[GRASS-SVN] r41919 - grass-addons/gui/wxpython/data_catalog
Sun Apr 18 08:56:40 EDT 2010
Author: rashadkm
Date: 2010-04-18 08:56:40 -0400 (Sun, 18 Apr 2010)
New Revision: 41919
   grass-addons/gui/wxpython/data_catalog/catalog.py
   grass-addons/gui/wxpython/data_catalog/wxgui.py
fixed mapdisplay switching;
Modified: grass-addons/gui/wxpython/data_catalog/catalog.py
--- grass-addons/gui/wxpython/data_catalog/catalog.py	2010-04-18 10:47:38 UTC (rev 41918)
+++ grass-addons/gui/wxpython/data_catalog/catalog.py	2010-04-18 12:56:40 UTC (rev 41919)
@@ -144,6 +144,7 @@
         self.g_catalog=None
+        self.locationchange = True
         self.menucmd       = dict()
@@ -181,6 +182,8 @@
         self.maptree = None
         self.pg_panel = None
+        self.cb_loclist = []
+        self.cb_maplist = []
         #creating controls
         #self.mInfo = wx.TextCtrl(self.pRight, wx.ID_ANY, style = wx.TE_MULTILINE|wx.HSCROLL|wx.TE_READONLY)
@@ -509,10 +512,104 @@
         self.notebook.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CHANGED, self.OnPageChanged)
         self.notebook.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CLOSING, self.OnPageClosed)
+        self.notebook.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CHANGED, self.OnCBPageChanged)
+        self.notebook.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CLOSING, self.OnCBPageClosed)
         return self.notebook
+    def OnPageChanged(self, event):
+        """!Page in notebook changed"""
+        pageno = event.GetSelection()
+        self.page = self.notebook.GetPage(pageno)
+        self.page.Map.__init__()
+        self.page.Map.region = self.page.Map.GetRegion()
+        p =event.GetParent()
+        print "ss"
+        if page == self.goutput.pageid:
+            # remove '(...)'
+            self.notebook.SetPageText(page, _("Command output"))
+        event.Skip()
+    def OnCBPageClosed(self, event):
+        Page of notebook closed
+        Also close associated map display
+        if UserSettings.Get(group='manager', key='askOnQuit', subkey='enabled'):
+            maptree = self.curr_page.maptree
+            if self.workspaceFile:
+                message = _("Do you want to save changes in the workspace?")
+            else:
+                message = _("Do you want to store current settings "
+                            "to workspace file?")
+            # ask user to save current settings
+            if maptree.GetCount() > 0:
+                dlg = wx.MessageDialog(self,
+                                       message=message,
+                                       caption=_("Close Map Display %d") % (self.curr_pagenum + 1),
+                                       style=wx.YES_NO | wx.YES_DEFAULT |
+                                       wx.CANCEL | wx.ICON_QUESTION | wx.CENTRE)
+                ret = dlg.ShowModal()
+                if ret == wx.ID_YES:
+                    if not self.workspaceFile:
+                        self.OnWorkspaceSaveAs()
+                    else:
+                        self.SaveToWorkspaceFile(self.workspaceFile)
+                elif ret == wx.ID_CANCEL:
+                    event.Veto()
+                    dlg.Destroy()
+                    return
+                dlg.Destroy()
+        self.notebook.GetPage(event.GetSelection()).maptree.Map.Clean()
+        self.notebook.GetPage(event.GetSelection()).maptree.Close(True)
+        self.curr_page = None
+        event.Skip()
+    def OnCBPageChanged(self, event):
+        """!Page in notebook (display) changed"""
+        old_pgnum = event.GetOldSelection()
+        new_pgnum = event.GetSelection()
+        self.curr_page   = self.notebook.GetCurrentPage()
+        self.curr_pagenum = self.notebook.GetSelection()
+        self.ltree.DeleteAllItems()
+  #      self.cmbMapset.SetValue(self.cb_loclist[self.disp_idx])
+ #       self.cmbLocation.SetValue(self.cb_loclist[self.disp_idx])
+#        self.disp_idx
+        index  = self.notebook.GetSelection()
+        print index
+        #index = index - 1
+        try:
+            a_loc = str(self.cb_loclist[index])
+            a_map =  str(self.cb_maplist[index])
+        except IndexError:
+            a_loc = "Select Location"
+            a_map = "Select Mapset"
+        self.cmbLocation.SetValue(a_loc)
+        self.cmbMapset.SetValue(a_map)
+        self.ltree.AddTreeNodes(a_loc,a_map)
+        try:
+            self.curr_page.maptree.mapdisplay.SetFocus()
+            self.curr_page.maptree.mapdisplay.Raise()
+        except:
+            pass
+        event.Skip()
     def OnGeorectify(self, event):
         Launch georectifier module
@@ -1284,12 +1381,21 @@
         self.disp_idx = self.disp_idx + 1
 #        self.curr_pagenum  = self.disp_idx
+#        self.cb_loclist.append( str(self.cmbLocation.GetValue()) )
+ #       self.cb_maplist.append( str(self.cmbMapset.GetValue()) )
+        #print self.cb_maplist
+        #print self.cb_loclist
         self.page = MapFrame(parent=self.notebook, id=wx.ID_ANY, Map=render.Map(),  size=globalvar.MAP_WINDOW_SIZE,frame=self)
         self.notebook.AddPage(self.page, text="Display "+ str(self.disp_idx), select = True)
         self.current = self.notebook.GetCurrentPage()
     # toolBar button handlers
@@ -1675,8 +1781,16 @@
         self.page = self.notebook.GetPage(self.notebook.GetSelection())
+        if self.locationchange:
+            self.cb_loclist.append( str(self.cmbLocation.GetValue()) )
+            self.cb_maplist.append( str(self.cmbMapset.GetValue()) )
+            self.locationchange=False
+            print self.cb_loclist
     def OnRunScript():
         print "for grass7"
Modified: grass-addons/gui/wxpython/data_catalog/wxgui.py
--- grass-addons/gui/wxpython/data_catalog/wxgui.py	2010-04-18 10:47:38 UTC (rev 41918)
+++ grass-addons/gui/wxpython/data_catalog/wxgui.py	2010-04-18 12:56:40 UTC (rev 41919)
@@ -124,58 +124,8 @@
         #self._auimgr = wx.aui.AuiManager(self)
         self.frame = frame
-        # initialize variables
-        self.disp_idx      = 0            # index value for map displays and layer trees
-        self.curr_page     = ''           # currently selected page for layer tree notebook
-        self.curr_pagenum  = ''           # currently selected page number for layer tree notebook
-        self.encoding      = 'ISO-8859-1' # default encoding for display fonts
-        self.workspaceFile = workspace    # workspace file
-        self.menucmd       = dict()       # menuId / cmd
-        self.georectifying = None         # reference to GCP class or None
-        # list of open dialogs
-        self.dialogs        = dict()
-        self.dialogs['preferences'] = None
-        self.dialogs['atm'] = list()
-        # creating widgets
-        # -> self.notebook, self.goutput, self.outpage
-        #self.notebook  = self.__createNoteBook()
-        self.menubar, self.menudata = self.__createMenuBar()
-        #self.statusbar = self.CreateStatusBar(number=1)
-        #self.cmdprompt, self.cmdinput = self.__createCommandPrompt()
-        self.toolbar   = self.__createToolBar()
-        # bindings
-        self.Bind(wx.EVT_CLOSE,    self.OnCloseWindow)
-        self.Bind(wx.EVT_KEY_UP,   self.OnKey)
-        # minimal frame size
-        #self.SetMinSize((500, 400))
-        # AUI stuff
-        #       self._auimgr.AddPane(self.toolbar, wx.aui.AuiPaneInfo().ToolbarPane().
