[GRASS-SVN] r41730 - grass/branches/develbranch_6/scripts/v.krige
Mon Apr 5 11:34:53 EDT 2010
Author: martinl
Date: 2010-04-05 11:34:52 -0400 (Mon, 05 Apr 2010)
New Revision: 41730
Added:
   grass/branches/develbranch_6/scripts/v.krige/v.krige.py
Removed:
   grass/branches/develbranch_6/scripts/v.krige/Makefile
rename script
Modified: grass/branches/develbranch_6/scripts/v.krige/Makefile
--- grass/branches/develbranch_6/scripts/v.krige/Makefile	2010-04-05 13:43:20 UTC (rev 41729)
+++ grass/branches/develbranch_6/scripts/v.krige/Makefile	2010-04-05 15:34:52 UTC (rev 41730)
@@ -1,7 +1,7 @@
 MODULE_TOPDIR = ../..
-PGM = v.krige
+PGM = v.krige.py
 include $(MODULE_TOPDIR)/include/Make/Script.make
-default: script
+default:
Deleted: grass/branches/develbranch_6/scripts/v.krige/v.krige
--- grass/branches/develbranch_6/scripts/v.krige/v.krige	2010-04-05 13:43:20 UTC (rev 41729)
+++ grass/branches/develbranch_6/scripts/v.krige/v.krige	2010-04-05 15:34:52 UTC (rev 41730)
@@ -1,421 +0,0 @@
-#!/usr/bin/env python
-MODULE:    v.krige
-AUTHOR(S): Anne Ghisla <a.ghisla AT gmail.com>
-PURPOSE:   Performs ordinary or block kriging
-DEPENDS:   R 2.x, packages gstat, maptools and spgrass6, optional: automap
-COPYRIGHT: (C) 2009 by the GRASS Development Team
-This program is free software under the GNU General Public
-License (>=v2). Read the file COPYING that comes with GRASS
-for details.
-## g.parser informations
-#%module
-#% description: Performs ordinary or block kriging.
-#% keywords: vector, interpolation, kriging
-#%end
-#%option
-#% key: input
-#% type: string
-#% gisprompt: old,vector,vector
-#% description: Name of point vector map containing sample data
-#% required: yes
-#%end
-#%option
-#% key: column
-#% type: string
-#% gisprompt: old,dbcolumn,dbcolumn
-#% description: Name of attribute column with numerical value to be interpolated
-#% required : yes
-#%end
-#%option
-#% key: output
-#% type: string
-#% gisprompt: new,cell,raster
-#% label: Name for output raster map
-#% description: If omitted, will be <input name>_kriging
-#% required : no
-#%end
-#%option
-#% key: package
-#% type: string
-#% options: gstat
-#% answer: gstat
-#% description: R package to use
-#% required: no
-#%end
-#%option
-#% key: model
-#% type: string
-#% options: Exp,Sph,Gau,Mat,Lin
-#% multiple: yes
-#% label: Variogram model(s)
-#% description: Leave empty to test all models (requires automap)
-#% required: no
-#%end
-#%option
-#% key: block
-#% type: integer
-#% multiple: no
-#% label: Block size (square block)
-#% description: Block size. Used by block kriging.
-#% required: no
-#%end
-#%option
-#% key: range
-#% type: integer
-#% label: Range value
-#% description: Automatically fixed if not set
-#% required : no
-#%end
-#%option
-#% key: nugget
-#% type: integer
-#% label: Nugget value
-#% required : no
-#%end
-#%option
-#% key: sill
-#% type: integer
-#% label: Sill value
-#% required : no
-#%end
-#%option
-#% key: output_var
-#% type: string
-#% label: Name for output variance raster map
-#% description: If omitted, will be <input name>_kriging_var
-#% required : no
-#%end
-import os, sys
-from tempfile import gettempdir
-import time
-import thread
-GUIModulesPath = os.path.join(os.getenv("GISBASE"), "etc", "wxpython", "gui_modules")
-sys.path.append(GUIModulesPath)
-#GUIPath = os.path.join(os.getenv("GISBASE"), "etc", "wxpython")
-#sys.path.append(GUIPath)
-#import globalvar
-#if not os.getenv("GRASS_WXBUNDLED"):
-#    globalvar.CheckForWx()
-#import gselect
-#import goutput
-#import menuform
-#from preferences import globalSettings as UserSettings
-##import help
-#import wx
-#import wx.lib.flatnotebook as FN
-##import wx.lib.plot as plot # for plotting the variogram.
