[GRASS-SVN] r39829 - grass/trunk/vector/v.hull
svn_grass at osgeo.org
Fri Nov 27 12:51:51 EST 2009
Author: martinl
Date: 2009-11-27 12:51:50 -0500 (Fri, 27 Nov 2009)
New Revision: 39829
Added:
grass/trunk/vector/v.hull/hull.c
grass/trunk/vector/v.hull/hull.h
grass/trunk/vector/v.hull/read.c
grass/trunk/vector/v.hull/write.c
Removed:
grass/trunk/vector/v.hull/chull.h
grass/trunk/vector/v.hull/chull.c
grass/trunk/vector/v.hull/main.c
v.hull: code reorganization + OGR support (read access)
Modified: grass/trunk/vector/v.hull/chull.c
--- grass/trunk/vector/v.hull/chull.c 2009-11-27 17:29:24 UTC (rev 39828)
+++ grass/trunk/vector/v.hull/chull.c 2009-11-27 17:51:50 UTC (rev 39829)
@@ -228,8 +228,6 @@
void writeVertices(struct Map_info *Map)
/* Pointers to vertices, edges, faces. */
- tVertex v;
- tEdge e;
tFace f;
double *px, *py, *pz;
double fx, fy, fz;
@@ -333,9 +331,8 @@
int DoubleTriangle(void)
- tVertex v0, v1, v2, v3, t;
+ tVertex v0, v1, v2, v3;
tFace f0, f1 = NULL;
- tEdge e0, e1, e2, s;
long int vol;
/* Find 3 noncollinear points. */
@@ -391,7 +388,6 @@
void ConstructHull(void)
tVertex v, vnext;
- long int vol;
bool changed; /* T if addition changes hull; not used. */
int i;
int numVertices;
Property changes on: grass/trunk/vector/v.hull/chull.c
___________________________________________________________________
Added: svn:keywords
+ Author Date Id
Deleted: grass/trunk/vector/v.hull/chull.h
--- grass/trunk/vector/v.hull/chull.h 2009-11-27 17:29:24 UTC (rev 39828)
+++ grass/trunk/vector/v.hull/chull.h 2009-11-27 17:51:50 UTC (rev 39829)
@@ -1,4 +0,0 @@
-#include <grass/vector.h>
-int make3DHull(double *X, double *Y, double *Z, int num_points,
- struct Map_info *Map);
Added: grass/trunk/vector/v.hull/hull.c
--- grass/trunk/vector/v.hull/hull.c (rev 0)
+++ grass/trunk/vector/v.hull/hull.c 2009-11-27 17:51:50 UTC (rev 39829)
@@ -0,0 +1,113 @@
+#include <grass/glocale.h>
+#include "hull.h"
+int rightTurn(struct Point *P, int i, int j, int k)
+ double a, b, c, d;
+ a = P[i].x - P[j].x;
+ b = P[i].y - P[j].y;
+ c = P[k].x - P[j].x;
+ d = P[k].y - P[j].y;
+ return a * d - b * c < 0;
+int cmpPoints(const void *v1, const void *v2)
+ struct Point *p1, *p2;
+ p1 = (struct Point *)v1;
+ p2 = (struct Point *)v2;
+ if (p1->x > p2->x)
+ return 1;
+ else if (p1->x < p2->x)
+ return -1;
+ else
+ return 0;
+int convexHull(struct Point *P, int numPoints, int **hull)
+ int pointIdx, upPoints, loPoints;
+ int *upHull, *loHull;
+ /* sort points in ascending x order */
+ qsort(P, numPoints, sizeof(struct Point), cmpPoints);
+ *hull = (int *)G_malloc(numPoints * 2 * sizeof(int));
+ /* compute upper hull */
+ upHull = *hull;
+ upHull[0] = 0;
+ upHull[1] = 1;
+ upPoints = 1;
+ for (pointIdx = 2; pointIdx < numPoints; pointIdx++) {
+ upPoints++;
+ upHull[upPoints] = pointIdx;
+ while (upPoints > 1 &&
+ !rightTurn(P, upHull[upPoints], upHull[upPoints - 1],
+ upHull[upPoints - 2])
+ upHull[upPoints - 1] = upHull[upPoints];
+ upPoints--;
+ /* compute lower hull, overwrite last point of upper hull */
+ loHull = &(upHull[upPoints]);
+ loHull[0] = numPoints - 1;
+ loHull[1] = numPoints - 2;
+ loPoints = 1;
+ for (pointIdx = numPoints - 3; pointIdx >= 0; pointIdx--) {
