[GRASS-SVN] r42963 - grass/trunk/lib/vector/Vlib
Mon Aug 2 11:30:55 EDT 2010
Author: mmetz
Date: 2010-08-02 15:30:55 +0000 (Mon, 02 Aug 2010)
New Revision: 42963
   grass/trunk/lib/vector/Vlib/remove_areas.c
partially revert r42962
Modified: grass/trunk/lib/vector/Vlib/remove_areas.c
--- grass/trunk/lib/vector/Vlib/remove_areas.c	2010-08-02 15:28:12 UTC (rev 42962)
+++ grass/trunk/lib/vector/Vlib/remove_areas.c	2010-08-02 15:30:55 UTC (rev 42963)
@@ -104,7 +104,7 @@
 	G_debug(3, "num neighbours = %d", AList->n_values);
-	/* Go through the list of neighours and find that with the longest boundary */
+	/* Go through the list of neghours and find that with the longest boundary */
 	dissolve_neighbour = 0;
 	length = -1.0;
 	for (i = 0; i < AList->n_values; i++) {
@@ -178,483 +178,5 @@
     G_verbose_message(_("%d areas of total size %g removed"), nremoved,
 		size_removed);
-    Vect_build_partial(Map, GV_BUILD_BASE);
-    Vect_merge_lines(Map, GV_BOUNDARY, NULL, NULL);
     return (nremoved);
-/* faster version */
-int
-Vect_remove_small_areas_faster(struct Map_info *Map, double thresh,
-			struct Map_info *Err, double *removed_area)
-    int area, nareas;
-    int nremoved = 0;
-    struct ilist *List;
-    struct ilist *AList;
-    struct line_pnts *Points;
-    struct line_cats *Cats;
-    double size_removed = 0.0;
-    int left, right, dissolve_neighbour;
-    List = Vect_new_list();
-    AList = Vect_new_list();
-    Points = Vect_new_line_struct();
-    Cats = Vect_new_cats_struct();
-    nareas = Vect_get_num_areas(Map);
-    for (area = 1; area <= Vect_get_num_areas(Map); area++) {
-	int i, centroid, remove_boundary;
-	double length, size;
-	if (area <= nareas)
-	    G_percent(area, nareas, 1);
-	G_debug(3, "area = %d", area);
-	if (!Vect_area_alive(Map, area))
-	    continue;
-	size = Vect_get_area_area(Map, area);
-	if (size > thresh)
-	    continue;
-	size_removed += size;
-	/* The area is smaller than the limit -> remove */
-	/* Remove centroid */
-	centroid = Vect_get_area_centroid(Map, area);
-	if (centroid > 0) {
-	    if (Err) {
-		Vect_read_line(Map, Points, Cats, centroid);
-		Vect_write_line(Err, GV_CENTROID, Points, Cats);
-	    Vect_delete_line(Map, centroid);
-	/* Find the adjacent area with which the longest boundary is shared */
-	Vect_get_area_boundaries(Map, area, List);
-	/* Go through the list of boundaries and find the longest boundary */
-	remove_boundary = 0;
-	length = -1.0;
-	for (i = 0; i < List->n_values; i++) {
-	    int line;
-	    double l = 0.0;
-	    line = List->value[i];
-	    G_debug(4, "   line = %d", line);
-	    Vect_read_line(Map, Points, NULL, abs(line));
-	    l = Vect_line_length(Points);
-	    if (l > length) {
-		length = l;
-		remove_boundary = line;
-	G_debug(3, "remove_boundary = %d", remove_boundary);
-	Vect_get_line_areas(Map, abs(remove_boundary), &left, &right);
-	dissolve_neighbour = 0;
-	if (remove_boundary > 0)
-	    dissolve_neighbour = left;
-	else
-	    dissolve_neighbour = right;
-	G_debug(3, "dissolve_neighbour = %d", dissolve_neighbour);
-	if (dissolve_neighbour == 0)
-	    G_fatal_error("could not find neighbour to dissolve");
-	/* Make list of boundaries to be removed */