-### i18N
-import gettext
-gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
-### dependencies to be checked once, as they are quite time-consuming. cfr. grass.parser.
-# GRASS binding
-try:
-    import grass.script as grass
-except ImportError:
-    sys.exit(_("No GRASS-python library found."))
-# move other checks in functions, as R?
-# globals
-Region = grass.region()
-Command = None
-InputData = None
-Variogram = None
-VariogramFunction = None
-robjects = None
-rinterface = None
-#classes in alphabetical order. methods in logical order :)
-class Controller:
-    """ Executes analysis. For the moment, only with gstat functions."""
-    def ImportMap(self, map, column):
-        """ Imports GRASS map as SpatialPointsDataFrame and adds x/y columns to attribute table.
-        Checks for NULL values in the provided column and exits if they are present."""
-        #@NOTE: new way with R - as it doesn't alter original data
-        Rpointmap = robjects.r.readVECT6(map, type =  'point')
-        # checks if x,y columns are present in dataframe. If they do are present, but with different names,
-        # they'll be duplicated.
-        if "x" not in robjects.r.names(Rpointmap):
-            # extract coordinates with S4 method
-            coordinatesPreDF = robjects.r['as.data.frame'](robjects.r.coordinates(Rpointmap))
-            coordinatesDF = robjects.r['data.frame'](x = coordinatesPreDF.r['coords.x1'][0],
-                                                     y = coordinatesPreDF.r['coords.x2'][0])
-            # match coordinates with data slot of SpatialPointsDataFrame - maptools function
-            # match is done on row.names
-            Rpointmap = robjects.r.spCbind(Rpointmap, coordinatesDF)
-        # GRASS checks for null values in the chosen column. R can hardly handle column as a variable,
-        # looks for a hardcoded string.
-        cols = grass.vector_columns(map=map, layer=1)
-        nulls = int(grass.parse_command('v.univar',
-                                        map=map,
-                                        column=column,
-                                        type='point',
-                                        parse = (grass.parse_key_val,
-                                                 {'sep':': '}
-                                        )['number of NULL attributes'])
-        if nulls > 0:
-            grass.fatal(_("%d NULL value(s) in the selected column - unable to perform kriging.") % nulls)
-        return Rpointmap
-    def CreateGrid(self, inputdata):
-        Grid = robjects.r.gmeta2grd()
-        # addition of coordinates columns into dataframe.
-        coordinatesDF = robjects.r['as.data.frame'](robjects.r.coordinates(Grid))
-        data = robjects.r['data.frame'](x = coordinatesDF.r['s1'][0],
-                                        y = coordinatesDF.r['s2'][0],
-                                        k = robjects.r.rep(1, Region['cols']*Region['rows']))
-        GridPredicted = robjects.r.SpatialGridDataFrame(Grid,
-                                                        data,
-                                                        proj4string =  robjects.r.CRS(robjects.r.proj4string(inputdata)))
-        return GridPredicted
-    def ComposeFormula(self, column, isblock, inputdata):
-        if isblock is True:
-            predictor = 'x+y'
-        else:
-            predictor = 1
-        Formula = robjects.r['as.formula'](robjects.r.paste(column, "~", predictor))
-        #print Formula
-        return Formula
-    def FitVariogram(self, formula, inputdata, sill, nugget, range, model = ''):
-        """ Fits variogram either automagically either specifying all parameters.
