[GRASS-SVN] r41702 - grass/trunk/vector/v.out.ogr
Sun Apr 4 07:20:10 EDT 2010
Author: neteler
Date: 2010-04-04 07:20:10 -0400 (Sun, 04 Apr 2010)
New Revision: 41702
   grass/trunk/vector/v.out.ogr/v.out.ogr.html
+3D point + faces export; examples simplified
Modified: grass/trunk/vector/v.out.ogr/v.out.ogr.html
--- grass/trunk/vector/v.out.ogr/v.out.ogr.html	2010-04-04 11:09:47 UTC (rev 41701)
+++ grass/trunk/vector/v.out.ogr/v.out.ogr.html	2010-04-04 11:20:10 UTC (rev 41702)
@@ -31,23 +31,31 @@
 <h3>Export to Shapefile</h3>
-Export lines from GRASS vector map to Shapefile format
- (generates /tmp/testogr.shp and related files):
+Export lines from GRASS vector map to Shapefile format:
 <div class="code"><pre>
-v.out.ogr input=multi type=line dsn=/tmp olayer=testogr
+v.out.ogr input=lines type=line dsn=lines.shp
 </pre></div>
+<p>
 Export areas from GRASS vector map to Shapefile format, converting
 islands (holes) to filled areas (generates /tmp/testogr.shp and related files):
-v.out.ogr -c input=multi type=area dsn=/tmp olayer=testogr
+v.out.ogr -c input=areas_islands type=area dsn=areas_islands.shp
 </pre></div>
-Export 3D lines from GRASS vector map to Shapefile format
- (use <tt>SHPT=POLYGONZ</tt> for 3D faces):
+<p>
+Export 3D lines from GRASS vector map to Shapefile format:
-v.out.ogr input=lines_3d type=line dsn=/tmp olayer=testogr lco="SHPT=ARCZ"
+v.out.ogr input=lines_3d type=line dsn=lines_3d.shp lco="SHPT=ARCZ"
 </pre></div>
+<p>
+Export 3D points (e.g., Lidar points) from GRASS vector map to Shapefile format
+<div class="code"><pre>
+v.out.ogr points_3d type=point dsn=points_3d.shp lco="SHPT=POINTZ"
+</pre></div>
+<p>
+Export 3D faces from GRASS vector map to Shapefile format:
+v.out.ogr input=objects_3d type=face dsn=faces_3d.shp lco="SHPT=POLYGONZ"
+</pre></div>
 <h3>Export to GML</h3>
