[GRASS-SVN] r43077 - grass/trunk/lib/db/dbmi_base
Thu Aug 12 13:52:44 EDT 2010
Author: mmetz
Date: 2010-08-12 17:52:44 +0000 (Thu, 12 Aug 2010)
New Revision: 43077
   grass/trunk/lib/db/dbmi_base/login.c
avoid struct stat
Modified: grass/trunk/lib/db/dbmi_base/login.c
--- grass/trunk/lib/db/dbmi_base/login.c	2010-08-12 17:39:39 UTC (rev 43076)
+++ grass/trunk/lib/db/dbmi_base/login.c	2010-08-12 17:52:44 UTC (rev 43077)
@@ -81,7 +81,6 @@
     int ret;
     const char *file;
-    struct stat info;
     FILE *fd;
     char buf[2001], dr[500], db[500], usr[500], pwd[500];
@@ -90,7 +89,7 @@
     G_debug(3, "DB login file = <%s>", file);
-    if (stat(file, &info) != 0) {
+    if (access(file, F_OK) != 0) {
 	G_debug(3, "login file does not exist");
 	return 0;