-        Returns a list containing data and model variograms. """
-        Variograms = {}
-        if model is '':
-            robjects.r.require('automap')
-            DottedParams = {}
-            #print (nugget.r_repr(), sill, range)
-            DottedParams['fix.values'] = robjects.r.c(nugget, range, sill)
-            VariogramModel = robjects.r.autofitVariogram(formula, inputdata, **DottedParams)
-            #print robjects.r.warnings()
-            Variograms['datavariogram'] = VariogramModel.r['exp_var'][0]
-            Variograms['variogrammodel'] = VariogramModel.r['var_model'][0]
-            # obtain the model name. *Too* complicated to get the string instead of level, unlike R does.
-            VariogramAsDF = robjects.r['as.data.frame'](VariogramModel.r['var_model'][0]) # force conversion
-            ModelDF = VariogramAsDF.r['model'][0]
-            Variograms['model'] = robjects.r.levels(ModelDF).subset(ModelDF[1])[0]
-        else:
-            DataVariogram = robjects.r['variogram'](formula, inputdata)
-            VariogramModel = robjects.r['fit.variogram'](DataVariogram,
-                                                         model = robjects.r.vgm(psill = sill,
-        model = model,
-        nugget = nugget,
-        range = range))
-            Variograms['datavariogram'] = DataVariogram
-            Variograms['model'] = model
-        return Variograms
-    def DoKriging(self, formula, inputdata, grid, model, block):
-        DottedParams = {'debug.level': -1} # let krige() print percentage status
-        if block is not '': #@FIXME(anne): but it's a string!! and krige accepts it!!
-            DottedParams['block'] = block
-        #print DottedParams
-        KrigingResult = robjects.r.krige(formula, inputdata, grid, model, **DottedParams)
-        return KrigingResult
-    def ExportMap(self, map, column, name, overwrite, command, variograms):
-        # add kriging parameters to raster map history
-        robjects.r.writeRAST6(map, vname = name, zcol = column, overwrite = overwrite)
-        grass.run_command('r.support',
-                          map = name,
-                          title = 'Kriging output',
-                          history = 'Issued from command v.krige ' + command)
-        if command.find('model') is -1: # if the command has no model option, add automap chosen model
-                                      map = name,
-                                      history = 'Model chosen by automatic fitting: ' + variograms['model'])
-    def Run(self, input, column, output, package, sill, nugget, range, logger, \
-            overwrite, model, block, output_var, command, **kwargs):
-        """ Wrapper for all functions above. """
-        logger.message(_("Processing %d cells. Computing time raises exponentially with resolution." % Region['cells']))
-        logger.message(_("Importing data..."))
-        if globals()["InputData"] is None:
-            globals()["InputData"] = self.ImportMap(input, column)
-        # and from here over, InputData refers to the global variable
-        #print(robjects.r.slot(InputData, 'data').names)
-        logger.message(_("Data successfully imported."))
-        GridPredicted = self.CreateGrid(InputData)
-        logger.message(_("Fitting variogram..."))
-        isblock = block is not ''
-        Formula = self.ComposeFormula(column, isblock, InputData)
-        if globals()["Variogram"] is None:
-            globals()["Variogram"] = self.FitVariogram(Formula,
-                                          InputData,
-                                          model = model,
-                                          sill = sill,
-                                          nugget = nugget,
-                                          range = range)
-        logger.message(_("Variogram fitted."))
-        logger.message(_("Kriging..."))
-        KrigingResult = self.DoKriging(Formula, InputData, GridPredicted, Variogram['variogrammodel'], block) # using global ones
-        logger.message(_("Kriging performed."))
-        self.ExportMap(map = KrigingResult,
-                       column='var1.pred',
-                       name = output,
-                       overwrite = overwrite,
-                       command = command,
-                       variograms = Variogram)
-        if output_var is not '':
-                           column='var1.var',
-                           name = output_var,
-def main(argv = None):
-    """ Main. Calls either GUI or CLI, depending on arguments provided. """
-    #@FIXME: solve this double ifelse. the control should not be done twice.
