[GRASS-SVN] r38945 - grass/branches/develbranch_6/scripts/g.extension
Wed Sep 2 09:58:21 EDT 2009
Author: hamish
Date: 2009-09-02 09:58:21 -0400 (Wed, 02 Sep 2009)
New Revision: 38945
   grass/branches/develbranch_6/scripts/g.extension/g.extension
 - add -a flag to send to GRASS_ADDON_PATH if it exists
    (ugly hack, hopefully something better can be done in python)
 - allow extention names like vector/v.module and vector/adehabitat/...
Modified: grass/branches/develbranch_6/scripts/g.extension/g.extension
--- grass/branches/develbranch_6/scripts/g.extension/g.extension	2009-09-02 09:01:03 UTC (rev 38944)
+++ grass/branches/develbranch_6/scripts/g.extension/g.extension	2009-09-02 13:58:21 UTC (rev 38945)
@@ -54,13 +54,17 @@
 #% answer: ${GISBASE}
 #% required: yes
 #%end
 #%flag
+#% key: a
+#% description: Install to $GRASS_ADDON_PATH instead of using prefix option
+#%end
+#%flag
 #% key: l
 #% description: List available modules in the GRASS Addons SVN repository
 #% guisection: Print
 #%end
 if  [ -z "$GISBASE" ] ; then
     echo "You must be in GRASS GIS to run this program." >&2
     exit 1
@@ -73,16 +77,26 @@
 # definitions
 SVNURL_ADDONS=${GIS_OPT_SVNURL}
-if [ "$GIS_OPT_PREFIX" = '${GISBASE}' ] ; then
-   MYINST_DIR=${GISBASE}
+if [ $GIS_FLAG_A -eq 0 ] ; then
+   if [ "$GIS_OPT_PREFIX" = '${GISBASE}' ] ; then
+      MYINST_DIR=${GISBASE}
+   else
+      MYINST_DIR=${GIS_OPT_PREFIX}
+   fi
 else
-   MYINST_DIR=${GIS_OPT_PREFIX}
+   if [ -d "$GRASS_ADDON_PATH" ] ; then
+      MYINST_DIR="$GRASS_ADDON_PATH"
+   else
+      g.message -e '$GRASS_ADDON_PATH does not exist'
+      exit 1
+   fi
 fi
 #make a temporary directory
 TMPDIR="`g.tempfile pid=$$`"
 if [ $? -ne 0 ] || [ -z "$TMPDIR" ] ; then
-    g.message "Unable to create temporary files"
+    g.message -e "Unable to create temporary files"
     exit 1
 fi
 rm -f "$TMPDIR"
@@ -90,13 +104,13 @@
 # check if we have the svn client
 if [ ! -x "`which svn`" ] ; then
-    echo "ERROR: svn client required. Please install subversion first." 1>&2
+    g.message -e "svn client required. Please install Subversion first."
     exit 1
 fi
 # check if we have the make program
 if [ ! -x "`which make`" ] ; then
-    echo "ERROR: 'make' program required. Please install first." 1>&2
+    g.message -e "'make' program required. Please install first."
     exit 1
 fi
@@ -138,16 +152,25 @@
 #  elif [ "$1" = "s" ]  ; then
 #    echo "sites"
   elif [ "$1" = "v" ]  ; then
-    echo "vector"
+    echo "vector"
   else
     echo "$1"
  fi
-MODULE=$GIS_OPT_EXTENSION
-CLASSCHAR=`echo $MODULE | cut -d'.' -f1`
-MODULECLASS=`expand_module_class_name $CLASSCHAR`
+MODULE="$GIS_OPT_EXTENSION"
+if [ `echo "$MODULE" | grep -c '/'` -eq 0 ] ; then
+   CLASSCHAR=`echo $MODULE | cut -d'.' -f1`
+   MODULECLASS=`expand_module_class_name $CLASSCHAR`
+else
+   # handle vector/adehabitat/ or just vector/v.module ...
+   TOPLEVEL=`echo $MODULE | cut -d'/' -f1`
+   MODULECLASS="$TOPLEVEL"
+   MODULE=`echo "$MODULE" | sed -e "s+^$MODULECLASS/++"`
+fi
 list_available_modules()
  # a very dirty hack
@@ -186,6 +209,7 @@
    exit 1
 fi
+g.message -d "svn co [$SVNURL_ADDONS]/[$MODULECLASS]/[$MODULE]"
 cd ${TMPDIR}
 g.message message="Fetching <$MODULE> from GRASS-Addons SVN (be patient)..."
@@ -207,8 +231,15 @@
    g.message message="Installing ${MODULE}..."
    # can we write? Install dir present?
    if test ! -d ${MYINST_DIR} ; then
+      mkdir -p ${MYINST_DIR}
+   fi
+   if test ! -d ${MYINST_DIR}/bin ; then
       mkdir -p ${MYINST_DIR}/bin
+   fi
+   if test ! -d ${MYINST_DIR}/docs/html ; then
       mkdir -p ${MYINST_DIR}/docs/html
+   fi
+   if test ! -d ${MYINST_DIR}/man/man1 ; then
       mkdir -p ${MYINST_DIR}/man/man1
    fi
    touch "${MYINST_DIR}/`basename $0`.$$"
@@ -226,10 +257,15 @@
          cleanup
          exit 1
       fi
+      if [ $GIS_FLAG_A -eq 1 ] ; then
+         \mv ${MYINST_DIR}/bin/${MODULE} ${MYINST_DIR}/
+	 rmdir ${MYINST_DIR}/bin
+      fi
    fi
 fi
 cleanup
+g.message message=""
 g.message message="Installation of <${MODULE}> in <${MYINST_DIR}> successfully finished."
 exit 0
