ${OBJS} ; ${RANLIB} $@'
-        fi
-    fi
-        MAKE_STUB_LIB='${STLIB_LD} $@ ${STUB_LIB_OBJS}'
-    else
-        MAKE_STUB_LIB='${STLIB_LD} $@ ${STUB_LIB_OBJS} ; ${RANLIB} $@'
-    fi
 LDFLAGS="${ac_save_ldflags} $LDFLAGS"
 # Enable options
@@ -3578,7 +2254,7 @@
 # Done checking fortran
 echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3582: checking for additional include dirs" >&5
+echo "configure:2258: checking for additional include dirs" >&5
 case "$with_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3601,7 +2277,7 @@
 # With libs option
 echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3605: checking for additional library dirs" >&5
+echo "configure:2281: checking for additional library dirs" >&5
 case "$with_libs" in
 	{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3635,7 +2311,7 @@
 # SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
 # ./install, which can be erroneously created by make from ./install.sh.
 echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3639: checking for a BSD compatible install" >&5
+echo "configure:2315: checking for a BSD compatible install" >&5
 if test -z "$INSTALL"; then
   IFS="${IFS= 	}"; ac_save_IFS="$IFS"; IFS=":"
@@ -3688,7 +2364,7 @@
 # Extract the first word of "flex", so it can be a program name with args.
 set dummy flex; ac_word=$2
-echo "configure:3692: checking for $ac_word" >&5
+echo "configure:2368: checking for $ac_word" >&5
 if test -n "$LEX"; then
   ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3719,13 +2395,13 @@
   *) ac_lib=l ;;
   esac
   echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3723: checking for yywrap in -l$ac_lib" >&5
+echo "configure:2399: checking for yywrap in -l$ac_lib" >&5
 ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
 LIBS="-l$ac_lib  $LIBS"
-#line 3729 "configure"
+#line 2405 "configure"
@@ -3736,7 +2412,7 @@
 yywrap()
 ; return 0; }
 EOF
-if { (eval echo configure:3740: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2416: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3761,7 +2437,7 @@
     # Extract the first word of "lex", so it can be a program name with args.
 set dummy lex; ac_word=$2
-echo "configure:3765: checking for $ac_word" >&5
+echo "configure:2441: checking for $ac_word" >&5
 case "$LEXPATH" in
@@ -3801,7 +2477,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:3805: checking for $ac_word" >&5
+echo "configure:2481: checking for $ac_word" >&5
 if test -n "$YACC"; then
   ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3832,7 +2508,7 @@
     # Extract the first word of "yacc", so it can be a program name with args.
 set dummy yacc; ac_word=$2
-echo "configure:3836: checking for $ac_word" >&5
+echo "configure:2512: checking for $ac_word" >&5
 case "$YACCPATH" in
@@ -3870,7 +2546,7 @@
-echo "configure:3874: checking for $ac_word" >&5
+echo "configure:2550: checking for $ac_word" >&5
@@ -3899,7 +2575,7 @@
-echo "configure:3903: checking for $ac_word" >&5
+echo "configure:2579: checking for $ac_word" >&5
@@ -3930,7 +2606,7 @@
-echo "configure:3934: checking for $ac_word" >&5
+echo "configure:2610: checking for $ac_word" >&5
 if test -n "$ENV"; then
   ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3959,7 +2635,7 @@
 # Extract the first word of "perl", so it can be a program name with args.
 set dummy perl; ac_word=$2
-echo "configure:3963: checking for $ac_word" >&5
+echo "configure:2639: checking for $ac_word" >&5
 case "$PERL" in
@@ -3989,11 +2665,88 @@
 fi
+echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
+echo "configure:2670: checking how to run the C preprocessor" >&5
+# On Suns, sometimes $CPP names a directory.
+if test -n "$CPP" && test -d "$CPP"; then
+  CPP=
+fi
+if test -z "$CPP"; then
+  # This must be in double quotes, not single quotes, because CPP may get
+  # substituted into the Makefile and "${CC-cc}" will confuse make.
+  CPP="${CC-cc} -E"
+  # On the NeXT, cc -E runs the code through the compiler's parser,
+  # not just through cpp.
+  cat > conftest.$ac_ext <<EOF
+#line 2683 "configure"
+#include "confdefs.h"
+#include <assert.h>
+Syntax Error
+EOF
+ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
+{ (eval echo configure:2689: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
+if test -z "$ac_err"; then
+else
+  echo "$ac_err" >&5
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+  CPP="${CC-cc} -E -traditional-cpp"
+#line 2700 "configure"
+Syntax Error
+EOF
+{ (eval echo configure:2706: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+else
+  rm -rf conftest*
+  CPP="${CC-cc} -nologo -E"
+#line 2717 "configure"
+Syntax Error
+EOF
+{ (eval echo configure:2723: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+else
+  rm -rf conftest*
+  CPP=/lib/cpp
+fi
+rm -f conftest*
+fi
+rm -f conftest*
+fi
+rm -f conftest*
+  ac_cv_prog_CPP="$CPP"
+  CPP="$ac_cv_prog_CPP"
+else
+fi
+echo "$ac_t""$CPP" 1>&6
 echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:3994: checking for ANSI C header files" >&5
+echo "configure:2747: checking for ANSI C header files" >&5
-#line 3997 "configure"
+#line 2750 "configure"
 #include <stdlib.h>
 #include <stdarg.h>
@@ -4001,7 +2754,7 @@
 #include <float.h>
 EOF
-{ (eval echo configure:4005: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2758: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4018,7 +2771,7 @@
 if test $ac_cv_header_stdc = yes; then
   # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 4022 "configure"
+#line 2775 "configure"
 #include <string.h>
 EOF
@@ -4036,7 +2789,7 @@
   # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 4040 "configure"
+#line 2793 "configure"
 #include <stdlib.h>
 EOF
@@ -4057,7 +2810,7 @@
 else
-#line 4061 "configure"
+#line 2814 "configure"
 #include <ctype.h>
 #define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -4068,7 +2821,7 @@
 exit (0); }
 EOF
-if { (eval echo configure:4072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:2825: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
 else
@@ -4095,15 +2848,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:4099: checking for $ac_hdr" >&5
+echo "configure:2852: checking for $ac_hdr" >&5
-#line 4102 "configure"
+#line 2855 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4107: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2860: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4132,15 +2885,15 @@
 do
-echo "configure:4136: checking for $ac_hdr" >&5
+echo "configure:2889: checking for $ac_hdr" >&5
-#line 4139 "configure"
+#line 2892 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4144: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2897: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4169,15 +2922,15 @@
 do
-echo "configure:4173: checking for $ac_hdr" >&5
+echo "configure:2926: checking for $ac_hdr" >&5
-#line 4176 "configure"
+#line 2929 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4181: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2934: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4206,15 +2959,15 @@
 do
-echo "configure:4210: checking for $ac_hdr" >&5
+echo "configure:2963: checking for $ac_hdr" >&5
-#line 4213 "configure"
+#line 2966 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4218: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2971: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4243,15 +2996,15 @@
 do
-echo "configure:4247: checking for $ac_hdr" >&5
+echo "configure:3000: checking for $ac_hdr" >&5
-#line 4250 "configure"
+#line 3003 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4255: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3008: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4277,10 +3030,10 @@
 done
 echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4281: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:3034: checking whether time.h and sys/time.h may both be included" >&5
-#line 4284 "configure"
+#line 3037 "configure"
 #include <sys/types.h>
 #include <sys/time.h>
@@ -4289,7 +3042,7 @@
 struct tm *tp;
 ; return 0; }
 EOF
-if { (eval echo configure:4293: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3046: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_header_time=yes
 else
@@ -4309,10 +3062,10 @@
 fi
 echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4313: checking for off_t" >&5
+echo "configure:3066: checking for off_t" >&5
-#line 4316 "configure"
+#line 3069 "configure"
 #if STDC_HEADERS
@@ -4339,10 +3092,10 @@
 fi
 echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4343: checking for uid_t in sys/types.h" >&5
+echo "configure:3096: checking for uid_t in sys/types.h" >&5
-#line 4346 "configure"
+#line 3099 "configure"
 EOF
@@ -4370,10 +3123,10 @@
 fi
 echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4374: checking return type of signal handlers" >&5
+echo "configure:3127: checking return type of signal handlers" >&5
-#line 4377 "configure"
+#line 3130 "configure"
 #include <signal.h>
@@ -4390,7 +3143,7 @@
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:4394: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3147: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_type_signal=void
 else
@@ -4408,10 +3161,10 @@
-echo "configure:4412: checking for Cygwin environment" >&5
+echo "configure:3165: checking for Cygwin environment" >&5
-#line 4415 "configure"
+#line 3168 "configure"
 int main() {
@@ -4422,7 +3175,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:4426: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3179: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -4440,10 +3193,10 @@
 for ac_func in ftime gethostname gettimeofday lseek nice time uname
 do
 echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4444: checking for $ac_func" >&5
+echo "configure:3197: checking for $ac_func" >&5
-#line 4447 "configure"
+#line 3200 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char $ac_func(); below.  */
@@ -4466,7 +3219,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4470: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3223: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_$ac_func=yes"
 else
@@ -4492,10 +3245,10 @@
 for ac_func in seteuid setpriority setreuid setruid
 do
-echo "configure:4496: checking for $ac_func" >&5
+echo "configure:3249: checking for $ac_func" >&5
-#line 4499 "configure"
+#line 3252 "configure"
@@ -4518,7 +3271,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3275: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4544,10 +3297,10 @@
 for ac_func in drand48
 do
-echo "configure:4548: checking for $ac_func" >&5
+echo "configure:3301: checking for $ac_func" >&5
-#line 4551 "configure"
+#line 3304 "configure"
@@ -4570,7 +3323,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4574: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3327: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4596,10 +3349,10 @@
 for ac_func in putenv setenv
 do
-echo "configure:4600: checking for $ac_func" >&5
+echo "configure:3353: checking for $ac_func" >&5
-#line 4603 "configure"
+#line 3356 "configure"
@@ -4622,7 +3375,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4626: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4648,10 +3401,10 @@
 for ac_func in nanosleep
 do
-echo "configure:4652: checking for $ac_func" >&5
+echo "configure:3405: checking for $ac_func" >&5
-#line 4655 "configure"
+#line 3408 "configure"
@@ -4674,7 +3427,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4678: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4699,13 +3452,13 @@
 if test "$cross_compiling" != "yes" ; then
 echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4703: checking whether setpgrp takes no argument" >&5
+echo "configure:3456: checking whether setpgrp takes no argument" >&5
   { echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
 else
-#line 4709 "configure"
+#line 3462 "configure"
 #ifdef HAVE_UNISTD_H
@@ -4725,7 +3478,7 @@
 EOF
-if { (eval echo configure:4729: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3482: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
   ac_cv_func_setpgrp_void=no
 else
@@ -4753,16 +3506,16 @@
 fi
 echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4757: checking for long long int" >&5
+echo "configure:3510: checking for long long int" >&5
-#line 4759 "configure"
+#line 3512 "configure"
 int main() {
 long long int x;
 ; return 0; }
 EOF
-if { (eval echo configure:4766: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3519: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
@@ -4782,7 +3535,7 @@
 rm -f conftest*
 echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4786: checking for W11" >&5
+echo "configure:3539: checking for W11" >&5
 case "$enable_w11" in
 	yes|no)	echo "$ac_t"""$enable_w11"" 1>&6	;;