-    controller = Controller()
-    if argv is None:
-        importR()
-        argv = sys.argv[1:] #stripping first item, the full name of this script
-        # wxGUI call.
-        import v_krige_wxGUI
-        import wx
-        app = wx.App()
-        KrigingFrame = v_krige_wxGUI.KrigingModule(parent = None,
-                                                   Rinstance = robjects,
-                                                   controller = controller)
-        KrigingFrame.Centre()
-        KrigingFrame.Show()
-        app.MainLoop()
-    else:
-        #CLI
-        options, flags = argv
-        #@TODO: Work on verbosity. Sometimes it's too verbose (R), sometimes not enough.
-        if grass.find_file(options['input'], element = 'vector')['fullname'] is '':
-            grass.fatal(_("option: <input>: Vector map not found.")) #TODO cosmetics, insert real map name
-        #@TODO: elaborate input string, if contains mapset or not.. thanks again to Bob for testing on 64bit.
-        # create output map name, if not specified
-        if options['output'] is '':
-            try: # to strip mapset name from fullname. Ugh.
-                options['input'] = options['input'].split("@")[0]
-            except:
-                pass
-            options['output'] = options['input'] + '_kriging'
-        # check for output map with same name. g.parser can't handle this, afaik.
-        if grass.find_file(options['output'], element = 'cell')['fullname'] and os.getenv("GRASS_OVERWRITE") == None:
-            grass.fatal(_("option: <output>: Raster map already exists."))
-        if options['output_var'] is not '' and (grass.find_file(options['output_var'], element = 'cell')['fullname'] and os.getenv("GRASS_OVERWRITE") == None):
-            grass.fatal(_("option: <output>: Variance raster map already exists."))
-        importR()
-        if options['model'] is '':
-            try:
-                robjects.r.require("automap")
-            except ImportError, e:
-                grass.fatal(_("R package automap is missing, no variogram autofit available."))
-        else:
-            if options['sill'] is '' or options['nugget'] is '' or options['range'] is '':
-                grass.fatal(_("You have specified model, but forgot at least one of sill, nugget and range."))
-        #@TODO: let GRASS remount its commandstring. Until then, keep that 4 lines below.
-        #print grass.write_command(argv)
-        command = ""
-        notnulloptions = {}
-        for k, v in options.items():
-            if v is not '':
-                notnulloptions[k] = v
-        command = command.join("%s=%s " % (k, v) for k, v in notnulloptions.items())
-        #print command
-        # re-cast integers from strings, as parser() cast everything to string.
-        for each in ("sill","nugget","range"):
-            if options[each] is not '':
-                options[each] = int(options[each])
-            else:
-                options[each] = robjects.r('''NA''')
-        #controller = Controller()
-        controller.Run(input = options['input'],
-                       column = options['column'],
-                       output = options['output'],
-                       overwrite = os.getenv("GRASS_OVERWRITE") == 1,
-                       package = options['package'],
-                       model = options['model'],
-                       block = options['block'],
-                       sill = options['sill'],
-                       nugget = options['nugget'],
-                       range = options['range'],
-                       output_var = options['output_var'],
-                       logger = grass)
-def importR():
-    # R
-    # unuseful since rpy2 will complain adequately.
-    # try:
-    #    #@FIXME: in Windows, it launches R terminal
-    #    grass.find_program('R')
-    # except:
-    #    sys.exit(_("R is not installed. Install it and re-run, or modify environment variables."))
-    # rpy2
-    global robjects
-    global rinterface
-    grass.message(_('Loading packages, please wait...'))
-    try:
-        import rpy2.robjects as robjects
-        import rpy2.rinterface as rinterface #to speed up kriging? for plots.
-        haveRpy2 = True
-    except ImportError:
-        print >> sys.stderr, _("Rpy2 not found. Please install it and re-run.") # ok for other OSes?
