[GRASS-SVN] r39174 - in grass/trunk: include lib/vector/Vlib
Sun Sep 13 08:51:05 EDT 2009
Author: mmetz
Date: 2009-09-13 08:51:04 -0400 (Sun, 13 Sep 2009)
New Revision: 39174
   grass/trunk/include/vector.h
   grass/trunk/lib/vector/Vlib/field.c
Vector libs: check for duplicate layer names
Modified: grass/trunk/include/vector.h
--- grass/trunk/include/vector.h	2009-09-13 11:00:12 UTC (rev 39173)
+++ grass/trunk/include/vector.h	2009-09-13 12:51:04 UTC (rev 39174)
@@ -98,12 +98,12 @@
 void Vect_reset_dblinks(struct dblinks *);
 int Vect_add_dblink(struct dblinks *, int, const char *,
 		    const char *, const char *, const char *, const char *);
-int Vect_check_dblink(const struct dblinks *, int);
+int Vect_check_dblink(const struct dblinks *, int, const char *);
 int Vect_map_add_dblink(struct Map_info *, int, const char *,
 			const char *);
 int Vect_map_del_dblink(struct Map_info *, int);
-int Vect_map_check_dblink(const struct Map_info *, int);
+int Vect_map_check_dblink(const struct Map_info *, int, const char *);
 int Vect_read_dblinks(struct Map_info *);
 int Vect_write_dblinks(struct Map_info *);
 struct field_info *Vect_default_field_info(struct Map_info *, int,
Modified: grass/trunk/lib/vector/Vlib/field.c
--- grass/trunk/lib/vector/Vlib/field.c	2009-09-13 11:00:12 UTC (rev 39173)
+++ grass/trunk/lib/vector/Vlib/field.c	2009-09-13 12:51:04 UTC (rev 39174)
@@ -160,9 +160,9 @@
   \return 1 dblink for field exists
   \return 0 dblink does not exist for field
-int Vect_map_check_dblink(const struct Map_info *Map, int field)
+int Vect_map_check_dblink(const struct Map_info *Map, int field, const char *name)
-    return Vect_check_dblink(Map->dblnk, field);
+    return Vect_check_dblink(Map->dblnk, field, name);
@@ -174,16 +174,20 @@
-int Vect_check_dblink(const struct dblinks *p, int field)
+int Vect_check_dblink(const struct dblinks *p, int field, const char *name)
     int i;
-    G_debug(3, "Vect_check_dblink: field %d", field);
+    G_debug(3, "Vect_check_dblink: field %d, name %s", field, (name != NULL ? name : "not given"));
     for (i = 0; i < p->n_fields; i++) {
 	if (p->field[i].number == field) {
 	    return 1;
+	if (name != NULL && p->field[i].name != NULL) {
+	    if (strcmp(p->field[i].name, name) == 0)
+		return 1;
     return 0;
@@ -209,7 +213,7 @@
     int ret;
     G_debug(3, "Field number <%d>, name <%s>", number, name);
-    ret = Vect_check_dblink(p, number);
+    ret = Vect_check_dblink(p, number, name);
     if (ret == 1) {
 	G_warning(_("Layer number %d or name <%s> already exists"), number,
 		  name);
@@ -225,8 +229,11 @@
     p->field[p->n_fields].number = number;
-    if (name != NULL)
+    if (name != NULL) {
 	p->field[p->n_fields].name = G_store(name);
+	/* replace all spaces with underscore, otherwise dbln can't be read */
+	G_strchg(p->field[p->n_fields].name, ' ', '_');
     else
 	p->field[p->n_fields].name = NULL;