 	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
@@ -4810,7 +3563,7 @@
 # Uses ac_ vars as temps to allow command line to override cache and checks.
 # --without-x overrides everything else, but does not touch the cache.
 echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4814: checking for X" >&5
+echo "configure:3567: checking for X" >&5
 # Check whether --with-x or --without-x was given.
 if test "${with_x+set}" = set; then
@@ -4870,12 +3623,12 @@
   # First, try using that file with no special directory specified.
-#line 4874 "configure"
+#line 3627 "configure"
 #include <$x_direct_test_include>
 EOF
-{ (eval echo configure:4879: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3632: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4944,14 +3697,14 @@
   LIBS="-l$x_direct_test_library $LIBS"
-#line 4948 "configure"
+#line 3701 "configure"
 int main() {
 ${x_direct_test_function}()
 ; return 0; }
 EOF
-if { (eval echo configure:4955: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3708: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 # We can link X programs with no special library path.
@@ -5056,17 +3809,17 @@
     case "`(uname -sr) 2>/dev/null`" in
     "SunOS 5"*)
       echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:5060: checking whether -R must be followed by a space" >&5
+echo "configure:3813: checking whether -R must be followed by a space" >&5
       ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 5063 "configure"
+#line 3816 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:5070: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_nospace=yes
 else
@@ -5082,14 +3835,14 @@
       else
 	LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 5086 "configure"
+#line 3839 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:5093: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_space=yes
 else
@@ -5121,13 +3874,13 @@
     # libraries were built with DECnet support.  And karl at cs.umb.edu says
     # the Alpha needs dnet_stub (dnet does not exist).
     echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:5125: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:3878: checking for dnet_ntoa in -ldnet" >&5
 ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet  $LIBS"
-#line 5131 "configure"
+#line 3884 "configure"
@@ -5138,7 +3891,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:5142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5159,13 +3912,13 @@
     if test $ac_cv_lib_dnet_dnet_ntoa = no; then
       echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:5163: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:3916: checking for dnet_ntoa in -ldnet_stub" >&5
 ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet_stub  $LIBS"
-#line 5169 "configure"
+#line 3922 "configure"
@@ -5176,7 +3929,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:5180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3933: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5204,10 +3957,10 @@
     # The nsl library prevents programs from opening the X display
     # on Irix 5.2, according to dickey at clark.net.
     echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:5208: checking for gethostbyname" >&5
+echo "configure:3961: checking for gethostbyname" >&5
-#line 5211 "configure"
+#line 3964 "configure"
     which can conflict with char gethostbyname(); below.  */
@@ -5230,7 +3983,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5234: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3987: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gethostbyname=yes"
 else
@@ -5250,13 +4003,13 @@
     if test $ac_cv_func_gethostbyname = no; then
       echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5254: checking for gethostbyname in -lnsl" >&5
+echo "configure:4007: checking for gethostbyname in -lnsl" >&5
 ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 5260 "configure"
+#line 4013 "configure"
@@ -5267,7 +4020,7 @@
 gethostbyname()
 ; return 0; }
 EOF
-if { (eval echo configure:5271: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5296,10 +4049,10 @@
     # -lsocket must be given before -lnsl if both are needed.
     # We assume that if connect needs -lnsl, so does gethostbyname.
     echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5300: checking for connect" >&5
+echo "configure:4053: checking for connect" >&5
-#line 5303 "configure"
+#line 4056 "configure"
     which can conflict with char connect(); below.  */
@@ -5322,7 +4075,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5326: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4079: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_connect=yes"
 else
@@ -5342,13 +4095,13 @@
     if test $ac_cv_func_connect = no; then
       echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5346: checking for connect in -lsocket" >&5
+echo "configure:4099: checking for connect in -lsocket" >&5
 ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
 LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5352 "configure"
+#line 4105 "configure"
@@ -5359,7 +4112,7 @@
 connect()
 ; return 0; }
 EOF
-if { (eval echo configure:5363: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5382,10 +4135,10 @@
     # gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
     echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5386: checking for remove" >&5
+echo "configure:4139: checking for remove" >&5
-#line 5389 "configure"
+#line 4142 "configure"
     which can conflict with char remove(); below.  */
@@ -5408,7 +4161,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5412: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4165: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_remove=yes"
 else
@@ -5428,13 +4181,13 @@
     if test $ac_cv_func_remove = no; then
       echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5432: checking for remove in -lposix" >&5
+echo "configure:4185: checking for remove in -lposix" >&5
 ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
 LIBS="-lposix  $LIBS"
-#line 5438 "configure"
+#line 4191 "configure"
@@ -5445,7 +4198,7 @@
 remove()
 ; return 0; }
 EOF
-if { (eval echo configure:5449: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4202: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5468,10 +4221,10 @@
     # BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
     echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5472: checking for shmat" >&5
+echo "configure:4225: checking for shmat" >&5
-#line 5475 "configure"
+#line 4228 "configure"
     which can conflict with char shmat(); below.  */
@@ -5494,7 +4247,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4251: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_shmat=yes"
 else
@@ -5514,13 +4267,13 @@
     if test $ac_cv_func_shmat = no; then
       echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5518: checking for shmat in -lipc" >&5
+echo "configure:4271: checking for shmat in -lipc" >&5
 ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
 LIBS="-lipc  $LIBS"
-#line 5524 "configure"
+#line 4277 "configure"
@@ -5531,7 +4284,7 @@
 shmat()
 ; return 0; }
 EOF
-if { (eval echo configure:5535: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4288: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5563,13 +4316,13 @@
