[GRASS-SVN] r39224 - grass-web/trunk/bugtracking
Tue Sep 15 21:45:29 EDT 2009
Author: hamish
Date: 2009-09-15 21:45:28 -0400 (Tue, 15 Sep 2009)
New Revision: 39224
   grass-web/trunk/bugtracking/explain_new_tracker.inc
wording
Modified: grass-web/trunk/bugtracking/explain_new_tracker.inc
--- grass-web/trunk/bugtracking/explain_new_tracker.inc	2009-09-15 15:20:05 UTC (rev 39223)
+++ grass-web/trunk/bugtracking/explain_new_tracker.inc	2009-09-16 01:45:28 UTC (rev 39224)
@@ -22,7 +22,7 @@
 <h3>Some considerations</h3>
 Please consider the following when submitting bugs or feature requests:<ul>
-<li>Only report bugs if using at least the current stable release version.
+<li>Check if the bug is still present in at least the current stable release version before reporting.
 If you use an older version, please consider <a href="../download/index.php">upgrading</a>.
 <li> Make sure that the developers have all the information needed
         to recreate the bug