-	Vect_reset_list(AList);
-	    int line, neighbour;
-	    Vect_get_line_areas(Map, abs(line), &left, &right);
-	    if (line > 0)
-		neighbour = left;
-	    else
-		neighbour = right;
-	    G_debug(3, "   neighbour = %d", neighbour);
-	    if (neighbour == dissolve_neighbour) {
-		Vect_list_append(AList, abs(line));
-	/* Remove boundaries */
-	for (i = 0; i < AList->n_values; i++) {
-	    int line;
-	    line = AList->value[i];
-	    if (Err) {
-		Vect_read_line(Map, Points, Cats, line);
-		Vect_write_line(Err, GV_BOUNDARY, Points, Cats);
-	    Vect_delete_line(Map, line);
-	nremoved++;
-    if (removed_area)
-	*removed_area = size_removed;
-    G_verbose_message(_("%d areas of total size %g removed"), nremoved,
-		size_removed);
-    return (nremoved);
-/* much faster version */
-int
-Vect_remove_small_areas_fastest(struct Map_info *Map, double thresh,
-    int area, nareas;
-    int nremoved = 0;
-    struct ilist *BList;
-    struct ilist *NList;
-    struct ilist *IList;
-    int dissolve_neighbour;
-    int line, left, right, neighbour;
-    int nisles, nnisles;
-    BList = Vect_new_list();
-    NList = Vect_new_list();
-    IList = Vect_new_list();
-	int i, j, centroid;
-	double length, l, size;
-	int outer_isle = 1, outer_area = -1;
-	    continue;
-	    continue;
-	    if (Err) {
-	/* Create a list of neighbour areas */
-	    if (!Vect_line_alive(Map, abs(line)))	/* Should not happen */
-		G_fatal_error(_("Area is composed of dead boundary"));
-	    if (line > 0)
-		neighbour = left;
-	    else
-	    G_debug(4, "  line = %d left = %d right = %d neighbour = %d",
-		    line, left, right, neighbour);
-	    Vect_list_append(AList, neighbour);	/* this checks for duplicity */
-	G_debug(3, "num neighbours = %d", AList->n_values);
-	/* Go through the list of neighbours and find the one with the longest boundary */
-	length = -1.0;
-	    int neighbour1;
-	    l = 0.0;
-	    neighbour1 = AList->value[i];
-	    G_debug(4, "   neighbour1 = %d", neighbour1);
-	    for (j = 0; j < List->n_values; j++) {
-		int neighbour2;
-		line = List->value[j];
-		if (line > 0)
-		    neighbour2 = left;
-		else
-		    neighbour2 = right;
-		if (neighbour2 == neighbour1) {
-		    l += Vect_line_length(Points);
-	    if (l > length) {
-		length = l;
-		dissolve_neighbour = neighbour1;
-	if (dissolve_neighbour == 0) {
-	Vect_reset_list(BList);
-	    if (line > 0)
-		neighbour = left;
-	    else
-	    else
-		Vect_list_append(BList, line);
-	    if (neighbour < 0) {
-		if (outer_isle > 0)
-		    outer_isle = neighbour;
-		else if (outer_isle != neighbour)
-		    G_fatal_error("Two different isles outside area");
-	G_debug(3, "remove %d of %d boundaries", AList->n_values, List->n_values);
-	/* Get isles inside area */
-	Vect_reset_list(IList);
-	if ((nisles = Vect_get_area_num_isles(Map, area)) > 0) {
-	    for (i = 0; i < nisles; i++) {
-		Vect_list_append(IList, Vect_get_area_isle(Map, area, i));
-	    int ret;
-	    if (Err) {
-	    /* Vect_delete_line(Map, line); */
-	    /* delete the line from coor */
-	    ret = V1_delete_line_nat(Map, Map->plus.Line[line]->offset);
-	    if (ret == -1) {
-		G_fatal_error("Could not delete line from coor");
