[GRASS-SVN] r39802 - grass/trunk/gui/scripts
Thu Nov 26 00:13:55 EST 2009
Author: glynn
Date: 2009-11-26 00:13:54 -0500 (Thu, 26 Nov 2009)
New Revision: 39802
Removed:
   grass/trunk/gui/scripts/d.path.sh
Remove d.path.sh
Deleted: grass/trunk/gui/scripts/d.path.sh
--- grass/trunk/gui/scripts/d.path.sh	2009-11-25 23:51:26 UTC (rev 39801)
+++ grass/trunk/gui/scripts/d.path.sh	2009-11-26 05:13:54 UTC (rev 39802)
@@ -1,186 +0,0 @@
-#!/bin/sh
-# MODULE:       d.path_wrapper.sh
-# AUTHOR(S):    Hamish Bowman  (Otago University, New Zealand)
-# PURPOSE:      Draw vector map to xmon before running d.path and pass opts
-# COPYRIGHT:    (c) 2007 by Hamish Bowman, and the GRASS Development Team
-#               This program is free software under the GNU General Public
-#               License (>=v2). Read the file COPYING that comes with GRASS
-#               for details.
-# Notes:
-#   Created with "d.path --script" from GRASS 6.3-CVS 6 March 2007
-#   Be sure menu entry runs guarantee_xmon first. for example:
-#     "guarantee_xmon; d.path_wrapper.sh -b --ui"
-#   d.path is interactive with the xmon, but does not need to run in a xterm
-#%Module
-#% description: Find shortest path for selected starting and ending node
-#% keywords: display, networking
-#%End
-#%Flag
-#% key: g
-#% description: Use geodesic calculation for longitude-latitude locations
-#%End
-#%Flag
-#% key: b
-#% description: Render bold lines
-#% guisection: Rendering
-#%End
-#%Option
-#% key: map
-#% type: string
-#% required: yes
-#% multiple: no
-#% key_desc: name
-#% description: Name of input vector map
-#% gisprompt: old,vector,vector
-#%End
-#%Option
-#% key: type
-#% type: string
-#% required: no
-#% multiple: yes
-#% options: line,boundary
-#% label: Type
-#% description: Arc type
-#% answer: line,boundary
-#%End
-#%Option
-#% key: coor
-#% type: string
-#% required: no
-#% multiple: no
-#% key_desc: x1,y1,x2,y2
-#% description: Starting and ending coordinates
-#%End
-#%Option
-#% key: alayer
-#% type: integer
-#% required: no
-#% multiple: no
-#% label: Layer number
-#% description: Arc layer
-#% answer: 1
-#%End
-#%Option
-#% key: nlayer
-#% type: integer
-#% required: no
-#% multiple: no
-#% description: Node layer
-#% answer: 2
-#%End
-#%Option
-#% key: afcol
-#% type: string
-#% required: no
-#% multiple: no
-#% description: Arc forward/both direction(s) cost column
-#%End
-#%Option
-#% key: abcol
-#% type: string
-#% required: no
-#% multiple: no
-#% description: Arc backward direction cost column
-#%End
-#%Option
-#% key: ncol
-#% type: string
-#% required: no
-#% multiple: no
-#% description: Node cost column
-#%End
-#%Option
-#% key: color
-#% type: string
-#% required: no
-#% multiple: no
-#% description: Original line color
-#% answer: black
-#% gisprompt: color,grass,color
-#%End
-#%Option
-#% key: hcolor
-#% type: string
-#% required: no
-#% multiple: no
-#% description: Highlight color
-#% answer: red
-#%End
-#%Option
-#% key: bgcolor
-#% type: string
-#% required: no
-#% multiple: no
-#% description: Background color
-#% answer: white
-#%End
-if [ -z "$GISBASE" ] ; then
-    echo "You must be in GRASS GIS to run this program." 1>&2
-    exit 1
-fi
-if [ "$1" != "@ARGS_PARSED@" ] ; then
-    exec g.parser "$0" "$@"
-fi
-d.vect map="$GIS_OPT_MAP" color="$GIS_OPT_COLOR"
-if [ "$GIS_FLAG_G" -eq 1 ] ; then
-    flag_g="-g"
-else
-    flag_g=""
-fi
-if [ "$GIS_FLAG_B" -eq 1 ] ; then
-    flag_b="-b"
-else
-    flag_b=""
-fi
-if [ -n "$GIS_OPT_COOR" ] ; then
-    opt_coor="coor=$GIS_OPT_COOR"
-else
-    opt_coor=""
-fi
-if [ -n "$GIS_OPT_AFCOL" ] ; then
-    opt_afcol="afcol=$GIS_OPT_AFCOL"
-else
-    opt_afcol=""
-fi
-if [ -n "$GIS_OPT_ABCOL" ] ; then
-    opt_abcol="abcol=$GIS_OPT_ABCOL"
-else
-    opt_abcol=""
-fi
-if [ -n "$GIS_OPT_NCOL" ] ; then
-    opt_ncol="ncol=$GIS_OPT_NCOL"
-else
-    opt_ncol=""
-fi
-exec d.path $flag_g $flag_b \
-	map="$GIS_OPT_MAP" \
-	type="$GIS_OPT_TYPE" \
-	$opt_coor \
-	alayer="$GIS_OPT_ALAYER" \
-	nlayer="$GIS_OPT_NLAYER" \
-	$opt_afcol $opt_abcol $opt_ncol \
-	color="$GIS_OPT_COLOR" \
-	hcolor="$GIS_OPT_HCOLOR" \
-	bgcolor="$GIS_OPT_BGCOLOR"