   # libraries we check for below, so use a different variable.
   #  --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
   echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5567: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:4320: checking for IceConnectionNumber in -lICE" >&5
 ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
 LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5573 "configure"
+#line 4326 "configure"
@@ -5580,7 +4333,7 @@
 IceConnectionNumber()
 ; return 0; }
 EOF
-if { (eval echo configure:5584: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5620,12 +4373,12 @@
 LIBS=""
 echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:5624: checking for library containing cuserid" >&5
+echo "configure:4377: checking for library containing cuserid" >&5
 ac_func_search_save_LIBS="$LIBS"
 ac_cv_search_cuserid="no"
-#line 5629 "configure"
+#line 4382 "configure"
@@ -5636,7 +4389,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:5640: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4393: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="none required"
 else
@@ -5647,7 +4400,7 @@
 test "$ac_cv_search_cuserid" = "no" && for i in compat; do
 LIBS="-l$i  $ac_func_search_save_LIBS"
-#line 5651 "configure"
+#line 4404 "configure"
@@ -5658,7 +4411,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:5662: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="-l$i"
 break
@@ -5684,10 +4437,10 @@
 # Note: -lxdr -liberty -lws2_32 is for MinGW
 echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:5688: checking for xdrmem_create" >&5
+echo "configure:4441: checking for xdrmem_create" >&5
-#line 5691 "configure"
+#line 4444 "configure"
     which can conflict with char xdrmem_create(); below.  */
@@ -5710,7 +4463,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5714: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_xdrmem_create=yes"
 else
@@ -5728,13 +4481,13 @@
 echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:5732: checking for xdrmem_create in -lsun" >&5
+echo "configure:4485: checking for xdrmem_create in -lsun" >&5
 ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lsun  $LIBS"
-#line 5738 "configure"
+#line 4491 "configure"
@@ -5745,7 +4498,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5749: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4502: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5764,13 +4517,13 @@
 echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:5768: checking for xdrmem_create in -lnsl" >&5
+echo "configure:4521: checking for xdrmem_create in -lnsl" >&5
 ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 5774 "configure"
+#line 4527 "configure"
@@ -5781,7 +4534,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5785: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4538: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5800,13 +4553,13 @@
 echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:5804: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:4557: checking for xdrmem_create in -lrpclib" >&5
 ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lrpclib  $LIBS"
-#line 5810 "configure"
+#line 4563 "configure"
@@ -5817,7 +4570,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4574: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5836,13 +4589,13 @@
 echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:5840: checking for xdrmem_create in -lxdr" >&5
+echo "configure:4593: checking for xdrmem_create in -lxdr" >&5
 ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lxdr -liberty -lws2_32  $LIBS"
-#line 5846 "configure"
+#line 4599 "configure"
@@ -5853,7 +4606,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5857: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4610: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5887,10 +4640,10 @@
 for ac_func in asprintf
 do
-echo "configure:5891: checking for $ac_func" >&5
+echo "configure:4644: checking for $ac_func" >&5
-#line 5894 "configure"
+#line 4647 "configure"
@@ -5913,7 +4666,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5917: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4670: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5940,10 +4693,10 @@
 # Test if mathlib needs -lm flag or is included with libc
 echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:5944: checking for atan" >&5
+echo "configure:4697: checking for atan" >&5
-#line 5947 "configure"
+#line 4700 "configure"
     which can conflict with char atan(); below.  */
@@ -5966,7 +4719,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4723: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_atan=yes"
 else
@@ -5984,13 +4737,13 @@
 echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:5988: checking for atan in -lm" >&5
+echo "configure:4741: checking for atan in -lm" >&5
 ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
 LIBS="-lm  $LIBS"
-#line 5994 "configure"
+#line 4747 "configure"
@@ -6001,7 +4754,7 @@
 atan()
 ; return 0; }
 EOF
-if { (eval echo configure:6005: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4758: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6028,10 +4781,10 @@
 echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:6032: checking for dlsym" >&5
+echo "configure:4785: checking for dlsym" >&5
-#line 6035 "configure"
+#line 4788 "configure"
     which can conflict with char dlsym(); below.  */
@@ -6054,7 +4807,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6058: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4811: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dlsym=yes"
 else
@@ -6072,13 +4825,13 @@
 echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:6076: checking for dlsym in -ldl" >&5
+echo "configure:4829: checking for dlsym in -ldl" >&5
 ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
 LIBS="-ldl  $LIBS"
-#line 6082 "configure"
+#line 4835 "configure"
@@ -6089,7 +4842,7 @@
 dlsym()
 ; return 0; }
 EOF
-if { (eval echo configure:6093: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6116,10 +4869,10 @@
 echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:6120: checking for iconv" >&5
+echo "configure:4873: checking for iconv" >&5
-#line 6123 "configure"
+#line 4876 "configure"
     which can conflict with char iconv(); below.  */
@@ -6142,7 +4895,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6146: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4899: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_iconv=yes"
 else
@@ -6160,13 +4913,13 @@
 echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6164: checking for iconv in -liconv" >&5
+echo "configure:4917: checking for iconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-liconv  $LIBS"
-#line 6170 "configure"
+#line 4923 "configure"
@@ -6177,7 +4930,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6181: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6196,13 +4949,13 @@
 echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6200: checking for iconv in -lgiconv" >&5
+echo "configure:4953: checking for iconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-lgiconv  $LIBS"
-#line 6206 "configure"
+#line 4959 "configure"
@@ -6213,7 +4966,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6232,10 +4985,10 @@
 echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6236: checking for libiconv" >&5
+echo "configure:4989: checking for libiconv" >&5
-#line 6239 "configure"
+#line 4992 "configure"
     which can conflict with char libiconv(); below.  */
@@ -6258,7 +5011,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6262: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5015: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_libiconv=yes"
 else
@@ -6276,13 +5029,13 @@
 echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6280: checking for libiconv in -liconv" >&5
+echo "configure:5033: checking for libiconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6286 "configure"
+#line 5039 "configure"
@@ -6293,7 +5046,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5050: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6312,13 +5065,13 @@
 echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6316: checking for libiconv in -lgiconv" >&5
+echo "configure:5069: checking for libiconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6322 "configure"
+#line 5075 "configure"
@@ -6329,7 +5082,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6333: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5086: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6366,10 +5119,10 @@
 have_socket=1
 echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6370: checking for socket" >&5
+echo "configure:5123: checking for socket" >&5
-#line 6373 "configure"
+#line 5126 "configure"
     which can conflict with char socket(); below.  */
@@ -6392,7 +5145,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6396: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5149: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_socket=yes"
 else
@@ -6410,13 +5163,13 @@
 echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6414: checking for socket in -lsocket" >&5
+echo "configure:5167: checking for socket in -lsocket" >&5
 ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
 LIBS="-lsocket  $LIBS"
-#line 6420 "configure"
+#line 5173 "configure"
@@ -6427,7 +5180,7 @@
 socket()
 ; return 0; }
 EOF
-if { (eval echo configure:6431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5184: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6475,7 +5228,7 @@
 echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6479: checking for location of zlib includes" >&5
+echo "configure:5232: checking for location of zlib includes" >&5
 case "$with_zlib_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6501,15 +5254,15 @@
 do
-echo "configure:6505: checking for $ac_hdr" >&5
+echo "configure:5258: checking for $ac_hdr" >&5
-#line 6508 "configure"
+#line 5261 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6513: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5266: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6543,7 +5296,7 @@
 echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6547: checking for location of zlib library" >&5
+echo "configure:5300: checking for location of zlib library" >&5
 case "$with_zlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6568,13 +5321,13 @@
 echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6572: checking for deflate in -lz" >&5
+echo "configure:5325: checking for deflate in -lz" >&5
 ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
 LIBS="-lz  $LIBS"
-#line 6578 "configure"
+#line 5331 "configure"
@@ -6585,7 +5338,7 @@
 deflate()
 ; return 0; }
 EOF
-if { (eval echo configure:6589: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5342: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6633,7 +5386,7 @@
 echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:6637: checking for location of External PROJ.4 includes" >&5
+echo "configure:5390: checking for location of External PROJ.4 includes" >&5
 case "$with_proj_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -6659,15 +5412,15 @@
 do
-echo "configure:6663: checking for $ac_hdr" >&5
+echo "configure:5416: checking for $ac_hdr" >&5
-#line 6666 "configure"
+#line 5419 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6671: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5424: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6704,7 +5457,7 @@
 else
 echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:6708: checking External PROJ.4 version" >&5
+echo "configure:5461: checking External PROJ.4 version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -6712,7 +5465,7 @@
 else
-#line 6716 "configure"
+#line 5469 "configure"
 #include <stdio.h>
@@ -6724,7 +5477,7 @@
 EOF
-if { (eval echo configure:6728: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:5481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      proj_ver=`cat conftestdata`
         echo "$ac_t""$proj_ver" 1>&6
@@ -6749,7 +5502,7 @@
 echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:6753: checking for location of External PROJ.4 library" >&5
+echo "configure:5506: checking for location of External PROJ.4 library" >&5
 case "$with_proj_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -6774,13 +5527,13 @@
 echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:6778: checking for pj_get_def in -lproj" >&5
+echo "configure:5531: checking for pj_get_def in -lproj" >&5
 ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
 LIBS="-lproj  $LIBS"
-#line 6784 "configure"
+#line 5537 "configure"
@@ -6791,7 +5544,7 @@
 pj_get_def()
 ; return 0; }
 EOF
-if { (eval echo configure:6795: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5548: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6825,7 +5578,7 @@
 echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:6829: checking for location of External PROJ.4 data files" >&5
+echo "configure:5582: checking for location of External PROJ.4 data files" >&5
 case "$with_proj_share" in
         { echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -6849,14 +5602,14 @@
 # LOC_CHECK_SHARE does not work when cross compiling
 if test "$cross_compiling" = "yes" ; then
     echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:6853: checking for epsg" >&5
+echo "configure:5606: checking for epsg" >&5
 else
 ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:6860: checking for $PROJSHARE/epsg" >&5
