[GRASS-SVN] r39323 - in grass/trunk: gui/wxpython/nviz include lib/nviz lib/ogsf visualization/nviz2/cmd
Tue Sep 29 04:37:07 EDT 2009
Author: marisn
Date: 2009-09-29 04:37:06 -0400 (Tue, 29 Sep 2009)
New Revision: 39323
   grass/trunk/gui/wxpython/nviz/vector.cpp
   grass/trunk/include/gstypes.h
   grass/trunk/include/gsurf.h
   grass/trunk/include/ogsf_proto.h
   grass/trunk/lib/nviz/map_obj.c
   grass/trunk/lib/ogsf/GP2.c
   grass/trunk/lib/ogsf/GS2.c
   grass/trunk/lib/ogsf/GV2.c
   grass/trunk/lib/ogsf/GVL2.c
   grass/trunk/lib/ogsf/Gp3.c
   grass/trunk/lib/ogsf/Gv3.c
   grass/trunk/lib/ogsf/gp.c
   grass/trunk/lib/ogsf/gpd.c
   grass/trunk/lib/ogsf/gsd_objs.c
   grass/trunk/lib/ogsf/gv.c
   grass/trunk/lib/ogsf/gvd.c
   grass/trunk/lib/ogsf/gvl.c
   grass/trunk/lib/ogsf/gvl_calc.c
   grass/trunk/visualization/nviz2/cmd/vector.c
Move OGSF to new vector feature styling approach
Modified: grass/trunk/gui/wxpython/nviz/vector.cpp
--- grass/trunk/gui/wxpython/nviz/vector.cpp	2009-09-29 07:31:55 UTC (rev 39322)
+++ grass/trunk/gui/wxpython/nviz/vector.cpp	2009-09-29 08:37:06 UTC (rev 39323)
@@ -119,8 +119,7 @@
     color = Nviz_color_from_str(color_str);
-    if (GP_set_sitemode(id, ST_ATT_NONE,
-			color, width, size, marker) < 0)
+    if (GP_set_style(id, color, width, size, marker) < 0)
 	return -2;
     return 1;
Modified: grass/trunk/include/gstypes.h
--- grass/trunk/include/gstypes.h	2009-09-29 07:31:55 UTC (rev 39322)
+++ grass/trunk/include/gstypes.h	2009-09-29 08:37:06 UTC (rev 39323)
@@ -162,6 +162,22 @@
    vector file to have multiple attributes ?   Cached lines should
    usually be stored as 2d, since they may be draped on multiple
    surfaces & Z will vary depending upon surface. */
+/* Struct for vector feature displaying attributes */
+typedef struct g_vect_style
+    int color; 		/* Line color */
+    int symbol;		/* Point symbol/line type */
+    float size;		/* Symbol size. Unset for lines. */
+    int width;		/* Line width. Also used for lines forming symbols i.e. X */
+    /*TODO:fill;	 Area fill pattern */
+    /*TODO:falpha;	 Area fill transparency */
+    /*TODO:lalpha;	 Line/boundary/point transparency */
+    /*TODO:struct *orientation;  Symbol orientation */
+    struct g_vect_style *next; /* Point to next gvstyle struct if single point has multiple styles. In such case feature with next style should be shifted.  */
+} gvstyle;
+/* Line instance */
 typedef struct g_line
     int type;
@@ -169,9 +185,15 @@
     int dims, npts;
     Point3 *p3;
     Point2 *p2;
+    struct line_cats *cats;	/* Store information about all layers/cats for thematic display */
+    gvstyle *style;	/* Line instance look&feel */
+    signed char highlighted; /* >0 Feature is highlighted */
     struct g_line *next;
 } geoline;
+/* Vector line layer */
     int gvect_id;
@@ -179,7 +201,6 @@
     int drape_surf_id[MAX_SURFS];	/* if you want 'em flat, define the surface */
     int flat_val;
     int n_surfs;
-    int color, width;
     char *filename;
     float x_trans, y_trans, z_trans;
     /* also maybe center & rotate? */
@@ -188,59 +209,47 @@
     int (*bgn_read) (), (*end_read) (), (*nxt_line) ();
     struct g_vect *next;
     void *clientdata;
+    int thematic_layer;		/* Layer number to use for thematic mapping. <0 == no thematic mapping;
+				    0 == thematic mapping is unset but initialized;
+				    >0 use specified layer */
+    gvstyle *style;	/* Vector default look&feel */
+    gvstyle *hstyle;	/* IMHO highlight should be per layer basis. */
 } geovect;
-/* ACS_MODIFY one line site_attr ********************************************** */
-#define GPT_MAX_ATTR 8
+/* Point instance */
 typedef struct g_point
     int dims;
     Point3 p3;
-    float fattr;		/* may want to make these pointers or arrays for mult atts */
-    int iattr;
-    char *cattr;
+    gvstyle *style;
-    /* ACS_MODIFY_BEGIN site_attr ************************************************* */
-    int cat;
-    int color[GPT_MAX_ATTR];
-    float size[GPT_MAX_ATTR];
-    int marker[GPT_MAX_ATTR];
-    /* ACS_MODIFY_END site_attr *************************************************** */
-    /* ACS_MODIFY_BEGIN highlight ************************************************* */
