[GRASS-SVN] r42972 - grass/trunk/gui/wxpython/gui_modules
    svn_grass at osgeo.org
    Mon Aug  2 17:14:01 EDT 2010
Author: martinl
Date: 2010-08-02 21:14:01 +0000 (Mon, 02 Aug 2010)
New Revision: 42972
   grass/trunk/gui/wxpython/gui_modules/render.py
wxGUI: fix calling gcmd.GError
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py	2010-08-02 20:55:47 UTC (rev 42971)
+++ grass/trunk/gui/wxpython/gui_modules/render.py	2010-08-02 21:14:01 UTC (rev 42972)
@@ -41,7 +41,6 @@
 import globalvar
 import utils
 import gcmd
-from gcmd import GException
 from debug import Debug as Debug
 from preferences import globalSettings as UserSettings
@@ -623,7 +622,7 @@
                 message = _("Unable to get current geographic extent. "
                             "Force quiting wxGUI. Please run manually g.region to "
                             "fix the problem.")
-            GError(message)
+            gcmd.GError(message)
             return self.region
         for reg in ret.splitlines():
@@ -1034,8 +1033,8 @@
             layer.SetOpacity(kargs['opacity'])
         if render and not layer.Render():
-            raise GException(_("Unable to render map layer <%s>.") %
-                             (name))
+            raise gcmd.GException(_("Unable to render map layer <%s>.") %
+                                  (name))
         return layer
@@ -1143,8 +1142,8 @@
         self.overlays.append(overlay)
         if l_render and command != '' and not overlay.Render():
-            raise GException(_("Unable render overlay <%s>.") %
-                             (name))
+            raise gcmd.GException(_("Unable render overlay <%s>.") %
+                                  (name))
         return self.overlays[-1]
@@ -1182,8 +1181,8 @@
             overlay.SetOpacity(kargs['opacity'])
         if render and command != [] and not overlay.Render():
-            raise GException(_("Unable render overlay <%s>") %
-                             (name))
+            raise gcmd.GException(_("Unable render overlay <%s>") %
+                                  (name))
         return overlay