+echo "configure:5613: checking for $PROJSHARE/epsg" >&5
@@ -6888,7 +5641,7 @@
 # Extract the first word of "nad2bin", so it can be a program name with args.
 set dummy nad2bin; ac_word=$2
-echo "configure:6892: checking for $ac_word" >&5
+echo "configure:5645: checking for $ac_word" >&5
 case "$NAD2BIN" in
@@ -6928,7 +5681,7 @@
 echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:6932: checking whether to use regex" >&5
+echo "configure:5685: checking whether to use regex" >&5
 echo "$ac_t"""$with_regex"" 1>&6
 case "$with_regex" in
 	"no")	USE_REGEX=	;;
@@ -6948,7 +5701,7 @@
 echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:6952: checking for location of regex includes" >&5
+echo "configure:5705: checking for location of regex includes" >&5
 case "$with_regex_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -6974,15 +5727,15 @@
 do
-echo "configure:6978: checking for $ac_hdr" >&5
+echo "configure:5731: checking for $ac_hdr" >&5
-#line 6981 "configure"
+#line 5734 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6986: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5739: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7016,7 +5769,7 @@
 echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:7020: checking for location of regex library" >&5
+echo "configure:5773: checking for location of regex library" >&5
 case "$with_regex_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -7041,10 +5794,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:7045: checking for regcomp" >&5
+echo "configure:5798: checking for regcomp" >&5
-#line 7048 "configure"
+#line 5801 "configure"
     which can conflict with char regcomp(); below.  */
@@ -7067,7 +5820,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7071: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5824: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_regcomp=yes"
 else
@@ -7094,13 +5847,13 @@
 echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:7098: checking for regcomp in -lregex" >&5
+echo "configure:5851: checking for regcomp in -lregex" >&5
 ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
 LIBS="-lregex  $LIBS"
-#line 7104 "configure"
+#line 5857 "configure"
@@ -7111,7 +5864,7 @@
 regcomp()
 ; return 0; }
 EOF
-if { (eval echo configure:7115: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7161,7 +5914,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7165: checking whether to use Readline" >&5
+echo "configure:5918: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -7182,7 +5935,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7186: checking for location of Readline includes" >&5
+echo "configure:5939: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7208,15 +5961,15 @@
 do
-echo "configure:7212: checking for $ac_hdr" >&5
+echo "configure:5965: checking for $ac_hdr" >&5
-#line 7215 "configure"
+#line 5968 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7220: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5973: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7252,15 +6005,15 @@
 do
-echo "configure:7256: checking for $ac_hdr" >&5
+echo "configure:6009: checking for $ac_hdr" >&5
-#line 7259 "configure"
+#line 6012 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7264: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6017: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7294,7 +6047,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7298: checking for location of Readline library" >&5
+echo "configure:6051: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7319,13 +6072,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7323: checking for readline in -lreadline" >&5
+echo "configure:6076: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
-#line 7329 "configure"
+#line 6082 "configure"
@@ -7336,7 +6089,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:7340: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6093: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7371,13 +6124,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7375: checking for add_history in -lhistory" >&5
+echo "configure:6128: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 7381 "configure"
+#line 6134 "configure"
@@ -7388,7 +6141,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:7392: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6145: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7431,7 +6184,7 @@
 echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7435: checking whether to use JPEG" >&5
+echo "configure:6188: checking whether to use JPEG" >&5
 echo "$ac_t"""$with_jpeg"" 1>&6
 case "$with_jpeg" in
 	"no")	USE_JPEG=	;;
@@ -7451,7 +6204,7 @@
 echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7455: checking for location of JPEG includes" >&5
+echo "configure:6208: checking for location of JPEG includes" >&5
 case "$with_jpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -7477,15 +6230,15 @@
 do
-echo "configure:7481: checking for $ac_hdr" >&5
+echo "configure:6234: checking for $ac_hdr" >&5
-#line 7484 "configure"
+#line 6237 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7489: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6242: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7519,7 +6272,7 @@
 echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7523: checking for location of JPEG library" >&5
+echo "configure:6276: checking for location of JPEG library" >&5
 case "$with_jpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -7546,13 +6299,13 @@
 echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7550: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:6303: checking for jpeg_start_compress in -ljpeg" >&5
 ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
 LIBS="-ljpeg  $LIBS"
-#line 7556 "configure"
+#line 6309 "configure"
@@ -7563,7 +6316,7 @@
 jpeg_start_compress()
 ; return 0; }
 EOF
-if { (eval echo configure:7567: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6320: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7582,13 +6335,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:7586: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:6339: checking for jpeg_start_compress in -ljpeg" >&5
 LIBS="-ljpeg $ZLIB $LIBS"
-#line 7592 "configure"
+#line 6345 "configure"
@@ -7599,7 +6352,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7603: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6356: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7648,7 +6401,7 @@
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:7652: checking whether to use GDAL" >&5
+echo "configure:6405: checking whether to use GDAL" >&5
 GDAL_LIBS=
 GDAL_CFLAGS=
@@ -7666,7 +6419,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:7670: checking for $ac_word" >&5
+echo "configure:6423: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -7721,14 +6474,14 @@
   LIBS="$LIBS $GDAL_LIBS"
   CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 7725 "configure"
+#line 6478 "configure"
 #include <gdal.h>
 int main() {
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:7732: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6485: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -7737,14 +6490,14 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 7741 "configure"
+#line 6494 "configure"
 #include <gdal.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:7748: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -7776,7 +6529,7 @@
 # GEOS option
 echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:7780: checking whether to use GEOS" >&5
+echo "configure:6533: checking whether to use GEOS" >&5
 GEOS_LIBS=
 GGEOS_CFLAGS=
@@ -7793,7 +6546,7 @@
   # Extract the first word of "geos-config", so it can be a program name with args.
 set dummy geos-config; ac_word=$2
-echo "configure:7797: checking for $ac_word" >&5
+echo "configure:6550: checking for $ac_word" >&5
 case "$GEOS_CONFIG" in
@@ -7841,15 +6594,15 @@
 do
-echo "configure:7845: checking for $ac_hdr" >&5
+echo "configure:6598: checking for $ac_hdr" >&5
-#line 7848 "configure"
+#line 6601 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7853: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6606: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7884,13 +6637,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:7888: checking for initGEOS in -lgeos_c" >&5
+echo "configure:6641: checking for initGEOS in -lgeos_c" >&5
 ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lgeos_c  $LIBS"
-#line 7894 "configure"
+#line 6647 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -7901,7 +6654,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:7905: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6658: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -7944,7 +6697,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:7948: checking whether to use TIFF" >&5
+echo "configure:6701: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -7964,7 +6717,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:7968: checking for location of TIFF includes" >&5
+echo "configure:6721: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -7990,15 +6743,15 @@
 do
-echo "configure:7994: checking for $ac_hdr" >&5
+echo "configure:6747: checking for $ac_hdr" >&5
-#line 7997 "configure"
+#line 6750 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8002: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6755: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8032,7 +6785,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:8036: checking for location of TIFF library" >&5
+echo "configure:6789: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -8063,13 +6816,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:8067: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6820: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 LIBS="-ltiff  $LIBS"
-#line 8073 "configure"
+#line 6826 "configure"
@@ -8080,7 +6833,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8084: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6837: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8099,13 +6852,13 @@
-echo "configure:8103: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6856: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 8109 "configure"
+#line 6862 "configure"
@@ -8116,7 +6869,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6873: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8135,13 +6888,13 @@
-echo "configure:8139: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6892: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 8145 "configure"
+#line 6898 "configure"
@@ -8152,7 +6905,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6909: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8171,13 +6924,13 @@
-echo "configure:8175: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6928: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 8181 "configure"
+#line 6934 "configure"
@@ -8188,7 +6941,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8192: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6945: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8207,13 +6960,13 @@
-echo "configure:8211: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6964: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 8217 "configure"
+#line 6970 "configure"
@@ -8224,7 +6977,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8228: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6981: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8243,13 +6996,13 @@
-echo "configure:8247: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7000: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8253 "configure"
+#line 7006 "configure"
@@ -8260,7 +7013,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8264: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7017: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8279,13 +7032,13 @@
-echo "configure:8283: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7036: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8289 "configure"
+#line 7042 "configure"
@@ -8296,7 +7049,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8300: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7053: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8315,13 +7068,13 @@
-echo "configure:8319: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7072: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8325 "configure"
+#line 7078 "configure"
@@ -8332,7 +7085,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8336: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8430,7 +7183,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8434: checking whether to use PNG" >&5
+echo "configure:7187: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -8449,7 +7202,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8453: checking for location of PNG includes" >&5
+echo "configure:7206: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8475,15 +7228,15 @@
 do
-echo "configure:8479: checking for $ac_hdr" >&5
+echo "configure:7232: checking for $ac_hdr" >&5
-#line 8482 "configure"
+#line 7235 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8487: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7240: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8517,7 +7270,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8521: checking for location of PNG library" >&5
+echo "configure:7274: checking for location of PNG library" >&5
 case "$with_png_libs" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8542,13 +7295,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8546: checking for png_read_image in -lpng" >&5
+echo "configure:7299: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8552 "configure"
+#line 7305 "configure"
@@ -8559,7 +7312,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:8563: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7316: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8601,7 +7354,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:8605: checking whether to use PostgreSQL" >&5
+echo "configure:7358: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -8628,7 +7381,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:8632: checking for location of PostgreSQL includes" >&5
+echo "configure:7385: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -8654,15 +7407,15 @@
 do
-echo "configure:8658: checking for $ac_hdr" >&5
+echo "configure:7411: checking for $ac_hdr" >&5
-#line 8661 "configure"