-        #                              Top().Dockable(False).CloseButton(False).
-        #                              DestroyOnClose(True).Row(0).Layer(0))
-        #self._auimgr.AddPane(self.notebook, wx.aui.AuiPaneInfo().
-        #                     Left().CentrePane().BestSize((-1,-1)).Dockable(False).
-        #                     CloseButton(False).DestroyOnClose(True).Row(1).Layer(0))
-        #self._auimgr.AddPane(self.cmdprompt, wx.aui.AuiPaneInfo().
-        #                     Bottom().BestSize((-1, 65)).Dockable(False).
-        #                     PaneBorder(False).Row(1).Layer(0).Position(0).
-        #                     CaptionVisible(False))
-        #self._auimgr.Update()
-        #wx.CallAfter(self.notebook.SetSelection, 0)
-        #wx.CallAfter(self.cmdinput.SetFocus)
-        # use default window layout ?
         if UserSettings.Get(group='general', key='defWindowPos', subkey='enabled') is True:
             dim = UserSettings.Get(group='general', key='defWindowPos', subkey='dim')
             try:
@@ -188,1285 +138,3 @@
-    def OnMapsetChange(self,event):
-	    Create the tree nodes based on selected location and mapset.
-	    Also update gisrc and grassrc files.
-	    self.tree.DeleteAllItems()
-	    self.AddTreeNodes(self.cmbLocation.GetValue(),self.cmbMapset.GetValue())
-	    self.gisrc['LOCATION_NAME'] = str(self.cmbLocation.GetValue())
-	    self.gisrc['MAPSET'] = str(self.cmbMapset.GetValue())
-	    self.update_grassrc(self.gisrc)
-	    #gcmd.RunCommand("g.gisenv", set = "MAPSET=%s" % str(self.cmbMapset.GetValue()))
-    def OnLocationChange(self,event):
-	    Populate mapset combobox with selected location.
-	    self.cmbMapset.Clear()
-	    self.cmbMapset.SetValue("Select Mapset")
-	    maplists = self.GetMapsets(self.cmbLocation.GetValue())
-	    for mapsets in maplists:
-		    self.cmbMapset.Append(str(mapsets))
-    def GetMapsets(self,location):
-	    Read and returns all mapset int GRASS data directory.
-	    maplist = []
-	    for mapset in glob.glob(os.path.join(self.gisdbase, location, "*")):
-		    if os.path.isdir(mapset) and os.path.isfile(os.path.join(self.gisdbase, location, mapset, "WIND")):
-			    maplist.append(os.path.basename(mapset))
-	    return maplist
-    def __createMenuBar(self):
-        """!Creates menubar"""
-        self.menubar = wx.MenuBar()
-        self.menudata = menudata.Data()
-        for eachMenuData in self.menudata.GetMenu():
-            for eachHeading in eachMenuData:
-                menuLabel = eachHeading[0]
-                menuItems = eachHeading[1]
-                self.menubar.Append(self.__createMenu(menuItems), menuLabel)
-        self.frame.SetMenuBar(self.menubar)
-        return (self.menubar, self.menudata)
-    def __createMenu(self, menuData):
-        """!Creates menu"""
-        menu = wx.Menu()
-        for eachItem in menuData:
-            if len(eachItem) == 2:
-                label = eachItem[0]
-                subMenu = self.__createMenu(eachItem[1])
-                menu.AppendMenu(wx.ID_ANY, label, subMenu)
-            else:
-                self.__createMenuItem(menu, *eachItem)
-        self.Bind(wx.EVT_MENU_HIGHLIGHT_ALL, self.OnMenuHighlight)
-        return menu
-    def __createMenuItem(self, menu, label, help, handler, gcmd, keywords, shortcut = '', kind = wx.ITEM_NORMAL):
-        """!Creates menu items"""
-        if not label:
-            menu.AppendSeparator()
-            return
-        if len(gcmd) > 0:
-            helpString = gcmd + ' -- ' + help
-        else:
-            helpString = help
-        if shortcut:
-            label += '\t' + shortcut
-        menuItem = menu.Append(wx.ID_ANY, label, helpString, kind)
-        self.menucmd[menuItem.GetId()] = gcmd
-        if len(gcmd) > 0 and \
-                gcmd.split()[0] not in globalvar.grassCmd['all']:
-            menuItem.Enable (False)
-        rhandler = eval(handler)
-        self.Bind(wx.EVT_MENU, rhandler, menuItem)
-    def __createToolBar(self):
-        """!Creates toolbar"""
-        self.toolbar = self.frame.CreateToolBar()
-        self.toolbar.SetToolBitmapSize(globalvar.toolbarSize)
-        for each in self.ToolbarData():
-            self.AddToolbarButton(self.toolbar, *each)
-        self.toolbar.Realize()
-        return self.toolbar
-    def OnMenuHighlight(self, event):
-        Default menu help handler
-         # Show how to get menu item info from this event handler
-        id = event.GetMenuId()
-        item = self.GetMenuBar().FindItemById(id)
-        if item:
-            text = item.GetText()
-            help = item.GetHelp()
-        # but in this case just call Skip so the default is done
-        event.Skip()
-    def OnGeorectify(self, event):
-        Launch georectifier module
-        georect.GeorectWizard(self)
-    def OnMapsets(self, event):
-        Launch mapset access dialog
-        dlg = preferences.MapsetAccess(parent=self, id=wx.ID_ANY)
-        dlg.CenterOnScreen()
-        # if OK is pressed...