+ loPoints++;
+ loHull[loPoints] = pointIdx;
+ while (loPoints > 1 &&
+ !rightTurn(P, loHull[loPoints], loHull[loPoints - 1],
+ loHull[loPoints - 2])
+ loHull[loPoints - 1] = loHull[loPoints];
+ loPoints--;
+ G_debug(3, "numPoints:%d loPoints:%d upPoints:%d",
+ numPoints, loPoints, upPoints);
+ /* reclaim uneeded memory */
+ *hull = (int *)G_realloc(*hull, (loPoints + upPoints) * sizeof(int));
+ return loPoints + upPoints;
+void convexHull3d(struct Point *P, const int numPoints, struct Map_info *Map)
+ int error;
+ int i;
+ double *px;
+ double *py;
+ double *pz;
+ px = G_malloc(sizeof(double) * numPoints);
+ py = G_malloc(sizeof(double) * numPoints);
+ pz = G_malloc(sizeof(double) * numPoints);
+ for (i = 0; i < numPoints; i++) {
+ px[i] = (P)[i].x;
+ py[i] = (P)[i].y;
+ pz[i] = (P)[i].z;
+ /* make 3D hull */
+ error = make3DHull(px, py, pz, numPoints, Map);
+ if (error < 0) {
+ G_fatal_error(_("Simple planar hulls not implemented yet"));
+ G_free(px);
+ G_free(py);
+ G_free(pz);
Copied: grass/trunk/vector/v.hull/hull.h (from rev 39808, grass/trunk/vector/v.hull/chull.h)
--- grass/trunk/vector/v.hull/hull.h (rev 0)
+++ grass/trunk/vector/v.hull/hull.h 2009-11-27 17:51:50 UTC (rev 39829)
@@ -0,0 +1,23 @@
+#include <grass/vector.h>
+struct Point
+ double x;
+ double y;
+ double z;
+#define ALLOC_CHUNK 256
+int loadSiteCoordinates(struct Map_info *, struct Point **, int,
+ struct Cell_head *, int);
+int convexHull(struct Point *, int, int **);
+int outputHull(struct Map_info *, struct Point *, int *,
+ int);
+int make3DHull(double *, double *, double *, int,
+ struct Map_info *);
+void convexHull3d(struct Point *, int, struct Map_info *);
Modified: grass/trunk/vector/v.hull/main.c
--- grass/trunk/vector/v.hull/main.c 2009-11-27 17:29:24 UTC (rev 39828)
+++ grass/trunk/vector/v.hull/main.c 2009-11-27 17:51:50 UTC (rev 39829)
@@ -1,273 +1,37 @@
-* hull.c <s.hull>
-* Creates the convex hull surrounding a sites list
+ * MODULE: v.hull
+ * AUTHOR(S): Andrea Aime <aaime at libero.it>
+ * Updated 19 Dec 2003, Markus Neteler to 5.7
+ * Last updated 16 jan 2007, Benjamin Ducke to support 3D hull creation
+ * OGR support by Martin Landa <landa.martin gmail.com> (2009)
+ * PURPOSE: Creates the convex hull surrounding a vector points.
+ * COPYRIGHT: (C) 2001-2009 by the GRASS Development Team
+ * This program is free software under the GNU General
+ * Public License (>=v2). Read the file COPYING that
+ * comes with GRASS for details.
-* @Copyright Andrea Aime <aaime at libero.it>
-* 23 Sept. 2001
-* Updated 19 Dec 2003, Markus Neteler to 5.7
-* Last updated 16 jan 2007, Benjamin Ducke to support 3D hull creation
-* This file is part of GRASS GIS. It is free software. You can
-* redistribute it and/or modify it under the terms of
-* the GNU General Public License as published by the Free Software
-* Foundation; either version 2 of the License, or (at your option)
-* any later version.
-* This program is distributed in the hope that it will be useful,
-* but WITHOUT ANY WARRANTY; without even the implied warranty of
-* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-* GNU General Public License for more details.
