[GRASS-SVN] r43074 - grass/trunk/lib/vector/Vlib
Thu Aug 12 13:23:46 EDT 2010
Author: mmetz
Date: 2010-08-12 17:23:46 +0000 (Thu, 12 Aug 2010)
New Revision: 43074
   grass/trunk/lib/vector/Vlib/cindex.c
avoid struct stat
Modified: grass/trunk/lib/vector/Vlib/cindex.c
--- grass/trunk/lib/vector/Vlib/cindex.c	2010-08-12 17:23:15 UTC (rev 43073)
+++ grass/trunk/lib/vector/Vlib/cindex.c	2010-08-12 17:23:46 UTC (rev 43074)
@@ -490,7 +490,6 @@
     char buf[500], file_path[2000];
     struct gvfile fp;
     struct Plus_head *Plus;
-    struct stat info;
     G_debug(2, "Vect_cidx_open(): name = %s mapset= %s", Map->name,
 	    Map->mapset);
@@ -500,7 +499,7 @@
     sprintf(buf, "%s/%s", GV_DIRECTORY, Map->name);
     G__file_name(file_path, buf, GV_CIDX_ELEMENT, Map->mapset);
-    if (stat(file_path, &info) != 0)	/* does not exist */
+    if (access(file_path, F_OK) != 0)	/* does not exist */
 	return 1;
