[GRASS-SVN] r39599 - in grass-addons/gui/wxpython: . data_catalog
Tue Oct 20 09:12:50 EDT 2009
Author: rashadkm
Date: 2009-10-20 09:12:49 -0400 (Tue, 20 Oct 2009)
New Revision: 39599
Added:
   grass-addons/gui/wxpython/data_catalog/
   grass-addons/gui/wxpython/data_catalog/catalog.py
   grass-addons/gui/wxpython/data_catalog/mapwindow.py
s
Added: grass-addons/gui/wxpython/data_catalog/catalog.py
--- grass-addons/gui/wxpython/data_catalog/catalog.py	                        (rev 0)
+++ grass-addons/gui/wxpython/data_catalog/catalog.py	2009-10-20 13:12:49 UTC (rev 39599)
@@ -0,0 +1,509 @@
+ at package catalog.py
+GRASS DataCatalog.
+ at breif A GRASS GIS data manager used to copy,rename,delete,
+display maps in different mapsets and locations.
+Classes:
+ - DataCatalog
+ - CatalogApp
+(C) 2007 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Mohammed Rashad K.M <rashadkm at gmail dot com>
+import os
+import sys
+#To run DataCatalog from any directory set this pathname for access to gui_modules
+gbase = os.getenv("GISBASE")
+pypath = os.path.join(gbase,'etc','wxpython','gui_modules')
+sys.path.append(pypath)
+import globalvar
+if not os.getenv("GRASS_WXBUNDLED"):
+    globalvar.CheckForWx()
+import wx
+import gcmd
+import glob
+import render
+from mapwindow import BufferedWindow
+class DataCatalog(wx.Frame):
+    def __init__(self,size=wx.DefaultSize):
+        wx.Frame.__init__(self, None, wx.ID_ANY, "Data Catalog", wx.DefaultPosition, wx.DefaultSize)
+        self.Maximize()
+        self.gisbase  = os.getenv("GISBASE")
+        self.gisrc  = self.read_gisrc()
+        self.viewInfo = True        #to display v/r.info on mapdisplay
+        self.gisdbase = self.gisrc['GISDBASE']
+        #backup location and mapset from gisrc which may be modified  by datacatalog
+        self.iLocation = self.gisrc['LOCATION_NAME']
+        self.iMapset = self.gisrc['MAPSET']
+        self.ID_REN= wx.NewId()
+        self.ID_COPY = wx.NewId()
+        self.ID_DEL = wx.NewId()
+        acel = wx.AcceleratorTable([
+               (wx.ACCEL_CTRL,  ord('R'), self.ID_REN ) ,
+               (wx.ACCEL_CTRL,  ord('C'), self.ID_COPY) ,
+               (wx.ACCEL_NORMAL, wx.WXK_DELETE, self.ID_DEL) ])
+        self.SetAcceleratorTable(acel)
+        #creating sizers
+        self.cmbSizer = wx.GridBagSizer(hgap=5, vgap=0)
+        self.mSizer = wx.BoxSizer(wx.VERTICAL)
+        #these two sizers are applied to splitter window
+        self.leftSizer = wx.BoxSizer(wx.HORIZONTAL)
+        self.rightSizer = wx.BoxSizer(wx.VERTICAL)
+        #populate location combobox
+        self.loclist = self.GetLocations()
+        #setting splitter window
+        self.win = wx.SplitterWindow(self)
+        self.pLeft = wx.Panel(self.win, style=wx.SUNKEN_BORDER)
+        self.pRight = wx.Panel(self.win, style=wx.SUNKEN_BORDER)
+        self.cmbPanel = wx.Panel(self)
+        self.pRight.SetBackgroundColour("white")
+        self.pLeft.Hide()
+        self.pRight.Hide()
+        self.win.Initialize(self.pLeft)
+        self.win.SplitVertically(self.pLeft, self.pRight, 310)
+        #creating controls
+        self.mInfo = wx.TextCtrl(self.pRight, wx.ID_ANY, style = wx.TE_MULTILINE|wx.HSCROLL|wx.TE_READONLY)
+        self.chkInfo = wx.CheckBox(self.cmbPanel, wx.ID_ANY,"display Info", wx.DefaultPosition, wx.DefaultSize)