+#line 7414 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8666: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7419: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8700,7 +7453,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:8704: checking for location of PostgreSQL library" >&5
+echo "configure:7457: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -8729,13 +7482,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:8733: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7486: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 8739 "configure"
+#line 7492 "configure"
@@ -8746,7 +7499,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:8750: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7503: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8765,13 +7518,13 @@
-echo "configure:8769: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7522: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 8775 "configure"
+#line 7528 "configure"
@@ -8782,7 +7535,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:8786: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7539: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8801,13 +7554,13 @@
-echo "configure:8805: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7558: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 8811 "configure"
+#line 7564 "configure"
 #include "confdefs.h"
@@ -8818,7 +7571,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:8822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7575: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8837,13 +7590,13 @@
-echo "configure:8841: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7594: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 8847 "configure"
+#line 7600 "configure"
@@ -8854,7 +7607,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:8858: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7611: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8911,13 +7664,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:8915: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7668: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 8921 "configure"
+#line 7674 "configure"
@@ -8928,7 +7681,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:8932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8950,13 +7703,13 @@
-echo "configure:8954: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7707: checking for PQcmdTuples in -lpq" >&5
-#line 8960 "configure"
+#line 7713 "configure"
@@ -8967,7 +7720,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:8971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7724: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9010,7 +7763,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9014: checking whether to use MySQL" >&5
+echo "configure:7767: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -9030,7 +7783,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9034: checking for location of MySQL includes" >&5
+echo "configure:7787: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9056,15 +7809,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:9060: checking for $ac_hdr" >&5
+echo "configure:7813: checking for $ac_hdr" >&5
-#line 9063 "configure"
+#line 7816 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:9068: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7821: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -9101,7 +7854,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9105: checking for location of MySQL library" >&5
+echo "configure:7858: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9132,13 +7885,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9136: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7889: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 9142 "configure"
+#line 7895 "configure"
@@ -9149,7 +7902,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7906: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9168,13 +7921,13 @@
-echo "configure:9172: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7925: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9178 "configure"
+#line 7931 "configure"
@@ -9185,7 +7938,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9189: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7942: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9204,13 +7957,13 @@
-echo "configure:9208: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7961: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9214 "configure"
+#line 7967 "configure"
@@ -9221,7 +7974,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7978: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9240,13 +7993,13 @@
-echo "configure:9244: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7997: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9250 "configure"
+#line 8003 "configure"
@@ -9257,7 +8010,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8014: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9276,13 +8029,13 @@
-echo "configure:9280: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8033: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9286 "configure"
+#line 8039 "configure"
@@ -9293,7 +8046,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8050: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9312,13 +8065,13 @@
-echo "configure:9316: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8069: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9322 "configure"
+#line 8075 "configure"
@@ -9329,7 +8082,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9333: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8086: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9348,13 +8101,13 @@
-echo "configure:9352: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8105: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 9358 "configure"
+#line 8111 "configure"
@@ -9365,7 +8118,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9369: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8122: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9384,13 +8137,13 @@
-echo "configure:9388: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8141: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 9394 "configure"
+#line 8147 "configure"
@@ -9401,7 +8154,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9405: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8158: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9491,7 +8244,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
-echo "configure:9495: checking for $ac_word" >&5
+echo "configure:8248: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -9540,10 +8293,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:9544: checking for mysql_server_init" >&5
+echo "configure:8297: checking for mysql_server_init" >&5
-#line 9547 "configure"
+#line 8300 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -9569,7 +8322,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9573: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8326: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -9621,7 +8374,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:9625: checking whether to use SQLite" >&5
+echo "configure:8378: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -9641,7 +8394,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:9645: checking for location of SQLite includes" >&5
+echo "configure:8398: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -9667,15 +8420,15 @@
 do
-echo "configure:9671: checking for $ac_hdr" >&5
+echo "configure:8424: checking for $ac_hdr" >&5
-#line 9674 "configure"
+#line 8427 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9679: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8432: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9718,7 +8471,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:9722: checking for location of SQLite library" >&5
+echo "configure:8475: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -9745,13 +8498,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:9749: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8502: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 9755 "configure"
+#line 8508 "configure"
@@ -9762,7 +8515,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:9766: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8519: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9781,13 +8534,13 @@
-echo "configure:9785: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8538: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 9791 "configure"
+#line 8544 "configure"
@@ -9798,7 +8551,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:9802: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8555: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9851,7 +8604,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:9855: checking whether to use FFMPEG" >&5
+echo "configure:8608: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -9871,7 +8624,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:9875: checking for location of FFMPEG includes" >&5
+echo "configure:8628: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -9897,15 +8650,15 @@
 do
-echo "configure:9901: checking for $ac_hdr" >&5
+echo "configure:8654: checking for $ac_hdr" >&5
-#line 9904 "configure"
+#line 8657 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9909: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8662: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9941,15 +8694,15 @@
 do
-echo "configure:9945: checking for $ac_hdr" >&5
+echo "configure:8698: checking for $ac_hdr" >&5
-#line 9948 "configure"
+#line 8701 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9953: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8706: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9985,15 +8738,15 @@
 do
-echo "configure:9989: checking for $ac_hdr" >&5
+echo "configure:8742: checking for $ac_hdr" >&5
-#line 9992 "configure"
+#line 8745 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9997: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8750: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10036,7 +8789,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10040: checking for location of FFMPEG library" >&5
+echo "configure:8793: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10063,13 +8816,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10067: checking for av_free in -lavutil" >&5
+echo "configure:8820: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 10073 "configure"
+#line 8826 "configure"
@@ -10080,7 +8833,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10084: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8837: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10099,13 +8852,13 @@
-echo "configure:10103: checking for av_free in -lavutil" >&5
+echo "configure:8856: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 10109 "configure"
+#line 8862 "configure"
@@ -10116,7 +8869,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8873: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10161,13 +8914,13 @@
 echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10165: checking for avcodec_init in -lavcodec" >&5
+echo "configure:8918: checking for avcodec_init in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 10171 "configure"
+#line 8924 "configure"
@@ -10178,7 +8931,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10182: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10197,13 +8950,13 @@
-echo "configure:10201: checking for avcodec_init in -lavcodec" >&5
+echo "configure:8954: checking for avcodec_init in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10207 "configure"
+#line 8960 "configure"
@@ -10214,7 +8967,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10218: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10259,13 +9012,13 @@
 echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10263: checking for av_set_parameters in -lavformat" >&5
+echo "configure:9016: checking for av_set_parameters in -lavformat" >&5
 ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 10269 "configure"
+#line 9022 "configure"
@@ -10276,7 +9029,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10280: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10295,13 +9048,13 @@
-echo "configure:10299: checking for av_set_parameters in -lavformat" >&5
+echo "configure:9052: checking for av_set_parameters in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10305 "configure"
+#line 9058 "configure"
@@ -10312,7 +9065,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10316: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9069: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10371,7 +9124,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10375: checking whether to use OpenGL" >&5
+echo "configure:9128: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -10405,7 +9158,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10409: checking for location of OpenGL includes" >&5
+echo "configure:9162: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10431,15 +9184,15 @@
 do
-echo "configure:10435: checking for $ac_hdr" >&5
+echo "configure:9188: checking for $ac_hdr" >&5
-#line 10438 "configure"
+#line 9191 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10443: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9196: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10473,7 +9226,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:10477: checking for location of OpenGL library" >&5
+echo "configure:9230: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -10502,13 +9255,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:10506: checking for glBegin in -lGL" >&5
+echo "configure:9259: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 10512 "configure"
+#line 9265 "configure"
@@ -10519,7 +9272,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9276: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10538,13 +9291,13 @@
-echo "configure:10542: checking for glBegin in -lGL" >&5
+echo "configure:9295: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 10548 "configure"
+#line 9301 "configure"
@@ -10555,7 +9308,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10559: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9312: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10574,13 +9327,13 @@
-echo "configure:10578: checking for glBegin in -lGL" >&5
+echo "configure:9331: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 10584 "configure"
+#line 9337 "configure"
@@ -10591,7 +9344,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10595: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9348: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10610,13 +9363,13 @@