-    int highlight_color;
-    int highlight_size;
-    int highlight_marker;
-    int highlight_color_value;
-    float highlight_size_value;
-    int highlight_marker_value;
-    /* ACS_MODIFY_END highlight *************************************************** */
     struct g_point *next;
 } geopoint;
+/* Point layer */
 typedef struct g_site
     int gsite_id;
     int drape_surf_id[MAX_SURFS];	/* ditto */
     int n_surfs, n_sites;
-    int color, width, marker, use_z, use_mem;
-    int has_z, has_att;		/* set when file loaded */
-    int attr_mode;		/* ST_ATT_COLOR, ST_ATT_MARKER, ST_ATT_SIZE, ST_ATT_NONE */
+    int use_z, use_mem;
+    int has_z;		/* set when file loaded */
-    /* ACS_MODIFY OneLine site_attr *********************************************** */
-    int use_attr[GPT_MAX_ATTR];	/* ST_ATT_COLOR, ST_ATT_MARKER, ST_ATT_SIZE, ST_ATT_NONE, for multiple attr's */
     char *filename;
     transform attr_trans;
-    float size;
     geopoint *points;
     int (*bgn_read) (), (*end_read) (), (*nxt_site) ();
     struct g_site *next;
     void *clientdata;
+    int thematic_layer; /* Layer number to use for thematic mapping. */
 } geosite;
 typedef struct
Modified: grass/trunk/include/gsurf.h
--- grass/trunk/include/gsurf.h	2009-09-29 07:31:55 UTC (rev 39322)
+++ grass/trunk/include/gsurf.h	2009-09-29 08:37:06 UTC (rev 39323)
@@ -86,16 +86,8 @@
 #define ST_CON_TREE   7
 #define ST_ASTER      8
 #define ST_GYRO       9
-/* ACS_MODIFY_One Line site_attr management ************************************** */
 #define ST_HISTOGRAM  10
-/* site attribute modes (what attribute of marker category is used for) */
-/* TODO: may want to make these OR'able */
-#define ST_ATT_NONE     0x00000000
-#define ST_ATT_COLOR    0x00000001
-#define ST_ATT_SIZE     0x00000002
-#define ST_ATT_MARKER   0x00000004
 /* Buffer modes */
 #define GSD_FRONT 1
 #define GSD_BACK  2
Modified: grass/trunk/include/ogsf_proto.h
--- grass/trunk/include/ogsf_proto.h	2009-09-29 07:31:55 UTC (rev 39322)
+++ grass/trunk/include/ogsf_proto.h	2009-09-29 08:37:06 UTC (rev 39323)
@@ -61,8 +61,8 @@
 int GP_delete_site(int);
 int GP_load_site(int, const char *);
 int GP_get_sitename(int, char **);
-int GP_get_sitemode(int, int *, int *, int *, float *, int *);
-int GP_set_sitemode(int, int, int, int, float, int);
+int GP_get_style(int, int *, int *, float *, int *);
+int GP_set_style(int, int, int, float, int);
 int GP_attmode_color(int, const char *);
 int GP_attmode_none(int);
 int GP_set_zmode(int, int);
@@ -306,7 +306,7 @@
 /* From Gp3.c */
 int Gp_set_color(const char *, geopoint *);
-geopoint *Gp_load_sites(const char *, int *, int *, int *);
+geopoint *Gp_load_sites(const char *, int *, int *);
 /* From Gs3.c */
 double Gs_distance(double *, double *);
@@ -369,7 +369,7 @@
 /* From gpd.c */
 int gs_point_in_region(geosurf *, float *, float *);
-void gpd_obj(geosurf *, int, float, int, Point3);
+void gpd_obj(geosurf *, gvstyle *, Point3);
 int gpd_2dsite(geosite *, geosurf *, int);
 int gpd_3dsite(geosite *, float, float, int);
Modified: grass/trunk/lib/nviz/map_obj.c
--- grass/trunk/lib/nviz/map_obj.c	2009-09-29 07:31:55 UTC (rev 39322)
+++ grass/trunk/lib/nviz/map_obj.c	2009-09-29 08:37:06 UTC (rev 39323)
@@ -136,7 +136,7 @@
 	/* initialize display parameters */
-	GP_set_sitemode(new_id, ST_ATT_NONE, 0xFF0000, 2, 100, ST_X);
+	GP_set_style(new_id, 0xFF0000, 2, 100, ST_X);
 	surf_list = GS_get_surf_list(&num_surfs);
 	for (i = 0; i < num_surfs; i++) {
 	    GP_select_surf(new_id, surf_list[i]);
@@ -340,9 +340,6 @@
     if (!gp)
 	return 0;
-    for (i = 0; i < GPT_MAX_ATTR; i++)
-	gp->use_attr[i] = ST_ATT_NONE;
     return 1;
Modified: grass/trunk/lib/ogsf/GP2.c
--- grass/trunk/lib/ogsf/GP2.c	2009-09-29 07:31:55 UTC (rev 39322)
+++ grass/trunk/lib/ogsf/GP2.c	2009-09-29 08:37:06 UTC (rev 39323)
@@ -39,6 +39,8 @@
     int i, found = 0;
+    G_debug(4, "GP_site_exists(%d)", id);
     if (NULL == gp_get_site(id)) {
 	return (0);
@@ -132,7 +134,7 @@
     int i, j, found = 0;
-    G_debug(3, "GP_delete_site(): id=%d", id);
+    G_debug(4, "GP_delete_site(%d)", id);
     if (GP_site_exists(id)) {
 	gp_delete_site(id);