+        self.lbLocation = wx.StaticText(self.cmbPanel, wx.ID_ANY, "Location")
+        self.lbMapset = wx.StaticText(self.cmbPanel, wx.ID_ANY, "Mapset")
+        self.cmbLocation = wx.ComboBox(self.cmbPanel, value = "Select Location",size=wx.DefaultSize, choices=self.loclist)
+        self.cmbMapset = wx.ComboBox(self.cmbPanel, value = "Select Mapset", size=wx.DefaultSize)
+        self.tree = wx.TreeCtrl(self.pLeft, wx.ID_ANY, wx.DefaultPosition, wx.DefaultSize, wx.TR_HIDE_ROOT|wx.TR_HAS_BUTTONS|wx.TR_EDIT_LABELS)
+        self.itemFont = wx.Font(pointSize=9,weight=0, family=wx.FONTFAMILY_DEFAULT ,style=wx.FONTSTYLE_ITALIC)
+        #self.redir = wx.TextCtrl(self, wx.ID_ANY)
+        self.Map = render.Map()
+        self.MapWindow = BufferedWindow(self.pRight, wx.ID_ANY,wx.DefaultPosition, size=(640,480), Map=self.Map)
+        self.Map.Clean()
+        #By default v/r.info will be displayed
+        self.chkInfo.SetValue(True)
+        #apply bindings and setting layouts
+        self.doBindings()
+        self.doLayout()
+        self.Centre()
+    def OnToggleInfo(self,event):
+    	if self.chkInfo.GetValue() == True:
+    	    self.mInfo.Show()
+    	else:
+	        self.viewInfo = False
+	        self.mInfo.Hide()
+    def OnBeginRename(self,event):
+	    item = self.tree.GetItemText(event.GetItem())
+	    if type(item) == str and item in ("Raster Map", "Vector Map" , "DBF"):
+	        event.Veto()             #disable editing of parent items
+    def OnEndRename(self,event):
+        Rename mapset using grass commands
+        item = event.GetItem()
+        oldName = self.tree.GetItemText(item)
+        try:
+            newName =  self.tree.GetEditControl().GetValue()
+        except:
+            return
+        parent =self.tree.GetItemParent(item)
+        if self.tree.GetItemText(parent) == "Raster Map" :
+            cmdflag = 'rast=' +  oldName + ',' + newName
+        elif self.tree.GetItemText(parent) == "Vector Map" :
+            cmdflag = 'vect=' +  oldName + ',' + newName
+        if cmdflag:
+            command = ["g.rename", cmdflag]
+            gcmd.CommandThread(command,stdout=None,stderr=None).run()
+    def OnTreePopUp(self,event):
+        Display a popupMenu for copy,rename & delete operations
+        if not self.tree.ItemHasChildren(item) and \
+	           self.tree.GetItemFont(item) != self.itemFont:
+            self.popupmenu = wx.Menu()
+            mnuCopy = self.popupmenu.Append(self.ID_COPY,'&Copy\tCtrl+C')
+            mnuRename = self.popupmenu.Append(self.ID_REN,'&Rename\tCtrl-R')
+            mnuDel = self.popupmenu.Append(self.ID_DEL,'&Delete\tDEL')
+            self.tree.PopupMenu(self.popupmenu)
+    def OnCopy( self,event ):
+        #print "copy"
+        item =  self.tree.GetSelection()
+        parent = self.tree.GetItemParent(item)
+        pText = self.tree.GetItemText(parent)
+        name = self.GetCopyName(item)
+        if pText == "Raster Map" :
+            cmdflag = 'rast=' + self.tree.GetItemText(item) + ',' + name
+            self.tree.InsertItem(parent,item, name)
+        elif pText  == "Vector Map" :
+            cmdflag = 'vect=' + self.tree.GetItemText(item) + ',' + name
+        if cmdflag:
+            command = ["g.copy", cmdflag]
+    def GetCopyName(self, item):
+        Returns unique name depending on the mapname to be copied.