-        if dlg.ShowModal() == wx.ID_OK:
-            ms = dlg.GetMapsets()
-            # run g.mapsets with string of accessible mapsets
-            gcmd.RunCommand('g.mapsets',
-                            parent = self,
-                            mapset = '%s' % ','.join(ms))
-    def OnRDigit(self, event):
-        Launch raster digitizing module
-        pass
-    def OnCBPageChanged(self, event):
-        """!Page in notebook (display) changed"""
-        old_pgnum = event.GetOldSelection()
-        new_pgnum = event.GetSelection()
-        self.curr_page   = self.notebook.GetCurrentPage()
-        self.curr_pagenum = self.notebook.GetSelection()
-        try:
-            self.curr_page.maptree.mapdisplay.SetFocus()
-            self.curr_page.maptree.mapdisplay.Raise()
-            print self.curr_page.ltree + "ddd"
-        except:
-            pass
-        event.Skip()
-    def OnPageChanged(self, event):
-        """!Page in notebook changed"""
-        pageno = event.GetSelection()
-        self.page = self.notebook.GetPage(pageno)
-        self.page.Map.__init__()
-        self.page.Map.region = self.page.Map.GetRegion()
-        if page == self.goutput.pageid:
-            # remove '(...)'
-            self.notebook.SetPageText(page, _("Command output"))
-        event.Skip()
-    def OnCBPageClosed(self, event):
-        Page of notebook closed
-        Also close associated map display
-        if UserSettings.Get(group='manager', key='askOnQuit', subkey='enabled'):
-            maptree = self.curr_page.maptree
-            if self.workspaceFile:
-                message = _("Do you want to save changes in the workspace?")
-            else:
-                message = _("Do you want to store current settings "
-                            "to workspace file?")
-            # ask user to save current settings
-            if maptree.GetCount() > 0:
-                dlg = wx.MessageDialog(self,
-                                       message=message,
-                                       caption=_("Close Map Display %d") % (self.curr_pagenum + 1),
-                                       style=wx.YES_NO | wx.YES_DEFAULT |
-                                       wx.CANCEL | wx.ICON_QUESTION | wx.CENTRE)
-                ret = dlg.ShowModal()
-                if ret == wx.ID_YES:
-                    if not self.workspaceFile:
-                        self.OnWorkspaceSaveAs()
-                    else:
-                        self.SaveToWorkspaceFile(self.workspaceFile)
-                elif ret == wx.ID_CANCEL:
-                    event.Veto()
-                    dlg.Destroy()
-                    return
-                dlg.Destroy()
-        self.notebook.GetPage(event.GetSelection()).maptree.Map.Clean()
-        self.notebook.GetPage(event.GetSelection()).maptree.Close(True)
-        self.curr_page = None
-        event.Skip()
-    def GetLogWindow(self):
-        """!Get widget for command output"""
-        return self.goutput
-    def GetMenuCmd(self, event):
-        """!Get GRASS command from menu item
-        Return command as a list"""
-        layer = None
-        if event:
-            cmd = self.menucmd[event.GetId()]
-        try:
-            cmdlist = cmd.split(' ')
-        except: # already list?
-            cmdlist = cmd
-        # check list of dummy commands for GUI modules that do not have GRASS
-        # bin modules or scripts.
-        if cmd in ['vcolors']:
-            return cmdlist
-        try:
-            layer = self.curr_page.maptree.layer_selected
-            name = self.curr_page.maptree.GetPyData(layer)[0]['maplayer'].name
-            type = self.curr_page.maptree.GetPyData(layer)[0]['type']
-        except:
-            layer = None
-        if layer and len(cmdlist) == 1: # only if no paramaters given
-            if (type == 'raster' and cmdlist[0][0] == 'r' and cmdlist[0][1] != '3') or \
-                    (type == 'vector' and cmdlist[0][0] == 'v'):
-                input = menuform.GUI().GetCommandInputMapParamKey(cmdlist[0])
-                if input:
-                    cmdlist.append("%s=%s" % (input, name))
-        return cmdlist
-    def RunMenuCmd(self, event):
-        """!Run command selected from menu"""
-        cmd = self.GetMenuCmd(event)
-        self.goutput.RunCmd(cmd, switchPage=True)
-    def OnMenuCmd(self, event, cmd = ''):
-        """!Parse command selected from menu"""
-        if event:
-        menuform.GUI().ParseCommand(cmd, parentframe=self)
-    def OnChangeLocation(self, event):
-        """Change current location"""
-        dlg = gdialogs.LocationDialog(parent = self)
-            location, mapset = dlg.GetValues()
-            if location and mapset:
-                ret = gcmd.RunCommand("g.gisenv",
-                                      set = "LOCATION_NAME=%s" % location)
-                ret += gcmd.RunCommand("g.gisenv",
-                                       set = "MAPSET=%s" % mapset)
-                if ret > 0:
-                    wx.MessageBox(parent = self,
-                                  message = _("Unable to switch to location <%(loc)s> mapset <%(mapset)s>.") % \
-                                      { 'loc' : location, 'mapset' : mapset },
-                                  caption = _("Error"), style = wx.OK | wx.ICON_ERROR | wx.CENTRE)
-                else:
-                    # close workspace
-                    self.OnWorkspaceClose()
-                    self.OnWorkspaceNew()
-                                  message = _("Current location is <%(loc)s>.\n"
-                                              "Current mapset is <%(mapset)s>.") % \
-                                  caption = _("Info"), style = wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
-    def OnChangeMapset(self, event):
-        """Change current mapset"""
-        dlg = gdialogs.MapsetDialog(parent = self)
-            mapset = dlg.GetMapset()
-            if mapset:
-                if gcmd.RunCommand("g.gisenv",
-                                   set = "MAPSET=%s" % mapset) != 0:
-                                  message = _("Unable to switch to mapset <%s>.") % mapset,
-                else:
