[GRASS-SVN] r39807 - grass/trunk/vector/v.db.select
Thu Nov 26 13:38:41 EST 2009
Author: martinl
Date: 2009-11-26 13:38:41 -0500 (Thu, 26 Nov 2009)
New Revision: 39807
   grass/trunk/vector/v.db.select/main.c
remove out-dated comment
Modified: grass/trunk/vector/v.db.select/main.c
--- grass/trunk/vector/v.db.select/main.c	2009-11-26 18:38:37 UTC (rev 39806)
+++ grass/trunk/vector/v.db.select/main.c	2009-11-26 18:38:41 UTC (rev 39807)
@@ -227,7 +227,6 @@
 	if (r_flag->answer) {
 	    /* get minimal region extent */
-	    /* TODO: support layer name */
 	    Vect_cidx_find_all(&Map, Vect_get_field_number(&Map, field_opt->answer), -1, cat, list_lines);
 	    for (i = 0; i < list_lines->n_values; i++) {
 		line = list_lines->value[i];
