[GRASS-SVN] r41861 - in grass/trunk: raster/r.grow.distance scripts/r.buffer
Wed Apr 14 10:33:27 EDT 2010
Author: martinl
Date: 2010-04-14 10:33:27 -0400 (Wed, 14 Apr 2010)
New Revision: 41861
   grass/trunk/raster/r.grow.distance/main.c
   grass/trunk/scripts/r.buffer/r.buffer.py
r.buffer/r.grow.distance: be more verbose
Modified: grass/trunk/raster/r.grow.distance/main.c
--- grass/trunk/raster/r.grow.distance/main.c	2010-04-14 14:03:56 UTC (rev 41860)
+++ grass/trunk/raster/r.grow.distance/main.c	2010-04-14 14:33:27 UTC (rev 41861)
@@ -1,7 +1,7 @@
- * MODULE:       r.grow2
+ * MODULE:       r.grow.distance
  * AUTHOR(S):    Marjorie Larson - CERL
  *               Glynn Clements
@@ -9,7 +9,7 @@
  * PURPOSE:      Generates a raster map layer with contiguous areas
  *               grown by one cell.
- * COPYRIGHT:    (C) 2006 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2006, 2010 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -147,8 +147,9 @@
     module = G_define_module();
     G_add_keyword(_("raster"));
+    G_add_keyword(_("distance"));
     module->description =
-	_("Generates a raster map layer of distance to features in input layer.");
+	_("Generates a raster map of distance to features in input raster map.");
     opt.in = G_define_standard_option(G_OPT_R_INPUT);
@@ -203,7 +204,7 @@
 	G_begin_geodesic_distance(a, e2);
     else
-	G_fatal_error(_("Unknown metric: [%s]."), opt.met->answer);
+	G_fatal_error(_("Unknown metric: '%s'"), opt.met->answer);
     if (flag.m->answer)
 	scale = G_database_units_to_meters_factor();
@@ -246,6 +247,7 @@
     Rast_set_c_null_value(old_x_row, ncols);
     Rast_set_c_null_value(old_y_row, ncols);
+    G_message(_("Reading raster map <%s>..."), opt.in->answer);
     for (row = 0; row < nrows; row++) {
 	int irow = nrows - 1 - row;
@@ -293,6 +295,7 @@
+    G_message(_("Writing output raster maps..."), opt.in->answer);
 	off_t offset =
Modified: grass/trunk/scripts/r.buffer/r.buffer.py
--- grass/trunk/scripts/r.buffer/r.buffer.py	2010-04-14 14:03:56 UTC (rev 41860)
+++ grass/trunk/scripts/r.buffer/r.buffer.py	2010-04-14 14:33:27 UTC (rev 41861)
@@ -6,7 +6,7 @@
 # AUTHOR(S):	Glynn Clements
 # PURPOSE:	Replacement for r.buffer using r.grow.distance
-# COPYRIGHT:	(C) 2008 by Glynn Clements
+# COPYRIGHT:	(C) 2008, 2010 by Glynn Clements
 #		This program is free software under the GNU General Public
 #		License (>=v2). Read the file COPYING that comes with GRASS
@@ -15,7 +15,7 @@
 #%Module
-#% description: Creates a raster map layer showing buffer zones surrounding cells that contain non-NULL category values.
+#% description: Creates a raster map showing buffer zones surrounding cells that contain non-NULL category values.
 #% keywords: raster
 #% keywords: buffer
 #%End
@@ -115,6 +115,7 @@
     else:
 	exp = "$temp_src = if(isnull($input),null(),1)"
+    grass.message(_("Extracting buffers (1/2)..."))
     grass.mapcalc(exp, temp_src = temp_src, input = input)
     exp = "$output = if(!isnull($input),$input,%s)"
@@ -122,6 +123,7 @@
 	exp %= "if($dist <= %f,%d,%%s)" % (dist2,n + 2)
     exp %= "null()"
+    grass.message(_("Extracting buffers (2/2)..."))
     grass.mapcalc(exp, output = output, input = temp_src, dist = temp_dist)
     p = grass.feed_command('r.category', map = output, rules = '-')
@@ -137,7 +139,7 @@
     # write cmd history:
     grass.raster_history(output)
 if __name__ == "__main__":
     options, flags = grass.parser()
     atexit.register(cleanup)