-echo "configure:10614: checking for glBegin in -lGL" >&5
+echo "configure:9367: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 10620 "configure"
+#line 9373 "configure"
@@ -10627,7 +9380,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10631: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9384: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10689,13 +9442,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:10693: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9446: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 10699 "configure"
+#line 9452 "configure"
@@ -10706,7 +9459,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:10710: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9463: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10725,13 +9478,13 @@
-echo "configure:10729: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9482: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 10735 "configure"
+#line 9488 "configure"
@@ -10742,7 +9495,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:10746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9499: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10789,10 +9542,10 @@
 LIBS=" $OPENGLLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:10793: checking for glXCreatePbuffer" >&5
+echo "configure:9546: checking for glXCreatePbuffer" >&5
-#line 10796 "configure"
+#line 9549 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -10815,7 +9568,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10819: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9572: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -10852,10 +9605,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:10856: checking for glXCreateGLXPixmap" >&5
+echo "configure:9609: checking for glXCreateGLXPixmap" >&5
-#line 10859 "configure"
+#line 9612 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -10878,7 +9631,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10882: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9635: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -10921,7 +9674,7 @@
 echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:10925: checking for location of OpenGL framework" >&5
+echo "configure:9678: checking for location of OpenGL framework" >&5
 case "$with_opengl_framework" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -10945,15 +9698,15 @@
 do
-echo "configure:10949: checking for $ac_hdr" >&5
+echo "configure:9702: checking for $ac_hdr" >&5
-#line 10952 "configure"
+#line 9705 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10957: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9710: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10989,10 +9742,10 @@
 LIBS="-framework OpenGL -framework AGL -framework ApplicationServices  $LIBS"
 LDFLAGS="$OPENGLPATH $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:10993: checking for glBegin" >&5
+echo "configure:9746: checking for glBegin" >&5
-#line 10996 "configure"
+#line 9749 "configure"
     which can conflict with char glBegin(); below.  */
@@ -11015,7 +9768,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9772: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -11052,10 +9805,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11056: checking for gluBeginCurve" >&5
+echo "configure:9809: checking for gluBeginCurve" >&5
-#line 11059 "configure"
+#line 9812 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -11078,7 +9831,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11082: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9835: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -11126,7 +9879,7 @@
-echo "configure:11130: checking for location of OpenGL includes" >&5
+echo "configure:9883: checking for location of OpenGL includes" >&5
@@ -11152,15 +9905,15 @@
 do
-echo "configure:11156: checking for $ac_hdr" >&5
+echo "configure:9909: checking for $ac_hdr" >&5
-#line 11159 "configure"
+#line 9912 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11164: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9917: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11194,7 +9947,7 @@
-echo "configure:11198: checking for location of OpenGL library" >&5
+echo "configure:9951: checking for location of OpenGL library" >&5
@@ -11219,18 +9972,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11223: checking for OpenGL library" >&5
+echo "configure:9976: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 11227 "configure"
+#line 9980 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:11234: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9987: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -11254,18 +10007,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11258: checking for GLU library" >&5
+echo "configure:10011: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 11262 "configure"
+#line 10015 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:11269: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -11314,7 +10067,7 @@
 echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:11318: checking whether to use Tcl/Tk" >&5
+echo "configure:10071: checking whether to use Tcl/Tk" >&5
 echo "$ac_t"""$with_tcltk"" 1>&6
 case "$with_tcltk" in
 	"no")	USE_TCLTK=	;;
@@ -11334,7 +10087,7 @@
 echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:11338: checking for location of Tcl/Tk includes" >&5
+echo "configure:10091: checking for location of Tcl/Tk includes" >&5
 case "$with_tcltk_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -11360,15 +10113,15 @@
 do
-echo "configure:11364: checking for $ac_hdr" >&5
+echo "configure:10117: checking for $ac_hdr" >&5
-#line 11367 "configure"
+#line 10120 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11372: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10125: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11405,15 +10158,15 @@
 do
-echo "configure:11409: checking for $ac_hdr" >&5
+echo "configure:10162: checking for $ac_hdr" >&5
-#line 11412 "configure"
+#line 10165 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11417: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10170: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11447,7 +10200,7 @@
 echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:11451: checking Tcl version" >&5
+echo "configure:10204: checking Tcl version" >&5
 CPPFLAGS="$TCLINCDIR $CPPFLAGS"
 if test "$cross_compiling" = yes; then
@@ -11455,7 +10208,7 @@
     echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
-#line 11459 "configure"
+#line 10212 "configure"
 #include <stdio.h>
@@ -11467,7 +10220,7 @@
 EOF
-if { (eval echo configure:11471: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:10224: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tcl_ver=`cat conftestdata`
     echo "$ac_t""$tcl_ver" 1>&6
@@ -11485,7 +10238,7 @@
 echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:11489: checking Tk version" >&5
+echo "configure:10242: checking Tk version" >&5
 CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -11493,7 +10246,7 @@
 else
-#line 11497 "configure"
+#line 10250 "configure"
 #include <stdio.h>
@@ -11505,7 +10258,7 @@
 EOF
-if { (eval echo configure:11509: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:10262: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tk_ver=`cat conftestdata`
     echo "$ac_t""$tk_ver" 1>&6
@@ -11534,7 +10287,7 @@
 echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:11538: checking for location of Tcl/Tk library" >&5
+echo "configure:10291: checking for location of Tcl/Tk library" >&5
 case "$with_tcltk_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -11574,13 +10327,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:11578: checking for Tcl_Init in -ltcl" >&5
+echo "configure:10331: checking for Tcl_Init in -ltcl" >&5
 ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl $MATHLIB $LIBS"
-#line 11584 "configure"
+#line 10337 "configure"
@@ -11591,7 +10344,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11595: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10348: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11610,13 +10363,13 @@
-echo "configure:11614: checking for Tcl_Init in -ltcl" >&5
+echo "configure:10367: checking for Tcl_Init in -ltcl" >&5
 LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 11620 "configure"
+#line 10373 "configure"
@@ -11627,7 +10380,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11631: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10384: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11654,13 +10407,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:11658: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:10411: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 11664 "configure"
+#line 10417 "configure"
@@ -11671,7 +10424,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10428: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11690,13 +10443,13 @@
-echo "configure:11694: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:10447: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 11700 "configure"
+#line 10453 "configure"
@@ -11707,7 +10460,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10464: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11734,13 +10487,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:11738: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:10491: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 11744 "configure"
+#line 10497 "configure"
@@ -11751,7 +10504,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11755: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10508: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11770,13 +10523,13 @@
-echo "configure:11774: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:10527: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 11780 "configure"
+#line 10533 "configure"
@@ -11787,7 +10540,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11791: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11865,13 +10618,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:11869: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:10622: checking for Tk_MainWindow in -ltk" >&5
 ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 11875 "configure"
+#line 10628 "configure"
@@ -11882,7 +10635,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:11886: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10639: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11901,13 +10654,13 @@
-echo "configure:11905: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:10658: checking for Tk_MainWindow in -ltk" >&5
 LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 11911 "configure"
+#line 10664 "configure"
@@ -11918,7 +10671,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:11922: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11945,13 +10698,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:11949: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:10702: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 11955 "configure"
+#line 10708 "configure"
@@ -11962,7 +10715,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:11966: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10719: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11981,13 +10734,13 @@
-echo "configure:11985: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:10738: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 11991 "configure"
+#line 10744 "configure"
@@ -11998,7 +10751,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12002: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10755: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12025,13 +10778,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12029: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:10782: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 12035 "configure"
+#line 10788 "configure"
@@ -12042,7 +10795,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12046: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10799: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12061,13 +10814,13 @@
-echo "configure:12065: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:10818: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12071 "configure"
+#line 10824 "configure"
@@ -12078,7 +10831,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12082: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10835: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12168,13 +10921,13 @@
   do
     # add only if in MACOSX_ARCHS
     echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
-echo "configure:12172: checking for Tcl_Init in -l$tlib" >&5
+echo "configure:10925: checking for Tcl_Init in -l$tlib" >&5
 ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
-#line 12178 "configure"
+#line 10931 "configure"
@@ -12185,7 +10938,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:12189: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10942: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12228,13 +10981,14 @@
 # Done checking Tcl/Tk
 # Enable ODBC option
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:12238: checking whether to use ODBC" >&5
+echo "configure:10992: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -12253,7 +11007,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12257: checking for location of ODBC includes" >&5
+echo "configure:11011: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12279,15 +11033,15 @@
 do
-echo "configure:12283: checking for $ac_hdr" >&5
+echo "configure:11037: checking for $ac_hdr" >&5
-#line 12286 "configure"
+#line 11040 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12291: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11045: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12321,7 +11075,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12325: checking for location of ODBC library" >&5
+echo "configure:11079: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12346,13 +11100,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12350: checking for SQLConnect in -lodbc" >&5
+echo "configure:11104: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 12356 "configure"
+#line 11110 "configure"
@@ -12363,7 +11117,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12367: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11121: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12388,13 +11142,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12392: checking for SQLConnect in -liodbc" >&5
+echo "configure:11146: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 12398 "configure"
