[GRASS-SVN] r43119 - grass/trunk/include
Sun Aug 15 07:08:34 EDT 2010
Author: mmetz
Date: 2010-08-15 11:08:34 +0000 (Sun, 15 Aug 2010)
New Revision: 43119
   grass/trunk/include/config.h.in
LFS for wingrass
Modified: grass/trunk/include/config.h.in
--- grass/trunk/include/config.h.in	2010-08-14 22:29:37 UTC (rev 43118)
+++ grass/trunk/include/config.h.in	2010-08-15 11:08:34 UTC (rev 43119)
@@ -259,8 +259,11 @@
  * Defines needed to get large file support - from cdrtools-2.01
-#ifdef	USE_LARGEFILES
+#undef	HAVE_LARGEFILES
+#ifdef	HAVE_LARGEFILES		/* If we have working largefiles at all	   */
+				/* This is not defined with glibc-2.1.3	   */
 #undef _FILE_OFFSET_BITS	/* # of bits in off_t if settable	   */
 #undef _LARGEFILE_SOURCE	/* To make ftello() visible (HP-UX 10.20). */
 #undef _LARGE_FILES		/* Large file defined on AIX-style hosts.  */
@@ -275,13 +278,54 @@
 #if defined(__MINGW32__) && defined(_FILE_OFFSET_BITS) && _FILE_OFFSET_BITS == 64
 /* add/remove as needed */
+/* no old names for sys/types.h */
+#define	_NO_OLDNAMES
+/* but... */
+#define pid_t _pid_t
+/* ...and these old names from fcntl.h: */
+#define O_RDONLY	_O_RDONLY
+#define O_WRONLY	_O_WRONLY
+#define O_RDWR		_O_RDWR
+#define O_ACCMODE	_O_ACCMODE
+#define O_APPEND	_O_APPEND
+#define O_CREAT		_O_CREAT
+#define O_TRUNC		_O_TRUNC
+#define O_EXCL		_O_EXCL
+#define O_TEXT		_O_TEXT
+#define O_BINARY	_O_BINARY
+#define O_TEMPORARY	_O_TEMPORARY
+#define O_NOINHERIT	_O_NOINHERIT
+#define O_SEQUENTIAL	_O_SEQUENTIAL
+#define O_RANDOM	_O_RANDOM
+/* ...and these old names from stat.h */
+#define S_IFIFO		_S_IFIFO
+#define S_IFCHR		_S_IFCHR
+#define S_IFBLK		_S_IFBLK
+#define S_IFDIR		_S_IFDIR
+#define S_IFREG		_S_IFREG
+#define S_IFMT		_S_IFMT
+#define S_IEXEC		_S_IEXEC
+#define S_IWRITE	_S_IWRITE
+#define S_IREAD		_S_IREAD
+#define S_IRWXU		_S_IRWXU
+#define S_IXUSR		_S_IXUSR
+#define S_IWUSR		_S_IWUSR
+#define S_IRUSR		_S_IRUSR
+#define S_ISDIR(m)	(((m) & S_IFMT) == S_IFDIR)
+#define S_ISFIFO(m)	(((m) & S_IFMT) == S_IFIFO)
+#define S_ISCHR(m)	(((m) & S_IFMT) == S_IFCHR)
+#define S_ISBLK(m)	(((m) & S_IFMT) == S_IFBLK)
+#define S_ISREG(m)	(((m) & S_IFMT) == S_IFREG)
 #define off_t off64_t
-#define HAVE_FSEEKO
 #define fseeko fseeko64
 #define ftello ftello64
 #define lseek lseek64
-#define stat stat64
-#define fstat fstat64
+/* use _stati64 compatible with MSVCRT < 6.1 */
+#define stat _stati64
+#define fstat _fstati64
 typedef struct _stati64 STRUCT_STAT;
 #else
 typedef struct stat STRUCT_STAT;
@@ -289,7 +333,7 @@
 #else
-#endif	/* USE_LARGEFILES */
+#endif	/* HAVE_LARGEFILES */
 /* define if langinfo.h exists */
 #undef HAVE_LANGINFO_H
