[GRASS-SVN] r43014 - in grass/branches/develbranch_6: include lib/gis
Sat Aug 7 15:19:01 EDT 2010
Author: martinl
Date: 2010-08-07 19:19:01 +0000 (Sat, 07 Aug 2010)
New Revision: 43014
   grass/branches/develbranch_6/include/gisdefs.h
   grass/branches/develbranch_6/lib/gis/error.c
   grass/branches/develbranch_6/lib/gis/percent.c
backport G_set/unset_percent_routine() from trunk (used by wxnviz)
Modified: grass/branches/develbranch_6/include/gisdefs.h
--- grass/branches/develbranch_6/include/gisdefs.h	2010-08-07 19:17:15 UTC (rev 43013)
+++ grass/branches/develbranch_6/include/gisdefs.h	2010-08-07 19:19:01 UTC (rev 43014)
@@ -904,6 +904,8 @@
 int G_percent(long, long, int);
 int G_percent2(long, long, int, FILE *);
 int G_percent_reset(void);
+void G_set_percent_routine(int (*) (int));
+void G_unset_percent_routine(void);
 /* plot.c */
 int G_setup_plot(double, double, double, double, int (*)(int, int),
Modified: grass/branches/develbranch_6/lib/gis/error.c
--- grass/branches/develbranch_6/lib/gis/error.c	2010-08-07 19:17:15 UTC (rev 43013)
+++ grass/branches/develbranch_6/lib/gis/error.c	2010-08-07 19:19:01 UTC (rev 43014)
@@ -263,7 +263,7 @@
     else			/* WARN */
 	fatal = FALSE;
-    if ((type == WARN || type == ERR) && ext_error) {	/* Function defined by application */
+    if ((type == MSG || type == WARN || type == ERR) && ext_error) {	/* Function defined by application */
 	ext_error(msg, fatal);
     else {
Modified: grass/branches/develbranch_6/lib/gis/percent.c
--- grass/branches/develbranch_6/lib/gis/percent.c	2010-08-07 19:17:15 UTC (rev 43013)
+++ grass/branches/develbranch_6/lib/gis/percent.c	2010-08-07 19:19:01 UTC (rev 43014)
@@ -1,17 +1,15 @@
- * \file percent.c
+ * \file gis/percent.c
  * \brief GIS Library - percentage progress functions.
- * (C) 2001-2008 by the GRASS Development Team
+ * (C) 2001-2008, 2010 by the GRASS Development Team
  * This program is free software under the GNU General Public License
  * (>=v2). Read the file COPYING that comes with GRASS for details.
  * \author GRASS GIS Development Team
- * \date 1999-2008
 #include <stdio.h>
@@ -21,6 +19,7 @@
 static int prev = -1;
 static int first = 1;
+static int (*ext_percent) (int);
  * \brief Print percent complete messages.
@@ -97,35 +96,42 @@
     if (n <= 0 || n >= d || x > prev + s) {
 	prev = x;
-	if (format == G_INFO_FORMAT_STANDARD) {
-	    if (out != NULL) {
-		fprintf(out, "%4d%%\b\b\b\b\b", x);
+	if (ext_percent) {
+	    ext_percent(x);
 	else {
-	    if (format == G_INFO_FORMAT_PLAIN) {
+	    if (format == G_INFO_FORMAT_STANDARD) {
 		if (out != NULL) {
-		    if (x == 100)
-			fprintf(out, "%d\n", x);
-		    else
-			fprintf(out, "%d..", x);
+		    fprintf(out, "%4d%%\b\b\b\b\b", x);
-	    else {		/* GUI */
-		    if (first) {
-			fprintf(out, "\n");
+	    else {
+		if (format == G_INFO_FORMAT_PLAIN) {
+		    if (out != NULL) {
+			if (x == 100)
+			    fprintf(out, "%d\n", x);
+			else
+			    fprintf(out, "%d..", x);
-		    fprintf(out, "GRASS_INFO_PERCENT: %d\n", x);
-		    fflush(out);
-		first = 0;
+		else {		/* GUI */
+			if (first) {
+			    fprintf(out, "\n");
+			fprintf(out, "GRASS_INFO_PERCENT: %d\n", x);
+			fflush(out);
+		    first = 0;
     if (x >= 100) {
+	    ext_percent(100);
+	else if (format == G_INFO_FORMAT_STANDARD) {
 	    if (out != NULL) {
 		fprintf(out, "\n");
@@ -137,7 +143,6 @@
     return 0;
  * \brief Reset G_percent() to 0%; do not add newline.
@@ -151,3 +156,25 @@
     return 0;
+ * \brief Establishes percent_routine as the routine that will handle
+ * the printing of percentage progress messages.
+ * \param percent_routine routine will be called like this: percent_routine(x)
+void G_set_percent_routine(int (*percent_routine) (int))
+    ext_percent = percent_routine;
+ * \brief After this call subsequent percentage progress messages will
+ * be handled in the default method.
+ * Percentage progress messages are printed directly to stderr.
+    ext_percent = NULL;