+#line 11152 "configure"
@@ -12405,7 +11159,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12409: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11163: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12430,11 +11184,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12434: checking for ODBC library" >&5
+echo "configure:11188: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 12438 "configure"
+#line 11192 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -12442,7 +11196,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:12446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11200: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12491,7 +11245,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12495: checking whether to use FFTW" >&5
+echo "configure:11249: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -12510,7 +11264,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12514: checking for location of FFTW includes" >&5
+echo "configure:11268: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12536,15 +11290,15 @@
 do
-echo "configure:12540: checking for $ac_hdr" >&5
+echo "configure:11294: checking for $ac_hdr" >&5
-#line 12543 "configure"
+#line 11297 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12548: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11302: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12572,15 +11326,15 @@
 do
-echo "configure:12576: checking for $ac_hdr" >&5
+echo "configure:11330: checking for $ac_hdr" >&5
-#line 12579 "configure"
+#line 11333 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12584: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11338: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12608,15 +11362,15 @@
 do
-echo "configure:12612: checking for $ac_hdr" >&5
+echo "configure:11366: checking for $ac_hdr" >&5
-#line 12615 "configure"
+#line 11369 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12620: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11374: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12662,7 +11416,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12666: checking for location of FFTW library" >&5
+echo "configure:11420: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12687,13 +11441,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12691: checking for fftw_execute in -lfftw3" >&5
+echo "configure:11445: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12697 "configure"
+#line 11451 "configure"
@@ -12704,7 +11458,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:12708: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11462: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12729,13 +11483,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12733: checking for fftwnd_one in -lfftw" >&5
+echo "configure:11487: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 12739 "configure"
+#line 11493 "configure"
@@ -12746,7 +11500,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12750: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11504: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12771,13 +11525,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12775: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:11529: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12781 "configure"
+#line 11535 "configure"
@@ -12788,7 +11542,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12792: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12845,7 +11599,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12849: checking whether to use BLAS" >&5
+echo "configure:11603: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -12866,7 +11620,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12870: checking for location of BLAS includes" >&5
+echo "configure:11624: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12886,7 +11640,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12890: checking for location of BLAS library" >&5
+echo "configure:11644: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12912,15 +11666,15 @@
 do
-echo "configure:12916: checking for $ac_hdr" >&5
+echo "configure:11670: checking for $ac_hdr" >&5
-#line 12919 "configure"
+#line 11673 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12924: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11678: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12955,13 +11709,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12959: checking for dnrm2_ in -lblas" >&5
+echo "configure:11713: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 12965 "configure"
+#line 11719 "configure"
@@ -12972,7 +11726,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12976: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11730: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12991,13 +11745,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:12995: checking for dnrm2_ in -lblas" >&5
+echo "configure:11749: checking for dnrm2_ in -lblas" >&5
 ac_save_LIBS="$LIBS"
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 13001 "configure"
+#line 11755 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -13008,7 +11762,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:13012: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11766: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -13052,13 +11806,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:13056: checking for ATL_xerbla in -latlas" >&5
+echo "configure:11810: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 13062 "configure"
+#line 11816 "configure"
@@ -13069,7 +11823,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:13073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11827: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13084,13 +11838,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo "$ac_t""yes" 1>&6
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:13088: checking for sgemm_ in -lf77blas" >&5
+echo "configure:11842: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 13094 "configure"
+#line 11848 "configure"
@@ -13101,7 +11855,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13116,13 +11870,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:13120: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:11874: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 13126 "configure"
+#line 11880 "configure"
@@ -13133,7 +11887,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:13137: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11891: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13179,16 +11933,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:13183: checking for sgemm in $vlib_flags" >&5
+echo "configure:11937: checking for sgemm in $vlib_flags" >&5
-#line 13185 "configure"
+#line 11939 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:13192: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11946: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -13206,13 +11960,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:13210: checking for sgemm_ in -lblas" >&5
+echo "configure:11964: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 13216 "configure"
+#line 11970 "configure"
@@ -13223,7 +11977,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13227: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11981: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13238,13 +11992,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:13242: checking for dgemm_ in -ldgemm" >&5
+echo "configure:11996: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 13248 "configure"
+#line 12002 "configure"
@@ -13255,7 +12009,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13259: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12013: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13270,13 +12024,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13274: checking for sgemm_ in -lsgemm" >&5
+echo "configure:12028: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 13280 "configure"
+#line 12034 "configure"
@@ -13287,7 +12041,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13291: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13321,13 +12075,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13325: checking for acosp in -lsunmath" >&5
+echo "configure:12079: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 13331 "configure"
+#line 12085 "configure"
@@ -13338,7 +12092,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:13342: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12096: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13353,13 +12107,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13357: checking for sgemm_ in -lsunperf" >&5
+echo "configure:12111: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 13363 "configure"
+#line 12117 "configure"
@@ -13370,7 +12124,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13374: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12128: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13400,13 +12154,13 @@
 # Generic BLAS library
-echo "configure:13404: checking for sgemm_ in -lblas" >&5
+echo "configure:12158: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 13410 "configure"
+#line 12164 "configure"
@@ -13417,7 +12171,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13421: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13456,7 +12210,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13460: checking whether to use LAPACK" >&5
+echo "configure:12214: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -13481,7 +12235,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13485: checking for location of LAPACK includes" >&5
+echo "configure:12239: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13501,7 +12255,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13505: checking for location of LAPACK library" >&5
+echo "configure:12259: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13527,15 +12281,15 @@
 do
-echo "configure:13531: checking for $ac_hdr" >&5
+echo "configure:12285: checking for $ac_hdr" >&5
-#line 13534 "configure"
+#line 12288 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13539: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12293: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13567,10 +12321,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13571: checking for dsegv_" >&5
+echo "configure:12325: checking for dsegv_" >&5
-#line 13574 "configure"
+#line 12328 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -13593,7 +12347,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13597: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12351: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -13620,13 +12374,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13624: checking for desgv_ in -llapack" >&5
+echo "configure:12378: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 13630 "configure"
+#line 12384 "configure"
@@ -13637,7 +12391,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13641: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12395: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13669,13 +12423,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13673: checking for dgesv_ in -llapack" >&5
+echo "configure:12427: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 13679 "configure"
+#line 12433 "configure"
@@ -13686,7 +12440,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13690: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12444: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13705,13 +12459,13 @@
-echo "configure:13709: checking for dgesv_ in -llapack" >&5
+echo "configure:12463: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 13715 "configure"
+#line 12469 "configure"
 #include "confdefs.h"
@@ -13722,7 +12476,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13726: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12480: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13778,7 +12532,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13782: checking whether to use Cairo" >&5
+echo "configure:12536: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -13804,7 +12558,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:13808: checking for location of cairo includes" >&5
+echo "configure:12562: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -13830,15 +12584,15 @@
 do
-echo "configure:13834: checking for $ac_hdr" >&5
+echo "configure:12588: checking for $ac_hdr" >&5
-#line 13837 "configure"
+#line 12591 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13842: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12596: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13874,7 +12628,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:13878: checking for location of cairo library" >&5
+echo "configure:12632: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -13894,7 +12648,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:13898: checking for cairo linking flags" >&5
+echo "configure:12652: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -13910,10 +12664,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13914: checking for cairo_create" >&5
+echo "configure:12668: checking for cairo_create" >&5
-#line 13917 "configure"
+#line 12671 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -13936,7 +12690,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13940: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12694: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -13970,10 +12724,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:13974: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:12728: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 13977 "configure"
+#line 12731 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -13996,7 +12750,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12754: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -14029,10 +12783,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:14033: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:12787: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 14036 "configure"
+#line 12790 "configure"
     which can conflict with char cairo_xlib_surface_get_xrender_format(); below.  */
@@ -14055,7 +12809,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14059: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12813: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
 else
@@ -14097,7 +12851,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:14101: checking whether to use FreeType" >&5
+echo "configure:12855: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -14116,7 +12870,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:14120: checking for location of FreeType includes" >&5