-                                  message = _("Current mapset is <%s>.") % mapset,
-    def OnNewVector(self, event):
-        """!Create new vector map layer"""
-        name, add = gdialogs.CreateNewVector(self, log = self.goutput,
-                                             cmd = (('v.edit',
-                                                     { 'tool' : 'create' },
-                                                     'map')))
-        if name and add:
-            # add layer to map layer tree
-            self.curr_page.maptree.AddLayer(ltype='vector',
-                                            lname=name,
-                                            lchecked=True,
-                                            lopacity=1.0,
-                                            lcmd=['d.vect', 'map=%s' % name])
-    def OnMenuTree(self, event):
-        """!Show dialog with menu tree"""
-        dlg = MenuTreeWindow(self)
-        dlg.CentreOnScreen()
-        dlg.Show()
-    def OnAboutGRASS(self, event):
-        """!Display 'About GRASS' dialog"""
-        win = AboutWindow(self)
-        win.Centre()
-        win.Show(True)
-    def OnWorkspace(self, event):
-        """!Workspace menu (new, load)"""
-        point = wx.GetMousePosition()
-        menu = wx.Menu()
-        # Add items to the menu
-        new = wx.MenuItem(menu, wx.ID_ANY, Icons["workspaceNew"].GetLabel())
-        new.SetBitmap(Icons["workspaceNew"].GetBitmap(self.iconsize))
-        menu.AppendItem(new)
-        self.Bind(wx.EVT_MENU, self.OnWorkspaceNew, new)
-        load = wx.MenuItem(menu, wx.ID_ANY, Icons["workspaceLoad"].GetLabel())
-        load.SetBitmap(Icons["workspaceLoad"].GetBitmap(self.iconsize))
-        menu.AppendItem(load)
-        self.Bind(wx.EVT_MENU, self.OnWorkspaceLoad, load)
-        # create menu
-        self.PopupMenu(menu)
-        menu.Destroy()
-    def OnWorkspaceNew(self, event=None):
-        """!Create new workspace file
-        Erase current workspace settings first"""
-        Debug.msg(4, "GMFrame.OnWorkspaceNew():")
-        # start new map display if no display is available
-        if not self.curr_page:
-            self.NewDisplay()
-             dlg = wx.MessageDialog(self, message=_("Current workspace is not empty. "
-                                                    "Do you want to store current settings "
-                                                    "to workspace file?"),
-                                    caption=_("Create new workspace?"),
-                                    style=wx.YES_NO | wx.YES_DEFAULT | \
-                                        wx.CANCEL | wx.ICON_QUESTION)
-                 dlg.Destroy()
-                 return
-             dlg.Destroy()
-        # delete all items
-        maptree.DeleteAllItems()
-        # add new root element
-        maptree.root = maptree.AddRoot("Map Layers")
-        self.curr_page.maptree.SetPyData(maptree.root, (None,None))
-        # no workspace file loaded
-        self.workspaceFile = None
-        self.SetTitle(self.baseTitle)
-    def OnWorkspaceOpen(self, event=None):
-        """!Open file with workspace definition"""
-        dlg = wx.FileDialog(parent=self, message=_("Choose workspace file"),
-                            defaultDir=os.getcwd(), wildcard="*.gxw")
-        filename = ''
-            filename = dlg.GetPath()
-        if filename == '':
-            return
-        Debug.msg(4, "GMFrame.OnWorkspaceOpen(): filename=%s" % filename)
-        # delete current layer tree content
-        self.LoadWorkspaceFile(filename)
-        self.workspaceFile = filename
-        self.SetTitle(self.baseTitle + " - " +  os.path.basename(self.workspaceFile))
-    def LoadWorkspaceFile(self, filename):
-        """!Load layer tree definition stored in GRASS Workspace XML file (gxw)
-        @todo Validate against DTD
-        @return True on success
-        @return False on error
-        # dtd
-        dtdFilename = os.path.join(globalvar.ETCWXDIR, "xml", "grass-gxw.dtd")
-        # parse workspace file
-        try:
-            gxwXml = workspace.ProcessWorkspaceFile(etree.parse(filename))
-        except Exception, err:
-            raise gcmd.GStdError(_("Reading workspace file <%(file)s> failed.\n"
-                                   "Invalid file, unable to parse XML document."
-                                   "\n\n%(err)s") % { 'file' : filename, 'err': err},
-                                 parent = self)
-        busy = wx.BusyInfo(message=_("Please wait, loading workspace..."),
-                           parent=self)
-        wx.Yield()
-        # load layer manager window properties
-        if UserSettings.Get(group='workspace', key='posManager', subkey='enabled') is False:
-            if gxwXml.layerManager['pos']:
-                self.SetPosition(gxwXml.layerManager['pos'])
-            if gxwXml.layerManager['size']:
-                self.SetSize(gxwXml.layerManager['size'])
-        # start map displays first (list of layers can be empty)
-        displayId = 0
-        mapdisplay = []
-        for display in gxwXml.displays:
-            mapdisplay.append(self.NewDisplay(show=False))
-            maptree = self.notebook.GetPage(displayId).maptree
-            # set windows properties
-            mapdisplay[-1].SetProperties(render=display['render'],
-                                         mode=display['mode'],
-                                         showCompExtent=display['showCompExtent'],
-                                         constrainRes=display['constrainRes'],
-                                         projection=display['projection']['enabled'])
-            if display['projection']['enabled']:
-                if display['projection']['epsg']:
-                    UserSettings.Set(group = 'display', key = 'projection', subkey = 'epsg',
-                                     value = display['projection']['epsg'])
-                    if display['projection']['proj']:
-                        UserSettings.Set(group = 'display', key = 'projection', subkey = 'proj4',
-                                         value = display['projection']['proj'])
-            # set position and size of map display
