[GRASS-SVN] r39827 - grass/trunk/vector/v.extrude
Fri Nov 27 12:21:44 EST 2009
Author: martinl
Date: 2009-11-27 12:21:44 -0500 (Fri, 27 Nov 2009)
New Revision: 39827
   grass/trunk/vector/v.extrude/main.c
v.extrude: OGR support (read acccess)
Modified: grass/trunk/vector/v.extrude/main.c
--- grass/trunk/vector/v.extrude/main.c	2009-11-27 17:14:08 UTC (rev 39826)
+++ grass/trunk/vector/v.extrude/main.c	2009-11-27 17:21:44 UTC (rev 39827)
@@ -7,17 +7,16 @@
  *             Based on v.example by Radim Blazek
  *             Inspired by d.vect and v.drape
  *             Coding help and code cleaning by Markus Neteler
- *             Support for points added by Martin Landa (08/2007)
+ *             Support for points & OGR support added by Martin Landa (08/2007 / 2009)
  * PURPOSE:    "Extrudes" flat polygons and lines to 3D with defined height
  *              Useful for creating buildings for displaying with NVIZ
- * COPYRIGHT:  (C) 2005-2007 by the GRASS Development Team
+ * COPYRIGHT:  (C) 2005-2009 by the GRASS Development Team
- *             This program is free software under the
- *             GNU General Public License (>=v2).
- *             Read the file COPYING that comes with GRASS
- *             for details.
+ *             This program is free software under the GNU General
+ *             Public License (>=v2). Read the file COPYING that comes
+ *             with GRASS for details.
 #include <stdio.h>
@@ -42,6 +41,7 @@
     struct Map_info In, Out;
     struct line_pnts *Points;
     struct line_cats *Cats;
+    struct bound_box map_box;
     struct Cell_head window;
     struct cat_list *Clist;
@@ -69,17 +69,21 @@
     G_add_keyword(_("geometry"));
     G_add_keyword(_("3D"));
     module->description =
-	_("Extrudes flat vector object to 3D with defined height.");
+	_("Extrudes flat vector features to 3D with defined height.");
     t_flag = G_define_flag();
     t_flag->key = 't';
     t_flag->description = _("Trace elevation");
     old = G_define_standard_option(G_OPT_V_INPUT);
-    old->description = _("Name of input 2D vector map");
+    field_opt = G_define_standard_option(G_OPT_V_FIELD);
+    type_opt = G_define_standard_option(G_OPT_V_TYPE);
+    type_opt->answer = "point,line,boundary,area";
+    type_opt->options = "point,line,boundary,area";
     new = G_define_standard_option(G_OPT_V_OUTPUT);
-    new->description = _("Name of resulting 3D vector map");
     zshift = G_define_option();
     zshift->key = "zshift";
@@ -105,12 +109,6 @@
     hcolumn->multiple = NO;
     hcolumn->description = _("Name of attribute column with object heights");
-    type_opt = G_define_standard_option(G_OPT_V_TYPE);
-    type_opt->answer = "point,line,boundary,area";
-    type_opt->options = "point,line,boundary,area";
-    field_opt = G_define_standard_option(G_OPT_V_FIELD);
     G_gisinit(argv[0]);
     if (G_parser(argc, argv))
@@ -150,7 +148,7 @@
     Vect_open_new(&Out, new->answer, WITH_Z);
     /* opening old vector */
-    Vect_open_old(&In, old->answer, "");
+    Vect_open_old2(&In, old->answer, "", field_opt->answer);
     Vect_hist_copy(&In, &Out);
     Vect_hist_command(&Out);
@@ -250,7 +248,7 @@
 	i = 1;
 	/* loop through each line in the dataset */
 	nelements = Vect_get_num_lines(&In);
-	G_message(_("Extruding vector primitives..."));
+	G_message(_("Extruding features..."));
 	for (line = 1; line <= nelements; line++) {
 	    /* read line */
@@ -336,12 +334,16 @@
     Vect_set_comment(&Out, comment);
     G_free(comment);
+    Vect_get_map_box(&Out, &map_box);
     Vect_close(&In);
     Vect_close(&Out);
     Vect_destroy_line_struct(Points);
     Vect_destroy_cats_struct(Cats);
+    G_done_msg("T: %f B: %f.", map_box.T, map_box.B);
     exit(EXIT_SUCCESS);
