[GRASS-SVN] r43088 - grass/trunk/scripts/g.extension
Fri Aug 13 06:17:12 EDT 2010
Author: martinl
Date: 2010-08-13 10:17:12 +0000 (Fri, 13 Aug 2010)
New Revision: 43088
   grass/trunk/scripts/g.extension/g.extension.py
g.extension: fix remove option when module is not available
add new flag to avoid removing downloaded source code
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py	2010-08-13 08:22:39 UTC (rev 43087)
+++ grass/trunk/scripts/g.extension/g.extension.py	2010-08-13 10:17:12 UTC (rev 43088)
@@ -79,6 +79,10 @@
 #% description: List available modules in the add-ons repository in shell script style
 #% guisection: Print
 #%end
+#%flag
+#% key: d
+#% description: Don't deleted downloaded source code when installing new extension
+#%end
 import os
 import sys
@@ -90,6 +94,7 @@
 from grass.script import core as grass
 # temp dir
+remove_tmpdir = True
 tmpdir = grass.tempfile()
 grass.try_remove(tmpdir)
 os.mkdir(tmpdir)
@@ -241,9 +246,12 @@
     return ret
 def cleanup():
-    global tmpdir
-    grass.try_rmdir(tmpdir)
+    global tmpdir, remove_tmpdir
+    if remove_tmpdir:
+        grass.try_rmdir(tmpdir)
+    else:
+        grass.info(_("Path to the source code: '%s'") % tmpdir)
 def install_extension(svnurl, prefix, module):
     gisbase = os.getenv('GISBASE')
     if not gisbase:
@@ -295,8 +303,8 @@
 def remove_extension(prefix, module):
     # is module available?
-    if not grass.find_program(module):
-        grass.fatal(_("'%s' not found") % module)
+    if not os.path.exists(os.path.join(prefix, 'bin', module)):
+        grass.fatal(_("Module '%s' not found") % module)
     for file in [os.path.join(prefix, 'bin', module),
                  os.path.join(prefix, 'scripts', module),
@@ -337,6 +345,13 @@
         grass.warning(_("'%s' created") % options['prefix'])
+    if flags['d']:
+        if options['operation'] != 'add':
+            grass.warning(_("Flag 'd' is relevant only to 'operation=add'. Ignoring this flag."))
+        else:
+            global remove_tmpdir
+            remove_tmpdir = False
     if options['operation'] == 'add':
         install_extension(options['svnurl'], options['prefix'], options['extension'])
     else: # remove