-        haveRpy2 = False
-        if not haveRpy2:
-            sys.exit(1)
-    # R packages check.
-    # @FIXME: it leaves a Rtmpxxxx folder into the make tempfolder and causes make complain. [markus]
-    for each in ["gstat", "spgrass6", "maptools"]:
-        if not robjects.r.require(each, quietly = True)[0]:
-            sys.exit(_("R package '%s' is missing. Install it and re-run v.krige.") % each)
-if __name__ == '__main__':
-    if len(sys.argv) > 1:
-        sys.exit(main(argv = grass.parser()))
-    else:
-        main()
Copied: grass/branches/develbranch_6/scripts/v.krige/v.krige.py (from rev 41705, grass/branches/develbranch_6/scripts/v.krige/v.krige)
--- grass/branches/develbranch_6/scripts/v.krige/v.krige.py	                        (rev 0)
+++ grass/branches/develbranch_6/scripts/v.krige/v.krige.py	2010-04-05 15:34:52 UTC (rev 41730)
@@ -0,0 +1,421 @@
+#!/usr/bin/env python
+MODULE:    v.krige
+AUTHOR(S): Anne Ghisla <a.ghisla AT gmail.com>
+PURPOSE:   Performs ordinary or block kriging
+DEPENDS:   R 2.x, packages gstat, maptools and spgrass6, optional: automap
+COPYRIGHT: (C) 2009 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+## g.parser informations
+#%module
+#% description: Performs ordinary or block kriging.
+#% keywords: vector, interpolation, kriging
+#%end
+#%option
+#% key: input
+#% type: string
+#% gisprompt: old,vector,vector
+#% description: Name of point vector map containing sample data
+#% required: yes
+#%end
+#%option
+#% key: column
+#% type: string
+#% gisprompt: old,dbcolumn,dbcolumn
+#% description: Name of attribute column with numerical value to be interpolated
+#% required : yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new,cell,raster
+#% label: Name for output raster map
+#% description: If omitted, will be <input name>_kriging
+#% required : no
+#%end
+#%option
+#% key: package
+#% type: string
+#% options: gstat
+#% answer: gstat
+#% description: R package to use
+#% required: no
+#%end
+#%option
+#% key: model
+#% type: string
+#% options: Exp,Sph,Gau,Mat,Lin
+#% multiple: yes
+#% label: Variogram model(s)
+#% description: Leave empty to test all models (requires automap)
+#% required: no
+#%end
+#%option
+#% key: block
+#% type: integer
+#% multiple: no
+#% label: Block size (square block)
+#% description: Block size. Used by block kriging.
+#% required: no
+#%end
+#%option
+#% key: range
+#% type: integer
+#% label: Range value
+#% description: Automatically fixed if not set
+#% required : no
+#%end
+#%option
+#% key: nugget
+#% type: integer
+#% label: Nugget value
+#% required : no
+#%end
+#%option
+#% key: sill
+#% type: integer
+#% label: Sill value
+#% required : no
+#%end
+#%option
+#% key: output_var
+#% type: string
+#% label: Name for output variance raster map
+#% description: If omitted, will be <input name>_kriging_var
+#% required : no
+#%end
+import os, sys
+from tempfile import gettempdir
+import time
+import thread
+GUIModulesPath = os.path.join(os.getenv("GISBASE"), "etc", "wxpython", "gui_modules")
+sys.path.append(GUIModulesPath)
+#GUIPath = os.path.join(os.getenv("GISBASE"), "etc", "wxpython")
+#sys.path.append(GUIPath)
+#import globalvar
+#if not os.getenv("GRASS_WXBUNDLED"):
+#    globalvar.CheckForWx()
+#import gselect
+#import goutput
+#import menuform
+#from preferences import globalSettings as UserSettings
+##import help
+#import wx
+#import wx.lib.flatnotebook as FN
+##import wx.lib.plot as plot # for plotting the variogram.