@@ -174,6 +176,8 @@
     geosite *gp;
+    G_debug(3, "GP_load_site(%d, %s)", id, filename);
     if (NULL == (gp = gp_get_site(id))) {
 	return (-1);
@@ -184,8 +188,7 @@
     gp->filename = G_store(filename);
-    gp->points = Gp_load_sites(filename, &(gp->n_sites),
-			       &(gp->has_z), &(gp->has_att));
+    gp->points = Gp_load_sites(filename, &(gp->n_sites), &(gp->has_z));
     if (gp->points) {
 	return (1);
@@ -209,6 +212,8 @@
     geosite *gp;
+    G_debug(4, "GP_get_sitename(%d)", id);
 	return (-1);
@@ -219,106 +224,57 @@
-   \brief Get point set mode
+   \brief Get point set style
+   \param id point set id
+   \return -1 on error (point set not found)
-int GP_get_sitemode(int id, int *atmod, int *color, int *width, float *size,
-		    int *marker)
+int GP_get_style(int id, int *color, int *width, float *size, int *symbol)
     geosite *gp;
+    G_debug(4, "GP_get_style(%d)", id);
 	return (-1);
-    *atmod = gp->attr_mode;
-    *color = gp->color;
-    *width = gp->width;
-    *marker = gp->marker;
-    *size = gp->size;
+    *color = gp->style->color;
+    *width = gp->style->width;
+    *symbol = gp->style->symbol;
+    *size = gp->style->size;
     return (1);
-   \brief Set point set mode
+   \brief Set point set style
-   \param atmod
    \param color icon color
    \param width icon line width
    \param size icon size
-   \param marker icon symbol
+   \param symbol icon symbol
-int GP_set_sitemode(int id, int atmod, int color, int width, float size,
-		    int marker)
+int GP_set_style(int id, int color, int width, float size, int symbol)
     geosite *gp;
-    if (NULL == (gp = gp_get_site(id))) {
-	return (-1);
+    G_debug(4, "GP_set_style(%d, %d, %d, %f, %d)", id, color, width, size,
+	    symbol);
-    gp->attr_mode = atmod;	/* FIX this - probably should be seperate */
-    gp->color = color;
-    gp->width = width;
-    gp->marker = marker;
-    gp->size = size;
-    return (1);
-   \brief Set attribute mode color
-   \todo make similar routines for attmode_size, attmode_marker (use transform)
-   \param id surface id
-   \param filename filename
-   \return 1 for success
-   \return 0 for no attribute info
-   \return -1 for bad parameter
-int GP_attmode_color(int id, const char *filename)
-    geosite *gp;
 	return (-1);
-    if (!gp->has_att) {
-	return (0);
+    gp->style->color = color;
+    gp->style->symbol = symbol;
+    gp->style->size = size;
+    gp->style->width = width;
-    if (Gp_set_color(filename, gp->points)) {
-	gp->attr_mode = ST_ATT_COLOR;
-	return (1);
-    return (-1);
-   \brief Set attribute mode to none
-   \param id point set id
-   \return -1 on error (invalid point set id)
-   \return 1 on success
-int GP_attmode_none(int id)
-    geosite *gp;
-	return (-1);
-    gp->attr_mode = ST_ATT_NONE;
     return (1);
@@ -332,10 +288,13 @@
    \return 0 no z
+/* I don't see who is using it? Why it's required? */
 int GP_set_zmode(int id, int use_z)
     geosite *gp;
+    G_debug(3, "GP_set_zmode(%d,%d)", id, use_z);
 	return (-1);
@@ -362,10 +321,13 @@
+/* Who's using this? */
 int GP_get_zmode(int id, int *use_z)
     geosite *gp;
+    G_debug(4, "GP_get_zmode(%d)", id);
 	return (-1);
@@ -434,6 +396,8 @@
     geosite *gp;
+    G_debug(3, "GP_select_surf(%d,%d)", hp, hs);
     if (GP_surf_is_selected(hp, hs)) {
 	return (1);
@@ -463,6 +427,8 @@
     geosite *gp;
     int i, j;
+    G_debug(3, "GP_unselect_surf(%d,%d)", hp, hs);
     if (!GP_surf_is_selected(hp, hs)) {
 	return (1);
@@ -499,6 +465,8 @@
     int i;
     geosite *gp;
+    G_debug(3, "GP_surf_is_selected(%d,%d)", hp, hs);
     gp = gp_get_site(hp);
     if (gp) {
@@ -538,11 +506,8 @@
 		if (gs) {
 		    gpd_2dsite(gp, gs, 0);
-#ifdef TRACE_GP_FUNCS
-		    G_debug(3, "Drawing site %d on Surf %d", id,
+		    G_debug(5, "Drawing site %d on Surf %d", id,
 			    gp->drape_surf_id[i]);
-		    print_site_fields(gp);
-#endif
Modified: grass/trunk/lib/ogsf/GS2.c
--- grass/trunk/lib/ogsf/GS2.c	2009-09-29 07:31:55 UTC (rev 39322)
+++ grass/trunk/lib/ogsf/GS2.c	2009-09-29 08:37:06 UTC (rev 39323)
@@ -616,8 +616,10 @@
-   \brief ADD
+   \brief Draw place marker
+   Used to display query point for raster queries.
