[GRASS-SVN] r42993 - grass/trunk/db/db.connect
Wed Aug 4 07:10:54 EDT 2010
Author: martinl
Date: 2010-08-04 11:10:54 +0000 (Wed, 04 Aug 2010)
New Revision: 42993
   grass/trunk/db/db.connect/main.c
db.connect: new 'd' flag (set from default settings)
Modified: grass/trunk/db/db.connect/main.c
--- grass/trunk/db/db.connect/main.c	2010-08-04 10:54:10 UTC (rev 42992)
+++ grass/trunk/db/db.connect/main.c	2010-08-04 11:10:54 UTC (rev 42993)
@@ -7,8 +7,9 @@
  *               Glynn Clements <glynn gclements.plus.com>,
  *               Markus Neteler <neteler itc.it>,
  *               Hamish Bowman <hamish_b yahoo com>
+ *               Martin Landa <landa.martin gmail.com> ('d' flag)
  * PURPOSE:      set parameters for connection to database
- * COPYRIGHT:    (C) 2002-2009 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2002-2010 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -30,13 +31,12 @@
 int main(int argc, char *argv[])
     dbConnection conn;
-    struct Flag *print, *check_set_default;
+    struct Flag *print, *check_set_default, *def;
     /*    struct Option *driver, *database, *user, *password, *keycol; */
     struct Option *driver, *database, *schema, *group;
     struct GModule *module;
     /* Initialize the GIS calls */
     G_gisinit(argv[0]);
@@ -46,9 +46,8 @@
     G_add_keyword(_("attribute table"));
     G_add_keyword(_("connection settings"));
     module->description =
-	_("Prints/sets general DB connection for current mapset and exits.");
+	_("Prints/sets general DB connection for current mapset.");
     print = G_define_flag();
     print->key = 'p';
     print->description = _("Print current connection parameters and exit");
@@ -58,7 +57,13 @@
     check_set_default->key = 'c';
     check_set_default->description =
 	_("Check connection parameters, set if uninitialized, and exit");
-    check_set_default->guisection = _("Print");
+    check_set_default->guisection = _("Set");
+    def = G_define_flag();
+    def->key = 'd';
+    def->label = _("Set from default settings and exit");
+    def->description = _("Overwrite current settings if initialized");
+    def->guisection = _("Set");
     driver = G_define_standard_option(G_OPT_DB_DRIVER);
     driver->options = db_list_drivers();
@@ -102,7 +107,6 @@
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
     if (print->answer) {
 	/* get and print connection */
 	if (db_get_connection(&conn) == DB_OK) {
@@ -121,7 +125,6 @@
 	exit(EXIT_SUCCESS);
     if (check_set_default->answer) {
 	/* check connection and set to system-wide default in required */
@@ -153,6 +156,16 @@
+    if (def->answer) {
+	db_set_default_connection();
+	db_get_connection(&conn);
+	G_important_message(_("Default driver / database set to:\n"
+			      "driver: %s\ndatabase: %s"), conn.driverName,
+			    conn.databaseName);
+	exit(EXIT_SUCCESS);
     /* set connection */
     db_get_connection(&conn);	/* read current */