#include <stdlib.h>
#include <stdio.h>
#include <assert.h>
#include <grass/gis.h>
-#include "chull.h"
+#include "hull.h"
-struct Point
- double x;
- double y;
- double z;
-int rightTurn(struct Point *P, int i, int j, int k)
- double a, b, c, d;
- a = P[i].x - P[j].x;
- b = P[i].y - P[j].y;
- c = P[k].x - P[j].x;
- d = P[k].y - P[j].y;
- return a * d - b * c < 0;
-int cmpPoints(const void *v1, const void *v2)
- struct Point *p1, *p2;
- p1 = (struct Point *)v1;
- p2 = (struct Point *)v2;
- if (p1->x > p2->x)
- return 1;
- else if (p1->x < p2->x)
- return -1;
- else
- return 0;
-int convexHull(struct Point *P, const int numPoints, int **hull)
- int pointIdx, upPoints, loPoints;
- int *upHull, *loHull;
- /* sort points in ascending x order */
- qsort(P, numPoints, sizeof(struct Point), cmpPoints);
- *hull = (int *)G_malloc(numPoints * 2 * sizeof(int));
- /* compute upper hull */
- upHull = *hull;
- upHull[0] = 0;
- upHull[1] = 1;
- upPoints = 1;
- for (pointIdx = 2; pointIdx < numPoints; pointIdx++) {
- upPoints++;
- upHull[upPoints] = pointIdx;
- while (upPoints > 1 &&
- !rightTurn(P, upHull[upPoints], upHull[upPoints - 1],
- upHull[upPoints - 2])
- upHull[upPoints - 1] = upHull[upPoints];
- upPoints--;
- printf("upPoints: %d\n", upPoints);
- for(pointIdx = 0; pointIdx <= upPoints; pointIdx ++)
- printf("%d ", upHull[pointIdx]);
- printf("\n");
- /* compute lower hull, overwrite last point of upper hull */
- loHull = &(upHull[upPoints]);
- loHull[0] = numPoints - 1;
- loHull[1] = numPoints - 2;
- loPoints = 1;
- for (pointIdx = numPoints - 3; pointIdx >= 0; pointIdx--) {
- loPoints++;
- loHull[loPoints] = pointIdx;
- while (loPoints > 1 &&
- !rightTurn(P, loHull[loPoints], loHull[loPoints - 1],
- loHull[loPoints - 2])
- loHull[loPoints - 1] = loHull[loPoints];
- loPoints--;
- G_debug(3, "numPoints:%d loPoints:%d upPoints:%d",
- numPoints, loPoints, upPoints);
- printf("loPoints: %d\n", loPoints);
- for(pointIdx = 0; pointIdx <= loPoints; pointIdx ++)
- printf("%d ", loHull[pointIdx]);
- printf("\n");
- /* reclaim uneeded memory */
- *hull = (int *)G_realloc(*hull, (loPoints + upPoints) * sizeof(int));
- return loPoints + upPoints;
-void convexHull3d(struct Point *P, const int numPoints, struct Map_info *Map)
- int error;
- int i;
- double *px;
- double *py;
- double *pz;
- px = G_malloc(sizeof(double) * numPoints);
- py = G_malloc(sizeof(double) * numPoints);
- pz = G_malloc(sizeof(double) * numPoints);
- for (i = 0; i < numPoints; i++) {
- px[i] = (P)[i].x;
- py[i] = (P)[i].y;
- pz[i] = (P)[i].z;
- /* make 3D hull */
- error = make3DHull(px, py, pz, numPoints, Map);
- if (error < 0) {
- G_fatal_error("Simple planar hulls not implemented yet");
- G_free(px);
- G_free(py);
- G_free(pz);
-#define ALLOC_CHUNK 256
-int loadSiteCoordinates(struct Map_info *Map, struct Point **points, int all,
- struct Cell_head *window)
- int pointIdx = 0;
- struct line_pnts *sites;
- struct line_cats *cats;
- struct bound_box box;
- int cat, type;
- sites = Vect_new_line_struct();
- cats = Vect_new_cats_struct();
- *points = NULL;
- /* copy window to box */
- Vect_region_box(window, &box);
- while ((type = Vect_read_next_line(Map, sites, cats)) > -1) {
- if (type != GV_POINT)
- continue;
- Vect_cat_get(cats, 1, &cat);
- G_debug(4, "Point: %f|%f|%f|#%d", sites->x[0], sites->y[0],
- sites->z[0], cat);
- if (all ||
- Vect_point_in_box(sites->x[0], sites->y[0], sites->z[0], &box)) {