-            if UserSettings.Get(group='workspace', key='posDisplay', subkey='enabled') is False:
-                if display['pos']:
-                    mapdisplay[-1].SetPosition(display['pos'])
-                if display['size']:
-                    mapdisplay[-1].SetSize(display['size'])
-            # set extent if defined
-            if display['extent']:
-                w, s, e, n = display['extent']
-                maptree.Map.region = maptree.Map.GetRegion(w=w, s=s, e=e, n=n)
-            mapdisplay[-1].Show()
-            displayId += 1
-        maptree = None
-        selected = [] # list of selected layers
-        # load list of map layers
-        for layer in gxwXml.layers:
-            display = layer['display']
-            maptree = self.notebook.GetPage(display).maptree
-            newItem = maptree.AddLayer(ltype=layer['type'],
-                                       lname=layer['name'],
-                                       lchecked=layer['checked'],
-                                       lopacity=layer['opacity'],
-                                       lcmd=layer['cmd'],
-                                       lgroup=layer['group'],
-                                       lnviz=layer['nviz'],
-                                       lvdigit=layer['vdigit'])
-            if layer.has_key('selected'):
-                if layer['selected']:
-                    selected.append((maptree, newItem))
-                else:
-                    maptree.SelectItem(newItem, select=False)
-        for maptree, layer in selected:
-            if not maptree.IsSelected(layer):
-                maptree.SelectItem(layer, select=True)
-                maptree.layer_selected = layer
-        busy.Destroy()
-        if maptree:
-            # reverse list of map layers
-            maptree.Map.ReverseListOfLayers()
-        for mdisp in mapdisplay:
-            mdisp.MapWindow2D.UpdateMap()
-        return True
-    def OnWorkspaceLoad(self, event=None):
-        """!Load given map layers into layer tree"""
-        dialog = gdialogs.LoadMapLayersDialog(parent=self, title=_("Load map layers into layer tree"))
-        if dialog.ShowModal() == wx.ID_OK:
-                self.NewDisplay()
-                               parent=self)
-            wx.Yield()
-            for layerName in dialog.GetMapLayers():
-                if dialog.GetLayerType() == 'raster':
-                    cmd = ['d.rast', 'map=%s' % layerName]
-                elif dialog.GetLayerType() == 'vector':
-                    cmd = ['d.vect', 'map=%s' % layerName]
-                newItem = maptree.AddLayer(ltype=dialog.GetLayerType(),
-                                           lname=layerName,
-                                           lchecked=True,
-                                           lopacity=1.0,
-                                           lcmd=cmd,
-                                           lgroup=None)
-            busy.Destroy()
-    def OnWorkspaceLoadGrcFile(self, event):
-        """!Load map layers from GRC file (Tcl/Tk GUI) into map layer tree"""
-        dlg = wx.FileDialog(parent=self, message=_("Choose GRC file to load"),
-                            defaultDir=os.getcwd(), wildcard="*.grc")
-        filename = ''
-            return
-        Debug.msg(4, "GMFrame.OnWorkspaceLoadGrcFile(): filename=%s" % filename)
-            self.NewDisplay()
-                           parent=self)
-        wx.Yield()
-        maptree = None
-        for layer in workspace.ProcessGrcFile(filename).read(self):
-            maptree = self.notebook.GetPage(layer['display']).maptree
-                                       lgroup=layer['group'])
-            busy.Destroy()
-        if maptree:
-    def OnWorkspaceSaveAs(self, event=None):
-        """!Save workspace definition to selected file"""
-        dlg = wx.FileDialog(parent=self, message=_("Choose file to save current workspace"),
-                            defaultDir=os.getcwd(), wildcard="*.gxw", style=wx.FD_SAVE)
-        filename = ''
-            return False
-        # check for extension
-        if filename[-4:] != ".gxw":
-            filename += ".gxw"
-        if os.path.exists(filename):
-            dlg = wx.MessageDialog(self, message=_("Workspace file <%s> already exists. "
-                                                   "Do you want to overwrite this file?") % filename,
-                                   caption=_("Save workspace"), style=wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
-            if dlg.ShowModal() != wx.ID_YES:
-                dlg.Destroy()
-                return False
-        Debug.msg(4, "GMFrame.OnWorkspaceSaveAs(): filename=%s" % filename)
-        self.SaveToWorkspaceFile(filename)
-    def OnWorkspaceSave(self, event=None):
-        """!Save file with workspace definition"""
-                                                   "Do you want to overwrite this file?") % \
-                                       self.workspaceFile,
-            if dlg.ShowModal() == wx.ID_NO:
-                dlg.Destroy()
-            else:
-                Debug.msg(4, "GMFrame.OnWorkspaceSave(): filename=%s" % self.workspaceFile)
-        else:
-    def SaveToWorkspaceFile(self, filename):
-        """!Save layer tree layout to workspace file
-        Return True on success, False on error
-        try:
-            file = open(filename, "w")
-        except IOError:
-            wx.MessageBox(parent=self,
-                          message=_("Unable to open workspace file <%s> for writing.") % filename,
-                          caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
-            return False
-        try:
-            workspace.WriteWorkspaceFile(lmgr=self, file=file)
-        except StandardError, e:
-            file.close()
-                          message=_("Writing current settings to workspace file failed (%s)." % e),
-                          style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
-            return False
-        file.close()
-        return True
-    def OnWorkspaceClose(self, event=None):
-        """!Close file with workspace definition
-        If workspace has been modified ask user to save the changes.