    \param pt point, X, Y value in true world coordinates
@@ -626,10 +628,11 @@
     geosurf *gs;
     Point3 pos;
     float siz;
+    gvstyle style;
     if ((gs = gs_get_surf(id))) {
 	GS_get_longdim(&siz);
-	siz /= 200.;
+	style.size = siz / 200.;
 	pos[X] = pt[X] - gs->ox;
 	pos[Y] = pt[Y] - gs->oy;
 	_viewcell_tri_interp(gs, pos);
@@ -644,8 +647,9 @@
 	    pos[Z] = gs->att[ATT_TOPO].constant;
 	    gs = NULL;		/* tells gpd_obj to use given Z val */
-	gpd_obj(gs, Gd.bgcol, siz, ST_GYRO, pos);
+	style.color = Gd.bgcol;
+	style.symbol = ST_GYRO;
+	gpd_obj(gs, &style, pos);
 	gsd_flush();
 	gsd_popmatrix();
@@ -1646,7 +1650,8 @@
 	if (0 < (hdata = gsds_findh(filename, &changed, &atty, begin))) {
-	    G_debug(3, "GS_load_att_map(): %s already has data handle %d.CF=%x",
+	    G_debug(3,
+		    "GS_load_att_map(): %s already has data handle %d.CF=%x",
 		    filename, hdata, changed);
 	    /* handle found */
@@ -1686,7 +1691,8 @@
 		filename, hdata);
     else {
-	G_debug(3, "GS_load_att_map(): %s not loaded in correct form - loading now",
+	G_debug(3,
+		"GS_load_att_map(): %s not loaded in correct form - loading now",
 		filename);
 	/* not loaded - need to get new dataset handle */
Modified: grass/trunk/lib/ogsf/GV2.c
--- grass/trunk/lib/ogsf/GV2.c	2009-09-29 07:31:55 UTC (rev 39322)
+++ grass/trunk/lib/ogsf/GV2.c	2009-09-29 08:37:06 UTC (rev 39323)
@@ -237,9 +237,9 @@
     gv->use_mem = mem;
-    gv->color = color;
-    gv->width = width;
     gv->flat_val = flat;
+    gv->style->color = color;
+    gv->style->width = width;
     return (1);
@@ -265,8 +265,8 @@
     *mem = gv->use_mem;
-    *color = gv->color;
-    *width = gv->width;
+    *color = gv->style->color;
+    *width = gv->style->width;
     *flat = gv->flat_val;
     return (1);
Modified: grass/trunk/lib/ogsf/GVL2.c
--- grass/trunk/lib/ogsf/GVL2.c	2009-09-29 07:31:55 UTC (rev 39322)
+++ grass/trunk/lib/ogsf/GVL2.c	2009-09-29 08:37:06 UTC (rev 39323)
@@ -239,8 +239,7 @@
     geovol *gvl;
     int handle;
-    G_debug(3, "GVL_load_vol(): id=%d, name=%s",
-	    id, filename);
+    G_debug(3, "GVL_load_vol(): id=%d, name=%s", id, filename);
     if (NULL == (gvl = gvl_get_vol(id))) {
 	return (-1);
Modified: grass/trunk/lib/ogsf/Gp3.c
--- grass/trunk/lib/ogsf/Gp3.c	2009-09-29 07:31:55 UTC (rev 39322)
+++ grass/trunk/lib/ogsf/Gp3.c	2009-09-29 08:37:06 UTC (rev 39323)
@@ -26,56 +26,6 @@
 #include <grass/gstypes.h>
-   \brief Set color for point set
-   used when site attribute mode is ST_ATT_COLOR
-   Gets color structure for grass file, goes through points and
-   uses fattr as CAT, putting rgb color in iattr.
-   \param grassname raster map name
-   \param gp pointer to geopoint struct
-   \return 0 on failure
-int Gp_set_color(const char *grassname, geopoint * gp)
-    const char *col_map;
-    struct Colors sc;
-    CELL cat;
-    geopoint *tp;
-    int r, g, b, color;
-    /* TODO: handle error messages */
-    if (grassname) {
-	col_map = G_find_raster2(grassname, "");
-	if (!col_map) {
-	    G_warning(_("Raster map <%s> not found"), grassname);
-	    return 0;
-	Rast_read_colors(grassname, col_map, &sc);
-	for (tp = gp; tp; tp = tp->next) {
-	    cat = (int)tp->fattr;
-	    color = NULL_COLOR;
-	    if (Rast_get_c_color(&cat, &r, &g, &b, &sc)) {
-		color = (r & 0xff) | ((g & 0xff) << 8) | ((b & 0xff) << 16);
-	    tp->iattr = color;
-	return (1);
-    return (0);
    \brief Load to points to memory
    The other alternative may be to load to a tmp file.
@@ -83,17 +33,15 @@
    \param grassname vector point map
    \param nsites
    \param has_z 2D or 3D points?