- G_debug(4, "Point in the box");
- if ((pointIdx % ALLOC_CHUNK) == 0)
- *points =
- (struct Point *)G_realloc(*points,
- (pointIdx +
- ALLOC_CHUNK) *
- sizeof(struct Point));
- (*points)[pointIdx].x = sites->x[0];
- (*points)[pointIdx].y = sites->y[0];
- (*points)[pointIdx].z = sites->z[0];
- pointIdx++;
- if (pointIdx > 0)
- *points =
- (pointIdx + 1) * sizeof(struct Point));
- return pointIdx;
- * Outputs the points that comprises the convex hull as a single closed line
- * and the hull baricenter as the label points (as it is a linear combination
- * of points on the hull is guaranteed to be inside the hull, follow from the
- * definition of convex polygon)
-int outputHull(struct Map_info *Map, struct Point *P, int *hull,
- int numPoints)
- struct line_pnts *Points;
- struct line_cats *Cats;
- double *tmpx, *tmpy;
- int i, pointIdx;
- double xc, yc;
- tmpx = (double *)G_malloc((numPoints + 1) * sizeof(double));
- tmpy = (double *)G_malloc((numPoints + 1) * sizeof(double));
- xc = yc = 0;
- pointIdx = hull[i];
- tmpx[i] = P[pointIdx].x;
- tmpy[i] = P[pointIdx].y;
- /* average coordinates calculation... may introduce a little
- numerical error but guaratees that no overflow will occurr */
- xc = xc + tmpx[i] / numPoints;
- yc = yc + tmpy[i] / numPoints;
- tmpx[numPoints] = P[hull[0]].x;
- tmpy[numPoints] = P[hull[0]].y;
- Points = Vect_new_line_struct();
- Cats = Vect_new_cats_struct();
- Vect_copy_xyz_to_pnts(Points, tmpx, tmpy, 0, numPoints + 1);
- G_free(tmpx);
- G_free(tmpy);
- /* write out convex hull */
- Vect_write_line(Map, GV_BOUNDARY, Points, Cats);
- /* find and add centroid */
- Vect_reset_line(Points);
- Vect_append_point(Points, xc, yc, 0.0);
- Vect_cat_set(Cats, 1, 1);
- Vect_write_line(Map, GV_CENTROID, Points, Cats);
- Vect_destroy_line_struct(Points);
- return 0;
int main(int argc, char **argv)
struct GModule *module;
- struct Option *input, *output;
+ struct Option *input, *output, *field;
struct Flag *all, *flat;
struct Cell_head window;
@@ -279,21 +43,20 @@
int numSitePoints, numHullPoints;
int MODE2D;
G_gisinit(argv[0]);
module = G_define_module();
G_add_keyword(_("vector"));
G_add_keyword(_("geometry"));
module->description =
- _("Uses a GRASS vector points map to produce a convex hull vector map.");
+ _("Creates convex hull for vector point map.");
input = G_define_standard_option(G_OPT_V_INPUT);
- input->description = _("Name of input vector points map");
+ field = G_define_standard_option(G_OPT_V_FIELD);
output = G_define_standard_option(G_OPT_V_OUTPUT);
- output->description = _("Name of output vector area map");
all = G_define_flag();
all->key = 'a';
@@ -313,13 +76,13 @@
Vect_check_input_output_name(input->answer, output->answer,
GV_FATAL_EXIT);
- /* open site file */
- if (Vect_open_old(&Map, sitefile, "") < 0)
- G_fatal_error(_("Cannot open vector map <%s>"), sitefile);
+ if (Vect_open_old2(&Map, sitefile, "", field->answer) < 0)
+ G_fatal_error(_("Unable to open vector map <%s>"), sitefile);
/* load site coordinates */
G_get_window(&window);
- numSitePoints = loadSiteCoordinates(&Map, &points, all->answer, &window);
+ numSitePoints = loadSiteCoordinates(&Map, &points, all->answer, &window,
+ Vect_get_field_number(&Map, field->answer));
if (numSitePoints < 0)
G_fatal_error(_("Error loading vector points map <%s>"), sitefile);
@@ -340,12 +103,12 @@
/* create vector map */
if (MODE2D) {
if (0 > Vect_open_new(&Map, output->answer, 0)) {
