[GRASS-SVN] r39372 - grass/trunk/lib/vector
Fri Oct 2 04:40:11 EDT 2009
Author: martinl
Date: 2009-10-02 04:40:11 -0400 (Fri, 02 Oct 2009)
New Revision: 39372
   grass/trunk/lib/vector/vectorlib.dox
update doxygen docs - add ref to ascii fns
Modified: grass/trunk/lib/vector/vectorlib.dox
--- grass/trunk/lib/vector/vectorlib.dox	2009-10-02 08:21:35 UTC (rev 39371)
+++ grass/trunk/lib/vector/vectorlib.dox	2009-10-02 08:40:11 UTC (rev 39372)
@@ -1523,7 +1523,9 @@
 Vector map can be converted to the ASCII representation at user level
 by <tt>v.out.ascii format=standard</tt> command.
+See \ref vlibAsciiFn for list of related functions.
 The header is similar as the head file of vector binary format (see
 \ref vlibHeadFileFormat) but contains bounding box also. Keywords are:
@@ -1689,6 +1691,7 @@
 - \subpage vlibType
 - \subpage vlibDelete
 - \subpage vlibWrite
+- \subpage vlibAsciiFn
 - \subpage vlibGeos
 \section vlibArea Vector area functions
@@ -2311,7 +2314,7 @@
  - Vect_rewind()
-\section vlibSindex Vector spatial index functions
+\section vlibSelect Vector select functions
  - Vect_select_areas_by_box()
@@ -2326,7 +2329,7 @@
  - Vect_select_nodes_by_box()
-\section vlibSelect custom spatial index functions
+\section vlibSindex Vector spatial index functions
  - Vect_spatial_index_add_item()
@@ -2372,6 +2375,16 @@
  - Vect_rewrite_line()
+\subsection vlibAsciiFn Vector ASCII functions
+ - Vect_read_ascii()
+ - Vect_read_ascii_head()
+ - Vect_write_ascii()
+ - Vect_write_ascii_head()
 \section vlibGeos Vector GEOS functions
 Note: The functions are available only if GRASS is compiled with