-	/* update topo */
-	if (outer_isle < 0) {
-	    /* outer area */
-	    outer_area = Vect_get_isle_area(Map, -outer_isle);
-	if (dissolve_neighbour > 0) {
-	    int nareas_old;
-	    G_debug(3, "dissolve with neighbour area");
-	    /* get neighbour centroid */
-	    centroid = Vect_get_area_centroid(Map, dissolve_neighbour);
-	    /* get neighbour isles */
-	    if ((nnisles = Vect_get_area_num_isles(Map, dissolve_neighbour)) > 0) {
-		for (i = 0; i < nnisles; i++) {
-		    Vect_list_append(IList, Vect_get_area_isle(Map, dissolve_neighbour, i));
-	    /* get neighbour boundaries */
-	    Vect_get_area_boundaries(Map, dissolve_neighbour, NList);
-	    /* delete area from topo */
-	    dig_del_area(&(Map->plus), area);
-	    /* delete neighbour area from topo */
-	    dig_del_area(&(Map->plus), dissolve_neighbour);
-	    /* delete boundaries from topo */
-		dig_del_line(&(Map->plus), line);
-	    /* rebuild neighbour area from leftover boundaries */
-	    nareas_old = Vect_get_num_areas(Map);
-	    for (i = 0; i < BList->n_values; i++) {
-		line = BList->value[i];
-		if (Map->plus.Line[abs(line)]->left == 0 || Map->plus.Line[abs(line)]->right == 0) {
-		    int new_isle;
-		    new_isle = Vect_build_line_area(Map, abs(line), (line > 0 ? GV_RIGHT : GV_LEFT));
-		    if (new_isle > 0) {
-			outer_area = new_isle;
-			/* reattach centroid */
-			Map->plus.Area[outer_area]->centroid = centroid;
-			if (centroid > 0)
-			    Map->plus.Line[centroid]->left = outer_area;
-		    else if (new_isle < 0) {
-			Vect_list_append(IList, -new_isle);
-		/* check */
-		    G_fatal_error("dissolve with neighbour area: corrupt topology");
-	    for (i = 0; i < NList->n_values; i++) {
-		line = NList->value[i];
-		    continue;
-		    int new_isle;
-			if (outer_area < 0) {
-			    if (centroid > 0)
-			else
-			    G_fatal_error("WTF");
-		    G_fatal_error("dissolve with neighbour area n bounds: corrupt topology");
-	/* dissolve with outer isle */
-	else if (dissolve_neighbour < 0) {
-	    int nisles_old;
-	    G_debug(3, "dissolve with outer isle");
-	    if (dissolve_neighbour != outer_isle)
-		G_fatal_error("wrong outer isle to dissolve");
-	    /* get isle boundaries */
-	    Vect_get_isle_boundaries(Map, -dissolve_neighbour, NList);
-	    /* delete isle from topo */
-	    dig_del_isle(&(Map->plus), -dissolve_neighbour);
-	    /* rebuild isles from leftover boundaries */
-		    int new_isle;
-		    nisles_old = Vect_get_num_islands(Map);
-		    if (new_isle > 0 || (new_isle < 0 && nisles_old == Vect_get_num_islands(Map)))
-			G_fatal_error("failed to build new isle");
-		    if (new_isle < 0) {
-		/* check */
-		    G_fatal_error("dissolve with outer isle: corrupt topology");
-		    continue;
-		    int new_isle;
-		    if (new_isle >= 0)
-		/* check */
-		    G_fatal_error("dissolve with outer isle n bounds: corrupt topology");
-	/* attach all isles to outer or new area */
-	if (outer_area >= 0) {
-	    for (i = 0; i < IList->n_values; i++) {
-		Map->plus.Isle[IList->value[i]]->area = outer_area;
-		if (outer_area > 0)
-		    dig_area_add_isle(&(Map->plus), outer_area, IList->value[i]);
-	nremoved++;
-    if (removed_area)
-		size_removed);