-   \param has_att attributes included
    \return pointer to geopoint struct
    \return NULL on failure
-geopoint *Gp_load_sites(const char *grassname, int *nsites, int *has_z,
-			int *has_att)
+geopoint *Gp_load_sites(const char *grassname, int *nsites, int *has_z)
     struct Map_info map;
     static struct line_pnts *Points = NULL;
-    static struct line_cats *Cats = NULL;
+    struct line_cats *Cats = NULL;
     geopoint *top, *gpt, *prev;
     int np, ltype, eof;
     struct Cell_head wind;
@@ -103,7 +51,7 @@
     np = 0;
     eof = 0;
-    *has_z = *has_att = 0;
+    *has_z = 0;
     mapset = G_find_vector2(grassname, "");
     if (!mapset) {
@@ -166,20 +114,17 @@
 		*has_z = 0;
+	    /* Store category info for thematic display */
 	    if (Cats->n_cats > 0) {
-		*has_att = 1;
-		gpt->fattr = Cats->field[0];	/* Is this correct? */
-		/* gpt->cat = ; ??** */
-		gpt->highlight_color = gpt->highlight_size =
-		    gpt->highlight_marker = FALSE;
+		gpt->cats = Cats;
+		Cats = Vect_new_cats_struct();
 	    else {
-		gpt->fattr = 0;
-		*has_att = 0;
+		gpt->cats = NULL;
+		Vect_reset_cats(Cats);
+	    gpt->highlighted = 0;
-	    gpt->iattr = gpt->fattr;
-	    gpt->cattr = NULL;
 	    G_debug(3, "loading vector point %d %f %f -- %d",
 		    np, Points->x[0], Points->y[0], Cats->n_cats);
Modified: grass/trunk/lib/ogsf/Gv3.c
--- grass/trunk/lib/ogsf/Gv3.c	2009-09-29 07:31:55 UTC (rev 39322)
+++ grass/trunk/lib/ogsf/Gv3.c	2009-09-29 08:37:06 UTC (rev 39323)
@@ -46,6 +46,7 @@
     struct line_pnts *points;
     geoline *top, *gln, *prev;
     int np, i, n, nareas, nl = 0, area, type, is3d;
@@ -77,6 +78,7 @@
 #endif
     points = Vect_new_line_struct();
     G_get_set_window(&wind);
     Vect_set_constraint_region(&map, wind.north, wind.south, wind.east,
@@ -90,7 +92,6 @@
     G_debug(3, "Reading vector areas (nareas = %d)", n);
     for (area = 1; area <= n; area++) {
 	G_debug(3, " area %d", area);
 	Vect_get_area_points(&map, area, points);
 	if (points->n_points < 3)
 	    continue;
@@ -159,9 +160,8 @@
     /* Read all lines */
     G_debug(3, "Reading vector lines ...");
-    while (-1 < (type = Vect_read_next_line(&map, points, NULL))) {
+    while (-1 < (type = Vect_read_next_line(&map, points, Cats))) {
 	G_debug(3, "line type = %d", type);
 	if (type & (GV_LINES | GV_FACE)) {
 	    if (type & (GV_LINES)) {
 		gln->type = OGSF_LINE;
@@ -219,6 +219,16 @@
 			gln->norm[2]);
+	    if (Cats->n_cats > 0) {
+		gln->cats = Cats;
+	    else {
+		gln->cats = NULL;
 	    gln->next = (geoline *) G_malloc(sizeof(geoline));	/* G_fatal_error */
 	    if (!gln->next) {
 		return (NULL);
Modified: grass/trunk/lib/ogsf/gp.c
--- grass/trunk/lib/ogsf/gp.c	2009-09-29 07:31:55 UTC (rev 39322)
+++ grass/trunk/lib/ogsf/gp.c	2009-09-29 08:37:06 UTC (rev 39323)
@@ -37,7 +37,7 @@
     geosite *gp;
-    G_debug(5, "gp_get_site");
+    G_debug(5, "gp_get_site(%d)", id);
     for (gp = Site_top; gp; gp = gp->next) {
 	if (gp->gsite_id == id) {
@@ -60,7 +60,7 @@
     geosite *pp;
-    G_debug(5, "gp_get_prev_site");
+    G_debug(5, "gp_get_prev_site(%d)", id);
     for (pp = Site_top; pp; pp = pp->next) {
 	if (pp->gsite_id == id - 1) {
@@ -139,6 +139,12 @@
     np->next = NULL;
+    np->style = (gvstyle *) G_malloc(sizeof(gvstyle));
+    if (!np->style)
+	return NULL;
+    np->hstyle = (gvstyle *) G_malloc(sizeof(gvstyle));
+    if (!np->hstyle)
+	return NULL;
     return (np);
@@ -196,13 +202,18 @@
     gp->filename = NULL;
     gp->n_sites = gp->use_z = gp->n_surfs = gp->use_mem = 0;
     gp->x_trans = gp->y_trans = gp->z_trans = 0.0;
-    gp->size = dim / 100.;
     gp->points = NULL;
-    gp->width = 1;
-    gp->color = 0xFFFFFF;
-    gp->marker = ST_X;
-    gp->has_z = gp->has_att = 0;
+    gp->has_z = 0;
+    gp->thematic_layer = -1;
+    gp->style->color = 0xF0F0F0;
+    gp->style->size = dim / 100.;
+    gp->style->width = 1;
+    gp->style->symbol = ST_X;
+    gp->style->next = NULL;
+    gp->hstyle->color = 0xFF0000;
+    gp->hstyle->size = dim / 150.;
+    gp->hstyle->symbol = ST_X;
+    gp->hstyle->next = NULL;
     gp->next = NULL;
     for (i = 0; i < MAX_SURFS; i++) {
 	gp->drape_surf_id[i] = 0;
@@ -212,34 +223,6 @@
-   \brief Print point set fields, debugging
-   \param gp pointer to geosite struct
-void print_site_fields(geosite * gp)
-    int i;
-    fprintf(stderr, "n_sites=%d use_z=%d n_surfs=%d use_mem=%d\n",
-	    gp->n_sites, gp->use_z, gp->n_surfs, gp->use_mem);