+        def GetPrefix(prefix):
+            This returns a prefix to the given map name
+            prefix applied here is _copy_x.
+            prefix = "_copy_" + str(self.count)
+            self.count = self.count + 1
+            return prefix
+            #end of GetPrefix
+        def CheckName(parent,prefix,name):
+            Checks all silbings of the parent wheather the name
+            already exists.
+            ncount = self.tree.GetChildrenCount(parent, False)
+            ck = 1
+            current , ck = self.tree.GetFirstChild(parent)
+            for i in range(ncount):
+           		if str(self.tree.GetItemText(current)) == str(name + prefix):
+				    return False
+         		else:
+          			current,ck = self.tree.GetNextChild(parent,ck)
+            return True
+            #End of CheckName
+        #GetCopyName function starts here
+        ext = None
+        self.count  = 1
+        ext = GetPrefix(ext)
+        name = str(self.tree.GetItemText(item))
+        while  CheckName(parent,ext,name) == False:
+		    CheckName(parent,ext,name)
+        name = str(name + ext)
+        return name
+    def OnRename( self,event ):
+	    self.tree.EditLabel( self.tree.GetSelection())
+    def OnDelete( self,event ):
+        Performs grass command for deleting a map
+		    cmdflag = 'rast=' + str(self.tree.GetItemText(item))
+		    cmdflag = 'vect=' + str(self.tree.GetItemText(item))
+        if cmdflag:
+		    command = ["g.remove", cmdflag]
+		    select = self.tree.GetPrevSibling(item)
+		    self.tree.Delete(item)
+		    self.tree.SelectItem(select)
+    def OnCloseWindow(self,event):
+        if self.gisrc['LOCATION_NAME'] != self.iLocation or \
+            self.gisrc['MAPSET'] != self.iMapset:
+            self.gisrc['LOCATION_NAME'] = self.iLocation
+            self.gisrc['MAPSET'] = self.iMapset
+            self.update_grassrc(self.gisrc)
+        self.Map.Clean()
+        event.Skip()
+        #self.Destroy()
+    def OnDisplay(self, event):
+		pText = self.tree.GetItemText(self.tree.GetItemParent(item))
+		if not self.tree.ItemHasChildren(item):
+			self.mapname = "map=" + self.tree.GetItemText(item) + "@" +self.cmbMapset.GetValue()
+				self.cmd= ['d.rast', str(self.mapname)]
+				self.infocmd = ["r.info", str(self.mapname)]
+				self.cmd= ['d.vect', str(self.mapname)]
+				self.infocmd = ["v.info", str(self.mapname)]
+		if self.cmd:
+			self.Map.Clean()
+			self.Map.AddLayer(type='raster', name='layer1', command=self.cmd)
+			self.Map.region = self.Map.GetRegion()
+			self.MapWindow.Map = self.Map
+			self.MapWindow.flag = True
+			self.MapWindow.UpdateMap(render=True)
+		if self.viewInfo is True:
+	   		gcmd.CommandThread(self.infocmd, stdout=self.mInfo).run()
+	   		lines = self.mInfo.GetValue()
+	   		lines = lines.replace('|','')
+	   		lines =lines.replace('+','')
+	   		lines =lines.replace('-','')
+	   		#lines =lines.replace('-+','-------------------------------+')
+	   		#lines =lines.replace('-\n','---------------------------------')
+	   		#lines = lines.replace('+','----+')
+	   		self.mInfo.SetValue(lines)
+    def OnMapsetChange(self,event):
+        Create the tree nodes based on selected location and mapset.
+        Also update gisrc and grassrc files.
+        self.tree.DeleteAllItems()
+        self.AddTreeNodes(self.cmbLocation.GetValue(),self.cmbMapset.GetValue())
+        self.gisrc['LOCATION_NAME'] = str(self.cmbLocation.GetValue())
+        self.gisrc['MAPSET'] = str(self.cmbMapset.GetValue())
+    def OnLocationChange(self,event):
+        Populate mapset combobox with selected location.
