[GRASS-SVN] r39813 - grass/trunk/vector/v.class
Thu Nov 26 15:52:45 EST 2009
Author: martinl
Date: 2009-11-26 15:52:44 -0500 (Thu, 26 Nov 2009)
New Revision: 39813
   grass/trunk/vector/v.class/main.c
v.class: OGR support (read access)
Modified: grass/trunk/vector/v.class/main.c
--- grass/trunk/vector/v.class/main.c	2009-11-26 20:43:03 UTC (rev 39812)
+++ grass/trunk/vector/v.class/main.c	2009-11-26 20:52:44 UTC (rev 39813)
@@ -4,15 +4,15 @@
  * MODULE:       v.class
  * AUTHOR(S):    Moritz Lennert
+ *               OGR support by Martin Landa <landa.martin gmail.com>
  * PURPOSE:      Create data classes, mainly for thematic mapping
- * COPYRIGHT:    (C) 2004-2007 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2004-2009 by the GRASS Development Team
- *               This program is free software under the
- *               GNU General Public License (>=v2).
- *               Read the file COPYING that comes with GRASS
- *               for details.
+ *               This program is free software under the GNU General
+ *               Public License (>=v2).  Read the file COPYING that
+ *               comes with GRASS for details.
 #include <stdlib.h>
@@ -42,6 +42,7 @@
     module = G_define_module();
     G_add_keyword(_("vector"));
+    G_add_keyword(_("attributes"));
     G_add_keyword(_("statistics"));
     module->description =
 	_("Classifies attribute data, e.g. for thematic mapping");
@@ -50,11 +51,8 @@
     field_opt = G_define_standard_option(G_OPT_V_FIELD);
-    col_opt = G_define_option();
-    col_opt->key = "column";
-    col_opt->type = TYPE_STRING;
+    col_opt = G_define_standard_option(G_OPT_DB_COLUMN);
     col_opt->required = YES;
-    col_opt->multiple = NO;
     col_opt->description = _("Column name or expression");
     where_opt = G_define_standard_option(G_OPT_DB_WHERE);
@@ -87,13 +85,13 @@
     G_gisinit(argv[0]);
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
-    ofield = atoi(field_opt->answer);
     /* open input vector */
     Vect_set_open_level(2);
-    Vect_open_old(&Map, map_opt->answer, "");
+    Vect_open_old2(&Map, map_opt->answer, "", field_opt->answer);
+    ofield = Vect_get_field_number(&Map, field_opt->answer);
     /* Read attributes */
     db_CatValArray_init(&Cvarr);
     Fi = Vect_get_field(&Map, ofield);
@@ -105,7 +103,7 @@
     Driver = db_start_driver_open_database(Fi->driver, Fi->database);
     if (Driver == NULL)
-	G_fatal_error("Unable to open database <%s> by driver <%s>",
+	G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
 		      Fi->database, Fi->driver);
     /* Note: do not check if the column exists in the table because it may be an expression */
@@ -126,7 +124,7 @@
     ret = db_CatValArray_sort_by_value(&Cvarr);
     if (ret == DB_FAILED)
-	G_fatal_error("Could not sort array of values..");
+	G_fatal_error(_("Unable to sort array of values"));
     data = (double *)G_malloc((nrec) * sizeof(double));
@@ -160,7 +158,9 @@
     if (G_strcasecmp(algo_opt->answer, "dis") == 0 && finfo < 3.84148)
-	G_warning(_("The discontinuities algorithm indicates that some class breaks are not statistically significant at alpha=0.05. You are advised to reduce the number of classes."));
+	G_warning(_("The discontinuities algorithm indicates that some "
+		    "class breaks are not statistically significant at "
+		    "alpha=0.05. You are advised to reduce the number of classes."));
     /*output to be piped to other modules ? */
     if (shell_flag->answer) {
@@ -214,11 +214,8 @@
 	fprintf(stdout, _("\nNote: Minimum of first class is including\n\n"));
     fflush(stdout);
     exit(EXIT_SUCCESS);
