[GRASS-SVN] r39820 - grass/trunk/scripts/v.db.addcolumn
Thu Nov 26 17:32:44 EST 2009
Author: martinl
Date: 2009-11-26 17:32:43 -0500 (Thu, 26 Nov 2009)
New Revision: 39820
Added:
   grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.html
   grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.py
Removed:
   grass/trunk/scripts/v.db.addcolumn/v.db.addcol.html
   grass/trunk/scripts/v.db.addcolumn/v.db.addcol.py
v.db.addcol renamed to v.db.addcolumn
Deleted: grass/trunk/scripts/v.db.addcolumn/v.db.addcol.html
--- grass/trunk/scripts/v.db.addcolumn/v.db.addcol.html	2009-11-26 21:57:08 UTC (rev 39819)
+++ grass/trunk/scripts/v.db.addcolumn/v.db.addcol.html	2009-11-26 22:32:43 UTC (rev 39820)
@@ -1,47 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>v.db.addcolumn</em> adds one or more column(s) to the attribute table
-connected to a given vector map. It automatically checks the connection for the
-specified layer.
-<h2>NOTES</h2>
-v.db.addcolumn is a front-end to <em>db.execute</em> to allow easier usage.
-The supported types of columns depend on the database backend. However, all
-backends should support VARCHAR, INT, DOUBLE PRECISION and DATE. The default
-dbf backend supports only these types.
-The existing database connection(s) can be verified with <em>v.db.connect</em>.
-<h2>EXAMPLES</h2>
-Adding a single column:<br>
-<div class="code"><pre>
-v.db.addcolumn sentiero_brenta_points columns="slope double precision"
-v.info -c sentiero_brenta_points
-</pre></div>
-<p>
-Adding two columns:<br>
-v.db.addcolumn sentiero_brenta_points columns="slope double precision,myname varchar(15)"
-</pre></div>
-<h2>SEE ALSO</h2>
-<em><a HREF="db.execute.html">db.execute</a></em>,
-<em><a HREF="v.db.addtable.html">v.db.addtable</a></em>,
-<em><a HREF="v.db.connect.html">v.db.connect</a></em>,
-<em><a HREF="v.db.dropcolumn.html">v.db.dropcolumn</a></em>,
-<em><a HREF="v.db.droptable.html">v.db.droptable</a></em>,
-<em><a HREF="v.db.select.html">v.db.select</a></em>,
-<em><a HREF="v.db.update.html">v.db.update</a></em>
-<h2>AUTHOR</h2>
-Moritz Lennert (mlennert at club.worldonline.be)
-<p><i>Last changed: $Date$</i>
Deleted: grass/trunk/scripts/v.db.addcolumn/v.db.addcol.py
--- grass/trunk/scripts/v.db.addcolumn/v.db.addcol.py	2009-11-26 21:57:08 UTC (rev 39819)
+++ grass/trunk/scripts/v.db.addcolumn/v.db.addcol.py	2009-11-26 22:32:43 UTC (rev 39820)
@@ -1,92 +0,0 @@
-#!/usr/bin/env python
-# MODULE:       v.db.addcolumnumn
-# AUTHOR(S):   	Moritz Lennert
-#               Converted to Python by Glynn Clements
-# PURPOSE:      interface to db.execute to add a column to the attribute table
-#               connected to a given vector map
-# COPYRIGHT:    (C) 2005 by the GRASS Development Team
-#               This program is free software under the GNU General Public
-#               License (>=v2). Read the file COPYING that comes with GRASS
-#               for details.
-#%Module
-#%  description: Adds one or more columns to the attribute table connected to a given vector map.
-#%  keywords: vector
-#%  keywords: database
-#%  keywords: attribute table
-#%End
-#%option
-#% key: map
-#% type: string
-#% gisprompt: old,vector,vector
-#% key_desc : name
-#% description: Vector map for which to edit attribute table
-#% required : yes
-#%end
-#%option
-#% key: layer
-#% type: integer
-#% description: Layer where to add column
-#% answer: 1
-#% required : no
-#%end
-#%option
-#% key: columns
-#% type: string
-#% description: Name and type of the new column(s) ('name type [,name type, ...]' - types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE)
-#% required : yes
-#%end
-import sys
-import os
-import grass.script as grass
-def main():
-    map = options['map']
-    layer = options['layer']
-    columns = options['columns']
-    columns = [col.strip() for col in columns.split(',')]
-    # does map exist in CURRENT mapset?
-    mapset = grass.gisenv()['MAPSET']
-    exists = bool(grass.find_file(map, element = 'vector', mapset = mapset)['file'])
-    if not exists:
-	grass.fatal(_("Vector map <%s> not found in current mapset") % map)
-    try:
-        f = grass.vector_db(map)[int(layer)]
-    except KeyError:
-	grass.fatal(_("There is no table connected to this map. Run v.db.connect or v.db.addtable first."))
-    table = f['table']
-    database = f['database']
-    driver = f['driver']
-    colnum = len(columns)
-    for col in columns:
-	if not col:
-	    grass.fatal(_("There is an empty column. Did you leave a trailing comma?"))
