[GRASS-SVN] r39579 - grass/trunk/vector/v.out.ogr
Mon Oct 19 04:44:45 EDT 2009
Author: martinl
Date: 2009-10-19 04:44:44 -0400 (Mon, 19 Oct 2009)
New Revision: 39579
   grass/trunk/vector/v.out.ogr/attrb.c
   grass/trunk/vector/v.out.ogr/main.c
v.out.ogr: don't write attributes twice (bugfix)
	   fix intendation
Modified: grass/trunk/vector/v.out.ogr/attrb.c
--- grass/trunk/vector/v.out.ogr/attrb.c	2009-10-19 07:49:42 UTC (rev 39578)
+++ grass/trunk/vector/v.out.ogr/attrb.c	2009-10-19 08:44:44 UTC (rev 39579)
@@ -68,32 +68,34 @@
 			ogrfieldnum = OGR_F_GetFieldIndex(Ogr_feature,
 							  db_get_column_name(Column));
+			G_debug(2, "  column = %s -> fieldnum = %d",
+				db_get_column_name(Column), ogrfieldnum);
 			/* Reset */
 			OGR_F_UnsetField(Ogr_feature, ogrfieldnum);
 			/* prevent writing NULL values */
 			if (!db_test_value_isnull(Value)) {
-				switch (colctype) {
-				case DB_C_TYPE_INT:
-					OGR_F_SetFieldInteger(Ogr_feature, ogrfieldnum,
-							db_get_value_int(Value));
-					break;
-				case DB_C_TYPE_DOUBLE:
-					OGR_F_SetFieldDouble(Ogr_feature, ogrfieldnum,
-							db_get_value_double(Value));
-					break;
-				case DB_C_TYPE_STRING:
-					OGR_F_SetFieldString(Ogr_feature, ogrfieldnum,
-							db_get_value_string(Value));
-					break;
-				case DB_C_TYPE_DATETIME:
-					db_convert_column_value_to_string(Column,
-									&dbstring);
-							db_get_string(&dbstring));
-					break;
+			    switch (colctype) {
+			    case DB_C_TYPE_INT:
+				OGR_F_SetFieldInteger(Ogr_feature, ogrfieldnum,
+						      db_get_value_int(Value));
+				break;
+			    case DB_C_TYPE_DOUBLE:
+				OGR_F_SetFieldDouble(Ogr_feature, ogrfieldnum,
+						     db_get_value_double(Value));
+				break;
+			    case DB_C_TYPE_STRING:
+				OGR_F_SetFieldString(Ogr_feature, ogrfieldnum,
+						     db_get_value_string(Value));
+				break;
+			    case DB_C_TYPE_DATETIME:
+				db_convert_column_value_to_string(Column,
+								  &dbstring);
+						     db_get_string(&dbstring));
+				break;
Modified: grass/trunk/vector/v.out.ogr/main.c
--- grass/trunk/vector/v.out.ogr/main.c	2009-10-19 07:49:42 UTC (rev 39578)
+++ grass/trunk/vector/v.out.ogr/main.c	2009-10-19 08:44:44 UTC (rev 39579)
@@ -52,7 +52,6 @@
     int doatt = 0, ncol = 0, colsqltype, colctype, keycol = -1;
     struct field_info *Fi = NULL;
     dbDriver *Driver = NULL;
-    dbHandle handle;
     dbTable *Table;
     dbString dbstring;
     dbColumn *Column;
@@ -345,16 +344,11 @@
 	    doatt = 0;
 	else {
-	    Driver = db_start_driver(Fi->driver);
-	    if (Driver == NULL)
-		G_fatal_error(_("Unable to start driver <%s>"), Fi->driver);
-	    db_init_handle(&handle);
-	    db_set_handle(&handle, Fi->database, NULL);
-	    if (db_open_database(Driver, &handle) != DB_OK)
+	    Driver = db_start_driver_open_database(Fi->driver, Fi->database);
+	    if (!Driver)
 		G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
 			      Fi->database, Fi->driver);
 	    db_set_string(&dbstring, Fi->table);
 	    if (db_describe_table(Driver, &dbstring, &Table) != DB_OK)
 		G_fatal_error(_("Unable to describe table <%s>"), Fi->table);
@@ -393,11 +387,7 @@
 		    keycol = i;
 		G_debug(2, "%s x %s -> %s x %s -> keycol = %d", Fi->key,
 			db_get_column_name(Column), key1, key2, keycol);
-		Ogr_field =
-		    OGR_Fld_Create(db_get_column_name(Column), ogr_ftype);
-		OGR_L_CreateField(Ogr_layer, Ogr_field, 0);
-		OGR_Fld_Destroy(Ogr_field);
 		if (!flags.nocat->answer) {
 		    Ogr_field =
@@ -405,16 +395,16 @@
 		} else {
 		    /* skip export of 'cat' field */
-		    if (strcmp (Fi->key,db_get_column_name(Column)) != 0) {
+		    if (strcmp (Fi->key, db_get_column_name(Column)) != 0) {
 			Ogr_field =
 	    if (keycol == -1)
-		G_fatal_error(_("Key column '%s' not found"), Fi->key);
+		G_fatal_error(_("Key column <%s> not found"), Fi->key);
@@ -552,8 +542,7 @@
 		nocatskip++;
 		continue;
 	    /* Geometry */
 	    if (type == GV_LINE && flags.poly->answer) {
 		OGRGeometryH ring;
