[GRASS-SVN] r39761 - grass/trunk/lib/segment
Thu Nov 19 04:19:30 EST 2009
Author: mmetz
Date: 2009-11-19 04:19:28 -0500 (Thu, 19 Nov 2009)
New Revision: 39761
   grass/trunk/lib/segment/address.c
   grass/trunk/lib/segment/pagein.c
   grass/trunk/lib/segment/rbtree.c
   grass/trunk/lib/segment/setup.c
cosmetics
Modified: grass/trunk/lib/segment/address.c
--- grass/trunk/lib/segment/address.c	2009-11-19 09:09:45 UTC (rev 39760)
+++ grass/trunk/lib/segment/address.c	2009-11-19 09:19:28 UTC (rev 39761)
@@ -25,6 +25,11 @@
 	*index =
 	    ((row - (seg_r << SEG->srowbits)) << SEG->scolbits) + col -
 	    (seg_c << SEG->scolbits);
+	*n = (row >> SEG->srowbits) * SEG->spr + (col >> SEG->scolbits);
+	*index = ((row & (SEG->srows - 1)) << SEG->scolbits) + (col & (SEG->scols - 1));
     /* for simple arrays */
     else {
Modified: grass/trunk/lib/segment/pagein.c
--- grass/trunk/lib/segment/pagein.c	2009-11-19 09:09:45 UTC (rev 39760)
+++ grass/trunk/lib/segment/pagein.c	2009-11-19 09:19:28 UTC (rev 39761)
@@ -93,7 +93,6 @@
 	cur = SEG->freeslot[--SEG->nfreeslots];
     /* read in the segment */
     SEG->scb[cur].n = n;
     SEG->scb[cur].dirty = 0;
Modified: grass/trunk/lib/segment/rbtree.c
--- grass/trunk/lib/segment/rbtree.c	2009-11-19 09:09:45 UTC (rev 39760)
+++ grass/trunk/lib/segment/rbtree.c	2009-11-19 09:19:28 UTC (rev 39761)
@@ -83,11 +83,8 @@
     else {
 	struct RB_NODE head = { 0 };	/* False tree root */
 	struct RB_NODE *g, *t;	/* Grandparent & parent */
 	struct RB_NODE *p, *q;	/* Iterator & parent */
 	int dir = 0, last = 0;
 	/* Set up helpers */
@@ -245,7 +242,7 @@
 void *rbtree_find(struct RB_TREE *tree, const void *data)
     struct RB_NODE *curr_node = tree->root;
-    int cmp = 0;
+    int cmp;
     assert(tree && data);
@@ -253,9 +250,8 @@
 	cmp = tree->rb_compare(curr_node->data, data);
 	if (cmp == 0)
 	    return curr_node->data;	/* found */
-	else {
-	    curr_node = curr_node->link[cmp < 0];
+	curr_node = curr_node->link[cmp < 0];
     return NULL;
Modified: grass/trunk/lib/segment/setup.c
--- grass/trunk/lib/segment/setup.c	2009-11-19 09:09:45 UTC (rev 39760)
+++ grass/trunk/lib/segment/setup.c	2009-11-19 09:19:28 UTC (rev 39761)
@@ -135,15 +135,18 @@
 int segment_compare(const void *sega, const void *segb)
-    SEGID *a, *b;
+    SEGID *a = (SEGID *) sega;
+    SEGID *b = (SEGID *) segb;
-    a = (SEGID *) sega;
-    b = (SEGID *) segb;
+    return a->n < b->n ? -1 : (a->n > b->n);
+    /* short version of
     if (a->n > b->n)
 	return 1;
     else if (a->n < b->n)
 	return -1;
     return 0;