+        self.cmbMapset.Clear()
+        self.cmbMapset.SetValue("Select Mapset")
+        maplists = self.GetMapsets(self.cmbLocation.GetValue())
+        for mapsets in maplists:
+            self.cmbMapset.Append(str(mapsets))
+    def AddTreeNodes(self,location,mapset):
+        Adds tree nodes. raster,vector and dbf files are identified using
+        their directory structure.
+        root = self.tree.AddRoot('root')
+        node_raster = self.tree.AppendItem(root, "Raster Map")
+        node_vector = self.tree.AppendItem(root, "Vector Map")
+        node_dbf = self.tree.AppendItem(root, "DBF")
+        treeNodes = [node_raster,node_vector,node_dbf]
+        glocs = glob.glob(os.path.join(self.gisdbase,location, mapset,"*"))
+        for gloc in glocs:
+	            if not os.path.isfile(gloc) and os.path.isdir(gloc):
+	                if(os.path.basename(gloc)=='cats'):
+	                    for rast in glob.glob(os.path.join(self.gisdbase,location, mapset,gloc, "*")):
+	                	    self.tree.AppendItem(node_raster, os.path.basename(rast))
+	                elif(os.path.basename(gloc)=='vector'):
+	                    for vect in glob.glob(os.path.join(self.gisdbase,location, mapset,gloc, "*")):
+		                    self.tree.AppendItem(node_vector, os.path.basename(vect))
+	                elif(os.path.basename(gloc)=='dbf'):
+	                    for dfile in glob.glob(os.path.join(self.gisdbase,location, mapset,gloc, "*")):
+		                    self.tree.AppendItem(node_dbf, os.path.basename(dfile))
+        #Nodes with no children are given an italic type font
+        for node in treeNodes:
+	        if not self.tree.ItemHasChildren(node):
+		        if self.tree.GetItemText(node) == 'Raster Map':
+		   	        tmp_item = self.tree.AppendItem(node, "No raster maps found.")
+		        elif self.tree.GetItemText(node) == 'Vector Map':
+		   	        tmp_item = self.tree.AppendItem(node, "No vector maps found.")
+		        elif self.tree.GetItemText(node) == 'DBF':
+		   	        tmp_item = self.tree.AppendItem(node, "No DBF files found.")
+	                self.tree.SetItemFont(tmp_item,self.itemFont)
+    def GetMapsets(self,location):
+        Read and returns all mapset int GRASS data directory.
+    	maplist = []
+        for mapset in glob.glob(os.path.join(self.gisdbase, location, "*")):
+            if os.path.isdir(mapset) and os.path.isfile(os.path.join(self.gisdbase, location, mapset, "WIND")):
+	            maplist.append(os.path.basename(mapset))
+	    return maplist
+    def GetLocations(self):
+        Read and returns all locations int GRASS data directory.
+        loclist = []
+        for location in glob.glob(os.path.join(self.gisdbase, "*")):
+             if os.path.join(location, "PERMANENT") in glob.glob(os.path.join(location, "*")):
+		         loclist.append(os.path.basename(location))
+        return loclist
+    def doBindings(self):
+        #Event bindings for combo boxes
+    	self.Bind(wx.EVT_COMBOBOX,self.OnMapsetChange,self.cmbMapset)
+    	self.Bind(wx.EVT_COMBOBOX,self.OnLocationChange,self.cmbLocation)
+        #Event bindings for tree -(display,popup,label edit.)