-        Debug.msg(4, "GMFrame.OnWorkspaceClose(): file=%s" % self.workspaceFile)
-        displays = []
-        for page in range(0, self.notebook.GetPageCount()):
-            displays.append(self.notebook.GetPage(page).maptree.mapdisplay)
-        for display in displays:
-            display.OnCloseWindow(event)
-        self.disp_idx = 0
-    def RulesCmd(self, event, cmd = ''):
-        Launches dialog for commands that need rules
-        input and processes rules
-        if event:
-        if cmd[0] == 'r.colors' or cmd[0] == 'vcolors':
-            ctable = colorrules.ColorTable(self, cmd=cmd[0])
-            ctable.Show()
-        else:
-            dlg = rules.RulesText(self, cmd=cmd)
-                gtemp = utils.GetTempfile()
-                output = open(gtemp, "w")
-                try:
-                    output.write(dlg.rules)
-                finally:
-                    output.close()
-                cmdlist = [cmd[0],
-                           'input=%s' % dlg.inmap,
-                           'output=%s' % dlg.outmap,
-                           'rules=%s' % gtemp]
-                if dlg.overwrite == True:
-                    cmdlist.append('--o')
-                dlg.Destroy()
-                self.goutput.RunCmd(cmdlist)
-    def OnPreferences(self, event):
-        """!General GUI preferences/settings"""
-        if not self.dialogs['preferences']:
-            dlg = preferences.PreferencesDialog(parent=self)
-            self.dialogs['preferences'] = dlg
-            self.dialogs['preferences'].CenterOnScreen()
-        self.dialogs['preferences'].ShowModal()
-    def DispHistogram(self, event):
-        Init histogram display canvas and tools
-        self.histogram = histogram.HistFrame(self,
-                                             id=wx.ID_ANY, pos=wx.DefaultPosition, size=(400,300),
-                                             style=wx.DEFAULT_FRAME_STYLE)
-        #show new display
-        self.histogram.Show()
-        self.histogram.Refresh()
-        self.histogram.Update()
-    def DispProfile(self, event):
-        Init profile canvas and tools
-        self.profile = profile.ProfileFrame(self,
-        self.profile.Show()
-        self.profile.Refresh()
-        self.profile.Update()
-    def DispMapCalculator(self, event):
-        Init map calculator for interactive creation of mapcalc statements
-        self.mapcalculator = mapcalculator.MapCalcFrame(self, wx.ID_ANY, title='',
-                                                        dimension=2)
-    def Disp3DMapCalculator(self, event):
-                                                        dimension=3)
-    def AddToolbarButton(self, toolbar, label, icon, help, handler):
-        """!Adds button to the given toolbar"""
-        if not label:
-            toolbar.AddSeparator()
-            return
-        tool = toolbar.AddLabelTool(id=wx.ID_ANY, label=label, bitmap=icon, shortHelp=help)
-        self.Bind(wx.EVT_TOOL, handler, tool)
-    def ToolbarData(self):
-        return   (
-                 ('newdisplay', Icons["newdisplay"].GetBitmap(),
-                  Icons["newdisplay"].GetLabel(), self.OnNewDisplay),
-                 ('workspaceLoad', Icons["workspaceLoad"].GetBitmap(),
-                  Icons["workspaceLoad"].GetLabel(), self.OnWorkspace),
-                 ('workspaceOpen', Icons["workspaceOpen"].GetBitmap(),
-                  Icons["workspaceOpen"].GetLabel(), self.OnWorkspaceOpen),
-                 ('workspaceSave', Icons["workspaceSave"].GetBitmap(),
-                  Icons["workspaceSave"].GetLabel(), self.OnWorkspaceSave),
-                 ('addrast', Icons["addrast"].GetBitmap(),
-                  Icons["addrast"].GetLabel(), self.OnAddRaster),
-                 ('addshaded', Icons["addshaded"].GetBitmap(),
-                  _("Add various raster-based map layers"), self.OnAddRasterMisc),
-                 ('addvect', Icons["addvect"].GetBitmap(),
-                  Icons["addvect"].GetLabel(), self.OnAddVector),
-                 ('addthematic', Icons["addthematic"].GetBitmap(),
-                  _("Add various vector-based map layer"), self.OnAddVectorMisc),
-                 ('addcmd',  Icons["addcmd"].GetBitmap(),
-                  Icons["addcmd"].GetLabel(),  self.OnAddCommand),
-                 ('addgrp',  Icons["addgrp"].GetBitmap(),
-                  Icons["addgrp"].GetLabel(), self.OnAddGroup),
-                 ('addovl',  Icons["addovl"].GetBitmap(),
-                  Icons["addovl"].GetLabel(), self.OnAddOverlay),
-                 ('delcmd',  Icons["delcmd"].GetBitmap(),
-                  Icons["delcmd"].GetLabel(), self.OnDeleteLayer),
-                 ('attrtable', Icons["attrtable"].GetBitmap(),
-                  Icons["attrtable"].GetLabel(), self.OnShowAttributeTable)
-    def OnImportDxfFile(self, event):
-        """!Convert multiple DXF layers to GRASS vector map layers"""
-        dlg = gdialogs.MultiImportDialog(parent=self, type='dxf',
-                                         title=_("Import DXF layers"))
-        dlg.ShowModal()
-    def OnImportGdalLayers(self, event):
-        """!Convert multiple GDAL layers to GRASS raster map layers"""
-        dlg = gdialogs.MultiImportDialog(parent=self, type='gdal',
-                                         title=_("Import GDAL layers"))
-        dlg.ShowModal()
-    def OnLinkGdalLayers(self, event):
-        """!Link multiple GDAL layers to GRASS raster map layers"""
-                                         title=_("Link GDAL layers"),
-                                         link = True)
-        dlg.ShowModal()
-    def OnImportOgrLayers(self, event):
-        """!Convert multiple OGR layers to GRASS vector map layers"""
-        dlg = gdialogs.MultiImportDialog(parent=self, type='ogr',
-                                         title=_("Import OGR layers"))
-        dlg.ShowModal()
-    def OnLinkOgrLayers(self, event):
-        """!Links multiple OGR layers to GRASS vector map layers"""
-                                         title=_("Link OGR layers"),
-                                         link = True)
-        dlg.ShowModal()
-    def OnImportWMS(self, event):
-        """!Import data from OGC WMS server"""
-        dlg = ogc_services.WMSDialog(parent = self, service = 'wms')
-        if dlg.ShowModal() == wx.ID_OK: # -> import layers
-            layers = dlg.GetLayers()
-            if len(layers.keys()) > 0:
-                for layer in layers.keys():
-                    cmd = ['r.in.wms',
-                           'mapserver=%s' % dlg.GetSettings()['server'],
-                           'layers=%s' % layer,
-                           'output=%s' % layer]
-                    styles = ','.join(layers[layer])
-                    if styles:
-                        cmd.append('styles=%s' % styles)
-                    self.goutput.RunCmd(cmd, switchPage = True)
-            else:
-                self.goutput.WriteWarning(_("Nothing to import. No WMS layer selected."))