+### i18N
+import gettext
+gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
+### dependencies to be checked once, as they are quite time-consuming. cfr. grass.parser.
+# GRASS binding
+try:
+    import grass.script as grass
+except ImportError:
+    sys.exit(_("No GRASS-python library found."))
+# move other checks in functions, as R?
+# globals
+Region = grass.region()
+Command = None
+InputData = None
+Variogram = None
+VariogramFunction = None
+robjects = None
+rinterface = None
+#classes in alphabetical order. methods in logical order :)
+class Controller:
+    """ Executes analysis. For the moment, only with gstat functions."""
+    def ImportMap(self, map, column):
+        """ Imports GRASS map as SpatialPointsDataFrame and adds x/y columns to attribute table.
+        Checks for NULL values in the provided column and exits if they are present."""
+        #@NOTE: new way with R - as it doesn't alter original data
+        Rpointmap = robjects.r.readVECT6(map, type =  'point')
+        # checks if x,y columns are present in dataframe. If they do are present, but with different names,
+        # they'll be duplicated.
+        if "x" not in robjects.r.names(Rpointmap):
+            # extract coordinates with S4 method
+            coordinatesPreDF = robjects.r['as.data.frame'](robjects.r.coordinates(Rpointmap))
+            coordinatesDF = robjects.r['data.frame'](x = coordinatesPreDF.r['coords.x1'][0],
+                                                     y = coordinatesPreDF.r['coords.x2'][0])
+            # match coordinates with data slot of SpatialPointsDataFrame - maptools function
+            # match is done on row.names
+            Rpointmap = robjects.r.spCbind(Rpointmap, coordinatesDF)
+        # GRASS checks for null values in the chosen column. R can hardly handle column as a variable,
+        # looks for a hardcoded string.
+        cols = grass.vector_columns(map=map, layer=1)
+        nulls = int(grass.parse_command('v.univar',
+                                        map=map,
+                                        column=column,
+                                        type='point',
+                                        parse = (grass.parse_key_val,
+                                                 {'sep':': '}
+                                        )['number of NULL attributes'])
+        if nulls > 0:
+            grass.fatal(_("%d NULL value(s) in the selected column - unable to perform kriging.") % nulls)
+        return Rpointmap
+    def CreateGrid(self, inputdata):
+        Grid = robjects.r.gmeta2grd()
+        # addition of coordinates columns into dataframe.
+        coordinatesDF = robjects.r['as.data.frame'](robjects.r.coordinates(Grid))
+        data = robjects.r['data.frame'](x = coordinatesDF.r['s1'][0],
+                                        y = coordinatesDF.r['s2'][0],
+                                        k = robjects.r.rep(1, Region['cols']*Region['rows']))
+        GridPredicted = robjects.r.SpatialGridDataFrame(Grid,
+                                                        data,
+                                                        proj4string =  robjects.r.CRS(robjects.r.proj4string(inputdata)))
+        return GridPredicted
+    def ComposeFormula(self, column, isblock, inputdata):
+        if isblock is True:
+            predictor = 'x+y'
+        else:
+            predictor = 1
+        Formula = robjects.r['as.formula'](robjects.r.paste(column, "~", predictor))
+        #print Formula
+        return Formula
+    def FitVariogram(self, formula, inputdata, sill, nugget, range, model = ''):
+        """ Fits variogram either automagically either specifying all parameters.
+        Returns a list containing data and model variograms. """
+        Variograms = {}
+        if model is '':
+            robjects.r.require('automap')
+            DottedParams = {}
+            #print (nugget.r_repr(), sill, range)
+            DottedParams['fix.values'] = robjects.r.c(nugget, range, sill)
+            VariogramModel = robjects.r.autofitVariogram(formula, inputdata, **DottedParams)
+            #print robjects.r.warnings()
+            Variograms['datavariogram'] = VariogramModel.r['exp_var'][0]
+            Variograms['variogrammodel'] = VariogramModel.r['var_model'][0]
+            # obtain the model name. *Too* complicated to get the string instead of level, unlike R does.