-    fprintf(stderr, "x_trans=%.2f x_trans=%.2f x_trans=%.2f\n",
-	    gp->x_trans, gp->y_trans, gp->z_trans);
-    fprintf(stderr, "size = %.2f\n", gp->size);
-    fprintf(stderr, "points = %lx\n", (unsigned long)gp->points);
-    fprintf(stderr, "width = %d\n", gp->width);
-    fprintf(stderr, "color = %x\n", gp->color);
-    fprintf(stderr, "marker = %d\n", gp->marker);
-    fprintf(stderr, "has_z = %d, has_att = %d\n", gp->has_z, gp->has_att);
-    fprintf(stderr, "attr_mode = %d\n", gp->attr_mode);
-    for (i = 0; i < MAX_SURFS; i++) {
-	fprintf(stderr, "drape_surf_id[%d] = %d\n", i, gp->drape_surf_id[i]);
-    return;
    \brief Initialize geosite struct
@@ -338,14 +321,24 @@
 void gp_free_sitemem(geosite * fp)
     geopoint *gpt, *tmp;
+    gvstyle *gvs, *tmpstyle;
     G_free((void *)fp->filename);
     fp->filename = NULL;
+    if (fp->style)
+	G_free(fp->style);
+    if (fp->hstyle)
+	G_free(fp->hstyle);
     if (fp->points) {
 	for (gpt = fp->points; gpt;) {
-	    if (gpt->cattr) {
-		G_free(gpt->cattr);
+	    G_free(gpt->cats);
+	    if (fp->thematic_layer > -1) {	/* Style also exists for features */
+		for (gvs = fp->style; gvs;) {
+		    tmpstyle = gvs;
+		    gvs = gvs->next;
+		    G_free(tmpstyle);
 	    tmp = gpt;
 	    gpt = gpt->next;
Modified: grass/trunk/lib/ogsf/gpd.c
--- grass/trunk/lib/ogsf/gpd.c	2009-09-29 07:31:55 UTC (rev 39322)
+++ grass/trunk/lib/ogsf/gpd.c	2009-09-29 08:37:06 UTC (rev 39323)
@@ -28,131 +28,7 @@
 /* BOB -- border allowed outside of viewport */
 #define v_border 50
-/* ACS_MODIFY_BEGIN site_attr management ************************************** */
-static float _cur_size_;
-   \brief Substitutes gpd_obj()
-   \param gs surface (geosurf)
-   \param gp site (geosite)
-   \param gpt point (point)
-   \param site point
-   \return 0
-int gpd_obj_site_attr(geosurf * gs, geosite * gp, geopoint * gpt, Point3 site)
-    float size, z, y, x, z_scale, z_offset;
-    int marker, color, i, ii, iii;
-    int use_attr, has_drawn;
-    int _put_aside_;
-    _put_aside_ = 0;
-    _cur_size_ = gp->size;
-    z_scale = GS_global_exag();
-    z_offset = 0.0;
-    has_drawn = 0;
-    for (i = 0; i < GPT_MAX_ATTR; i++) {
-	color = gp->color;
-	marker = gp->marker;
-	size = gp->size;
-	use_attr = 0;
-	if (gp->use_attr[i] & ST_ATT_COLOR) {
-	    use_attr = 1;
-	    color = gpt->color[i];
-	if (gp->use_attr[i] & ST_ATT_MARKER) {
-	    use_attr = 1;
-	    marker = gpt->marker[i];
-	if (gp->use_attr[i] & ST_ATT_SIZE) {
-	    use_attr = 1;
-	    size = gpt->size[i] * gp->size;
-	    if (gp->marker == ST_HISTOGRAM)
-		_put_aside_ = 1;
-	/* ACS_MODIFY_BEGIN site_highlight management ********************************* */
-	if (gpt->highlight_color)
-	    color = gpt->highlight_color_value;
-	if (gpt->highlight_marker)
-	    marker = gpt->highlight_marker_value;
-	if (gpt->highlight_size)
-	    size *= gpt->highlight_size_value;
-	/* ACS_MODIFY_END site_highlight management *********************************** */
-	if (_put_aside_) {
-	    if (use_attr == 1) {
-		has_drawn = 1;
-		fixed size = gp->size
-		this is mailny intended for "histograms" that grow in z, but not in xy
-        square filling to right and then up
-         15 14 13 12
-          8  7  6 11
-          3  2  5 10
-          0  1  4  9
-		x = site[X];
-		y = site[Y];
-		ii = (int)(sqrt(i));
-		iii = ii * ii + ii;
-		if (i <= iii) {
-		    site[X] += ii * 2.2 * gp->size;
-		    site[Y] += (i - ii) * 2.2 * gp->size;
-		else {
-		    site[X] += (ii - (i - iii)) * 2.2 * gp->size;
-		    site[Y] += ii * 2.2 * gp->size;
-		gpd_obj(gs, color, size, marker, site);
-		site[X] = x;
-		site[Y] = y;
-	else {
-	    if (i > 0)
-		z_offset += size;
-		has_drawn = 1;
-		z = site[Z];
-		site[Z] += z_offset / z_scale;
-		site[Z] = z;
-	    z_offset += size;
-    if (has_drawn == 0)
-    return (0);
-/* ACS_MODIFY_END site_attr management **************************************** */
    \brief Check if point is in region
    Check for cancel every CHK_FREQ points
@@ -186,30 +62,26 @@
-   \brief ADD
+   \brief Draw point representing object
    Do normal transforms before calling
    Note gs: NULL if 3d obj or const elev surface
-   \todo add size1, size2 & dir1, dir2 (eg azimuth, elevation) variables
-   \param size
-   \param marker
+   \param style object displaying style (highlighted or not)
    \param pt 3d point (Point3)
-void gpd_obj(geosurf * gs, int color, float size, int marker, Point3 pt)