-        dlg.Destroy()
-    def OnShowAttributeTable(self, event):
-        Show attribute table of the given vector map layer
-            self.MsgNoLayerSelected()
-            return
-        # no map layer selected
-        if not layer:
-            return
-        # available only for vector map layers
-        try:
-            maptype = self.curr_page.maptree.GetPyData(layer)[0]['maplayer'].type
-        except:
-            maptype = None
-        if not maptype or maptype != 'vector':
-                          message=_("Attribute management is available only "
-                                    "for vector maps."),
-                          caption=_("Message"),
-                          style=wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
-            return
-        if not self.curr_page.maptree.GetPyData(layer)[0]:
-            return
-        dcmd = self.curr_page.maptree.GetPyData(layer)[0]['cmd']
-        if not dcmd:
-            return
-        busy = wx.BusyInfo(message=_("Please wait, loading attribute data..."),
-                           parent=self)
-        wx.Yield()
-        dbmanager = dbm.AttributeManager(parent=self, id=wx.ID_ANY,
-                                         size=wx.Size(500, 300),
-                                         item=layer, log=self.goutput)
-        busy.Destroy()
-        # register ATM dialog
-        self.dialogs['atm'].append(dbmanager)
-        # show ATM window
-        dbmanager.Show()
-    def OnNewDisplay(self, event=None):
-        """!Create new layer tree and map display instance"""
-        self.NewDisplay()
-    def NewDisplay(self, show=True):
-        """!Create new layer tree, which will
-        create an associated map display frame
-        @param show show map display window if True
-        @return reference to mapdisplay intance
-        Debug.msg(1, "GMFrame.NewDisplay(): idx=%d" % self.disp_idx)
-        # make a new page in the bookcontrol for the layer tree (on page 0 of the notebook)
-        self.pg_panel = wx.Panel(self.notebook, id=wx.ID_ANY, style= wx.EXPAND)
-        self.notebook.AddPage(self.pg_panel, text="Display "+ str(self.disp_idx + 1), select = True)
-        # create layer tree (tree control for managing GIS layers)  and put on new notebook page
-        self.curr_page.maptree = wxgui_utils.LayerTree(self.curr_page, id=wx.ID_ANY, pos=wx.DefaultPosition,
-                                                       size=wx.DefaultSize, style=wx.TR_HAS_BUTTONS
-                                                       |wx.TR_LINES_AT_ROOT|wx.TR_HIDE_ROOT
-                                                       |wx.TR_DEFAULT_STYLE|wx.NO_BORDER|wx.FULL_REPAINT_ON_RESIZE,
-                                                       idx=self.disp_idx, lmgr=self, notebook=self.notebook,
-                                                       auimgr=self._auimgr, showMapDisplay=show)
-        #self.pg_panel.Map.__init__()
-        #self.pg_panel.Map.region = self.pg_panel.Map.GetRegion()
-        # layout for controls
-        cb_boxsizer = wx.BoxSizer(wx.VERTICAL)
-        cb_boxsizer.Add(self.curr_page.maptree, proportion=1, flag=wx.EXPAND, border=1)
-        self.curr_page.SetSizer(cb_boxsizer)
-        cb_boxsizer.Fit(self.curr_page.maptree)
-        self.curr_page.Layout()
-        self.curr_page.maptree.Layout()
-        if UserSettings.Get(group='general', key='defWindowPos', subkey='enabled') is True:
-            dim = UserSettings.Get(group='general', key='defWindowPos', subkey='dim')
-            idx = 4 + self.disp_idx * 4
-            try:
-                x, y = map(int, dim.split(',')[idx:idx + 2])
-                w, h = map(int, dim.split(',')[idx + 2:idx + 4])
-                self.curr_page.maptree.mapdisplay.SetPosition((x, y))
-                self.curr_page.maptree.mapdisplay.SetSize((w, h))
-            except:
-                pass
-        self.disp_idx += 1
-        return self.curr_page.maptree.mapdisplay
-    # toolBar button handlers
-    def OnAddRaster(self, event):
-        """!Add raster map layer"""
-            self.NewDisplay(show=False)
-        self.AddRaster(event)
-    def OnAddRasterMisc(self, event):
-        """!Add raster menu"""
-        rastmenu = wx.Menu()
-        # add items to the menu
-        if self.curr_page.maptree.mapdisplay.toolbars['nviz']:
-            addrast3d = wx.MenuItem(rastmenu, -1, Icons ["addrast3d"].GetLabel())
-            addrast3d.SetBitmap(Icons["addrast3d"].GetBitmap (self.iconsize))
-            rastmenu.AppendItem(addrast3d)
-            self.Bind(wx.EVT_MENU, self.AddRaster3d, addrast3d)
-        addshaded = wx.MenuItem(rastmenu, -1, Icons ["addshaded"].GetLabel())
-        addshaded.SetBitmap(Icons["addshaded"].GetBitmap (self.iconsize))
-        rastmenu.AppendItem(addshaded)
-        self.Bind(wx.EVT_MENU, self.AddShaded, addshaded)
-        addrgb = wx.MenuItem(rastmenu, -1, Icons["addrgb"].GetLabel())
-        addrgb.SetBitmap(Icons["addrgb"].GetBitmap(self.iconsize))
-        rastmenu.AppendItem(addrgb)
-        self.Bind(wx.EVT_MENU, self.AddRGB, addrgb)
-        addhis = wx.MenuItem(rastmenu, -1, Icons ["addhis"].GetLabel())
-        addhis.SetBitmap(Icons["addhis"].GetBitmap (self.iconsize))
-        rastmenu.AppendItem(addhis)
-        self.Bind(wx.EVT_MENU, self.AddHIS, addhis)
-        addrastarrow = wx.MenuItem(rastmenu, -1, Icons ["addrarrow"].GetLabel())
-        addrastarrow.SetBitmap(Icons["addrarrow"].GetBitmap (self.iconsize))
-        rastmenu.AppendItem(addrastarrow)
-        self.Bind(wx.EVT_MENU, self.AddRastarrow, addrastarrow)
-        addrastnums = wx.MenuItem(rastmenu, -1, Icons ["addrnum"].GetLabel())
-        addrastnums.SetBitmap(Icons["addrnum"].GetBitmap (self.iconsize))
-        rastmenu.AppendItem(addrastnums)
-        self.Bind(wx.EVT_MENU, self.AddRastnum, addrastnums)
-        # Popup the menu.  If an item is selected then its handler
-        # will be called before PopupMenu returns.
