[GRASS-SVN] r39386 - grass/trunk/lib/gis
Sat Oct 3 02:36:39 EDT 2009
Author: martinl
Date: 2009-10-03 02:36:38 -0400 (Sat, 03 Oct 2009)
New Revision: 39386
   grass/trunk/lib/gis/gislib.dox
gisprompt docs updated based on Glynn's notes in ML
Modified: grass/trunk/lib/gis/gislib.dox
--- grass/trunk/lib/gis/gislib.dox	2009-10-03 05:52:40 UTC (rev 39385)
+++ grass/trunk/lib/gis/gislib.dox	2009-10-03 06:36:38 UTC (rev 39386)
@@ -1806,8 +1806,7 @@
 \subsection gisprompt_Member gisprompt Member
-The <b>gisprompt</b> Option structure item requires a bit more
+The <em>gisprompt</em> Option structure item requires a bit more
 description. The three comma-separated (no spaces allowed)
 sub-arguments are defined as follows:
@@ -1815,9 +1814,20 @@
 subroutine G_open_old(), "new" to G_open_new(), otherwise "any" or
 "mapset".
+  - If any option has "new" as the first component, the <tt>--o</tt>
+(overwrite) flag will be listed in the module's interface
+(<tt>--help</tt> output, manual page, GUI dialog, etc).
+  - If an option which has "new" as the first component is given, the
+parser checks whether the entity (map, etc.) already exists.
  - Second argument: This is identical to the "element" argument in the
 above subroutine calls. It specifies a directory inside the mapset
-that may contain the user's response.
+that may contain the user's response. In other words the second field
+is used to determine where to look for the file (i.e. if the option
+has "new,cell,...", it will look in the "cell" directory). The second
+field should be the name of one of the standard subdirectories of the
+mapset, as listed in $GISBASE/etc/element_list.
  - Third argument: Identical to the "prompt" argument in the above
 subroutine calls. This is a string presented to the user that
@@ -1830,6 +1840,13 @@
 "old,vector,vector" G_open_old("vector", "map")
 \endverbatim
+The gisprompt values are passed to any GUI code, both self-contained
+dialogs generated by the parser for the <tt>--ui</tt> option, and
+stand-alone GUIs (wxGUI) which use the <tt>--xml-description</tt>
+flags to obtain a machine-readable description of the module's
+interface. How the GUI interprets this is up to the GUI.
 \subsection Common_Questions Common Questions