+            VariogramAsDF = robjects.r['as.data.frame'](VariogramModel.r['var_model'][0]) # force conversion
+            ModelDF = VariogramAsDF.r['model'][0]
+            Variograms['model'] = robjects.r.levels(ModelDF).subset(ModelDF[1])[0]
+        else:
+            DataVariogram = robjects.r['variogram'](formula, inputdata)
+            VariogramModel = robjects.r['fit.variogram'](DataVariogram,
+                                                         model = robjects.r.vgm(psill = sill,
+        model = model,
+        nugget = nugget,
+        range = range))
+            Variograms['datavariogram'] = DataVariogram
+            Variograms['model'] = model
+        return Variograms
+    def DoKriging(self, formula, inputdata, grid, model, block):
+        DottedParams = {'debug.level': -1} # let krige() print percentage status
+        if block is not '': #@FIXME(anne): but it's a string!! and krige accepts it!!
+            DottedParams['block'] = block
+        #print DottedParams
+        KrigingResult = robjects.r.krige(formula, inputdata, grid, model, **DottedParams)
+        return KrigingResult
+    def ExportMap(self, map, column, name, overwrite, command, variograms):
+        # add kriging parameters to raster map history
+        robjects.r.writeRAST6(map, vname = name, zcol = column, overwrite = overwrite)
+        grass.run_command('r.support',
+                          map = name,
+                          title = 'Kriging output',
+                          history = 'Issued from command v.krige ' + command)
+        if command.find('model') is -1: # if the command has no model option, add automap chosen model
+                                      map = name,
+                                      history = 'Model chosen by automatic fitting: ' + variograms['model'])
+    def Run(self, input, column, output, package, sill, nugget, range, logger, \
+            overwrite, model, block, output_var, command, **kwargs):
+        """ Wrapper for all functions above. """
+        logger.message(_("Processing %d cells. Computing time raises exponentially with resolution." % Region['cells']))
+        logger.message(_("Importing data..."))
+        if globals()["InputData"] is None:
+            globals()["InputData"] = self.ImportMap(input, column)
+        # and from here over, InputData refers to the global variable
+        #print(robjects.r.slot(InputData, 'data').names)
+        logger.message(_("Data successfully imported."))
+        GridPredicted = self.CreateGrid(InputData)
+        logger.message(_("Fitting variogram..."))
+        isblock = block is not ''
+        Formula = self.ComposeFormula(column, isblock, InputData)
+        if globals()["Variogram"] is None:
+            globals()["Variogram"] = self.FitVariogram(Formula,
+                                          InputData,
+                                          model = model,
+                                          sill = sill,
+                                          nugget = nugget,
+                                          range = range)
+        logger.message(_("Variogram fitted."))
+        logger.message(_("Kriging..."))
+        KrigingResult = self.DoKriging(Formula, InputData, GridPredicted, Variogram['variogrammodel'], block) # using global ones
+        logger.message(_("Kriging performed."))
+        self.ExportMap(map = KrigingResult,
+                       column='var1.pred',
+                       name = output,
+                       overwrite = overwrite,
+                       command = command,
+                       variograms = Variogram)
+        if output_var is not '':
+                           column='var1.var',
+                           name = output_var,
+def main(argv = None):
+    """ Main. Calls either GUI or CLI, depending on arguments provided. """
+    #@FIXME: solve this double ifelse. the control should not be done twice.
+    controller = Controller()
+    if argv is None:
+        importR()
+        argv = sys.argv[1:] #stripping first item, the full name of this script
+        # wxGUI call.
+        import v_krige_wxGUI
+        import wx
+        app = wx.App()
+        KrigingFrame = v_krige_wxGUI.KrigingModule(parent = None,
+                                                   Rinstance = robjects,
+                                                   controller = controller)
+        KrigingFrame.Centre()
+        KrigingFrame.Show()
+        app.MainLoop()
+    else:
+        #CLI
+        options, flags = argv
+        #@TODO: Work on verbosity. Sometimes it's too verbose (R), sometimes not enough.