+echo "configure:12874: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -14142,15 +12896,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:14146: checking for $ac_hdr" >&5
+echo "configure:12900: checking for $ac_hdr" >&5
-#line 14149 "configure"
+#line 12903 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:14154: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12908: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -14184,7 +12938,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:14188: checking for location of FreeType library" >&5
+echo "configure:12942: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -14209,13 +12963,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:14213: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:12967: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 14219 "configure"
+#line 12973 "configure"
@@ -14226,7 +12980,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:14230: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14267,7 +13021,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:14271: checking whether to use NLS" >&5
+echo "configure:13025: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -14287,10 +13041,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:14291: checking for gettext" >&5
+echo "configure:13045: checking for gettext" >&5
-#line 14294 "configure"
+#line 13048 "configure"
     which can conflict with char gettext(); below.  */
@@ -14313,7 +13067,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14317: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13071: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -14331,13 +13085,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:14335: checking for gettext in -lintl" >&5
+echo "configure:13089: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 14341 "configure"
+#line 13095 "configure"
@@ -14348,7 +13102,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:14352: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13106: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14383,7 +13137,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:14387: checking whether to use C++" >&5
+echo "configure:13141: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -14399,7 +13153,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:14403: checking for $ac_word" >&5
+echo "configure:13157: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -14428,7 +13182,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:14432: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:13186: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -14439,12 +13193,12 @@
 cat > conftest.$ac_ext << EOF
-#line 14443 "configure"
+#line 13197 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:14448: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13202: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -14470,19 +13224,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:14474: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:13228: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:14479: checking whether we are using GNU C++" >&5
+echo "configure:13233: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14486: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13240: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -14500,7 +13254,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:14504: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:13258: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -14541,7 +13295,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:14545: checking whether to use openDWG" >&5
+echo "configure:13299: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -14561,7 +13315,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:14565: checking for location of openDGW includes" >&5
+echo "configure:13319: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -14587,15 +13341,15 @@
 do
-echo "configure:14591: checking for $ac_hdr" >&5
+echo "configure:13345: checking for $ac_hdr" >&5
-#line 14594 "configure"
+#line 13348 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14599: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13353: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14629,7 +13383,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:14633: checking for location of openDWG library" >&5
+echo "configure:13387: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -14670,7 +13424,7 @@
 echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:14674: checking whether to use POSIX threads" >&5
+echo "configure:13428: checking whether to use POSIX threads" >&5
 echo "$ac_t"""$with_pthread"" 1>&6
 case "$with_pthread" in
 	"no")	USE_PTHREAD=	;;
@@ -14690,7 +13444,7 @@
 echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:14694: checking for location of POSIX threads includes" >&5
+echo "configure:13448: checking for location of POSIX threads includes" >&5
 case "$with_pthread_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -14716,15 +13470,15 @@
 do
-echo "configure:14720: checking for $ac_hdr" >&5
+echo "configure:13474: checking for $ac_hdr" >&5
-#line 14723 "configure"
+#line 13477 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14728: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13482: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14758,7 +13512,7 @@
 echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:14762: checking for location of POSIX threads library" >&5
+echo "configure:13516: checking for location of POSIX threads library" >&5
 case "$with_pthread_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -14783,10 +13537,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:14787: checking for pthread_create" >&5
+echo "configure:13541: checking for pthread_create" >&5
-#line 14790 "configure"
+#line 13544 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char pthread_create(); below.  */
@@ -14809,7 +13563,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14813: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13567: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_pthread_create=yes"
 else
@@ -14836,13 +13590,13 @@
 echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:14840: checking for pthread_create in -lpthread" >&5
+echo "configure:13594: checking for pthread_create in -lpthread" >&5
 ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
 LIBS="-lpthread  $LIBS"
-#line 14846 "configure"
+#line 13600 "configure"
@@ -14853,7 +13607,7 @@
 pthread_create()
 ; return 0; }
 EOF
-if { (eval echo configure:14857: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13611: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14909,7 +13663,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14913: checking for special C compiler options needed for large files" >&5
+echo "configure:13667: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -14917,7 +13671,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 14921 "configure"
+#line 13675 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -14933,7 +13687,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14937: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13691: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   echo "configure: failed program was:" >&5
@@ -14942,7 +13696,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 14946 "configure"
+#line 13700 "configure"
@@ -14958,7 +13712,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14962: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13716: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -14978,11 +13732,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:14982: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13736: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 14986 "configure"
+#line 13740 "configure"
@@ -14998,14 +13752,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15002: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13756: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   cat conftest.$ac_ext >&5
   rm -rf conftest*
-#line 15009 "configure"
+#line 13763 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -15023,7 +13777,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15027: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13781: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -15042,11 +13796,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15046: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13800: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 15050 "configure"
+#line 13804 "configure"
@@ -15062,14 +13816,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15066: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13820: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15073 "configure"
+#line 13827 "configure"
 #define _LARGE_FILES 1
@@ -15087,7 +13841,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15091: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13845: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -15106,25 +13860,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15110: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13864: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 15114 "configure"
+#line 13868 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15121: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13875: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15128 "configure"
+#line 13882 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -15133,7 +13887,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15137: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13891: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -15154,10 +13908,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:15158: checking if system supports Large Files at all" >&5
+echo "configure:13912: checking if system supports Large Files at all" >&5
-#line 15161 "configure"
+#line 13915 "configure"
 #include <stdio.h>
@@ -15189,7 +13943,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:15193: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13947: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -15218,7 +13972,7 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:15222: checking whether to use Python" >&5
+echo "configure:13976: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
@@ -15239,7 +13993,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
-echo "configure:15243: checking for $ac_word" >&5
+echo "configure:13997: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -15281,15 +14035,15 @@
 do
-echo "configure:15285: checking for $ac_hdr" >&5
+echo "configure:14039: checking for $ac_hdr" >&5
-#line 15288 "configure"
+#line 14042 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15293: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14047: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15337,7 +14091,7 @@
   # Extract the first word of "swig", so it can be a program name with args.
 set dummy swig; ac_word=$2
-echo "configure:15341: checking for $ac_word" >&5
+echo "configure:14095: checking for $ac_word" >&5
 case "$SWIG" in
@@ -15399,7 +14153,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:15403: checking whether to use wxWidgets" >&5
+echo "configure:14157: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -15420,7 +14174,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:15424: checking for $ac_word" >&5
+echo "configure:14178: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -15468,7 +14222,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:15472: checking wxWidgets version" >&5
+echo "configure:14226: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -15491,15 +14245,15 @@
 do
-echo "configure:15495: checking for $ac_hdr" >&5
+echo "configure:14249: checking for $ac_hdr" >&5
-#line 15498 "configure"
+#line 14252 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15503: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14257: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15695,30 +14449,17 @@
 s%@GRASS_LIB_PREFIX@%$GRASS_LIB_PREFIX%g
 s%@GRASS_LIB_SUFFIX@%$GRASS_LIB_SUFFIX%g
 s%@GRASS_LIBRARY_TYPE@%$GRASS_LIBRARY_TYPE%g
-s%@RANLIB@%$RANLIB%g
-s%@AR@%$AR%g
-s%@CPP@%$CPP%g
 s%@PLAT_OBJS@%$PLAT_OBJS%g
-s%@CFLAGS_DEBUG@%$CFLAGS_DEBUG%g
-s%@CFLAGS_OPTIMIZE@%$CFLAGS_OPTIMIZE%g
-s%@CFLAGS_WARNING@%$CFLAGS_WARNING%g
-s%@EXTRA_CFLAGS@%$EXTRA_CFLAGS%g
-s%@LDFLAGS_DEBUG@%$LDFLAGS_DEBUG%g
-s%@LDFLAGS_OPTIMIZE@%$LDFLAGS_OPTIMIZE%g
 s%@CC_SEARCH_FLAGS@%$CC_SEARCH_FLAGS%g
 s%@LD_SEARCH_FLAGS@%$LD_SEARCH_FLAGS%g
 s%@LD_LIBRARY_PATH_VAR@%$LD_LIBRARY_PATH_VAR%g
-s%@STLIB_LD@%$STLIB_LD%g
 s%@SHLIB_LD@%$SHLIB_LD%g
-s%@GRASS_SHLIB_LD_EXTRAS@%$GRASS_SHLIB_LD_EXTRAS%g
 s%@SHLIB_LD_FLAGS@%$SHLIB_LD_FLAGS%g
 s%@SHLIB_LD_LIBS@%$SHLIB_LD_LIBS%g
 s%@SHLIB_CFLAGS@%$SHLIB_CFLAGS%g
 s%@SHLIB_SUFFIX@%$SHLIB_SUFFIX%g
-s%@MAKE_LIB@%$MAKE_LIB%g
-s%@MAKE_STUB_LIB@%$MAKE_STUB_LIB%g
-s%@INSTALL_LIB@%$INSTALL_LIB%g
-s%@INSTALL_STUB_LIB@%$INSTALL_STUB_LIB%g
+s%@STLIB_LD@%$STLIB_LD%g
+s%@STLIB_SUFFIX@%$STLIB_SUFFIX%g
 s%@INCLUDE_DIRS@%$INCLUDE_DIRS%g
 s%@LIBRARY_DIRS@%$LIBRARY_DIRS%g
 s%@INSTALL_PROGRAM@%$INSTALL_PROGRAM%g
@@ -15729,8 +14470,11 @@
 s%@LEXPATH@%$LEXPATH%g
 s%@YACC@%$YACC%g
 s%@YACCPATH@%$YACCPATH%g
+s%@RANLIB@%$RANLIB%g
+s%@AR@%$AR%g
 s%@ENV@%$ENV%g
 s%@PERL@%$PERL%g
+s%@CPP@%$CPP%g
 s%@CROSS_COMPILING@%$CROSS_COMPILING%g
 s%@X_CFLAGS@%$X_CFLAGS%g
 s%@X_LIBS@%$X_LIBS%g
@@ -15805,6 +14549,7 @@
 s%@OPENGLINC@%$OPENGLINC%g
 s%@OPENGLLIB@%$OPENGLLIB%g
 s%@OPENGLULIB@%$OPENGLULIB%g
+s%@USE_TCLTK@%$USE_TCLTK%g
 s%@TCLINCDIR@%$TCLINCDIR%g
 s%@TKINCDIR@%$TKINCDIR%g
 s%@TCLTKLIBPATH@%$TCLTKLIBPATH%g
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in	2009-11-14 12:03:37 UTC (rev 39730)
+++ grass/trunk/configure.in	2009-11-14 18:31:05 UTC (rev 39731)
@@ -1303,6 +1303,7 @@
 TKINCDIR=$TCLINCDIR
+AC_SUBST(USE_TCLTK)
 AC_SUBST(TCLINCDIR)
 AC_SUBST(TKINCDIR)
 AC_SUBST(TCLTKLIBPATH)
Modified: grass/trunk/include/Make/Platform.make.in
--- grass/trunk/include/Make/Platform.make.in	2009-11-14 12:03:37 UTC (rev 39730)
+++ grass/trunk/include/Make/Platform.make.in	2009-11-14 18:31:05 UTC (rev 39731)
@@ -63,12 +63,11 @@
 #static libs:
 STLIB_LD            = @STLIB_LD@
 STLIB_PREFIX        = lib
-STLIB_SUFFIX        = .a
+STLIB_SUFFIX        = @STLIB_SUFFIX@
 #shared libs
 SHLIB_PREFIX        = lib
 SHLIB_LD            = @SHLIB_LD@
-SHLIB_LD_EXTRAS     = @GRASS_SHLIB_LD_EXTRAS@
 SHLIB_LD_FLAGS      = @SHLIB_LD_FLAGS@
 SHLIB_LD_LIBS       = @SHLIB_LD_LIBS@
 SHLIB_CFLAGS        = @SHLIB_CFLAGS@
