[GRASS-SVN] r39785 - grass/trunk/vector/lidar/v.outlier
Mon Nov 23 02:42:54 EST 2009
Author: mmetz
Date: 2009-11-23 02:42:49 -0500 (Mon, 23 Nov 2009)
New Revision: 39785
   grass/trunk/vector/lidar/v.outlier/main.c
fix for auxiliar table
Modified: grass/trunk/vector/lidar/v.outlier/main.c
--- grass/trunk/vector/lidar/v.outlier/main.c	2009-11-22 22:32:25 UTC (rev 39784)
+++ grass/trunk/vector/lidar/v.outlier/main.c	2009-11-23 07:42:49 UTC (rev 39785)
@@ -137,7 +137,8 @@
     Thres_Outlier = atof(Thres_O_opt->answer);
     /* Setting auxiliar table's name */
-    sprintf(table_name, "%s_aux", out_opt->answer);
+    /* sprintf(table_name, "%s_aux", out_opt->answer); */
+    sprintf(table_name, "Auxiliar_outlier_table");
     /* Checking vector names */
     Vect_check_input_output_name(in_opt->answer, out_opt->answer,
@@ -191,6 +192,12 @@
 	G_fatal_error(_("No database connection for driver <%s> is defined. Run db.connect."),
 		      dvr);
+    /*Something went wrong in a previous v.outlier execution */
+    if (db_table_exists(dvr, db, table_name)) {
+	if (P_Drop_Aux_Table(driver, table_name) != DB_OK)
+	    G_fatal_error(_("Old auxiliar table could not be dropped"));
     /* Setting regions and boxes */
     G_get_set_window(&original_reg);
     G_get_set_window(&elaboration_reg);
@@ -358,7 +365,7 @@
 	Vect_close(&Qgis);
-    G_done_msg("");
+    G_done_msg(" ");
     exit(EXIT_SUCCESS);
 }				/*!END MAIN */