-	p = grass.feed_command('db.execute', input = '-', database = database, driver = driver)
-	p.stdin.write("ALTER TABLE %s ADD COLUMN %s" % (table, col))
-	p.stdin.close()
-	if p.wait() != 0:
-	    grass.fatal(_("Unable to add column <%s>.") % col)
-    # write cmd history:
-    grass.vector_history(map)
-if __name__ == "__main__":
-    options, flags = grass.parser()
-    main()
Copied: grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.html (from rev 39817, grass/trunk/scripts/v.db.addcolumn/v.db.addcol.html)
--- grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.html	                        (rev 0)
+++ grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.html	2009-11-26 22:32:43 UTC (rev 39820)
@@ -0,0 +1,47 @@
+<h2>DESCRIPTION</h2>
+<em>v.db.addcolumn</em> adds one or more column(s) to the attribute table
+connected to a given vector map. It automatically checks the connection for the
+specified layer.
+<h2>NOTES</h2>
+v.db.addcolumn is a front-end to <em>db.execute</em> to allow easier usage.
+The supported types of columns depend on the database backend. However, all
+backends should support VARCHAR, INT, DOUBLE PRECISION and DATE. The default
+dbf backend supports only these types.
+The existing database connection(s) can be verified with <em>v.db.connect</em>.
+<h2>EXAMPLES</h2>
+Adding a single column:<br>
+<div class="code"><pre>
+v.db.addcolumn sentiero_brenta_points columns="slope double precision"
+v.info -c sentiero_brenta_points
+</pre></div>
+<p>
+Adding two columns:<br>
+v.db.addcolumn sentiero_brenta_points columns="slope double precision,myname varchar(15)"
+</pre></div>
+<h2>SEE ALSO</h2>
+<em><a HREF="db.execute.html">db.execute</a></em>,
+<em><a HREF="v.db.addtable.html">v.db.addtable</a></em>,
+<em><a HREF="v.db.connect.html">v.db.connect</a></em>,
+<em><a HREF="v.db.dropcolumn.html">v.db.dropcolumn</a></em>,
+<em><a HREF="v.db.droptable.html">v.db.droptable</a></em>,
+<em><a HREF="v.db.select.html">v.db.select</a></em>,
+<em><a HREF="v.db.update.html">v.db.update</a></em>
+<h2>AUTHOR</h2>
+Moritz Lennert (mlennert at club.worldonline.be)
+<p><i>Last changed: $Date$</i>
Copied: grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.py (from rev 39817, grass/trunk/scripts/v.db.addcolumn/v.db.addcol.py)
--- grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.py	                        (rev 0)
+++ grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.py	2009-11-26 22:32:43 UTC (rev 39820)
@@ -0,0 +1,92 @@
+#!/usr/bin/env python
+# MODULE:       v.db.addcolumnumn
+# AUTHOR(S):   	Moritz Lennert
+#               Converted to Python by Glynn Clements
+# PURPOSE:      interface to db.execute to add a column to the attribute table
+#               connected to a given vector map
+# COPYRIGHT:    (C) 2005 by the GRASS Development Team
+#               This program is free software under the GNU General Public
+#               License (>=v2). Read the file COPYING that comes with GRASS
+#               for details.
+#%Module
+#%  description: Adds one or more columns to the attribute table connected to a given vector map.
+#%  keywords: vector
+#%  keywords: database
+#%  keywords: attribute table
+#%End
+#%option
+#% key: map
+#% type: string
+#% gisprompt: old,vector,vector
+#% key_desc : name
+#% description: Vector map for which to edit attribute table
+#% required : yes
+#%end
+#%option
+#% key: layer
+#% type: integer
+#% description: Layer where to add column
+#% answer: 1
+#% required : no
+#%end
+#%option
+#% key: columns
+#% type: string
+#% description: Name and type of the new column(s) ('name type [,name type, ...]' - types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE)
+#% required : yes
+#%end
+import sys
+import os
+import grass.script as grass
+def main():
+    map = options['map']
+    layer = options['layer']
+    columns = options['columns']
+    columns = [col.strip() for col in columns.split(',')]
+    # does map exist in CURRENT mapset?
+    mapset = grass.gisenv()['MAPSET']
+    exists = bool(grass.find_file(map, element = 'vector', mapset = mapset)['file'])
+    if not exists:
+	grass.fatal(_("Vector map <%s> not found in current mapset") % map)
+    try:
+        f = grass.vector_db(map)[int(layer)]
+    except KeyError:
+	grass.fatal(_("There is no table connected to this map. Run v.db.connect or v.db.addtable first."))
+    table = f['table']
+    database = f['database']
+    driver = f['driver']
+    colnum = len(columns)
+    for col in columns:
+	if not col:
+	    grass.fatal(_("There is an empty column. Did you leave a trailing comma?"))
+	p = grass.feed_command('db.execute', input = '-', database = database, driver = driver)
+	p.stdin.write("ALTER TABLE %s ADD COLUMN %s" % (table, col))
+	p.stdin.close()
+	if p.wait() != 0:
+	    grass.fatal(_("Unable to add column <%s>.") % col)
+    # write cmd history:
+    grass.vector_history(map)
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    main()