- G_fatal_error(_("Cannot open vector map <%s>"), output->answer);
+ G_fatal_error(_("Unable to create vector map <%s>"), output->answer);
else {
if (0 > Vect_open_new(&Map, output->answer, 1)) {
@@ -358,16 +121,12 @@
/* output vector map */
outputHull(&Map, points, hull, numHullPoints);
else {
/* this does everything for the 3D hull including vector map creation */
convexHull3d(points, numSitePoints, &Map);
/* clean up and bye bye */
Vect_build(&Map);
Vect_close(&Map);
Added: grass/trunk/vector/v.hull/read.c
--- grass/trunk/vector/v.hull/read.c (rev 0)
+++ grass/trunk/vector/v.hull/read.c 2009-11-27 17:51:50 UTC (rev 39829)
@@ -0,0 +1,57 @@
+#include <grass/gis.h>
+#include "hull.h"
+int loadSiteCoordinates(struct Map_info *Map, struct Point **points, int all,
+ struct Cell_head *window, int field)
+ int pointIdx = 0;
+ struct line_pnts *sites;
+ struct line_cats *cats;
+ struct bound_box box;
+ int cat, type;
+ sites = Vect_new_line_struct();
+ cats = Vect_new_cats_struct();
+ *points = NULL;
+ /* copy window to box */
+ Vect_region_box(window, &box);
+ while ((type = Vect_read_next_line(Map, sites, cats)) > -1) {
+ if (type != GV_POINT)
+ continue;
+ if (Vect_cat_get(cats, field, &cat) == 0)
+ continue;
+ G_debug(4, "Point: %f|%f|%f|#%d", sites->x[0], sites->y[0],
+ sites->z[0], cat);
+ if (all ||
+ Vect_point_in_box(sites->x[0], sites->y[0], sites->z[0], &box)) {
+ G_debug(4, "Point in the box");
+ if ((pointIdx % ALLOC_CHUNK) == 0)
+ *points =
+ (struct Point *)G_realloc(*points,
+ (pointIdx +
+ ALLOC_CHUNK) *
+ sizeof(struct Point));
+ (*points)[pointIdx].x = sites->x[0];
+ (*points)[pointIdx].y = sites->y[0];
+ (*points)[pointIdx].z = sites->z[0];
+ pointIdx++;
+ if (pointIdx > 0)
+ *points =
+ (pointIdx + 1) * sizeof(struct Point));
+ return pointIdx;
Added: grass/trunk/vector/v.hull/write.c
--- grass/trunk/vector/v.hull/write.c (rev 0)
+++ grass/trunk/vector/v.hull/write.c 2009-11-27 17:51:50 UTC (rev 39829)
@@ -0,0 +1,51 @@
+#include "hull.h"
+ * Outputs the points that comprises the convex hull as a single closed line
+ * and the hull baricenter as the label points (as it is a linear combination
+ * of points on the hull is guaranteed to be inside the hull, follow from the
+ * definition of convex polygon)
+int outputHull(struct Map_info *Map, struct Point *P, int *hull,
+ int numPoints)
+ struct line_pnts *Points;
+ struct line_cats *Cats;
+ double *tmpx, *tmpy;
+ int i, pointIdx;
+ double xc, yc;
+ tmpx = (double *)G_malloc((numPoints + 1) * sizeof(double));
+ tmpy = (double *)G_malloc((numPoints + 1) * sizeof(double));
+ xc = yc = 0;
+ pointIdx = hull[i];
+ tmpx[i] = P[pointIdx].x;
+ tmpy[i] = P[pointIdx].y;
+ /* average coordinates calculation... may introduce a little
+ numerical error but guaratees that no overflow will occurr */
+ xc = xc + tmpx[i] / numPoints;
+ yc = yc + tmpy[i] / numPoints;
+ tmpx[numPoints] = P[hull[0]].x;
+ tmpy[numPoints] = P[hull[0]].y;
+ Points = Vect_new_line_struct();
+ Cats = Vect_new_cats_struct();
+ Vect_copy_xyz_to_pnts(Points, tmpx, tmpy, 0, numPoints + 1);
+ G_free(tmpx);
+ G_free(tmpy);
+ /* write out convex hull */
+ Vect_write_line(Map, GV_BOUNDARY, Points, Cats);
+ /* find and add centroid */
+ Vect_reset_line(Points);
+ Vect_append_point(Points, xc, yc, 0.0);
+ Vect_cat_set(Cats, 1, 1);
+ Vect_write_line(Map, GV_CENTROID, Points, Cats);
+ Vect_destroy_line_struct(Points);
+ return 0;