+void gpd_obj(geosurf * gs, gvstyle * style, Point3 pt)
     float sz, lpt[3];
     float siz[3];
-    gsd_color_func(color);
+    gsd_color_func(style->color);
     sz = GS_global_exag();
     GS_v3eq(lpt, pt);		/* CHANGING Z OF POINT PASSED, so use copy */
-    switch (marker) {
-	/* ACS_MODIFY_BEGIN site_attr management ************************************** */
+    switch (style->symbol) {
     case ST_HISTOGRAM:
 	gsd_colormode(CM_DIFFUSE);
 	gsd_pushmatrix();
@@ -219,17 +91,16 @@
 	    gsd_scale(1.0, 1.0, 1. / sz);
-	siz[0] = _cur_size_;
-	siz[1] = _cur_size_;
-	siz[2] = size;
+	siz[0] = style->size;	/*TODO: Fix historgam drawing */
+	siz[1] = style->size;
+	siz[2] = style->size;
-	gsd_box(lpt, color, siz);
+	gsd_box(lpt, style->color, siz);
 	gsd_popmatrix();
 	gsd_colormode(CM_COLOR);
 	break;
-	/* ACS_MODIFY_END   site_attr management ************************************** */
     case ST_DIAMOND:
 	   gsd_colormode(CM_AD);
@@ -242,7 +113,7 @@
-	gsd_diamond(lpt, color, size);
+	gsd_diamond(lpt, style->color, style->size);
 	gsd_popmatrix();
@@ -256,7 +127,7 @@
-	gsd_draw_box(lpt, color, size);
+	gsd_draw_box(lpt, style->color, style->size);
 	gsd_popmatrix();
 	break;
@@ -272,7 +143,7 @@
-	gsd_sphere(lpt, size);
+	gsd_sphere(lpt, style->size);
 	gsd_popmatrix();
@@ -286,7 +157,7 @@
-	gsd_draw_gyro(lpt, color, size);
+	gsd_draw_gyro(lpt, style->color, style->size);
 	gsd_popmatrix();
 	break;
@@ -299,7 +170,7 @@
-	gsd_draw_asterisk(lpt, color, size);
+	gsd_draw_asterisk(lpt, style->color, style->size);
 	gsd_popmatrix();
 	break;
@@ -312,7 +183,7 @@
-	gsd_cube(lpt, color, size);
+	gsd_cube(lpt, style->color, style->size);
 	gsd_popmatrix();
@@ -320,7 +191,7 @@
     default:
     case ST_X:
-	gsd_x(gs, lpt, color, size);
+	gsd_x(gs, lpt, style->color, style->size);
 	break;
@@ -349,8 +220,7 @@
 int gpd_2dsite(geosite * gp, geosurf * gs, int do_fast)
     float site[3], konst;
-    float size;
-    int src, check, marker, color;
+    int src, check;
     geopoint *gpt;
     typbuff *buf;
     GLdouble modelMatrix[16], projMatrix[16];
@@ -384,12 +254,8 @@
 	gsd_translate(gs->x_trans, gs->y_trans, gs->z_trans);
-	gsd_linewidth(gp->width);
+	gsd_linewidth(gp->style->width);
 	check = 0;
-	size = gp->size;
 	for (gpt = gp->points; gpt; gpt = gpt->next) {
 	    if (!(++check % CHK_FREQ)) {
@@ -408,11 +274,6 @@
 		continue;
-	    /* TODO: set other dynamic attributes */
-	    if (gp->attr_mode & ST_ATT_COLOR) {
-		color = gpt->iattr;
 	    if (src == MAP_ATT) {
 		if (viewcell_tri_interp(gs, buf, site, 1)) {
 		    /* returns 0 if outside or masked */
@@ -421,23 +282,33 @@
 		    if (gsd_checkpoint
 			(site, window, viewport, modelMatrix, projMatrix))
 			continue;
+		    else {
+			if (gpt->highlighted > 0)
+			    gpd_obj(gs, gp->hstyle, site);
+			else if (gp->thematic_layer > 0)
+			    gpd_obj(gs, gpt->style, site);
 		    else
-			/* ACS_MODIFY_OneLine site_attr management - was: gpd_obj(gs, color, size, marker, site); */
-			gpd_obj_site_attr(gs, gp, gpt, site);
+			    gpd_obj(gs, gp->style, site);
 	    else if (src == CONST_ATT) {
 		if (gs_point_in_region(gs, site, NULL)) {
 		    site[Z] += gp->z_trans;
 		    if (gsd_checkpoint
 			continue;
+		    else {
 		    else
-			/* ACS_MODIFY_OneLine site_attr management - was: gpd_obj(NULL, color, size, marker, site); */
-			gpd_obj_site_attr(NULL, gp, gpt, site);
 	gsd_linewidth(1);
 	gsd_popmatrix();
@@ -459,8 +330,7 @@
 int gpd_3dsite(geosite * gp, float xo, float yo, int do_fast)
     float site[3], tz;
-    float size;
-    int check, color, marker;
+    int check;
     geopoint *gpt;
     GLint viewport[4];
@@ -480,11 +350,8 @@
     site[Z] = 0.0;
     check = 0;
-    size = gp->size;
@@ -503,18 +370,19 @@
 	    site[Z] = gpt->p3[Z] + gp->z_trans;
 	if (gsd_checkpoint(site, window, viewport, modelMatrix, projMatrix))
 	    continue;
 	else
 	    /* clip points outside default region? */
+		gpd_obj(NULL, gp->hstyle, site);
+		gpd_obj(NULL, gpt->style, site);
+	    else
+		gpd_obj(NULL, gp->style, site);
     gsd_linewidth(1);
     gsd_popmatrix();
Modified: grass/trunk/lib/ogsf/gsd_objs.c
--- grass/trunk/lib/ogsf/gsd_objs.c	2009-09-29 07:31:55 UTC (rev 39322)
+++ grass/trunk/lib/ogsf/gsd_objs.c	2009-09-29 08:37:06 UTC (rev 39323)
@@ -267,7 +267,7 @@
-   \brief ADD
+   \brief Draw X symbol
    Note gs: NULL if flat
@@ -823,6 +823,8 @@
    \return 1
+/*TODO: Store arrow somewhere to enable it's removal/change.
