[GRASS-SVN] r39377 - in grass/trunk: include/vect lib/vector/Vlib vector/v.out.ascii
Fri Oct 2 15:27:49 EDT 2009
Author: martinl
Date: 2009-10-02 15:27:49 -0400 (Fri, 02 Oct 2009)
New Revision: 39377
   grass/trunk/include/vect/dig_defines.h
   grass/trunk/lib/vector/Vlib/ascii.c
   grass/trunk/lib/vector/Vlib/simple_features.c
   grass/trunk/vector/v.out.ascii/main.c
simple features API: initial support for Polygon added
Modified: grass/trunk/include/vect/dig_defines.h
--- grass/trunk/include/vect/dig_defines.h	2009-10-02 18:03:34 UTC (rev 39376)
+++ grass/trunk/include/vect/dig_defines.h	2009-10-02 19:27:49 UTC (rev 39377)
@@ -233,5 +233,6 @@
 #define SF_LINE	      0x02
 #define SF_LINESTRING 0x04
 #define SF_LINEARRING 0x08
+#define SF_POLYGON    0x10
 #define HEADSTR	50
Modified: grass/trunk/lib/vector/Vlib/ascii.c
--- grass/trunk/lib/vector/Vlib/ascii.c	2009-10-02 18:03:34 UTC (rev 39376)
+++ grass/trunk/lib/vector/Vlib/ascii.c	2009-10-02 19:27:49 UTC (rev 39377)
@@ -348,7 +348,7 @@
 		db_close_database(driver);
 		db_shutdown_driver(driver);
-	    return n_lines;
+	    break;
 	if (format == GV_ASCII_FORMAT_POINT && !(type & GV_POINTS))
@@ -559,6 +559,8 @@
 	else if (format == GV_ASCII_FORMAT_WKT) {
+	    if (type & (GV_BOUNDARY | GV_CENTROID | GV_FACE | GV_KERNEL))
+		continue;
 	    /* Well-Known Text */
 	    Vect_sfa_write_line_wkt(Points, type, Vect_is_3d(Map), dp, ascii);
@@ -568,7 +570,46 @@
 	n_lines++;
-    /* not reached */
+    if (format == GV_ASCII_FORMAT_WKT) {
+	/* process areas - topology required */
+	int i, area, nareas, isle, nisles;
+	if (Vect_level(Map) < 2) {
+	    G_warning(_("Topology not available, unable to process areas"));
+	    nareas = 0;
+	else {
+	    nareas = Vect_get_num_areas(Map);
+	for (area = 1; area <= nareas; area++) {
+	    if (!Vect_area_alive(Map, area)) /* skip dead areas */
+		continue;
+	    if (Vect_get_area_cat(Map, area, field) < 0)
+		continue;
+	    /* get boundary -> linearring */
+	    if (Vect_get_area_points(Map, area, Points) < 0) {
+		G_warning(_("Unable to get boundary of area id %d"), area);
+		continue;
+	    fprintf(ascii, "POLYGON(");
+	    /* write outter ring */
+	    Vect_sfa_write_line_wkt(Points, GV_BOUNDARY, 0, dp, ascii); /* boundary is always 2D */
+	    /* get isles (holes) -> inner rings */
+	    nisles = Vect_get_area_num_isles(Map, area);
+	    for (i = 0; i < nisles; i++) {
+		/* get isle boundary -> linearring */
+		isle = Vect_get_area_isle(Map, area, i);
+		if (Vect_get_isle_points(Map, isle, Points) < 0) {
+		    G_warning(_("Unable to get boundary of isle id %d (area id %d)"), isle, area);
+		    continue;
+		fprintf(ascii, ", ");
+		/* write inner ring */
+	    fprintf(ascii, ")\n");
     return n_lines;
Modified: grass/trunk/lib/vector/Vlib/simple_features.c
--- grass/trunk/lib/vector/Vlib/simple_features.c	2009-10-02 18:03:34 UTC (rev 39376)
+++ grass/trunk/lib/vector/Vlib/simple_features.c	2009-10-02 19:27:49 UTC (rev 39377)
@@ -74,7 +74,7 @@
 void Vect_sfa_write_line_wkt(const struct line_pnts *Points, int type, int with_z, int precision, FILE *file)
-    int sftype;
+    int i, sftype;
     sftype = Vect_sfa_get_line_type(Points, type, with_z);
@@ -86,7 +86,6 @@
 	break;
     case SF_LINESTRING: case SF_LINE: case SF_LINEARRING: {
-	int i;
 	if (sftype == SF_LINESTRING)
 	    fprintf(file, "LINESTRING(");
 	else if (sftype ==  SF_LINE)
@@ -101,6 +100,17 @@
 	fprintf(file, ")\n");
 	break;
+    case SF_POLYGON: {
+	/* write only outter/inner ring */
+	fprintf(file, "(");
+	for (i = 0; i < Points->n_points; i++) {
+	    print_point(Points, i, with_z, precision, file);
+	    if (i < Points->n_points - 1)
+		fprintf(file, ", ");
+	fprintf(file, ")");
+	break;
     default: {
 	G_warning(_("Unknown Simple Features type (%d)"), sftype);
 	break;
@@ -136,6 +146,15 @@
+    if (type == GV_BOUNDARY) {
+	int num = Vect_get_num_line_points(points);
+	if (sftype == SF_POLYGON &&
+	    points->x[0] == points->x[num-1] &&
+	    points->y[0] == points->y[num-1]) {
+	    return 1;
     return 0;
@@ -153,6 +172,9 @@
     if (check_sftype(points, type, SF_LINESTRING, with_z))
 	return SF_LINESTRING;
+    if (check_sftype(points, type, SF_POLYGON, with_z))
+	return SF_POLYGON;
     return -1;
Modified: grass/trunk/vector/v.out.ascii/main.c
--- grass/trunk/vector/v.out.ascii/main.c	2009-10-02 18:03:34 UTC (rev 39376)
+++ grass/trunk/vector/v.out.ascii/main.c	2009-10-02 19:27:49 UTC (rev 39377)
@@ -66,10 +66,18 @@
 	G_fatal_error(_("'output' must be given for old version"));
-    Vect_set_open_level(1);	/* only need level I */
-    if (Vect_open_old(&Map, input, "") < 0)
-	G_fatal_error(_("Unable to open vector map <%s>"),
+    if (format != GV_ASCII_FORMAT_WKT) {
+	Vect_set_open_level(1);	/* topology not needed */
+	if (Vect_open_old(&Map, input, "") < 0)
+	    G_fatal_error(_("Unable to open vector map <%s>"),
+			  input);
+    else {
+	if (Vect_open_old(&Map, input, "") < 2) /* topology required for polygons */
+	    G_warning(_("Unable to open vector map <%s> at topology level. "
+			"Only points, lines can be processed."),
 		      input);
     if (strcmp(output, "-") != 0) {
 	if (ver == 4) {