+        if grass.find_file(options['input'], element = 'vector')['fullname'] is '':
+            grass.fatal(_("option: <input>: Vector map not found.")) #TODO cosmetics, insert real map name
+        #@TODO: elaborate input string, if contains mapset or not.. thanks again to Bob for testing on 64bit.
+        # create output map name, if not specified
+        if options['output'] is '':
+            try: # to strip mapset name from fullname. Ugh.
+                options['input'] = options['input'].split("@")[0]
+            except:
+                pass
+            options['output'] = options['input'] + '_kriging'
+        # check for output map with same name. g.parser can't handle this, afaik.
+        if grass.find_file(options['output'], element = 'cell')['fullname'] and os.getenv("GRASS_OVERWRITE") == None:
+            grass.fatal(_("option: <output>: Raster map already exists."))
+        if options['output_var'] is not '' and (grass.find_file(options['output_var'], element = 'cell')['fullname'] and os.getenv("GRASS_OVERWRITE") == None):
+            grass.fatal(_("option: <output>: Variance raster map already exists."))
+        importR()
+        if options['model'] is '':
+            try:
+                robjects.r.require("automap")
+            except ImportError, e:
+                grass.fatal(_("R package automap is missing, no variogram autofit available."))
+        else:
+            if options['sill'] is '' or options['nugget'] is '' or options['range'] is '':
+                grass.fatal(_("You have specified model, but forgot at least one of sill, nugget and range."))
+        #@TODO: let GRASS remount its commandstring. Until then, keep that 4 lines below.
+        #print grass.write_command(argv)
+        command = ""
+        notnulloptions = {}
+        for k, v in options.items():
+            if v is not '':
+                notnulloptions[k] = v
+        command = command.join("%s=%s " % (k, v) for k, v in notnulloptions.items())
+        #print command
+        # re-cast integers from strings, as parser() cast everything to string.
+        for each in ("sill","nugget","range"):
+            if options[each] is not '':
+                options[each] = int(options[each])
+            else:
+                options[each] = robjects.r('''NA''')
+        #controller = Controller()
+        controller.Run(input = options['input'],
+                       column = options['column'],
+                       output = options['output'],
+                       overwrite = os.getenv("GRASS_OVERWRITE") == 1,
+                       package = options['package'],
+                       model = options['model'],
+                       block = options['block'],
+                       sill = options['sill'],
+                       nugget = options['nugget'],
+                       range = options['range'],
+                       output_var = options['output_var'],
+                       logger = grass)
+def importR():
+    # R
+    # unuseful since rpy2 will complain adequately.
+    # try:
+    #    #@FIXME: in Windows, it launches R terminal
+    #    grass.find_program('R')
+    # except:
+    #    sys.exit(_("R is not installed. Install it and re-run, or modify environment variables."))
+    # rpy2
+    global robjects
+    global rinterface
+    grass.message(_('Loading packages, please wait...'))
+    try:
+        import rpy2.robjects as robjects
+        import rpy2.rinterface as rinterface #to speed up kriging? for plots.
+        haveRpy2 = True
+    except ImportError:
+        print >> sys.stderr, _("Rpy2 not found. Please install it and re-run.") # ok for other OSes?
+        haveRpy2 = False
+        if not haveRpy2:
+            sys.exit(1)
+    # R packages check.
+    # @FIXME: it leaves a Rtmpxxxx folder into the make tempfolder and causes make complain. [markus]
+    for each in ["gstat", "spgrass6", "maptools"]:
+        if not robjects.r.require(each, quietly = True)[0]:
+            sys.exit(_("R package '%s' is missing. Install it and re-run v.krige.") % each)
+if __name__ == '__main__':
+    if len(sys.argv) > 1:
+        sys.exit(main(argv = grass.parser()))
+    else:
+        main()