+        self.Bind(wx.EVT_TREE_ITEM_ACTIVATED, self.OnDisplay,self.tree)
+        self.Bind(wx.EVT_TREE_ITEM_RIGHT_CLICK,self.OnTreePopUp,self.tree)
+        self.Bind(wx.EVT_TREE_END_LABEL_EDIT, self.OnEndRename,self.tree)
+        self.Bind(wx.EVT_TREE_BEGIN_LABEL_EDIT, self.OnBeginRename,self.tree)
+        #Event bindings for tree menu
+        self.Bind(wx.EVT_MENU,self.OnCopy,id=self.ID_COPY)
+        self.Bind(wx.EVT_MENU,self.OnRename,id=self.ID_REN)
+        self.Bind(wx.EVT_MENU,self.OnDelete,id=self.ID_DEL)
+        self.Bind(wx.EVT_CLOSE,    self.OnCloseWindow)
+        #Event bindings for v/r.info checkbox
+        self.Bind(wx.EVT_CHECKBOX, self.OnToggleInfo,self.chkInfo)
+    def doLayout(self):
+	    #combo panel sizers
+        self.cmbSizer.Add(self.lbLocation,pos=(1,0),flag=wx.ALL,border=2)
+        self.cmbSizer.Add(self.lbMapset,pos=(1,1),flag=wx.ALL,border=2)
+        self.cmbSizer.Add(self.cmbLocation,pos=(2,0),flag=wx.ALL)
+        self.cmbSizer.Add(self.cmbMapset,pos=(2,1),flag=wx.ALL)
+        self.cmbSizer.Add(self.chkInfo,pos=(2,2),flag=wx.ALL)
+        self.cmbPanel.SetSizer(self.cmbSizer)
+    	#splitter window sizers
+        self.mSizer.Add(self.cmbPanel,flag=wx.EXPAND)
+        self.mSizer.Add(self.win, 1, wx.EXPAND)
+        self.SetSizer(self.mSizer)
+	    #sizers for splitter window panels
+        self.leftSizer.Add(self.tree,1,wx.EXPAND)
+        self.rightSizer.Add(self.MapWindow)
+        self.rightSizer.Add(self.mInfo,1,wx.EXPAND)
+        self.pLeft.SetSizer(self.leftSizer)
+        self.pRight.SetSizer(self.rightSizer)
+    def read_gisrc(self):
+        Read variables from $HOME/.grassrc7 file
+        rc = {}
+        gisrc = os.getenv("GISRC")
+        if gisrc and os.path.isfile(gisrc):
+            try:
+                f = open(gisrc, "r")
+                for line in f.readlines():
+                    key, val = line.split(":", 1)
+                    rc[key.strip()] = val.strip()
+            finally:
+                f.close()
+        return rc
+    def update_grassrc(self,gisrc):
+        Update $HOME/.grassrc7 and gisrc files
+        rc = os.getenv("GISRC")
+        grassrc = os.path.join(os.getenv('HOME'), ".grassrc7.%s" % os.uname()[1])
+    	if not os.access(grassrc, os.R_OK):
+	        grassrc = os.path.join(os.getenv('HOME'), ".grassrc7")
+        if rc and os.path.isfile(rc):
+            try:
+                f = open(rc, 'w')
+                for key, val in gisrc.iteritems():
+		            f.write("%s: %s\n" % (key, val))
+            finally:
+                f.close()
+        if grassrc and os.path.isfile(grassrc):
+            try:
+                g = open(grassrc, 'w')
+                    g.write("%s: %s\n" % (key, val))
+            finally:
+                    g.close()
+#End of DataCatalog class
+class CatalogApp(wx.App):
+    def OnInit(self):
+        wx.InitAllImageHandlers()
+        self.catalog = DataCatalog()
+        self.catalog.Show()
+	    #self.catalog.Maximize()
+	return 1
+# end of class MapApp
+# Run the program
+if __name__ == "__main__":
+    g_catalog = CatalogApp(0)
+    g_catalog.MainLoop()
+    #sys.exit(0)
Added: grass-addons/gui/wxpython/data_catalog/mapwindow.py
--- grass-addons/gui/wxpython/data_catalog/mapwindow.py	                        (rev 0)
+++ grass-addons/gui/wxpython/data_catalog/mapwindow.py	2009-10-20 13:12:49 UTC (rev 39599)
@@ -0,0 +1,154 @@
+ at package mapwindow.py
+ at brief buffered window, map display for DataCatalog.
+orginal code from wxGUI module mapdisp_window.py.
+Modified for map display in DataCatalog.
+Classes:
+ - BufferedWindow
+(C) 2006-2009 by the GRASS Development Team
+for details.