-        self.PopupMenu(rastmenu)
-        rastmenu.Destroy()
-        # show map display
-        self.curr_page.maptree.mapdisplay.Show()
-    def OnAddVector(self, event):
-        """!Add vector map layer"""
-        self.AddVector(event)
-    def OnAddVectorMisc(self, event):
-        """!Add vector menu"""
-        vectmenu = wx.Menu()
-        addtheme = wx.MenuItem(vectmenu, -1, Icons["addthematic"].GetLabel())
-        addtheme.SetBitmap(Icons["addthematic"].GetBitmap(self.iconsize))
-        vectmenu.AppendItem(addtheme)
-        self.Bind(wx.EVT_MENU, self.AddThemeMap, addtheme)
-        addchart = wx.MenuItem(vectmenu, -1, Icons["addchart"].GetLabel())
-        addchart.SetBitmap(Icons["addchart"].GetBitmap(self.iconsize))
-        vectmenu.AppendItem(addchart)
-        self.Bind(wx.EVT_MENU, self.AddThemeChart, addchart)
-        self.PopupMenu(vectmenu)
-        vectmenu.Destroy()
-    def OnAddOverlay(self, event):
-        """!Add overlay menu"""
-        ovlmenu = wx.Menu()
-        addgrid = wx.MenuItem(ovlmenu, wx.ID_ANY, Icons["addgrid"].GetLabel())
-        addgrid.SetBitmap(Icons["addgrid"].GetBitmap(self.iconsize))
-        ovlmenu.AppendItem(addgrid)
-        self.Bind(wx.EVT_MENU, self.AddGrid, addgrid)
-        addlabels = wx.MenuItem(ovlmenu, wx.ID_ANY, Icons["addlabels"].GetLabel())
-        addlabels.SetBitmap(Icons["addlabels"].GetBitmap(self.iconsize))
-        ovlmenu.AppendItem(addlabels)
-        self.Bind(wx.EVT_MENU, self.OnAddLabels, addlabels)
-        addgeodesic = wx.MenuItem(ovlmenu, wx.ID_ANY, Icons["addgeodesic"].GetLabel())
-        addgeodesic.SetBitmap(Icons["addgeodesic"].GetBitmap(self.iconsize))
-        ovlmenu.AppendItem(addgeodesic)
-        self.Bind(wx.EVT_MENU, self.AddGeodesic, addgeodesic)
-        addrhumb = wx.MenuItem(ovlmenu, wx.ID_ANY, Icons["addrhumb"].GetLabel())
-        addrhumb.SetBitmap(Icons["addrhumb"].GetBitmap(self.iconsize))
-        ovlmenu.AppendItem(addrhumb)
-        self.Bind(wx.EVT_MENU, self.AddRhumb, addrhumb)
-        self.PopupMenu(ovlmenu)
-        ovlmenu.Destroy()
-    def AddRaster(self, event):
-        self.notebook.SetSelection(0)
-        self.curr_page.maptree.AddLayer('raster')
-    def AddRaster3d(self, event):
-        self.curr_page.maptree.AddLayer('3d-raster')
-    def AddRGB(self, event):
-        """!Add RGB layer"""
-        self.curr_page.maptree.AddLayer('rgb')
-    def AddHIS(self, event):
-        """!Add HIS layer"""
-        self.curr_page.maptree.AddLayer('his')
-    def AddShaded(self, event):
-        """!Add shaded relief map layer"""
-        self.curr_page.maptree.AddLayer('shaded')
-    def AddRastarrow(self, event):
-        """!Add raster flow arrows map"""
-        self.curr_page.maptree.AddLayer('rastarrow')
-    def AddRastnum(self, event):
-        """!Add raster map with cell numbers"""
-        self.curr_page.maptree.AddLayer('rastnum')
-    def AddVector(self, event):
-        """!Add vector layer"""
-        self.curr_page.maptree.AddLayer('vector')
-    def AddThemeMap(self, event):
-        """!Add thematic map layer"""
-        self.curr_page.maptree.AddLayer('thememap')
-    def AddThemeChart(self, event):
-        """!Add thematic chart layer"""
-        self.curr_page.maptree.AddLayer('themechart')
-    def OnAddCommand(self, event):
-        """!Add command line layer"""
-        self.curr_page.maptree.AddLayer('command')
-    def OnAddGroup(self, event):
-        """!Add layer group"""
-        self.curr_page.maptree.AddLayer('group')
-    def AddGrid(self, event):
-        """!Add layer grid"""
-        self.curr_page.maptree.AddLayer('grid')
-    def AddGeodesic(self, event):
-        """!Add layer geodesic"""
-        self.curr_page.maptree.AddLayer('geodesic')
-    def AddRhumb(self, event):
-        """!Add layer rhumb"""
-        self.curr_page.maptree.AddLayer('rhumb')
-    def OnAddLabels(self, event):
-        """!Add layer vector labels"""
-        self.curr_page.maptree.AddLayer('labels')
-    def OnDeleteLayer(self, event):
-        Delete selected map display layer in GIS Manager tree widget
-        if not self.curr_page or not self.curr_page.maptree.layer_selected:
-            return
-        if UserSettings.Get(group='manager', key='askOnRemoveLayer', subkey='enabled'):
-            layerName = ''
-            for item in self.curr_page.maptree.GetSelections():
-                name = str(self.curr_page.maptree.GetItemText(item))
-                idx = name.find('(opacity')
-                if idx > -1:
-                    layerName += '<' + name[:idx].strip(' ') + '>,\n'
-                else:
-                    layerName += '<' + name + '>,\n'
-            layerName = layerName.rstrip(',\n')
-            if len(layerName) > 2: # <>
-                message = _("Do you want to remove map layer(s)\n%s\n"
-                            "from layer tree?") % layerName
-            else:
-                message = _("Do you want to remove selected map layer(s) "
-            dlg = wx.MessageDialog (parent=self, message=message,
-                                    caption=_("Remove map layer"),
-                                    style=wx.YES_NO | wx.YES_DEFAULT | wx.CANCEL | wx.ICON_QUESTION)
-            if dlg.ShowModal() in [wx.ID_NO, wx.ID_CANCEL]:
-                dlg.Destroy()
-                return
-            dlg.Destroy()
-        for layer in self.curr_page.maptree.GetSelections():
-            if self.curr_page.maptree.GetPyData(layer)[0]['type'] == 'group':
-                self.curr_page.maptree.DeleteChildren(layer)
-            self.curr_page.maptree.Delete(layer)
-    def OnKey(self, event):
-        """!Check hotkey"""
-        try:
-            kc = chr(event.GetKeyCode())
-        except ValueError:
-            event.Skip()
-            return
-        if event.AltDown():
-            if kc == 'R':
-                self.OnAddRaster(None)
-            elif kc == 'V':
-                self.OnAddVector(None)
-        event.Skip()
-    def OnCloseWindow(self, event):
-        """!Cleanup when wxGUI is quit"""
-        self.Destroy()
-    def MsgNoLayerSelected(self):
-        """!Show dialog message 'No layer selected'"""
-                      message=_("No map layer selected. Operation cancelled."),