+   Add option to specify north text and font. */
 int gsd_north_arrow(float *pos2, float len, GLuint fontbase,
 		    unsigned long arw_clr, unsigned long text_clr)
Modified: grass/trunk/lib/ogsf/gv.c
--- grass/trunk/lib/ogsf/gv.c	2009-09-29 07:31:55 UTC (rev 39322)
+++ grass/trunk/lib/ogsf/gv.c	2009-09-29 08:37:06 UTC (rev 39323)
@@ -137,6 +137,13 @@
     nv->next = NULL;
+    nv->style = (gvstyle *) G_malloc(sizeof(gvstyle));
+    if (NULL == nv->style)
+	return NULL;
+    nv->hstyle = (gvstyle *) G_malloc(sizeof(gvstyle));
+    if (NULL == nv->hstyle)
+	return NULL;
     G_debug(5, "gv_get_new_vect() id=%d", nv->gvect_id);
     return (nv);
@@ -192,9 +199,15 @@
     gv->x_trans = gv->y_trans = gv->z_trans = 0.0;
     gv->lines = NULL;
     gv->fastlines = NULL;
-    gv->width = 1;
-    gv->color = 0xFFFFFF;
     gv->flat_val = 0;
+    gv->thematic_layer = -1;
+    gv->style->color = 0xF0F0F0;
+    gv->style->width = 1;
+    gv->style->next = NULL;
+    gv->hstyle->color = 0xFF0000;
+    gv->hstyle->width = 2;
+    gv->hstyle->next = NULL;
+    gv->next = NULL;
 	gv->drape_surf_id[i] = 0;
@@ -301,9 +314,14 @@
 void gv_free_vectmem(geovect * fv)
     geoline *gln, *tmpln;
     G_free((void *)fv->filename);
     fv->filename = NULL;
+    if (fv->style)
+	G_free(fv->style);
+    if (fv->hstyle)
+	G_free(fv->hstyle);
     if (fv->lines) {
 	for (gln = fv->lines; gln;) {
@@ -316,6 +334,15 @@
 		G_free(gln->p3);
+	    G_free(gln->cats);
+	    if (fv->thematic_layer > -1) {	/* Style also exists for features */
+		for (gvs = gln->style; gvs;) {
+		    tmpstyle = gvs;
+		    gvs = gvs->next;
+		    G_free(tmpstyle);
 	    tmpln = gln;
 	    gln = gln->next;
 	    sub_Vectmem(sizeof(geoline));
Modified: grass/trunk/lib/ogsf/gvd.c
--- grass/trunk/lib/ogsf/gvd.c	2009-09-29 07:31:55 UTC (rev 39322)
+++ grass/trunk/lib/ogsf/gvd.c	2009-09-29 08:37:06 UTC (rev 39323)
@@ -123,8 +123,8 @@
     gsd_translate(gs->x_trans, gs->y_trans, gs->z_trans + fudge);
-    gsd_color_func(gv->color);
-    gsd_linewidth(gv->width);
+    gsd_color_func(gv->style->color);
+    gsd_linewidth(gv->style->width);
     check = 0;
     if (do_fast) {
@@ -205,7 +205,7 @@
 		G_debug(5, "gvd_vect(): 3D vector line");
 		points = (Point3 *) malloc(sizeof(Point3));
 		gsd_bgnline();
 		for (k = 0; k < gln->npts; k++) {
 		    points[0][X] =
@@ -241,7 +241,7 @@
 		    glBegin(GL_POLYGON);
 		    glColor3f(1.0, 0, 0);
 		    glNormal3fv(gln->norm);
Modified: grass/trunk/lib/ogsf/gvl.c
--- grass/trunk/lib/ogsf/gvl.c	2009-09-29 07:31:55 UTC (rev 39322)
+++ grass/trunk/lib/ogsf/gvl.c	2009-09-29 08:37:06 UTC (rev 39323)
@@ -578,8 +578,7 @@
     geovol *gvl;
-    G_debug(5, "gvl_isosurf_get_isosurf(): id=%d isosurf=%d",
-	    id, isosurf_id);
+    G_debug(5, "gvl_isosurf_get_isosurf(): id=%d isosurf=%d", id, isosurf_id);
     gvl = gvl_get_vol(id);
Modified: grass/trunk/lib/ogsf/gvl_calc.c
--- grass/trunk/lib/ogsf/gvl_calc.c	2009-09-29 07:31:55 UTC (rev 39322)
+++ grass/trunk/lib/ogsf/gvl_calc.c	2009-09-29 08:37:06 UTC (rev 39323)
@@ -392,7 +392,8 @@
 	iso_get_cube_values(isosurf, ATT_EMIT, x, y, z, val[ATT_EMIT]);
-    FOR_0_TO_N(3, d_sum[FOR_VAR] = 0.; n_sum[FOR_VAR] = 0.);
+    FOR_0_TO_N(3, d_sum[FOR_VAR] = 0.;
+	       n_sum[FOR_VAR] = 0.);
     /* loop in edges */
     for (i = 0; i < cell_table[c_ndx].nedges; i++) {
Modified: grass/trunk/visualization/nviz2/cmd/vector.c
--- grass/trunk/visualization/nviz2/cmd/vector.c	2009-09-29 07:31:55 UTC (rev 39322)
+++ grass/trunk/visualization/nviz2/cmd/vector.c	2009-09-29 08:37:06 UTC (rev 39323)
@@ -180,8 +180,7 @@
 	else
 	    G_fatal_error(_("Unknown icon marker"));
-	GP_set_sitemode(site_list[i], ST_ATT_NONE,
-			color, width, size, marker);
+	GP_set_style(site_list[i], color, width, size, marker);
     return 1;