+ at author Michael Barton (original author)
+ at author Jachym Cepicky (original author)
+ at author Martin Landa <landa.martin gmail.com> (original author)
+ at author Mohammed Rashad K.M (modified for DataCatalog)
+import os
+import time
+import math
+import sys
+import tempfile
+import wx
+import globalvar
+import gselect
+from debug import Debug
+from vdigit import PseudoDC
+class BufferedWindow(wx.Window):
+    def __init__(self, parent, id,
+                 pos = wx.DefaultPosition,
+                 size = wx.DefaultSize,
+                 style=wx.NO_FULL_REPAINT_ON_RESIZE,Map=None):
+        wx.Window.__init__(self, parent, id, pos, size, style)
+        Debug.msg(4, "BufferedWindow.__init(): Map=%s" % Map)
+	self.Map = Map
+	self.flag = False
+        self.Bind(wx.EVT_PAINT,        self.OnPaint)
+        self.buffer = wx.EmptyBitmap(max(1, self.Map.width), max(1, self.Map.height))
+        self.mapfile = None
+        self.img = ""
+        self.imagedict = {}
+        self.select = {}
+        self.pdc = PseudoDC()
+        self.pdcTmp = PseudoDC()
+    def Draw(self, pdc, img=None, drawid=None, pdctype='image', coords=[0, 0, 0, 0]):
+        if drawid == None:
+            if pdctype == 'image' and img:
+                drawid = self.imagedict[img]
+            else:
+                drawid = wx.NewId()
+        if img and pdctype == 'image':
+            self.select[self.imagedict[img]['id']] = False # ?
+        pdc.BeginDrawing()
+        Debug.msg (5, "BufferedWindow.Draw(): id=%s, pdctype=%s, coord=%s" % \
+                       (drawid, pdctype, coords))
+        # set PseudoDC id
+        if drawid is not None:
+            pdc.SetId(drawid)
+        if pdctype == 'image': # draw selected image
+            bitmap = wx.BitmapFromImage(img)
+            w,h = bitmap.GetSize()
+            pdc.DrawBitmap(bitmap, coords[0], coords[1], True) # draw the composite map
+            pdc.SetIdBounds(drawid, wx.Rect(coords[0],coords[1], w, h))
+        pdc.EndDrawing()
+        self.Refresh()
+        return drawid
+    def OnPaint(self, event):
+        #Debug.msg(4, "BufferedWindow.OnPaint(): redrawAll=%s" % self.redrawAll)
+        dc = wx.BufferedPaintDC(self, self.buffer)
+        dc.Clear()
+        self.PrepareDC(dc)
+        self.bufferLast = None
+        self.pdc.DrawToDC(dc)
+        self.bufferLast = dc.GetAsBitmap(wx.Rect(0, 0, self.Map.width, self.Map.height))
+        pdcLast = PseudoDC()
+        pdcLast.DrawBitmap(self.bufferLast, 0, 0, False)
+        pdcLast.DrawToDC(dc)
+        self.pdcTmp.DrawToDC(dc)
+	if self.flag :
+	        self.UpdateMap(render=True)
+		self.flag=False
+    def GetImage(self):
+        imgId = 99
+        if self.Map.mapfile and os.path.isfile(self.Map.mapfile) and \
+                os.path.getsize(self.Map.mapfile):
+            img = wx.Image(self.Map.mapfile, wx.BITMAP_TYPE_ANY)
+	    #print self.Map.mapfile
+        else:
+            img = None
+        self.imagedict[img] = { 'id': imgId }
+        return img
+    def UpdateMap(self, render=True, renderVector=True):
+        start = time.clock()
+        if self.img is None:
+            render = True
+        if render:
+            # update display size
+            self.Map.ChangeMapSize(self.GetClientSize())
+            self.mapfile = self.Map.Render(force=True,  windres=False)
+        else:
+            self.mapfile = self.Map.Render(force=False)
+        self.img = self.GetImage() # id=99
+        for pdc in (self.pdc,  self.pdcTmp):
+            pdc.Clear()
+            pdc.RemoveAll()
+        if not self.img:
+            self.Draw(self.pdc, pdctype='clear')
+        else:
+            try:
+                id = self.imagedict[self.img]['id']
+            except:
+                return False
+            self.Draw(self.pdc, self.img, drawid=id)
+        stop = time.clock()
+        return True
